2008-04-17Introduce down_killable()Matthew Wilcox
down_killable() is the functional counterpart of mutex_lock_killable. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Add semaphore.h to kernel_lock.cMatthew Wilcox
kernel_lock.c uses DECLARE_MUTEX, up() and down() without explicitly including asm/semaphore.h. This is fragile and leaves it vulnerable to breakage during header reorganisations. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-17Fix quota.h includesMatthew Wilcox
quota.h currently relies on asm/semaphore.h (through some chain; it doesn't actually include semaphore.h itself) to include wait.h. As well as being bad practice to rely on an implicit include, subsequent patches will break this. While I'm in this file, add atomic.h and list.h, and sort the list of includes. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-16Linux 2.6.25v2.6.25Linus Torvalds
2008-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: it821x: do not describe noraid parameter with its value Pb1200/DBAu1200: fix bad IDE resource size Au1200: IDE driver build fix Au1200: kill IDE driver function prototypes avr32 mustn't select HAVE_IDE
2008-04-17it821x: do not describe noraid parameter with its valuePaul Bolle
Describe noraid parameter with its name (and not its value). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Pb1200/DBAu1200: fix bad IDE resource sizeSergei Shtylyov
The header files for the Pb1200/DBAu1200 boards have wrong definition for the IDE interface's decoded range length -- it should be 512 bytes according to what the IDE driver does. In addition, the IDE platform device claims 1 byte too many for its memory resource -- fix the platform code and the IDE driver in accordance. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Au1200: IDE driver build fixSergei Shtylyov
The driver fails to compile with CONFIG_BLK_DEV_IDE_AU1XXX_MDMA2_DBDMA enabled: drivers/ide/mips/au1xxx-ide.c: In function `auide_build_dmatable': drivers/ide/mips/au1xxx-ide.c:256: error: implicit declaration of function `sg_virt' drivers/ide/mips/au1xxx-ide.c:275: error: implicit declaration of function `sg_next' drivers/ide/mips/au1xxx-ide.c:275: warning: assignment makes pointer from integer without a cast Fix this by including <linux/scatterlist.h>. While at it, remove the #include's without which the driver happily builds. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Au1200: kill IDE driver function prototypesSergei Shtylyov
Fix these warnings emitted when compiling drivers/ide/mips/au1xxx-ide.c: include/asm/mach-au1x00/au1xxx_ide.h:137: warning: 'auide_tune_drive' declared `static' but never defined include/asm/mach-au1x00/au1xxx_ide.h:138: warning: 'auide_tune_chipset' declared `static' but never defined by wiping out the whole "function prototyping" section from the header file <asm-mips/mach-au1x00/au1xxx_ide.h> as it mostly declared functions that are already dead in the IDE driver; move the only useful prototype into the driver. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17avr32 mustn't select HAVE_IDEAdrian Bunk
There's a libata based PATA driver for avr32, but no support for drivers/ide/ on avr32. This patch fixes the following compile error: <-- snip --> ... CC [M] drivers/ide/ide-cd.o In file included from /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/ide/ide-cd.c:37: /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/ide.h:209:21: error: asm/ide.h: No such file or directory make[3]: *** [drivers/ide/ide-cd.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-16Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: update git url for blktrace io context: increment task attachment count in ioc_task_link()
2008-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: remove broken usb-serial num_endpoints check USB: option: Add new vendor ID and device ID for AMOI HSDPA modem USB: support more Huawei data card product IDs USB: option.c: add more device IDs USB: Obscure Maxon BP3-USB Device Support 16d8:6280 for option driver
2008-04-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [TCP]: Add return value indication to tcp_prune_ofo_queue(). PS3: gelic: fix the oops on the broken IE returned from the hypervisor b43legacy: fix DMA mapping leakage mac80211: remove message on receiving unexpected unencrypted frames Update rt2x00 MAINTAINERS entry Add rfkill to MAINTAINERS file rfkill: Fix device type check when toggling states b43legacy: Fix usage of struct device used for DMAing ssb: Fix usage of struct device used for DMAing MAINTAINERS: move to generic repository for iwlwifi b43legacy: fix initvals loading on bcm4303 rtl8187: Add missing priv->vif assignments netconsole: only set CON_PRINTBUFFER if the user specifies a netconsole [CAN]: Update documentation of struct sockaddr_can MAINTAINERS: isdn4linux@listserv.isdn4linux.de is subscribers-only [TCP]: Fix never pruned tcp out-of-order queue. [NET_SCHED] sch_api: fix qdisc_tree_decrease_qlen() loop
2008-04-16AFS: Do not describe debug parameters with their valuePaul Bolle
Describe debug parameters with their names (and not their values). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15USB: remove broken usb-serial num_endpoints checkGreg Kroah-Hartman
The num_interrupt_in, num_bulk_in, and other checks in the usb-serial code are just wrong, there are too many different devices out there with different numbers of endpoints. We need to just be sticking with the device ids instead of trying to catch this kind of thing. It broke too many different devices. This fixes a large number of usb-serial devices to get them working properly again. Cc: Oliver Neukum <oliver@neukum.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15USB: option: Add new vendor ID and device ID for AMOI HSDPA modemtang kai
This patch add new vendor ID and device ID for AMOI HSDPA modem. From: tang kai <tangk73@hotmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15USB: support more Huawei data card product IDsfangxiaozhi
- declare the unusal device for Huawei data card devices in unusual_devs.h - disable the product ID matching for Huawei data card devices in usb_match_device function of driver.c - declare the product IDs in option.c. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15USB: option.c: add more device IDsMatthias Urlichs
Add devices by AMOI and NovatelWireless. Signed-Off-By: Matthias Urlichs <matthias@urlichs.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15USB: Obscure Maxon BP3-USB Device Support 16d8:6280 for option driverJames Cameron
The modem was detected, the ttyUSB{0,1,2} appeared, a call could be made, and the expected data rate was achieved. Tested for an hour or two, total of 100Mb. I shall do more testing. Signed-off-by: James Cameron <quozl@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-15[TCP]: Add return value indication to tcp_prune_ofo_queue().Vitaliy Gusev
Returns non-zero if tp->out_of_order_queue was seen non-empty. This allows tcp_try_rmem_schedule() to return early. Signed-off-by: Vitaliy Gusev <vgusev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15acpi: unneccessary to scan the PCI bus already scannedyakui.zhao@intel.com
http://bugzilla.kernel.org/show_bug.cgi?id=10124 this change: commit 08f1c192c3c32797068bfe97738babb3295bbf42 Author: Muli Ben-Yehuda <muli@il.ibm.com> Date: Sun Jul 22 00:23:39 2007 +0300 x86-64: introduce struct pci_sysdata to facilitate sharing of ->sysdata This patch introduces struct pci_sysdata to x86 and x86-64, and converts the existing two users (NUMA, Calgary) to use it. This lays the groundwork for having other users of sysdata, such as the PCI domains work. The Calgary bits are tested, the NUMA bits just look ok. replaces pcibios_scan_root by pci_scan_bus_parented... but in pcibios_scan_root we have a check about scanned busses. Cc: <yakui.zhao@intel.com> Cc: Stian Jordet <stian@jordet.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15acpi thermal trip points increased to 12Krzysztof Helt
The THERMAL_MAX_TRIPS value is set to 10. It is too few for the Compaq AP550 machine which has 12 trip points. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15acpi: bus: check once more for an empty list after locking itChuck Ebbert
List could have become empty after the unlocked check that was made earlier, so check again inside the lock. Should fix https://bugzilla.redhat.com/show_bug.cgi?id=427765 Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Cc: <stable@kernel.org> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15spi: spi_s3c24xx must initialize num_chipselectBen Dooks
The SPI core now expects num_chipselect to be set correctly as due to added checks on the chip being selected before an transfer is allowed. This patch adds a num_cs field to the platform data which needs to be set correctly before adding the SPI platform device. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15spi: spi_s3c24xx must initialize bus_numBen Dooks
Pass the bus number we expect the S3C24XX SPI driver to attach to via the platform data. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15spi: spi_s3c24xx driver must init completionBen Dooks
The s3c24xx_spi_txrx() function should initialise the completion each time before using it, otherwise we end up with the possibility of returning success before the interrupt handler has processed all the data. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15vfs: fix possible deadlock in ext2, ext3, ext4 when using xattrsJan Kara
mb_cache_entry_alloc() was allocating cache entries with GFP_KERNEL. But filesystems are calling this function while holding xattr_sem so possible recursion into the fs violates locking ordering of xattr_sem and transaction start / i_mutex for ext2-4. Change mb_cache_entry_alloc() so that filesystems can specify desired gfp mask and use GFP_NOFS from all of them. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Dave Jones <davej@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15Documentation: correct overcommit caveat in hugetlbpage.txtNishanth Aravamudan
As shown by Gurudas Pai recently, we can put hugepages into the surplus state (by echo 0 > /proc/sys/vm/nr_hugepages), even when /proc/sys/vm/nr_overcommit_hugepages is 0. This is actually correct, to allow the original goal (shrink the static pool to 0) to succeed (we are converting hugepages to surplus because they are in use). However, the documentation does not accurately reflect this case. Update it. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15add "Isolate" migratetype name to /proc/pagetypeinfoKOSAKI Motohiro
In a5d76b54a3f3a40385d7f76069a2feac9f1bad63 (memory unplug: page isolation by KAMEZAWA Hiroyuki), "isolate" migratetype added. but unfortunately, it doesn't treat /proc/pagetypeinfo display logic. this patch add "Isolate" to pagetype name field. /proc/pagetype before: ------------------------------------------------------------------------------------------------------------------------ Free pages count per migrate type at order 0 1 2 3 4 5 6 7 8 9 10 Node 0, zone DMA, type Unmovable 1 2 2 2 1 2 2 1 1 0 0 Node 0, zone DMA, type Reclaimable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone DMA, type Movable 2 3 3 1 3 3 2 0 0 0 0 Node 0, zone DMA, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone DMA, type <NULL> 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone Normal, type Unmovable 1 9 7 4 1 1 1 1 0 0 0 Node 0, zone Normal, type Reclaimable 5 2 0 0 1 1 0 0 0 1 0 Node 0, zone Normal, type Movable 0 1 1 0 0 0 1 0 0 1 60 Node 0, zone Normal, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone Normal, type <NULL> 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone HighMem, type Unmovable 0 0 1 1 1 0 1 1 2 2 0 Node 0, zone HighMem, type Reclaimable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone HighMem, type Movable 236 62 6 2 2 1 1 0 1 1 16 Node 0, zone HighMem, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone HighMem, type <NULL> 0 0 0 0 0 0 0 0 0 0 0 Number of blocks type Unmovable Reclaimable Movable Reserve <NULL> Node 0, zone DMA 1 0 2 1 0 Node 0, zone Normal 10 40 169 1 0 Node 0, zone HighMem 2 0 283 1 0 after: ------------------------------------------------------------------------------------------------------------------------ Free pages count per migrate type at order 0 1 2 3 4 5 6 7 8 9 10 Node 0, zone DMA, type Unmovable 1 2 2 2 1 2 2 1 1 0 0 Node 0, zone DMA, type Reclaimable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone DMA, type Movable 2 3 3 1 3 3 2 0 0 0 0 Node 0, zone DMA, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone DMA, type Isolate 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone Normal, type Unmovable 0 2 1 1 0 1 0 0 0 0 0 Node 0, zone Normal, type Reclaimable 1 1 1 1 1 0 1 1 1 0 0 Node 0, zone Normal, type Movable 0 1 1 1 0 1 0 1 0 0 196 Node 0, zone Normal, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone Normal, type Isolate 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone HighMem, type Unmovable 0 1 0 0 0 1 1 1 2 2 0 Node 0, zone HighMem, type Reclaimable 0 0 0 0 0 0 0 0 0 0 0 Node 0, zone HighMem, type Movable 1 0 1 1 0 0 0 0 1 0 200 Node 0, zone HighMem, type Reserve 0 0 0 0 0 0 0 0 0 0 1 Node 0, zone HighMem, type Isolate 0 0 0 0 0 0 0 0 0 0 0 Number of blocks type Unmovable Reclaimable Movable Reserve Isolate Node 0, zone DMA 1 0 2 1 0 Node 0, zone Normal 8 4 207 1 0 Node 0, zone HighMem 2 0 283 1 0 Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15Fix typos in Documentation/filesystems/seq_file.txtDmitri Vorobiev
A couple of typos crept into the newly added document about the seq_file interface. This patch corrects those typos and simultaneously deletes unnecessary trailing spaces. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15uml: compile error fixWANG Cong
This patch fixes this error: In file included from /home/wangcong/projects/linux-2.6/arch/um/kernel/smp.c:9: include2/asm/tlb.h: In function `tlb_remove_page': include2/asm/tlb.h:101: error: implicit declaration of function `page_cache_release' And since including <linux/pagemap.h> in <linux/swap.h> will break sparc, we add this #include in uml's own header. Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15memcg: fix oops in oom handlingLi Zefan
When I used a test program to fork mass processes and immediately move them to a cgroup where the memory limit is low enough to trigger oom kill, I got oops: BUG: unable to handle kernel NULL pointer dereference at 0000000000000808 IP: [<ffffffff8045c47f>] _spin_lock_irqsave+0x8/0x18 PGD 4c95f067 PUD 4406c067 PMD 0 Oops: 0002 [1] SMP CPU 2 Modules linked in: Pid: 11973, comm: a.out Not tainted 2.6.25-rc7 #5 RIP: 0010:[<ffffffff8045c47f>] [<ffffffff8045c47f>] _spin_lock_irqsave+0x8/0x18 RSP: 0018:ffff8100448c7c30 EFLAGS: 00010002 RAX: 0000000000000202 RBX: 0000000000000009 RCX: 000000000001c9f3 RDX: 0000000000000100 RSI: 0000000000000001 RDI: 0000000000000808 RBP: ffff81007e444080 R08: 0000000000000000 R09: ffff8100448c7900 R10: ffff81000105f480 R11: 00000100ffffffff R12: ffff810067c84140 R13: 0000000000000001 R14: ffff8100441d0018 R15: ffff81007da56200 FS: 00007f70eb1856f0(0000) GS:ffff81007fbad3c0(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000808 CR3: 000000004498a000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process a.out (pid: 11973, threadinfo ffff8100448c6000, task ffff81007da533e0) Stack: ffffffff8023ef5a 00000000000000d0 ffffffff80548dc0 00000000000000d0 ffff810067c84140 ffff81007e444080 ffffffff8026cef9 00000000000000d0 ffff8100441d0000 00000000000000d0 ffff8100441d0000 ffff8100505445c0 Call Trace: [<ffffffff8023ef5a>] ? force_sig_info+0x25/0xb9 [<ffffffff8026cef9>] ? oom_kill_task+0x77/0xe2 [<ffffffff8026d696>] ? mem_cgroup_out_of_memory+0x55/0x67 [<ffffffff802910ad>] ? mem_cgroup_charge_common+0xec/0x202 [<ffffffff8027997b>] ? handle_mm_fault+0x24e/0x77f [<ffffffff8022c4af>] ? default_wake_function+0x0/0xe [<ffffffff8027a17a>] ? get_user_pages+0x2ce/0x3af [<ffffffff80290fee>] ? mem_cgroup_charge_common+0x2d/0x202 [<ffffffff8027a441>] ? make_pages_present+0x8e/0xa4 [<ffffffff8027d1ab>] ? mmap_region+0x373/0x429 [<ffffffff8027d7eb>] ? do_mmap_pgoff+0x2ff/0x364 [<ffffffff80210471>] ? sys_mmap+0xe5/0x111 [<ffffffff8020bfc9>] ? tracesys+0xdc/0xe1 Code: 00 00 01 48 8b 3c 24 e9 46 d4 dd ff f0 ff 07 48 8b 3c 24 e9 3a d4 dd ff fe 07 48 8b 3c 24 e9 2f d4 dd ff 9c 58 fa ba 00 01 00 00 <f0> 66 0f c1 17 38 f2 74 06 f3 90 8a 17 eb f6 c3 fa b8 00 01 00 RIP [<ffffffff8045c47f>] _spin_lock_irqsave+0x8/0x18 RSP <ffff8100448c7c30> CR2: 0000000000000808 ---[ end trace c3702fa668021ea4 ]--- It's reproducable in a x86_64 box, but doesn't happen in x86_32. This is because tsk->sighand is not guarded by RCU, so we have to hold tasklist_lock, just as what out_of_memory() does. Signed-off-by: Li Zefan <lizf@cn.fujitsu> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Rientjes <rientjes@cs.washington.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15serial: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable serial platform drivers, to re-enable auto loading. NOTE that Kconfig for some of these drivers doesn't allow modular builds, and thus doesn't match the driver source's unload support. Presumably their unload code is buggy and/or weakly tested... [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15pcmcia: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable PCMCIA platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15misc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable 'misc' platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: bugfix, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15fbdev: fix /proc/fb oops after module removalAlexey Dobriyan
/proc/fb is not removed during rmmod. Steps to reproduce: modprobe fb rmmod fb ls /proc BUG: unable to handle kernel paging request at ffffffffa0094370 IP: [<ffffffff802b92a1>] proc_get_inode+0x101/0x130 PGD 203067 PUD 207063 PMD 17e758067 PTE 0 Oops: 0000 [1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:1e.0/0000:05:02.0/resource CPU 1 Modules linked in: nf_conntrack_irc xt_state iptable_filter ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack ip_tables x_tables vfat fat usbhid ehci_hcd uhci_hcd usbcore sr_mod cdrom [last unloaded: fb] Pid: 21205, comm: ls Not tainted 2.6.25-rc8-mm2 #14 RIP: 0010:[<ffffffff802b92a1>] [<ffffffff802b92a1>] proc_get_inode+0x101/0x130 RSP: 0018:ffff81017c4bfc78 EFLAGS: 00010246 RAX: 0000000000008000 RBX: ffff8101787f5470 RCX: 0000000048011ccc RDX: ffffffffa0094320 RSI: ffff810006ad43b0 RDI: ffff81017fc2cc00 RBP: ffff81017e450300 R08: 0000000000000002 R09: ffff81017c5d1000 R10: 0000000000000000 R11: 0000000000000246 R12: ffff81016b903a28 R13: ffff81017f822020 R14: ffff81017c4bfd58 R15: ffff81017f822020 FS: 00007f08e71696f0(0000) GS:ffff81017fc06480(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffffffffa0094370 CR3: 000000017e54a000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process ls (pid: 21205, threadinfo ffff81017c4be000, task ffff81017de48770) Stack: ffff81017c5d1000 00000000ffffffea ffff81017e450300 ffffffff802bdd1e ffff81017f802258 ffff81017c4bfe48 ffff81016b903a28 ffff81017f822020 ffff81017c4bfd48 ffffffff802b9ba0 ffff81016b903a28 ffff81017f802258 Call Trace: [<ffffffff802bdd1e>] ? proc_lookup_de+0x8e/0x100 [<ffffffff802b9ba0>] ? proc_root_lookup+0x20/0x60 [<ffffffff802882a7>] ? do_lookup+0x1b7/0x210 [<ffffffff8028883d>] ? __link_path_walk+0x53d/0x7f0 [<ffffffff80295eb8>] ? mntput_no_expire+0x28/0x130 [<ffffffff80288b4a>] ? path_walk+0x5a/0xc0 [<ffffffff80288dd3>] ? do_path_lookup+0x83/0x1c0 [<ffffffff80287785>] ? getname+0xe5/0x210 [<ffffffff80289adb>] ? __user_walk_fd+0x4b/0x80 [<ffffffff8028236c>] ? vfs_lstat_fd+0x2c/0x70 [<ffffffff8028bf1e>] ? filldir+0xae/0xf0 [<ffffffff802b92e9>] ? de_put+0x9/0x50 [<ffffffff8029633d>] ? mnt_want_write+0x2d/0x80 [<ffffffff8029339f>] ? touch_atime+0x1f/0x170 [<ffffffff802b9b1d>] ? proc_root_readdir+0x7d/0xa0 [<ffffffff802825e7>] ? sys_newlstat+0x27/0x50 [<ffffffff8028bffb>] ? vfs_readdir+0x9b/0xd0 [<ffffffff8028c0fe>] ? sys_getdents+0xce/0xe0 [<ffffffff8020b39b>] ? system_call_after_swapgs+0x7b/0x80 Code: b7 83 b2 00 00 00 25 00 f0 00 00 3d 00 80 00 00 74 19 48 89 93 f0 00 00 00 48 89 df e8 39 9a fd ff 48 89 d8 48 83 c4 08 5b 5d c3 <48> 83 7a 50 00 48 c7 c0 60 16 45 80 48 c7 c2 40 17 45 80 48 0f RIP [<ffffffff802b92a1>] proc_get_inode+0x101/0x130 RSP <ffff81017c4bfc78> CR2: ffffffffa0094370 ---[ end trace c71hiarjan8ab739 ]--- Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> "Antonino A. Daplas" <adaplas@pol.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15leds: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable platform LED drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15rtc: fix the error in the function of cmos_set_alarmZhao Yakui
There is a bug in the function of cmos_set_alarm. RTC alarm time for October can't be set correctly. For October: 0x0A will be written into the RTC region (MONTH_ALARM) in current kernel. But in fact 0x10 should be written. Wildcards are also not handled correctly. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15mmc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable MMC host platform drivers, to re-enable auto loading. Also, add missing owner declarations in driver init. [dbrownell@users.sourceforge.net: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15mm: sparsemem memory_present() fixIngo Molnar
Fix memory corruption and crash on 32-bit x86 systems. If a !PAE x86 kernel is booted on a 32-bit system with more than 4GB of RAM, then we call memory_present() with a start/end that goes outside the scope of MAX_PHYSMEM_BITS. That causes this loop to happily walk over the limit of the sparse memory section map: for (pfn = start; pfn < end; pfn += PAGES_PER_SECTION) { unsigned long section = pfn_to_section_nr(pfn); struct mem_section *ms; sparse_index_init(section, nid); set_section_nid(section, nid); ms = __nr_to_section(section); if (!ms->section_mem_map) ms->section_mem_map = sparse_encode_early_nid(nid) | SECTION_MARKED_PRESENT; 'ms' will be out of bounds and we'll corrupt a small amount of memory by encoding the node ID and writing SECTION_MARKED_PRESENT (==0x1) over it. The corruption might happen when encoding a non-zero node ID, or due to the SECTION_MARKED_PRESENT which is 0x1: mmzone.h:#define SECTION_MARKED_PRESENT (1UL<<0) The fix is to sanity check anything the architecture passes to sparsemem. This bug seems to be rather old (as old as sparsemem support itself), but the exact incarnation depended on random details like configs, which made this bug more prominent in v2.6.25-to-be. An additional enhancement might be to print a warning about ignored or trimmed memory ranges. Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Yinghai Lu <Yinghai.Lu@sun.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-04-15[PARISC] fix signal trampoline cache flushingKyle McMartin
The signal trampolines were accidently flushing the kernel I$ instead of the users. Fix that up, and also add a missing user D$ flush while we're at it. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15Fix locking bug in "acquire_console_semaphore_for_printk()"Linus Torvalds
When I cleaned up printk() and split up the printk locking logic in commit 266c2e0abeca649fa6667a1a427ad1da507c6375 ("Make printk() console semaphore accesses sensible") I had incorrectly moved the call to have_callable_console() outside of the console semaphore. That was buggy. The console semaphore protects the console_drivers list that is used by have_callable_console(). Thanks go to Bongani Hlope who saw this as a hang on shutdown and reboot and bisected the bug to the right commit, and tested this patch. See http://lkml.org/lkml/2008/4/11/315 Bisected-and-tested-by: Bongani Hlope <bonganilinux@mweb.co.za> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-15PS3: gelic: fix the oops on the broken IE returned from the hypervisorMasakazu Mokuno
This fixes the bug that the driver would try to over-scan the memory if the sum of the length field of every IEs does not match the length returned from the hypervisor. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15b43legacy: fix DMA mapping leakageStefano Brivio
This fixes a DMA mapping leakage in the case where we reject a DMA buffer because of its address. The patch by Michael Buesch has been ported to b43legacy. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Cc: Christian Casteyde <casteyde.christian@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15mac80211: remove message on receiving unexpected unencrypted framesJohannes Berg
Some people are getting this message a lot, and we have traced it to broken access points that much too often send completely empty frames (all bytes zeroed, which they shouldn't do at all.) Since we cannot do anything about such frames in any case except the special case where we're debugging an AP, just remove the message. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15Update rt2x00 MAINTAINERS entryIvo van Doorn
Add the tree entry for rt2x00 to inform people about the rt2x00.git tree. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15Add rfkill to MAINTAINERS fileIvo van Doorn
I have been acting as the maintainer since the rfkill introduction, so lets make it official by adding a rfkill entry in the MAINTAINERS file. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15rfkill: Fix device type check when toggling statesCarlos Corbacho
rfkill_switch_all() is supposed to only switch all the interfaces of a given type, but does not actually do this; instead, it just switches everything currently in the same state. Add the necessary type check in. (This fixes a bug I've been seeing while developing an rfkill laptop driver, with both bluetooth and wireless simultaneously changing state after only pressing either KEY_WLAN or KEY_BLUETOOTH). Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
