2012-03-23powerpc/pmac: Fix SMP kernels on pre-core99 UP machinesBenjamin Herrenschmidt
commit 78c5c68a4cf4329d17abfa469345ddf323d4fd62 upstream. The code for "powersurge" SMP would kick in and cause a crash at boot due to the lack of a NULL test. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Reported-by: Adam Conrad <adconrad@ubuntu.com> Tested-by: Adam Conrad <adconrad@ubuntu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23iwl3945: fix possible il->txq NULL pointer dereference in delayed worksStanislaw Gruszka
commit 210787e82a0ac1ffb5d7be1c796f0c51050849ad upstream. On il3945_down procedure we free tx queue data and nullify il->txq pointer. After that we drop mutex and then cancel delayed works. There is possibility, that after drooping mutex and before the cancel, some delayed work will start and crash while trying to send commands to the device. For example, here is reported crash in il3945_bg_reg_txpower_periodic(): https://bugzilla.kernel.org/show_bug.cgi?id=42766#c10 Patch fix problem by adding il->txq check on works that send commands, hence utilize tx queue. Reported-by: Clemens Eisserer <linuxhippy@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-23ipv6: Don't dev_hold(dev) in ip6_mc_find_dev_rcu.RongQing.Li
[ Upstream commit c577923756b7fe9071f28a76b66b83b306d1d001 ] ip6_mc_find_dev_rcu() is called with rcu_read_lock(), so don't need to dev_hold(). With dev_hold(), not corresponding dev_put(), will lead to leak. [ bug introduced in 96b52e61be1 (ipv6: mcast: RCU conversions) ] Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23tcp: fix syncookie regressionEric Dumazet
[ Upstream commit dfd25ffffc132c00070eed64200e8950da5d7e9d ] commit ea4fc0d619 (ipv4: Don't use rt->rt_{src,dst} in ip_queue_xmit()) added a serious regression on synflood handling. Simon Kirby discovered a successful connection was delayed by 20 seconds before being responsive. In my tests, I discovered that xmit frames were lost, and needed ~4 retransmits and a socket dst rebuild before being really sent. In case of syncookie initiated connection, we use a different path to initialize the socket dst, and inet->cork.fl.u.ip4 is left cleared. As ip_queue_xmit() now depends on inet flow being setup, fix this by copying the temp flowi4 we use in cookie_v4_check(). Reported-by: Simon Kirby <sim@netnation.com> Bisected-by: Simon Kirby <sim@netnation.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23perf tools: Use scnprintf where applicableArnaldo Carvalho de Melo
commit e7f01d1e3d8d501deb8abeaa269d5d48a703b8b0 upstream. Several places were expecting that the value returned was the number of characters printed, not what would be printed if there was space. Fix it by using the scnprintf and vscnprintf variants we inherited from the kernel sources. Some corner cases where the number of printed characters were not accounted were fixed too. Reported-by: Anton Blanchard <anton@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/n/tip-kwxo2eh29cxmd8ilixi2005x@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23perf tools: Incorrect use of snprintf results in SEGVAnton Blanchard
commit b832796caa1fda8516464a003c8c7cc547bc20c2 upstream. I have a workload where perf top scribbles over the stack and we SEGV. What makes it interesting is that an snprintf is causing this. The workload is a c++ gem that has method names over 3000 characters long, but snprintf is designed to avoid overrunning buffers. So what went wrong? The problem is we assume snprintf returns the number of characters written: ret += repsep_snprintf(bf + ret, size - ret, "[%c] ", self->level); ... ret += repsep_snprintf(bf + ret, size - ret, "%s", self->ms.sym->name); Unfortunately this is not how snprintf works. snprintf returns the number of characters that would have been written if there was enough space. In the above case, if the first snprintf returns a value larger than size, we pass a negative size into the second snprintf and happily scribble over the stack. If you have 3000 character c++ methods thats a lot of stack to trample. This patch fixes repsep_snprintf by clamping the value at size - 1 which is the maximum snprintf can write before adding the NULL terminator. I get the sinking feeling that there are a lot of other uses of snprintf that have this same bug, we should audit them all. Cc: David Ahern <dsahern@gmail.com> Cc: Eric B Munson <emunson@mgebm.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20120307114249.44275ca3@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23afs: Remote abort can cause BUG in rxrpc codeAnton Blanchard
commit c0173863528a8c9212c53e080d63a1aaae5ef4f4 upstream. When writing files to afs I sometimes hit a BUG: kernel BUG at fs/afs/rxrpc.c:179! With a backtrace of: afs_free_call afs_make_call afs_fs_store_data afs_vnode_store_data afs_write_back_from_locked_page afs_writepages_region afs_writepages The cause is: ASSERT(skb_queue_empty(&call->rx_queue)); Looking at a tcpdump of the session the abort happens because we are exceeding our disk quota: rx abort fs reply store-data error diskquota exceeded (32) So the abort error is valid. We hit the BUG because we haven't freed all the resources for the call. By freeing any skbs in call->rx_queue before calling afs_free_call we avoid hitting leaking memory and avoid hitting the BUG. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23afs: Read of file returns EBADMSGAnton Blanchard
commit 2c724fb92732c0b2a5629eb8af74e82eb62ac947 upstream. A read of a large file on an afs mount failed: # cat junk.file > /dev/null cat: junk.file: Bad message Looking at the trace, call->offset wrapped since it is only an unsigned short. In afs_extract_data: _enter("{%u},{%zu},%d,,%zu", call->offset, len, last, count); ... if (call->offset < count) { if (last) { _leave(" = -EBADMSG [%d < %zu]", call->offset, count); return -EBADMSG; } Which matches the trace: [cat ] ==> afs_extract_data({65132},{524},1,,65536) [cat ] <== afs_extract_data() = -EBADMSG [0 < 65536] call->offset went from 65132 to 0. Fix this by making call->offset an unsigned int. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23nilfs2: fix NULL pointer dereference in nilfs_load_super_block()Ryusuke Konishi
commit d7178c79d9b7c5518f9943188091a75fc6ce0675 upstream. According to the report from Slicky Devil, nilfs caused kernel oops at nilfs_load_super_block function during mount after he shrank the partition without resizing the filesystem: BUG: unable to handle kernel NULL pointer dereference at 00000048 IP: [<d0d7a08e>] nilfs_load_super_block+0x17e/0x280 [nilfs2] *pde = 00000000 Oops: 0000 [#1] PREEMPT SMP ... Call Trace: [<d0d7a87b>] init_nilfs+0x4b/0x2e0 [nilfs2] [<d0d6f707>] nilfs_mount+0x447/0x5b0 [nilfs2] [<c0226636>] mount_fs+0x36/0x180 [<c023d961>] vfs_kern_mount+0x51/0xa0 [<c023ddae>] do_kern_mount+0x3e/0xe0 [<c023f189>] do_mount+0x169/0x700 [<c023fa9b>] sys_mount+0x6b/0xa0 [<c04abd1f>] sysenter_do_call+0x12/0x28 Code: 53 18 8b 43 20 89 4b 18 8b 4b 24 89 53 1c 89 43 24 89 4b 20 8b 43 20 c7 43 2c 00 00 00 00 23 75 e8 8b 50 68 89 53 28 8b 54 b3 20 <8b> 72 48 8b 7a 4c 8b 55 08 89 b3 84 00 00 00 89 bb 88 00 00 00 EIP: [<d0d7a08e>] nilfs_load_super_block+0x17e/0x280 [nilfs2] SS:ESP 0068:ca9bbdcc CR2: 0000000000000048 This turned out due to a defect in an error path which runs if the calculated location of the secondary super block was invalid. This patch fixes it and eliminates the reported oops. Reported-by: Slicky Devil <slicky.dvl@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Slicky Devil <slicky.dvl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19Linux 3.2.12v3.2.12Greg Kroah-Hartman
2012-03-19hwmon: (zl6100) Enable interval between chip accesses for all chipsGuenter Roeck
commit fecfb64422d91a9621a3f96ab75c3a5f13e80b58 upstream. Intersil reports that all chips supported by the zl6100 driver require an interval between chip accesses, even ZL2004 and ZL6105 which were thought to be safe. Reported-by: Vivek Gani <vgani@intersil.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19target: Fix compatible reservation handling (CRH=1) with legacy RESERVE/RELEASENicholas Bellinger
commit 087a03b3ea1c8d6e2d5743a8d1c6d571058caa04 upstream. This patch addresses a bug with target_check_scsi2_reservation_conflict() return checking in target_scsi2_reservation_[reserve,release]() that was preventing CRH=1 operation from silently succeeding in the two special cases defined by SPC-3, and not failing with reservation conflict status when dealing with legacy RESERVE/RELEASE + active SPC-3 PR logic. Also explictly set cmd->scsi_status = SAM_STAT_RESERVATION_CONFLICT during the early non reservation holder failure from pr_ops->t10_seq_non_holder() check in transport_generic_cmd_sequencer() for fabrics that already expect it to be set. This bug was originally introduced in mainline commit: commit eacac00ce5bfde8086cd0615fb53c986f7f970fe Author: Christoph Hellwig <hch@infradead.org> Date: Thu Nov 3 17:50:40 2011 -0400 target: split core_scsi2_emulate_crh Reported-by: Martin Svec <martin.svec@zoner.cz> Cc: Martin Svec <martin.svec@zoner.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19iscsi-target: Fix reservation conflict -EBUSY response handling bugNicholas Bellinger
commit 00fdc6bbef77844ce397a7de7acfaf25e8e2e4eb upstream. This patch addresses a iscsi-target specific bug related to reservation conflict handling in iscsit_handle_scsi_cmd() that has been causing reservation conflicts to complete and not fail as expected due to incorrect errno checking. The problem occured with the change to return -EBUSY from transport_generic_cmd_sequencer() -> transport_generic_allocate_tasks() failures, that broke iscsit_handle_scsi_cmd() checking for -EINVAL in order to invoke a non GOOD status response. This was manifesting itself as data corruption with legacy SPC-2 reservations, but also effects iscsi-target LUNs with SPC-3 persistent reservations. This bug was originally introduced in lio-core commit: commit 03e98c9eb916f3f0868c1dc344dde2a60287ff72 Author: Nicholas Bellinger <nab@linux-iscsi.org> Date: Fri Nov 4 02:36:16 2011 -0700 target: Address legacy PYX_TRANSPORT_* return code breakage Reported-by: Martin Svec <martin.svec@zoner.cz> Cc: Martin Svec <martin.svec@zoner.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19i2c-algo-bit: Fix spurious SCL timeouts under heavy loadVille Syrjala
commit 8ee161ce5e0cfc689eb677f227a6248191165fac upstream. When the system is under heavy load, there can be a significant delay between the getscl() and time_after() calls inside sclhi(). That delay may cause the time_after() check to trigger after SCL has gone high, causing sclhi() to return -ETIMEDOUT. To fix the problem, double check that SCL is still low after the timeout has been reached, before deciding to return -ETIMEDOUT. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19rapidio/tsi721: fix bug in register offset definitionsAlexandre Bounine
commit 9bbad7da76b3dd578fb55c862624366a8c9ccd22 upstream. Fix indexed register offset definitions that use decimal (wrong) instead of hexadecimal (correct) notation for indexing multipliers. Incorrect definitions do not affect Tsi721 driver in its current default configuration because it uses only IDB queue 0. Loss of inbound doorbell functionality should be observed if queue other than 0 is used. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Chul Kim <chul.kim@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix temp2 source for W83627UHGJean Delvare
commit aacb6b0052692c72fe0cb94c6b547202def6ef46 upstream. Properly set the source of temp2 for the W83627UHG. Also fix a comment right before that, and document the W83627UHG as reporting up to 3 temperatures. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix memory leak in probe functionGuenter Roeck
commit 32260d94408c553dca4ce54104edf79941a27536 upstream. The driver probe function leaked memory if creating the cpu0_vid attribute file failed. Fix by converting the driver to use devm_kzalloc. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19hwmon: (w83627ehf) Fix writing into fan_stop_time for NCT6775F/NCT6776FGuenter Roeck
commit 33fa9b620409edfc71aa6cf01a51f990fbe46ab8 upstream. NCT6775F and NCT6776F have their own set of registers for FAN_STOP_TIME. The correct registers were used to read FAN_STOP_TIME, but writes used the wrong registers. Fix it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19sparc32: Add -Av8 to assembler command line.David S. Miller
commit e0adb9902fb338a9fe634c3c2a3e474075c733ba upstream. Newer version of binutils are more strict about specifying the correct options to enable certain classes of instructions. The sparc32 build is done for v7 in order to support sun4c systems which lack hardware integer multiply and divide instructions. So we have to pass -Av8 when building the assembler routines that use these instructions and get patched into the kernel when we find out that we have a v8 capable cpu. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19Block: use a freezable workqueue for disk-event pollingAlan Stern
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream. This patch (as1519) fixes a bug in the block layer's disk-events polling. The polling is done by a work routine queued on the system_nrt_wq workqueue. Since that workqueue isn't freezable, the polling continues even in the middle of a system sleep transition. Obviously, polling a suspended drive for media changes and such isn't a good thing to do; in the case of USB mass-storage devices it can lead to real problems requiring device resets and even re-enumeration. The patch fixes things by creating a new system-wide, non-reentrant, freezable workqueue and using it for disk-events polling. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19block: fix __blkdev_get and add_disk race conditionStanislaw Gruszka
commit 9f53d2fe815b4011ff930a7b6db98385d45faa68 upstream. The following situation might occur: __blkdev_get: add_disk: register_disk() get_gendisk() disk_block_events() disk->ev == NULL disk_add_events() __disk_unblock_events() disk->ev != NULL --ev->block Then we unblock events, when they are suppose to be blocked. This can trigger events related block/genhd.c warnings, but also can crash in sd_check_events() or other places. I'm able to reproduce crashes with the following scripts (with connected usb dongle as sdb disk). <snip> DEV=/dev/sdb ENABLE=/sys/bus/usb/devices/1-2/bConfigurationValue function stop_me() { for i in `jobs -p` ; do kill $i 2> /dev/null ; done exit } trap stop_me SIGHUP SIGINT SIGTERM for ((i = 0; i < 10; i++)) ; do while true; do fdisk -l $DEV 2>&1 > /dev/null ; done & done while true ; do echo 1 > $ENABLE sleep 1 echo 0 > $ENABLE done </snip> I use the script to verify patch fixing oops in sd_revalidate_disk http://marc.info/?l=linux-scsi&m=132935572512352&w=2 Without Jun'ichi Nomura patch titled "Fix NULL pointer dereference in sd_revalidate_disk" or this one, script easily crash kernel within a few seconds. With both patches applied I do not observe crash. Unfortunately after some time (dozen of minutes), script will hung in: [ 1563.906432] [<c08354f5>] schedule_timeout_uninterruptible+0x15/0x20 [ 1563.906437] [<c04532d5>] msleep+0x15/0x20 [ 1563.906443] [<c05d60b2>] blk_drain_queue+0x32/0xd0 [ 1563.906447] [<c05d6e00>] blk_cleanup_queue+0xd0/0x170 [ 1563.906454] [<c06d278f>] scsi_free_queue+0x3f/0x60 [ 1563.906459] [<c06d7e6e>] __scsi_remove_device+0x6e/0xb0 [ 1563.906463] [<c06d4aff>] scsi_forget_host+0x4f/0x60 [ 1563.906468] [<c06cd84a>] scsi_remove_host+0x5a/0xf0 [ 1563.906482] [<f7f030fb>] quiesce_and_remove_host+0x5b/0xa0 [usb_storage] [ 1563.906490] [<f7f03203>] usb_stor_disconnect+0x13/0x20 [usb_storage] Anyway I think this patch is some step forward. As drawback, I do not teardown on sysfs file create error, because I do not know how to nullify disk->ev (since it can be used). However add_disk error handling practically does not exist too, and things will work without this sysfs file, except events will not be exported to user space. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19block, sx8: fix pointer math issue getting fw versionDan Carpenter
commit ea5f4db8ece896c2ab9eafa0924148a2596c52e4 upstream. "mem" is type u8. We need parenthesis here or it screws up the pointer math probably leading to an oops. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19block: Fix NULL pointer dereference in sd_revalidate_diskJun'ichi Nomura
commit fe316bf2d5847bc5dd975668671a7b1067603bc7 upstream. Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(), __blkdev_get() calls rescan_partitions() to remove in-kernel partition structures and raise KOBJ_CHANGE uevent. However it ends up calling driver's revalidate_disk without open and could cause oops. In the case of SCSI: process A process B ---------------------------------------------- sys_open __blkdev_get sd_open returns -ENOMEDIUM scsi_remove_device <scsi_device torn down> rescan_partitions sd_revalidate_disk <oops> Oopses are reported here: http://marc.info/?l=linux-scsi&m=132388619710052 This patch separates the partition invalidation from rescan_partitions() and use it for -ENOMEDIUM case. Reported-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19regulator: Fix setting selector in tps6524x set_voltage functionAxel Lin
commit f03570cf1709397ebe656608266b44ec772960c2 upstream. Don't assign the voltage to selector. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19usb: asix: Patch for Sitecom LN-031Joerg Neikes
commit 4e50391968849860dff1aacde358b4eb14aa5127 upstream. This patch adds support for the Sitecom LN-031 USB adapter with a AX88178 chip. Added USB id to find correct driver for AX88178 1000 Ethernet adapter. Signed-off-by: Joerg Neikes <j.neikes@midlandgate.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19IPv6: Fix not join all-router mcast group when forwarding set.Li Wei
[ Upstream commit d6ddef9e641d1229d4ec841dc75ae703171c3e92 ] When forwarding was set and a new net device is register, we need add this device to the all-router mcast group. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19tcp: fix tcp_shift_skb_data() to not shift SACKed data below snd_unaNeal Cardwell
[ Upstream commit 4648dc97af9d496218a05353b0e442b3dfa6aaab ] This commit fixes tcp_shift_skb_data() so that it does not shift SACKed data below snd_una. This fixes an issue whose symptoms exactly match reports showing tp->sacked_out going negative since 3.3.0-rc4 (see "WARNING: at net/ipv4/tcp_input.c:3418" thread on netdev). Since 2008 (832d11c5cd076abc0aa1eaf7be96c81d1a59ce41) tcp_shift_skb_data() had been shifting SACKed ranges that were below snd_una. It checked that the *end* of the skb it was about to shift from was above snd_una, but did not check that the end of the actual shifted range was above snd_una; this commit adds that check. Shifting SACKed ranges below snd_una is problematic because for such ranges tcp_sacktag_one() short-circuits: it does not declare anything as SACKed and does not increase sacked_out. Before the fixes in commits cc9a672ee522d4805495b98680f4a3db5d0a0af9 and daef52bab1fd26e24e8e9578f8fb33ba1d0cb412, shifting SACKed ranges below snd_una happened to work because tcp_shifted_skb() was always (incorrectly) passing in to tcp_sacktag_one() an skb whose end_seq tcp_shift_skb_data() had already guaranteed was beyond snd_una. Hence tcp_sacktag_one() never short-circuited and always increased tp->sacked_out in this case. After those two fixes, my testing has verified that shifting SACKed ranges below snd_una could cause tp->sacked_out to go negative with the following sequence of events: (1) tcp_shift_skb_data() sees an skb whose end_seq is beyond snd_una, then shifts a prefix of that skb that is below snd_una (2) tcp_shifted_skb() increments the packet count of the already-SACKed prev sk_buff (3) tcp_sacktag_one() sees the end of the new SACKed range is below snd_una, so it short-circuits and doesn't increase tp->sacked_out (5) tcp_clean_rtx_queue() sees the SACKed skb has been ACKed, decrements tp->sacked_out by this "inflated" pcount that was missing a matching increase in tp->sacked_out, and hence tp->sacked_out underflows to a u32 like 0xFFFFFFFF, which casted to s32 is negative. (6) this leads to the warnings seen in the recent "WARNING: at net/ipv4/tcp_input.c:3418" thread on the netdev list; e.g.: tcp_input.c:3418 WARN_ON((int)tp->sacked_out < 0); More generally, I think this bug can be tickled in some cases where two or more ACKs from the receiver are lost and then a DSACK arrives that is immediately above an existing SACKed skb in the write queue. This fix changes tcp_shift_skb_data() to abort this sequence at step (1) in the scenario above by noticing that the bytes are below snd_una and not shifting them. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19bridge: check return value of ipv6_dev_get_saddr()Ulrich Weber
[ Upstream commit d1d81d4c3dd886d5fa25a2c4fa1e39cb89613712 ] otherwise source IPv6 address of ICMPV6_MGM_QUERY packet might be random junk if IPv6 is disabled on interface or link-local address is not yet ready (DAD). Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19tcp: don't fragment SACKed skbs in tcp_mark_head_lost()Neal Cardwell
[ Upstream commit c0638c247f559e1a16ee79e54df14bca2cb679ea ] In tcp_mark_head_lost() we should not attempt to fragment a SACKed skb to mark the first portion as lost. This is for two primary reasons: (1) tcp_shifted_skb() coalesces adjacent regions of SACKed skbs. When doing this, it preserves the sum of their packet counts in order to reflect the real-world dynamics on the wire. But given that skbs can have remainders that do not align to MSS boundaries, this packet count preservation means that for SACKed skbs there is not necessarily a direct linear relationship between tcp_skb_pcount(skb) and skb->len. Thus tcp_mark_head_lost()'s previous attempts to fragment off and mark as lost a prefix of length (packets - oldcnt)*mss from SACKed skbs were leading to occasional failures of the WARN_ON(len > skb->len) in tcp_fragment() (which used to be a BUG_ON(); see the recent "crash in tcp_fragment" thread on netdev). (2) there is no real point in fragmenting off part of a SACKed skb and calling tcp_skb_mark_lost() on it, since tcp_skb_mark_lost() is a NOP for SACKed skbs. Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Yuchung Cheng <ycheng@google.com> Acked-by: Nandita Dukkipati <nanditad@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19r8169: corrupted IP fragments fix for large mtu.françois romieu
[ Upstream commit 9c5028e9da1255dd2b99762d8627b88b29f68cce ] Noticed with the 8168d (-vb-gr, aka RTL_GIGA_MAC_VER_26). ConfigX registers should only be written while the Config9346 lock is held. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Reported-by: Nick Bowler <nbowler@elliptictech.com> Cc: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19packetengines: fix config defaultstephen hemminger
[ Upstream commit 3f2010b2ad3d66d5291497c9b274315e7b807ecd ] As part of the big network driver reorg, each vendor directory defaults to yes, so that older config's can migrate correctly. Looks like this one got missed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19vmxnet3: Fix transport header sizeShreyas Bhatewara
[ Upstream commit efead8710aad9e384730ecf25eae0287878840d7 ] Fix transport header size Fix the transpoert header size for UDP packets. Signed-off-by: Shreyas N Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19tcp: fix false reordering signal in tcp_shifted_skbNeal Cardwell
[ Upstream commit 4c90d3b30334833450ccbb02f452d4972a3c3c3f ] When tcp_shifted_skb() shifts bytes from the skb that is currently pointed to by 'highest_sack' then the increment of TCP_SKB_CB(skb)->seq implicitly advances tcp_highest_sack_seq(). This implicit advancement, combined with the recent fix to pass the correct SACKed range into tcp_sacktag_one(), caused tcp_sacktag_one() to think that the newly SACKed range was before the tcp_highest_sack_seq(), leading to a call to tcp_update_reordering() with a degree of reordering matching the size of the newly SACKed range (typically just 1 packet, which is a NOP, but potentially larger). This commit fixes this by simply calling tcp_sacktag_one() before the TCP_SKB_CB(skb)->seq advancement that can advance our notion of the highest SACKed sequence. Correspondingly, we can simplify the code a little now that tcp_shifted_skb() should update the lost_cnt_hint in all cases where skb == tp->lost_skb_hint. Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19sfc: Fix assignment of ip_summed for pre-allocated skbsBen Hutchings
[ Upstream commit ff3bc1e7527504a93710535611b2f812f3bb89bf ] When pre-allocating skbs for received packets, we set ip_summed = CHECKSUM_UNNCESSARY. We used to change it back to CHECKSUM_NONE when the received packet had an incorrect checksum or unhandled protocol. Commit bc8acf2c8c3e43fcc192762a9f964b3e9a17748b ('drivers/net: avoid some skb->ip_summed initializations') mistakenly replaced the latter assignment with a DEBUG-only assertion that ip_summed == CHECKSUM_NONE. This assertion is always false, but it seems no-one has exercised this code path in a DEBUG build. Fix this by moving our assignment of CHECKSUM_UNNECESSARY into efx_rx_packet_gro(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19ppp: fix 'ppp_mp_reconstruct bad seq' errorsBen McKeegan
[ Upstream commit 8a49ad6e89feb5015e77ce6efeb2678947117e20 ] This patch fixes a (mostly cosmetic) bug introduced by the patch 'ppp: Use SKB queue abstraction interfaces in fragment processing' found here: http://www.spinics.net/lists/netdev/msg153312.html The above patch rewrote and moved the code responsible for cleaning up discarded fragments but the new code does not catch every case where this is necessary. This results in some discarded fragments remaining in the queue, and triggering a 'bad seq' error on the subsequent call to ppp_mp_reconstruct. Fragments are discarded whenever other fragments of the same frame have been lost. This can generate a lot of unwanted and misleading log messages. This patch also adds additional detail to the debug logging to make it clearer which fragments were lost and which other fragments were discarded as a result of losses. (Run pppd with 'kdebug 1' option to enable debug logging.) Signed-off-by: Ben McKeegan <ben@netservers.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19ipsec: be careful of non existing mac headersEric Dumazet
[ Upstream commit 03606895cd98c0a628b17324fd7b5ff15db7e3cd ] Niccolo Belli reported ipsec crashes in case we handle a frame without mac header (atm in his case) Before copying mac header, better make sure it is present. Bugzilla reference: https://bugzilla.kernel.org/show_bug.cgi?id=42809 Reported-by: Niccolò Belli <darkbasic@linuxsystems.it> Tested-by: Niccolò Belli <darkbasic@linuxsystems.it> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19neighbour: Fixed race condition at tbl->nhtMichel Machado
[ Upstream commit 84338a6c9dbb6ff3de4749864020f8f25d86fc81 ] When the fixed race condition happens: 1. While function neigh_periodic_work scans the neighbor hash table pointed by field tbl->nht, it unlocks and locks tbl->lock between buckets in order to call cond_resched. 2. Assume that function neigh_periodic_work calls cond_resched, that is, the lock tbl->lock is available, and function neigh_hash_grow runs. 3. Once function neigh_hash_grow finishes, and RCU calls neigh_hash_free_rcu, the original struct neigh_hash_table that function neigh_periodic_work was using doesn't exist anymore. 4. Once back at neigh_periodic_work, whenever the old struct neigh_hash_table is accessed, things can go badly. Signed-off-by: Michel Machado <michel@digirati.com.br> CC: "David S. Miller" <davem@davemloft.net> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19atl1c: dont use highprio tx queueEric Dumazet
[ Upstream commit 11aad99af6ef629ff3b05d1c9f0936589b204316 ] This driver attempts to use two TX rings but lacks proper support : 1) IRQ handler only takes care of TX completion on first TX ring 2) the stop/start logic uses the legacy functions (for non multiqueue drivers) This means all packets witk skb mark set to 1 are sent through high queue but are never cleaned and queue eventualy fills and block the device, triggering the infamous "NETDEV WATCHDOG" message. Lets use a single TX ring to fix the problem, this driver is not a real multiqueue one yet. Minimal fix for stable kernels. Reported-by: Thomas Meyer <thomas@m3y3r.de> Tested-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: No wifi rfkill on Lenovo machinesIke Panhc
commit 461e74377cfcfc2c0d6bbdfa8fc5fbc21b052c2a upstream. We have several reports which says acer-wmi is loaded on ideapads and register rfkill for wifi which can not be unblocked. Since ideapad-laptop also register rfkill for wifi and it works reliably, it will be fine acer-wmi is not going to register rfkill for wifi once VPC2004 is found. Also put IBM0068/LEN0068 in the list. Though thinkpad_acpi has no wifi rfkill capability, there are reports which says acer-wmi also block wireless on Thinkpad E520/E420. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19vfs: fix double put after complete_walk()Miklos Szeredi
commit 097b180ca09b581ef0dc24fbcfc1b227de3875df upstream. complete_walk() already puts nd->path, no need to do it again at cleanup time. This would result in Oopses if triggered, apparently the codepath is not too well exercised. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19vfs: fix return value from do_last()Miklos Szeredi
commit 7f6c7e62fcc123e6bd9206da99a2163fe3facc31 upstream. complete_walk() returns either ECHILD or ESTALE. do_last() turns this into ECHILD unconditionally. If not in RCU mode, this error will reach userspace which is complete nonsense. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19CIFS: Do not kmalloc under the flocks spinlockPavel Shilovsky
commit d5751469f210d2149cc2159ffff66cbeef6da3f2 upstream. Reorganize the code to make the memory already allocated before spinlock'ed loop. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19perf/x86: Fix local vs remote memory events for NHM/WSMPeter Zijlstra
commit 87e24f4b67e68d9fd8df16e0bf9c66d1ad2a2533 upstream. Verified using the below proglet.. before: [root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 0 remote write Performance counter stats for './numa 0': 2,101,554 node-stores 2,096,931 node-store-misses 5.021546079 seconds time elapsed [root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 1 local write Performance counter stats for './numa 1': 501,137 node-stores 199 node-store-misses 5.124451068 seconds time elapsed After: [root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 0 remote write Performance counter stats for './numa 0': 2,107,516 node-stores 2,097,187 node-store-misses 5.012755149 seconds time elapsed [root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 1 local write Performance counter stats for './numa 1': 2,063,355 node-stores 165 node-store-misses 5.082091494 seconds time elapsed #define _GNU_SOURCE #include <sched.h> #include <stdio.h> #include <errno.h> #include <sys/mman.h> #include <sys/types.h> #include <dirent.h> #include <signal.h> #include <unistd.h> #include <numaif.h> #include <stdlib.h> #define SIZE (32*1024*1024) volatile int done; void sig_done(int sig) { done = 1; } int main(int argc, char **argv) { cpu_set_t *mask, *mask2; size_t size; int i, err, t; int nrcpus = 1024; char *mem; unsigned long nodemask = 0x01; /* node 0 */ DIR *node; struct dirent *de; int read = 0; int local = 0; if (argc < 2) { printf("usage: %s [0-3]\n", argv[0]); printf(" bit0 - local/remote\n"); printf(" bit1 - read/write\n"); exit(0); } switch (atoi(argv[1])) { case 0: printf("remote write\n"); break; case 1: printf("local write\n"); local = 1; break; case 2: printf("remote read\n"); read = 1; break; case 3: printf("local read\n"); local = 1; read = 1; break; } mask = CPU_ALLOC(nrcpus); size = CPU_ALLOC_SIZE(nrcpus); CPU_ZERO_S(size, mask); node = opendir("/sys/devices/system/node/node0/"); if (!node) perror("opendir"); while ((de = readdir(node))) { int cpu; if (sscanf(de->d_name, "cpu%d", &cpu) == 1) CPU_SET_S(cpu, size, mask); } closedir(node); mask2 = CPU_ALLOC(nrcpus); CPU_ZERO_S(size, mask2); for (i = 0; i < size; i++) CPU_SET_S(i, size, mask2); CPU_XOR_S(size, mask2, mask2, mask); // invert if (!local) mask = mask2; err = sched_setaffinity(0, size, mask); if (err) perror("sched_setaffinity"); mem = mmap(0, SIZE, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0); err = mbind(mem, SIZE, MPOL_BIND, &nodemask, 8*sizeof(nodemask), MPOL_MF_MOVE); if (err) perror("mbind"); signal(SIGALRM, sig_done); alarm(5); if (!read) { while (!done) { for (i = 0; i < SIZE; i++) mem[i] = 0x01; } } else { while (!done) { for (i = 0; i < SIZE; i++) t += *(volatile char *)(mem + i); } } return 0; } Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-tq73sxus35xmqpojf7ootxgs@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19rt2x00: fix random stallsStanislaw Gruszka
commit 3780d038fdf4b5ef26ead10b0604ab1f46dd9510 upstream. Is possible that we stop queue and then do not wake up it again, especially when packets are transmitted fast. That can be easily reproduced with modified tx queue entry_num to some small value e.g. 16. If mac80211 already hold local->queue_stop_reason_lock, then we can wait on that lock in both rt2x00queue_pause_queue() and rt2x00queue_unpause_queue(). After drooping ->queue_stop_reason_lock is possible that __ieee80211_wake_queue() will be performed before __ieee80211_stop_queue(), hence we stop queue and newer wake up it again. Another race condition is possible when between rt2x00queue_threshold() check and rt2x00queue_pause_queue() we will process all pending tx buffers on different cpu. This might happen if for example interrupt will be triggered on cpu performing rt2x00mac_tx(). To prevent race conditions serialize pause/unpause by queue->tx_lock. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19omap3isp: ccdc: Fix crash in HS/VS interrupt handlerLaurent Pinchart
commit bd0f2e6da7ea9e225cb2dbd3229e25584b0e9538 upstream. The HS/VS interrupt handler needs to access the pipeline object. It erronously tries to get it from the CCDC output video node, which isn't necessarily included in the pipeline. This leads to a NULL pointer dereference. Fix the bug by getting the pipeline object from the CCDC subdev entity. Reported-by: Gary Thomas <gary@mlbassoc.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19PCI: ignore pre-1.1 ASPM quirking when ASPM is disabledMatthew Garrett
commit 4949be16822e92a18ea0cc1616319926628092ee upstream. Right now we won't touch ASPM state if ASPM is disabled, except in the case where we find a device that appears to be too old to reliably support ASPM. Right now we'll clear it in that case, which is almost certainly the wrong thing to do. The easiest way around this is just to disable the blacklisting when ASPM is disabled. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19x86: Derandom delay_tsc for 64 bitThomas Gleixner
commit a7f4255f906f60f72e00aad2fb000939449ff32e upstream. Commit f0fbf0abc093 ("x86: integrate delay functions") converted delay_tsc() into a random delay generator for 64 bit. The reason is that it merged the mostly identical versions of delay_32.c and delay_64.c. Though the subtle difference of the result was: static void delay_tsc(unsigned long loops) { - unsigned bclock, now; + unsigned long bclock, now; Now the function uses rdtscl() which returns the lower 32bit of the TSC. On 32bit that's not problematic as unsigned long is 32bit. On 64 bit this fails when the lower 32bit are close to wrap around when bclock is read, because the following check if ((now - bclock) >= loops) break; evaluated to true on 64bit for e.g. bclock = 0xffffffff and now = 0 because the unsigned long (now - bclock) of these values results in 0xffffffff00000001 which is definitely larger than the loops value. That explains Tvortkos observation: "Because I am seeing udelay(500) (_occasionally_) being short, and that by delaying for some duration between 0us (yep) and 491us." Make those variables explicitely u32 again, so this works for both 32 and 64 bit. Reported-by: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19aio: fix the "too late munmap()" raceAl Viro
commit c7b285550544c22bc005ec20978472c9ac7138c6 upstream. Current code has put_ioctx() called asynchronously from aio_fput_routine(); that's done *after* we have killed the request that used to pin ioctx, so there's nothing to stop io_destroy() waiting in wait_for_all_aios() from progressing. As the result, we can end up with async call of put_ioctx() being the last one and possibly happening during exit_mmap() or elf_core_dump(), neither of which expects stray munmap() being done to them... We do need to prevent _freeing_ ioctx until aio_fput_routine() is done with that, but that's all we care about - neither io_destroy() nor exit_aio() will progress past wait_for_all_aios() until aio_fput_routine() does really_put_req(), so the ioctx teardown won't be done until then and we don't care about the contents of ioctx past that point. Since actual freeing of these suckers is RCU-delayed, we don't need to bump ioctx refcount when request goes into list for async removal. All we need is rcu_read_lock held just over the ->ctx_lock-protected area in aio_fput_routine(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19aio: fix io_setup/io_destroy raceAl Viro
commit 86b62a2cb4fc09037bbce2959d2992962396fd7f upstream. Have ioctx_alloc() return an extra reference, so that caller would drop it on success and not bother with re-grabbing it on failure exit. The current code is obviously broken - io_destroy() from another thread that managed to guess the address io_setup() would've returned would free ioctx right under us; gets especially interesting if aio_context_t * we pass to io_setup() points to PROT_READ mapping, so put_user() fails and we end up doing io_destroy() on kioctx another thread has just got freed... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19ALSA: hda/realtek - Apply the coef-setup only to ALC269VBKailang Yang
commit 526af6eb4dc71302f59806e2ccac7793963a7fe0 upstream. The coef setup in alc269_fill_coef() was designed only for ALC269VB model, and this has some bad effects for other ALC269 variants, such as turning off the external mic input. Apply it only to ALC269VB. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
