git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (30 commits)
USB: ftdi_sio: add Calao reference board support
USB option driver K3765/K4505 avoid CDC_DATA interface
USB: option: add YUGA device id to driver
usb: s5p-ehci: fix a NULL pointer deference
USB: EHCI: Do not rely on PORT_SUSPEND to stop USB resuming in ehci_bus_resume().
USB option driver add PID of Huawei Vodafone K4605
USB option driver add PID of Huawei Vodafone K3806
xhci: Handle zero-length isochronous packets.
USB: Avoid NULL pointer deref in usb_hcd_alloc_bandwidth.
usb: musb: gadget: fix error path
usb: gadget: f_phonet: unlock in error case
usb: musb: blackfin: include prefetch head file
usb: musb: tusb6010: fix compilation
usb: gadget: renesas_usbhs: fix DMA build by including dma-mapping.h
usb: musb: cppi: fix build errors due to DBG and missing musb variable
usb: musb: ux500: replace missing DBG with dev_dbg
usb: musb: ux500: set dma config for both src and dst
usb: musb: fix oops on musb_gadget_pullup
usb: host: ehci-omap: fix .remove and failure handling path of .probe(v1)
usb: gadget: hid: don't STALL when processing a HID Descriptor request
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
omap-serial: Allow IXON and IXOFF to be disabled.
TTY: serial, document ignoring of uart->ops->startup error
TTY: pty, fix pty counting
8250: Fix race condition in serial8250_backup_timeout().
serial/8250_pci: delete duplicate data definition
8250_pci: add support for Rosewill RC-305 4x serial port card
tty: Add "spi:" prefix for spi modalias
atmel_serial: fix atmel_default_console_device
serial: 8250_pnp: add Intermec CV60 touchscreen device
drivers/serial/ucc_uart.c: Fix compiler warning
pch_uart: Set PCIe bus number using probe parameter
serial: samsung: Fix build error
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
drivers:misc: ti-st: fix unexpected UART close
drivers:misc: ti-st: free skb on firmware download
drivers:misc: ti-st: wait for completion at fail
drivers:misc: ti-st: reinit completion before send
drivers:misc: ti-st: fail-safe on wrong pkt type
drivers:misc: ti-st: reinit completion on ver read
drivers:misc:ti-st: platform hooks for chip states
drivers:misc: ti-st: avoid a misleading dbg msg
base/devres.c: quiet sparse noise about context imbalance
pti: add missing CONFIG_PCI dependency
drivers/base/devtmpfs.c: correct annotation of `setup_done'
driver core: fix kernel-doc warning in platform.c
firmware: fix google/gsmi.c build warning
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6:
staging: tidspbridge: fix compilation on dsp clock functions
staging: octeon-ethernet: Add missing #includes.
Staging: zcache: signedness bug in tmem_get()
staging: zcache: fix crash on high memory swap
staging: brcm80211: SPARC build error fix
staging: brcm80211: fix compile error on non-x86 archs since 3.0 kernel
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] memory hotplug: only unassign assigned increments
[S390] Change default action from reipl to stop for on_restart
[S390] arch/s390/kernel/ipl.c: correct error detection check
[S390] drivers/s390/block/dasd_ioctl.c: add missing kfree
[S390] nss,initrd: kernel image and initrd must be in different segments
According to the SFI specification irq number 0xFF means device has no
interrupt or interrupt attached via GPIO.
Currently, we don't handle this special case and set irq field in
*_board_info structs to 255. It leads to confusion in some drivers.
Accelerometer driver tries to register interrupt 255, fails and prints
"Cannot get IRQ" to dmesg.
Signed-off-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (32 commits)
ALSA: hda: Conexant: Allow different output types to share DAC
ASoC: Correct element count for WM8996 sidetone HPF
ASoC: Tegra: wm8903 machine driver: Drop Ventana support
ASoC: Add samsung maintainer
ASoC: Add Springbank I/O card to Speyside Kconfig
ALSA: hda/conexant - Enable ADC-switching for auto-mic mode, too
ALSA: hda - Fix double-headphone/speaker paths for Cxt auto-parser
ALSA: hda - Update jack-sense info even when no automute is set
ALSA: hda - Fix output-path initialization for Realtek auto-parser
sound/soc/fsl/mpc8610_hpcd.c: add missing of_node_put
sound/soc/fsl/p1022_ds.c: add missing of_node_put
sound/soc/ep93xx/ep93xx-i2s.c: add missing kfree
sound/soc/kirkwood/kirkwood-i2s.c: add missing kfree
ASoC: soc-core: use GFP_KERNEL flag for kmalloc in snd_soc_cnew
sound/soc/fsl/fsl_dma.c: add missing of_node_put
ASoC: Clear completions from late WM8996 FLL lock IRQs
ASoC: Clear any outstanding WM8962 FLL lock completions before waiting
ASoC: Ensure we only run Speyside WM8962 bias level callbacks once
ASoC: Fix configuration of WM8996 input enables
ASoC: WM8996 record paths need AIFCLK
This bug causes the IECSR register clear failure. In this case, the RETE
(retry error threshold exceeded) interrupt will be generated and cannot be
cleared. So the related ISR may be called persistently.
The RETE bit in IECSR is cleared by writing a 1 to it.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: <stable@kernel.org>
have irq.
The previous rtc-s3c had two issues related with its IRQ.
1. Users cannot open rtc multiple times because an open operation
calls request_irq on the same IRQ. (e.g., two user processes wants to
open and read RTC time from rtc-s3c at the same time)
2. If alarm is set and no one has the rtc opened with filesystem
(either the alarm is set by kernel/boot-loader or user set an alarm and
closed rtc dev file), the pending bit is not cleared and no further
interrupt is invoked. When the alarm is used by the system itself such
as a resume from suspend-to-RAM or other Low-power modes/idle, this is
a critical issue.
This patch mitigates these issues by calling request_irq at probe and
free_irq at remove.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Changhwan Youn <chaos.youn@samsung.com>
RTC-S3C used to print out debug messages incorrectly. This patch
corrects incorrect outputs. (undecoded bcd numbers, incorrectly decoded
register values)
This patch affects the pr-debug messages only.
unregister all registered leds
bd2802_unregister_led_classdev() should unregister all registered
instances of led_classdev class that had registered by
bd2802_register_led_classdev().
Acked-by: Kim Kyuwon <q1.kim@samsung.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Fix the following build errors:
drivers/tty/serial/8250_early.c:160: error: 'BASE_BAUD' undeclared (first use in this function): 1 errors in 1 logs
drivers/tty/serial/8250_early.c:37:24: error: asm/serial.h: No such file or directory: 1 errors in 1 logs
I am not sure if (1843200 / 16) is suitable for cris, but most other
arch's define it as this value.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Since 43cc71eed12 ("platform: prefix MODALIAS with "platform:""), the
platform modalias is prefixed with "platform:".
This patch changes the MODULE_ALIAS to "platform:ab8500-pwm".
Acked-by: Arun Murthy <arun.murthy@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
Make sure we are passing the same cookie in all calls to
request_threaded_irq() and free_irq().
Cc: Donggeun Kim <dg77.kim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
This is an i2c driver, not a platform driver, thus use "i2c" prefix for
the module alias.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
We need a callback to do some things after pwm_enable, pwm_disable
and pwm_config.
Signed-off-by: Dilan Lee <dilee@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Arun Murthy <arun.murthy@stericsson.com>
Commit 79dfdaccd1d5 ("memcg: make oom_lock 0 and 1 based rather than
counter") tried to oom lock the hierarchy and roll back upon
encountering an already locked memcg.
The code is confused when it comes to detecting a locked memcg, though,
so it would fail and rollback after locking one memcg and encountering
an unlocked second one.
The result is that oom-locking hierarchies fails unconditionally and
that every oom killer invocation simply goes to sleep on the oom
waitqueue forever. The tasks practically hang forever without anyone
intervening, possibly holding locks that trip up unrelated tasks, too.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Add missing include of linux/module.h for drivers that use interfaces from
linux/module.h. This patch fixes build errors.
Cc: Jonathan McDowell <noodles@earth.li>
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Cc: Magnus Damm <damm@opensource.se>
ep93xx_bl.c uses interfaces from linux/module.h, so it should include
that file. This patch fixes build errors:
CC [M] drivers/video/backlight/ep93xx_bl.o
drivers/video/backlight/ep93xx_bl.c:138: error: 'THIS_MODULE' undeclared here (not in a function)
drivers/video/backlight/ep93xx_bl.c:158: error: expected declaration specifiers or '...' before string constant
drivers/video/backlight/ep93xx_bl.c:158: warning: data definition has no type or storage class
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Ryan Mallon <rmallon@gmail.com>
Replace/remove use of RIO v.1.2 registers/bits that are not
forward-compatible with newer versions of RapidIO specification.
RapidIO specification v.1.3 removed Write Port CSR, Doorbell CSR,
Mailbox CSR and Mailbox and Doorbell bits of the PEF CAR.
Use of removed (since RIO v.1.3) register bits affects users of
currently available 1.3 and 2.x compliant devices who may use not so
recent kernel versions.
Removing checks for unsupported bits makes corresponding routines
compatible with all versions of RapidIO specification. Therefore,
backporting makes stable kernel versions compliant with RIO v.1.3 and
later as well.
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: Thomas Moll <thomas.moll@sysgo.com>
Cc: Chul Kim <chul.kim@idt.com>
ZONE_CONGESTED is only cleared in kswapd, but pages can be freed in any
task. It's possible ZONE_CONGESTED isn't cleared in some cases:
1. the zone is already balanced just entering balance_pgdat() for
order-0 because concurrent tasks free memory. In this case, later
check will skip the zone as it's balanced so the flag isn't cleared.
2. high order balance fallbacks to order-0. quote from Mel: At the
end of balance_pgdat(), kswapd uses the following logic;
If reclaiming at high order {
for each zone {
if all_unreclaimable
skip
if watermark is not met
order = 0
loop again
/* watermark is met */
clear congested
i.e. it clears ZONE_CONGESTED if it the zone is balanced. if not,
it restarts balancing at order-0. However, if the higher zones are
balanced for order-0, kswapd will miss clearing ZONE_CONGESTED as
that only happens after a zone is shrunk. This can mean that
wait_iff_congested() stalls unnecessarily.
This patch makes kswapd clear ZONE_CONGESTED during its initial
highmem->dma scan for zones that are already balanced.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
It seems that 7bf693951a8e ("console: allow to retain boot console via
boot option keep_bootcon") doesn't always achieve what it aims, as when
printk_late_init() runs it unconditionally turns off all boot consoles.
With this patch, I am able to see more messages on the boot console in
KVM guests than I can without, when keep_bootcon is specified.
I think it is appropriate for the relevant -stable trees. However, it's
more of an annoyance than a serious bug (ideally you don't need to keep
the boot console around as console handover should be working -- I was
encountering a situation where the console handover wasn't working and
not having the boot console available meant I couldn't see why).
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg KH <gregkh@suse.de>
Acked-by: Fabio M. Di Nitto <fdinitto@redhat.com>
Cc: <stable@kernel.org> [2.6.39.x, 3.0.x]
Paul said: I left Google at the end of last week - if it's not bouncing
already, menage@google.com isn't going to work for much longer.
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Acked-by: Paul Menage <paul@paulmenage.org>
I get the below warning:
BUG: using smp_processor_id() in preemptible [00000000] code: bash/746
caller is native_sched_clock+0x37/0x6e
Pid: 746, comm: bash Tainted: G W 3.0.0+ #254
Call Trace:
[<ffffffff813435c6>] debug_smp_processor_id+0xc2/0xdc
[<ffffffff8104158d>] native_sched_clock+0x37/0x6e
[<ffffffff81116219>] try_to_free_mem_cgroup_pages+0x7d/0x270
[<ffffffff8114f1f8>] mem_cgroup_force_empty+0x24b/0x27a
[<ffffffff8114ff21>] ? sys_close+0x38/0x138
[<ffffffff8114f257>] mem_cgroup_force_empty_write+0x17/0x19
[<ffffffff810c72fb>] cgroup_file_write+0xa8/0xba
[<ffffffff811522d2>] vfs_write+0xb3/0x138
[<ffffffff8115241a>] sys_write+0x4a/0x71
[<ffffffff8114ffd9>] ? sys_close+0xf0/0x138
[<ffffffff8176deab>] system_call_fastpath+0x16/0x1b
sched_clock() can't be used with preempt enabled. And we don't need
fast approach to get clock here, so let's use ktime API.
Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The various basic memory allocation function return NULL, not an
ERR_PTR.
The semantic patch that makes this change is available in
scripts/coccinelle/null/eno.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Cc: Niranjana Vishwanathapura <nvishwan@codeaurora.org>
The test for bad usage of min_t() and max_t() is missing the --ignore
type. Add it.
Signed-off-by: Hui Zhu <teawater@gmail.com>
Change to new git tree -
(git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git).
Signed-off-by: Ralf Thielow <ralf.thielow@googlemail.com>
Cc: Joe Perches <joe@perches.com>
Commit d1a05b6973c7 ("memcg do not try to drain per-cpu caches without
pages") added a drain_local_stock() call to a preemptible section.
The draining task looks up the cpu-local stock twice to set the
draining-flag, then to drain the stock and clear the flag again. If the
task is migrated to a different CPU in between, noone will clear the
flag on the first stock and it will be forever undrainable. Its charge
can not be recovered and the cgroup can not be deleted anymore.
Properly pin the task to the executing CPU while draining stocks.
Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
The for loop was looking for i <= 0 instead of i >= 0 so this function
never did anything. Also we started with i = NB_SYSFS_BIN_FILES instead
of "NB_SYSFS_BIN_FILES - 1" which is an off by one bug.
Reported-by: Bojan Prtvar <prtvar.b@gmail.com>
Acked-by: Jean-Franois Dagenais <dagenaisj@sonatest.com>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
The bug was accidentally found by the following program:
#include <asm/sysinfo.h>
#include <asm/unistd.h>
#include <sys/syscall.h>
static int setsysinfo(unsigned long op, void *buffer, unsigned long size,
int *start, void *arg, unsigned long flag) {
return syscall(__NR_osf_setsysinfo, op, buffer, size, start, arg, flag);
int main(int argc, char **argv) {
short x[10];
unsigned int buf[2] = { SSIN_UACPROC, UAC_SIGBUS, };
setsysinfo(SSI_NVPAIRS, buf, 1, 0, 0, 0);
int *y = (int*) (x+1);
*y = 0;
return 0;
The program shoud fail on SIGBUS, but didn't.
The patch is a second part of userspace flag fix (commit 745dd2405e28
"Alpha: Rearrange thread info flags fixing two regressions").
Deleted outdated out-of-sync 'UAC_SHIFT' (the cause of bug) in favour of
'ALPHA_UAC_SHIFT'.
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Acked-by: Michael Cree <mcree@orcon.net.nz>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Found on allmodconfig build (ARCH=alpha)
drivers/misc/pti.c: In function 'get_id':
drivers/misc/pti.c:249: error: implicit declaration of function 'kmalloc'
drivers/misc/pti.c: In function 'pti_char_write':
drivers/misc/pti.c:658: error: implicit declaration of function 'copy_from_user'
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: J Freyensee <james_p_freyensee@linux.intel.com>
Cc: Jeremy Rocher <rocher.jeremy@gmail.com>
entry_32.S contained a hardcoded alternative instruction entry, and the
format changed in commit 59e97e4d6fbc ("x86: Make alternative
instruction pointers relative").
Replace the hardcoded entry with the altinstruction_entry macro. This
fixes the 32-bit boot with CONFIG_X86_INVD_BUG=y.
Reported-and-tested-by: Arnaud Lacombe <lacombar@gmail.com>
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Cc: Peter Anvin <hpa@zytor.com>
While removing custom rendezvous code and switching to stop_machine,
commit 192d8857427d ("x86, mtrr: use stop_machine APIs for doing MTRR
rendezvous") completely dropped mtrr setting code on !CONFIG_SMP
breaking MTRR settting on UP.
Fix it by removing the incorrect CONFIG_SMP.
Reported-by: Anders Eriksson <aeriksson@fastmail.fm>
Tested-and-acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Purely in-memory filesystems do not use the inode hash as the dcache
tells us if an entry already exists. As a result, they do not call
unlock_new_inode, and thus directory inodes do not get put into a
different lockdep class for i_sem.
We need the different lockdep classes, because the locking order for
i_mutex is different for directory inodes and regular inodes. Directory
inodes can do "readdir()", which takes i_mutex *before* possibly taking
mm->mmap_sem (due to a page fault while copying the directory entry to
user space).
In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem
before accessing i_mutex.
The two cases can never happen for the same inode, so no real deadlock
can occur, but without the different lockdep classes, lockdep cannot
understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this
can lead to false positives from lockdep like below:
find/645 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac
but task is already holding lock:
(&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>]
vfs_readdir+0x5b/0xb4
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}:
[<ffffffff8108ac26>] lock_acquire+0xbf/0x103
[<ffffffff814db822>] __mutex_lock_common+0x4c/0x361
[<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45
[<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110
[<ffffffff81111557>] mmap_region+0x258/0x432
[<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306
[<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a
[<ffffffff8100c858>] sys_mmap+0x22/0x24
[<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7
[<ffffffff81109541>] might_fault+0x89/0xac
[<ffffffff81149cff>] filldir+0x6f/0xc7
[<ffffffff811586ea>] dcache_readdir+0x67/0x205
[<ffffffff81149f54>] vfs_readdir+0x7b/0xb4
[<ffffffff8114a073>] sys_getdents+0x7e/0xd1
This patch moves the directory vs file lockdep annotation into a helper
function that can be called by in-memory filesystems and has hugetlbfs
call it.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback:
squeeze max-pause area and drop pass-good area
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils:
cpupower: use man(1) when calling "cpupower help subcommand"
cpupower: make NLS truly optional
cpupower: fix Makefile typo
cpupower: Make monitor command -c/--cpu aware
cpupower: Better detect offlined CPUs
cpupower: Do not show an empty Idle_Stats monitor if no idle driver is available
cpupower: mperf monitor - Use TSC to calculate max frequency if possible
cpupower: avoid using symlinks
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: (i5k_amb) Drop i5k_channel_pci_id
hwmon: (ntc_thermistor) Simplify if sequence
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
* '3.1-rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (21 commits)
target: Convert acl_node_lock to be IRQ-disabling
target: Make locking in transport_deregister_session() IRQ safe
tcm_fc: init/exit functions should not be protected by "#ifdef MODULE"
target: Print subpage too for unhandled MODE SENSE pages
iscsi-target: Fix iscsit_allocate_se_cmd_for_tmr failure path bugs
iscsi-target: Implement iSCSI target IPv6 address printing.
target: Fix task SGL chaining breakage with transport_allocate_data_tasks
target: Fix task count > 1 handling breakage and use max_sector page alignment
target: Add missing DATA_SG_IO transport_cmd_get_valid_sectors check
target: Fix SYNCHRONIZE_CACHE zero LBA + range breakage
target: Remove duplicate task completions in transport_emulate_control_cdb
target: Fix WRITE_SAME usage with transport_get_size
target: Add WRITE_SAME (10) parsing and refactor passthrough checks
target: Fix write payload exception handling with ->new_cmd_map
iscsi-target: forever loop bug in iscsit_attach_ooo_cmdsn()
iscsi-target: remove duplicate return
target: Convert target_core_rd.c to use use BUG_ON
iscsi-target: Fix leak on failure in iscsi_copy_param_list()
target: Use ERR_CAST inlined function
target: Make standard INQUIRY return 'not connected' for tpg_virt_lun0
I ran into a couple of programs which broke with the new Linux 3.0
version. Some of those were binary only. I tried to use LD_PRELOAD to
work around it, but it was quite difficult and in one case impossible
because of a mix of 32bit and 64bit executables.
For example, all kind of management software from HP doesnt work, unless
we pretend to run a 2.6 kernel.
$ uname -a
Linux svivoipvnx001 3.0.0-08107-g97cd98f #1062 SMP Fri Aug 12 18:11:45 CEST 2011 i686 i686 i386 GNU/Linux
$ hpacucli ctrl all show
Error: No controllers detected.
$ rpm -qf /usr/sbin/hpacucli
hpacucli-8.75-12.0
Another notable case is that Python now reports "linux3" from
sys.platform(); which in turn can break things that were checking
sys.platform() == "linux2":
https://bugzilla.mozilla.org/show_bug.cgi?id=664564
It seems pretty clear to me though it's a bug in the apps that are using
'==' instead of .startswith(), but this allows us to unbreak broken
programs.
This patch adds a UNAME26 personality that makes the kernel report a
2.6.40+x version number instead. The x is the x in 3.x.
I know this is somewhat ugly, but I didn't find a better workaround, and
compatibility to existing programs is important.
Some programs also read /proc/sys/kernel/osrelease. This can be worked
around in user space with mount --bind (and a mount namespace)
To use:
wget ftp://ftp.kernel.org/pub/linux/kernel/people/ak/uname26/uname26.c
gcc -o uname26 uname26.c
./uname26 program
Calao use on there dev kits a FT2232 where the port 0 is used for the JTAG and
port 1 for the UART
They use the same VID and PID as FTDI Chip but they program the manufacturer
name in the eeprom
So use this information to detect it
Cc: Gregory Hermant <gregory.hermant@calao-systems.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: stable <stable@kernel.org>
Headphones has stopped working for the original reported (a regression
compared to 2.6.38). This is because Speaker and Headphones share the
same DAC, in which case no Headphones volume control was created.
This patch fixes so that both Speaker and Headphones volume
controls are created in such scenario.
BugLink: http://bugs.launchpad.net/bugs/817943
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
In commit a144c6a6c924 ("PM: Print a warning if firmware is requested
when tasks are frozen") we not only printed a warning if somebody tried
to load the firmware when tasks are frozen - we also failed the load.
But that check was done before the check for built-in firmware, and then
when we disallowed usermode helpers during bootup (commit 288d5abec831:
"Boot up with usermodehelper disabled"), that actually means that
built-in modules can no longer load their firmware even if the firmware
is built in too. Which used to work, and some people depended on it for
the R100 driver.
So move the test for usermodehelper_is_disabled() down, to after
checking the built-in firmware.
This should fix:
https://bugzilla.kernel.org/show_bug.cgi?id=40952
Reported-by: James Cloos <cloos@hjcloos.com>
Bisected-by: Elimar Riesebieter <riesebie@lxtec.de>
Cc: Michel Dänzer <michel@daenzer.net>
Cc: Rafael Wysocki <rjw@sisk.pl>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
* 'for-31-rc3/i2c-fixes' of git://git.fluff.org/bjdooks/linux:
i2c-nomadik: fix kerneldoc warning
Revert "i2c-omap: fix static suspend vs. runtime suspend"
i2c-nomadik: Do not use _interruptible_ variant call
There was a missing struct item in the kerneldoc, add it and fix
another pretty-printing formatting issue with a missing space.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Seen on v3.1-rc3, patch:
omap: mcbsp: Drop in-driver transfer support
bafe2721a0fbd1cc1af04384133684f660f3658e
Removed code that now cause tidspbridge to break while compiling.
Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: wiimote: Add status and return request handlers
HID: wiimote: Add drm request
HID: wiimote: Register led class devices
HID: wiimote: Correctly call HID open/close callbacks
HID: wiimote: Simplify synchronization
HID: usbhid: Add support for SiGma Micro chip
HID: add support for new revision of Apple aluminum keyboard
I can count. Honest.
Acked-by: Liam Girdwood <lrg@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: ad714x - read the interrupt status registers in a row
Input: ad714x - use DMA-safe buffers for spi_write()
Input: ad714x - fix endianness issues
Input: ad714xx-spi - force SPI bus into the default 8-bit mode
Input: ep93xx_keypad - add missing include of linux/module.h
Input: tnetv107x-ts - add missing include of linux/module.h
Input: max11801_ts - correct license statement
Input: atmel_mxt_ts - report pressure information from the driver
Input: bcm5974 - Add support for newer MacBookPro8,2
Input: wacom - report id 3 returns 4 bytes of data
Input: wacom - add WAC_MSG_RETRIES define
Input: wacom - add support for the Wacom Bamboo Pen (CTL-660/K)
Input: tegra-kbc - correct call to input_free_device
Input: mpu3050 - correct call to input_free_device
Input: bcm5974 - add support for touchpads found in MacBookAir4,2
Input: mma8450 - fix module device table type
Input: remove CLOCK_TICK_RATE from analog joystick driver
