2010-12-06tg3: Update version to 3.116Matt Carlson
This patch updates the tg3 version to 3.116. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06tg3: Relax EEE thresholdsMatt Carlson
The hardware defaults to fairly aggressive EEE thresholds. While there appear to be no ill effects, this patch relaxes them, just as a precaution. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06tg3: Minor EEE code tweaksMatt Carlson
The first hunk of this patch makes sure that the driver checks for the appropriate preconditions before checking if EEE negotiation succeeded. More specifically the link needs to be full duplex for EEE to be enabled. The second and third hunks of this patch fix a bug where the eee advertisement register would be programmed with extra bits set. The fourth hunk of this patch makes sure the EEE capability flag is not set for 5718 A0 devices and that the device is not a serdes device. None of these modifications are strictly necessary. The driver / hardware still does the right thing. They are submitted primarily for correctness. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06tg3: Fix 57765 EEE supportMatt Carlson
EEE support in the 57765 internal phy will not enable after a phy reset unless it sees that EEE is supported in the MAC. This patch moves the code that programs the CPMU EEE registers to a place before the phy reset. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06tg3: Move EEE definitions into mdio.hMatt Carlson
In commit 52b02d04c801fff51ca49ad033210846d1713253 entitled "tg3: Add EEE support", Ben Hutchings had commented that the EEE advertisement register will be in a standard location. This patch moves that definition into mdio.h and changes the code to use it. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06tg3: Raise the jumbo frame BD flag thresholdMatt Carlson
The current transmit routines set the jumbo frame BD flag too aggressively. This can reduce performance for common cases. This patch raises the jumbo flag threshold to 1518, up from 1500. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03net: don't reallocate skb->head unless the current one hasn't the needed ↵Changli Gao
extra size or is shared skb head being allocated by kmalloc(), it might be larger than what actually requested because of discrete kmem caches sizes. Before reallocating a new skb head, check if the current one has the needed extra size. Do this check only if skb head is not shared. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03ixgbe: add support for new format of PBA numbersDon Skidmore
The new PBA format is stored as a string. This patch allows the driver to support both the old and new format. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03ixgbe: add support for 82599 FCoE SKUDon Skidmore
Add both NIC and backplane support for FCoE enabled devices IDs. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03ixgbe: add WOL support for SFP+ subdeviceDon Skidmore
This patch will add wake on LAN support to the dev/sub_dev 10FB 11A9. This will also include ixgbe ethtool support for this device. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03ixgbe: fix link behavior for SFP+ when driver is brought downDon Skidmore
We have had several requests to have ifconfig down command disable the SFP+ laser and thus make link go down. Likewise on ifconfig up the laser would be enabled and link would come up. This patch enables that behavior. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03qlcnic: Updated driver version to 5.0.13Anirban Chakraborty
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03qlcnic: LICENSE file for qlcnicSritej Velaga
Signed-off-by: Sritej Velaga <sritej.velaga@qlogic.com> Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03qlcnic: validate eswitch config values for PFAmit Kumar Salecha
Currently driver set default eswitch configuration values for PF function, instead of validating values sent by application. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03qlcnic: Disable loopback supportSucheta Chakraborty
Loopback mode can not be supported in CNA mode. Removing it until FW is fixed. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Store MAC address from NVRAM in net_device::perm_addrBen Hutchings
For some reason we failed to make this change when perm_addr was introduced. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Use current MAC address, not NVRAM MAC address, for WoL filterBen Hutchings
2010-12-03sfc: When waking a stopped tx_queue, only lock that tx_queueSteve Hodgson
2010-12-03sfc: Update kernel-doc to match earlier move of Toeplitz hash keyBen Hutchings
2010-12-03sfc: Move xmac_poll_required into struct falcon_nic_dataBen Hutchings
2010-12-03sfc: Move Falcon global event handling to falcon.cBen Hutchings
2010-12-03sfc: Move mdio_lock to struct falcon_nic_dataBen Hutchings
We only have direct access to MDIO on Falcon, so move this out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Move SPI state to struct falcon_nic_dataBen Hutchings
We only have direct access to SPI on Falcon, so move all this state out of struct efx_nic. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Remove unnecessary inclusion of various private header filesBen Hutchings
2010-12-03sfc: Expose Falcon BootROM config through MTD, not ethtoolBen Hutchings
The ethtool EEPROM interface is really meant for exposing chip configuration, not BootROM configuration. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Remove broken automatic fallback for invalid Falcon chip/board configBen Hutchings
If the Falcon board config is invalid, we cannot proceed - we do not have a valid board type to pass to falcon_probe_board(), and if we kluge that to work with an unknown board then other initialisation code will crash. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Fix event based MCDI completion and MC REBOOT/CMDDONE ordering issueSteve Hodgson
The mcfw *never* sends CMDDONE when rebooting. Changing this so that it always sends CMDDONE *before* REBOOT is easy on Siena, but it's not obvious that we could guarantee to be able to implement this on future hardware. Given this, I'm less convinced that the protocol should be changed. To reiterate the failure mode: The driver sees this: issue command receive REBOOT event Was that reboot event sent before the command was issued, or in response to the command? If the former then there will be a subsequent CMDDONE event, if the latter, then there will be no CMDDONE event. Options to resolve this are: 1. REBOOT always completes an outstanding mcdi request, and we set the credits count to ignore a subsequent CMDDONE event with mismatching seqno. 2. REBOOT never completes an outstanding mcdi request. If there is no CMDDONE event then we rely on the mcdi timeout code to complete the outstanding request, incurring a 10s delay. I'd argue that (2) is tidier, but that incurring a 10s delay is a little needless. Let's go with (1). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Clear RXIN_SEL when soft-resetting QT2025CBen Hutchings
When we enable PMA/PMD loopback this automatically sets RXIN_SEL (inverse polarity for RXIN). We need to clear that bit during the soft-reset sequence, as it is not done automatically. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Read-to-clear LM87 alarm/interrupt status at start of dayBen Hutchings
We do not want to shut down the board based on a fault that has already been cleared. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Distinguish critical and non-critical over-temperature conditionsBen Hutchings
Set both the 'maximum' and critical temperature limits for LM87 hardware monitors on Falcon boards. Do not shut down a port until the critical temperature is reached, but warn as soon as the 'maximum' temperature is reached. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-03sfc: Fix condition for no-op in set_phy_flash_cfg()Ben Hutchings
2010-12-03sfc: Reduce log level for MCDI error response in efx_mcdi_rpc()Ben Hutchings
Some errors are expected, e.g. when sending new commands to an MC running old firmware. Only the caller of efx_mcdi_rpc() can decide what is a real error. Therefore log the error responses with netif_dbg(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete tipc_ownidentity()Allan Stephens
Moves the content of the native API routine tipc_ownidentity() into the sole routine that calls it, since it can no longer be called in isolation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate obsolete native API forwarding routinesAllan Stephens
Moves the content of each native API message forwarding routine into the sole routine that calls it, since the forwarding routines no longer be called in isolation. Also removes code in each routine that altered the outgoing message's importance level since this is now no longer possible. The previous function mapping (parent function, and child API) was as follows: tipc_send2name \--tipc_forward2name tipc_send2port \--tipc_forward2port tipc_send_buf2port \--tipc_forward_buf2port After this commit, the children don't exist and their functionality is completely in the respective parent. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate an unused symbolic constant in link codeAllan Stephens
Removes a symbol that is not referenced anywhere by TIPC's link code. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate useless initialization when creating subscriberAllan Stephens
Removes initialization of a local variable that is always assigned a different value before it is referenced. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove unused domain argument from multicast send routineAllan Stephens
Eliminates an unused argument from tipc_multicast(), now that this routine can no longer be called by kernel-based applications. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove support for TIPC mode change callbackAllan Stephens
Eliminates support for the callback routine invoked when TIPC changes its mode of operation from inactive to standalone or from standalone to networked. This callback was part of TIPC's obsolete native API and is not used by TIPC internally. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete useless function prototypesAllan Stephens
Removes several function declarations that aren't used anywhere, either because they reference routines that no longer exist or because all users of the function reference it after it has already been defined. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Eliminate useless return value when disabling a bearerAllan Stephens
Modifies bearer_disable() to return void since it always indicates success anyway. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Delete unused configuration service structure definitionAllan Stephens
Removes a structure definition that is no longer used by TIPC's configuration service. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete inclusions of header filesAllan Stephens
Gets rid of #include statements that are no longer required as a result of the merging of obsolete native API header file content into other TIPC include files. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tipc: Remove obsolete native API files and exportsAllan Stephens
As part of the removal of TIPC's native API support it is no longer necessary for TIPC to export symbols for routines that can be called by kernel-based applications, nor for it to have header files that kernel-based applications can include to access the declarations for those routines. This commit eliminates the exporting of symbols by TIPC and migrates the contents of each obsolete native API include file into its corresponding non-native API equivalent. The code which was migrated in this commit was migrated intact, in that there are no technical changes combined with the relocation. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: kill unused macros from head fileShan Wei
These macros have been defined for several years since v2.6.12-rc2(tracing by git), but never be used. So remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02ipv6: use ND_REACHABLE_TIME and ND_RETRANS_TIMER instead of magic numberShan Wei
ND_REACHABLE_TIME and ND_RETRANS_TIMER have defined since v2.6.12-rc2, but never been used. So use them instead of magic number. This patch also changes original code style to read comfortably . Thank YOSHIFUJI Hideaki for pointing it out. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02tcp: use TCP_BASE_MSS to set basic mss valueShan Wei
TCP_BASE_MSS is defined, but not used. commit 5d424d5a introduce this macro, so use it to initial sysctl_tcp_base_mss. commit 5d424d5a674f782d0659a3b66d951f412901faee Author: John Heffner <jheffner@psc.edu> Date: Mon Mar 20 17:53:41 2006 -0800 [TCP]: MTU probing Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: snmp: fix the wrong ICMP_MIB_MAX valueShan Wei
__ICMP_MIB_MAX is equal to the total number of icmp mib, So no need to add 1. This wastes 4/8 bytes memory. Change it to be same as ICMP6_MIB_MAX, TCP_MIB_MAX, UDP_MIB_MAX. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02can: EG20T PCH: Delete unnecessary spin_lockTomoya
Delete unnecessary spin_lock for accessing Message Object. Since all message objects are divided into tx/rx area completely, spin_lock processing is unnecessary. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02can: EG20T PCH: Enumerate LEC macrosTomoya
For easy to readable, LEC #define macros are replaced to enums. Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02can: EG20T PCH: Change Message Object IndexTomoya
For easy to readable, add Message Object index like below. PCH_RX_OBJ_START PCH_RX_OBJ_END PCH_TX_OBJ_START PCH_TX_OBJ_END Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
