Because synchronize_rcu_bh() is identical to synchronize_sched(),
make the former a static inline invoking the latter, saving the
overhead of an EXPORT_SYMBOL_GPL() and the duplicate code.
The rcu_scheduler_active check has been wrapped into the new
debug_lockdep_rcu_enabled() function, so update the comments to
reflect this new reality.
It is CONFIG_DEBUG_LOCK_ALLOC rather than CONFIG_PROVE_LOCKING, so fix it.
Offline CPUs are not in nohz_cpu_mask, but can be ignored when checking
for the last non-dyntick-idle CPU. This patch therefore only checks
online CPUs for not being dyntick idle, allowing fast entry into
full-system dyntick-idle state even when there are some offline CPUs.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Shrink the RCU_INIT_FLAVOR() macro by moving all but the initialization
of the ->rda[] array to rcu_init_one(). The call to rcu_init_one()
can then be moved to the end of the RCU_INIT_FLAVOR() macro, which is
required because rcu_boot_init_percpu_data(), which is now called from
rcu_init_one(), depends on the initialization of the ->rda[] array.
cleanup: make dead code really dead
This patch adds a check to __rcu_pending() that does a local
set_need_resched() if the current CPU is holding up the current grace
period and if force_quiescent_state() will be called soon. The goal is
to reduce the probability that force_quiescent_state() will need to do
smp_send_reschedule(), which sends an IPI and is therefore more expensive
on most architectures.
Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
There is no need to disable lockdep after an RCU lockdep splat,
so remove the debug_lockdeps_off() from lockdep_rcu_dereference().
To avoid repeated lockdep splats, use a static variable in the inlined
rcu_dereference_check() and rcu_dereference_protected() macros so that
a given instance splats only once, but so that multiple instances can
be detected per boot.
This is controlled by a new config variable CONFIG_PROVE_RCU_REPEATEDLY,
which is disabled by default. This provides the normal lockdep behavior
by default, but permits people who want to find multiple RCU-lockdep
splats per boot to easily do so.
Requested-by: Eric Paris <eparis@redhat.com>
Tested-by: Eric Paris <eparis@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] Retry commands with UNIT_ATTENTION sense codes to fix ext3/ext4 I/O error
[SCSI] Enable retries for SYNCRONIZE_CACHE commands to fix I/O error
[SCSI] scsi_debug: virtual_gb ignores sector_size
[SCSI] libiscsi: regression: fix header digest errors
[SCSI] fix locking around blk_abort_request()
[SCSI] advansys: fix narrow board error path
commit 672917dcc78 ("cpuidle: menu governor: reduce latency on exit")
added an optimization, where the analysis on the past idle period moved
from the end of idle, to the beginning of the new idle.
Unfortunately, this optimization had a bug where it zeroed one key
variable for new use, that is needed for the analysis. The fix is
simple, zero the variable after doing the work from the previous idle.
During the audit of the code that found this issue, another issue was
also found; the ->measured_us data structure member is never set, a
local variable is always used instead.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Corrado Zoccolo <czoccolo@gmail.com>
Cc: stable@kernel.org
* 'for-linus' of git://neil.brown.name/md:
md: restore ability of spare drives to spin down.
md/raid6: Fix raid-6 read-error correction in degraded state
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: fix compilation after 16bit state locking changes
pcmcia: order userspace suspend and resume requests
pcmcia: avoid pccard_validate_cis failure in resume callpath
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
blk-cgroup: Fix an RCU warning in blkiocg_create()
blk-cgroup: Fix RCU correctness warning in cfq_init_queue()
drbd: don't expose failed local READ to upper layers
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/ttm: Remove the ttm_bo_block_reservation() function.
drm/ttm: Remove some leftover debug messages.
drm/radeon: async event synchronization for drmWaitVblank
Move initialization of the virtio framework before the initialization of
mtd, so that block2mtd can be used on virtio-based block devices.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15644
Signed-off-by: Stijn Tintel <stijn@linux-ipv6.be>
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix RCU issues in the NFSv4 delegation code
NFSv4: Fix the locking in nfs_inode_reclaim_delegation()
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: sleep: init_set_sci_en_on_resume for Dell Studio 155x
ACPI: fix acpi_hest_firmware_first_pci() caused oops
sbshc: acpi_device_class "smbus_host_controller" too long
power_meter: acpi_device_class "power_meter_resource" too long
acpi_pad: "processor_aggregator" name too long
PNP: don't check for conflicts with bridge windows
ACPI: DMI init_set_sci_en_on_resume for multiple Lenovo ThinkPads
PNPACPI: compute Address Space length rather than using _LEN
ACPI: silence kmemcheck false positive
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_2.6.34' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB: pxa_camera: move fifo reset direct before dma start
V4L/DVB: video: testing unsigned for less than 0
V4L/DVB: mx1-camera: compile fix
V4L/DVB: budget: Oops: "BUG: unable to handle kernel NULL pointer dereference"
V4L/DVB: ngene: Workaround for stuck DiSEqC pin
V4L/DVB: saa7146: fix regression of the av7110/budget-av driver
V4L/DVB: v4l: fix config dependencies: mxb and saa7191 are V4L2 drivers, not V4L1
V4L/DVB: feature-removal: announce videotext.h removal
V4L/DVB: V4L - vpfe capture - fix for kernel crash
V4L/DVB: gspca: make usb id 0461:0815 get handled by the right driver
V4L/DVB: gspca - stv06xx: Remove the 046d:08da from the stv06xx driver
V4L/DVB: gspca - sn9c20x: Correct onstack wait_queue_head declaration
V4L/DVB: saa7146: fix up bytesperline if it is an impossible value
V4L/DVB: V4L: vpfe_capture - free ccdc_lock when memory allocation fails
V4L/DVB: V4L - Makfile:Removed duplicate entry of davinci
V4L/DVB: omap24xxcam: potential buffer overflow
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: create rcu_my_thread_group_empty() wrapper
memcg: css_id() must be called under rcu_read_lock()
cgroup: Check task_lock in task_subsys_state()
sched: Fix an RCU warning in print_task()
cgroup: Fix an RCU warning in alloc_css_id()
cgroup: Fix an RCU warning in cgroup_path()
KEYS: Fix an RCU warning in the reading of user keys
Some time ago we stopped the clean/active metadata updates
from being written to a 'spare' device in most cases so that
it could spin down and say spun down. Device failure/removal
etc are still recorded on spares.
However commit 51d5668cb2e3fd1827a55 broke this 50% of the time,
depending on whether the event count is even or odd.
The change log entry said:
This means that the alignment between 'odd/even' and
'clean/dirty' might take a little longer to attain,
how ever the code makes no attempt to create that alignment, so it
could take arbitrarily long.
So when we find that clean/dirty is not aligned with odd/even,
force a second metadata-update immediately. There are already cases
where a second metadata-update is needed immediately (e.g. when a
device fails during the metadata update). We just piggy-back on that.
Reported-by: Joe Bryant <tenminjoe@yahoo.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Fix: Raid-6 was not trying to correct a read-error when in
singly-degraded state and was instead dropping one more device, going to
doubly-degraded state. This patch fixes this behaviour.
Tested-by: Janos Haar <janos.haar@netcenter.hu>
Signed-off-by: Gabriele A. Trombetti <g.trombetti.lkrnl1213@logicschema.com>
Reported-by: Janos Haar <janos.haar@netcenter.hu>
with CONFIG_PROVE_RCU=y, a warning can be triggered:
# mount -t cgroup -o blkio xxx /mnt
# mkdir /mnt/subgroup
kernel/cgroup.c:4442 invoked rcu_dereference_check() without protection!
To fix this, we avoid caling css_depth() here, which is a bit simpler
than the original code.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
'bugzilla-15903' and 'misc-2.6.34' into release
It's unused and buggy in its current form, since it can place a bo
in the reserved state without removing it from lru lists.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Bring radeon up to speed with the async event synchronization for
drmWaitVblank. See c9a9c5e02aedc1a2815877b0268f886d2640b771 for
more information. Without this patch event never get delivered
to userspace client.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Move the fifo reset from pxa_camera_start_capture to pxa_camera_irq direct
before the dma start after an end of frame interrupt to prevent images from
shifting because of old data at the begin of the frame.
Signed-off-by: Stefan Herbrechtsmeier <hbmeier@hni.uni-paderborn.de>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
soc_mbus_bytes_per_line() returns -EINVAL on error but we store it in an
unsigned int so the test for less than zero doesn't work. I think it
always returns "small" positive values so we can just cast it to int
here.
This fixes a regression of
7d58289 (mx1: prefix SOC specific defines with MX1_ and deprecate old names)
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Never call dvb_frontend_detach if we failed to attach a frontend. This fixes
the following oops, which will be triggered by a missing stv090x module:
[ 8.172997] DVB: registering new adapter (TT-Budget S2-1600 PCI)
[ 8.209018] adapter has MAC addr = 00:d0:5c:cc:a7:29
[ 8.328665] Intel ICH 0000:00:1f.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 8.328753] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 8.562047] DVB: Unable to find symbol stv090x_attach()
[ 8.562117] BUG: unable to handle kernel NULL pointer dereference at 000000ac
[ 8.562239] IP: [<e08b04a3>] dvb_frontend_detach+0x4/0x67 [dvb_core]
Ref http://bugs.debian.org/575207
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Send one DiSEqC byte to make sure that the pin is set to low level.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Reviewed-by: Manu Abraham <abraham.manu@gmail.com>
An earlier regression fix for the mxb driver (V4L/DVB: saa7146_vv: fix
regression where v4l2_device was registered too late) caused a new
regression in the av7110 driver.
Reverted the old fix and fixed the problem in the mxb driver instead.
Tested on mxb and budget-av cards.
The real problem is that the saa7146 framework has separate probe()
and attach() driver callbacks which should be rolled into one. This
is now done for the mxb driver, but others should do the same. Lack
of hardware makes this hard to do, though. I hope to get hold of some
hexium cards and then I can try to improve the framework to prevent
this from happening again.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
V4L1
As part of upstream merge, set_params() function was removed from isif.c.
This requires removal of BUG_ON() and check for set_params ptr in
vpfe_capture.c. Without this kernel crash dump is seen while bootup on DM365
Also made following changes:-
1) converted error messages to debug messages since it is not right to flood
the console with error messages for user mistakes.
2) returns -EINVAL if ioctl is not supported
Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com>
The 0461:0815 camera is spca561 based not spca508
Signed-off-by: John Ellson <john.ellson@comcast.net>
The 046d:08da usb id shouldn't be associated with the stv06xx driver as they're
not compatible with each other.
This fixes a bug where Quickcam Messenger cams fail to use its proper driver
(gspca-zc3xx), rendering the camera inoperable.
Signed-off-by: Erik Andrén <erik.andren@gmail.com>
Tested-by: Gabriel Craciunescu <nix.or.die@googlemail.com>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
Use DECLARE_WAIT_QUEUE_HEAD_ONSTACK to make lockdep happy
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
CC: Brian Johnson <brijohn@gmail.com>
xawtv using DGA on a Radeon graphics card provides bogus
values to S_FBUF, which will then screw up overlay video:
https://bugs.launchpad.net/ubuntu/+source/xawtv/+bug/499734
This fixes the bytesperline value if it is off completely.
Signed-off-by: Michael Hunold <michael@mihu.de>
This patch fixes a bug in vpfe_probe() that doesn't call mutex_unlock() if memory
allocation for ccdc_cfg fails. See also the smatch warning report from Dan
Carpenter that shows this as an issue.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Muralidharan Karicheri <mkaricheri@gmail.com>
The previous loop goes until last == VIDEO_MAX_FRAME, so this could
potentially go one past the end of the loop.
Acked-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com>
Add Dell Studio models (1558, 1557, 1555) to the 'set_sci_en_on_resume'
list to fix hang on resume.
BugLink: http://bugs.launchpad.net/bugs/553498
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
Acked-by: Alex Chiang <achiang@canonical.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Some RCU-lockdep splat repairs need to know whether they are running
in a single-threaded process. Unfortunately, the thread_group_empty()
primitive is defined in sched.h, and can induce #include hell. This
commit therefore introduces a rcu_my_thread_group_empty() wrapper that
is defined in rcupdate.c, thus avoiding the need to include sched.h
everywhere.
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Defconfig update
microblaze: Optimize CACHE_LOOP_LIMITS and CACHE_RANGE_LOOP macros
microblaze: Fix consistent-sync code
microblaze: Define correct L1_CACHE_SHIFT value
microblaze: cpuinfo shows cache line length
microblaze: Fix kmalloc alignment on non-coherent DMA platforms
microblaze: Fix typo fault in cache code
microblaze: Fix consistent code
microblaze: pci-dma: use include/linux/dma-mapping.h
microblaze: page.h: Remove get_user_page and free_user_page
microblaze: Remove "cache" optimized copy_page function
microblaze: invoke oom-killer from page fault
microblaze: fix divide by zero exception message
microblaze: Add isa_dma_bridge_buggy to dma.h
microblaze: Remove ancient code
microblaze: Quiet section mismatch warnings for MMU version
microblaze: Fix IRQ entry/exit ftracing
microblaze: resource/PCI: align functions now return start of resource
microblaze: PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refs
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] pxa/colibri: fix missing #include <mach/mfp.h> in colibri.h
[ARM] pxa/spitz: fix On/off key name to fix warning during boot
[ARM] pxa: fix the incorrect cpu_is_pxa950()
[ARM] pxa: update cpuid pattern for pxa9xx in head.S
[ARM] pxa/viper: fix timeout usage for I2C
[ARM] pxa/raumfeld: fix button name
[ARM] pxa/imote2: Fix iMote2 defconfig
[ARM] pxa: add missing new line to regs-u2d.h
ARM: 6093/1: Fix kernel memory printing for sparsemem
arch/arm/include/asm/elf.h: forward-declare the task-struct
arch/arm/plat-pxa/dma.c: correct NULL test
ARM: 6076/1: SA1100: add processor check to sa1110-cpufreq driver
ARM: 6075/1: SA1100: fix wrong CPU type for h3100 and h3600
ARM: Update mach-types
ARM: 6066/1: Fix "BUG: scheduling while atomic: swapper/0/0x00000002
ARM: 6068/1: Fix build break with KPROBES enabled
mx5: Fix build error for mx51_defconfig
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'sh/for-2.6.34' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: fix a number of Oopses and leaks in SH framebuffer driver
SH: fix error paths in DMA driver
sh: sh7751 pci controller io port fix
sh: Fix maximum number of SCIF ports in R2D defconfigs
SH: fix TS field shift calculation for DMA drivers
1. Remove CACHE_ALL_LOOP2 macro because it is identical to CACHE_ALL_LOOP
2. Change BUG_ON to WARN_ON
3. Remove end aligned from CACHE_LOOP_LIMITS.
C implementation do not need aligned end address and ASM code do aligned
in their macros
4. ASM optimized CACHE_RANGE_LOOP_1/2 macros needs to get aligned end address.
Because end address is compound from start + size, end address is the first address
which is exclude.
Here is the corresponding code which describe it.
+ int align = ~(line_length - 1);
+ end = ((end & align) == end) ? end - line_length : end & align;
a) end is aligned:
it is necessary to subtruct line length because we don't want to work with
next cacheline
b) end address is not aligned:
Just align it to be ready for ASM code.
