SCM is the protocol used to communicate between the secure and
non-secure code executing on the applications processor. The
non-secure side uses a physically contiguous buffer to pass
information to the secure side; where the buffer conforms to a
format that is agreed upon by both sides. The use of a buffer
allows multiple pending requests to be in flight on the secure
side. It also benefits use cases where the command or response
buffer contains large chunks of data.
Reviewed-by: Saravana Kannan <skannan@codeaurora.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: David Brown <davidb@codeaurora.org>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Constify function scope static struct sched_param usage
sched: Fix strncmp operation
sched: Move sched_autogroup_exit() to free_signal_struct()
sched: Fix struct autogroup memory leak
sched: Mark autogroup_init() __init
sched: Consolidate the name of root_task_group and init_task_group
* 'x86-apic-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: apic: Cleanup and simplify setup_local_APIC()
x86: Further simplify mp_irq info handling
x86: Unify 3 similar ways of saving mp_irqs info
x86, ioapic: Avoid writing io_apic id if already correct
x86, x2apic: Don't map lapic addr for preenabled x2apic systems
x86, sfi: Use register_lapic_address()
x86, apic: Use register_lapic_address() in init_apic_mapping()
x86, apic: Remove early_init_lapic_mapping()
x86, apic: Unify identical register_lapic_address() functions
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
* 'mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC, MCE: Fix NB error formatting
EDAC, MCE: Use BIT_64() to eliminate warnings on 32-bit
EDAC, MCE: Enable MCE decoding on F15h
EDAC, MCE: Allow F15h bank 6 MCE injection
EDAC, MCE: Shorten error report formatting
EDAC, MCE: Overhaul error fields extraction macros
EDAC, MCE: Add F15h FP MCE decoder
EDAC, MCE: Add F15 EX MCE decoder
EDAC, MCE: Add an F15h NB MCE decoder
EDAC, MCE: No F15h LS MCE decoder
EDAC, MCE: Add F15h CU MCE decoder
EDAC, MCE: Add F15h IC MCE decoder
EDAC, MCE: Add F15h DC MCE decoder
EDAC, MCE: Select extended error code mask
* 'edac-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Disable DRAM ECC injection on K8
EDAC: Fixup scrubrate manipulation
amd64_edac: Remove two-stage initialization
amd64_edac: Check ECC capabilities initially
amd64_edac: Carve out ECC-related hw settings
amd64_edac: Remove PCI ECS enabling functions
amd64_edac: Remove explicit Kconfig PCI dependency
amd64_edac: Allocate driver instances dynamically
amd64_edac: Rework printk macros
amd64_edac: Rename CPU PCI devices
amd64_edac: Concentrate per-family init even more
amd64_edac: Cleanup the CPU PCI device reservation
amd64_edac: Simplify CPU family detection
amd64_edac: Add per-family init function
amd64_edac: Use cached extended CPU model
amd64_edac: Remove F11h support
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (65 commits)
[S390] prevent unneccesary loops_per_jiffy recalculation
[S390] cpuinfo: use get_online_cpus() instead of preempt_disable()
[S390] smp: remove cpu hotplug messages
[S390] mutex: enable spinning mutex on s390
[S390] mutex: Introduce arch_mutex_cpu_relax()
[S390] cio: fix ccwgroup unregistration race condition
[S390] perf: add DWARF register lookup for s390
[S390] cleanup ftrace backend functions
[S390] ptrace cleanup
[S390] smp/idle: call init_idle() before starting a new cpu
[S390] smp: delay idle task creation
[S390] dasd: Correct retry counter for terminated I/O.
[S390] dasd: Add support for raw ECKD access.
[S390] dasd: Prevent deadlock during suspend/resume.
[S390] dasd: Improve handling of stolen DASD reservation
[S390] dasd: do path verification for paths added at runtime
[S390] dasd: add High Performance FICON multitrack support
[S390] cio: reduce memory consumption of itcw structures
[S390] nmi: enable machine checks early
[S390] qeth: buffer count imbalance
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'rmobile-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (67 commits)
ARM: mach-shmobile: update for SMP changes.
ARM: mach-shmobile: update for GIC changes.
ARM: mach-shmobile: Fix up clkdev fallout for SH73A0.
dma: shdma: don't register the global die notifier multiple times
ARM: mach-shmobile: Rely on run-time IRQ handlers
ARM: mach-shmobile: Run-time IRQ handler for GIC
ARM: mach-shmobile: Run-time IRQ handler for INTCA
ARM: mach-shmobile: Enable CONFIG_MULTI_IRQ_HANDLER
ARM: mach-shmobile: Use shared GIC entry macros
ARM: mach-shmobile: mackerel: Add zboot support
ARM: mach-shmobile: mackerel: Add HDMI sound support
ARM: mach-shmobile: mackerel: add HDMI video support
ARM: mach-shmobile: ap4evb: fixup clk_put timing of fsib_clk
ARM: mach-shmobile: sh73a0: fix div4 table
ARM: mach-shmobile: ap4/mackerel: modify wrong comment out of USB
ARM: mach-shmobile: Mackerel VGA camera support
mmc: sh_mmcif: make DMA support by the driver unconditional
ARM: mach-shmobile: Add eMMC support through MMCIF on AG5EVM
ARM: mach-shmobile: Use pullups for AG5EVM KEYSC pins
ARM: mach-shmobile: sh73a0 GPIO pullup improvement
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits)
Input: wacom_w8001 - support pen or touch only devices
Input: wacom_w8001 - use __set_bit to set keybits
Input: bu21013_ts - fix misuse of logical operation in place of bitop
Input: i8042 - add Acer Aspire 5100 to the Dritek list
Input: wacom - add support for digitizer in Lenovo W700
Input: psmouse - disable the synaptics extension on OLPC machines
Input: psmouse - fix up Synaptics comment
Input: synaptics - ignore bogus mt packet
Input: synaptics - add multi-finger and semi-mt support
Input: synaptics - report clickpad property
input: mt: Document interface updates
Input: fix double equality sign in uevent
Input: introduce device properties
hid: egalax: Add support for Wetab (726b)
Input: include MT library as source for kerneldoc
MAINTAINERS: Update input-mt entry
hid: egalax: Add support for Samsung NB30 netbook
hid: egalax: Document the new devices in Kconfig
hid: egalax: Convert to MT slots
Fixed up trivial conflict in drivers/input/keyboard/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits)
serial: apbuart: Fixup apbuart_console_init()
TTY: Add tty ioctl to figure device node of the system console.
tty: add 'active' sysfs attribute to tty0 and console device
drivers: serial: apbuart: Handle OF failures gracefully
Serial: Avoid unbalanced IRQ wake disable during resume
tty: fix typos/errors in tty_driver.h comments
pch_uart : fix warnings for 64bit compile
8250: fix uninitialized FIFOs
ip2: fix compiler warning on ip2main_pci_tbl
specialix: fix compiler warning on specialix_pci_tbl
rocket: fix compiler warning on rocket_pci_ids
8250: add a UPIO_DWAPB32 for 32 bit accesses
8250: use container_of() instead of casting
serial: omap-serial: Add support for kernel debugger
serial: fix pch_uart kconfig & build
drivers: char: hvc: add arm JTAG DCC console support
RS485 documentation: add 16C950 UART description
serial: ifx6x60: fix memory leak
serial: ifx6x60: free IRQ on error
Serial: EG20T: add PCH_UART driver
Fixed up conflicts in drivers/serial/apbuart.c with evil merge that
makes the code look fairly sane (unlike either side).
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (144 commits)
USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004)
USB: serial: ftdi_sio: add support for TIOCSERGETLSR
USB: ehci-mxc: Setup portsc register prior to accessing OTG viewport
USB: atmel_usba_udc: fix freeing irq in usba_udc_remove()
usb: ehci-omap: fix tll channel enable mask
usb: ohci-omap3: fix trivial typo
USB: gadget: ci13xxx: don't assume that PAGE_SIZE is 4096
USB: gadget: ci13xxx: fix complete() callback for no_interrupt rq's
USB: gadget: update ci13xxx to work with g_ether
USB: gadgets: ci13xxx: fix probing of compiled-in gadget drivers
Revert "USB: musb: pm: don't rely fully on clock support"
Revert "USB: musb: blackfin: pm: make it work"
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
Manually fix up trivial conflicts in USB Kconfig changes in:
arch/arm/mach-omap2/Kconfig
arch/sh/Kconfig
drivers/usb/Kconfig
drivers/usb/host/ehci-hcd.c
and annoying chip clock data conflicts in:
arch/arm/mach-omap2/clock3xxx_data.c
arch/arm/mach-omap2/clock44xx_data.c
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (147 commits)
[SCSI] arcmsr: fix write to device check
[SCSI] lpfc: lower stack use in lpfc_fc_frame_check
[SCSI] eliminate an unnecessary local variable from scsi_remove_target()
[SCSI] libiscsi: use bh locking instead of irq with session lock
[SCSI] libiscsi: do not take host lock in queuecommand
[SCSI] be2iscsi: fix null ptr when accessing task hdr
[SCSI] be2iscsi: fix gfp use in alloc_pdu
[SCSI] libiscsi: add more informative failure message during iscsi scsi eh
[SCSI] gdth: Add missing call to gdth_ioctl_free
[SCSI] bfa: remove unused defintions and misc cleanups
[SCSI] bfa: remove inactive functions
[SCSI] bfa: replace bfa_assert with WARN_ON
[SCSI] qla2xxx: Use sg_next to fetch next sg element while walking sg list.
[SCSI] qla2xxx: Fix to avoid recursive lock failure during BSG timeout.
[SCSI] qla2xxx: Remove code to not reset ISP82xx on failure.
[SCSI] qla2xxx: Display mailbox register 4 during 8012 AEN for ISP82XX parts.
[SCSI] qla2xxx: Don't perform a BIG_HAMMER if Get-ID (0x20) mailbox command fails on CNAs.
[SCSI] qla2xxx: Remove redundant module parameter permission bits
[SCSI] qla2xxx: Add sysfs node for displaying board temperature.
[SCSI] qla2xxx: Code cleanup to remove unwanted comments and code.
There was a semi-colon missing and it broke the compile.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin
* 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits)
fs: scale mntget/mntput
fs: rename vfsmount counter helpers
fs: implement faster dentry memcmp
fs: prefetch inode data in dcache lookup
fs: improve scalability of pseudo filesystems
fs: dcache per-inode inode alias locking
fs: dcache per-bucket dcache hash locking
bit_spinlock: add required includes
kernel: add bl_list
xfs: provide simple rcu-walk ACL implementation
btrfs: provide simple rcu-walk ACL implementation
ext2,3,4: provide simple rcu-walk ACL implementation
fs: provide simple rcu-walk generic_check_acl implementation
fs: provide rcu-walk aware permission i_ops
fs: rcu-walk aware d_revalidate method
fs: cache optimise dentry and inode for rcu-walk
fs: dcache reduce branches in lookup path
fs: dcache remove d_mounted
fs: fs_struct use seqlock
fs: rcu-walk for path lookup
Function-scope statics are discouraged because they are
easily overlooked and can cause subtle bugs/races due to
their global (non-SMP safe) nature.
Linus noticed that we did this for sched_param - at minimum
make the const.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: Message-ID: <AANLkTinotRxScOHEb0HgFgSpGPkq_6jKTv5CfvnQM=ee@mail.gmail.com>
One of the operands, buf, is incorrect, since it is stripped and the
correct address for subsequent string comparing could change if
leading white spaces, if any, are removed from buf.
It is fixed by replacing buf with cmp.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
LKML-Reference: <AANLkTinOPuYsVovrZpbuCCmG5deEyc8WgA_A1RJx_YK7@mail.gmail.com>
Per Oleg's suggestion, undo fork failure free/put_signal_struct change,
and move sched_autogroup_exit() to free_signal_struct() instead.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
LKML-Reference: <1294222564.8369.6.camel@marge.simson.net>
Seems I lost a change somewhere, leaking memory.
sched: fix struct autogroup memory leak
Add missing change to actually use autogroup_free().
LKML-Reference: <1294222285.8369.2.camel@marge.simson.net>
autogroup_init() is only called at boot time.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1294375425-31065-1-git-send-email-yong.zhang0@gmail.com>
root_task_group is the leftover of USER_SCHED, now it's always
same to init_task_group.
But as Mike suggested, root_task_group is maybe the suitable name
to keep for a tree.
So in this patch:
init_task_group --> root_task_group
init_task_group_load --> root_task_group_load
INIT_TASK_GROUP_LOAD --> ROOT_TASK_GROUP_LOAD
Suggested-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <20110107071736.GA32635@windriver.com>
arch/x86/include/asm/io_apic.h
Merge reason: Resolve the conflict, update to a more recent -rc base
Minor formatting fixup since the information which core was associated
with the MCE is not always valid.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Building for X86_32 produces shift count warnings, so use BIT_64() to
eliminate the warnings.
drivers/edac/mce_amd.c:778: warning: left shift count >= width of type
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: bluesmoke-devel@lists.sourceforge.net
Now that everything is inplace, enable MCE decoding on F15h. Make
initcall routine a bit more readable.
F15h adds a sixth MCE bank: adjust bank number check in the injection
code.
Shorten up MCi_STATUS flags and add BD's new deferred and poison types.
Also, simplify formatting.
Make macro names shorter thus making code shorter and more clear.
Add decoder for FP MCEs.
Integrate the single FIROB signature into an expanded table along with
the new BD MCE types.
by (almost) reusing the F10h one since the signatures are the same.
F15h BD doesn't generate LS MCEs so warn about it.
MCE bank 2 is redefined from a BU to a CU (Combined Unit) bank on F15h.
Add a decoder function for CU MCEs.
Add support for decoding F15h IC MCEs.
Add a decoder for F15h DC MCEs to support the new types of DC MCEs
introduced by the BD microarchitecture.
F15h enlarges the extended error code of an MCE to a 5-bit field
(MCi_STATUS[20:16]). Add a mask variable which default 0xf is overridden
on F15h.
K8 does not allow for an atomic RMW to a cacheline as F10h does so
disable the error injection interface for it.
Make the ->{get|set}_sdram_scrub_rate return the actual scrub rate
bandwidth it succeeded setting and remove superfluous arg pointer used
for that. A negative value returned still means that an error occurred
while setting the scrubrate. Document this for future reference.
Now that all prerequisites are in place, drop the two-stage driver
instances initialization in favor of the following simple init sequence:
1. Probe PCI device: we only test ECC capabilities here and if none exit
early.
2. If the hw supports ECC and it is/can be enabled, we init the per-node
instance.
Remove "amd64_" prefix from static functions touched, while at it.
There actually should be no visible functional change resulting from
this patch.
Rework the code to check the hardware ECC capabilities at PCI probing
time. We do all further initialization only if we actually can/have ECC
enabled.
While at it:
0. Fix function naming.
1. Simplify/clarify debug output.
2. Remove amd64_ prefix from the static functions
3. Reorganize code.
This is in preparation for the init path reorganization where we want
only to
1) test whether a particular node supports ECC
2) can it be enabled
and only then do the necessary allocation/initialization. For that,
we need to decouple the ECC settings of the node from the instance's
descriptor.
The should be no functional change introduced by this patch.
PCI ECS is being enabled by default since 2.6.26 on AMD so this code is
just superfluous now, remove it.
AMD_NB pulls in the dependency on PCI. Clarify/fix help text while at it.
Remove static allocation in favor of dynamically allocating space for as
many driver instances as northbridges present on the system.
There should be no functional change resulting from this patch.
Add a macro per printk level, shorten up error messages. Add relevant
information to KERN_INFO level. No functional change.
Rename variables representing PCI devices to their BKDG names for faster
search and shorter, clearer code.
Move the remaining per-family init code into the proper place and
simplify the rest of the initialization. Reorganize error handling in
amd64_init_one_instance().
Shorten code and clarify comments, return proper -E* values on error.
Concentrate CPU family detection in the per-family init function.
Run a per-family init function which does all the settings based on
the family this driver instance is running on. Move the scrubrate
calculation in it and simplify code.
... instead of computing it needlessly again.
F11h doesn't support DRAM ECC so whack it away.
