2006-01-11add missing printk loglevel in mm/swapfile.cJesper Juhl
in mm/swapfile.c a printk() is missing a loglevel. I believe the proper loglevel for this situation is KERN_ERR, so that's what the patch below sets -if you agree, please apply. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11Tiny esthetic changes to Documentation/laptop-mode.txtJesper Juhl
Here's a tiny patch making a few esthetic changes to Documentation/laptop-mode.txt To me this patch makes sense, but feel free to disagree, I don't feel strongly about it at all. It changes a single URL to its strictly correct form (directories should end in /), and it makes the arguments to main in an included example program follow convention and be named argc and argv. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-11MAINTAINERS: sh: update the mailing listAdrian Bunk
2006-01-11ext2: trivial indentation fix.Luiz Fernando Capitulino
This memset() line was indented with seven spaces, this patch fixes it to use a tab instead. Yes, very trivial but it's the third time I have to look at this line.. Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-10[PATCH] mutex: trivial whitespace cleanupsIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2006-01-10[PATCH] mark mutex_lock*() as might_sleep()Ingo Molnar
Mark mutex_lock() and mutex_lock_interruptible() as might_sleep() functions. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fix i386 mutex fastpath on FRAME_POINTER && !DEBUG_MUTEXESIngo Molnar
Call the mutex slowpath more conservatively - e.g. FRAME_POINTERS can change the calling convention, in which case a direct branch to the slowpath becomes illegal. Bug found by Hugh Dickins. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove unnecessary asm/mutex.h from kernel/mutex-debug.cIngo Molnar
Remove unnecessary (and incorrect) inclusion of asm/mutex.h, pointed out by David Howells. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[EBTABLES] Don't match tcp/udp source/destination port for IP fragmentsBart De Schuymer
Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[IRDA] DONGLE_OLD: remove dependency on non-existing symbolAdrian Bunk
Jean-Luc Leger <reiga@dspnet.fr.eu.org> reported this alternative dependency on a non-existing symbol. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[IRDA]: kill drivers/net/irda/sir_core.cAdrian Bunk
EXPORT_SYMBOL's do nowadays belong to the files where the actual functions are. Moving the module_init/module_exit to the file with the actual functions has the advantage of saving a few bytes due to the removal of two functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[ATM]: Remove unneeded kmalloc() return value casts + tiny whitespace cleanupJesper Juhl
Small cleanups for drivers/atm/zatm.c Get rid of unneeded cast of kmalloc() return value. Small whitespace/CodingStyle/formatting cleanup (since I was in there anyway). Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NET]: Remove unneeded kmalloc() return value castsJesper Juhl
Get rid of needless casting of kmalloc() return value in net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[RXRPC]: Decrease number of pointer derefs in connection.cJesper Juhl
Decrease the number of pointer derefs in net/rxrpc/connection.c Benefits of the patch: - Fewer pointer dereferences should make the code slightly faster. - Size of generated code is smaller - improved readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[AF_NETLINK]: Fix DoS in netlink_rcv_skb()Martin Murray
From: Martin Murray <murrayma@citi.umich.edu> Sanity check nlmsg_len during netlink_rcv_skb. An nlmsg_len == 0 can cause infinite loop in kernel, effectively DoSing machine. Noted by Matin Murray. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Fix timeout sysctls on big-endian 64bit architecturesPatrick McHardy
The connection tracking timeout variables are unsigned long, but proc_dointvec_jiffies is used with sizeof(unsigned int) in the sysctl tables. Since there is no proc_doulongvec_jiffies function, change the timeout variables to unsigned int. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Remove unused function from NAT protocol helpersPatrick McHardy
->print and ->print_range are not used (and apparently never were). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Fix return value confusion in PPTP NAT helperPatrick McHardy
ip_nat_mangle_tcp_packet doesn't return NF_* values but 0/1 for failure/success. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Fix another crash in ip_nat_pptpPatrick McHardy
The PPTP NAT helper calculates the offset at which the packet needs to be mangled as difference between two pointers to the header. With non-linear skbs however the pointers may point to two seperate buffers on the stack and the calculation results in a wrong offset beeing used. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: Fix crash in ip_nat_pptpPatrick McHardy
When an inbound PPTP_IN_CALL_REQUEST packet is received the PPTP NAT helper uses a NULL pointer in pointer arithmentic to calculate the offset in the packet which needs to be mangled and corrupts random memory or crashes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NETFILTER]: net/ipv[46]/netfilter.c cleanupsPatrick McHardy
Don't wrap entire file in #ifdef CONFIG_NETFILTER, remove a few unneccessary includes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[NET]: Change memcmp(,,ETH_ALEN) to compare_ether_addr()Kris Katterjohn
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[INET]: congestion and af_ops can be constStephen Hemminger
The congestion ops and af_ops in the inet_connection_sock can be const. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[PATCH] moxa serial: add proper capability checkAlan Cox
This requires the proper capabilities for the moxa bios update ioctl's. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: save reg a5 on context changeGreg Ungerer
Fix a5 register corruption when processing user space signals handlers. We need to save a5 through each contenxt change. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix find_next_zero_bit in bitops.hGreg Ungerer
We're starting a number of big applications (memory footprint app. 1MByte) on our Arcturus uC5272. Therefore memory fragmentation is a real pain for us. We've switched to uClinux-2.4.27-uc1 and found that page_alloc2 fragments the memory heavily. Digging into it we found a bug in the find_next_zero_bit function in the m68knommu/bitops.h file. if the size isn't a multiple of 32 than the upper bits of the last word to be searched should be masked. But the functions masks the lower bits of the last word because it uses a right shift instead of a left shift operator. Patch submitted by Sascha Smejkal <s.smejkal@centersystems.at> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] uclinux: delay binfmt_flat traceGreg Ungerer
Modify the initial trace output (which is based on flags in the binary header) so that it is not done until after the magic number check. This may well not be a flat format binary, so the flags could be invalid. (Prime example, running a script). Changes prompted by patches from Stuart Hughs. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: set irq priority/level different for each ColdFire serial ↵Greg Ungerer
port Set the hardware interrupt priority to a different value for each attached ColdFire serial port. According to the CPU documentation you should not use the same combination of level/priority on more than one device. People have reported odd serial port behavior with them set the same. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: allow configure of FEC for M520x CPU familyGreg Ungerer
Allow the ColdFire FEC ethernet driver to be enabled on the M520x CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix ram length of m5208evb boardGreg Ungerer
Adjust length of M5208EVB ram define. It should size up to 32MB after adding in the dBUG reserved 128k. Problem pointed out be Milton Miller <miltonm@bga.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix a5 reg corruption in signal handlersGreg Ungerer
This is a patch adapted from a posting by Andrea Tarani which was pointed out to me by Bernardo Innocenti. Thanks to both of them for their help and patience. The original posting is here: http://mailman.uclinux.org/pipermail/uclinux-dev/2005-July/033543.html The problem first manifest itself as busybox ping terminating with an "Illegal instruction". I reduced this to a test case and found that variable size arrays allocated on the stack could lead to stacks not aligned on 32 bit boundaries. For the Coldfire this proved fatal. Having been pointed out this patch by Bernardo, I applied it and it fixed the first test case. I then went back to busybox's ping. This still failed with "Illegal instruction", but in a different way. Before it depended on the size allocated for the ping buffer, now it happened every time. I also found it depended on optimisation level (gcc-3.4.0) -Os was okay but not -O2. After a lot of looking, it turned out that register a5 was being corrupted by the signal handler (after applying the patch). I re-worked the patch a bit to save/restore a5 and now all seems well. Patch submitted by Stuart Hughs <stuarth@freescale.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: fix mangled 'truct' in ptrace.cGreg Ungerer
Fix broken "truct" -> "struct" in arch_ptrace() parameter list. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] m68knommu: don't set gcc optimizer flagsGreg Ungerer
Don't specify compiler optimization flags in the m68knommu Makefile. Let the top level Makefile/config set it. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] h8300: remove MAGIC_ROM_PTR from memory.cGreg Ungerer
Remove obsolete MAGIC_ROM_PTR code from h8300 architecture. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] h8300: remove MAGIC_ROM_PTR from k8300_ksyms.cGreg Ungerer
2006-01-10Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
2006-01-10Fix rpc shutdown event condition bugLinus Torvalds
We want to wait for the cl_users to go down to zero, not for it to stay positive. Quoth Trond (who wasn't even the author, but acked the wrong version): "Argh! I need to increase my daily caffeine dosages." Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] rcu: fix hotplug-cpu ->donelist leakOleg Nesterov
Pointed out by Srivatsa Vaddagiri <vatsa@in.ibm.com>. rcu_do_batch() stops after processing maxbatch callbacks on ->donelist leaving rcu_tasklet in TASKLET_STATE_SCHED state. If CPU_DEAD event happens remaining ->donelist entries are lost, rcu_offline_cpu() kills this tasklet. With this patch ->donelist migrates along with ->curlist and ->nxtlist to the current cpu. Compile tested. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] rcu: join rcu_ctrlblk and rcu_stateOleg Nesterov
This patch moves rcu_state into the rcu_ctrlblk. I think there are no reasons why we should have 2 different variables to control rcu state. Every user of rcu_state has also "rcu_ctrlblk *rcp" in the parameter list. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] ide-cd: clear random-write capability it not supportedAndrey Borzenkov
Add CDC-RAM to capability mask. This prevents udev incorrectly reporting RAM capabilities for device. Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dm: don't enable bouncing by defaultJens Axboe
DM doesn't need to bounce bio's on its own, but the block layer defaults to that in blk_queue_make_request(). The lower level drivers should bounce ios themselves, that is what they need to do if not layered below dm anyways. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] cdrom: kill "open failed" error messageJens Axboe
This triggers all the time with the various polled event programs, change it to CD_OPEN so it's supressed by default. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] ide: preserve errors for failed requestsJens Axboe
To preserve the ->errors values for requests that failed, use the normal completion path for that. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Work around ppc64 compiler bugAnton Blanchard
In the process of optimising our per cpu data code, I found a ppc64 compiler bug that has been around forever. Basically the current RELOC_HIDE can end up trashing r30. Details of the bug can be found at http://gcc.gnu.org/bugzilla/show_bug.cgi?id=25572 This bug is present in all compilers before 4.1. It is masked by the fact that our current per cpu data code is inefficient and causes other loads that end up marking r30 as used. A workaround identified by Alan Modra is to use the =r asm constraint instead of =g. Signed-off-by: Anton Blanchard <anton@samba.org> [ Verified that this makes no real difference on x86[-64] */ Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
2006-01-10Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2006-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-01-10Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
Fix up some trivial conflicts in {i386|ia64}/Makefile
2006-01-10[PATCH] fs/hfsplus/: remove the hfsplus_inode_check() debug functionAdrian Bunk
This patch removes the hfsplus_inode_check() debug function. It also removes the now obsolete last_inode_cnt and inode_cnt from struct hfsplus_sb_info. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
