2008-02-29mac80211: Extend filter flag documentation about unsupported flagsMichael Buesch
This extends the filter flags documentation to make it clear what clearing a flag really means. Signed-off-by: Michael Buesch <mb@bu3sch.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: give burst time in txop rather than 0.1msec unitsJohannes Berg
This changes mac80211 to pass the burst time to conf_tx in txop units rather than 0.1msec units. 0.1msec units are only required by atheros hardware (according to current driver support), all other drivers do other calculations or require the txop value. Therefore, it results in fewer calculations and more precision if we just pass the txop value through to the driver. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43: Fix bandswitchMichael Buesch
This fixes bandswitching for the new mac80211 band API. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29iwlwifi: Update iwlwifi version stamp to 1.2.26Reinette Chatre
We update the version stamp at this time to distinguish the in-kernel driver from the out of tree driver. The out of tree driver currently has version number 1.2.25, but the latest driver code can only be found in this in-kernel driver. Having a later version number will reduce confusion between the two versions as we transition from out of tree to in-kernel. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: defer master netdev allocation to ieee80211_register_hwJohannes Berg
When we want to go multiqueue, we will need to know the number of queues the hardware has for registering the master netdev. This number is only available in ieee80211_register_hw() rather than ieee80211_alloc_hw(), so defer allocation of the master device to ieee80211_register_hw(). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: fix B43legacy_WARN_ON macroStefano Brivio
Fix the B43legacy_WARN_ON macro so that it will evaluate expressions. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: fix upload of beacon packets to the hardwareStefano Brivio
This fixes uploading of the beacon data and writing of the TIM and DTIM offsets. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29b43legacy: add definitions for MAC control registerStefano Brivio
This adds some definitions for the MAC control register and uses them. This is basically no functional change. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29iwlwifi: remove IWL{4965,3945}_QOSRon Rindjunsky
This patch removes the IWL4965_QOS and IWL3945_QOS defines from Kconfig file along with all uses of it. These defines were relevant for the period QoS code was tested to be stable in driver's flows. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: adjustable number of bits for qdisc poolRon Rindjunsky
This fix allows to control the number of bits that qdiscs book keeping can be done for with respect to the qdisc pool Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: Add cooked monitor mode supportMichael Wu
This adds "cooked" monitor mode to mac80211. A monitor interface in "cooked" mode will see all frames that mac80211 has not used internally. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: move some code into ieee80211_invoke_rx_handlersJohannes Berg
There is some duplicated code that sits in front of each function call to ieee80211_invoke_rx_handlers() that can very well be part of that function if it gets slightly different arguments. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: remove "dynamic" RX/TX handlersJohannes Berg
It doesn't really make sense to have extra pointers to the RX/TX handler arrays instead of just using the arrays directly, that also allows us to make them static. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: clean up some things in the RX pathJohannes Berg
Uninline ieee80211_invoke_rx_handlers to save .text space, make the code more readable in some places and remove the "optimisation" that is hit only very few times and unclear to start with. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: Use monitor configuration flagsMichael Wu
Take advantage of the monitor configuration flags now provided by cfg80211. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29nl80211: Add monitor interface configuration flagsMichael Wu
This allows precise control over what a monitor interface shows. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: split RX_DROPJohannes Berg
Some instances of RX_DROP mean that the frame was useless, others mean that the frame should be visible in userspace on "cooked" monitor interfaces. This patch splits up RX_DROP and changes each instance appropriately. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: split ieee80211_txrx_resultJohannes Berg
The _DROP result will need to be split in the RX path but not in the TX path, so for preparation split up the type into two types, one for RX and one for TX. Also make sure (via sparse) that they cannot be confused. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29iwlwifi: Fix HT compilation breakage caused by cfg80211 API for ↵Tomas Winkler
channels/bitrates patch This patch fixes compilation breakage caused by 'cfg80211 API for channels/bitrates' patch. however it doesn't fix the driver's functional problems caused by that patch. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Release rt2x00 2.1.0Ivo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix rate initializationIvo van Doorn
Fix typo in rate initialization. This fixes the WARN_ON() in net/wireless/util.cpp:83 Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Enable LED class support for rt2500usb/rt73usbIvo van Doorn
Add kerneldoc for vendor request functions in rt2x00usb. Add asynchroneous vendor request function in rt2x00usb. With the availability of the asynchroneuous vendor request we can now enable LED class support for rt2500usb and rt73usb. Since LED handling is not important, it doesn't really matter if a register call fails (This solution is better then no LED class support at all). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Make use of MAC80211_LED_TRIGGERSIvo van Doorn
Make use of the led triggers provided by mac80211 to control the led status. This can be enabled through a per-driver configuration option which will automatically enable the generic handler in rt2x00lib. This has been enabled for rt2500usb and rt73usb for the moment since the led class will call set_brightness in irq context which will not work correctly with the usb drivers who need to sleep. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Use ieee80211_channel_to_frequency()Ivo van Doorn
No need to perform the calculation ourselves when wireless provides a helper function for it. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Remove HWMODE_{A,B,G}Ivo van Doorn
rt2500usb initialized the SIFS and EIFS without using the values coming from rt2x000lib. After this is fixed HWMODE_{A,B,G} is now unused and can be removed in favour of the ieee80211_band enumeration which could still be usefull later. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Rate structure overhaulIvo van Doorn
Recent changes to the rate structure registration broke rt2x00, the hw_value was reduced from 32bits to 16bits while rt2x00 used the full 32bits. However the way rt2x00 used the value was inflexible and needed to be changed anyway. This patch creates a array containing information for each rate, the hw_value passed to mac80211 is the index value for that array including a field to indicate if short preamble should be enabled. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k/phy.c: fix negative array indexLuis R. Rodriguez
Author: Adrian Bunk <bunk@kernel.org> This patch fixes a negative array index spotted by the Coverity checker. Changes-licensed-under: ISC Acked-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: Use software encryption for nowLuis R. Rodriguez
Hardware encryption doesn't work yet so lets use software encryption for now. Changes-licensed-under: 3-Clause-BSD Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: Port debug.c over to the new band API and enable as build optionLuis R. Rodriguez
This patch finishes the port and enables debug as an build option. This was tested on: Atheros AR5213A chip found (MAC: 0x59, PHY: 0x43) RF5112A multiband radio found (0x36) Note: For 2 GHz band on the above card I noticed we get negative channel numbers. Will look into this unless someone beats me to it. Example out put when loading using: sudo modprobe ath5k debug=0x00000400 Band 2 GHz: channels 26, rates 12 channels: 1 2412 00c0 0000 2 2417 00c0 0000 3 2422 00c0 0000 4 2427 00c0 0000 5 2432 00c0 0000 6 2437 00c0 0000 7 2442 00c0 0000 8 2447 00c0 0000 9 2452 00c0 0000 10 2457 00c0 0000 11 2462 00c0 0000 12 2467 00c0 0000 13 2472 00c0 0000 14 2484 00c0 0000 -498 2512 00c0 0000 -494 2532 00c0 0000 -490 2552 00c0 0000 -486 2572 00c0 0000 -482 2592 00c0 0000 -478 2612 00c0 0000 -474 2632 00c0 0000 -470 2652 00c0 0000 -466 2672 00c0 0000 -462 2692 00c0 0000 -458 2712 00c0 0000 -454 2732 00c0 0000 Band 5 GHz: channels 194, rates 8 channels: 27 5135 0140 0000 28 5140 0140 0000 [... etc ] 219 6095 0140 0000 220 6100 0140 0000 rates: 60 000b 0000 0000 90 000f 0000 0000 120 000a 0000 0000 180 000e 0000 0000 240 0009 0000 0000 360 000d 0000 0000 480 0008 0000 0000 540 000c 0000 0000 Changes to base.c, base.h Changes-licensed-under: 3-Clause-BSD Changes to debug.c, debug.h Changes-licensed-under: GPL Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: Use our own Kconfig file, we'll be expanding this shortlyLuis R. Rodriguez
Apologoes, this is a re-post of patch-04, forgot to git-add our Kconfig... New series (only 2 patches needed fixing, which I am reposting) can be found here: http://kernel.org/pub/linux/kernel/people/mcgrof/patches/ath5k/2008-02-04.v2/ Use our own Kconfig file, we'll be expanding this shortly. Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: ath5k_copy_channels() was not setting the channel bandLuis R. Rodriguez
ath5k_copy_channels() wasn't setting the channel's band so all driver channels had a 2GHz band set. Lets set this. Changes-licensed-under: 3-Clause-BSD Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: Cleanup after API changesLuis R. Rodriguez
Cleanup after API changes patch (checkpatch.pl stuff) and on ath5k_hw_channel() make use of the existing ath5k_channel_ok() instead of re-implementing the checks again. This was necessary to make the code cleaner and fit the 80-chars wide limit so sending it within the same patch. Finally make a note that we *may* eventually move cap_range stuff to struct wiphy (band frequency range capabilities). This information can later be exported to userspace, for example, and giving it access to mac80211 and drivers in general can come in handy. Changes to initvals.c, phy.c Changes-licensed-under: ISC Changes to ath5k.h, base.c Changes-licensed-under: 3-Clause-BSD Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29ath5k: Port to new bitrate/channel APILuis R. Rodriguez
Author: Nick Kossifidis <mickflemm@gmail.com> Tested on 5211, 5213+5112, 5213A+2112A and it wors fine. Also i figured out a way to process rate vallue found on status descriptors, it's still buggy but we are getting closer (i think it improved stability a little). Changes to hw.c, initvals.c, phy.c Changes-licensed-under: ISC Changes to ath5k.h, base.c, base.h Changes-licensed-under: 3-Clause-BSD Acked-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Nick Kossifidis <mickflemm@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29wireless: Fix WARN_ON() with ieee802.11bIvo van Doorn
When the driver registers a IEEE80211_BAND_2GHZ band, it can either be 802.11b or 802.11g. But when 802.11b rates are registered "want" will be 3 (since 4 rates are being registered, and each of those 4 rates will decrease "want"). Since this is a correct situation, there is no need to trigger a WARN_ON() for this. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29iwlwifi: set rate_idx correctly from plcpMohamed Abbas
rate_idx is derived from plcp information Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29iwlwifi: initialize ieee80211_channel->hw_valueMohamed Abbas
hw_value is being used uninitialized. fix it. Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29wireless: fix ERP rate flagsJohannes Berg
In the rate API patch I accidentally reverted the test for ERP rates, this fixes it. All rates except 1, 2, 5.5 and 11 MBit are ERP rates, not those. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rc80211-pid: fix rate adjustmentStefano Brivio
Merge rate_control_pid_shift_adjust() to rate_control_pid_adjust_rate() in order to make the learning algorithm aware of constraints on rates. Also add some comments and rename variables. This fixes a bug which prevented 802.11b/g non-AP STAs from working with 802.11b only AP STAs. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: remove port control enable switch, clean up sta flagsJohannes Berg
This patch removes the 802.1X port acess control enable flag since it is not required. Instead, set the authorized flag for each station that we normally communicate with (WDS peers, IBSS peers and APs we're associated to) and require hostapd to set the authorized flag for all stations when port control is not enabled. Also, since I was working in that area, this documents station flags and removes the unused "permanent" one. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: fix scan band off-by-one errorJohannes Berg
When checking for the next band to advance to, there was an off-by-one error that could lead to an access to an invalid array index. Additionally, the later check for scan_band >= IEEE80211_NUM_BANDS is not required since that will never be true. This also improves the comments related to that code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29nl80211: export hardware bitrate/channel capabilitiesJohannes Berg
This makes nl80211 export the hardware bitrate/channel capabilities as registered in a wiphy. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29cfg80211 API for channels/bitrates, mac80211 and driver conversionJohannes Berg
This patch creates new cfg80211 wiphy API for channel and bitrate registration and converts mac80211 and drivers to the new API. The old mac80211 API is completely ripped out. All drivers (except ath5k) are updated to the new API, in many cases I expect that optimisations can be done. Along with the regulatory code I've also ripped out the IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be unnecessary if the hardware simply gives us whatever channels it wants to support and we then enable/disable them as required, which is pretty much required for travelling. Additionally, the patch adds proper "basic" rate handling for STA mode interface, AP mode interface will have to have new API added to allow userspace to set the basic rate set, currently it'll be empty... However, the basic rate handling will need to be moved to the BSS conf stuff. I do expect there to be bugs in this, especially wrt. transmit power handling where I'm basically clueless about how it should work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix queue index handlingIvo van Doorn
When Q_INDEX is increased, the queue->length should be increased, only when Q_INDEX_DONE is increased should queue_length be descreased. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Move beacon and atim queue defines into rt2x00Ivo van Doorn
As Johannes Berg indicated the BEACON and AFTER_BEACON queue indeces in mac80211 should be removed because they are too hardware specific. This patch adds the queue index defines into rt2x00queue.h and removes the dependency of the defines inside mac80211.h. Also move rt2x00pci_beacon_update() into rt2400pci and rt2500pci individually since it is no longer a generic function since rt61 and rt2800 no longer use that. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Initialize QID from queue->qidIvo van Doorn
The QID_MGMT is assigned to the beacon and atim queue during initialization. This means we don't need a seperate check in write_tx_desc().. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Remove TX_MGMT queue usageIvo van Doorn
rt73usb doesn't have a 5th queue, correctly initialize hw->queues rt61pci had a 5th queue but was removed recently, correctly initialize hw->queues and remove the last remnants. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Add per-interface structureIvo van Doorn
Rework the interface handling. Delete the interface structure and replace it with a per-interface structure. This changes the way rt2x00 handles the active interface drastically. Copy ieee80211_bss_conf to the this rt2x00_intf structure during the bss_info_changed() callback function. This will allow us to reference it later, and removes the requirement for the device flag SHORT_PREAMBLE flag which is interface specific. Drivers receive the option to give the maximum number of virtual interfaces the device can handle. Virtual interface support: rt2400pci: 1 sta or 1 ap, * monitor interfaces rt2500pci: 1 sta or 1 ap, * monitor interfaces rt2500usb: 1 sta or 1 ap, * monitor interfaces rt61pci: 1 sta or 4 ap, * monitor interfaces rt73usb: 1 sta or 4 ap, * monitor interfaces At the moment none of the drivers support AP and STA interfaces simultaneously, this is a hardware limitation so future support will be very unlikely. Each interface structure receives its dedicated beacon entry, with this we can easily work with beaconing while multiple master mode interfaces are currently active. The configuration handlers for the MAC, BSSID and type are often called together since they all belong to the interface configuration. Merge the 3 configuration calls and cleanup the API between rt2x00lib and the drivers. While we are cleaning up the interface configuration anyway, we might as well clean up the configuration handler as well. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Driver requiring firmware should select crc algoIvo van Doorn
The driver should select what CRC algorithm is required when performing a checksum on the firmware. rt61pci & rt73usb require crc-itu-t rt2800pci & rt2800usb require crc-ccitt Legacy 2800pci/usb driver uses crc-itu-t + bit order reversion, but that is just inefficient especially since the end result is the same as a different algorithm which is also available as library. ;) Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Enable master and adhoc mode againIvo van Doorn
This will enable the creation of master mode and adhoc interfaces again. This does not mean the issues surrounding beaconing have been resolved, but this will make testing easier and perhaps we can discover which cards are actually working and which ones not. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Fix tx parameter initializationIvo van Doorn
Check if the aifs, cw_min and cw_max are above 0 when determining if the default should be used. Tor aifs a negative number is used to determine if the default should be used or not. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
