* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/numa: Add constraints check for nid parameters
mm, x86: Remove debug_pagealloc_enabled
x86/mm: Initialize high mem before free_all_bootmem()
arch/x86/kernel/e820.c: quiet sparse noise about plain integer as NULL pointer
arch/x86/kernel/e820.c: Eliminate bubble sort from sanitize_e820_map()
x86: Fix mmap random address range
x86, mm: Unify zone_sizes_init()
x86, mm: Prepare zone_sizes_init() for unification
x86, mm: Use max_low_pfn for ZONE_NORMAL on 64-bit
x86, mm: Wrap ZONE_DMA32 with CONFIG_ZONE_DMA32
x86, mm: Use max_pfn instead of highend_pfn
x86, mm: Move zone init from paging_init() on 64-bit
x86, mm: Use MAX_DMA_PFN for ZONE_DMA on 32-bit
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: (23 commits)
[CPUFREQ] EXYNOS: Removed useless headers and codes
[CPUFREQ] EXYNOS: Make EXYNOS common cpufreq driver
[CPUFREQ] powernow-k8: Update copyright, maintainer and documentation information
[CPUFREQ] powernow-k8: Fix indexing issue
[CPUFREQ] powernow-k8: Avoid Pstate MSR accesses on systems supporting CPB
[CPUFREQ] update lpj only if frequency has changed
[CPUFREQ] cpufreq:userspace: fix cpu_cur_freq updation
[CPUFREQ] Remove wall variable from cpufreq_gov_dbs_init()
[CPUFREQ] EXYNOS4210: cpufreq code is changed for stable working
[CPUFREQ] EXYNOS4210: Update frequency table for cpu divider
[CPUFREQ] EXYNOS4210: Remove code about bus on cpufreq
[CPUFREQ] s3c64xx: Use pr_fmt() for consistent log messages
cpufreq: OMAP: fixup for omap_device changes, include <linux/module.h>
cpufreq: OMAP: fix freq_table leak
cpufreq: OMAP: put clk if cpu_init failed
cpufreq: OMAP: only supports OPP library
cpufreq: OMAP: dont support !freq_table
cpufreq: OMAP: deny initialization if no mpudev
cpufreq: OMAP: move clk name decision to init
cpufreq: OMAP: notify even with bad boot frequency
* git://git.infradead.org/battery-2.6: (68 commits)
power_supply: Mark da9052 driver as broken
power_supply: Drop usage of nowarn variant of sysfs_create_link()
s3c_adc_battery: Average over more than one adc sample
power_supply: Add DA9052 battery driver
isp1704_charger: Fix missing check
jz4740-battery: Fix signedness bug
power_supply: Assume mains power by default
sbs-battery: Fix devicetree match table
ARM: rx51: Add bq27200 i2c board info
sbs-battery: Change power supply name
devicetree-bindings: Propagate bq20z75->sbs rename to dt bindings
devicetree-bindings: Add vendor entry for Smart Battery Systems
sbs-battery: Rename internals to new name
bq20z75: Rename to sbs-battery
wm97xx_battery: Use DEFINE_MUTEX() for work_lock
max8997_charger: Remove duplicate module.h
lp8727_charger: Some minor fixes for the header
lp8727_charger: Add header file
power_supply: Convert drivers/power/* to use module_platform_driver()
power_supply: Add "unknown" in power supply type
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
* 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
slub: disallow changing cpu_partial from userspace for debug caches
slub: add missed accounting
slub: Extract get_freelist from __slab_alloc
slub: Switch per cpu partial page support off for debugging
slub: fix a possible memleak in __slab_alloc()
slub: fix slub_max_order Documentation
slab: add taint flag outputting to debug paths.
slub: add taint flag outputting to debug paths
slab: introduce slab_max_order kernel parameter
slab: rename slab_break_gfp_order to slab_max_order
Two bugfixes for md.
One is a recently introduced regression that affects an unusual
configuration with a guaranteed BUG_ON. Has been tagged for -stable.
The other is minor missing functionality.
* tag 'md-3.3-fixes' of git://neil.brown.name/md:
md/raid1: perform bad-block tests for WriteMostly devices too.
md: notify the 'degraded' sysfs attribute on failure.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
frv, h8300, m68k, microblaze, openrisc, score, um and xtensa currently
do not register a CPU device. Add the config option GENERIC_CPU_DEVICES
which causes a generic CPU device to be registered for each present CPU,
and make all these architectures select it.
Richard Weinberger <richard@nod.at> covered UML and suggested using
per_cpu.
cpu_dev_init() is only called from driver_init(), which does not check
its return value. Therefore make cpu_dev_init() return void.
We must register the CPU subsystem, so panic if this fails.
If sched_create_sysfs_power_savings_entries() fails, the damage is
contained, so ignore this (as before).
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (54 commits)
crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in Kconfig
crypto: serpent-sse2 - remove unneeded LRW/XTS #ifdefs
crypto: serpent-sse2 - select LRW and XTS
crypto: twofish-x86_64-3way - remove unneeded LRW/XTS #ifdefs
crypto: twofish-x86_64-3way - select LRW and XTS
crypto: xts - remove dependency on EXPERIMENTAL
crypto: lrw - remove dependency on EXPERIMENTAL
crypto: picoxcell - fix boolean and / or confusion
crypto: caam - remove DECO access initialization code
crypto: caam - fix polarity of "propagate error" logic
crypto: caam - more desc.h cleanups
crypto: caam - desc.h - convert spaces to tabs
crypto: talitos - convert talitos_error to struct device
crypto: talitos - remove NO_IRQ references
crypto: talitos - fix bad kfree
crypto: convert drivers/crypto/* to use module_platform_driver()
char: hw_random: convert drivers/char/hw_random/* to use module_platform_driver()
crypto: serpent-sse2 - should select CRYPTO_CRYPTD
crypto: serpent - rename serpent.c to serpent_generic.c
crypto: serpent - cleanup checkpatch errors and warnings
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: (32 commits)
ima: fix invalid memory reference
ima: free duplicate measurement memory
security: update security_file_mmap() docs
selinux: Casting (void *) value returned by kmalloc is useless
apparmor: fix module parameter handling
Security: tomoyo: add .gitignore file
tomoyo: add missing rcu_dereference()
apparmor: add missing rcu_dereference()
evm: prevent racing during tfm allocation
evm: key must be set once during initialization
mpi/mpi-mpow: NULL dereference on allocation failure
digsig: build dependency fix
KEYS: Give key types their own lockdep class for key->sem
TPM: fix transmit_cmd error logic
TPM: NSC and TIS drivers X86 dependency fix
TPM: Export wait_for_stat for other vendor specific drivers
TPM: Use vendor specific function for status probe
tpm_tis: add delay after aborting command
tpm_tis: Check return code from getting timeouts/durations
tpm: Introduce function to poll for result of self test
Fix up trivial conflict in lib/Makefile due to addition of CONFIG_MPI
and SIGSIG next to CONFIG_DQL addition.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
autofs4: deal with autofs4_write/autofs4_write races
autofs4: catatonic_mode vs. notify_daemon race
autofs4: autofs4_wait() vs. autofs4_catatonic_mode() race
hfsplus: creation of hidden dir on mount can fail
block_dev: Suppress bdev_cache_init() kmemleak warninig
fix shrink_dcache_parent() livelock
coda: switch coda_cnode_make() to sane API as well, clean coda_lookup()
coda: deal correctly with allocation failure from coda_cnode_makectl()
securityfs: fix object creation races
Just serialize the actual writing of packets into pipe on
a new mutex, independent from everything else in the locking
hierarchy. As soon as something has started feeding a piece
of packet into the pipe to daemon, we *want* everything else
about to try the same to wait until we are done.
Acked-by: Ian Kent <raven@themaw.net>
we need to hold ->wq_mutex while we are forming the packet to send,
lest we have autofs4_catatonic_mode() setting wq->name.name to NULL
just as autofs4_notify_daemon() decides to memcpy() from it...
We do have check for catatonic mode immediately after that (under
->wq_mutex, as it ought to be) and packet won't be actually sent,
but it'll be too late for us if we oops on that memcpy() from NULL...
Fix is obvious - just extend the area covered by ->wq_mutex over
that switch and check whether it's catatonic *before* doing anything
else.
We need to recheck ->catatonic after autofs4_wait() got ->wq_mutex
for good, or we might end up with wq inserted into queue after
autofs4_catatonic_mode() had done its thing. It will stick there
forever, since there won't be anything to clear its ->name.name.
A bit of a complication: validate_request() drops and regains ->wq_mutex.
It actually ends up the most convenient place to stick the check into...
lib: use generic pci_iomap on all architectures
Many architectures don't want to pull in iomap.c,
so they ended up duplicating pci_iomap from that file.
That function isn't trivial, and we are going to modify it
https://lkml.org/lkml/2011/11/14/183
so the duplication hurts.
This reduces the scope of the problem significantly,
by moving pci_iomap to a separate file and
referencing that from all architectures.
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
alpha: drop pci_iomap/pci_iounmap from pci-noop.c
mn10300: switch to GENERIC_PCI_IOMAP
mn10300: add missing __iomap markers
frv: switch to GENERIC_PCI_IOMAP
tile: switch to GENERIC_PCI_IOMAP
tile: don't panic on iomap
sparc: switch to GENERIC_PCI_IOMAP
sh: switch to GENERIC_PCI_IOMAP
powerpc: switch to GENERIC_PCI_IOMAP
parisc: switch to GENERIC_PCI_IOMAP
mips: switch to GENERIC_PCI_IOMAP
microblaze: switch to GENERIC_PCI_IOMAP
arm: switch to GENERIC_PCI_IOMAP
alpha: switch to GENERIC_PCI_IOMAP
lib: add GENERIC_PCI_IOMAP
lib: move GENERIC_IOMAP to lib/Kconfig
Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
git://linux-c6x.org/git/projects/linux-c6x-upstreaming
* tag 'for-linux-3.3-merge-window' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: (29 commits)
C6X: replace tick_nohz_stop/restart_sched_tick calls
C6X: add register_cpu call
C6X: deal with memblock API changes
C6X: fix timer64 initialization
C6X: fix layout of EMIFA registers
C6X: MAINTAINERS
C6X: DSCR - Device State Configuration Registers
C6X: EMIF - External Memory Interface
C6X: general SoC support
C6X: library code
C6X: headers
C6X: ptrace support
C6X: loadable module support
C6X: cache control
C6X: clocks
C6X: build infrastructure
C6X: syscalls
C6X: interrupt handling
C6X: time management
C6X: signal management
* 'next' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Wire-up new system calls
microblaze: Remove NO_IRQ from architecture
input: xilinx_ps2: Don't use NO_IRQ
block: xsysace: Don't use NO_IRQ
microblaze: Trivial asm fix
microblaze: Fix debug message in module
microblaze: Remove eprintk macro
microblaze: Send CR before LF for early console
microblaze: Change NO_IRQ to 0
microblaze: Use irq_of_parse_and_map for timer
microblaze: intc: Change variable name
microblaze: Use of_find_compatible_node for timer and intc
microblaze: Add __cmpdi2
microblaze: Synchronize __pa __va macros
* 'unicore32' of git://github.com/gxt/linux:
rtc-puv3: solve section mismatch in rtc-puv3.c
rtc-puv3: using module_platform_driver()
i2c-puv3: using module_platform_driver()
rtc-puv3: irq: remove IRQF_DISABLED
unicore32: Remove IRQF_DISABLED
unicore32: Use set_current_blocked()
unicore32: add ioremap_nocache definition
unicore32: delete specified xlate_dev_mem_ptr
of: add include asm/setup.h in drivers/of/fdt.c
unicore32: standardize /proc/iomem "Kernel code" name
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin:
blackfin: bf561: add adv7183 capture support
blackfin: bf537: add capture support
blackfin: bf548: add capture support
blackfin: time-ts: rm unused func broadcast_timer_setup()
blackfin: i2c-lcd: change default clock rate
blackfin: mac: dsa: add vlan mask in board file
blackfin: bf537: change num_chipselect for spi-sport
blackfin: serial: bfin-uart: remove unused field
bf54x: get mem size: missing break in switch
blackfin: smp: fix msg queue overflow issue
blackfin: config: update macro SPI_BFIN in board file
blackfin: config: update def config for all boards
blackfin: smp: cleanup smp code
blackfin: smp: add suspend and wakeup irq flags
blackfin: bf533-stamp: add missed patches for new asoc driver
blackfin: bf533-stamp: fix ad1836 name
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: move MIN_WRITEBACK_PAGES to fs-writeback.c
writeback: balanced_rate cannot exceed write bandwidth
writeback: do strict bdi dirty_exceeded
writeback: avoid tiny dirty poll intervals
writeback: max, min and target dirty pause time
writeback: dirty ratelimit - think time compensation
btrfs: fix dirtied pages accounting on sub-page writes
writeback: fix dirtied pages accounting on redirty
writeback: fix dirtied pages accounting on sub-page writes
writeback: charge leaked page dirties to active tasks
writeback: Include all dirty inodes in background writeback
Andrew elucidates:
- First installmeant of MM. We have a HUGE number of MM patches this
time. It's crazy.
- MAINTAINERS updates
- backlight updates
- leds
- checkpatch updates
- misc ELF stuff
- rtc updates
- reiserfs
- procfs
- some misc other bits
* akpm: (124 commits)
user namespace: make signal.c respect user namespaces
workqueue: make alloc_workqueue() take printf fmt and args for name
procfs: add hidepid= and gid= mount options
procfs: parse mount options
procfs: introduce the /proc/<pid>/map_files/ directory
procfs: make proc_get_link to use dentry instead of inode
signal: add block_sigmask() for adding sigmask to current->blocked
sparc: make SA_NOMASK a synonym of SA_NODEFER
reiserfs: don't lock root inode searching
reiserfs: don't lock journal_init()
reiserfs: delay reiserfs lock until journal initialization
reiserfs: delete comments referring to the BKL
drivers/rtc/interface.c: fix alarm rollover when day or month is out-of-range
drivers/rtc/rtc-twl.c: add DT support for RTC inside twl4030/twl6030
drivers/rtc/: remove redundant spi driver bus initialization
drivers/rtc/rtc-jz4740.c: make jz4740_rtc_driver static
drivers/rtc/rtc-mc13xxx.c: make mc13xxx_rtc_idtable static
rtc: convert drivers/rtc/* to use module_platform_driver()
drivers/rtc/rtc-wm831x.c: convert to devm_kzalloc()
drivers/rtc/rtc-wm831x.c: remove unused period IRQ handler
ipc/mqueue.c: for __SI_MESQ, convert the uid being sent to recipient's
user namespace. (new, thanks Oleg)
__send_signal: convert current's uid to the recipient's user namespace
for any siginfo which is not SI_FROMKERNEL (patch from Oleg, thanks
again :)
do_notify_parent and do_notify_parent_cldstop: map task's uid to parent's
user namespace
ptrace_signal maps parent's uid into current's user namespace before
including in signal to current. IIUC Oleg has argued that this shouldn't
matter as the debugger will play with it, but it seems like not converting
the value currently being set is misleading.
Changelog:
Sep 20: Inspired by Oleg's suggestion, define map_cred_ns() helper to
simplify callers and help make clear what we are translating
(which uid into which namespace). Passing the target task would
make callers even easier to read, but we pass in user_ns because
current_user_ns() != task_cred_xxx(current, user_ns).
Sep 20: As recommended by Oleg, also put task_pid_vnr() under rcu_read_lock
in ptrace_signal().
Sep 23: In send_signal(), detect when (user) signal is coming from an
ancestor or unrelated user namespace. Pass that on to __send_signal,
which sets si_uid to 0 or overflowuid if needed.
Oct 12: Base on Oleg's fixup_uid() patch. On top of that, handle all
SI_FROMKERNEL cases at callers, because we can't assume sender is
current in those cases.
Nov 10: (mhelsley) rename fixup_uid to more meaningful usern_fixup_signal_uid
Nov 10: (akpm) make the !CONFIG_USER_NS case clearer
Signed-off-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Subject: __send_signal: pass q->info, not info, to userns_fixup_signal_uid (v2)
Eric Biederman pointed out that passing info is a bug and could lead to a
NULL pointer deref to boot.
A collection of signal, securebits, filecaps, cap_bounds, and a few other
ltp tests passed with this kernel.
Changelog:
Nov 18: previous patch missed a leading '&'
Subject: ipc/mqueue: lock() => unlock() typo
There was a double lock typo introduced in b085f4bd6b21 "user namespace:
make signal.c respect user namespaces"
Acked-by: Serge Hallyn <serge@hallyn.com>
alloc_workqueue() currently expects the passed in @name pointer to remain
accessible. This is inconvenient and a bit silly given that the whole wq
is being dynamically allocated. This patch updates alloc_workqueue() and
friends to take printf format string instead of opaque string and matching
varargs at the end. The name is allocated together with the wq and
formatted.
alloc_ordered_workqueue() is converted to a macro to unify varargs
handling with alloc_workqueue(), and, while at it, add comment to
alloc_workqueue().
None of the current in-kernel users pass in string with '%' as constant
name and this change shouldn't cause any problem.
[akpm@linux-foundation.org: use __printf]
Suggested-by: Christoph Hellwig <hch@infradead.org>
Add support for mount options to restrict access to /proc/PID/
directories. The default backward-compatible "relaxed" behaviour is left
untouched.
The first mount option is called "hidepid" and its value defines how much
info about processes we want to be available for non-owners:
hidepid=0 (default) means the old behavior - anybody may read all
world-readable /proc/PID/* files.
hidepid=1 means users may not access any /proc/<pid>/ directories, but
their own. Sensitive files like cmdline, sched*, status are now protected
against other users. As permission checking done in proc_pid_permission()
and files' permissions are left untouched, programs expecting specific
files' modes are not confused.
hidepid=2 means hidepid=1 plus all /proc/PID/ will be invisible to other
users. It doesn't mean that it hides whether a process exists (it can be
learned by other means, e.g. by kill -0 $PID), but it hides process' euid
and egid. It compicates intruder's task of gathering info about running
processes, whether some daemon runs with elevated privileges, whether
another user runs some sensitive program, whether other users run any
program at all, etc.
gid=XXX defines a group that will be able to gather all processes' info
(as in hidepid=0 mode). This group should be used instead of putting
nonroot user in sudoers file or something. However, untrusted users (like
daemons, etc.) which are not supposed to monitor the tasks in the whole
system should not be added to the group.
hidepid=1 or higher is designed to restrict access to procfs files, which
might reveal some sensitive private information like precise keystrokes
timings:
http://www.openwall.com/lists/oss-security/2011/11/05/3
hidepid=1/2 doesn't break monitoring userspace tools. ps, top, pgrep, and
conky gracefully handle EPERM/ENOENT and behave as if the current user is
the only user running processes. pstree shows the process subtree which
contains "pstree" process.
Note: the patch doesn't deal with setuid/setgid issues of keeping
preopened descriptors of procfs files (like
https://lkml.org/lkml/2011/2/7/368). We rely on that the leaked
information like the scheduling counters of setuid apps doesn't threaten
anybody's privacy - only the user started the setuid program may read the
counters.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Greg KH <greg@kroah.com>
Cc: Theodore Tso <tytso@MIT.EDU>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add support for procfs mount options. Actual mount options are coming in
the next patches.
This one behaves similarly to the /proc/<pid>/fd/ one - it contains
symlinks one for each mapping with file, the name of a symlink is
"vma->vm_start-vma->vm_end", the target is the file. Opening a symlink
results in a file that point exactly to the same inode as them vma's one.
For example the ls -l of some arbitrary /proc/<pid>/map_files/
| lr-x------ 1 root root 64 Aug 26 06:40 7f8f80403000-7f8f80404000 -> /lib64/libc-2.5.so
| lr-x------ 1 root root 64 Aug 26 06:40 7f8f8061e000-7f8f80620000 -> /lib64/libselinux.so.1
| lr-x------ 1 root root 64 Aug 26 06:40 7f8f80826000-7f8f80827000 -> /lib64/libacl.so.1.1.0
| lr-x------ 1 root root 64 Aug 26 06:40 7f8f80a2f000-7f8f80a30000 -> /lib64/librt-2.5.so
| lr-x------ 1 root root 64 Aug 26 06:40 7f8f80a30000-7f8f80a4c000 -> /lib64/ld-2.5.so
This *helps* checkpointing process in three ways:
1. When dumping a task mappings we do know exact file that is mapped
by particular region. We do this by opening
/proc/$pid/map_files/$address symlink the way we do with file
descriptors.
2. This also helps in determining which anonymous shared mappings are
shared with each other by comparing the inodes of them.
3. When restoring a set of processes in case two of them has a mapping
shared, we map the memory by the 1st one and then open its
/proc/$pid/map_files/$address file and map it by the 2nd task.
Using /proc/$pid/maps for this is quite inconvenient since it brings
repeatable re-reading and reparsing for this text file which slows down
restore procedure significantly. Also as being pointed in (3) it is a way
easier to use top level shared mapping in children as
/proc/$pid/map_files/$address when needed.
[gorcunov@openvz.org: make map_files depend on CHECKPOINT_RESTORE]
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Reviewed-by: Vasiliy Kulikov <segoon@openwall.com>
Reviewed-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Tejun Heo <tj@kernel.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Pavel Machek <pavel@ucw.cz>
Prepare the ground for the next "map_files" patch which needs a name of a
link file to analyse.
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Abstract the code sequence for adding a signal handler's sa_mask to
current->blocked because the sequence is identical for all architectures.
Furthermore, in the past some architectures actually got this code wrong,
so introduce a wrapper that all architectures can use.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Unlike other architectures, sparc currently has no SA_NODEFER definition
but only the older SA_NOMASK. Since SA_NOMASK is the historical name for
SA_NODEFER, add SA_NODEFER and copy what other architectures do by making
SA_NOMASK a synonym for SA_NODEFER.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Nothing requires that we lock the filesystem until the root inode is
provided.
Also iget5_locked() triggers a warning because we are holding the
filesystem lock while allocating the inode, which result in a lockdep
suspicion that we have a lock inversion against the reclaim path:
[ 1986.896979] =================================
[ 1986.896990] [ INFO: inconsistent lock state ]
[ 1986.896997] 3.1.1-main #8
[ 1986.897001] ---------------------------------
[ 1986.897007] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
[ 1986.897016] kswapd0/16 [HC0[0]:SC0[0]:HE1:SE1] takes:
[ 1986.897023] (&REISERFS_SB(s)->lock){+.+.?.}, at: [<c01f8bd4>] reiserfs_write_lock+0x20/0x2a
[ 1986.897044] {RECLAIM_FS-ON-W} state was registered at:
[ 1986.897050] [<c014a5b9>] mark_held_locks+0xae/0xd0
[ 1986.897060] [<c014aab3>] lockdep_trace_alloc+0x7d/0x91
[ 1986.897068] [<c0190ee0>] kmem_cache_alloc+0x1a/0x93
[ 1986.897078] [<c01e7728>] reiserfs_alloc_inode+0x13/0x3d
[ 1986.897088] [<c01a5b06>] alloc_inode+0x14/0x5f
[ 1986.897097] [<c01a5cb9>] iget5_locked+0x62/0x13a
[ 1986.897106] [<c01e99e0>] reiserfs_fill_super+0x410/0x8b9
[ 1986.897114] [<c01953da>] mount_bdev+0x10b/0x159
[ 1986.897123] [<c01e764d>] get_super_block+0x10/0x12
[ 1986.897131] [<c0195b38>] mount_fs+0x59/0x12d
[ 1986.897138] [<c01a80d1>] vfs_kern_mount+0x45/0x7a
[ 1986.897147] [<c01a83e3>] do_kern_mount+0x2f/0xb0
[ 1986.897155] [<c01a987a>] do_mount+0x5c2/0x612
[ 1986.897163] [<c01a9a72>] sys_mount+0x61/0x8f
[ 1986.897170] [<c044060c>] sysenter_do_call+0x12/0x32
[ 1986.897181] irq event stamp: 7509691
[ 1986.897186] hardirqs last enabled at (7509691): [<c0190f34>] kmem_cache_alloc+0x6e/0x93
[ 1986.897197] hardirqs last disabled at (7509690): [<c0190eea>] kmem_cache_alloc+0x24/0x93
[ 1986.897209] softirqs last enabled at (7508896): [<c01294bd>] __do_softirq+0xee/0xfd
[ 1986.897222] softirqs last disabled at (7508859): [<c01030ed>] do_softirq+0x50/0x9d
[ 1986.897234]
[ 1986.897235] other info that might help us debug this:
[ 1986.897242] Possible unsafe locking scenario:
[ 1986.897244]
[ 1986.897250] CPU0
[ 1986.897254] ----
[ 1986.897257] lock(&REISERFS_SB(s)->lock);
[ 1986.897265] <Interrupt>
[ 1986.897269] lock(&REISERFS_SB(s)->lock);
[ 1986.897276]
[ 1986.897277] *** DEADLOCK ***
[ 1986.897278]
[ 1986.897286] no locks held by kswapd0/16.
[ 1986.897291]
[ 1986.897292] stack backtrace:
[ 1986.897299] Pid: 16, comm: kswapd0 Not tainted 3.1.1-main #8
[ 1986.897306] Call Trace:
[ 1986.897314] [<c0439e76>] ? printk+0xf/0x11
[ 1986.897324] [<c01482d1>] print_usage_bug+0x20e/0x21a
[ 1986.897332] [<c01479b8>] ? print_irq_inversion_bug+0x172/0x172
[ 1986.897341] [<c014855c>] mark_lock+0x27f/0x483
[ 1986.897349] [<c0148d88>] __lock_acquire+0x628/0x1472
[ 1986.897358] [<c0149fae>] lock_acquire+0x47/0x5e
[ 1986.897366] [<c01f8bd4>] ? reiserfs_write_lock+0x20/0x2a
[ 1986.897384] [<c01f8bd4>] ? reiserfs_write_lock+0x20/0x2a
[ 1986.897397] [<c043b5ef>] mutex_lock_nested+0x35/0x26f
[ 1986.897409] [<c01f8bd4>] ? reiserfs_write_lock+0x20/0x2a
[ 1986.897421] [<c01f8bd4>] reiserfs_write_lock+0x20/0x2a
[ 1986.897433] [<c01e2edd>] map_block_for_writepage+0xc9/0x590
[ 1986.897448] [<c01b1706>] ? create_empty_buffers+0x33/0x8f
[ 1986.897461] [<c0121124>] ? get_parent_ip+0xb/0x31
[ 1986.897472] [<c043ef7f>] ? sub_preempt_count+0x81/0x8e
[ 1986.897485] [<c043cae0>] ? _raw_spin_unlock+0x27/0x3d
[ 1986.897496] [<c0121124>] ? get_parent_ip+0xb/0x31
[ 1986.897508] [<c01e355d>] reiserfs_writepage+0x1b9/0x3e7
[ 1986.897521] [<c0173b40>] ? clear_page_dirty_for_io+0xcb/0xde
[ 1986.897533] [<c014a6e3>] ? trace_hardirqs_on_caller+0x108/0x138
[ 1986.897546] [<c014a71e>] ? trace_hardirqs_on+0xb/0xd
[ 1986.897559] [<c0177b38>] shrink_page_list+0x34f/0x5e2
[ 1986.897572] [<c01780a7>] shrink_inactive_list+0x172/0x22c
[ 1986.897585] [<c0178464>] shrink_zone+0x303/0x3b1
[ 1986.897597] [<c043cae0>] ? _raw_spin_unlock+0x27/0x3d
[ 1986.897611] [<c01788c9>] kswapd+0x3b7/0x5f2
The deadlock shouldn't happen since we are doing that allocation in the
mount path, the filesystem is not available for any reclaim. Still the
warning is annoying.
To solve this, acquire the lock later only where we need it, right before
calling reiserfs_read_locked_inode() that wants to lock to walk the tree.
Reported-by: Knut Petersen <Knut_Petersen@t-online.de>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Jan Kara <jack@suse.cz>
journal_init() doesn't need the lock since no operation on the filesystem
is involved there. journal_read() and get_list_bitmap() have yet to be
reviewed carefully though before removing the lock there. Just keep the
it around these two calls for safety.
In the mount path, transactions that are made before journal
initialization don't involve the filesystem. We can delay the reiserfs
lock until we play with the journal.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Commit f44f7f96a20a ("RTC: Initialize kernel state from RTC") introduced a
potential infinite loop. If an alarm time contains a wildcard month and
an invalid day (> 31), or a wildcard year and an invalid month (>= 12),
the loop searching for the next matching date will never terminate. Treat
the invalid values as wildcards.
Fixes <http://bugs.debian.org/646429>, <http://bugs.debian.org/653331>
Reported-by: leo weppelman <leoweppelman@googlemail.com>
Reported-by: "P. van Gaans" <mailme667@yahoo.co.uk>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Cc: John Stultz <john.stultz@linaro.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: <stable@vger.kernel.org>
Add the DT support for the TI rtc-twl present in the twl4030 and twl6030
devices.
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
In ancient times it was necessary to manually initialize the bus field of
an spi_driver to spi_bus_type. These days this is done in
spi_driver_register(), so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This patch converts the drivers in drivers/rtc/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Ben Dooks <ben@simtec.co.uk>
Marginally less code and eliminate the possibility of memory leaks.
Due to changes in the RTC core the period interrupt is now unused so
delete the code managing it.
The rtc_calibration attribute allows user-space to get and set the
AB8500's RtcCalibration register. The AB8500 will then use the value in
this register to compensate for RTC drift every 60 seconds.
Signed-off-by: Mark Godfrey <mark.godfrey@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The resolution of msleep is related to HZ, so with HZ set to 100 any
msleep of less than 10ms will become ~10ms. This is not what we want.
Use the hrtimer-based usleep_range() and allow for some slack in the
non-critical path so we have more control of what is happening here.
Cc: Jonas Aaberg <jonas.aberg@stericsson.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Set can_wake flag so wakealarm property is visible in sysfs.
Signed-off-by: Andrew Lynn <andrew.lynn@stericsson.com>
Reviewed-by: Jonas ABERG <jonas.aberg@stericsson.com>
We want this driver to be able to wake up the system.
Signed-off-by: Robert Marklund <robert.marklund@stericsson.com>
Fix alarm IRQ handling, make the alarm one-shot. Cleanup black magick
with a validation of already validated time data.
Add ability to wake the system with alarm.
[akpm@linux-foundation.org: fix CONFIG_PM=n build]
Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com>
Cc: Daniel Mack <daniel@caiaq.de>
There is no way to track year in the i.MX1 RTC: Days Counter register is
9-bit wide only. Attempt to save date after 1970-01-01 plus 512 days
causes endless loop in mxc_rtc_set_mmss(). Fix this by resetting year to
1970.
[akpm@linux-foundation.org: use conventional comment layout]
Fix writing to NVRAM bank 2 in rtc-cmos driver. It never worked since its
introduction in 2.6.28 because of a typo.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
... by selecting ARCH_BINFMT_ELF_RANDOMIZE_PIE
Signed-off-by: David Daney <david.daney@cavium.com>
