2012-07-23Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull general arm-soc cleanups from Arnd Bergmann: "These are all boring changes, moving stuff around or renaming things mostly, and also getting rid of stuff that is duplicate or should not be there to start with. Platform-wise this is all over the place, mainly omap, samsung, at91, imx and tegra." Resolve trivial conflict in arch/arm/mach-omap2/clockdomains3xxx_data.c * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) ARM: clps711x: Remove the setting of the time ARM: clps711x: Removed superfluous transform virt_to_bus and related functions ARM: clps711x/p720t: Replace __initcall by .init_early call ARM: S3C24XX: Remove unused GPIO definitions for Openmoko GTA02 board ARM: S3C24XX: Remove unused GPIO definitions for port J ARM: S3C24XX: Remove unused GPA, GPE, GPH bank GPIO aliases ARM: S3C24XX: Convert the touchscreen setup code to common GPIO API ARM: S3C24XX: Convert the PM code to gpiolib API ARM: S3C24XX: Convert QT2410 board file to the gpiolib API ARM: S3C24XX: Convert SMDK board file to the gpiolib API ARM: S3C24XX: Free the backlight gpio requested in Mini2440 board code ARM: imx: remove unused pdata from device macros ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS ARM: at91: fix new build errors ARM: at91: add AIC5 support ARM: at91: remove mach/irqs.h ARM: at91: sparse irq support ARM: at91: at91 based machines specify their own irq handler at run time ARM: at91: remove static irq priorities for sam9x5 ARM: at91: add of irq priorities support ...
2012-07-23Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical arm-soc bug fixes from Arnd Bergmann: "These were submitted as bug fixes before v3.5 but not considered important enough to be included in it." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM:vt8500: Convert to use .restart and remove arch_reset() ARM: davinci: da8xx: fix interrupt handling ARM: OMAP2+: fix CONFIG_CPU_IDLE dependency on CONFIG_PM ARM: mxs/tx28: fix odd include ARM: OMAP: remove unused cpu detection macros ARM: OMAP: fix typos related to OMAP330 ARM: OMAP7XX: Remove omap730.h and omap850.h ARM: OMAP2+: fix naming collision of variable nr_irqs ARM: OMAP: omap2plus_defconfig: Enable EXT4 support ARM: OMAP depends on MMU arm: omap3: am35x: Set proper powerdomain states ARM: OMAP AM35x: clockdomain data: Fix clockdomain dependencies ARM: OMAP AM35x: EMAC/MDIO integration: Add Davinci EMAC/MDIO hwmod support ARM: OMAP: AM35xx: fix UART4 softreset ARM: OMAP AM35xx: clock and hwmod data: fix UART4 data ARM: OMAP AM35xx: clock and hwmod data: fix AM35xx HSOTGUSB hwmod ARM: OMAP: Fix dts files w/ status property: "disable" -> "disabled" ARM: OMAP: beagle: Set USB Host Port 1 to OMAP_USBHS_PORT_MODE_UNUSED ARM: OMAP2: twl-common: Fix compiler warning ARM: OMAP: fix the ads7846 init code ...
2012-07-23Merge tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubiLinus Torvalds
Pull UBI changes from Artem Bityutskiy: "Change the default amount of eraseblocks which UBI reserves for bad block handling from 1% to 2%, because 1% does not meet most modern flash requirements. 1% was good enough in the past for old high-quality SLCs, but nowadays 2% is much more appropriate.: Other changes are clean-ups. * tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubi: UBI: harmonize the update of ubi->beb_rsvd_pebs UBI: trivial: fix comment of ubi_calculate_reserved function UBI: fix spelling of detach in debug output UBI: Change the default percentage of reserved PEB
2012-07-23Merge tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBIFS updates from Artem Bityutskiy: - Added another debugfs knob for forcing UBIFS R/O mode without flushing caches or finishing commit or any other I/O operation. I've originally added this knob in order to reproduce the free space fixup bug (see commit c6727932cfdb: "UBIFS: fix a bug in empty space fix-up") on nandsim. Without this knob I would have to do real power-cuts, which would make debugging much harder. Then I've decided to keep this knob because it is also useful for UBIFS power-cut recovery end error-paths testing. - Well-spotted fix from Julia. This bug did not cause real troubles for UBIFS, but nevertheless it could cause issues for someone trying to modify the orphans handling code. Kudos to coccinelle! - Minor cleanups. * tag 'upstream-3.6-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: remove invalid reference to list iterator variable UBIFS: simplify reply code a bit UBIFS: add debugfs knob to switch to R/O mode UBIFS: fix compilation warning
2012-07-23locks: fix checking of fcntl_setlease argumentJ. Bruce Fields
The only checks of the long argument passed to fcntl(fd,F_SETLEASE,.) are done after converting the long to an int. Thus some illegal values may be let through and cause problems in later code. [ They actually *don't* cause problems in mainline, as of Dave Jones's commit 8d657eb3b438 "Remove easily user-triggerable BUG from generic_setlease", but we should fix this anyway. And this patch will be necessary to fix real bugs on earlier kernels. ] Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-22Merge tag 'mmc-merge-for-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.6: Core: - Rename cd-gpio to slot-gpio and extend it to support more slot GPIO functions, such as write-protect. - Add a function to get regulators (Vdd and Vccq) for a host. Drivers: - sdhci-pxav2, sdhci-pxav3: Add device tree support. - sdhi: Add device tree support. - sh_mmcif: Add support for regulators, device tree, slot-gpio. - tmio: Add regulator support, use slot-gpio." * tag 'mmc-merge-for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (62 commits) mmc: sdhci-dove: Prepare for common clock framework mmc: sdhci-dove: Add SDHCI_QUIRK_NO_HISPD_BIT mmc: omap_hsmmc: ensure probe returns error upon resource failure mmc: mxs-mmc: Add wp-inverted property mmc: esdhc: Fix DMA_MASK to not break mx25 DMA access mmc: core: reset signal voltage on power up mmc: sd: Fix sd current limit setting mmc: omap_hsmmc: add clk_prepare and clk_unprepare mmc: sdhci: When a UHS switch fails, cycle power if regulator is used mmc: atmel-mci: modify CLKDIV displaying in debugfs mmc: atmel-mci: fix incorrect setting of host->data to NULL mmc: sdhci: poll for card even when card is logically unremovable mmc: sdhci: Introduce new flag SDHCI_USING_RETUNING_TIMER mmc: sdio: Change pr_warning to pr_warn_ratelimited mmc: core: Simplify and fix for SD switch processing mmc: sdhci: restore host settings when card is removed mmc: sdhci: fix incorrect command used in tuning mmc: sdhci-pci: CaFe has broken card detection mmc: sdhci: Report failure reasons for all cases in sdhci_add_host() mmc: s3cmci: Convert s3cmci driver to gpiolib API ...
2012-07-22Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/mce changes from Ingo Molnar: "This tree improves the AMD thresholding bank code and includes a memory fault signal handling fixlet." * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce: Fix siginfo_t->si_addr value for non-recoverable memory faults x86, MCE, AMD: Update copyrights and boilerplate x86, MCE, AMD: Give proper names to the thresholding banks x86, MCE, AMD: Make error_count read only x86, MCE, AMD: Cleanup reading of error_count x86, MCE, AMD: Print decimal thresholding values x86, MCE, AMD: Move shared bank to node descriptor x86, MCE, AMD: Remove local_allocate_... wrapper x86, MCE, AMD: Remove shared banks sysfs linking x86, amd_nb: Export model 0x10 and later PCI id
2012-07-22mmc: sdhci-dove: Prepare for common clock frameworkSebastian Hesselbarth
As mach-dove is moving towards common clock framework prepare the sdhci driver to grab its clock. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: sdhci-dove: Add SDHCI_QUIRK_NO_HISPD_BITSebastian Hesselbarth
The sdio controller on dove doesn't have a bit to indicate high-speed. With the quirk set it fixes accessing high-speed sdcards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@googlemail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: omap_hsmmc: ensure probe returns error upon resource failureKevin Hilman
If platform_get_resource_by_name() fails, driver probe is aborted an should return an error so the driver is not bound to the device. However, in the current error path of platform_get_resource_by_name(), probe returns zero since the return value (ret) is not properly set. With a zero return value, the driver core assumes probe was successful and will bind the driver to the device. Fix this by ensuring that probe returns an error code in this failure path. Signed-off-by: Kevin Hilman <khilman@ti.com> Acked-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: mxs-mmc: Add wp-inverted propertyMarek Vasut
The write-protect GPIO is inverted on some boards. Handle such case. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22mmc: esdhc: Fix DMA_MASK to not break mx25 DMA accessWilson Callan
Patch to not set reserved bits in i.MX25 PROCTL register. DMA stops working if those bits get set. Signed-off-by: Wilson Callan <wilson.callan@savantsystems.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-07-22Merge tag 'pm-for-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: - ACPI conversion to PM handling based on struct dev_pm_ops. - Conversion of a number of platform drivers to PM handling based on struct dev_pm_ops and removal of empty legacy PM callbacks from a couple of PCI drivers. - Suspend-to-both for in-kernel hibernation from Bojan Smojver. - cpuidle fixes and cleanups from ShuoX Liu, Daniel Lezcano and Preeti Murthy. - cpufreq bug fixes from Jonghwa Lee and Stephen Boyd. - Suspend and hibernate fixes from Srivatsa Bhat and Colin Cross. - Generic PM domains framework updates. - RTC CMOS wakeup signaling update from Paul Fox. - sparse warnings fixes from Sachin Kamat. - Build warnings fixes for the generic PM domains framework and PM sysfs code. - sysfs switch for printing device suspend times from Sameer Nanda. - Documentation fix from Oskar Schirmer. * tag 'pm-for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (70 commits) cpufreq: Fix sysfs deadlock with concurrent hotplug/frequency switch EXYNOS: bugfix on retrieving old_index from freqs.old PM / Sleep: call early resume handlers when suspend_noirq fails PM / QoS: Use NULL pointer instead of plain integer in qos.c PM / QoS: Use NULL pointer instead of plain integer in pm_qos.h PM / Sleep: Require CAP_BLOCK_SUSPEND to use wake_lock/wake_unlock PM / Sleep: Add missing static storage class specifiers in main.c cpuilde / ACPI: remove time from acpi_processor_cx structure cpuidle / ACPI: remove usage from acpi_processor_cx structure cpuidle / ACPI : remove latency_ticks from acpi_processor_cx structure rtc-cmos: report wakeups from interrupt handler PM / Sleep: Fix build warning in sysfs.c for CONFIG_PM_SLEEP unset PM / Domains: Fix build warning for CONFIG_PM_RUNTIME unset olpc-xo15-sci: Use struct dev_pm_ops for power management PM / Domains: Replace plain integer with NULL pointer in domain.c file PM / Domains: Add missing static storage class specifier in domain.c file PM / crypto / ux500: Use struct dev_pm_ops for power management PM / IPMI: Remove empty legacy PCI PM callbacks tpm_nsc: Use struct dev_pm_ops for power management tpm_tis: Use struct dev_pm_ops for power management ...
2012-07-22Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull target updates from Nicholas Bellinger: "There have been lots of work in a number of areas this past round. The highlights include: - Break out target_core_cdb.c emulation into SPC/SBC ops (hch) - Add a parse_cdb method to target backend drivers (hch) - Move sync_cache + write_same + unmap into spc_ops (hch) - Use target_execute_cmd for WRITEs in iscsi_target + srpt (hch) - Offload WRITE I/O backend submission in tcm_qla2xxx + tcm_fc (hch + nab) - Refactor core_update_device_list_for_node() into enable/disable funcs (agrover) - Replace the TCM processing thread with a TMR work queue (hch) - Fix regression in transport_add_device_to_core_hba from TMR conversion (DanC) - Remove racy, now-redundant check of sess_tearing_down with qla2xxx (roland) - Add range checking, fix reading of data len + possible underflow in UNMAP (roland) - Allow for target_submit_cmd() returning errors + convert fabrics (roland + nab) - Drop bogus struct file usage for iSCSI/SCTP (viro)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (54 commits) iscsi-target: Drop bogus struct file usage for iSCSI/SCTP target: NULL dereference on error path target: Allow for target_submit_cmd() returning errors target: Check number of unmap descriptors against our limit target: Fix possible integer underflow in UNMAP emulation target: Fix reading of data length fields for UNMAP commands target: Add range checking to UNMAP emulation target: Add generation of LOGICAL BLOCK ADDRESS OUT OF RANGE target: Make unnecessarily global se_dev_align_max_sectors() static target: Remove se_session.sess_wait_list qla2xxx: Remove racy, now-redundant check of sess_tearing_down target: Check sess_tearing_down in target_get_sess_cmd() sbp-target: Consolidate duplicated error path code in sbp_handle_command() target: Un-export target_get_sess_cmd() qla2xxx: Get rid of redundant qla_tgt_sess.tearing_down target: Make core_disable_device_list_for_node use pre-refactoring lock ordering target: refactor core_update_device_list_for_node() target: Eliminate else using boolean logic target: Misc retval cleanups target: Remove hba param from core_dev_add_lun ...
2012-07-22Merge tag 'regulator-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "Lots and lots of fixes from Axel and some others here, plus some framework enhancements which continue the theme of factoring code out of the drivers and into the core. - Initial framework support for GPIO controlled enable signals, saving a bunch of code in drivers. - Move fixed regulator enable time and voltage mapping table specifications to data. - Used some of the recent framework enhancements to make voltage change notifications more useful, passing the voltage in as an argument to the notification. - Fixed the pattern used for finding individual regulators on a device to not rely on the node name, supporting the use of multiple PMICs of the same type in the system. - New drivers for Maxim MAX77686, TI LP872x and LP8788, Samsung S2MPS11, and Wolfson Arizona microphone supplies and LDOs." * tag 'regulator-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (176 commits) regulator: add new lp8788 regulator driver regulator: mc13xxx: Remove extern function declaration for mc13xxx_sw_regulator regulator: tps65910: set input_supply on desc unconditionally regulator: palmas: Fix calcuating selector in palmas_map_voltage_smps regulator: lp872x: Simplify implementation of lp872x_find_regulator_init_data() regulator: twl: Fix list_voltate for twl6030ldo_ops regulator: twl: Convert twl6030ldo_ops to [get|set]_voltage_sel regulator: twl: Fix the formula to calculate vsel and voltage for twl6030ldo regulator: s5m8767: Properly handle gpio_request failure regulator: max8997: Properly handle gpio_request failure regulator: tps62360: use devm_* for gpio request regulator: tps6586x: add support for input supply regulator: tps65217: Add device tree support regulator: aat2870: Remove unused min_uV and max_uV from struct aat2870_regulator regulator: aat2870: Convert to regulator_list_voltage_table regulator: da9052: initialize of_node param for regulator register regulator: Add REGULATOR_STATUS_UNDEFINED. regulator: Fix a typo in regulator_mode_to_status() core function. regulator: s2mps11: Use sec_reg_write rather than sec_reg_update when mask is 0xff regulator: s2mps11: Fix wrong setting for config.dev ...
2012-07-22Merge tag 'regmap-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "A few fixes plus a few features, the most generally useful thing being the register paging support which can be used by quite a few devices: - Support for wake IRQs in regmap-irq - Support for register paging - Support for explicitly specified endianness, mostly for MMIO." * tag 'regmap-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: Fix incorrect arguments to kzalloc() call regmap: Add hook for printk logging for debugging during early init regmap: Fix work_buf switching for page update during virtual range access. regmap: Add support for register indirect addressing. regmap: Move lock out from internal function _regmap_update_bits(). regmap: mmio: Staticize regmap_mmio_gen_context() regmap: Remove warning on stubbed dev_get_regmap() regmap: Implement support for wake IRQs regmap: Don't try to map non-existant IRQs regmap: Constify regmap_irq_chip regmap: mmio: request native endian formatting regmap: allow busses to request formatting with specific endianness
2012-07-23ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file()Al Viro
2012-07-23btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file()Al Viro
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-23spufs: shift dget/mntget towards dentry_open()Al Viro
2012-07-23zoran: don't bother with struct file * in zoran_mapAl Viro
all we need it for is file->private_data, which is assign-once, already assigned by that point and, incidentally, its value is already in use by zoran ->mmap() anyway. So just store that pointer instead... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23ecryptfs: don't reinvent the wheels, please - use struct completionAl Viro
... and keep the sodding requests on stack - they are small enough. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23don't expose I_NEW inodes via dentry->d_inodeAl Viro
d_instantiate(dentry, inode); unlock_new_inode(inode); is a bad idea; do it the other way round... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23tidy up namei.c a bitAl Viro
locking/unlocking for rcu walk taken to a couple of inline helpers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23unobfuscate follow_up() a bitAl Viro
really convoluted test in there has grown up during struct mount introduction; what it checks is that we'd reached the root of mount tree.
2012-07-23ext3: pass custom EOF to generic_file_llseek_size()Eric Sandeen
Use the new custom EOF argument to generic_file_llseek_size so that SEEK_END will go to the max hash value for htree dirs in ext3 rather than to i_size_read() Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23ext4: use core vfs llseek code for dir seeksEric Sandeen
Use the new functionality in generic_file_llseek_size() to accept a custom EOF position, and un-cut-and-paste all the vfs llseek code from ext4. Also fix up comments on ext4_llseek() to reflect reality. Signed-off-by: Eric Sandeen <sandeen@redaht.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23vfs: allow custom EOF in generic_file_llseek codeEric Sandeen
For ext3/4 htree directories, using the vfs llseek function with SEEK_END goes to i_size like for any other file, but in reality we want the maximum possible hash value. Recent changes in ext4 have cut & pasted generic_file_llseek() back into fs/ext4/dir.c, but replicating this core code seems like a bad idea, especially since the copy has already diverged from the vfs. This patch updates generic_file_llseek_size to accept both a custom maximum offset, and a custom EOF position. With this in place, ext4_dir_llseek can pass in the appropriate maximum hash position for both maxsize and eof, and get what it wants. As far as I know, this does not fix any bugs - nfs in the kernel doesn't use SEEK_END, and I don't know of any user who does. But some ext4 folks seem keen on doing the right thing here, and I can't really argue. (Patch also fixes up some comments slightly) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder ↵Jan Kara
sync passes wakeup_flusher_threads(0) will queue work doing complete writeback for each flusher thread. Thus there is not much point in submitting another work doing full inode WB_SYNC_NONE writeback by writeback_inodes_sb(). After this change it does not make sense to call nonblocking ->sync_fs and block device flush before calling sync_inodes_sb() because wakeup_flusher_threads() is completely asynchronous and thus these functions would be called in parallel with inode writeback running which will effectively void any work they do. So we move sync_inodes_sb() call before these two functions. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22vfs: Remove unnecessary flushing of block devicesJan Kara
It is not necessary to write block devices twice. The reason why we first did flush and then proper sync is that for_each_bdev() { write_bdev() wait_for_completion() } is much slower than for_each_bdev() write_bdev() for_each_bdev() wait_for_completion() when there is bigger amount of data. But as is seen in the above, there's no real need to scan pages and submit them twice. We just need to separate the submission and waiting part. This patch does that. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22vfs: Make sys_sync writeout also block device inodesJan Kara
In case block device does not have filesystem mounted on it, sys_sync will just ignore it and doesn't writeout its dirty pages. This is because writeback code avoids writing inodes from superblock without backing device and blockdev_superblock is such a superblock. Since it's unexpected that sync doesn't writeout dirty data for block devices be nice to users and change the behavior to do so. So now we iterate over all block devices on blockdev_super instead of iterating over all superblocks when syncing block devices. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22vfs: Create function for iterating over block devicesJan Kara
2012-07-22vfs: Reorder operations during sys_syncJan Kara
Change the order of operations during sync from for_each_sb { writeback_inodes_sb(); sync_fs(nowait); __sync_blockdev(nowait); } for_each_sb { sync_inodes_sb(); sync_fs(wait); __sync_blockdev(wait); } to for_each_sb writeback_inodes_sb(); for_each_sb sync_fs(nowait); for_each_sb __sync_blockdev(nowait); for_each_sb sync_inodes_sb(); for_each_sb sync_fs(wait); for_each_sb __sync_blockdev(wait); This is a preparation for the following patches in this series. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22quota: Move quota syncing to ->sync_fs methodJan Kara
Since the moment writes to quota files are using block device page cache and space for quota structures is reserved at the moment they are first accessed we have no reason to sync quota before inode writeback. In fact this order is now only harmful since quota information can easily change during inode writeback (either because conversion of delayed-allocated extents or simply because of allocation of new blocks for simple filesystems not using page_mkwrite). So move syncing of quota information after writeback of inodes into ->sync_fs method. This way we do not have to use ->quota_sync callback which is primarily intended for use by quotactl syscall anyway and we get rid of calling ->sync_fs() twice unnecessarily. We skip quota syncing for OCFS2 since it does proper quota journalling in all cases (unlike ext3, ext4, and reiserfs which also support legacy non-journalled quotas) and thus there are no dirty quota structures. CC: "Theodore Ts'o" <tytso@mit.edu> CC: Joel Becker <jlbec@evilplan.org> CC: reiserfs-devel@vger.kernel.org Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Dave Kleikamp <shaggy@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22quota: Split dquot_quota_sync() to writeback and cache flushing partJan Kara
Split off part of dquot_quota_sync() which writes dquots into a quota file to a separate function. In the next patch we will use the function from filesystems and we do not want to abuse ->quota_sync quotactl callback more than necessary. Acked-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22vfs: Move noop_backing_dev_info check from sync into writebackJan Kara
In principle, a filesystem may want to have ->sync_fs() called during sync(1) although it does not have a bdi (i.e. s_bdi is set to noop_backing_dev_info). Only writeback code really needs bdi set to something reasonable. So move the checks where they are more logical. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/ufs: get rid of write_superArtem Bityutskiy
This patch makes UFS stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The way we implement this is that we schedule a delay job instead relying on 's_dirt' and '->write_super()'. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/ufs: re-arrange the code a bitArtem Bityutskiy
This patch does not do any functional changes. It only moves 3 functions in fs/ufs/super.c a little bit up in order to prepare for further changes where I'll need this new arrangement to avoid forward declarations. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/ufs: remove extra superblock write on unmountArtem Bityutskiy
UFS calls 'ufs_write_super()' from 'ufs_put_super()' in order to write the superblocks to the media. However, it is not needed because VFS calls '->sync_fs()' before calling '->put_super()' - so by the time we are in 'ufs_write_super()', the superblocks are already synchronized. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/sysv: stop using write_super and s_dirtArtem Bityutskiy
It does not look like sysv FS needs 'write_super()' at all, because all it does is a timestamp update. I cannot test this patch, because this file-system is so old and probably has not been used by anyone for years, so there are no tools to create it in Linux. But from the code I see that marking the superblock as dirty is basically marking the superblock buffers as drity and then setting the s_dirt flag. And when 'write_super()' is executed to handle the s_dirt flag, we just update the timestamp and again mark the superblock buffer as dirty. Seems pointless. It looks like we can update the timestamp more opprtunistically - on unmount or remount of sync, and nothing should change. Thus, this patch removes 'sysv_write_super()' and 's_dirt'. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/sysv: remove another useless write_super callArtem Bityutskiy
We do not need to call 'sysv_write_super()' from 'sysv_remount()', because VFS has called 'sysv_sync_fs()' before calling '->remount()'. So remove it. Remove also '(un)lock_super()' which obvioulsy is becoming useless in this function. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/sysv: remove useless write_super callArtem Bityutskiy
We do not need to call 'sysv_write_super()' from 'sysv_put_super()', because VFS has called 'sysv_sync_fs()' before calling '->put_super()'. So remove it. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: get rid of hfs_sync_superArtem Bityutskiy
This patch makes hfs stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: introduce VFS superblock object back-referenceArtem Bityutskiy
Add an 'sb' VFS superblock back-reference to the 'struct hfs_sb_info' data structure - we will need to find the VFS superblock from a 'struct hfs_sb_info' object in the next patch, so this change is jut a preparation. Remove few useless newlines while on it. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: simplify a bit checking for R/OArtem Bityutskiy
We have the following pattern in 2 places in HFS if (!RDONLY) hfs_mdb_commit(); This patch pushes the RDONLY check down to 'hfs_mdb_commit()'. This will make the following patches a bit simpler. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: remove extra mdb write on unmountArtem Bityutskiy
HFS calls 'hfs_write_super()' from 'hfs_put_super()' in order to write the MDB to the media. However, it is not needed because VFS calls '->sync_fs()' before calling '->put_super()' - so by the time we are in 'hfs_write_super()', the MDB is already synchronized. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: get rid of lock_superArtem Bityutskiy
Stop using lock_super for serializing the MDB changes - use the buffer-head own lock instead. Tested with fsstress. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfs: push lock_super downArtem Bityutskiy
HFS uses 'lock_super()'/'unlock_super()' around 'hfs_mdb_commit()' in order to serialize MDB (Master Directory Block) changes. Push it down to 'hfs_mdb_commit()' in order to simplify the code a bit. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22hfsplus: get rid of write_superArtem Bityutskiy
This patch makes hfsplus stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
