On OMAP platforms, some people want to declare to segment up the memory
between the kernel and a separate application such that there is a hole
in the middle of the memory as far as Linux is concerned. However,
they want to be able to mmap() the hole.
This currently causes problems, because update_mmu_cache() thinks that
there are valid struct pages for the "hole". Fix this by making
pfn_valid() slightly more expensive, by checking whether the PFN is
contained within the meminfo array.
Tested-by: Khasim Syed Mohammed <khasim@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
sharpsl_pm.c code tries to read battery state very early during
resume, but those battery meters are connected on SPI and that's only
resumed way later.
Replace the check with simple checking of battery fatal signal, that
actually works at this stage.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Tested-by: Stanislav Brabec <utx@penguin.cz>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
This patch updates the default config for HP Jornada 700-series handhelds.
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
highmem
Let's suppose a highmem page is kmap'd with kmap(). A pkmap entry is
used, the page mapped to it, and the virtual cache is dirtied. Then
kunmap() is used which does virtually nothing except for decrementing a
usage count.
Then, let's suppose the _same_ page gets mapped using kmap_atomic().
It is therefore mapped onto a fixmap entry instead, which has a
different virtual address unaware of the dirty cache data for that page
sitting in the pkmap mapping.
Fortunately it is easy to know if a pkmap mapping still exists for that
page and use it directly with kmap_atomic(), thanks to kmap_high_get().
And actual testing with a printk in the added code path shows that this
condition is actually met *extremely* frequently. Seems that we've been
quite lucky that things have worked so well with highmem so far.
Cc: stable@kernel.org
Signed-off-by: Nicolas Pitre <nico@marvell.com>
disable_irq() cannot be called from interrupt context without self imposed deadlock. This was happening in ks8695uart_stop_tx().
Signed-off-by: Dick Hollenbeck <dick@softplc.com>
In xdr_partial_copy_from_skb() there is that sequence:
kaddr = kmap_atomic(*ppage, KM_SKB_SUNRPC_DATA);
flush_dcache_page(*ppage);
kunmap_atomic(kaddr, KM_SKB_SUNRPC_DATA);
Mixing flush_dcache_page() and kmap_atomic() is a bit odd,
especially since kunmap_atomic() must deal with cache issues
already. OTOH the non-highmem case must use flush_dcache_page()
as kunmap_atomic() becomes a no op with no cache maintenance.
Problem is that with highmem the implementation of kmap_atomic()
doesn't set page->virtual, and page_address(page) returns 0 in
that case. Here flush_dcache_page() calls __flush_dcache_page()
which calls __cpuc_flush_dcache_page(page_address(page)) resulting
in a kernel oops.
None of the kmap_atomic() implementations uses set_page_address().
Hence we can assume page_address() is always expected to return 0 in
that case. Let's conditionally call __cpuc_flush_dcache_page() only
when the page address is non zero, and perform that test only when
highmem is configured.
In the recent change by Al Viro that changes verious subsystems
to use "struct path" one case was missed in the autofs4 module
which causes mounts to no longer expire.
Signed-off-by: Ian Kent <raven@themaw.net>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix MacBookPro 3,1/4,1 quirk with ALC889A
ALSA: hda - Add missing mux check for VT1708
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB (12564a): MAINTAINERS: Update gspca sn9c20x name style
V4L/DVB (12502): gspca - sn9c20x: Fix gscpa sn9c20x build errors.
V4L/DVB (12495): em28xx: Don't call em28xx_ir_init when disable_ir is true
V4L/DVB (12457): zr364: wrong indexes
V4L/DVB (12451): Update KConfig File to enable SDIO and USB interfaces
V4L/DVB (12450): Siano: Fixed SDIO compilation bugs
V4L/DVB (12449): adds webcam for Micron device MT9M111 0x143A to em28xx
V4L/DVB (12446): sms1xxx: restore GPIO functionality for all Hauppauge devices
My previous patch (commit 4f8ee2c9cc: "lmb: Remove __init from
lmb_end_of_DRAM()") removed __init in lmb.c but missed the fact that it
was also marked as such in the .h
Commit log for commit 517d3cc15b36392e518abab6bacbb72089658313
("[libata] ata_piix: Enable parallel scan") says:
This patch turns on parallel scanning for the ata_piix driver.
This driver is used on most netbooks (no AHCI for cheap storage it seems).
The scan is the dominating time factor in the kernel boot for these
devices; with this flag it gets cut in half for the device I used
for testing (eeepc).
Alan took a look at the driver source and concluded that it ought to be safe
to do for this driver. Alan has also checked with the hardware team.
and it is all true but once we put all things together additional
constraints for PATA controllers show up (some hardware registers
have per-host not per-port atomicity) and we risk misprogramming
the controller.
I used the following test to check whether the issue is real:
@@ -736,8 +736,20 @@ static void piix_set_piomode(struct ata_
(timings[pio][1] << 8);
pci_write_config_word(dev, master_port, master_data);
- if (is_slave)
+ if (is_slave) {
+ if (ap->port_no == 0) {
+ u8 tmp = slave_data;
+ while (slave_data == tmp) {
+ pci_read_config_byte(dev, slave_port, &tmp);
+ msleep(50);
+ dev_printk(KERN_ERR, &dev->dev, "PATA parallel scan "
+ "race detected\n");
pci_write_config_byte(dev, slave_port, slave_data);
/* Ensure the UDMA bit is off - it will be turned back on if
UDMA is selected */
and it indeed triggered the error message.
Lets fix all such races by adding an extra locking to ->set_piomode
and ->set_dmamode methods for PATA controllers.
[ Alan: would be better to take the host lock in libata-core for these
cases so that we fix all the adapters in one swoop. "Looks fine as a
temproary quickfix tho" ]
Cc: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Jeff Garzik <jgarzik@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel:
drm/i915: Improve CRTDDC mapping by using VBT info
drm/i915: Fix CPU-spinning hangs related to fence usage by using an LRU.
drm/i915: Set crtc/clone mask in different output devices
drm/i915: Always use SDVO_B detect bit for SDVO output detection.
drm/i915: Fix typo that broke SVID1 in intel_sdvo_multifunc_encoder()
drm/i915: Check if BIOS enabled dual-channel LVDS on 8xx, not only on 9xx
drm/i915: Set the multiplier for SDVO on G33 platform
This patch fixes the wrong headphone output routing for MacBookPro 3,1/4,1
quirk with ALC889A codec, which caused the silent headphone output.
Also, this gives the individual Headphone and Speaker volume controls.
Reference: kernel bug#14078
http://bugzilla.kernel.org/show_bug.cgi?id=14078
Cc: <stable@kernel.org>
In patch_vt1708(), the check of MUX nids is missing and this results in
the -EINVAL error in accessing Input Source mixer element. Simpliy
adding the call of get_mux_nids() fixes the problem.
Reference: Novell bnc#534904
https://bugzilla.novell.com/show_bug.cgi?id=534904
To unsubscribe from this list: send the line "unsubscribe linux-media" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
Reported-by: Toralf Forster <toralf.foerster@gmx.de>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
We should call em28xx_ir_init(dev) only when disable_ir is true.
Signed-off-by: Shine Liu <shinel@foxmail.com>
Reviewed-by: Devin Heitmueller <dheitmueller@kernellabs.com>
The order of indexes is reversed
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Antoine Jacquet <royale@zerezo.com>
Update KConfig file to enbale selection of SDIO and USB
interfaces, and add dependancy on relevant modules.
[mchehab@redhat.com: fix merge conflicts, remove default: m, add missing endmenu]
Signed-off-by: Udi Atar <udia@siano-ms.com>
Also fixed a memory overrun issue in buffer management.
[mchehab@redhat.com: fix merge conflict and a few CodingStyle issues]
Signed-off-by: Steve Gotthardt <gotthardt@gmail.com>
Previous changesets broke Hauppauge devices and their GPIO configurations.
This changeset restores the LED & LNA functionality.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
Use VBT information to determine which DDC bus to use for CRTDCC.
Fall back to GPIOA if VBT info is not available.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eric Anholt <eric@anholt.net>
Tested on: 855 (David), and 945GM, 965GM, GM45, and G45 (anholt)
The lack of a proper LRU was partially worked around by taking the fence
from the object containing the oldest seqno. But if there are multiple
objects inactive, then they don't have seqnos and the first fence reg
among them would be chosen. If you were trying to copy data between two
mappings, this could result in each page fault stealing the fence from
the other argument, and your application hanging.
https://bugs.freedesktop.org/show_bug.cgi?id=23566
https://bugs.freedesktop.org/show_bug.cgi?id=23220
https://bugs.freedesktop.org/show_bug.cgi?id=23253
https://bugs.freedesktop.org/show_bug.cgi?id=23366
Cc: Stable Team <stable@kernel.org>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: don't free non-existent backlight in acpi video module
toshiba_acpi: return on a fail path
ACPICA: Windows compatibility fix: same buffer/string store
* 'for-linus' of git://git.infradead.org/users/eparis/notify:
inotify: update the group mask on mark addition
inotify: fix length reporting and size checking
inotify: do not send a block of zeros when no pathname is available
On Tue, Aug 18, 2009 at 01:45:17PM -0400, John David Anglin wrote:
> CC arch/parisc/kernel/traps.o
> arch/parisc/kernel/traps.c: In function 'handle_interruption':
> arch/parisc/kernel/traps.c:535:18: warning: operation on 'regs->iasq[0]'
> may be undefined
Yes - Line 535 should use both [0] and [1].
Reported-by: John David Anglin <dave@hiauly1.hia.nrc.ca>
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
This patch fixes the bug that was reported in
http://bugzilla.kernel.org/show_bug.cgi?id=14053
If we're in the case where we need to force a reencode and then resend of
the RPC request, due to xprt_transmit failing with a networking error, then
we _must_ retransmit the entire request.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
> James Bottomley (1):
> module: workaround duplicate section names
-tip testing found that this patch breaks the build on x86 if
CONFIG_KALLSYMS is disabled:
kernel/module.c: In function ‘load_module’:
kernel/module.c:2367: error: ‘struct module’ has no member named ‘sect_attrs’
distcc[8269] ERROR: compile kernel/module.c on ph/32 failed
make[1]: *** [kernel/module.o] Error 1
make: *** [kernel] Error 2
make: *** Waiting for unfinished jobs....
Commit 1b364bf misses the fact that section attributes are only
built and dealt with if kallsyms is enabled. The patch below fixes
this.
( note, technically speaking this should depend on CONFIG_SYSFS as
well but this patch is correct too and keeps the #ifdef less
intrusive - in the KALLSYMS && !SYSFS case the code is a NOP. )
[ Replaced patch with a slightly cleaner variation by James Bottomley ]
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix vSMP boot crash
x86, xen: Initialize cx to suppress warning
x86, xen: Suppress WP test on Xen
acpi_video_put_one_device was attempting to remove sysfs entries and
unregister a backlight device without first checking that said backlight
device structure had been created.
Signed-off-by: Keith Packard <keithp@keithp.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Return from bt_rfkill_poll() when hci_get_radio_state() fails.
value is invalid in that case and should not be assigned to the rfkill
state.
This also fixes a double unlock bug.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Fix a compatibility issue when the same buffer or string is
stored to itself. This has been seen in the field. Previously,
ACPICA would zero out the buffer/string. Now, the operation is
treated as a NOP.
http://bugzilla.acpica.org/show_bug.cgi?id=803
Reported-by: Rezwanul Kabir <Rezwanul_Kabir@Dell.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Seperating the addition and update of marks in inotify resulted in a
regression in that inotify never gets events. The inotify group mask is
always 0. This mask should be updated any time a new mark is added.
Signed-off-by: Eric Paris <eparis@redhat.com>
0db501bd0610ee0c0 introduced a regresion in that it now sends a nul
terminator but the length accounting when checking for space or
reporting to userspace did not take this into account. This corrects
all of the rounding logic.
When an event has no pathname, there's no need to pad it with a null byte and
therefore generate an inotify_event sized block of zeros. This fixes a
regression introduced by commit 0db501bd0610ee0c0aca84d927f90bcccd09e2bd where
my system wouldn't finish booting because some process was being confused by
this.
Signed-off-by: Brian Rogers <brian@xyzw.org>
The root cause is a duplicate section name (.text); is this legal?
[ Amerigo Wang: "AFAIK, yes." ]
However, there's a problem with commit
6d76013381ed28979cd122eb4b249a88b5e384fa in that if you fail to allocate
a mod->sect_attrs (in this case it's null because of the duplication),
it still gets used without checking in add_notes_attrs()
This should fix it
[ This patch leaves other problems, particularly the sections directory,
but recent parisc toolchains seem to produce these modules and this
prevents a crash and is a minimal change -- RR ]
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Tested-by: Helge Deller <deller@gmx.de>
The rarely-used symbol_put_addr() needs to use dereference_function_descriptor
on powerpc.
Reported-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au.
As soon as the framebuffer is registered, our methods may be called by the
kernel. This leads to a crash as xenfb_refresh() gets called before we have
the irq.
Connect to the backend before registering our framebuffer with the kernel.
[ Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=14059 ]
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
inotify: Ensure we alwasy write the terminating NULL.
inotify: fix locking around inotify watching in the idr
inotify: do not BUG on idr entries at inotify destruction
inotify: seperate new watch creation updating existing watches
We call lmb_end_of_DRAM() to test whether a DMA mask is ok on a machine
without IOMMU, but this function is marked as __init.
I don't think there's a clean way to get the top of RAM max_pfn doesn't
appear to include highmem or I missed (or we have a bug :-) so for now,
let's just avoid having a broken 2.6.31 by making this function
non-__init and we can revisit later.
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs:
9p: update documentation pointers
9p: remove unnecessary v9fses->options which duplicates the mount string
net/9p: insulate the client against an invalid error code sent by a 9p server
9p: Add missing cast for the error return value in v9fs_get_inode
9p: Remove redundant inode uid/gid assignment
9p: Fix possible regressions when ->get_sb fails.
9p: Fix v9fs show_options
9p: Fix possible memleak in v9fs_inode_from fid.
9p: minor comment fixes
9p: Fix possible inode leak in v9fs_get_inode.
9p: Check for error in return value of v9fs_fid_add
Add a check in ip_append_data() for NULL *rtp to prevent future bugs in
callers from being exploitable.
Signed-off-by: Julien Tinnes <julien@cr0.org>
Signed-off-by: Tavis Ormandy <taviso@sdf.lonestar.org>
kAFS crashes when asked to read a symbolic link because page_getlink()
passes a NULL file pointer to read_mapping_page(), but afs_readpage()
expects a file pointer from which to extract a key.
Modify afs_readpage() to request the appropriate key from the calling
process's keyrings if a file struct is not supplied with one attached.
Acked-by: Anton Blanchard <anton@samba.org>
Before the rewrite copy_event_to_user always wrote a terqminating '\0'
byte to user space after the filename. Since the rewrite that
terminating byte was skipped if your filename is exactly a multiple of
event_size. Ouch!
So add one byte to name_size before we round up and use clear_user to
set userspace to zero like /dev/zero does instead of copying the
strange nul_inotify_event. I can't quite convince myself len_to_zero
will never exceed 16 and even if it doesn't clear_user should be more
efficient and a more accurate reflection of what the code is trying to
do.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
The are races around the idr storage of inotify watches. It's possible
that a watch could be found from sys_inotify_rm_watch() in the idr, but it
could be removed from the idr before that code does it's removal. Move the
locking and the refcnt'ing so that these have to happen atomically.
If an inotify watch is left in the idr when an fsnotify group is destroyed
this will lead to a BUG. This is not a dangerous situation and really
indicates a programming bug and leak of memory. This patch changes it to
use a WARN and a printk rather than killing people's boxes.
There is nothing known wrong with the inotify watch addition/modification
but this patch seperates the two code paths to make them each easy to
verify as correct.
