2008-10-09[ARM] 5239/1: Palm Zire 72 power management supportSergey Lapin
This patch contains Palm Zire 72 power management support. Depends on #5238/1 Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: allow multi-machine PCMCIA buildsRussell King
2008-10-07[ARM] pxa: add preliminary CPUFREQ support for PXA3xxEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.hEric Miao
2008-10-07[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.cEric Miao
2008-10-07[ARM] pxa/zylonite: add support for USB OHCIEric Miao
2008-10-07[ARM] ohci-pxa27x: use ioremap() and offset for register accessEric Miao
This avoid the pre-mapping of OHCI controller register space, and the mapping is made only when necessary (OHCI is probed). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: introduce pxa27x_clear_otgph()Eric Miao
Direct access to pxa27x specific register PSSR in a generic ohci driver is no good, introduce pxa27x_clear_otgph() and move the implementation into processor specific code. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resourceEric Miao
Depending on the order of how resource is defined in the platform device is not good, use platform_get_{irq,resource} for the IRQ and memory resources. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: move OHCI controller specific registers into the driverEric Miao
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: simplify DMA register definitionsEric Miao
1. DRCMRxx is no longer recommended, use DRCMR(xx) instead, and pass DRCMR index by "struct resource" if possible 2. DCSRxx, DDADRxx, DSADRxx, DTADRxx, DCMDxx is never used, use DCSR(), DDADR(), DSADR(), DTADR(), DCMD() instead Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: make additional DCSR bits valid for PXA3xxEric Miao
2008-10-07[ARM] pxa: move i2c register and bit definitions into i2c-pxa.cEric Miao
2008-10-07[ARM] pxa: fix incorrect initialization of mfp sysdev when not pxa2xxEric Miao
The initialization of mfp sysdev in pxa2xx_mfp_init() shall really be avoided when !cpu_is_pxa2xx(). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07Merge branches 'pxa-core' and 'pxa-machines' into pxa-allRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c
2008-10-07Merge branch 'for_rmk' of git://git.mnementh.co.uk/linux-2.6-imRussell King
Merge branch 'pxa-eseries' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile
2008-10-07Merge branch 'viper-for-rmk' of git://www.misterjones.org/linux-2.6-armRussell King
Merge branch 'pxa-viper' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile drivers/pcmcia/Kconfig drivers/pcmcia/Makefile
2008-10-07Merge branch 'pxa-palm' into pxa-machinesRussell King
Conflicts: drivers/mfd/Kconfig drivers/pcmcia/Makefile
2008-10-07Merge branch 'pxa-trizeps' into pxa-machinesRussell King
Conflicts: drivers/pcmcia/Makefile
2008-10-07Merge branches 'metronomefb', 'pxa-cm2xx', 'pxa-gumstix', 'pxa-misc', ↵Russell King
'pxa-mitac', 'pxa-mp900', 'pxa-zylonite' and 'pxa-zaurus' into pxa-machines Conflicts: arch/arm/mach-pxa/poodle.c
2008-10-07[ARM] pxa: trizeps4: remove unused variableRussell King
2008-10-07[ARM] 5285/1: pxa: update xm_x2xx_defconfigMike Rapoport
Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5284/1: pxa: cm-x255: add NOR and NAND flash supportMike Rapoport
This patch adds support for NOR and NAND flashes on CM-X255. The NAND flash support uses not yet merged GPIO NAND driver. Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5283/1: pxa: add CM-X255 pcmcia supportMike Rapoport
2008-10-07[ARM] 5282/1: pxa: add CM-X255 supportMike Rapoport
2008-10-07[ARM] 5281/1: pxa: split cm-x2xx.c to cm-x2xx.c and cm-x270.cMike Rapoport
2008-10-07[ARM] 5280/1: pxa: prepare cm-x2xx.c and cm-x2xx-pci.[ch] for addition of ↵Mike Rapoport
CM-X255 - Change CM-X255 and CM-X270 common function prefix from cmx270 to cmx2xx - Split cmx2xx_init to common and CM-X270-specific parts - Use dynamic assignement for DM9000 resources and led GPIOs. Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5286/2: pxa: rename cm-x270* to cm-x2xx* to allow addition of cm-x255 ↵Mike Rapoport
support Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5294/1: Trizeps4 PCMCIA supportJürgen Schindele
Support for Trizeps4 SOM PCMCIA with ConXS or other baseboards. with double GPIO-free fixed (sorry!) replaces 5279/1 Signed-off-by: Jurgen Schindele <linux@schindele.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-03[ARM] 5278/1: i2c-pxa fast mode supportJonathan Cameron
Add fast_mode option to i2c_pxa_platform_data and use it to set the ICR_FM bit appropriately when i2c_pxa_reset is called. Parameter called fast_mode rather than frequency as this driver is also used for the i2c_pxa_pwr bus which has different normal and fast frequencies. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-03[ARM] 4733/1: export sharpsl_paramDmitry Baryshkov
EXPORT sharpsl_param which is necessary to support modular build of some depending drivers. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-02[ARM] 5277/1: Add basic support for MobilePro 900/cKristoffer Ericson
This patch adds basic support for the Mobilepro 900/c mini-laptop. At present it won't do much more than build and boot. Signed-off-by: Kristoffer Ericson <Kristoffer.Ericson@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-02[ARM] 5248/1: wm97xx generic battery driverMarek Vašut
This patch adds generic battery driver for wm97xx chips. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] 5251/1: remove old LED support for Trizeps4 SOMJürgen Schindele
Remove the old led support in arch/arm/mach-pxa/leds... for TRIZEPS4 SOM. It is / will be replaced by generic led driver drivers/leds/... Signed-off-by: Jürgen Schindele <linux@schindele.name> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] 5204/1: Trizeps4 SOM updateJürgen Schindele
- use MFP-API for GPIO - support TRIZEPS4WL module - cleanups Signed-off-by: Jrgen Schindele <linux@schindele.name> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa: make "gpio_leds" staticRussell King
Magician's "gpio_leds" was global, but actually is supposed to be private. Make it so. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa/pcm027: convert to use new MFP APIEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa/lpd270: use new .lcd_conn to specify LCD infoEric Miao
2008-09-26[ARM] pxa/lpd270: convert to use new MFP APIEric Miao
2008-09-26[ARM] pxa/idp: remove the unnecessary idp_init_irq()Eric Miao
TOUCH_PANEL_IRQ is never referenced, and set_irq_type() shouldn't be called in this way, remove it, as well as the idp_init_irq(), and use pxa25x_init_irq() instead. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Cliff Brake <cliff.brake@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa/idp: make use of "lcd_conn", add LCD pin configurationsEric Miao
2008-09-26[ARM] pxa/idp: convert to use new MFP APIEric Miao
2008-09-26[ARM] pxa/colibri: convert to use new MFP APIEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa/lubbock: add missing MFP pin configurationsEric Miao
2008-09-26[ARM] pxa: better MFP low power state support for pxa25x/pxa27xEric Miao
When configured as a specific low power state: MFP_LPM_DRIVE_LOW, MFP_LPM_DRIVE_HIGH, the corresponding GPDR register bit during low power mode shall be re-configured as output (if they are not configured so), thus the PGSRx bits can output. Create an additional low power values GPDR registers, and properly save/restore the GAFR + GPDR registers when doing suspend/resume. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-26[ARM] pxa: fix typo in pxa25x MFP definitionsEric Miao
2008-09-26[ARM] 5238/2: Very basic Palm Zire 72 supportSergey Lapin
This patch contains very basic support of Palm Zire 72. Signed-off-by: Sergey Lapin <slapin@ossfans.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
