2008-10-16gpiolib: request/free hooksDavid Brownell
Add a new internal mechanism to gpiolib to support low power operations by letting gpio_chip instances see when their GPIOs are in use. When no GPIOs are active, chips may be able to enter lower powered runtime states by disabling clocks and/or power domains. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Magnus Damm" <magnus.damm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16omap drivers: switch to standard GPIO callsDavid Brownell
This updates most of the OMAP drivers which are in mainline to switch to using the cross-platform GPIO calls instead of the older OMAP-specific ones. This is all fairly brainless/obvious stuff. Probably the most interesting bit is to observe that the omap-keypad code seems to now have a portable core that could work with non-OMAP matrix keypads. (That would improve with hardware IRQ debouncing enabled, of course...) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: gpio_to_irq() hooksDavid Brownell
Add a new gpiolib mechanism: gpio_chip instances can provide mappings between their (input) GPIOs and any associated IRQs. This makes it easier for platforms to support IRQs that are provided by board-specific external chips instead of as part of their core (such as SOC-integrated GPIOs). Also update the irq_to_gpio() description, saying to avoid it because it's not always supported. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: i2c expanders use subsys_initDavid Brownell
Make the I2C external GPIO expander drivers register themselves at subsys_initcall() time when they're statically linked. SOC-integrated GPIOs are available starting very early -- early in arch_initcall() at latest, but often even before initcalls start to run -- so this improves consistency, so more subsystems can rely on GPIOs in their own subsys_initcall() code. (This isn't a theoretical problem. This is one of several patches needed to resolve oopsing observed when statically linking kernels on a DaVinci EVM. Its pcf857x GPIOs needed to be available well before some other drivers initialized.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio_free might sleep, generic partUwe Kleine-König
According to the documentation gpio_free should only be called from task context only. To make this more explicit add a might sleep to all implementations. This is the generic part which changes gpiolib and the fallback implementation only. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: max7301: fix the race between chip addition and pins reconfigurationDmitry Baryshkov
There is a small race and code ugliness in max7301: pins are reconfigured after the chip is registered. Swap these calls so that the device is registered in correct state. Also this fixes the comile-time warning about unchecked gpiochip_remove. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Juergen Beisert <j.beisert@pengutronix.de> Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: make gpiochip label constDmitry Baryshkov
Mark gpiochip label as a const char pointer. Fixes things like arch/arm/common/scoop.c: In function `scoop_probe': arch/arm/common/scoop.c:250: warning: assignment discards qualifiers from pointer target type Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc-ds1672 new style driverAlessandro Zummo
New style conversion and reformatting as per indent --linux-style Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc-max6900 new style driverAlessandro Zummo
New style conversion and reformatting as per indent --linux-style Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc-at91rm9200: remove now-unneeded codeAndrew Victor
The non-functional periodic IRQ support was previously removed from the AT91RM9200 RTC driver. Remove the remaining AT91_RTC_FREQ definition. Signed-off-by: Andrew Victor <linux@maxim.org.za> Cc: David Brownell: <david-b@pacbell.net> Cc: Alessandro Zummo: <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: rtc-m41t80.c: add support for the ST M41T65 RTCSteven A. Falco
Add support for M41T65 Real Time Clock chip. The main differences I see between the M41T65 and M41T80 are that: 1) The M41T65 watchdog timer has three bits controlling resolution (versus two for the M41T80). 2) There is no register 0x13 for controlling square-wave output. Signed-off-by: Steven A. Falco <sfalco@harris.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: use CONFIG_PPC instead of CONFIG_PPC_MERGEKumar Gala
Now that arch/ppc is dead CONFIG_PPC_MERGE is always defined for all powerpc platforms and we want to get rid of it use CONFIG_PPC instead. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: file close() consistently disables repeating irqsDavid Brownell
Make the rtc framework consistent about disabling 1/second update IRQs that may have been activated through the /dev interface, when that /dev file is closed. (It may have closed because of coredump, etc.) This was previously done only for emulated update IRQs ... now, do it always. Also comment the current policy: repeating IRQs (periodic, update) that userspace enabled will be cleanly disabled, but alarms are left alone. Such repeating IRQs are a constant and pointless system load. Update some RTC drivers to remove now-needless release() methods. Most such methods just enforce that policy. The others all seem to be buggy, and mistreat in-kernel clients of periodic or alarm IRQs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Sharp <andy.sharp@onstor.com> Cc: Angelo Castello <angelo.castello@st.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: rtc-rs5c372: add support for Ricoh R2025S/D RTCPaul Mundt
This adds support for the Ricoh R2025S/D series of I2C RTCs, produced by Ricoh Japan and described at: http://www.ricoh.co.jp/LSI/product_rtc/2wire/r2025x/ This series has very minor deviations from the rest of the RS5C chips, most of which have to do with the oscillator, which was abstracted away in an earlier patch. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: Riku Voipio <riku.voipio@movial.fi> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: rtc-rs5c372: SMBus conversion/supportPaul Mundt
rtc-rs5c372 presently depends on I2C master mode transfers, despite the fact that these RTCs frequently find themselves on SMBus-only adapters. Given that the only capabilities that were checked were for I2C_FUNC_I2C, it's assumed that most of the adapters that are currently using this driver are fairly sane, and are able to handle SMBus emulation (though we adjust the default capabilities to check for I2C_FUNC_SMBUS_EMUL anyways, which is the vast majority of them. The adapters that don't have their own ->smbus_xfer() fall back on the ->master_xfer() through the emulated transfer). The special case is iop3xx, which has more than its fair share of hacks within this driver, it remains untested -- though also claims to support emulated SMBus accesses. The corner case there is rs5c_get_regs() which uses access mode #3 for transferring the register state, while we use mode #1 for SMBus. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: Riku Voipio <riku.voipio@movial.fi> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16legacy rtc: remove needless/confusing HPET_RTC_IRQ optionDavid Brownell
HPET_RTC_IRQ is no longer needed; HPET_EMULATE_RTC suffices and is more correct. (http://bugzilla.kernel.org/show_bug.cgi?id=11111) Note that when using the legacy RTC driver, platforms don't really do a dynamic switch between HPET and non-HPET modes based on whether HPET hardware actually exists ... only rtc-cmos (using the new RTC framework) currently switches that way. So this reflects bitrot in that legacy code, for x86/ia64: kernels with HPET support configured (e.g. for a clocksource) can't get IRQs from the legacy RTC driver unless they really have HPET hardware. (The obvious workaround is to not use the legacy RTC driver on those platforms when you configure HPET ... unless you know the target really has a HPET.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: remove some NOP open/release methodsDavid Brownell
Remove NOP methods from rtc-pl030 and rtc-pl031 drivers; this is pure wasted code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc-ds1307: alarm support for ds1337/ds1339Rodolfo Giometti
Update the ds1307 driver with alarm support for ds1337/ds1339. This uses the first alarm (there are two), and matches on seconds, minutes, hours, and day-of-month. Tested on ds1339. [dbrownell@users.sourceforge.net: add comments; fixup style, valid irq checks, debug dumps; lock; more careful IRQ shutdown; switch BCD2BIN to bcd2bin (and vice versa); ENOTTY not EINVAL.] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: add device driver for Dallas DS3234 SPI RTC chipDennis Aberilla
Add support for the Dallas DS3234 chip - extremely accurate SPI bus RTC with integrated crystal and SRAM. [akpm@linux-foundation.org: don't use BIN2BCD/BCD2BIN] Signed-off-by: Dennis Aberilla <denzzzhome@yahoo.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: DS1374 wakeup supportMarc Pignat
Wakeup support implementation. Signed-off-by: Marc Pignat <marc.pignat@hevs.ch> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc-pcf8563: remove client validationLaurent Pinchart
Validating clients with black magic register checks doesn't make much sense for new-style i2c driver and has been known to fail on valid NXP pcf8563 chips. This patch removes the client validation code. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: add miscellaneous device for ioctlsIan Kent
Add a miscellaneous device to the autofs4 module for routing ioctls. This provides the ability to obtain an ioctl file handle for an autofs mount point that is possibly covered by another mount. The actual problem with autofs is that it can't reconnect to existing mounts. Immediately one things of just adding the ability to remount autofs file systems would solve it, but alas, that can't work. This is because autofs direct mounts and the implementation of "on demand mount and expire" of nested mount trees have the file system mounted on top of the mount trigger dentry. To resolve this a miscellaneous device node for routing ioctl commands to these mount points has been implemented in the autofs4 kernel module and a library added to autofs. This provides the ability to open a file descriptor for these over mounted autofs mount points. Please refer to Documentation/filesystems/autofs4-mount-control.txt for a discussion of the problem, implementation alternatives considered and a description of the interface. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: device node ioctl documentationIan Kent
Add documentation for the miscellaneous device module of autofs4. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: track uid and gid of last mount requesterIan Kent
Track the uid and gid of the last process to request a mount for on an autofs dentry. [akpm@linux-foundation.org: fix tpyo in comment] Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16autofs4: cleanup autofs mount type usageIan Kent
Usage of the AUTOFS_TYPE_* defines is a little confusing and appears inconsistent. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16eCryptfs: remove netlink transportTyler Hicks
The netlink transport code has not worked for a while and the miscdev transport is a simpler solution. This patch removes the netlink code and makes the miscdev transport the only eCryptfs kernel to userspace transport. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dustin Kirkland <kirkland@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16ecryptfs: convert to use new aopsBadari Pulavarty
Convert ecryptfs to use write_begin/write_end Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16eCryptfs: remove retry loop in ecryptfs_readdir()Michael Halcrow
The retry block in ecryptfs_readdir() has been in the eCryptfs code base for a while, apparently for no good reason. This loop could potentially run without terminating. This patch removes the loop, instead erroring out if vfs_readdir() on the lower file fails. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Reported-by: Al Viro <viro@ZinIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16i2o: Fix 32/64bit DMA lockingAlan Cox
The I2O ioctls assume 32bits. In itself that is fine as they are old cards and nobody uses 64bit. However on LKML it was noted this assumption is also made for allocated memory and is unsafe on 64bit systems. Fixing this is a mess. It turns out there is tons of crap buried in a header file that does racy 32/64bit filtering on the masks. So we: - Verify all callers of the racy code can sleep (i2o_dma_[re]alloc) - Move the code into a new i2o/memory.c file - Remove the gfp_mask argument so nobody can try and misuse the function - Wrap a mutex around the problem area (a single mutex is easy to do and none of this is performance relevant) - Switch the remaining problem kmalloc holdout to use i2o_dma_alloc Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16spi: core and gpio expanders use subsys_initDavid Brownell
Make the SPI external GPIO expander drivers register themselves at subsys_initcall() time when they're statically linked, and make the SPI core do its driver model initialization earlier so that's safe. SOC-integrated GPIOs are available starting very early -- often before initcalls start to run, or earily in arch_initcall() at latest -- so this improves consistency, letting more subsystems rely on GPIOs being usable by their own subsys_initcall() code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16orion_spi: handle 88F6183 erratumLennert Buytenhek
Add support to orion_spi for the 88F6183 ARM SoC by adding code to work around a 6183-specific erratum. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pxa2xx_spi: fix chip_info defaults and documentation.Vernon Sauder
Make the chip info structure data optional by providing reasonable defaults. Improve corresponding documentation, and highlight the drawback of not providing explicit chipselect control. DMA can determine appropriate dma_burst_size and thresholds automatically so use DMA even if dma_burst_size is not specified. Signed-off-by: Vernon Sauder <VernonInHand@gmail.com> Reviewed-by: Ned Forrester <nforrester@whoi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pxa2xx_spi: minor cleanupGuennadi Liakhovetski
Minor fixes: remove redundant local variable initialization, fix "can not" to what I _think_ is a preferred spelling, output IRQ number if requesting it failed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16spi_s3c24xx: pin configuration updatesBen Dooks
Add a pin configuration callback for the s3c24xx SPI driver, as there are several options depending on the channel and the chip in use. This is needed as the controller may not have been setup by the initial bootloader and the fact that the SPI controller gets reset over suspend/resume into slave mode but the GPIO function registers do not. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16spi: simplify spi_write_then_read()Vernon Sauder
Modify spi_write_then_read() to use one transfer. This speeds up all callers, and is a minor code shrink. Signed-off-by: Vernon Sauder <Vernon.Sauder@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16mpc52xx_psc_spi: remove code associated with !CONFIG_PPC_MERGEKumar Gala
Now that arch/ppc is gone we don't need CONFIG_PPC_MERGE anymore remove the dead code associated with !CONFIG_PPC_MERGE. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: David Brownell <david-b@pacbell.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Allow recursion in binfmt_script and binfmt_miscKirill A. Shutemov
binfmt_script and binfmt_misc disallow recursion to avoid stack overflow using sh_bang and misc_bang. It causes problem in some cases: $ echo '#!/bin/ls' > /tmp/t0 $ echo '#!/tmp/t0' > /tmp/t1 $ echo '#!/tmp/t1' > /tmp/t2 $ chmod +x /tmp/t* $ /tmp/t2 zsh: exec format error: /tmp/t2 Similar problem with binfmt_misc. This patch introduces field 'recursion_depth' into struct linux_binprm to track recursion level in binfmt_misc and binfmt_script. If recursion level more then BINPRM_MAX_RECURSION it generates -ENOEXEC. [akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16alpha: introduce field 'taso' into struct linux_binprmKirill A. Shutemov
This change is Alpha-specific. It adds field 'taso' into struct linux_binprm to remember if the application is TASO. Previously, field sh_bang was used for this purpose. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16binfmt_som.c: add MODULE_LICENSEAdrian Bunk
Add the missing MODULE_LICENSE("GPL"). Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: version: 0.24Andy Whitcroft
Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: allow for comments either side of a brace on caseAndy Whitcroft
When specifying case we may have comments and/or braces at the end without actually having a 'statement'. Allow for these to occur in any order. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: suspect indent handle macro continuationAndy Whitcroft
When ignoring a macro in the middle of a conditional, we need to ignore the macro start and any continuation lines. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: trailing statements ensure we report the end of the lineAndy Whitcroft
When reporting some complex trailing statements we report only the starting line of the error, that tends to imply the shown line is in error and confuse the reader. As we do know where the actual error is report that line too with an appropriate gap marker where applicable. #ERROR: trailing statements should be on next line #1: FILE: Z202.c:1: + for (pbh = page_buffers(bh->b_page); pbh != bh; + pbh = pbh->b_this_page, key++); #ERROR: trailing statements should be on next line #4: FILE: Z202.c:4: + for (pbh = page_buffers(bh->b_page); [...] + pbh = pbh->b_this_page, key++); Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: DEFINE_ macros are real definitions for exportsAndy Whitcroft
When we want to confirm an export is directly after its definition we need to allow for DEFINE_ style macros. Add these to the execeptions. Refactor the exceptions. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: complex macros checks miss square bracketsAndy Whitcroft
We are missing 'simple' values which include square brackets. Refactor to ensure we handle nesting correctly and detect these simple forms. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: suspect code indent must stop at #else/#elifAndy Whitcroft
When we hit and #else or #elif we know we are meeting an alternative piece of code. All bets are off on indent if we did not see the open of the control so stop checking. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: pull out known acceptable typedefsAndy Whitcroft
Within the type checker we have a number of common kernel types which must be implemented as typedefs. Pull those out so that we can use the same expressions to trigger exclusions. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: accept any sized le/be typeAndy Whitcroft
We are likely going to have 24 bit types. Expand the type matcher to match any size. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: macros which define structure members are not complexAndy Whitcroft
We often see macros which define structure members, these are not complex and necessarily do not have braces or brackets. For example: #define _PLIST_HEAD_INIT(head) \ .prio_list = LIST_HEAD_INIT((head).prio_list), \ .node_list = LIST_HEAD_INIT((head).node_list) Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16checkpatch: handle do without braces if we have enough contextAndy Whitcroft
If we have sufficient context detect and handle do without braces ({). Else these incorrectly trigger a trailing statements error for the associated while. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
