To properly implement a pid namespace I need to deal exclusively in terms of
struct pid, because pid_t values become ambiguous.
To this end session_of_pgrp is transformed to take and return a struct pid
pointer. To avoid the need to worry about reference counting I now require my
caller to hold the appropriate locks. Leaving callers repsonsible for
increasing the reference count if they need access to the result outside of
the locks.
Since session_of_pgrp currently only has one caller and that caller simply
uses only test the result for equality with another process group, the locking
change means I don't actually have to acquire the tasklist_lock at all.
tiocspgrp is also modified to take and release the lock. The logic there is a
little more complicated but nothing I won't need when I convert pgrp of a tty
to a struct pid pointer.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
The goal is to remove users of the old signal helper functions so they can be
removed.
I am slowly moving to a model where all process killing is struct pid based
instead of pid_t based. The sunos compatibility code is one of the last users
of the old pid_t based kill_pg in the kernel. By being complete I allow for
the future removal of kill_pg from the kernel, which will ensure I don't miss
something.
commit 24ec839c431eb79bb8f6abc00c4e1eb3b8c4d517 while fixing the locking for
signal->tty got the locking wrong for signal->session. This places our
accesses of signal->session back under the tasklist_lock where they belong.
The code to look at tty_old_pgrp and send SIGHUP and SIGCONT when it is
present only executes when disassociate_ctty is called from do_exit. Make
this clear by adding an explict on_exit check, and explicitly setting
tty_old_pgrp to 0.
In addition fix the locking by reading tty_old_pgrp under the siglock.
The aim of this patch set is to start wrapping up the struct pid conversions.
As such this patchset culminates with the removal of kill_pg, kill_pg_info,
__kill_pg_info, do_each_task_pid, and while_each_task_pid.
kill_proc, daemonize, and kernel_thread are still in my sights but there is
still work to get to them.
The first three are basic cleanups around disassociate_ctty, while working on
converting it I found several issues. tty_old_pgrp can be a tricky concept to
wrap your head around.
1 tty: Make __proc_set_tty static.
2 tty: Clarify disassociate_ctty
3 tty: Fix the locking for signal->session in disassociate_ctty
These just stop using the old helper functions.
4 signal: Use kill_pgrp not kill_pg in the sunos compatibility code.
5 signal: Rewrite kill_something_info so it uses newer helpers.
Then the grind to convert the tty layer and all of it's helper functions to
struct pid.
6 pid: Make session_of_pgrp use struct pid instead of pid_t.
7 pid: Use struct pid for talking about process groups in exit.c
8 pid: Replace is_orphaned_pgrp with is_current_pgrp_orphaned
9 tty: Update the tty layer to work with struct pid.
A final helper function update.
10 pid: Replace do/while_each_task_pid with do/while_each_pid_task
And the removal of the functions that are now unused.
11 pid: Remove now unused do_each_task_pid and while_each_task_pid
12 pid: Remove the now unused kill_pg kill_pg_info and __kill_pg_info
All of these should be fairly simple and to the point.
This patch:
Currently all users of __proc_set_tty are in tty_io.c so make the function
static.
This morning I needed to read a Minix V3 filesystem, but unfortunately my
2.6.19 did not support that, and neither did the downloaded 2.6.20rc4.
Fortunately, google told me that Daniel Aragones had already done the work,
patch found at http://www.terra.es/personal2/danarag/
Unfortunaly, looking at the patch was painful to my eyes, so I polished it
a bit before applying. The resulting kernel boots, and reads the
filesystem it needed to read.
Signed-off-by: Daniel Aragones <danarag@gmail.com>
Signed-off-by: Andries Brouwer <aeb@cwi.nl>
This is adds a simple SPI EEPROM driver, providing access to the EEPROM
through sysfs much like the I2C "eeprom" driver ... except this driver
supports write access, and multiple EEPROM sizes.
Since I have EEPROMs on SPI with different address sizing, I made some
changes to your at25.c to support them. Works perfectly. (Also includes a
small bugfix for the "what size address" test.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Walter Tuppa <walter.tuppa@siemens.com>
This adds a new "wakealarm" sysfs attribute to RTC class devices which support
alarm operations and are wakeup-capable:
- It reads as either empty, or the scheduled alarm time as seconds
since the POSIX epoch. (That time may already have passed, since
nothing currently enforces one-shot alarm semantics.)
- It can be written with an alarm time in the future, again seconds
since the POSIX epoch, which enables the alarm.
- It can be written with an alarm time not in the future (such as 0,
the start of the POSIX epoch) to disable the alarm.
Usage examples (some need GNU date) after "cd /sys/class/rtc/rtcN":
alarm after 10 minutes:
# echo $(( $(cat since_epoch) + 10 * 60 )) > wakealarm
alarm tuesday evening 10pm:
# date -d '10pm tuesday' "+%s" > wakealarm
disable alarm:
# echo 0 > wakealarm
This resembles the /proc/acpi/alarm file in that nothing happens when the
alarm triggers ... except possibly waking the system from sleep. It's also
like that in a nasty way: not much can be done to prevent one task from
clobbering another task's alarm settings.
It differs from that file in that there's no in-kernel date parser.
Note that a few RTCs ignore rtc_wkalrm.enabled when setting alarms, or aren't
set up correctly, so they won't yet behave with this attribute.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Greg KH <greg@kroah.com>
This clarifies some aspects of the SPI programming interface, based on
feedback from Hans-Peter Nilsson. The in-memory representation of words is
right-aligned, so for example a twelve bit word is stored using sixteen bits
with four undefined bits in the MSB. And controller drivers must reject
protocol tweaking modes they do not support.
I'd like to assign NULL to kfree()d members of a structure. I can't do
that without ugly casting (see the PXA patch) when the structure pointed to
is const-qualified. I don't really see a reason why the cleanup method
isn't allowed to alter the object it should clean up. :-)
No, I didn't test the PXA patch, but I verified that the NULL-assignment
doesn't stop me from doing rmmod/insmodding my own spi_bitbang-based
driver.
Signed-off-by: Hans-Peter Nilsson <hp@axis.com>
A small bug-fix for spi_bitbang: it must always call the setup_transfer
function via the overridable pointer, not assume that its
spi_bitbang_setup_transfer is sufficient. Otherwise, if all options in the
transfers are default (0), the overrided function will never be called.
Granted, the function replacing it must call spi_bitbang_setup_transfer,
but it might also have other important things to do, even if the second
argument (the spi_transfer) is NULL. Tested together with the other
patches on the spi_crisv32_sser and spi_crisv32_gpio drivers (not yet in
the kernel, will IIUC be submitted as part of the usual
arch-maintainer-pushes).
Make the spi_unregister_driver() code fit in with the rest of the header
file, and only do the action if the driver passed is non-NULL.
This also makes the code a line smaller.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The spi_register_driver() sets the bus_type field of the spi_driver being
registered, so there is no need to have it set in the driver itself.
Add wrappers for getting and setting the driver data using spi_device
instead of using dev_{get|set}_drvdata with &spi->dev, to mirror the
platform_{get|set}_drvdata.
Add the SPI controller driver for Freescale i.MX(S/L/1).
Main features summary:
> Per chip setup via board specific code and/or protocol driver.
> Per transfer setup.
> PIO transfers.
> DMA transfers.
> Managing of NULL tx / rx buffer for rd only / wr only transfers.
This patch replace patch-2.6.20-rc4-spi_imx with the following changes:
> Few cosmetic changes.
> Function map_dma_buffers now return 0 for success and -1 for failure.
> Solved a bug inside spi_imx_probe function (wrong error path).
> Solved a bug inside setup function (bad undo setup for max_speed_hz).
> For read-only transfers, always write zero bytes.
This is almost the same as the 'BIS' version sent by Andrea, except for
updating the 'DUMMY' byte so that read-only transfers shift out zeroes.
That part of the API changed recently, since some half duplex peripheral
chips require that semantic.
Signed-off-by: Andrea Paterniani <a.paterniani@swapp-eng.it>
This adds a SPI driver for the Microwire controller on OMAP1 chips. This
driver has been used in the Linux-OMAP tree for some time now, including
with some of those displays using standardized 9-bit commands followed by
data with 8-bit words.
Microwire only supports half duplex transfers, but that's all that most SPI
protocols need. When full duplex, or higher speeds, are needed there are
several other controllers that can be used on OMAP.
[akpm@osdl.org: cleanups]
Signed-off-by: Imre Deak <imre.deak@solidboot.com>
Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com>
Minor Kconfig cleanup ... put the SPI_S3C24XX entry in the
correct location (alphabetical order).
drivers/char/ds1302.c::get_rtc_time() contains local_irq_disable() call
after local_irq_save(). This looks redundant.
drivers/char/ds1302.c::rtc_ioctl() contains local_irq_disable() call after
This patch adds the line discipline based driver for the Gigaset M101
wireless RS232 adapter. It also improves the documentation a bit.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Signed-off-by: Hansjoerg Lipp <hjlipp@web.de>
Convert:
BOOL -> bool
FALSE -> false
TRUE -> true
Change a variable ('mContinue') to boolean from char, since it is used
as boolean.
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
- Use timer macros to set function and data members and to modify
expiration time.
- Use DEFINE_TIMER for global timers and do not init them at run-time in
these cases.
- del_timer_sync is common in most cases -- we want to wait for timer
function if it's still running.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Dmitry Torokhov <dtor@mail.ru> (Input bits)
specialix, isr have 2 params
pt_regs are no longer the third parameter of isr, call sx_interrupt without
it.
Cc: <stable@kernel.org>
Change __init to __devinit in rtc drivers' probe functions.
Resolves MODPOST warnings:
WARNING: drivers/rtc/rtc-ds1553.o - Section mismatch: reference to
.init.text:ds1553_rtc_probe from .data.rel between 'ds1553_rtc_driver' (at
offset 0x0) and 'ds1553_nvram_attr'
WARNING: drivers/rtc/rtc-ds1742.o - Section mismatch: reference to
.init.text:ds1742_rtc_probe from .data.rel between 'ds1742_rtc_driver' (at
offset 0x0) and 'ds1742_nvram_attr'
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Was ufs_fs.h purposefully not exported to userspace or did it just slip
through the cracks ? assuming the latter scenario, the attached patch touches
up the relationship between ufs_fs.h and its sub headers (like ufs_fs_sb.h) so
that we can export it ... the silo bootloader takes advantage of this header
for example.
Cc: Evgeniy Dushistov <dushistov@mail.ru>
close_files() can sometimes take long enough to trigger the soft lockup
detector.
Cc: Eric Dumazet <dada1@cosmosbay.com>
Reduce the number of kernel messages the Gigaset drivers produce in case of an
excessively long device response, from one per character exceeding the limit
to one per overlong message.
Do not lock the cardstate structure mutex earlier than necessary.
oprofile hunting showed a stall in rw_verify_area(), because of triple
indirection and potential cache misses.
(file->f_path.dentry->d_inode->i_flock)
By moving initialization of 'struct inode' pointer before the pos/count
sanity tests, we allow the compiler and processor to perform two loads by
anticipation, reducing stall, without prefetch() hints. Even x86 arch has
enough registers to not use temporary variables and not increase text size.
I validated this patch running a bench and studied oprofile changes, and
absolute perf of the test program.
Results of my epoll_pipe_bench (source available on request) on a Pentium-M
1.6 GHz machine
Before :
# ./epoll_pipe_bench -l 30 -t 20
Avg: 436089 evts/sec read_count=8843037 write_count=8843040 21.218390 samples
per call
(best value out of 10 runs)
After :
Avg: 470980 evts/sec read_count=9549871 write_count=9549894 21.216694 samples
per call
oprofile CPU_CLK_UNHALTED events gave a reduction from 5.3401 % to 2.5851 %
for the rw_verify_area() function.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Need to export com20020 symbols for com20020_cs also.
WARNING: "com20020_found" [drivers/net/pcmcia/com20020_cs.ko] undefined!
WARNING: "com20020_check" [drivers/net/pcmcia/com20020_cs.ko] undefined!
Cc: Esben Nielsen <nielsen.esben@googlemail.com>
Cc: Jeff Garzik <jeff@garzik.org>
3117df0453828bd045c16244e6f50e5714667a8a causes this:
In file included from arch/s390/kernel/early.c:13:
include/linux/lockdep.h:300: warning:
"struct task_struct" declared inside parameter list
warning: its scope is only this definition or
declaration, which is probably not what you want
I've noticed that the boot options are not correct for in the documentation
for kdump. The "init" keyword is not necessary, and causes a kernel panic
when booting with an initrd on Fedora 5.
[horms@verge.net.au: put original comment with the latest version of the patch]
Signed-off-by: Judith Lebzeelter <judith@osdl.org>
Acked-by: Vivek Goyal <vgoyal@in.ibm.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Optimise swiotlb.c for size.
5009 89 64 5162 142a lib/swiotlb.o-before
4666 89 64 4819 12d3 lib/swiotlb.o-after
For some reason my gcc (4.0.2) doesn't want to tailcall these things.
swiotlb_sync_sg_for_device:
pushq %rbp #
movl $1, %r8d #,
movq %rsp, %rbp #,
call swiotlb_sync_sg #
leave
ret
.size swiotlb_sync_sg_for_device, .-swiotlb_sync_sg_for_device
.section .text.swiotlb_sync_sg_for_cpu,"ax",@progbits
.globl swiotlb_sync_sg_for_cpu
.type swiotlb_sync_sg_for_cpu, @function
swiotlb_sync_sg_for_cpu:
pushq %rbp #
xorl %r8d, %r8d #
movq %rsp, %rbp #,
leave
ret
Cc: Jan Beulich <jbeulich@novell.com>
Cc: Andi Kleen <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Access to chip-internal registers should always be native-endian. This is
especially important for AVR32 since it's a big-endian architecture and the
non-raw readl() and writel() macros are defined to do little-endian
accesses.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Andrew Victor <andrew@sanpeople.com>
While compiling my code with -Wconversion using gcc-trunk, I always get a
bunch of warrning from headers, here is fix for them:
__getblk is alawys called with unsigned argument,
but it takes signed, the same story with __bread,__breadahead and so on.
Signed-off-by: Tomasz Kvarsin
The problem we were assuming that current->nsproxy->ipc_ns would never
change while someone has our file in /proc/sysvipc/ file open. Given that
this can change with both unshare and by passing the file descriptor to
another process that assumption is occasionally wrong.
Therefore this patch causes /proc/sysvipc/* to cache the namespace and
increment it's count when we open the file and to decrement the count when
we close the file, ensuring consistent operation with no surprises.
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Use ARRAY_SIZE macro already defined in kernel.h
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
A patch to use ARRAY_SIZE macro already defined in kernel.h
Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
The problem is various drivers legally validly and sensibly try to claim
IRQs but the kernel insists on vomiting forth a giant irrelevant debugging
spew when the types clash.
Edit kernel/irq/manage.c go down to mismatch: in setup_irq() and ifdef out
the if clause that checks for mismatches. It'll then just do the right
thing and work sanely.
For the current -mm kernel this will do the trick (and moves it into shared
irq debugging as in debug mode the info spew is useful). I've had a
variant of this in my private tree for some time as I got fed up on the
mess on boxes where old legacy IRQs get reused.
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Drivers registering IRQ handlers with SA_SHIRQ really ought to be able to
handle an interrupt happening before request_irq() returns. They also
ought to be able to handle an interrupt happening during the start of their
call to free_irq(). Let's test that hypothesis....
[bunk@stusta.de: Kconfig fixes]
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Fix for inotify read bug (bugzilla.kernel.org #6999)
Problem Description:
When reading from an inotify device with an insufficient sized buffer, read(2)
will return 0 with no errno set. This is because of an logically incorrect
action from the user program thus should return an more logical value. My
suggestion is return -EINVAL as for bind(2).
This patch is based on the proposal from Ryan <wolf0403@hotmail.com>, and
feedback from John McCutchan <john@johnmccutchan.com>.
Return -EINVAL if we have not passed in enough buffer space to read a single
inotify event, rather than 0 which indicates that there is nothing to read.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: "John McCutchan" <john@johnmccutchan.com>
Cc: Ryan <wolf0403@hotmail.com>
Iterate over sb->s_inodes instead of sb->s_files in add_dquot_ref. This
reduces list search and lock hold time aswell as getting rid of one of the
few uses of file_list_lock which Ingo identified as a scalability problem.
Previously we called dq_op->initialize for every inode handing of a
writeable file that wasn't initialized before. Now we're calling it for
every inode that has a non-zero i_writecount, aka a writeable file
descriptor refering to it.
Thanks a lot to Jan Kara for running this patch through his quota test
harness.
Remove_dquot_ref can move to dqout.c instead of beeing in inode.c under
#ifdef CONFIG_QUOTA. Also clean the resulting code up a tiny little bit by
testing sb->dq_op earlier - it's constant over a filesystems lifetime.
Cc: Jan Kara <jack@ucw.cz>
The return value of scnprintf() never exceeds @size.
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
This patch fixes the documentation of nfsroot to match NFS_DEF_FILE_IO_SIZE.
Or perhaps we need to change NFS_DEF_FILE_IO_SIZE to match the
documentation?
Signed-off-by: Dan Aloni <da-x@monatomic.org>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cyclades no longer serves the 2 e-mails listed in MAINTAINERS. Remove them
and mark those entries as Orphaned.
Since quota.h declares a R/W semaphore, it should include rwsem.h
explicitly.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Acked-by: Jan Kara <jack@suse.cz>
Remove labs() since it is not used/needed.
