argument to BankField
Previously, only constants were supported, now any TermArg may
be used.
http://www.acpica.org/bugzilla/show_bug.cgi?id=387
http://www.acpica.org/bugzilla/show_bug.cgi?id=393
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Signed-off-by: Len Brown <len.brown@intel.com>
string arguments for DataTableRegion
This enables forward references and full operand resolution for
the three string arguments. Similar to OperationRegion deferred
argument execution.)
http://www.acpica.org/bugzilla/show_bug.cgi?id=430
incorrectly limited to a maximum of 32 bits
Now any size may be used.
the device tree could be terminated prematurely
In accordance with the ACPI specification, the search is terminated
if a device is both not present and not functional (instead of
just not present.) Yakui Zhao.
Update version to 20071114.
operator
The reference was incorrectly dereferenced before the copy. The
reference is now correctly copied.
http://bugzilla.kernel.org/show_bug.cgi?id=5391
References passed as arguments to control methods were dereferenced
immediately (before control was passed to the called method). The
references are now correctly passed directly to the called
method.
http://bugzilla.kernel.org/show_bug.cgi?id=5389
On some compilers, the ShortDivide function worked incorrectly,
causing problems with the BCD functions with large input
values. (Truncation from 64-bit to 32-bit occurred.) Internal
http://www.acpica.org/bugzilla/show_bug.cgi?id=435
Completes the package changes started with version 20071019.
Improved output of object dump routine.
Lint changes, fix compiler warnings, etc.
Update version to 20071019.
Implemented additional parameter validation for the LoadTable
operator. The length of the input strings SignatureString,
OemIdString, and OemTableId are now checked for maximum
lengths.
http://www.acpica.org/bugzilla/show_bug.cgi?id=582
Fixed a problem with the Increment and Decrement operators where
the type of the target object could be unexpectedly and incorrectly
changed.
http://www.acpica.org/bugzilla/show_bug.cgi?id=353
packages
Problem introduced in fix for Package references.
Fixed a problem with the Load and LoadTable operators where
the table location within the namespace was ignored. Instead,
the table was always loaded into the root or current scope.
Added additional error checking to prevent run-time faults.
Added a table checksum verification for the Load operator, in
the case where the load is from a buffer.
http://www.acpica.org/bugzilla/show_bug.cgi?id=578
Fixed a memory leak where DdbHandle objects were not deleted
automatically at control method exit.
Fixed a problem with the Debug object where a store of a DdbHandle
reference object to the Debug object could cause a fault.
Fixed a problem with the Load operator when loading a table from
a buffer object. The input buffer was prematurely zeroed and/or
deleted.
http://www.acpica.org/bugzilla/show_bug.cgi?id=577
Fixed a problem with the Alias operator when the target of the
alias is a named ASL operator that opens a new scope -- Scope,
Device, PowerResource, Processor, and ThermalZone. In these cases,
any children of the original operator could not be accessed via
the alias, potentially causing unexpected AE_NOT_FOUND exceptions.
Fixed a problem where objects of certain types (Device,
ThermalZone, Processor, PowerResource) can be not found if they
are declared and referenced from within the same control method
http://www.acpica.org/bugzilla/show_bug.cgi?id=341.
Designed and implemented new external interfaces to install and
remove handlers for ACPI table-related events. Current events that
are defined are LOAD and UNLOAD. These interfaces allow the host to
track ACPI tables as they are dynamically loaded and unloaded. See
AcpiInstallTableHandler and AcpiRemoveTableHandler.
SLIC - Software Licensing Description Table.
Implemented support to allow multiple files to be
compiled/disassembled in a single invocation. This includes
command line wildcard support for both the Windows and Unix
versions of the compiler. This feature simplifies the disassembly
and compilation of multiple ACPI tables in a single directory.
Added more information to make the message clearer.
Update version to 20070508.
Fixed a problem where the global lock handle was not properly
updated if a thread that acquired the global lock via
executing AML code then attempted to acquire the lock via the
AcpiAcquireGlobalLock interface.
pdate version to 20070320
Prevents infinite loop of 'Large Reference Count' messages in
aslts-bdemo-b286 test.
Fixes as a result of running full validation test suite.
pdate comments for acquire/release mutex interfaces
During operand evaluation, ensure that the ReturnObj field is
cleared on error and only valid pointers are stored there.
The interpreter now evaluates operands in the order that they
appear (both in the
AML and ASL), instead of in reverse order. This previously
caused subtle incompatibilities with the MS interpreter as well
as being non-intuitive.
Allows AcpiAcquireGlobalLock external interface to be called
multiple times by the
same thread. Allows use of AML fields that require the global
lock while the running AML is already holding the global lock.
Handling of AML_NAME_OP as a Reference.Opcode is no longer
needed. Kernel bugzilla 2874
fixes STACK_OVERFLOW exception on nested method calls. internal
bugzilla 262 and 275.
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
it821x: do not describe noraid parameter with its value
Pb1200/DBAu1200: fix bad IDE resource size
Au1200: IDE driver build fix
Au1200: kill IDE driver function prototypes
avr32 mustn't select HAVE_IDE
Describe noraid parameter with its name (and not its value).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
The header files for the Pb1200/DBAu1200 boards have wrong definition for the
IDE interface's decoded range length -- it should be 512 bytes according to
what the IDE driver does. In addition, the IDE platform device claims 1 byte
too many for its memory resource -- fix the platform code and the IDE driver
in accordance.
The driver fails to compile with CONFIG_BLK_DEV_IDE_AU1XXX_MDMA2_DBDMA enabled:
drivers/ide/mips/au1xxx-ide.c: In function `auide_build_dmatable':
drivers/ide/mips/au1xxx-ide.c:256: error: implicit declaration of function
`sg_virt'
drivers/ide/mips/au1xxx-ide.c:275: error: implicit declaration of function
`sg_next'
drivers/ide/mips/au1xxx-ide.c:275: warning: assignment makes pointer from
integer without a cast
Fix this by including <linux/scatterlist.h>. While at it, remove the #include's
without which the driver happily builds.
