2011-10-31md: Add in export.h for files using EXPORT_SYMBOLPaul Gortmaker
These files were getting the defines for EXPORT_SYMBOL because device.h was including module.h. But we are going to put an end to that. So add the proper export.h include now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31md: Add module.h to all files using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in md dir are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31hid: Fix up files needing export.h for EXPORT_SYMBOLPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31hid: Add module.h to fix up implicit users of itPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in clocksource are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/input: add export.h to symbol exporting files.Paul Gortmaker
These files are not modules but are exporting symbols and/or making use of THIS_MODULE macro. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/input: Add module.h to modular drivers implicitly using itPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in input dir are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers: power_supply_sysfs.c needs stat.hPaul Gortmaker
It was actually getting this before by a tangled mess of implict includes that is going to be cleaned up. Fix it now, so we don't get this after the cleanup. power_supply_sysfs.c: In function ‘power_supply_attr_is_visible’: power_supply_sysfs.c:184: error: ‘S_IRUSR’ undeclared (first use in this function) power_supply_sysfs.c:184: error: (Each undeclared identifier is reported only once power_supply_sysfs.c:184: error: for each function it appears in.) power_supply_sysfs.c:184: error: ‘S_IRGRP’ undeclared (first use in this function) power_supply_sysfs.c:184: error: ‘S_IROTH’ undeclared (first use in this function) power_supply_sysfs.c:196: error: ‘S_IWUSR’ undeclared (first use in this function) make[3]: *** [drivers/power/power_supply_sysfs.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/base: transport_class explicitly requires EXPORT_SYMBOLPaul Gortmaker
This file was getting <linux/module.h> via an implicit include path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give it the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31of: of_pci.c needs export.h since it uses EXPORT_SYMBOLSPaul Gortmaker
It was getting it implicitly before, since module.h was pulled in via device.h -- but that is something we are going to make go away soon. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31block: Change module.h -> export.h in bsg-lib.cPaul Gortmaker
This file isn't using full modular functionality, and hence can be "downgraded" to just using the export.h header. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31block: Fix files that are modules and hence need module.hPaul Gortmaker
We want to remove the implicit everywhere presence of module.h so fix up the people relying on that implicit presence in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31block: add export.h to files using EXPORT_SYMBOL/THIS_MODULE macrosPaul Gortmaker
These files were getting <linux/module.h> via an implicit include path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mtd: Add module.h to drivers users that were implicitly using it.Paul Gortmaker
We are cleaning up the implicit presence of module.h that these drivers are taking advantage of. Fix them in advance of the cleanup operation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mtd: Add export.h for EXPORT_SYMBOL/THIS_MODULE where neededPaul Gortmaker
These two common macros will be no longer present everywhere. Call out the include needs of them explicitly where required. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31crypto: add module.h to those files that are explicitly using itPaul Gortmaker
Part of the include cleanups means that the implicit inclusion of module.h via device.h is going away. So fix things up in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: fix mislocated headers in cxgb4/l2t.cPaul Gortmaker
For some reason three #include <linux/...> are buried way down in the file. Since the inclusion of module.h is one of them, the inclusion comes after use of EXPORT_SYMBOL which will cause warnings about implicit declarations. Relocate all the headers to the top. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: wireless/ath/ath5k/debug.c does not need module.hPaul Gortmaker
It only has module_param and EXPORT_SYMBOL, so now that export.h is in scope at the same time as the recent ath5k update, we can delete this module.h include. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: Add moduleparam.h to drivers as required.Paul Gortmaker
These files were using moduleparam infrastructure, but were not including anything for it -- which is fine when module.h is being implicitly included in all files, but that is going away. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: change moduleparam.h to module.h as required.Paul Gortmaker
2011-10-31drivers/net: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These were getting the macros from an implicit module.h include via device.h, but we are planning to clean that up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c This relatively recently added file uses EXPORT_SYMBOL and hence needs export.h included so that it is compatible with the module.h split up work. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: Add module.h to drivers who were implicitly using itPaul Gortmaker
The device.h header was including module.h, making it present for most of these drivers. But we want to clean that up. Call out the include of module.h in the modular network drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31unicore32: EXPORT_SYMBOL needs export.hAxel Lin
Include export.h to fix below warning: CC arch/unicore32/mm/init.o arch/unicore32/mm/init.c:227: warning: data definition has no type or storage class arch/unicore32/mm/init.c:227: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' arch/unicore32/mm/init.c:227: warning: parameter names (without types) in function declaration Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31microblaze: Add export.h to arch/microblaze files as requiredPaul Gortmaker
For access to the EXPORT_SYMBOL variants and THIS_MODULE macros. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sh: Add export.h to arch/sh specific files as required.Paul Gortmaker
2011-10-31sh: Add module.h to arch/sh specific files as required.Paul Gortmaker
2011-10-31sh: fix implicit use of stat.h in arch/sh specific filesPaul Gortmaker
To fix: arch/sh/drivers/dma/dma-sysfs.c:45:8: error: 'S_IRUGO' undeclared here (not in a function) arch/sh/drivers/dma/dma-sysfs.c:75:8: error: 'S_IWUSR' undeclared here (not in a function) make[4]: *** [arch/sh/drivers/dma/dma-sysfs.o] Error 1 drivers/sh/intc/core.c:449: error: 'S_IRUGO' undeclared here (not in a function) make[5]: *** [drivers/sh/intc/core.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31alpha: Add export.h for THIS_MODULE/EXPORT_SYMBOLPaul Gortmaker
These files were getting it via the implicit module.h presence that was everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31alpha: fix implicit stat.h usage in pci-sysfs.cPaul Gortmaker
To avoid this: arch/alpha/kernel/pci-sysfs.c:164: error: 'S_IRUSR' undeclared (first use in this function) arch/alpha/kernel/pci-sysfs.c:164: error: 'S_IWUSR' undeclared (first use in this function) make[2]: *** [arch/alpha/kernel/pci-sysfs.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31blackfin: add module.h to files implicitly expecting to use it.Paul Gortmaker
Its presence was implicit everywhere, but we are aiming to fix that, so call out the users explicitly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31blackfin: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These particular files were just assuming that module.h was somehow in the include paths. Give them the more minimalist header file explicitly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31parisc: add module.h to files really requiring itPaul Gortmaker
We want to clean up the implicit everywhere presence of module.h which means files like this that use module infrastructure need to explicitly call it out for inclusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31parisc: Add export.h to files needing EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These guys were getting it implicitly via module.h before, when module.h was everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31avr32: add export.h to arch/avr32 for EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Add it in where the module.h implicit presence was doing the job before. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31m68k: Add export.h to the m68k specific files as requiredPaul Gortmaker
2011-10-31ia64: Add export.h to arch/ia64 specific files as requiredPaul Gortmaker
2011-10-31s390: add missing module.h/export.h includesHeiko Carstens
Fix several compile errors on s390 caused by splitting module.h. Some include additions [e.g. qdio_setup.c, zfcp_qdio.c] are in anticipation of pending changes queued for s390 that increase the modular use footprint. [PG: added additional obvious changes since Heiko's original patch] Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or else we get lots of variations on this: arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' scattered throughout the build. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: remove needless include of module.h from core kernel files.Paul Gortmaker
None of these files are using modular infrastructure, and build tests reveal that none of these files are really relying on any implicit inclusions via. module.h either. So delete them. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: migrate core kernel file from module.h --> export.hPaul Gortmaker
These files are not modules, but were including module.h only for EXPORT_SYMBOL and/or THIS_MODULE. Now that we have the lightweight export.h, use it in these kinds of cases. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: fix implicit smp.h usage in various files.Paul Gortmaker
We need to call out inclusion of smp.h, or with the module.h cleanup we'll get things like: arch/mips/loongson/common/platform.c:21: error: implicit declaration of function 'smp_processor_id' arch/mips/vr41xx/common/giu.c:84: error: implicit declaration of function 'smp_processor_id' arch/mips/vr41xx/common/rtc.c:85: error: implicit declaration of function 'smp_processor_id' Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31mips: fix implicit use of asm/elf.h in kernel/cpu-probe.cPaul Gortmaker
We are relying on asm/elf.h being present implicitly. Once we clean up the root cause of that, we'll see this, so fix it in advance. arch/mips/kernel/cpu-probe.c: In function 'set_elf_platform': arch/mips/kernel/cpu-probe.c:298: error: '__elf_platform' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: Add module.h to files previously implicitly using it.Paul Gortmaker
The file mm/extable.c needs module.h for within_module_init(), and also for search_exception_tables [which arguably could be living somewhere more appropriate than module.h] - eventually causing this: arch/sparc/mm/extable.c: In function 'trim_init_extable': arch/sparc/mm/extable.c:74: error: dereferencing pointer to incomplete type arch/sparc/mm/extable.c:75: error: dereferencing pointer to incomplete type arch/sparc/mm/extable.c:77: error: implicit declaration of function 'within_module_init' arch/sparc/mm/extable.c:77: error: dereferencing pointer to incomplete type arch/sparc/mm/extable.c:78: error: dereferencing pointer to incomplete type arch/sparc/mm/extable.c:80: error: dereferencing pointer to incomplete type arch/sparc/mm/extable.c: In function 'search_extables_range': arch/sparc/mm/extable.c:93: error: implicit declaration of function 'search_exception_tables' The other instances are more straight forward uses of things like MODULE_* and module_* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: remove several unnecessary module.h include instancesPaul Gortmaker
Building an allyesconfig doesn't reveal a hidden need for any of these. Since module.h brings in the whole kitchen sink, it just needlessly adds 30k+ lines to the cpp burden. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: move symbol exporters to use export.h not module.hPaul Gortmaker
Many of the core sparc kernel files are not modules, but just including module.h for exporting symbols. Now these files can use the lighter footprint export.h for this role. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: add export.h to arch/sparc files as requiredPaul Gortmaker
These files are only exporting symbols, so they don't need the full module.h header file. Previously they were getting access to EXPORT_SYMBOL implicitly via overuse of module.h from within other .h files, but that is being cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: fix implicit use of uaccess.h header in mdesc.cPaul Gortmaker
Building sparc64 with the module.h cleanup reveals this implicit include being taken advantage of: arch/sparc/kernel/mdesc.c: In function 'mdesc_read': arch/sparc/kernel/mdesc.c:900: error: implicit declaration of function 'copy_to_user' Fix it up before the implicit module.h presence is removed. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31sparc: fix implicit use of spitfire.h in pcr.c and of_device_64.cPaul Gortmaker
To resolve these on 64bit allnoconfig builds: CC arch/sparc/kernel/pcr.o arch/sparc/kernel/pcr.c: In function 'register_perf_hsvc': arch/sparc/kernel/pcr.c:102: error: 'tlb_type' undeclared (first use in this function) CC arch/sparc/kernel/of_device_64.o arch/sparc/kernel/of_device_64.c: In function 'build_device_resources': arch/sparc/kernel/of_device_64.c:406: error: 'tlb_type' undeclared (first use in this function) Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31arm: Add moduleparam.h to arch/arm files as requiredPaul Gortmaker
Things like module_param and core_param come from the header moduleparam.h -- these files were relying on the fact that module.h is implicitly present everywhere and it in turn includes the moduleparam header. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31arm: fix implicit module.h users by adding it to arch/arm as required.Paul Gortmaker
These files will fail to compile if we dont clean them up in advance and have them include the appropriate headers they need. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31arm: Add export.h to ARM specific files as required.Paul Gortmaker
These files all make use of one of the EXPORT_SYMBOL variants or the THIS_MODULE macro. So they will need <linux/export.h> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
