2015-10-22arm/arm64: KVM: Support edge-triggered forwarded interruptsChristoffer Dall
We mark edge-triggered interrupts with the HW bit set as queued to prevent the VGIC code from injecting LRs with both the Active and Pending bits set at the same time while also setting the HW bit, because the hardware does not support this. However, this means that we must also clear the queued flag when we sync back a LR where the state on the physical distributor went from active to inactive because the guest deactivated the interrupt. At this point we must also check if the interrupt is pending on the distributor, and tell the VGIC to queue it again if it is. Since these actions on the sync path are extremely close to those for level-triggered interrupts, rename process_level_irq to process_queued_irq, allowing it to cater for both cases. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: Rework the arch timer to use level-triggered semanticsChristoffer Dall
The arch timer currently uses edge-triggered semantics in the sense that the line is never sampled by the vgic and lowering the line from the timer to the vgic doesn't have any effect on the pending state of virtual interrupts in the vgic. This means that we do not support a guest with the otherwise valid behavior of (1) disable interrupts (2) enable the timer (3) disable the timer (4) enable interrupts. Such a guest would validly not expect to see any interrupts on real hardware, but will see interrupts on KVM. This patch fixes this shortcoming through the following series of changes. First, we change the flow of the timer/vgic sync/flush operations. Now the timer is always flushed/synced before the vgic, because the vgic samples the state of the timer output. This has the implication that we move the timer operations in to non-preempible sections, but that is fine after the previous commit getting rid of hrtimer schedules on every entry/exit. Second, we change the internal behavior of the timer, letting the timer keep track of its previous output state, and only lower/raise the line to the vgic when the state changes. Note that in theory this could have been accomplished more simply by signalling the vgic every time the state *potentially* changed, but we don't want to be hitting the vgic more often than necessary. Third, we get rid of the use of the map->active field in the vgic and instead simply set the interrupt as active on the physical distributor whenever the input to the GIC is asserted and conversely clear the physical active state when the input to the GIC is deasserted. Fourth, and finally, we now initialize the timer PPIs (and all the other unused PPIs for now), to be level-triggered, and modify the sync code to sample the line state on HW sync and re-inject a new interrupt if it is still pending at that time. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: Add forwarded physical interrupts documentationChristoffer Dall
Forwarded physical interrupts on arm/arm64 is a tricky concept and the way we deal with them is not apparently easy to understand by reading various specs. Therefore, add a proper documentation file explaining the flow and rationale of the behavior of the vgic. Some of this text was contributed by Marc Zyngier and edited by me. Omissions and errors are all mine. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: Use appropriate define in VGIC reset codeChristoffer Dall
We currently initialize the SGIs to be enabled in the VGIC code, but we use the VGIC_NR_PPIS define for this purpose, instead of the the more natural VGIC_NR_SGIS. Change this slightly confusing use of the defines. Note: This should have no functional change, as both names are defined to the number 16. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: Implement GICD_ICFGR as RO for PPIsChristoffer Dall
The GICD_ICFGR allows the bits for the SGIs and PPIs to be read only. We currently simulate this behavior by writing a hardcoded value to the register for the SGIs and PPIs on every write of these bits to the register (ignoring what the guest actually wrote), and by writing the same value as the reset value to the register. This is a bit counter-intuitive, as the register is RO for these bits, and we can just implement it that way, allowing us to control the value of the bits purely in the reset code. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: vgic: Factor out level irq processing on guest exitChristoffer Dall
Currently vgic_process_maintenance() processes dealing with a completed level-triggered interrupt directly, but we are soon going to reuse this logic for level-triggered mapped interrupts with the HW bit set, so move this logic into a separate static function. Probably the most scary part of this commit is convincing yourself that the current flow is safe compared to the old one. In the following I try to list the changes and why they are harmless: Move vgic_irq_clear_queued after kvm_notify_acked_irq: Harmless because the only potential effect of clearing the queued flag wrt. kvm_set_irq is that vgic_update_irq_pending does not set the pending bit on the emulated CPU interface or in the pending_on_cpu bitmask if the function is called with level=1. However, the point of kvm_notify_acked_irq is to call kvm_set_irq with level=0, and we set the queued flag again in __kvm_vgic_sync_hwstate later on if the level is stil high. Move vgic_set_lr before kvm_notify_acked_irq: Also, harmless because the LR are cpu-local operations and kvm_notify_acked only affects the dist Move vgic_dist_irq_clear_soft_pend after kvm_notify_acked_irq: Also harmless, because now we check the level state in the clear_soft_pend function and lower the pending bits if the level is low. Reviewed-by: Eric Auger <eric.auger@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22arm/arm64: KVM: arch_timer: Only schedule soft timer on vcpu_blockChristoffer Dall
We currently schedule a soft timer every time we exit the guest if the timer did not expire while running the guest. This is really not necessary, because the only work we do in the timer work function is to kick the vcpu. Kicking the vcpu does two things: (1) If the vpcu thread is on a waitqueue, make it runnable and remove it from the waitqueue. (2) If the vcpu is running on a different physical CPU from the one doing the kick, it sends a reschedule IPI. The second case cannot happen, because the soft timer is only ever scheduled when the vcpu is not running. The first case is only relevant when the vcpu thread is on a waitqueue, which is only the case when the vcpu thread has called kvm_vcpu_block(). Therefore, we only need to make sure a timer is scheduled for kvm_vcpu_block(), which we do by encapsulating all calls to kvm_vcpu_block() with kvm_timer_{un}schedule calls. Additionally, we only schedule a soft timer if the timer is enabled and unmasked, since it is useless otherwise. Note that theoretically userspace can use the SET_ONE_REG interface to change registers that should cause the timer to fire, even if the vcpu is blocked without a scheduled timer, but this case was not supported before this patch and we leave it for future work for now. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-22KVM: Add kvm_arch_vcpu_{un}blocking callbacksChristoffer Dall
Some times it is useful for architecture implementations of KVM to know when the VCPU thread is about to block or when it comes back from blocking (arm/arm64 needs to know this to properly implement timers, for example). Therefore provide a generic architecture callback function in line with what we do elsewhere for KVM generic-arch interactions. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20arm/arm64: KVM: Fix disabled distributor operationChristoffer Dall
We currently do a single update of the vgic state when the distributor enable/disable control register is accessed and then bypass updating the state for as long as the distributor remains disabled. This is incorrect, because updating the state does not consider the distributor enable bit, and this you can end up in a situation where an interrupt is marked as pending on the CPU interface, but not pending on the distributor, which is an impossible state to be in, and triggers a warning. Consider for example the following sequence of events: 1. An interrupt is marked as pending on the distributor - the interrupt is also forwarded to the CPU interface 2. The guest turns off the distributor (it's about to do a reboot) - we stop updating the CPU interface state from now on 3. The guest disables the pending interrupt - we remove the pending state from the distributor, but don't touch the CPU interface, see point 2. Since the distributor disable bit really means that no interrupts should be forwarded to the CPU interface, we modify the code to keep updating the internal VGIC state, but always set the CPU interface pending bits to zero when the distributor is disabled. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20arm/arm64: KVM: Clear map->active on pend/active clearChristoffer Dall
When a guest reboots or offlines/onlines CPUs, it is not uncommon for it to clear the pending and active states of an interrupt through the emulated VGIC distributor. However, since the architected timers are defined by the architecture to be level triggered and the guest rightfully expects them to be that, but we emulate them as edge-triggered, we have to mimic level-triggered behavior for an edge-triggered virtual implementation. We currently do not signal the VGIC when the map->active field is true, because it indicates that the guest has already been signalled of the interrupt as required. Normally this field is set to false when the guest deactivates the virtual interrupt through the sync path. We also need to catch the case where the guest deactivates the interrupt through the emulated distributor, again allowing guests to boot even if the original virtual timer signal hit before the guest's GIC initialization sequence is run. Reviewed-by: Eric Auger <eric.auger@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20arm/arm64: KVM: Fix arch timer behavior for disabled interruptsChristoffer Dall
We have an interesting issue when the guest disables the timer interrupt on the VGIC, which happens when turning VCPUs off using PSCI, for example. The problem is that because the guest disables the virtual interrupt at the VGIC level, we never inject interrupts to the guest and therefore never mark the interrupt as active on the physical distributor. The host also never takes the timer interrupt (we only use the timer device to trigger a guest exit and everything else is done in software), so the interrupt does not become active through normal means. The result is that we keep entering the guest with a programmed timer that will always fire as soon as we context switch the hardware timer state and run the guest, preventing forward progress for the VCPU. Since the active state on the physical distributor is really part of the timer logic, it is the job of our virtual arch timer driver to manage this state. The timer->map->active boolean field indicates whether we have signalled this interrupt to the vgic and if that interrupt is still pending or active. As long as that is the case, the hardware doesn't have to generate physical interrupts and therefore we mark the interrupt as active on the physical distributor. We also have to restore the pending state of an interrupt that was queued to an LR but was retired from the LR for some reason, while remaining pending in the LR. Cc: Marc Zyngier <marc.zyngier@arm.com> Reported-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20KVM: arm: use GIC support unconditionallyArnd Bergmann
The vgic code on ARM is built for all configurations that enable KVM, but the parent_data field that it references is only present when CONFIG_IRQ_DOMAIN_HIERARCHY is set: virt/kvm/arm/vgic.c: In function 'kvm_vgic_map_phys_irq': virt/kvm/arm/vgic.c:1781:13: error: 'struct irq_data' has no member named 'parent_data' This flag is implied by the GIC driver, and indeed the VGIC code only makes sense if a GIC is present. This changes the CONFIG_KVM symbol to always select GIC, which avoids the issue. Fixes: 662d9715840 ("arm/arm64: KVM: Kill CONFIG_KVM_ARM_{VGIC,TIMER}") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20KVM: arm/arm64: Fix memory leak if timer initialization failsPavel Fedin
Jump to correct label and free kvm_host_cpu_state Reviewed-by: Wei Huang <wei@redhat.com> Signed-off-by: Pavel Fedin <p.fedin@samsung.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-10-20KVM: arm/arm64: Do not inject spurious interruptsPavel Fedin
When lowering a level-triggered line from userspace, we forgot to lower the pending bit on the emulated CPU interface and we also did not re-compute the pending_on_cpu bitmap for the CPU affected by the change. Update vgic_update_irq_pending() to fix the two issues above and also raise a warning in vgic_quue_irq_to_lr if we encounter an interrupt pending on a CPU which is neither marked active nor pending. [ Commit text reworked completely - Christoffer ] Signed-off-by: Pavel Fedin <p.fedin@samsung.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-09-25KVM: disable halt_poll_ns as default for s390xDavid Hildenbrand
We observed some performance degradation on s390x with dynamic halt polling. Until we can provide a proper fix, let's enable halt_poll_ns as default only for supported architectures. Architectures are now free to set their own halt_poll_ns default value. Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-25KVM: x86: fix off-by-one in reserved bits checkPaolo Bonzini
29ecd6601904 ("KVM: x86: avoid uninitialized variable warning", 2015-09-06) introduced a not-so-subtle problem, which probably escaped review because it was not part of the patch context. Before the patch, leaf was always equal to iterator.level. After, it is equal to iterator.level - 1 in the call to is_shadow_zero_bits_set, and when is_shadow_zero_bits_set does another "-1" the check on reserved bits becomes incorrect. Using "iterator.level" in the call fixes this call trace: WARNING: CPU: 2 PID: 17000 at arch/x86/kvm/mmu.c:3385 handle_mmio_page_fault.part.93+0x1a/0x20 [kvm]() Modules linked in: tun sha256_ssse3 sha256_generic drbg binfmt_misc ipv6 vfat fat fuse dm_crypt dm_mod kvm_amd kvm crc32_pclmul aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd fam15h_power amd64_edac_mod k10temp edac_core amdkfd amd_iommu_v2 radeon acpi_cpufreq [...] Call Trace: dump_stack+0x4e/0x84 warn_slowpath_common+0x95/0xe0 warn_slowpath_null+0x1a/0x20 handle_mmio_page_fault.part.93+0x1a/0x20 [kvm] tdp_page_fault+0x231/0x290 [kvm] ? emulator_pio_in_out+0x6e/0xf0 [kvm] kvm_mmu_page_fault+0x36/0x240 [kvm] ? svm_set_cr0+0x95/0xc0 [kvm_amd] pf_interception+0xde/0x1d0 [kvm_amd] handle_exit+0x181/0xa70 [kvm_amd] ? kvm_arch_vcpu_ioctl_run+0x68b/0x1730 [kvm] kvm_arch_vcpu_ioctl_run+0x6f6/0x1730 [kvm] ? kvm_arch_vcpu_ioctl_run+0x68b/0x1730 [kvm] ? preempt_count_sub+0x9b/0xf0 ? mutex_lock_killable_nested+0x26f/0x490 ? preempt_count_sub+0x9b/0xf0 kvm_vcpu_ioctl+0x358/0x710 [kvm] ? __fget+0x5/0x210 ? __fget+0x101/0x210 do_vfs_ioctl+0x2f4/0x560 ? __fget_light+0x29/0x90 SyS_ioctl+0x4c/0x90 entry_SYSCALL_64_fastpath+0x16/0x73 ---[ end trace 37901c8686d84de6 ]--- Reported-by: Borislav Petkov <bp@alien8.de> Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-25KVM: x86: use correct page table format to check nested page table reserved bitsPaolo Bonzini
Intel CPUID on AMD host or vice versa is a weird case, but it can happen. Handle it by checking the host CPU vendor instead of the guest's in reset_tdp_shadow_zero_bits_mask. For speed, the check uses the fact that Intel EPT has an X (executable) bit while AMD NPT has NX. Reported-by: Borislav Petkov <bp@alien8.de> Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-25KVM: svm: do not call kvm_set_cr0 from init_vmcbPaolo Bonzini
kvm_set_cr0 may want to call kvm_zap_gfn_range and thus access the memslots array (SRCU protected). Using a mini SRCU critical section is ugly, and adding it to kvm_arch_vcpu_create doesn't work because the VMX vcpu_create callback calls synchronize_srcu. Fixes this lockdep splat: =============================== [ INFO: suspicious RCU usage. ] 4.3.0-rc1+ #1 Not tainted ------------------------------- include/linux/kvm_host.h:488 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by qemu-system-i38/17000: #0: (&(&kvm->mmu_lock)->rlock){+.+...}, at: kvm_zap_gfn_range+0x24/0x1a0 [kvm] [...] Call Trace: dump_stack+0x4e/0x84 lockdep_rcu_suspicious+0xfd/0x130 kvm_zap_gfn_range+0x188/0x1a0 [kvm] kvm_set_cr0+0xde/0x1e0 [kvm] init_vmcb+0x760/0xad0 [kvm_amd] svm_create_vcpu+0x197/0x250 [kvm_amd] kvm_arch_vcpu_create+0x47/0x70 [kvm] kvm_vm_ioctl+0x302/0x7e0 [kvm] ? __lock_is_held+0x51/0x70 ? __fget+0x101/0x210 do_vfs_ioctl+0x2f4/0x560 ? __fget_light+0x29/0x90 SyS_ioctl+0x4c/0x90 entry_SYSCALL_64_fastpath+0x16/0x73 Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-22Merge branch 'kvm-ppc-fixes' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc into kvm-master
2015-09-21KVM: x86: trap AMD MSRs for the TSeg base and maskPaolo Bonzini
These have roughly the same purpose as the SMRR, which we do not need to implement in KVM. However, Linux accesses MSR_K8_TSEG_ADDR at boot, which causes problems when running a Xen dom0 under KVM. Just return 0, meaning that processor protection of SMRAM is not in effect. Reported-by: M A Young <m.a.young@durham.ac.uk> Cc: stable@vger.kernel.org Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-21KVM: PPC: Book3S: Take the kvm->srcu lock in kvmppc_h_logical_ci_load/store()Thomas Huth
Access to the kvm->buses (like with the kvm_io_bus_read() and -write() functions) has to be protected via the kvm->srcu lock. The kvmppc_h_logical_ci_load() and -store() functions are missing this lock so far, so let's add it there, too. This fixes the problem that the kernel reports "suspicious RCU usage" when lock debugging is enabled. Cc: stable@vger.kernel.org # v4.1+ Fixes: 99342cf8044420eebdf9297ca03a14cb6a7085a1 Signed-off-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2015-09-21KVM: PPC: Book3S HV: Pass the correct trap argument to kvmhv_commence_exitGautham R. Shenoy
In guest_exit_cont we call kvmhv_commence_exit which expects the trap number as the argument. However r3 doesn't contain the trap number at this point and as a result we would be calling the function with a spurious trap number. Fix this by copying r12 into r3 before calling kvmhv_commence_exit as r12 contains the trap number. Cc: stable@vger.kernel.org # v4.1+ Fixes: eddb60fb1443 Signed-off-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2015-09-21KVM: PPC: Book3S HV: Fix handling of interrupted VCPUsPaul Mackerras
This fixes a bug which results in stale vcore pointers being left in the per-cpu preempted vcore lists when a VM is destroyed. The result of the stale vcore pointers is usually either a crash or a lockup inside collect_piggybacks() when another VM is run. A typical lockup message looks like: [ 472.161074] NMI watchdog: BUG: soft lockup - CPU#24 stuck for 22s! [qemu-system-ppc:7039] [ 472.161204] Modules linked in: kvm_hv kvm_pr kvm xt_CHECKSUM ipt_MASQUERADE nf_nat_masquerade_ipv4 tun ip6t_rpfilter ip6t_REJECT nf_reject_ipv6 xt_conntrack ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6 ip6table_mangle ip6table_security ip6table_raw ip6table_filter ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw ses enclosure shpchp rtc_opal i2c_opal powernv_rng binfmt_misc dm_service_time scsi_dh_alua radeon i2c_algo_bit drm_kms_helper ttm drm tg3 ptp pps_core cxgb3 ipr i2c_core mdio dm_multipath [last unloaded: kvm_hv] [ 472.162111] CPU: 24 PID: 7039 Comm: qemu-system-ppc Not tainted 4.2.0-kvm+ #49 [ 472.162187] task: c000001e38512750 ti: c000001e41bfc000 task.ti: c000001e41bfc000 [ 472.162262] NIP: c00000000096b094 LR: c00000000096b08c CTR: c000000000111130 [ 472.162337] REGS: c000001e41bff520 TRAP: 0901 Not tainted (4.2.0-kvm+) [ 472.162399] MSR: 9000000100009033 <SF,HV,EE,ME,IR,DR,RI,LE> CR: 24848844 XER: 00000000 [ 472.162588] CFAR: c00000000096b0ac SOFTE: 1 GPR00: c000000000111170 c000001e41bff7a0 c00000000127df00 0000000000000001 GPR04: 0000000000000003 0000000000000001 0000000000000000 0000000000874821 GPR08: c000001e41bff8e0 0000000000000001 0000000000000000 d00000000efde740 GPR12: c000000000111130 c00000000fdae400 [ 472.163053] NIP [c00000000096b094] _raw_spin_lock_irqsave+0xa4/0x130 [ 472.163117] LR [c00000000096b08c] _raw_spin_lock_irqsave+0x9c/0x130 [ 472.163179] Call Trace: [ 472.163206] [c000001e41bff7a0] [c000001e41bff7f0] 0xc000001e41bff7f0 (unreliable) [ 472.163295] [c000001e41bff7e0] [c000000000111170] __wake_up+0x40/0x90 [ 472.163375] [c000001e41bff830] [d00000000efd6fc0] kvmppc_run_core+0x1240/0x1950 [kvm_hv] [ 472.163465] [c000001e41bffa30] [d00000000efd8510] kvmppc_vcpu_run_hv+0x5a0/0xd90 [kvm_hv] [ 472.163559] [c000001e41bffb70] [d00000000e9318a4] kvmppc_vcpu_run+0x44/0x60 [kvm] [ 472.163653] [c000001e41bffba0] [d00000000e92e674] kvm_arch_vcpu_ioctl_run+0x64/0x170 [kvm] [ 472.163745] [c000001e41bffbe0] [d00000000e9263a8] kvm_vcpu_ioctl+0x538/0x7b0 [kvm] [ 472.163834] [c000001e41bffd40] [c0000000002d0f50] do_vfs_ioctl+0x480/0x7c0 [ 472.163910] [c000001e41bffde0] [c0000000002d1364] SyS_ioctl+0xd4/0xf0 [ 472.163986] [c000001e41bffe30] [c000000000009260] system_call+0x38/0xd0 [ 472.164060] Instruction dump: [ 472.164098] ebc1fff0 ebe1fff8 7c0803a6 4e800020 60000000 60000000 60420000 8bad02e2 [ 472.164224] 7fc3f378 4b6a57c1 60000000 7c210b78 <e92d0000> 89290009 792affe3 40820070 The bug is that kvmppc_run_vcpu does not correctly handle the case where a vcpu task receives a signal while its guest vcpu is executing in the guest as a result of being piggy-backed onto the execution of another vcore. In that case we need to wait for the vcpu to finish executing inside the guest, and then remove this vcore from the preempted vcores list. That way, we avoid leaving this vcpu's vcore on the preempted vcores list when the vcpu gets interrupted. Fixes: ec2571650826 Reported-by: Thomas Huth <thuth@redhat.com> Tested-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2015-09-18kvm: svm: reset mmu on VCPU resetIgor Mammedov
When INIT/SIPI sequence is sent to VCPU which before that was in use by OS, VMRUN might fail with: KVM: entry failed, hardware error 0xffffffff EAX=00000000 EBX=00000000 ECX=00000000 EDX=000006d3 ESI=00000000 EDI=00000000 EBP=00000000 ESP=00000000 EIP=00000000 EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0 ES =0000 00000000 0000ffff 00009300 CS =9a00 0009a000 0000ffff 00009a00 [...] CR0=60000010 CR2=b6f3e000 CR3=01942000 CR4=000007e0 [...] EFER=0000000000000000 with corresponding SVM error: KVM: FAILED VMRUN WITH VMCB: [...] cpl: 0 efer: 0000000000001000 cr0: 0000000080010010 cr2: 00007fd7fe85bf90 cr3: 0000000187d0c000 cr4: 0000000000000020 [...] What happens is that VCPU state right after offlinig: CR0: 0x80050033 EFER: 0xd01 CR4: 0x7e0 -> long mode with CR3 pointing to longmode page tables and when VCPU gets INIT/SIPI following transition happens CR0: 0 -> 0x60000010 EFER: 0x0 CR4: 0x7e0 -> paging disabled with stale CR3 However SVM under the hood puts VCPU in Paged Real Mode* which effectively translates CR0 0x60000010 -> 80010010 after svm_vcpu_reset() -> init_vmcb() -> kvm_set_cr0() -> svm_set_cr0() but from kvm_set_cr0() perspective CR0: 0 -> 0x60000010 only caching bits are changed and commit d81135a57aa6 ("KVM: x86: do not reset mmu if CR0.CD and CR0.NW are changed")' regressed svm_vcpu_reset() which relied on MMU being reset. As result VMRUN after svm_vcpu_reset() tries to run VCPU in Paged Real Mode with stale MMU context (longmode page tables), which causes some AMD CPUs** to bail out with VMEXIT_INVALID. Fix issue by unconditionally resetting MMU context at init_vmcb() time. * AMD64 Architecture Programmer’s Manual, Volume 2: System Programming, rev: 3.25 15.19 Paged Real Mode ** Opteron 1216 Signed-off-by: Igor Mammedov <imammedo@redhat.com> Fixes: d81135a57aa6 Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-18sched: access local runqueue directly in single_task_runningDominik Dingel
Commit 2ee507c47293 ("sched: Add function single_task_running to let a task check if it is the only task running on a cpu") referenced the current runqueue with the smp_processor_id. When CONFIG_DEBUG_PREEMPT is enabled, that is only allowed if preemption is disabled or the currrent task is bound to the local cpu (e.g. kernel worker). With commit f78195129963 ("kvm: add halt_poll_ns module parameter") KVM calls single_task_running. If CONFIG_DEBUG_PREEMPT is enabled that generates a lot of kernel messages. To avoid adding preemption in that cases, as it would limit the usefulness, we change single_task_running to access directly the cpu local runqueue. Cc: Tim Chen <tim.c.chen@linux.intel.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Fixes: 2ee507c472939db4b146d545352b8a7c79ef47f8 Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-17Merge tag 'kvm-arm-for-4.3-rc2-2' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master Second set of KVM/ARM changes for 4.3-rc2 - Workaround for a Cortex-A57 erratum - Bug fix for the debugging infrastructure - Fix for 32bit guests with more than 4GB of address space on a 32bit host - A number of fixes for the (unusual) case when we don't use the in-kernel GIC emulation - Removal of ThumbEE handling on arm64, since these have been dropped from the architecture before anyone actually ever built a CPU - Remove the KVM_ARM_MAX_VCPUS limitation which has become fairly pointless
2015-09-17arm/arm64: KVM: Remove 'config KVM_ARM_MAX_VCPUS'Ming Lei
This patch removes config option of KVM_ARM_MAX_VCPUS, and like other ARCHs, just choose the maximum allowed value from hardware, and follows the reasons: 1) from distribution view, the option has to be defined as the max allowed value because it need to meet all kinds of virtulization applications and need to support most of SoCs; 2) using a bigger value doesn't introduce extra memory consumption, and the help text in Kconfig isn't accurate because kvm_vpu structure isn't allocated until request of creating VCPU is sent from QEMU; 3) the main effect is that the field of vcpus[] in 'struct kvm' becomes a bit bigger(sizeof(void *) per vcpu) and need more cache lines to hold the structure, but 'struct kvm' is one generic struct, and it has worked well on other ARCHs already in this way. Also, the world switch frequecy is often low, for example, it is ~2000 when running kernel building load in VM from APM xgene KVM host, so the effect is very small, and the difference can't be observed in my test at all. Cc: Dann Frazier <dann.frazier@canonical.com> Signed-off-by: Ming Lei <ming.lei@canonical.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-17arm64: KVM: Remove all traces of the ThumbEE registersWill Deacon
Although the ThumbEE registers and traps were present in earlier versions of the v8 architecture, it was retrospectively removed and so we can do the same. Whilst this breaks migrating a guest started on a previous version of the kernel, it is much better to kill these (non existent) registers as soon as possible. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> [maz: added commend about migration] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-17arm: KVM: Disable virtual timer even if the guest is not using itMarc Zyngier
When running a guest with the architected timer disabled (with QEMU and the kernel_irqchip=off option, for example), it is important to make sure the timer gets turned off. Otherwise, the guest may try to enable it anyway, leading to a screaming HW interrupt. The fix is to unconditionally turn off the virtual timer on guest exit. Cc: stable@vger.kernel.org Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-17arm64: KVM: Disable virtual timer even if the guest is not using itMarc Zyngier
When running a guest with the architected timer disabled (with QEMU and the kernel_irqchip=off option, for example), it is important to make sure the timer gets turned off. Otherwise, the guest may try to enable it anyway, leading to a screaming HW interrupt. The fix is to unconditionally turn off the virtual timer on guest exit. Cc: stable@vger.kernel.org Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-16arm/arm64: KVM: vgic: Check for !irqchip_in_kernel() when mapping resourcesPavel Fedin
Until b26e5fdac43c ("arm/arm64: KVM: introduce per-VM ops"), kvm_vgic_map_resources() used to include a check on irqchip_in_kernel(), and vgic_v2_map_resources() still has it. But now vm_ops are not initialized until we call kvm_vgic_create(). Therefore kvm_vgic_map_resources() can being called without a VGIC, and we die because vm_ops.map_resources is NULL. Fixing this restores QEMU's kernel-irqchip=off option to a working state, allowing to use GIC emulation in userspace. Fixes: b26e5fdac43c ("arm/arm64: KVM: introduce per-VM ops") Cc: stable@vger.kernel.org Signed-off-by: Pavel Fedin <p.fedin@samsung.com> [maz: reworked commit message] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-16KVM: s390: Replace incorrect atomic_or with atomic_andnotJason J. Herne
The offending commit accidentally replaces an atomic_clear with an atomic_or instead of an atomic_andnot in kvm_s390_vcpu_request_handled. The symptom is that kvm guests on s390 hang on startup. This patch simply replaces the incorrect atomic_or with atomic_andnot Fixes: 805de8f43c20 (atomic: Replace atomic_{set,clear}_mask() usage) Signed-off-by: Jason J. Herne <jjherne@linux.vnet.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-16arm: KVM: Fix incorrect device to IPA mappingMarek Majtyka
A critical bug has been found in device memory stage1 translation for VMs with more then 4GB of address space. Once vm_pgoff size is smaller then pa (which is true for LPAE case, u32 and u64 respectively) some more significant bits of pa may be lost as a shift operation is performed on u32 and later cast onto u64. Example: vm_pgoff(u32)=0x00210030, PAGE_SHIFT=12 expected pa(u64): 0x0000002010030000 produced pa(u64): 0x0000000010030000 The fix is to change the order of operations (casting first onto phys_addr_t and then shifting). Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> [maz: fixed changelog and patch formatting] Cc: stable@vger.kernel.org Signed-off-by: Marek Majtyka <marek.majtyka@tieto.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-16arm64: KVM: Fix user access for debug registersMarc Zyngier
When setting the debug register from userspace, make sure that copy_from_user() is called with its parameters in the expected order. It otherwise doesn't do what you think. Fixes: 84e690bfbed1 ("KVM: arm64: introduce vcpu->arch.debug_ptr") Reported-by: Peter Maydell <peter.maydell@linaro.org> Cc: Alex Bennée <alex.bennee@linaro.org> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-16KVM: vmx: fix VPID is 0000H in non-root operationWanpeng Li
Reference SDM 28.1: The current VPID is 0000H in the following situations: - Outside VMX operation. (This includes operation in system-management mode under the default treatment of SMIs and SMM with VMX operation; see Section 34.14.) - In VMX root operation. - In VMX non-root operation when the “enable VPID” VM-execution control is 0. The VPID should never be 0000H in non-root operation when "enable VPID" VM-execution control is 1. However, commit 34a1cd60 ("kvm: x86: vmx: move some vmx setting from vmx_init() to hardware_setup()") remove the codes which reserve 0000H for VMX root operation. This patch fix it by again reserving 0000H for VMX root operation. Cc: stable@vger.kernel.org # 3.19+ Fixes: 34a1cd60d17f62c1f077c1478a6c2ca8c3d17af4 Reported-by: Wincy Van <fanwenyi0529@gmail.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-16KVM: add halt_attempted_poll to VCPU statsPaolo Bonzini
This new statistic can help diagnosing VCPUs that, for any reason, trigger bad behavior of halt_poll_ns autotuning. For example, say halt_poll_ns = 480000, and wakeups are spaced exactly like 479us, 481us, 479us, 481us. Then KVM always fails polling and wastes 10+20+40+80+160+320+480 = 1110 microseconds out of every 479+481+479+481+479+481+479 = 3359 microseconds. The VCPU then is consuming about 30% more CPU than it would use without polling. This would show as an abnormally high number of attempted polling compared to the successful polls. Acked-by: Christian Borntraeger <borntraeger@de.ibm.com< Reviewed-by: David Matlack <dmatlack@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-15kvm: fix zero length mmio searchingJason Wang
Currently, if we had a zero length mmio eventfd assigned on KVM_MMIO_BUS. It will never be found by kvm_io_bus_cmp() since it always compares the kvm_io_range() with the length that guest wrote. This will cause e.g for vhost, kick will be trapped by qemu userspace instead of vhost. Fixing this by using zero length if an iodevice is zero length. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-15kvm: fix double free for fast mmio eventfdJason Wang
We register wildcard mmio eventfd on two buses, once for KVM_MMIO_BUS and once on KVM_FAST_MMIO_BUS but with a single iodev instance. This will lead to an issue: kvm_io_bus_destroy() knows nothing about the devices on two buses pointing to a single dev. Which will lead to double free[1] during exit. Fix this by allocating two instances of iodevs then registering one on KVM_MMIO_BUS and another on KVM_FAST_MMIO_BUS. CPU: 1 PID: 2894 Comm: qemu-system-x86 Not tainted 3.19.0-26-generic #28-Ubuntu Hardware name: LENOVO 2356BG6/2356BG6, BIOS G7ET96WW (2.56 ) 09/12/2013 task: ffff88009ae0c4b0 ti: ffff88020e7f0000 task.ti: ffff88020e7f0000 RIP: 0010:[<ffffffffc07e25d8>] [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP: 0018:ffff88020e7f3bc8 EFLAGS: 00010292 RAX: dead000000200200 RBX: ffff8801ec19c900 RCX: 000000018200016d RDX: ffff8801ec19cf80 RSI: ffffea0008bf1d40 RDI: ffff8801ec19c900 RBP: ffff88020e7f3bd8 R08: 000000002fc75a01 R09: 000000018200016d R10: ffffffffc07df6ae R11: ffff88022fc75a98 R12: ffff88021e7cc000 R13: ffff88021e7cca48 R14: ffff88021e7cca50 R15: ffff8801ec19c880 FS: 00007fc1ee3e6700(0000) GS:ffff88023e240000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f389d8000 CR3: 000000023dc13000 CR4: 00000000001427e0 Stack: ffff88021e7cc000 0000000000000000 ffff88020e7f3be8 ffffffffc07e2622 ffff88020e7f3c38 ffffffffc07df69a ffff880232524160 ffff88020e792d80 0000000000000000 ffff880219b78c00 0000000000000008 ffff8802321686a8 Call Trace: [<ffffffffc07e2622>] ioeventfd_destructor+0x12/0x20 [kvm] [<ffffffffc07df69a>] kvm_put_kvm+0xca/0x210 [kvm] [<ffffffffc07df818>] kvm_vcpu_release+0x18/0x20 [kvm] [<ffffffff811f69f7>] __fput+0xe7/0x250 [<ffffffff811f6bae>] ____fput+0xe/0x10 [<ffffffff81093f04>] task_work_run+0xd4/0xf0 [<ffffffff81079358>] do_exit+0x368/0xa50 [<ffffffff81082c8f>] ? recalc_sigpending+0x1f/0x60 [<ffffffff81079ad5>] do_group_exit+0x45/0xb0 [<ffffffff81085c71>] get_signal+0x291/0x750 [<ffffffff810144d8>] do_signal+0x28/0xab0 [<ffffffff810f3a3b>] ? do_futex+0xdb/0x5d0 [<ffffffff810b7028>] ? __wake_up_locked_key+0x18/0x20 [<ffffffff810f3fa6>] ? SyS_futex+0x76/0x170 [<ffffffff81014fc9>] do_notify_resume+0x69/0xb0 [<ffffffff817cb9af>] int_signal+0x12/0x17 Code: 5d c3 90 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 83 ec 08 48 8b 7f 20 e8 06 d6 a5 c0 48 8b 43 08 48 8b 13 48 89 df 48 89 42 08 <48> 89 10 48 b8 00 01 10 00 00 RIP [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP <ffff88020e7f3bc8> Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-15kvm: factor out core eventfd assign/deassign logicJason Wang
This patch factors out core eventfd assign/deassign logic and leaves the argument checking and bus index selection to callers. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-15kvm: don't try to register to KVM_FAST_MMIO_BUS for non mmio eventfdJason Wang
We only want zero length mmio eventfd to be registered on KVM_FAST_MMIO_BUS. So check this explicitly when arg->len is zero to make sure this. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-14KVM: make the declaration of functions within 80 charactersWei Yang
After 'commit 0b8ba4a2b658 ("KVM: fix checkpatch.pl errors in kvm/coalesced_mmio.h")', the declaration of the two function will exceed 80 characters. This patch reduces the TAPs to make each line in 80 characters. Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-14KVM: arm64: add workaround for Cortex-A57 erratum #852523Will Deacon
When restoring the system register state for an AArch32 guest at EL2, writes to DACR32_EL2 may not be correctly synchronised by Cortex-A57, which can lead to the guest effectively running with junk in the DACR and running into unexpected domain faults. This patch works around the issue by re-ordering our restoration of the AArch32 register aliases so that they happen before the AArch64 system registers. Ensuring that the registers are restored in this order guarantees that they will be correctly synchronised by the core. Cc: <stable@vger.kernel.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-09-14Merge tag 'kvm-arm-for-4.3-rc2' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master KVM/ARM changes for 4.3-rc2 - Fix timer interrupt injection after the rework that went in during the merge window - Reset the timer to zero on reboot - Make sure the TCR_EL2 RES1 bits are really set to 1 - Fix a PSCI affinity bug for non-existing vcpus
2015-09-14KVM: fix polling for guest halt continued even if disable itWanpeng Li
If there is already some polling ongoing, it's impossible to disable the polling, since as soon as somebody sets halt_poll_ns to 0, polling will never stop, as grow and shrink are only handled if halt_poll_ns is != 0. This patch fix it by reset vcpu->halt_poll_ns in order to stop polling when polling is disabled. Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-12Linux 4.3-rc1v4.3-rc1Linus Torvalds
2015-09-12Merge tag 'cris-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris Pull CRIS updates from Jesper Nilsson: "Mostly removal of old cruft of which we can use a generic version, or fixes for code not commonly run in the cris port, but also additions to enable some good debug" * tag 'cris-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris: (25 commits) CRISv10: delete unused lib/dmacopy.c CRISv10: delete unused lib/old_checksum.c CRIS: fix switch_mm() lockdep splat CRISv32: enable LOCKDEP_SUPPORT CRIS: add STACKTRACE_SUPPORT CRISv32: annotate irq enable in idle loop CRISv32: add support for irqflags tracing CRIS: UAPI: use generic types.h CRIS: UAPI: use generic shmbuf.h CRIS: UAPI: use generic msgbuf.h CRIS: UAPI: use generic socket.h CRIS: UAPI: use generic sembuf.h CRIS: UAPI: use generic sockios.h CRIS: UAPI: use generic auxvec.h CRIS: UAPI: use generic headers via Kbuild CRIS: UAPI: fix elf.h export CRIS: don't make asm/elf.h depend on asm/user.h CRIS: UAPI: fix ptrace.h CRISv32: Squash compile warnings for axisflashmap CRISv32: Add GPIO driver to the default configs ...
2015-09-12blk: rq_data_dir() should not return a booleanLinus Torvalds
rq_data_dir() returns either READ or WRITE (0 == READ, 1 == WRITE), not a boolean value. Now, admittedly the "!= 0" doesn't really change the value (0 stays as zero, 1 stays as one), but it's not only redundant, it confuses gcc, and causes gcc to warn about the construct switch (rq_data_dir(req)) { case READ: ... case WRITE: ... that we have in a few drivers. Now, the gcc warning is silly and stupid (it seems to warn not about the switch value having a different type from the case statements, but about _any_ boolean switch value), but in this case the code itself is silly and stupid too, so let's just change it, and get rid of warnings like this: drivers/block/hd.c: In function ‘hd_request’: drivers/block/hd.c:630:11: warning: switch condition has boolean value [-Wswitch-bool] switch (rq_data_dir(req)) { The odd '!= 0' came in when "cmd_flags" got turned into a "u64" in commit 5953316dbf90 ("block: make rq->cmd_flags be 64-bit") and is presumably because the old code (that just did a logical 'and' with 1) would then end up making the type of rq_data_dir() be u64 too. But if we want to retain the old regular integer type, let's just cast the result to 'int' rather than use that rather odd '!= 0'. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-12Merge branch 'writeback-plugging'Linus Torvalds
Fix up the writeback plugging introduced in commit d353d7587d02 ("writeback: plug writeback at a high level") that then caused problems due to the unplug happening with a spinlock held. * writeback-plugging: writeback: plug writeback in wb_writeback() and writeback_inodes_wb() Revert "writeback: plug writeback at a high level"
2015-09-12writeback: plug writeback in wb_writeback() and writeback_inodes_wb()Linus Torvalds
We had to revert the pluggin in writeback_sb_inodes() because the wb->list_lock is held, but we could easily plug at a higher level before taking that lock, and unplug after releasing it. This does that. Chris will run performance numbers, just to verify that this approach is comparable to the alternative (we could just drop and re-take the lock around the blk_finish_plug() rather than these two commits. I'd have preferred waiting for actual performance numbers before picking one approach over the other, but I don't want to release rc1 with the known "sleeping function called from invalid context" issue, so I'll pick this cleanup version for now. But if the numbers show that we really want to plug just at the writeback_sb_inodes() level, and we should just play ugly games with the spinlock, we'll switch to that. Cc: Chris Mason <clm@fb.com> Cc: Josef Bacik <jbacik@fb.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Neil Brown <neilb@suse.de> Cc: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11thermal: fix intel PCH thermal driver mismergeLinus Torvalds
I didn't notice this when merging the thermal code from Zhang, but his merge (commit 5a924a07f882: "Merge branches 'thermal-core' and 'thermal-intel' of .git into next") of the thermal-core and thermal-intel branches was wrong. In thermal-core, commit 17e8351a7739 ("thermal: consistently use int for temperatures") converted the thermal layer to use "int" for temperatures. But in parallel, in the thermal-intel branch commit d0a12625d2ff ("thermal: Add Intel PCH thermal driver") added support for the intel PCH thermal sensor using the old interfaces that used "unsigned long" pointers. This resulted in warnings like this: drivers/thermal/intel_pch_thermal.c:184:14: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] .get_temp = pch_thermal_get_temp, ^ drivers/thermal/intel_pch_thermal.c:184:14: note: (near initialization for ‘tzd_ops.get_temp’) drivers/thermal/intel_pch_thermal.c:186:19: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types] .get_trip_temp = pch_get_trip_temp, ^ drivers/thermal/intel_pch_thermal.c:186:19: note: (near initialization for ‘tzd_ops.get_trip_temp’) This fixes it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
