Instead of using a constant for initiator_depth and
responder_resources, read the per-QP values when the
device is enumerated, and then use these values when creating
the connection.
Signed-off-by: Andy Grover <andy.grover@oracle.com>
Implement a CMSG-based interface to do FADD and CSWP ops.
Alter send routines to handle atomic ops.
Add atomic counters to stats.
Add xmit_atomic() to struct rds_transport
Inline rds_ib_send_unmap_rdma into unmap_rm
The previous code was correct, but made the assumption that
if r_notifier was non-NULL then either r_recverr or r_notify
was true. Valid, but fragile. Changed to explicitly check
r_recverr (shows up in greps for recverr now, too.)
rds_message_alloc_sgs() now returns correctly-initialized
sg lists, so calleds need not do this themselves.
This eliminates a separate memory alloc, although
it is now necessary to add an "r_active" flag, since
it is no longer to use the m_rdma_op pointer as an
indicator of if an rdma op is present.
rdma SGs allocated from rm sg pool.
rds_rm_size also gets bigger. It's a little inefficient to
run through CMSGs twice, but it makes later steps a lot smoother.
RDMA is now an intrinsic part of RDS, so it's easier to just have
a single header.
r_m_copy_from_user used to allocate the rm as well as kernel
buffers for the data, and then copy the data in. Now, sendmsg()
allocates the rm, although the data buffer alloc still happens
in r_m_copy_from_user.
SGs are still allocated with rm, but now r_m_alloc_sgs() is
used to reserve them. This allows multiple SG lists to be
allocated from the one rm -- this is important once we also
want to alloc our rdma sgl from this pool.
First, it looks to me like the atomic_inc is wrong.
We should be decrementing refcount only once here, no? It's
already being done by the mr_put() at the end.
Second, simplify the logic a bit by bailing early (with a warning)
if !mr.
Clearly separate rdma-related variables in rm from data-related ones.
This is in anticipation of adding atomic support.
Favor "if (foo)" style over "if (foo != NULL)".
This fits better in connection.c, rather than threads.c.
Do not nest m_rs_lock under c_lock
Disable interrupts in {rdma,atomic}_send_complete
This function has been the source of numerous bugs; it's just
too complicated. Simplified to nest spinlocks cleanly within
the second loop body, and kick out early if there are no
rms to drop.
This will be a little slower because conn lock is grabbed for
each entry instead of "caching" the lock across rms, but this
should be entirely irrelevant to fastpath performance.
On second look at this bug (OFED #2002), it seems that the
collision is not with the retransmission queue (packet acked
by the peer), but with the local send completion. A theoretical
sequence of events (from time t0 to t3) is thought to be as
follows,
Thread #1
t0:
sock_release
rds_release
rds_send_drop_to /* wait on send completion */
t2:
rds_rdma_drop_keys() /* destroy & free all mrs */
Thread #2
t1:
rds_ib_send_cq_comp_handler
rds_ib_send_unmap_rm
rds_message_unmapped /* wake up #1 @ t0 */
t3:
rds_message_put
rds_message_purge
rds_mr_put /* memory corruption detected */
The problem with the rds_rdma_drop_keys() is it could
remove a mr's refcount more than its due (i.e. repeatedly
as long as it still remains in the tree (mr->r_refcount > 0)).
Theoretically it should remove only one reference - reference
by the tree.
/* Release any MRs associated with this socket */
while ((node = rb_first(&rs->rs_rdma_keys))) {
mr = container_of(node, struct rds_mr, r_rb_node);
if (mr->r_trans == rs->rs_transport)
mr->r_invalidate = 0;
rds_mr_put(mr);
I think the correct way of doing it is to remove the mr from
the tree and rds_destroy_mr it first, then a rds_mr_put()
to decrement its reference count by one. Whichever thread
holds the last reference will free the mr via rds_mr_put().
Signed-off-by: Tina Yang <tina.yang@oracle.com>
in_interrupt() is true in softirqs. The BUG_ONs are supposed
to check for if irqs are disabled, so we should use
BUG_ON(irqs_disabled()) instead, duh.
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN
The values didn't match the title after removing the LRO
statistics in commit fa37a9586f92051de03a13e55e5ec3880bb6783e
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
If failed to get skb frags using napi_get_frags(),
the packet is dropped.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Convert pr_<level>("%s" ..., (struct netdev *)->name ...)
to netdev_<level>((struct netdev *), ...)
This patch standardizes caif message logging prefixes.
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s(): " fmt, __func__
Add missing "\n"s to some logging messages
Convert pr_warning to pr_warn
This changes the logging message prefix from CAIF: to caif:
for all uses but caif_socket.c and chnl_net.c. Those now use
their filename without extension.
The function has an unsigned return type, but returns a negative constant
to indicate an error condition. The result of calling the function is
always stored in a variable of type (signed) int, and thus unsigned can be
dropped from the return type.
A sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@exists@
identifier f;
constant C;
unsigned f(...)
* return -C;
// </smpl>
// <smpl>
@exists@
identifier f;
constant C;
unsigned f(...)
* return -C;
// </smpl>
The CHELSIO_T1_1G ifdef isn't necessary at this point, because it is
checked in an outer ifdef level already and has no effect here.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Convert jeprintk to pr_err
Remove jeprintk macro define
Remove periods from end of logging messages
Coalesce format strings
This showed up in my audit because we use strcpy() to copy "ds" into a
32 character buffer inside the isdn_tty_dial() function. But it turns
out that we only ever use the first 32 characters so it's OK. I have
changed the declaration to make the static checkers happy.
cs->ics.parm.setup.phone is a 32 character array. In each of these
cases we're copying from a 35 character array into a 32 character array
so we should use strlcpy() instead of strcpy().
bnad_set_rx_mode omit to unlock bna_lock on one fail path. Fix that.
Cc: Debashis Dutt <ddutt@brocade.com>
Cc: Rasesh Mody <rmody@brocade.com>
In this case, a device_node structure is stored in another structure that
is then freed without first decrementing the reference count of the
device_node structure.
The semantic match that finds this problem is as follows:
// <smpl>
@r exists@
expression x;
identifier f;
position p1,p2;
x@p1->f = \(of_find_node_by_path\|of_find_node_by_name\|of_find_node_by_phandle\|of_get_parent\|of_get_next_parent\|of_get_next_child\|of_find_compatible_node\|of_match_node\|of_find_node_by_type\|of_find_node_with_property\|of_find_matching_node\|of_parse_phandle\|of_node_get\)(...);
... when != of_node_put(x)
kfree@p2(x)
@script:python@
p1 << r.p1;
p2 << r.p2;
cocci.print_main("call",p1)
cocci.print_secs("free",p2)
// </smpl>
pskb_expand_head() blindly takes references on fragments before calling
skb_release_data(), potentially releasing these references.
We can add a fast path, avoiding these atomic operations, if we own the
last reference on skb->head.
Based on a previous patch from David
Add an entry to the MAINTAINERS file for ibmveth, clean up the copyright
and add all authors. Change the name of the module to reflect the product name
over the last number of years.
Considering all the changes we have made, bump the driver version.
Signed-off-by: Santiago Leon <santil@linux.vnet.ibm.com>
These files probably came across from the skeleton driver. Remove them.
We had a driver specific assert function which wasn't enabled most of the
time. Convert them to BUG_ON and enable them all the time.
We had a few cases where we returned success on error.
Fix most of the kernel coding style issues in ibmveth.
IbmVethNumBufferPools -> IBMVETH_NUM_BUFF_POOLS
Also change IBMVETH_MAX_MTU -> IBMVETH_MIN_MTU, it refers to the minimum
size not the maximum.
Use netdev_err to standardise the error output.
Use netdev_dbg to standardise the debug output.
These functions appear before their use, so we can remove the redundant
prototypes.
We were using alloc_skb which doesn't create any headroom. Change it to
use netdev_alloc_skb to match most other drivers.
We export all the driver specific statistics via ethtool, so there is no need
to duplicate this in procfs.
This patch enables TCP checksum offload support for IPv6 on ibmveth.
This completely eliminates the generation and checking of the checksum
for IPv6 packets that are completely virtual and never touch a physical
network. A basic TCPIPV6_STREAM netperf run showed a ~30% throughput
improvement when an MTU of 64000 was used.
This featured is enabled by default, as is the case for IPv4 checksum
offload. When checksum offload is enabled the driver will negotiate
IPv4 and IPv6 offload with the firmware separately and enable what
is available. As long as either IPv4 or IPv6 offload is supported
and enabled the device will report that checksum offload is enabled.
The device stats, available through ethtool, will display which
checksum offload features are supported/enabled by firmware.
Performance testing against a stock kernel shows no regression for IPv4
or IPv6 in terms of throughput or processor utilization with checksum
disabled or enabled.
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Remove code in the device probe function where we set up the checksum
offload feature and replace it with a call to an existing function that
is doing the same. This is done to clean up the driver in preparation
of adding IPv6 checksum offload support.
On some machines we can improve the bandwidth by ensuring rx buffers are
not in the cache. Add a module option that is disabled by default that flushes
rx buffers on insertion.
ibmveth can scatter gather up to 6 segments. If we go over this then
we have no option but to call skb_linearize, like other drivers with
similar limitations do.
We want to order the read in ibmveth_rxq_pending_buffer and the read of
ibmveth_rxq_buffer_valid which are both cacheable memory. smp_rmb() is good
enough for this.
For small packets, create a new skb and copy the packet into it so we
avoid tearing down and creating a TCE entry.
Use the existing bounce buffer if we send a buffer under a certain size.
This saves the overhead of a TCE map/unmap.
I can't see any reason for the wmb() in the bounce buffer case, if we need
a barrier it will be before we call h_send_logical_lan but we have
nothing in the common case. Remove it.
The ibmveth adapter needs locking in the transmit routine to protect
the bounce_buffer but it sets LLTX and forgets to add any of its own
locking.
Just remove the deprecated LLTX option. Remove the stats lock in the process.
At the moment we try and replenish the receive ring on every rx interrupt.
We even have a pool->threshold but aren't using it.
To limit the maximum latency incurred when refilling, change the threshold
from 1/2 to 7/8 and reduce the largest rx pool from 768 buffers to 512 which
should be more than enough.
Replace some modulus operators with an increment and compare to avoid
an integer divide.
