2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25generic_acl: no need to clone acl just to push it to set_cached_acl()Al Viro
In-core acls are copy-on-write, so the reference taken by set_cached_acl() will do just fine. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25reiserfs: cache negative ACLs for v1 stat formatChristoph Hellwig
Always set up a negative ACL cache entry if the inode can't have ACLs. That behaves much better than doing this check inside ->check_acl. Also remove the left over MAY_NOT_BLOCK check. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: cache negative ACLs if there is no attribute forkChristoph Hellwig
Always set up a negative ACL cache entry if the inode doesn't have an attribute fork. That behaves much better than doing this check inside ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-259p: do no return 0 from ->check_acl without actually checkingChristoph Hellwig
If we do not want to use ACLs we at least need to perform normal Unix permission checks. From the comment I'm not quite sure that's what is intended, but if 0p wants to do permission checks entirely on the server it needs to do so in ->permission, not in ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25CIFS: Fix oops while mounting with prefixpathPavel Shilovsky
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: Fix wrong return value of xfs_file_aio_writeMarkus Trippelsdorf
The fsync prototype change commit 02c24a82187d accidentally overwrote the ssize_t return value of xfs_file_aio_write with 0 for SYNC type writes. Fix this by checking if an error occured when calling xfs_file_fsync and only change the return value in this case. In addition xfs_file_fsync actually returns a normal negative error, so fix this, too. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25fix devtmpfs raceAl Viro
After we's done complete(&req->done), there's nothing to prevent the scope containing *req from being gone and *req overwritten by any kind of junk. So we must read req->next before that... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24caam: don't pass bogus S_IFCHR to debugfs_create_...()Al Viro
it will be replaced with S_IFREG anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24get rid of create_proc_entry() abuses - proc_mkdir() is there for purposeAl Viro
2011-07-24asus-wmi: ->is_visible() can't return negativeAl Viro
It's mode_t; return 0 (no access) on error. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24fix jffs2 ACLs on big-endian with 16bit mode_tAl Viro
casting int * to mode_t * is not a good thing - on a *lot* of big-endian architectures mode_t happens to be smaller than int and there it breaks quite spectaculary... Fucked-up-by: commit cfc8dc6f6f69ede939e09c2af06a01adee577285 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-249p: close ACL leaksAl Viro
2011-07-24ocfs2_init_acl(): fix a leakAl Viro
2011-07-24VFS : mount lock scalability for internal mountsTim Chen
For a number of file systems that don't have a mount point (e.g. sockfs and pipefs), they are not marked as long term. Therefore in mntput_no_expire, all locks in vfs_mount lock are taken instead of just local cpu's lock to aggregate reference counts when we release reference to file objects. In fact, only local lock need to have been taken to update ref counts as these file systems are in no danger of going away until we are ready to unregister them. The attached patch marks file systems using kern_mount without mount point as long term. The contentions of vfs_mount lock is now eliminated. Before un-registering such file system, kern_unmount should be called to remove the long term flag and make the mount point ready to be freed. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64, vdso: Do not allocate memory for the vDSO clocksource: Change __ARCH_HAS_CLOCKSOURCE_DATA to a CONFIG option x86, vdso: Drop now wrong comment Document the vDSO and add a reference parser ia64: Replace clocksource.fsys_mmio with generic arch data x86-64: Move vread_tsc and vread_hpet into the vDSO clocksource: Replace vread with generic arch data x86-64: Add --no-undefined to vDSO build x86-64: Allow alternative patching in the vDSO x86: Make alternative instruction pointers relative x86-64: Improve vsyscall emulation CS and RIP handling x86-64: Emulate legacy vsyscalls x86-64: Fill unused parts of the vsyscall page with 0xcc x86-64: Remove vsyscall number 3 (venosys) x86-64: Map the HPET NX x86-64: Remove kernel.vsyscall64 sysctl x86-64: Give vvars their own page x86-64: Document some of entry_64.S x86-64: Fix alignment of jiffies variable
2011-07-22Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, UV: Correct UV2 BAU destination timeout x86, UV: Correct failed topology memory leak x86, UV: Remove cpumask_t from the stack x86, UV: Rename hubmask to pnmask x86, UV: Correct reset_with_ipi() x86, UV: Allow for non-consecutive sockets x86, UV: Inline header file functions x86, UV: Fix smp_processor_id() use in a preemptable region x66, UV: Enable 64-bit ACPI MFCG support for SGI UV2 platform x86, UV: Clean up uv_mmrs.h
2011-07-22Merge branch 'x86-signal-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-signal-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Kill handle_signal()->set_fs() x86, do_signal: Simplify the TS_RESTORE_SIGMASK logic x86, signals: Convert the X86_32 code to use set_current_blocked() x86, signals: Convert the IA32_EMULATION code to use set_current_blocked()
2011-07-22Merge branch 'x86-numa-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-numa-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, numa: Implement pfn -> nid mapping granularity check x86, mm: s/PAGES_PER_ELEMENT/PAGES_PER_SECTION/
2011-07-22Merge branch 'x86-mtrr-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mtrr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mtrr: Use pci_dev->revision x86, mtrr: use stop_machine APIs for doing MTRR rendezvous stop_machine: implement stop_machine_from_inactive_cpu() stop_machine: reorganize stop_cpus() implementation x86, mtrr: lock stop machine during MTRR rendezvous sequence
2011-07-22Merge branch 'x86-microcode-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, microcode, AMD: Fix section header size check x86, microcode, AMD: Correct buf references
2011-07-22Merge branch 'x86-mce-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mce: Use mce_sysdev_ prefix to group functions x86, mce: Use mce_chrdev_ prefix to group functions x86, mce: Cleanup mce_read() x86, mce: Cleanup mce_create()/remove_device() x86, mce: Check the result of ancient_init() x86, mce: Introduce mce_gather_info() x86, mce: Replace MCM_ with MCI_MISC_ x86, mce: Replace MCE_SELF_VECTOR by irq_work x86, mce, severity: Clean up trivial coding style problems x86, mce, severity: Cleanup severity table x86, mce, severity: Make formatting a bit more readable x86, mce, severity: Fix two severities table signatures
2011-07-22Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, efi: Properly pre-initialize table pointers x86, efi: Add infrastructure for UEFI 2.0 runtime services x86, efi: Fix argument types for SetVariable()
2011-07-22Merge branch 'x86-cpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, intel, power: Correct the MSR_IA32_ENERGY_PERF_BIAS message x86, msr: Fix typo in ENERGY_PERF_BIAS_POWERSAVE x86, intel, power: Initialize MSR_IA32_ENERGY_PERF_BIAS
2011-07-22Merge branch 'x86-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, smpboot: Mark the names[] array in __inquire_remote_apic() as const x86: Convert vmalloc()+memset() to vzalloc()
2011-07-22Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix write lock scalability 64-bit issue x86: Unify rwsem assembly implementation x86: Unify rwlock assembly implementation x86, asm: Fix binutils 2.16 issue with __USER32_CS x86, asm: Cleanup thunk_64.S x86, asm: Flip RESTORE_ARGS arguments logic x86, asm: Flip SAVE_ARGS arguments logic x86, asm: Thin down SAVE/RESTORE_* asm macros
2011-07-22Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, ioapic: Print IR_IO_APIC_route_entry when IR is enabled x86, ioapic: Print IRTE when IR is enabled x86, x2apic: Preserve high 32-bits of IA32_APIC_BASE MSR x86, ioapic: Also print Dest field x86, ioapic: Format clean up for IOAPIC output x86: print APIC data a little later during boot
2011-07-22Merge branch 'timers-rtc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-rtc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Serialize EFI time accesses on rtc_lock x86: Serialize SMP bootup CMOS accesses on rtc_lock rtc: stmp3xxx: Remove UIE handlers rtc: stmp3xxx: Get rid of mach-specific accessors rtc: stmp3xxx: Initialize drvdata before registering device rtc: stmp3xxx: Port stmp-functions to mxs-equivalents rtc: stmp3xxx: Restore register definitions rtc: vt8500: Use define instead of hardcoded value for status bit
2011-07-22Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: time: Fix stupid KERN_WARN compile issue rtc: Avoid accumulating time drift in suspend/resume time: Avoid accumulating time drift in suspend/resume time: Catch invalid timespec sleep values in __timekeeping_inject_sleeptime
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) sched: Cleanup duplicate local variable in [enqueue|dequeue]_task_fair sched: Replace use of entity_key() sched: Separate group-scheduling code more clearly sched: Reorder root_domain to remove 64 bit alignment padding sched: Do not attempt to destroy uninitialized rt_bandwidth sched: Remove unused function cpu_cfs_rq() sched: Fix (harmless) typo 'CONFG_FAIR_GROUP_SCHED' sched, cgroup: Optimize load_balance_fair() sched: Don't update shares twice on on_rq parent sched: update correct entity's runtime in check_preempt_wakeup() xtensa: Use generic config PREEMPT definition h8300: Use generic config PREEMPT definition m32r: Use generic PREEMPT config sched: Skip autogroup when looking for all rt sched groups sched: Simplify mutex_spin_on_owner() sched: Remove rcu_read_lock() from wake_affine() sched: Generalize sleep inside spinlock detection sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPT sched: Isolate preempt counting in its own config option sched: Remove pointless in_atomic() definition check ...
2011-07-22Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits) perf: Remove the nmi parameter from the oprofile_perf backend x86, perf: Make copy_from_user_nmi() a library function perf: Remove perf_event_attr::type check x86, perf: P4 PMU - Fix typos in comments and style cleanup perf tools: Make test use the preset debugfs path perf tools: Add automated tests for events parsing perf tools: De-opt the parse_events function perf script: Fix display of IP address for non-callchain path perf tools: Fix endian conversion reading event attr from file header perf tools: Add missing 'node' alias to the hw_cache[] array perf probe: Support adding probes on offline kernel modules perf probe: Add probed module in front of function perf probe: Introduce debuginfo to encapsulate dwarf information perf-probe: Move dwarf library routines to dwarf-aux.{c, h} perf probe: Remove redundant dwarf functions perf probe: Move strtailcmp to string.c perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END tracing/kprobe: Update symbol reference when loading module tracing/kprobes: Support module init function probing kprobes: Return -ENOENT if probe point doesn't exist ...
2011-07-22Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Fix wrong check in list_splice_init_rcu() net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu() sysctl,rcu: Convert call_rcu(free_head) to kfree vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu() vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu() ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu() ipc,rcu: Convert call_rcu(free_un) to kfree_rcu() security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu() security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu() ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu() block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu() scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu() audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu() security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu() md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
2011-07-22Merge branch 'core-printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Fix trace_[soft,hard]irqs_[on,off]() recursion printk: Fix console_sem vs logbuf_lock unlock race printk: Release console_sem after logbuf_lock
2011-07-22Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Fix lockdep_no_validate against IRQ states mutex: Make mutex_destroy() an inline function plist: Remove the need to supply locks to plist heads lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP option
2011-07-22vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filpKonstantin Khlebnikov
Replace unclear (struct dentry *) to (struct file *) typecast with ERR_CAST() macro. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22isofs: Remove global fs lockJan Kara
sbi->s_mutex isn't needed for isofs at all so we can just remove it. Generally, since isofs is always mounted read-only, filesystem structure cannot change under us. So buffer_head contents stays constant after it's filled in. That leaves us with possible changes of global data structures. Superblock changes only during filesystem mount (even remount does not change it), inodes are only filled in during reading from disk. So there are no changes of these structures to bother about. Arguments why sbi->s_mutex can be removed at each place: isofs_readdir: Accesses sb, inode, filp, local variables => s_mutex not needed isofs_lookup: Protected by directory's i_mutex. Accesses sb, inode, dentry, local variables => s_mutex not needed rock_ridge_symlink_readpage: Protected by page lock. Accesses sb, inode, local variables => s_mutex not needed. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directoryAl Viro
We don't generate IN_DELETE_SELF on victim of overwriting rename() if it happens to be a directory. Trivially fixed by doing to ->i_nlink what we do ->pino_nlink a couple of lines later in jffs2_rename(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.Al Viro
On ramfs and other simple_rename() users IN_DELETE_SELF is not generated for victim of overwriting rename() if it's is a directory. Works on most of the local filesystems and really trivial to fix... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22mm/truncate.c: fix build for CONFIG_BLOCK not enabledRandy Dunlap
Fix build error when CONFIG_BLOCK is not enabled by providing a stub inode_dio_wait() function. mm/truncate.c:612: error: implicit declaration of function 'inode_dio_wait' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: iommu/core: Fix build with INTR_REMAP=y && CONFIG_DMAR=n iommu/amd: Don't use MSI address range for DMA addresses iommu/amd: Move missing parts to drivers/iommu iommu: Move iommu Kconfig entries to submenu x86/ia64: intel-iommu: move to drivers/iommu/ x86: amd_iommu: move to drivers/iommu/ msm: iommu: move to drivers/iommu/ drivers: iommu: move to a dedicated folder x86/amd-iommu: Store device alias as dev_data pointer x86/amd-iommu: Search for existind dev_data before allocting a new one x86/amd-iommu: Allow dev_data->alias to be NULL x86/amd-iommu: Use only dev_data in low-level domain attach/detach functions x86/amd-iommu: Use only dev_data for dte and iotlb flushing routines x86/amd-iommu: Store ATS state in dev_data x86/amd-iommu: Store devid in dev_data x86/amd-iommu: Introduce global dev_data_list x86/amd-iommu: Remove redundant device_flush_dte() calls iommu-api: Add missing header file Fix up trivial conflicts (independent additions close to each other) in drivers/Makefile and include/linux/pci.h
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (51 commits) PM: Improve error code of pm_notifier_call_chain() PM: Add "RTC" to PM trace time stamps to avoid confusion PM / Suspend: Export suspend_set_ops, suspend_valid_only_mem PM / Suspend: Add .suspend_again() callback to suspend_ops PM / OPP: Introduce function to free cpufreq table ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active PM / Domains: Take .power_off() error code into account ARM / shmobile: Use genpd_queue_power_off_work() ARM / shmobile: Use pm_genpd_poweroff_unused() PM / Domains: Introduce function to power off all unused PM domains OMAP: PM: disable idle on suspend for GPIO and UART OMAP: PM: omap_device: add API to disable idle on suspend OMAP: PM: omap_device: add system PM methods for PM domain handling OMAP: PM: omap_device: conditionally use PM domain runtime helpers PM / Runtime: Add new helper function: pm_runtime_status_suspended() PM / Domains: Queue up power off work only if it is not pending PM / Domains: Improve handling of wakeup devices during system suspend PM / Domains: Do not restore all devices on power off error PM / Domains: Allow callbacks to execute all runtime PM helpers PM / Domains: Do not execute device callbacks under locks ...
2011-07-22Merge branch 'for-linus-core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-linus-core' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (38 commits) target: Bump version to v4.1.0-rc1-ml target: remove custom hex2bin() implementation target: fix typo Assoication -> Association target: Update QUEUE ALGORITHM MODIFIER control page default target: ->map_task_SG conversion to ->map_control_SG and ->map_data_SG target: Follow up core updates from AGrover and HCH (round 4) target: Eliminate usage of struct se_mem target: Pass 2nd param of transport_split_cdb by value target: Enforce 1 page max for control cdb buffer sizes target: Make all control CDBs scatter-gather target: Implement Block Device Characteristics VPD page target: Fix reporting of supported VPD pages target: Allow for built-in target modules tcm_fc: Convert to wake_up_process and schedule_timeout_interruptible tcm_fc: Makefile cleanups loopback: Fix memory leak in tcm_loop_make_scsi_hba() loopback: Remove duplicate scsi/scsi_tcq.h include loopback: off by one in tcm_loop_make_naa_tpg() target/iblock: Remove unused iblock_dev members target/iblock: Use request_queue->nr_request for se_device defaults ...
2011-07-22Merge branch 'for-3.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-3.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Fixup __this_cpu_xchg* operations
2011-07-22Merge branch 'for-3.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-3.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: separate out drain_workqueue() from destroy_workqueue() workqueue: remove cancel_rearming_delayed_work[queue]()
2011-07-22Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits) ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction connector: add an event for monitoring process tracers ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task() ptrace_init_task: initialize child->jobctl explicitly has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/ ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/ ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented() ptrace: ptrace_reparented() should check same_thread_group() redefine thread_group_leader() as exit_signal >= 0 do not change dead_task->exit_signal kill task_detached() reparent_leader: check EXIT_DEAD instead of task_detached() make do_notify_parent() __must_check, update the callers __ptrace_detach: avoid task_detached(), check do_notify_parent() kill tracehook_notify_death() make do_notify_parent() return bool ptrace: s/tracehook_tracer_task()/ptrace_parent()/ ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (31 commits) HID: fix support for Microsoft comfort mouse 4500 HID: hid-multitouch: add one new multitouch device's VID/PID HID: prodikeys: remove a redundant forward declaration of struct pcmidi_snd HID: prodikeys: make needlessly global symbols static HID: emsff: properly handle emsff_init failure HID: ACRUX - add missing hid_hw_stop() in ax_probe() error path HID: fix horizontal wheel for ms comfort mouse 4500 HID: uclogic: Add support for UC-Logic WP1062 HID: wiimote: Add sysfs support to wiimote driver HID: wiimote: Cache wiimote led state HID: wiimote: Add wiimote led request HID: wiimote: Add wiimote input button parser HID: wiimote: Add wiimote event handler HID: wiimote: Add output queue for wiimote driver HID: wiimote: Add wiimote send function HID: wiimote: Synchronize wiimote input and hid event handling HID: wiimote: Register input device in wiimote hid driver HID: wiimote: Add wiimote device structure HID: wiimote: Register wiimote hid driver stub HID: wiimote: Add Nintendo Wii Remote driver stub ...
