2006-10-25[SCSI] tmscsim: set max_sectorsGuennadi Liakhovetski
AM53C974A's Start Transfer Counter register has 24 bits, thus maximum transfer length is 16MiB. But the maximum I can test is 8MiB, so use that until somebody tests 16MiB. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] st: Fixup -ENOMEDIUMKai Makisara
Based on the original patch from Hannes Reinecke <hare@suse.de> Fix st_open() to return -ENOMEDIUM instead of -EIO if no medium is found. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] Scsi_Cmnd conversion in qlogicfas408 driverHenne
Change obsolete Scsi_Cmnd to struct scsi_cmnd in the Qlocic FAS408 driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] Scsi_Cmnd convertion in sun3-driverHenne
Change the obsolete Scsi_Cmnd to struct scsi_cmnd in the sun3-driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-10ACPI: Allow setting SCI_EN bit in PM1_CONTROL registerLinus Torvalds
This is needed by at least the Mac Mini's, which (incorrectly) come back from suspend with SCI_EN clear. Thanks to Frédéric Riss for hunting this down. Acked-by: Frédéric Riss <frederic.riss@gmail.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <len.brown@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] firmware/dcdbas: fix bug in error cleanupJeff Garzik
The error path path mistakenly called sysfs_create_group() rather than sysfs_remove_group(). They take the same arguments, so it's easy to cut-n-paste such a bug. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] irda: donauboe fixes, cleanupsJeff Garzik
- fix: toshoboe_invalid_dev() was recently removed, but not all callers were updated, causing the obvious linker error. Remove caller, because the check (like the one removed) isn't used. - fix: propagate request_irq() return value - cleanup: remove void* casts - cleanup: remove impossible ASSERTs Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix windfarm platform device usage [POWERPC] Fix i2c-powermac platform device usage [POWERPC] Fix secondary CPU startup on old "powersurge" SMP powermacs [POWERPC] ARCH=ppc pt_regs fixes [POWERPC] Update maple defconfig [POWERPC] Fix Maple secondary IDE interrupt [POWERPC] Make U4 PCIe work on maple [POWERPC] cell: fix default zImage build target [POWERPC] Fix boot wrapper invocation if CROSS_COMPILE contains spaces [POWERPC] Fix xmon IRQ handler for pt_regs removal
2006-10-10[PATCH] endianness annotations in s2ioAl Viro
2006-10-10[PATCH] ufs endianness annotationsAl Viro
2006-10-10[PATCH] fs/partitions endianness annotationsAl Viro
2006-10-10[PATCH] Finish annotations of struct vlan_ethhdrAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] isofs endianness annotationsAl Viro
2006-10-10[PATCH] smbfs endianness annotationsAl Viro
2006-10-10[PATCH] hpfs endianness annotationsAl Viro
2006-10-10[PATCH] fs/fat endianness annotationsAl Viro
2006-10-10[PATCH] befs: endianness annotationsAl Viro
split the data structures that exist in host- and disk-endian variants, annotate the fields of disk-endian ones, propagate changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] befs: missing fs32_to_cpu() in debug.cAl Viro
inode->mode is disk-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] befs: introduce on-disk endian typesAl Viro
2006-10-10[PATCH] befs: prepare to sanitizing headersAl Viro
pulled includes of endian.h from fs/befs/*.c to befs.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] befs: remove bogus typedefAl Viro
2006-10-10[PATCH] chelsio: add endian annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] serpent: fix endian warningsAlexey Dobriyan
2006-10-10[PATCH] cdrom: add endianness annotationsAlexey Dobriyan
2006-10-10[PATCH] use %p for pointersAl Viro
2006-10-10[PATCH] use %zu for size_tAl Viro
2006-10-10[PATCH] missed const in prototypeAl Viro
2006-10-10[PATCH] net/sunrpc/auth_gss/svcauth_gss.c endianness regressionAl Viro
2006-10-10[PATCH] strndup() would better take size_t, not intAl Viro
2006-10-10[PATCH] ptrdiff_t is %t, not %zAl Viro
2006-10-10[PATCH] cpuset ANSI prototypeAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] fs/inode.c NULL noise removalAl Viro
2006-10-10[PATCH] em28xx NULL noise removalAl Viro
2006-10-10[PATCH] __user annotations: loop.cAl Viro
2006-10-10[PATCH] openprom NULL noise removalAl Viro
2006-10-10[PATCH] trivial iomem annotations: sata_promiseAl Viro
2006-10-10[PATCH] gfp annotations: radix_tree_rootAl Viro
struct radix_tree_root has unused upper bits of ->gfp_mask reused for tags bitmap. Annotated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] gfp annotations: scsi_errorAl Viro
2006-10-10[PATCH] ptrace32 trivial __user annotationsAl Viro
2006-10-10[PATCH] trivial iomem annotations: istallionAl Viro
2006-10-10[PATCH] acpi NULL noise removalAl Viro
2006-10-10[PATCH] passing pointer to setup_timer() should be via unsigned longAl Viro
2006-10-10[PATCH] make kernel/relay.c __user-cleanAl Viro
2006-10-10[PATCH] fix misannotation in ioc4.hAl Viro
2006-10-10[PATCH] mtd: remove several bogus casts to void * in iounmap() argumentAl Viro
2006-10-10[PATCH] ia64/sn __iomem annotationsAl Viro
2006-10-10[PATCH] ia64/hp NULL noise removalAl Viro
2006-10-10[PATCH] __user annotations: futexAl Viro
2006-10-10[PATCH] tipc __user annotationsAl Viro
2006-10-10[PATCH] drivers/dma trivial annotationsAl Viro
