2009-01-22x86 PAT: ioremap_wc should take resource_size_t parametervenkatesh.pallipadi@intel.com
Impact: fix/extend ioremap_wc() beyond 4GB aperture on 32-bit ioremap_wc() was taking in unsigned long parameter, where as it should take 64-bit resource_size_t parameter like other ioremap variants. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ehca: Use consistent types for ehca_plpar_hcall9() IB/ehca: Fix printk format warnings from u64 type change IPoIB: Do not print error messages for multicast join retries IB/mlx4: Fix memory ordering problem when posting LSO sends mlx4_core: Fix min() warning IPoIB: Fix deadlock between ipoib_open() and child interface create IPoIB: Fix hang in napi_disable() if P_Key is never found
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: move wm8400-regulator's probe function to .devinit.text
2009-01-17dell_rbu: use scnprintf() instead of less secure sprintf()Pavel Roskin
Reading 0 bytes from /sys/devices/platform/dell_rbu/image_type or /sys/devices/platform/dell_rbu/packet_size by an ordinary user causes an oops. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-17security: introduce missing kfreeVegard Nossum
Plug this leak. Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <stable@kernel.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-17move wm8400-regulator's probe function to .devinit.textUwe Kleine-König
A pointer to wm8400_regulator_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-01-16Merge branches 'ehca', 'ipoib' and 'mlx4' into for-linusRoland Dreier
2009-01-16IB/ehca: Use consistent types for ehca_plpar_hcall9()Stephen Rothwell
ehca_plpar_hcall9() takes an unsigned long array, so make all callers pass that in. This fixes warnings introduced by commit fe333321 ("powerpc: Change u64/s64 to a long long integer type"), which changed u64 from unsigned long to unsigned long long. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-01-16IB/ehca: Fix printk format warnings from u64 type changeStephen Rothwell
Commit fe333321 ("powerpc: Change u64/s64 to a long long integer type") changed u64 from unsigned long to unsigned long long, which means that printk formats for printing u64 values should use "ll" instead of "l" to avoid warnings. Fix all the places affected by this in ehca. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-01-16IPoIB: Do not print error messages for multicast join retriesYossi Etigin
When IPoIB tries to join a multicast group, and the SA module's SM address handle is NULL (because of an SM change, etc), the join returns with -EAGAIN status. In that case, don't print an error message unless multicast debugging is enabled. Signed-off-by: Yossi Etigin <yosefe@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-01-16IB/mlx4: Fix memory ordering problem when posting LSO sendsRoland Dreier
The current work request posting code writes the LSO segment before writing any data segments. This leaves a window where the LSO segment overwrites the stamping in one cacheline that the HCA prefetches before the rest of the cacheline is filled with the correct data segments. When the HCA processes this work request, a local protection error may result. Fix this by saving the LSO header size field off and writing it only after all data segments are written. This fix is a cleaned-up version of a patch from Jack Morgenstein <jackm@dev.mellanox.co.il>. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1383>. Reported-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-01-16Linux 2.6.29-rc2v2.6.29-rc2Linus Torvalds
2009-01-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits) ACPI PCI hotplug: harden against panic regression ACPI: rename main.c to sleep.c dell-laptop: move to drivers/platform/x86/ from drivers/misc/ eeepc-laptop: enable Bluetooth ACPI details ACPI: fix ACPI_FADT_S4_RTC_WAKE comment kprobes: check CONFIG_FREEZER instead of CONFIG_PM PM: Fix freezer compilation if PM_SLEEP is unset thermal fixup for broken BIOS which has invalid trip points. ACPI: EC: Don't trust ECDT tables from ASUS ACPI: EC: Limit workaround for ASUS notebooks even more ACPI: thinkpad-acpi: bump up version to 0.22 ACPI: thinkpad-acpi: handle HKEY event 6030 ACPI: thinkpad-acpi: clean-up fan subdriver quirk ACPI: thinkpad-acpi: start the event hunt season ACPI: thinkpad-acpi: handle HKEY thermal and battery alarms ACPI: thinkpad-acpi: clean up hotkey_notify() ACPI: thinkpad-acpi: use killable instead of interruptible mutexes ACPI: thinkpad-acpi: add UWB radio support ACPI: thinkpad-acpi: preserve radio state across shutdown ACPI: thinkpad-acpi: resume with radios disabled ...
2009-01-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netxen: include ipv6.h (fixes build failure) netxen: avoid invalid iounmap
2009-01-16ACPI PCI hotplug: harden against panic regressionJames Bottomley
ACPI hotplug panic with current git head http://lkml.org/lkml/2009/1/10/136 Rather than reverting the entire commit that causes the crash: e8c331e963c58b83db24b7d0e39e8c07f687dbc6 "PCI hotplug: introduce functions for ACPI slot detection" simply harden against it while the changes to the hotplug code on this particularl machine are understood. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16Merge branch 'misc' into releaseLen Brown
2009-01-16Merge branch 'thinkpad-acpi' into releaseLen Brown
2009-01-16Merge branches 'bugzilla-11884' and 'bugzilla-8544' into releaseLen Brown
2009-01-16ACPI: rename main.c to sleep.cLen Brown
2009-01-16dell-laptop: move to drivers/platform/x86/ from drivers/misc/Len Brown
2009-01-16eeepc-laptop: enable Bluetooth ACPI detailsJonathan McDowell
Although rfkill support for the EEE bluetooth device has been added to 2.6.28-rc the appropriate ACPI accessor definitions were not added, so the support was non functional. The patch below adds the get and set accessors and has been verified to work on an EEE 901. Signed-off-by: Jonathan McDowell <noodles@earth.li> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16ACPI: fix ACPI_FADT_S4_RTC_WAKE commentDavid Brownell
Make the comment for ACPI_FADT_S4_RTC_WAKE match the ACPI spec; that bit has nothing to do with status bits. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16kprobes: check CONFIG_FREEZER instead of CONFIG_PMMasami Hiramatsu
Check CONFIG_FREEZER instead of CONFIG_PM because kprobe booster depends on freeze_processes() and thaw_processes() when CONFIG_PREEMPT=y. This fixes a linkage error which occurs when CONFIG_PREEMPT=y, CONFIG_PM=y and CONFIG_FREEZER=n. Reported-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16PM: Fix freezer compilation if PM_SLEEP is unsetRafael J. Wysocki
Freezer fails to compile if with the following configuration settings: CONFIG_CGROUPS=y CONFIG_CGROUP_FREEZER=y CONFIG_MODULES=y CONFIG_FREEZER=y CONFIG_PM=y CONFIG_PM_SLEEP=n Fix this by making process.o compilation depend on CONFIG_FREEZER. Reported-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16thermal fixup for broken BIOS which has invalid trip points.Zhang Rui
ACPI thermal driver only re-evaluate VALID trip points. For the broken BIOS show in http://bugzilla.kernel.org/show_bug.cgi?id=8544 the active[0] is set to invalid at boot time and it will not be re-evaluated again. We can still get a single warning message at boot time. http://marc.info/?l=linux-kernel&m=120496222629983&w=2 http://bugzilla.kernel.org/show_bug.cgi?id=12203 Signed-off-by: Zhang Rui<rui.zhang@intel.com> Tested-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16netxen: include ipv6.h (fixes build failure)Dhananjay Phadke
Fixes a build error in absence of CONFIG_IPV6: drivers/net/netxen/netxen_nic_main.c:1189: error: implicit declaration of function 'ipv6_hdr' drivers/net/netxen/netxen_nic_main.c:1189: error: invalid type argument of '->' Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-16ACPI: EC: Don't trust ECDT tables from ASUSAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=9399 http://bugzilla.kernel.org/show_bug.cgi?id=11880 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16netxen: avoid invalid iounmapDhananjay Phadke
For NX3031 only one I/O range is mapped, so unmapping other two which are used by older chips, causes this warning on ppc64. "Attempt to iounmap early bolted mapping at 0x0000000000000000" Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-16ACPI: EC: Limit workaround for ASUS notebooks even moreAlexey Starikovskiy
References: http://bugzilla.kernel.org/show_bug.cgi?id=11884 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix ioctl arg size (userland incompatible change!) Btrfs: Clear the device->running_pending flag before bailing on congestion
2009-01-16Btrfs: fix ioctl arg size (userland incompatible change!)Chris Mason
The structure used to send device in btrfs ioctl calls was not properly aligned, and so 32 bit ioctls would not work properly on 64 bit kernels. We could fix this with compat ioctls, but we're just one byte away and it doesn't make sense at this stage to carry about the compat ioctls forever at this stage in the project. This patch brings the ioctl arg up to an evenly aligned 4k. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-16Btrfs: Clear the device->running_pending flag before bailing on congestionChris Mason
Btrfs maintains a queue of async bio submissions so the checksumming threads don't have to wait on get_request_wait. In order to avoid extra wakeups, this code has a running_pending flag that is used to tell new submissions they don't need to wake the thread. When the threads notice congestion on a single device, they may decide to requeue the job and move on to other devices. This makes sure the running_pending flag is cleared before the job is requeued. It should help avoid IO stalls by making sure the task is woken up when new submissions come in. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2009-01-16Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: serial: Add 16850 uart type support to OF uart driver hvc_console: Remove tty->low_latency powerpc: Get the number of SLBs from "slb-size" property powerpc: is_hugepage_only_range() must account for both 4kB and 64kB slices powerpc/ps3: printing fixups for l64 to ll64 conversion drivers/video powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/scsi powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/ps3 powerpc/ps3: Printing fixups for l64 to ll64 conversion sound/ppc powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/char powerpc/ps3: Printing fixups for l64 to ll64 conversion drivers/block powerpc/ps3: Printing fixups for l64 to ll64 conversion arch/powerpc powerpc/ps3: ps3_repository_read_mm_info() takes u64 * arguments powerpc/ps3: clear_bit()/set_bit() operate on unsigned longs powerpc/ps3: The lv1_ routines have u64 parameters powerpc/ps3: Use dma_addr_t down through the stack powerpc/ps3: set_dabr() takes an unsigned long powerpc: Cleanup from l64 to ll64 change drivers/scsi
2009-01-16Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_fsl: Return non-zero on error in probe() drivers/ata/pata_ali.c: s/isa_bridge/ali_isa_bridge/ to fix alpha build libata: New driver for OCTEON SOC Compact Flash interface (v7). libata: Add another column to the ata_timing table. sata_via: Add VT8261 support pata_atiixp: update port enabledness test handling [libata] get-identity ioctl: Fix use of invalid memory pointer
2009-01-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] Skip deleted devices in __scsi_device_lookup_by_target() [SCSI] Add SUN Universal Xport to no attach blacklist [SCSI] iscsi_tcp: make padbuf non-static [SCSI] mpt fusion: Add Firmware debug support [SCSI] mpt fusion: Add separate msi enable disable for FC,SPI,SAS [SCSI] mpt fusion: Update MPI Headers to version 01.05.19 [SCSI] qla2xxx: Fix ISP restart bug in multiq code
2009-01-16Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: lock correct mutex around object unreference. drm/i915: add support for physical memory objects drm/i915: make LVDS fixed mode a preferred mode drm: handle depth & bpp changes correctly drm: initial KMS config fixes drm/i915: setup sarea properly in master_priv drm/i915: set vblank enabled flag correctly across IRQ install/uninstall drm/i915: don't enable vblanks on disabled pipes
2009-01-16Revert "PCI PM: Register power state of devices during initialization"Linus Torvalds
This reverts commit 98e6e286d7b01deb7453b717aa38ebb69d6cefc0, as Yinghai Lu reports that it breaks kexec with at least the e1000 and e1000e drivers. The reason is that the shutdown sequence puts the hardware into D3 sleep, and the commit causes us to claim that it then is in D0 (running) state just because we don't understand the PM capabilities. Which then later makes "pci_set_power_state()" not do anything, and the device never wakes up properly and just returns 0xff to everything. Reported-by: Yinghai Lu <yinghai@kernel.org> Acked-by: From: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-16sata_fsl: Return non-zero on error in probe()Michal Sojka
while I was looking over kernel sources I've found this small bug. Formerly, zero was returned even if an error happened. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16drivers/ata/pata_ali.c: s/isa_bridge/ali_isa_bridge/ to fix alpha buildAndrew Morton
drivers/ata/pata_ali.c:44: error: static declaration of 'isa_bridge' follows non-static declaration arch/alpha/include/asm/pci.h:274: error: previous declaration of 'isa_bridge' was here Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: New driver for OCTEON SOC Compact Flash interface (v7).David Daney
Cavium OCTEON processor support was recently merged, so now we have this CF driver for your consideration. Most OCTEON variants have *no* DMA or interrupt support on the CF interface so for these, only PIO is supported. Although if DMA is available, we do take advantage of it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: Add another column to the ata_timing table.David Daney
The forthcoming OCTEON SOC Compact Flash driver needs an additional timing value that was not available in the ata_timing table. I add a new column for dmack_hold time. The values were obtained from the Compact Flash specification Rev 4.1. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16sata_via: Add VT8261 supportJosephChan@via.com.tw
Signed-off-by: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16pata_atiixp: update port enabledness test handlingTejun Heo
Port enabledness test fits much better into init_one() instead of pre_reset(). The reason why these tests are in pre_reset() is purely historical at this point. Move it to init_one(). This will help further changes. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16[libata] get-identity ioctl: Fix use of invalid memory pointerJeff Garzik
for SAS drivers. Caught by Ke Wei (and team?) at Marvell. Also, move the ata_scsi_ioctl export to libata-scsi.c, as that seems to be the general trend. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16drm/i915: lock correct mutex around object unreference.Dave Airlie
This makes sure the mutex is held around the unreference. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-01-16drm/i915: add support for physical memory objectsDave Airlie
This is an initial patch to do support for objects which needs physical contiguous main ram, cursors and overlay registers on older chipsets. These objects are bound on cursor bin, like pinning, and we copy the data to/from the backing store object into the real one on attach/detach. notes: possible over the top in attach/detach operations. no overlay support yet. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-01-16drm/i915: make LVDS fixed mode a preferred modeJesse Barnes
The detected fixed panel mode really is preferred, so mark it as such and add it to the LVDS connector mode list. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-01-16drm: handle depth & bpp changes correctlyJesse Barnes
2009-01-16drm: initial KMS config fixesJesse Barnes
When mode setting is first initialized, the driver will call into drm_helper_initial_config() to set up an initial output and framebuffer configuration. This routine is responsible for probing the available connectors, encoders, and crtcs, looking for modes and putting together something reasonable (where reasonable is defined as "allows kernel messages to be visible on as many displays as possible"). However, the code was a bit too aggressive in setting default modes when none were found on a given connector. Even if some connectors had modes, any connectors found lacking modes would have the default 800x600 mode added to their mode list, which in some cases could cause problems later down the line. In my case, the LVDS was perfectly available, but the initial config code added 800x600 modes to both of the detected but unavailable HDMI connectors (which are on my non-existent docking station). This ended up preventing later code from setting a mode on my LVDS, which is bad. This patch fixes that behavior by making the initial config code walk through the connectors first, counting the available modes, before it decides to add any default modes to a possibly connected output. It also fixes the logic in drm_target_preferred() that was causing zeroed out modes to be set as the preferred mode for a given connector, even if no modes were available. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-01-16serial: Add 16850 uart type support to OF uart driverMatthias Fuchs
This patch adds support for "ns16850" as supported value of the compatible node in flat device tree uart descriptions. This is needed for example when you have a XR16C2850 uart connected to a PPC405's external bus controller. Signed-off-by: Matthias Fuchs <mfuchs@ma-fu.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
