2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30sparc32: make show_stack() acquire %fp if @_ksp is not specifiedTejun Heo
show_stack(current or NULL, NULL) is used by arch-independent code to dump backtrace of the current task; however, sparc32 show_stack() doesn't implement it and wouldn't print any backtrace when NULL @_ksp is specfied. Make show_stack() acquire and use %fp if @tsk is NULL or current and @_ksp is NULL. This makes %fp fetching in dump_stack() unnecessary. Make it use NULL for @_ksp instead. Only compile tested. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30x86: don't show trace beyond show_stack(NULL, NULL)Tejun Heo
There are multiple ways a task can be dumped - explicit call to dump_stack(), triggering WARN() or BUG(), through sysrq-t and so on. Most of what gets printed is upto each architecture and the current state is not particularly pretty. Different pieces of information are presented differently depending on which path the dump takes and which architecture it's running on. This is messy for no good reason and makes it exceedingly difficult to add or modify debug information to task dumps. In all archs except for s390, there's nothing arch-specific about the printed debug information. This patchset updates all those archs to use the same helpers to consistently print out the same debug information. An example WARN dump after this patchset. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #3 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f500 ffffffff82228240 0000000000000040 ffffffff8234a08e 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f500>] warn_slowpath_common+0x70/0xa0 [<ffffffff8108f54a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a0c3>] init_workqueues+0x35/0x505 ... And BUG dump. kernel BUG at kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... This patchset contains the following seven patches. 0001-x86-don-t-show-trace-beyond-show_stack-NULL-NULL.patch 0002-sparc32-make-show_stack-acquire-fp-if-_ksp-is-not-sp.patch 0003-dump_stack-consolidate-dump_stack-implementations-an.patch 0004-dmi-morph-dmi_dump_ids-into-dmi_format_ids-which-for.patch 0005-dump_stack-implement-arch-specific-hardware-descript.patch 0006-dump_stack-unify-debug-information-printed-by-show_r.patch 0007-arc-print-fatal-signals-reduce-duplicated-informatio.patch 0001-0002 update stack dumping functions in x86 and sparc32 in preparation. 0003 makes all arches except blackfin use generic dump_stack(). blackfin still uses the generic helper to print the same info. 0004-0005 properly abstract DMI identifier printing in WARN() and show_regs() so that all dumps print out the information. This enables show_regs() to use the same debug info message. 0006 updates show_regs() of all arches to use a common generic helper to print debug info. 0007 removes somem duplicate information from arc dumps. While this patchset changes how debug info is printed on some archs, the printed information is always superset of what used to be there. This patchset makes task dump debug messages consistent and enables adding more information. Workqueue is scheduled to add worker information including the workqueue in use and work item specific description. While this patch touches a lot of archs, it isn't too likely to cause non-trivial conflicts with arch-specfic changes and would probably be best to route together either through -mm. x86 is tested but other archs are either only compile tested or not tested at all. Changes to most archs are generally trivial. This patch: show_stack(current or NULL, NULL) is used to print the backtrace of the current task. As trace beyond the function itself isn't of much interest to anyone, don't show it by determining sp and bp in show_stack()'s frame and passing them to show_stack_log_lvl(). This brings show_stack(NULL, NULL)'s behavior in line with dump_stack(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: David S. Miller <davem@davemloft.net> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/range.c: subtract_range: fix the broken phrase issued by printkLin Feng
Also replace deprecated printk(KERN_ERR...) with pr_err() as suggested by Yinghai, attaching the function name to provide plenty info. Signed-off-by: Lin Feng <linfeng@cn.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30selftest: add simple test for soft-dirty bitPavel Emelyanov
It creates a mapping of 3 pages and checks that reads, writes and clear-refs result in present and soft-dirt bits reported from pagemap2 set as expected. [akpm@linux-foundation.org: alphasort the Makefile TARGETS to reduce rejects] Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30staging: zcache: enable zcache to be built/loaded as a moduleDan Magenheimer
Allow zcache to be built/loaded as a module. Note runtime dependency disallows loading if cleancache/frontswap lazy initialization patches are not present. Zsmalloc support has not yet been merged into zcache but, once merged, could now easily be selected via a module_param. If built-in (not built as a module), the original mechanism of enabling via a kernel boot parameter is retained, but this should be considered deprecated. Note that module unload is explicitly not yet supported. Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> [v1: Rebased with different order of patches] [v2: Removed [CLEANCACHE|FRONTSWAP]_HAS_LAZY_INIT ifdef] [v3: Rebased on top of ramster->zcache move] [v4: Redid the Makefile] [v5: s/ZCACHE2/ZCACHE/] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30staging: zcache: enable ramster to be built/loaded as a moduleDan Magenheimer
Enable module support for ramster. Note runtime dependency disallows loading if cleancache/frontswap lazy initialization patches are not present. If built-in (not built as a module), the original mechanism of enabling via a kernel boot parameter is retained, but this should be considered deprecated. Note that module unload is explicitly not yet supported. [v1: Fixed compile issues since ramster_init now has four arguments] [v2: Fixed rebase on ramster->zcache move] [akpm@linux-foundation.org: use_frontswap_selfshrink cannot be __initdata] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30zcache/tmem: Better error checking on frontswap_register_ops return value.Konrad Rzeszutek Wilk
In the past it either used to be NULL or the "older" backend. Now we also return -Exx error codes. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30xen: tmem: enable Xen tmem shim to be built/loaded as a moduleDan Magenheimer
Allow Xen tmem shim to be built/loaded as a module. Xen self-ballooning and frontswap-selfshrinking are now also "lazily" initialized when the Xen tmem shim is loaded as a module, unless explicitly disabled by module parameters. Note runtime dependency disallows loading if cleancache/frontswap lazy initialization patches are not present. If built-in (not built as a module), the original mechanism of enabling via a kernel boot parameter is retained, but this should be considered deprecated. Note that module unload is explicitly not yet supported. [v1: Removed the [CLEANCACHE|FRONTSWAP]_HAS_LAZY_INIT ifdef] [v2: Squashed the xen/tmem: Remove the subsys call patch in] [akpm@linux-foundation.org: fix build (disable_frontswap_selfshrinking undeclared)] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30mm: cleancache: clean up cleancache_enabledBob Liu
cleancache_ops is used to decide whether backend is registered. So now cleancache_enabled is always true if defined CONFIG_CLEANCACHE. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30cleancache: Make cleancache_init use a pointer for the opsKonrad Rzeszutek Wilk
Instead of using a backend_registered to determine whether a backend is enabled. This allows us to remove the backend_register check and just do 'if (cleancache_ops)' [v1: Rebase on top of b97c4b430b0a (ramster->zcache move] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30mm: cleancache: lazy initialization to allow tmem backends to build/run as ↵Dan Magenheimer
modules With the goal of allowing tmem backends (zcache, ramster, Xen tmem) to be built/loaded as modules rather than built-in and enabled by a boot parameter, this patch provides "lazy initialization", allowing backends to register to cleancache even after filesystems were mounted. Calls to init_fs and init_shared_fs are remembered as fake poolids but no real tmem_pools created. On backend registration the fake poolids are mapped to real poolids and respective tmem_pools. Signed-off-by: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Florian Schmaus <fschmaus@gmail.com> Signed-off-by: Andor Daam <andor.daam@googlemail.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> [v1: Minor fixes: used #define for some values and bools] [v2: Removed CLEANCACHE_HAS_LAZY_INIT] [v3: Added more comments, added a lock for [shared_|]fs_poolid_map] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30frontswap: get rid of swap_lock dependencyMinchan Kim
Frontswap initialization routine depends on swap_lock, which want to be atomic about frontswap's first appearance. IOW, frontswap is not present and will fail all calls OR frontswap is fully functional but if new swap_info_struct isn't registered by enable_swap_info, swap subsystem doesn't start I/O so there is no race between init procedure and page I/O working on frontswap. So let's remove unnecessary swap_lock dependency. Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Minchan Kim <minchan@kernel.org> [v1: Rebased on my branch, reworked to work with backends loading late] [v2: Added a check for !map] [v3: Made the invalidate path follow the init path] [v4: Address comments by Wanpeng Li <liwanp@linux.vnet.ibm.com>] Signed-off-by: Konrad Rzeszutek Wilk <konrad@darnok.org> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30mm: frontswap: cleanup codeBob Liu
After allowing tmem backends to build/run as modules, frontswap_enabled always true if defined CONFIG_FRONTSWAP. But frontswap_test() depends on whether backend is registered, mv it into frontswap.c using fronstswap_ops to make the decision. frontswap_set/clear are not used outside frontswap, so don't export them. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30frontswap: make frontswap_init use a pointer for the opsKonrad Rzeszutek Wilk
This simplifies the code in the frontswap - we can get rid of the 'backend_registered' test and instead check against frontswap_ops. [v1: Rebase on top of 703ba7fe5e0 (ramster->zcache move] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30mm: frontswap: lazy initialization to allow tmem backends to build/run as ↵Dan Magenheimer
modules With the goal of allowing tmem backends (zcache, ramster, Xen tmem) to be built/loaded as modules rather than built-in and enabled by a boot parameter, this patch provides "lazy initialization", allowing backends to register to frontswap even after swapon was run. Before a backend registers all calls to init are recorded and the creation of tmem_pools delayed until a backend registers or until a frontswap store is attempted. Signed-off-by: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Florian Schmaus <fschmaus@gmail.com> Signed-off-by: Andor Daam <andor.daam@googlemail.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> [v1: Fixes per Seth Jennings suggestions] [v2: Removed FRONTSWAP_HAS_.. ] [v3: Fix up per Bob Liu <lliubbo@gmail.com> recommendations] [v4: Fix up per Andrew's comments] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30fs/dcache.c: add cond_resched() to shrink_dcache_parent()Greg Thelen
Call cond_resched() in shrink_dcache_parent() to maintain interactivity. Before this patch: void shrink_dcache_parent(struct dentry * parent) { while ((found = select_parent(parent, &dispose)) != 0) shrink_dentry_list(&dispose); } select_parent() populates the dispose list with dentries which shrink_dentry_list() then deletes. select_parent() carefully uses need_resched() to avoid doing too much work at once. But neither shrink_dcache_parent() nor its called functions call cond_resched(). So once need_resched() is set select_parent() will return single dentry dispose list which is then deleted by shrink_dentry_list(). This is inefficient when there are a lot of dentry to process. This can cause softlockup and hurts interactivity on non preemptable kernels. This change adds cond_resched() in shrink_dcache_parent(). The benefit of this is that need_resched() is quickly cleared so that future calls to select_parent() are able to efficiently return a big batch of dentry. These additional cond_resched() do not seem to impact performance, at least for the workload below. Here is a program which can cause soft lockup if other system activity sets need_resched(). int main() { struct rlimit rlim; int i; int f[100000]; char buf[20]; struct timeval t1, t2; double diff; /* cleanup past run */ system("rm -rf x"); /* boost nfile rlimit */ rlim.rlim_cur = 200000; rlim.rlim_max = 200000; if (setrlimit(RLIMIT_NOFILE, &rlim)) err(1, "setrlimit"); /* make directory for files */ if (mkdir("x", 0700)) err(1, "mkdir"); if (gettimeofday(&t1, NULL)) err(1, "gettimeofday"); /* populate directory with open files */ for (i = 0; i < 100000; i++) { snprintf(buf, sizeof(buf), "x/%d", i); f[i] = open(buf, O_CREAT); if (f[i] == -1) err(1, "open"); } /* close some of the files */ for (i = 0; i < 85000; i++) close(f[i]); /* unlink all files, even open ones */ system("rm -rf x"); if (gettimeofday(&t2, NULL)) err(1, "gettimeofday"); diff = (((double)t2.tv_sec * 1000000 + t2.tv_usec) - ((double)t1.tv_sec * 1000000 + t1.tv_usec)); printf("done: %g elapsed\n", diff/1e6); return 0; } Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30fs/block_dev.c: no need to check inode->i_bdev in bd_forget()Yan Hong
Its only caller evict() has promised a non-NULL inode->i_bdev. Signed-off-by: Yan Hong <clouds.yan@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30inotify: invalid mask should return a error number but not set itZhao Hongjiang
When we run the crackerjack testsuite, the inotify_add_watch test is stalled. This is caused by the invalid mask 0 - the task is waiting for the event but it never comes. inotify_add_watch() should return -EINVAL as it did before commit 676a0675cf92 ("inotify: remove broken mask checks causing unmount to be EINVAL"). That commit removes the invalid mask check, but that check is needed. Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call. If none are set, just return -EINVAL. Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger the problem that above commit fixed. [akpm@linux-foundation.org: fix build] Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Acked-by: Jim Somerville <Jim.Somerville@windriver.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Eric Paris <eparis@parisplace.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30memory hotplug: fix warningsVincent Stehlé
Fix the following compilation warnings: mm/slab.c: In function `kmem_cache_init_late': mm/slab.c:1778:2: warning: statement with no effect [-Wunused-value] mm/page_cgroup.c: In function `page_cgroup_init': mm/page_cgroup.c:305:2: warning: statement with no effect [-Wunused-value] Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30drivers/usb/storage/realtek_cr.c: fix buildAndrew Morton
Remove unused local `us', which broke the build. Also nuke an unneeded cast. Repairs commit 191648d03d20 ("usb: storage: Convert US_DEBUGP to usb_stor_dbg"). Cc: Joe Perches <joe@perches.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 update from Catalin Marinas: "Main features: - Versatile Express SoC (model) support - DT files and Kconfig entries (there are no arch/arm64/mach-* directories). The bulk of the code has already been moved to drivers/ as part of the ARM SoC clean-up. - Basic multi-cluster support (CPU logical map initialised from the DT) - Simple earlyprintk support for UART 8250/16550 and FastModel console output - Optimised kernel library bitops and string functions. - Automatic initialisation of the irqchip and clocks via DT" * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (26 commits) arm64: Use acquire/release semantics instead of explicit DMB arm64: klib: bitops: fix unpredictable stxr usage arm64: vexpress: Enable ARMv8 RTSM model (SoC) support arm64: vexpress: Add dts files for the ARMv8 RTSM models arm64: Survive invalid cpu enable-methods arm64: mm: Correct show_pte behaviour arm64: Fix compat types affecting struct compat_stat arm64: Execute DSB during thread switching for TLB/cache maintenance arm64: compiling issue, need add include/asm/vga.h file arm64: smp: honour #address-size when parsing CPU reg property arm64: Define cmpxchg64 and cmpxchg64_local for outside use arm64: Define readq and writeq for driver module using arm64: Fix task tracing arm64: add explicit symbols to ESR_EL1 decoding arm64: Use irqchip_init() for interrupt controller initialisation arm64: psci: Use the MPIDR values from cpu_logical_map for cpu ids. arm64: klib: Optimised atomic bitops arm64: klib: Optimised string functions arm64: klib: Optimised memory functions arm64: head: match all affinity levels in the pen of the secondaries ...
2013-04-30Merge tag 'metag-for-v3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull arch/metag update from James Hogan: - Various fixes for the interrupting perf counter handling in metag's perf backend. - Add OProfile support based on perf. - Sets up cache partitions for SMP so bootloader doesn't have to. - Patch from Paul Bolle to remove ARCH_POPULATES_NODE_MAP again (touches microblaze too). - Add TLS pointer regset to metag ptrace api. - Add exported metag DSP extended context handling header <asm/ech.h>. - Increase defconfig log buffer size to 128KiB. - Various fixes, typos, missing exports. * tag 'metag-for-v3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: metag: defconfigs: increase log buffer 8KiB => 128KiB metag: avoid unnecessary builtin dtb rebuilds metag: add exported <asm/ech.h> for extended context handling metag: export _metag_da_present and cpu_2_hwthread_id metag: ptrace: Implement NT_METAG_TLS memblock: Kill ARCH_POPULATES_NODE_MAP once more metag: cachepart: fix get_global_dcache_size() typo metag: cachepart: take into account small cache bits metag: smp: copy cache partition and enable GCOn metag: OProfile support metag: perf: prepare for use by oprofile metag: perf: don't reset TXTACTCYC metag: perf: use hard_processor_id() to get thread metag: perf: fix frequency sampling (dynamic period) metag: perf: add missing prev_count updates metag: perf: fixes for interrupting perf counters metag: perf: fix wrap handling in delta calculation metag: perf: fix core internal / perf channel mux
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k update from Geert Uytterhoeven. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Remove inline strlen() implementation m68k/atari: USB - add platform devices for EtherNAT/NetUSBee ISP1160 HCD m68k: Implement ndelay() based on the existing udelay() logic m68k/atari: EtherNAT - add interrupt chip definition for CPLD interrupts m68k/atari: EtherNEC - add platform device support m68k/atari: EtherNAT - platform device and IRQ support code m68k/atari: use dedicated irq_chip for timer D interrupts m68k/atari: ROM port ISA adapter support m68k: Add missing cmpxchg64() if CONFIG_RMW_INSNS=y
2013-04-30Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac Pull edac fixes from Mauro Carvalho Chehab: "Two edac fixes: - i7300_edac currently reports a wrong number of DIMMs when the memory controller is in single channel mode - on some Sandy Bridge machines, the EDAC driver bails out as one of the PCI IDs used by the driver is hidden by BIOS. As the driver uses it only to detect the type of memory, make it optional at the driver" * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: edac: sb_edac.c should not require prescence of IMC_DDRIO device i7300_edac: Fix memory detection in single mode
2013-04-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media update from Mauro Carvalho Chehab: - OF documentation and patches at core and drivers, to be used by for embedded media systems - some I2C drivers used on go7007 were rewritten/promoted from staging: sony-btf-mpx, tw2804, tw9903, tw9906, wis-ov7640, wis-uda1342 - add fimc-is driver (Exynos) - add a new radio driver: radio-si476x - add a two new tuners: r820t and tuner_it913x - split camera code on em28xx driver and add more models - the cypress firmware load is used outside dvb usb drivers. So, move it to a common directory to make easier to re-use it - siano media driver updated to work with sms2270 devices - several work done in order to promote go7007 and solo6x1x out of staging (still, there are some pending issues) - several API compliance fixes at v4l2 drivers that don't behave as expected - as usual, lots of driver fixes, improvements, cleanups and new device addition at the existing drivers. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (831 commits) [media] cx88: make core less verbose [media] em28xx: fix oops at em28xx_dvb_bus_ctrl() [media] s5c73m3: fix indentation of the help section in Kconfig [media] cx25821-alsa: get rid of a __must_check warning [media] cx25821-video: declare cx25821_vidioc_s_std as static [media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap [media] r820t: Remove a warning for an unused value [media] dib0090: Fix a warning at dib0090_set_EFUSE [media] dib8000: fix a warning [media] dib8000: Fix sub-channel range [media] dib8000: store dtv_property_cache in a temp var [media] dib8000: warning fix: declare internal functions as static [media] r820t: quiet gcc warning on n_ring [media] r820t: memory leak in release() [media] r820t: precendence bug in r820t_xtal_check() [media] videodev2.h: Remove the unused old V4L1 buffer types [media] anysee: Grammar s/report the/report to/ [media] anysee: Initialize ret = 0 in anysee_frontend_attach() [media] media: videobuf2: fix the length check for mmap [media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0 ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - hid driver transport cleanup, finalizing the long-desired decoupling of core from transport layers, by Benjamin Tissoires and Henrik Rydberg - support for hybrid finger/pen multitouch HID devices, by Benjamin Tissoires - fix for long-standing issue in Logitech unifying driver sometimes not inializing properly due to device specifics, by Andrew de los Reyes - Wii remote driver updates to support 2nd generation of devices, by David Herrmann - support for Apple IR remote - roccat driver now supports new devices (Roccat Kone Pure, IskuFX), by Stefan Achatz - debugfs locking fixes in hid debug interface, by Jiri Kosina * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (43 commits) HID: protect hid_debug_list HID: debug: break out hid_dump_report() into hid-debug HID: Add PID for Japanese version of NE4K keyboard HID: hid-lg4ff add support for new version of DFGT wheel HID: icade: u16 which never < 0 HID: clarify Magic Mouse Kconfig description HID: appleir: add support for Apple ir devices HID: roccat: added media key support for Kone HID: hid-lenovo-tpkbd: remove doubled hid_get_drvdata HID: i2c-hid: fix length for set/get report in i2c hid HID: wiimote: parse reduced status reports HID: wiimote: add 2nd generation Wii Remote IDs HID: wiimote: use unique battery names HID: hidraw: warn if userspace headers are outdated HID: multitouch: force BTN_STYLUS for pen devices HID: multitouch: append " Pen" to the name of the stylus input HID: multitouch: add handling for pen in dual-sensors device HID: multitouch: change touch sensor detection in mt_input_configured() HID: multitouch: do not map usage from non used reports HID: multitouch: breaks out touch handling in specific functions ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: - Add an Intel CMCI hotplug fix - Add AMD family 16h EDAC support - Make the AMD MCE banks code more flexible for virtual environments * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: amd64_edac: Add Family 16h support x86/mce: Rework cmci_rediscover() to play well with CPU hotplug x86, MCE, AMD: Use MCG_CAP MSR to find out number of banks on AMD x86, MCE, AMD: Replace shared_bank array with is_shared_bank() helper
2013-04-30Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform changes from Ingo Molnar: "Small fixes and cleanups all over the map" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/setup: Drop unneeded include <asm/dmi.h> x86/olpc/xo1/sci: Don't call input_free_device() after input_unregister_device() x86/platform/intel/mrst: Remove cast for kmalloc() return value x86/platform/uv: Replace kmalloc() & memset with kzalloc()
2013-04-30Merge branch 'x86-paravirt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 paravirt update from Ingo Molnar: "Various paravirtualization related changes - the biggest one makes guest support optional via CONFIG_HYPERVISOR_GUEST" * 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, wakeup, sleep: Use pvops functions for changing GDT entries x86, xen, gdt: Remove the pvops variant of store_gdt. x86-32, gdt: Store/load GDT for ACPI S3 or hibernation/resume path is not needed x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed. x86: Make Linux guest support optional x86, Kconfig: Move PARAVIRT_DEBUG into the paravirt menu
2013-04-30Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "Misc smaller changes all over the map" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/iommu/dmar: Remove warning for HPET scope type x86/mm/gart: Drop unnecessary check x86/mm/hotplug: Put kernel_physical_mapping_remove() declaration in CONFIG_MEMORY_HOTREMOVE x86/mm/fixmap: Remove unused FIX_CYCLONE_TIMER x86/mm/numa: Simplify some bit mangling x86/mm: Re-enable DEBUG_TLBFLUSH for X86_32 x86/mm/cpa: Cleanup split_large_page() and its callee x86: Drop always empty .text..page_aligned section
2013-04-30Merge branch 'x86-kaslr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perparatory x86 kasrl changes from Ingo Molnar: "This contains changes from the ongoing KASLR work, by Kees Cook. The main changes are the use of a read-only IDT on x86 (which decouples the userspace visible virtual IDT address from the physical address), and a rework of ELF relocation support, in preparation of random, boot-time kernel image relocation." * 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, relocs: Refactor the relocs tool to merge 32- and 64-bit ELF x86, relocs: Build separate 32/64-bit tools x86, relocs: Add 64-bit ELF support to relocs tool x86, relocs: Consolidate processing logic x86, relocs: Generalize ELF structure names x86: Use a read-only IDT alias on all CPUs
2013-04-30Merge branch 'x86-debug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 debug update from Ingo Molnar: "Two small changes: a documentation update and a constification" * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, early-printk: Update earlyprintk documentation (and kill x86 copy) x86: Constify a few items
2013-04-30Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cpuid changes from Ingo Molnar: "The biggest change is x86 CPU bug handling refactoring and cleanups, by Borislav Petkov" * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, CPU, AMD: Drop useless label x86, AMD: Correct {rd,wr}msr_amd_safe warnings x86: Fold-in trivial check_config function x86, cpu: Convert AMD Erratum 400 x86, cpu: Convert AMD Erratum 383 x86, cpu: Convert Cyrix coma bug detection x86, cpu: Convert FDIV bug detection x86, cpu: Convert F00F bug detection x86, cpu: Expand cpufeature facility to include cpu bugs
2013-04-30Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cleanups from Ingo Molnar: "Misc smaller cleanups" * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/lib: Fix spelling, put space between a numeral and its units x86/lib: Fix spelling in the comments x86, quirks: Shut-up a long-standing gcc warning x86, msr: Unify variable names x86-64, docs, mm: Add vsyscall range to virtual address space layout x86: Drop KERNEL_IMAGE_START x86_64: Use __BOOT_DS instead_of __KERNEL_DS for safety
2013-04-30Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull extable dmesg fixlet from Ingo Molnar: "Small tweak to reduce kmsg boot time spam" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: extable: Flip the sorting message
2013-04-30Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core timer updates from Ingo Molnar: "The main changes in this cycle's merge are: - Implement shadow timekeeper to shorten in kernel reader side blocking, by Thomas Gleixner. - Posix timers enhancements by Pavel Emelyanov: - allocate timer ID per process, so that exact timer ID allocations can be re-created be checkpoint/restore code. - debuggability and tooling (/proc/PID/timers, etc.) improvements. - suspend/resume enhancements by Feng Tang: on certain new Intel Atom processors (Penwell and Cloverview), there is a feature that the TSC won't stop in S3 state, so the TSC value won't be reset to 0 after resume. This can be taken advantage of by the generic via the CLOCK_SOURCE_SUSPEND_NONSTOP flag: instead of using the RTC to recover/approximate sleep time, the main (and precise) clocksource can be used. - Fix /proc/timer_list for 4096 CPUs by Nathan Zimmer: on so many CPUs the file goes beyond 4MB of size and thus the current simplistic seqfile approach fails. Convert /proc/timer_list to a proper seq_file with its own iterator. - Cleanups and refactorings of the core timekeeping code by John Stultz. - International Atomic Clock time is managed by the NTP code internally currently but not exposed externally. Separate the TAI code out and add CLOCK_TAI support and TAI support to the hrtimer and posix-timer code, by John Stultz. - Add deep idle support enhacement to the broadcast clockevents core timer code, by Daniel Lezcano: add an opt-in CLOCK_EVT_FEAT_DYNIRQ clockevents feature (which will be utilized by future clockevents driver updates), which allows the use of IRQ affinities to avoid spurious wakeups of idle CPUs - the right CPU with an expiring timer will be woken. - Add new ARM bcm281xx clocksource driver, by Christian Daudt - ... various other fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits) clockevents: Set dummy handler on CPU_DEAD shutdown timekeeping: Update tk->cycle_last in resume posix-timers: Remove unused variable clockevents: Switch into oneshot mode even if broadcast registered late timer_list: Convert timer list to be a proper seq_file timer_list: Split timer_list_show_tickdevices posix-timers: Show sigevent info in proc file posix-timers: Introduce /proc/PID/timers file posix timers: Allocate timer id per process (v2) timekeeping: Make sure to notify hrtimers when TAI offset changes hrtimer: Fix ktime_add_ns() overflow on 32bit architectures hrtimer: Add expiry time overflow check in hrtimer_interrupt timekeeping: Shorten seq_count region timekeeping: Implement a shadow timekeeper timekeeping: Delay update of clock->cycle_last timekeeping: Store cycle_last value in timekeeper struct as well ntp: Remove ntp_lock, using the timekeeping locks to protect ntp state timekeeping: Simplify tai updating from do_adjtimex timekeeping: Hold timekeepering locks in do_adjtimex and hardpps timekeeping: Move ADJ_SETOFFSET to top level do_adjtimex() ...
2013-04-30arm64: Use acquire/release semantics instead of explicit DMBCatalin Marinas
This patch changes the test_and_*_bit functions to use the load-acquire/store-release instructions instead of explicit DMB. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-04-30arm64: klib: bitops: fix unpredictable stxr usageMark Rutland
We're currently relying on unpredictable behaviour in our testops (test_and_*_bit), as stxr is unpredictable when the status register and the source register are the same This patch changes reallocates the status register so as to bring us back into the realm of predictable behaviour. Boot tested on an AEMv8 model. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-30Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this development cycle were: - full dynticks preparatory work by Frederic Weisbecker - factor out the cpu time accounting code better, by Li Zefan - multi-CPU load balancer cleanups and improvements by Joonsoo Kim - various smaller fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) sched: Fix init NOHZ_IDLE flag sched: Prevent to re-select dst-cpu in load_balance() sched: Rename load_balance_tmpmask to load_balance_mask sched: Move up affinity check to mitigate useless redoing overhead sched: Don't consider other cpus in our group in case of NEWLY_IDLE sched: Explicitly cpu_idle_type checking in rebalance_domains() sched: Change position of resched_cpu() in load_balance() sched: Fix wrong rq's runnable_avg update with rt tasks sched: Document task_struct::personality field sched/cpuacct/UML: Fix header file dependency bug on the UML build cgroup: Kill subsys.active flag sched/cpuacct: No need to check subsys active state sched/cpuacct: Initialize cpuacct subsystem earlier sched/cpuacct: Initialize root cpuacct earlier sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically sched/cpuacct: Clean up cpuacct.h sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field() sched/cpuacct: Remove redundant NULL checks in cpuacct_charge() sched/cpuacct: Add cpuacct_acount_field() sched/cpuacct: Add cpuacct_init() ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-30Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "The main changes in this cycle are mostly related to preparatory work for the full-dynticks work: - Remove restrictions on no-CBs CPUs, make RCU_FAST_NO_HZ take advantage of numbered callbacks, do callback accelerations based on numbered callbacks. Posted to LKML at https://lkml.org/lkml/2013/3/18/960 - RCU documentation updates. Posted to LKML at https://lkml.org/lkml/2013/3/18/570 - Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/3/18/594" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rcu: Make rcu_accelerate_cbs() note need for future grace periods rcu: Abstract rcu_start_future_gp() from rcu_nocb_wait_gp() rcu: Rename n_nocb_gp_requests to need_future_gp rcu: Push lock release to rcu_start_gp()'s callers rcu: Repurpose no-CBs event tracing to future-GP events rcu: Rearrange locking in rcu_start_gp() rcu: Make RCU_FAST_NO_HZ take advantage of numbered callbacks rcu: Accelerate RCU callbacks at grace-period end rcu: Export RCU_FAST_NO_HZ parameters to sysfs rcu: Distinguish "rcuo" kthreads by RCU flavor rcu: Add event tracing for no-CBs CPUs' grace periods rcu: Add event tracing for no-CBs CPUs' callback registration rcu: Introduce proper blocking to no-CBs kthreads GP waits rcu: Provide compile-time control for no-CBs CPUs rcu: Tone down debugging during boot-up and shutdown. rcu: Add softirq-stall indications to stall-warning messages rcu: Documentation update rcu: Make bugginess of code sample more evident rcu: Fix hlist_bl_set_first_rcu() annotation rcu: Delete unused rcu_node "wakemask" field ...
2013-04-30tracing: Fix small merge bugSteven Rostedt
During the 3.10 merge, a conflict happened and the resolution was almost, but not quite, correct. An if statement was reversed. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> [ Duh. That was just silly of me - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge tag 'localmodconfig-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig Pull localmodconfig changes from Steven Rostedt: "A bug was recently found in the make localmodconfig where it would miss dependencies of config files are include in other config files inside an if statement. Also added a debug print that helped in solving this bug." * tag 'localmodconfig-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig: localmodconfig: Process source kconfig files as they are found localmodconfig: Add debug prints for dependencies of module configs
2013-04-30Merge branch 'devel-for-v3.10' into v4l_for_linusMauro Carvalho Chehab
* patchwork: (831 commits) [media] cx88: make core less verbose [media] em28xx: fix oops at em28xx_dvb_bus_ctrl() [media] s5c73m3: fix indentation of the help section in Kconfig [media] cx25821-alsa: get rid of a __must_check warning [media] cx25821-video: declare cx25821_vidioc_s_std as static [media] cx25821-video: remove maxw from cx25821_vidioc_try_fmt_vid_cap [media] r820t: Remove a warning for an unused value [media] dib0090: Fix a warning at dib0090_set_EFUSE [media] dib8000: fix a warning [media] dib8000: Fix sub-channel range [media] dib8000: store dtv_property_cache in a temp var [media] dib8000: warning fix: declare internal functions as static [media] r820t: quiet gcc warning on n_ring [media] r820t: memory leak in release() [media] r820t: precendence bug in r820t_xtal_check() [media] videodev2.h: Remove the unused old V4L1 buffer types [media] anysee: Grammar s/report the/report to/ [media] anysee: Initialize ret = 0 in anysee_frontend_attach() [media] media: videobuf2: fix the length check for mmap [media] em28xx: save isoc endpoint number for DVB only if endpoint has alt settings with xMaxPacketSize != 0 ... Conflicts: drivers/media/pci/cx25821/cx25821-video.c drivers/media/platform/Kconfig
2013-04-30Merge tag 'v3.9' into v4l_for_linusMauro Carvalho Chehab
Linux 3.9 * tag 'v3.9': (1099 commits) Linux 3.9 vm: add no-mmu vm_iomap_memory() stub efivars: only check for duplicates on the registered list TTY: fix atime/mtime regression aio: fix possible invalid memory access when DEBUG is enabled parisc: use spin_lock_irqsave/spin_unlock_irqrestore for PTE updates parisc: disable -mlong-calls compiler option for kernel modules parisc: uaccess: fix compiler warnings caused by __put_user casting parisc: Change kunmap macro to static inline function parisc: Provide __ucmpdi2 to resolve undefined references in 32 bit builds. sparc64: Fix missing put_cpu_var() in tlb_batch_add_one() when not batching. Revert "gpio: pxa: set initcall level to module init" efi: Check EFI revision in setup_efi_vars x86, efi: Fix a build warning Revert "MIPS: page.h: Provide more readable definition for PAGE_MASK." kernel/hz.bc: ignore. Linux 3.9-rc8 events: Protect access via task_subsys_state_check() net: fix incorrect credentials passing x86, microcode: Verify the family before dispatching microcode patching ...
2013-04-30Merge branches 'for-3.10/wiimote' and 'for-3.9/upstream-fixes' into for-linusJiri Kosina
2013-04-30Merge branches 'for-3.10/multitouch', 'for-3.10/roccat' and ↵Jiri Kosina
'for-3.10/upstream' into for-linus Conflicts: drivers/hid/Kconfig
