git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next
net/bluetooth/l2cap_sock.c
net/bluetooth/mgmt.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
Now that pending commands are hci_dev specific there's no need to check
whether a command matches hci_dev when iterating through them.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
For consistency the integer type should be u16 and not __u16.
The cancel_delayed_work_sync function should not be used if we hold any
locks. Luckily all places where this is the case it is also safe to use
the non-sync version.
Now that the pending commands are within struct hci_dev we can properly
control access to them throught the hci_dev locking mechanism.
This patch moves the pending management command list (previously global
to mgmt.c) into struct hci_dev. This makes it possible to do proper
locking when accessing it (through the existing hci_dev locks) and
thereby avoid race conditions.
The current global pending command list in mgmt.c is racy. Possibly the
simplest way to fix it is to have per-hci dev lists instead of a global
one (all commands that need a pending struct are hci_dev specific).
This way the list can be protected using the already existing per-hci
dev lock. To enable this refactoring the first thing that needs to be
done is to ensure that the mgmt functions have access to the hci_dev
struct (instead of just the dev id).
Signed-off-by: Thomas Pedersen <thomas@cozybit.com>
Signed-off-by: Ashok Nagarajan <anagar6@uic.edu>
Set peer's HT capabilities, and disallow peering if we're on a different
channel type.
Some refactoring for IBSS HT.
Move HT info and capability IEs building code into separate functions.
Add function to get the channel type from an HT info IE.
Signed-off-by: Alexander Simon <an.alexsimon@googlemail.com>
Remove most references to magic numbers, save a few bytes and hopefully
improve readability.
The initval tables are updated as per system team input to improve
rx performance and power accuracy at 5GHz.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
AR9462 chips have the capabilities to provoide bluetooth
profile information. For non-AR9462 btcoex chips, the BT
priority traffic was identified by periodically polling
the respective registers and updated dutycycle, stomptype,
etc. As AR9462 chip offers the BT profile informations,
let us make use of that to update aggregation limit,
dutycycle, stomptype and wieghtages.
To improve CCK sensitivity for AR9462 chips, performing
spur mitigation at 2440, 2464 frequencies alone is sufficient.
Signed-off-by: Jouni Malinen <j@w1.fi>
Some cards can generate CCMP IVs in HW, but require the space for the IV
to be pre-allocated in the frame at the correct offset. Add a key flag
that allows us to achieve this.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
genlmsg_end() cannot fail, it just returns the length
of the message. Thus, error handling for it is useless.
While removing it, I also noticed a useless variable
and removed this it as well.
The buffer endianess conversion functions in srom.c had a size
argument giving number of bytes but the function converts words.
Providing the number of words to the function is more sensible
so that is done in this patch.
Reported-by: Pavel Roskin <proski@gnu.org>
Reported-by: Larry Finger <Larry.Finger@lwfinger.net>
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Alwin Beukers <alwin@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
The usage of state decrease readability. Optimize the code flow to
get rid of it
Reviewed-by: Roland Vossen <rvossen@broadcom.com>
Reviewed-by: Arend van Spriel <arend@broadcom.com>
Make a proper use of private data area of net device by storing
interface related data structure instead of generic driver data
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Use brcmf_add_if for primary and virtual net device interfaces. This
is part of the net device interface clean up for fullmac.
In the receive path the frames are obtained from the dma using
multiple sk_buff that were linked using the skb next pointer.
This has been changed and it now used sk_buff lists and skb_queue
functions instead.
The functions ltoh16_buf() and htol16_buf() have been renamed
to le16_to_cpu_buf() and cpu_to_le16_buf() for more clarity
what it does.
Reported-by: Joe Perches <joe@perches.com>
The driver currently only supports STA operation. However, in
brcms_ops_add_interface() also AP and SSID mode were accepted.
Signed-off-by: Roland Vossen <rvossen@broadcom.com>
Monitor mode functionality (not functional yet) requires transmit to be
muted after ops_start() is called, transmit is unmuted when the first
interface is added.
Upon ops_start(), a Mac80211 driver should enable receive functionality to
support monitor mode. Also, upon ops_stop(), it should disable rx.
Driver did not follow this rule so code has been changed.
Transmit was muted in two ways: full mute and a partial mute called
'pre ism cac time' mute. But, this 'pre ism cac time' mute was done at
one place in the code (when tx_mute == false), and overridden later
on in another place in code.
To fix this, the 'pre ism cac time' mute has been replaced by a non
mute.
Transmit can only be muted if the mac core is enabled. When brcms_b_init()
is called, the mac core is suspended. Brcms_b_init() calls a transmit mute
function that requires an enabled mac core. This code path is never taken,
but would have been taken in subsequent patches.
Softmac would bring its interface down on an RF kill switch condition,
without Mac80211 intervention. Because Mac80211 should be the only party
initiating interfaces going up and down, this functionality has been
removed.
Softmac would bring its interface down on a certain Minimum Power Save
related condition, without Mac80211 intervention. Because Mac80211 should
be the only party initiating interfaces going up and down, this functionality
has been removed. All notions of 'MPC' have been removed in the code as
well.
Several member variables were never read.
The chip init sequence enables MPC (Minimum Power Consumption), but the
driver disables it after that. As there are no interfaces to enable this
mode the related code is unused (member variable wlc->mpc is false).
Use brcmf_del_if for primary and virtual net device interfaces. This
Watchdog timer should be able to be stopped even firmware is not
loaded.
If there are no cooked monitor interfaces, there's
no point in building the radiotap RX header for the
frame and iterating the interface list.
The functions in the receive patch of the fullmac now use sk_buff
list and skb_queue_xx() functions instead of dealing with list pointers
in the sk_buff directly.
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
The latest vendor (non-mac80211) driver of 9/22/2011 shows some new
device IDs for rtl8192cu. In addition, some typos in the table are
fixed and one duplicate is removed.
The function brcmu_format_hex() filled a string buffer with byte
values from a data buffer. The calling function used this string
buffer in a printk. Now the calling function uses the kernel
function print_hex_dump_bytes().
The function brcmu_pktfrombuf was only used in the brcmfmac source
and has been moved there. It has been refactored to match its use.
Obviously the phy api should be used to interface with the phy. In
rate.h a table within phy was accessed directly by declaring the
table extern in rate.h itself. This patch fixes this using the
provided api function to obtain the table reference. This bypass
was found by a sparse warning on the table not being defined static.
In main.c a couple of functions were not static although they
were only locally used. Sparse gave warnings on them and these
functions have been made static.
The data from the sprom consists of u16 values stored in little
endian notation over which a crc8 was determined. To validate this
the buffer needed to be converted for big-endian systems. Reading
the sprom data is now done per byte so conversion is only done
after a successful crc8 check.
The n-phy requested some srom variables that are no longer needed
and consequently not present in the srom revision 8 and higher that
this driver support. This code has been removed from the n-phy.
In case the hardware crashes, a reinitialization internal to the driver
was performed. Since Mac80211 must be in the know of such an event as
well, ieee80211_restart_hw() is now called.
struct brcmf_scan_results contained a 1 element array, but in reality
the number of scan results can be 0 or more, as indicated by the
count field in the same struct. Array has be redefined to be 0 elements
length to indicate the array is purely for reference.
Moved function to where it is called and made it more readable.
Made code more readable.
