2007-10-16Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: (33 commits) amd74xx: remove /proc/ide/amd74xx amd74xx/via82cxxx: don't initialize drive->dn sis5513: remove /proc/ide/sis ide: remove CONFIG_IDEDMA_ONLYDISK ide: add "hdx=nodma" kernel parameter ide: remove hwif->autodma and drive->autodma ide: remove "idex=dma" kernel parameter ide: remove CONFIG_BLK_DEV_IDEDMA_FORCED ide: use PCI_VDEVICE() macro sis5513: clear prefetch and postwrite for ATAPI devices it8213/piix/slc90e66: "de-couple" PIO and UDMA modes ide: unexport noautodma ide: unexport ide_tune_dma ide: remove ->ide_dma_check (take 2) ide-pmac: add PIO autotune fallback to ->ide_dma_check ide-cris: add PIO autotune fallback to ->ide_dma_check sl82c105: add PIO autotune fallback to ->ide_dma_check cs5530/sc1200: add PIO autotune fallback to ->ide_dma_check ide: remove ide_use_fast_pio() ide: remove drive->init_speed zeroing ...
2007-10-16fix cirrusfb breakageAl Viro
2007-10-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: SELinux: kills warnings in Improve SELinux performance when AVC misses SELinux: improve performance when AVC misses. SELinux: policy selectable handling of unknown classes and perms SELinux: Improve read/write performance SELinux: tune avtab to reduce memory usage
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (25 commits) firewire: fw-cdev: reorder wakeup vs. spinlock firewire: in-code doc updates. firewire: a header cleanup firewire: adopt read cycle timer ABI from raw1394 firewire: fw-ohci: check for misconfigured bus (phyID == 63) firewire: fw-ohci: missing dma_unmap_single firewire: fw-ohci: log posted write errors firewire: fw-ohci: reorder includes firewire: fw-ohci: fix includes firewire: fw-ohci: enforce read order for selfID generation firewire: fw-sbp2: use an own workqueue (fix system responsiveness) firewire: fw-sbp2: expose module parameter for workarounds firewire: fw-sbp2: add support for multiple logical units per target firewire: fw-sbp2: always enable IRQs before calling command ORB callback firewire: fw-core: local variable shadows a global one firewire: optimize fw_core_add_address_handler ieee1394: ieee1394_core.c: use DEFINE_SPINLOCK for spinlock definition ieee1394: csr1212: proper refcounting ieee1394: nodemgr: fix leak of struct csr1212_keyval ieee1394: pcilynx: I2C cleanups ...
2007-10-16Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: x86: fix boot error introduced by kbuild
2007-10-16Merge branch 'release' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of ssh://master.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix build for CONFIG_SMP=n
2007-10-17SELinux: kills warnings in Improve SELinux performance when AVC missesKaiGai Kohei
This patch kills ugly warnings when the "Improve SELinux performance when ACV misses" patch. Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17SELinux: improve performance when AVC misses.KaiGai Kohei
* We add ebitmap_for_each_positive_bit() which enables to walk on any positive bit on the given ebitmap, to improve its performance using common bit-operations defined in linux/bitops.h. In the previous version, this logic was implemented using a combination of ebitmap_for_each_bit() and ebitmap_node_get_bit(), but is was worse in performance aspect. This logic is most frequestly used to compute a new AVC entry, so this patch can improve SELinux performance when AVC misses are happen. * struct ebitmap_node is redefined as an array of "unsigned long", to get suitable for using find_next_bit() which is fasted than iteration of shift and logical operation, and to maximize memory usage allocated from general purpose slab. * Any ebitmap_for_each_bit() are repleced by the new implementation in ss/service.c and ss/mls.c. Some of related implementation are changed, however, there is no incompatibility with the previous version. * The width of any new line are less or equal than 80-chars. The following benchmark shows the effect of this patch, when we access many files which have different security context one after another. The number is more than /selinux/avc/cache_threshold, so any access always causes AVC misses. selinux-2.6 selinux-2.6-ebitmap AVG: 22.763 [s] 8.750 [s] STD: 0.265 0.019 ------------------------------------------ 1st: 22.558 [s] 8.786 [s] 2nd: 22.458 [s] 8.750 [s] 3rd: 22.478 [s] 8.754 [s] 4th: 22.724 [s] 8.745 [s] 5th: 22.918 [s] 8.748 [s] 6th: 22.905 [s] 8.764 [s] 7th: 23.238 [s] 8.726 [s] 8th: 22.822 [s] 8.729 [s] Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17SELinux: policy selectable handling of unknown classes and permsEric Paris
Allow policy to select, in much the same way as it selects MLS support, how the kernel should handle access decisions which contain either unknown classes or unknown permissions in known classes. The three choices for the policy flags are 0 - Deny unknown security access. (default) 2 - reject loading policy if it does not contain all definitions 4 - allow unknown security access The policy's choice is exported through 2 booleans in selinuxfs. /selinux/deny_unknown and /selinux/reject_unknown. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17SELinux: Improve read/write performanceYuichi Nakamura
It reduces the selinux overhead on read/write by only revalidating permissions in selinux_file_permission if the task or inode labels have changed or the policy has changed since the open-time check. A new LSM hook, security_dentry_open, is added to capture the necessary state at open time to allow this optimization. (see http://marc.info/?l=selinux&m=118972995207740&w=2) Signed-off-by: Yuichi Nakamura<ynakam@hitachisoft.jp> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17SELinux: tune avtab to reduce memory usageYuichi Nakamura
This patch reduces memory usage of SELinux by tuning avtab. Number of hash slots in avtab was 32768. Unused slots used memory when number of rules is fewer. This patch decides number of hash slots dynamically based on number of rules. (chain length)^2 is also printed out in avtab_hash_eval to see standard deviation of avtab hash table. Signed-off-by: Yuichi Nakamura<ynakam@hitachisoft.jp> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17firewire: fw-cdev: reorder wakeup vs. spinlockJay Fenlason
Signed-off-by: Jay Fenlason <fenlason@redhat.com> Prompted by https://bugzilla.redhat.com/show_bug.cgi?id=323411 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: in-code doc updates.Yann Dirson
Signed-off-by: Yann Dirson <ydirson@altern.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (update)
2007-10-17firewire: a header cleanupStefan Richter
fw_node() is not used (and not useful) outside fw-topology.c. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: adopt read cycle timer ABI from raw1394Stefan Richter
This duplicates the read cycle timer feature of raw1394 (added in Linux 2.6.21) in firewire-core's userspace ABI. The argument to the ioctl is reordered though to ensure 32/64 bit compatibility. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-ohci: check for misconfigured bus (phyID == 63)Stefan Richter
Check NodeID.nodeNumber as per OHCI 1.1 clause 7.2.3.2. See also IEEE 1394a table 5B-1. Also, demote the "node ID not valid" message from error to notification as it is not an error condition. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-ohci: missing dma_unmap_singleStefan Richter
at_context_queue_packet() didn't clean up in an early exit path. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-ohci: log posted write errorsStefan Richter
2007-10-17firewire: fw-ohci: reorder includesStefan Richter
2007-10-17firewire: fw-ohci: fix includesStefan Richter
Add used includes, remove unused includes. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-ohci: enforce read order for selfID generationStefan Richter
It seems unlikely, but access to self_id_cpu[0] could at least in theory be deferred until after the loop over self_id_cpu[1..n] or even after the subsequent reg_read. Enforce the desired order by a read barrier. Also prevent the reg_read from being reordered relative to the for loop. This isn't necessary if the loop's conditional printk counts as an implicit barrier, but better make it explicit. (self_id_cpu[] is a coherent DMA buffer.) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-sbp2: use an own workqueue (fix system responsiveness)Stefan Richter
Firewire-sbp2 did very uncooperative things in the kernel's shared workqueue: Sleeping until reception of management status from the target for up to 2 seconds, and performing SCSI inquiry and all of the setup of SCSI command set drivers via scsi_add_device. If there were transient or permanent error conditions, this caused long blockage of the kernel's events process, noticeable e.g. by blocked keyboard input. We now allocate a workqueue process exclusive to fw-sbp2. As a side effect, this also increases parallelism of fw-sbp2's login and reconnect work versus fw-core's device discovery and device update work which is performed in the shared workqueue. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-sbp2: expose module parameter for workaroundsStefan Richter
On rare occasions, the ability to set one of the workaround flags at runtime may save the day. People who experience I/O errors with firewire-sbp2 while the old sbp2 driver worked for them should try workarounds=1 and report to the devel mailinglist whether that improves things. Firewire-sbp2 defaults to the SCSI stack's maximum transfer size per command, while sbp2 limits them to 128 kBytes. Flag 1 accomplishes just that. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-sbp2: add support for multiple logical units per targetStefan Richter
Fixes "New firewire stack only recognizing half of a chain of drives", https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=242254 Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: fw-sbp2: always enable IRQs before calling command ORB callbackStefan Richter
On IOMMU-less noncoherent architectures, orb->callback will memcpy the whole SCSI command buffer for READ-like SCSI commands. It is therefore friendlier to enable IRQs before the call, like before patch "Add ref-counting for sbp2 orbs". Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Kristian Høgsberg <krh@redhat.com>
2007-10-17firewire: fw-core: local variable shadows a global oneStefan Richter
Sparse warned about it although it was apparently harmless: drivers/firewire/fw-cdev.c:624:23: warning: symbol 'interrupt' shadows an earlier one include/asm/hw_irq.h:29:13: originally declared here Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-17firewire: optimize fw_core_add_address_handlerStefan Richter
Potentially avoids unnecessary loop runs. Guarantee quadlet-aligned starts of address regions. Document the return values. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: ieee1394_core.c: use DEFINE_SPINLOCK for spinlock definitionMatthias Kaehlcke
drivers/ieee1394/ieee1394_core.c: Define spinlock using DEFINE_SPINLOCK instead of assignment to SPIN_LOCK_UNLOCKED Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: csr1212: proper refcountingStefan Richter
At least since nodemgr got rid of coarse global locking, accesses to struct csr1212_keyval's reference counter should be atomic and coupled with proper barriers. Also, calls to csr1212_keep_keyval(kv) should occur before kv is being used. (We probably should convert refcnt to struct kref, but how to keep csr1212_destroy_keyval's implementation non-recursively then?) Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: nodemgr: fix leak of struct csr1212_keyvalStefan Richter
csr1212_keep_keyval(kv) in nodemgr_process_root_directory was unbalanced if ne->vendor_name_kv already exists. This happens for example if eth1394 or raw1394 modify the local config ROM and it is parsed again. As a bonus, the attempt to add the vendor_name_kv sysfs attribute when it already exists is now fixed for good. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: pcilynx: I2C cleanupsJean Delvare
* Delete optional and empty i2c client_register and client_unregister callbacks. * Use the proper i2c adapter ID. * Don't use a template to initialize the i2c_adapter structure, it's inefficient. * Update a misleading comment on why we use i2c_transfer rather than higher level i2c functions. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: Fix kthread stopping in nodemgr_host_threadSatyam Sharma
The nodemgr host thread can exit on its own even when kthread_should_stop is not true, on receiving a signal (might never happen in practice, as it ignores signals). But considering kthread_stop() must not be mixed with kthreads that can exit on their own, I think changing the code like this is clearer. This change means the thread can cut its sleep short when receive a signal but looking at the code around, that sounds okay (and again, it might never actually recieve a signal in practice). Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: sbp2: fix unsafe iteration over list of devicesStefan Richter
sbp2_host_reset and sbp2_handle_status_write are not serialized against sbp2_alloc_device and sbp2_remove_device. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: pcilynx: superfluous local variablesStefan Richter
2007-10-16ieee1394: eth1394: fix lock imbalanceStefan Richter
bad_proto can be reached from points which did not take priv->lock. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-10-16ieee1394: eth1394: superfluous local variableStefan Richter
2007-10-16x86: fix boot error introduced by kbuildSam Ravnborg
x86 uses target specific assignment of EXTRA_AFLAGS, EXTRA_CFLAGS - this caused troubles with introducing asflags-y, ccflags-y. Fixed the target specific assignments in arch/x86/boot/Makefile and auditted the rest of the kernel for similar usage. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-16amd74xx: remove /proc/ide/amd74xxBartlomiej Zolnierkiewicz
This belongs to user-space (and only if really needed). text data bss dec hex filename 6723 2000 28 8751 222f drivers/ide/pci/amd74xx.o.before 3833 2000 16 5849 16d9 drivers/ide/pci/amd74xx.o.after Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16amd74xx/via82cxxx: don't initialize drive->dnBartlomiej Zolnierkiewicz
drive->dn is initialized by ide-probe.c::probe_hwif() so no need to do it in ->init_hwif method. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16sis5513: remove /proc/ide/sisBartlomiej Zolnierkiewicz
This belongs to user-space (and only if really needed). text data bss dec hex filename 7129 404 8 7541 1d75 drivers/ide/pci/sis5513.o.before 3916 404 1 4321 10e1 drivers/ide/pci/sis5513.o.after Additionaly to being bloat the code contained two bugs: - wrong cable bit was checked (0x0001 instead of 0x8000) on ATA_133 chipsets - incorrect UDMA cycle time was reported on ATA_100a/ATA_133 chipsets Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove CONFIG_IDEDMA_ONLYDISKBartlomiej Zolnierkiewicz
ATAPI devices with broken DMA support should be handled by DMA blacklist and for debugging purposes we have new shiny "hdx=nodma" kernel paremeter. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: add "hdx=nodma" kernel parameterBartlomiej Zolnierkiewicz
* Add "hdx=nodma" option allowing user to disallow DMA for a given device. * Obsolete "ide=nodma" option. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove hwif->autodma and drive->autodmaBartlomiej Zolnierkiewicz
* hpt34x.c: disable DMA masks for HPT345 (hwif->autodma is zero so DMA won't be enabled anyway). * trm290.c: disable IDE_HFLAG_TRUST_BIOS_FOR_DMA flag (hwif->autodma is zero so DMA won't be enabled anyway). * Check noautodma global variable instead of drive->autodma in ide_tune_dma(). This fixes handling of "ide=nodma" kernel parameter for icside, ide-cris, au1xxx-ide, pmac, it821x, jmicron, sgiioc4 and siimage host drivers. * Remove hwif->autodma (it was not checked by IDE core code anyway) and drive->autodma (was set by all host drivers - except HPT345/TRM290 special cases - unless "ide=nodma" was used). While at it: - remove needless printk() from icside.c - remove stale FIXME/comment from ide-probe.c - don't force DMA off if PCI bus-mastering had to be enabled in setup-pci.c (this setting was always later over-ridden by host drivers anyway) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove "idex=dma" kernel parameterBartlomiej Zolnierkiewicz
It has been obsoleted since 1 Nov 2004, is valid only when used together with "ide=nodma" kernel parameter (which makes no sense) and only for aec62xx, cmd64x, cs5220, generic, hpt366, sl82c105, tc86c001 and triflex host drivers. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove CONFIG_BLK_DEV_IDEDMA_FORCEDBartlomiej Zolnierkiewicz
This code doesn't use pci_assign_resource() and ide_get_or_set_dma_base() uses pci_resource_start() to get DMA base address so it has no chance of working. Moreover this belongs to PCI quirks (in case somebody would like to fix it). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: use PCI_VDEVICE() macroBartlomiej Zolnierkiewicz
While at it: - make struct pci_device_id tables const - use PCI_DEVICE_ID_ITE_8213 define in it8213.c - fix comment in generic.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16sis5513: clear prefetch and postwrite for ATAPI devicesBartlomiej Zolnierkiewicz
Clear prefetch and postwrite for ATAPI devices instead of depending on BIOS. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16it8213/piix/slc90e66: "de-couple" PIO and UDMA modesBartlomiej Zolnierkiewicz
Don't force PIO4 when programming UDMA mode (suggested by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: unexport noautodmaAdrian Bunk
noautodma can now be unexported. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: unexport ide_tune_dmaAdrian Bunk
static code mustn't be exported. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
