2008-05-24Merge branch 'x86-fixes-for-linus' of ↵tip-auto-x86-next-base-2008-05-26_08_52_Montip-auto-sched-next-base-2008-05-26_08_52_Montip-auto-latest-base-2008-05-26_08_52_Montip-auto-ftrace-next-base-2008-05-26_08_52_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: prevent PGE flush from interruption/preemption x86: use explicit copy in vdso_gettimeofday() namespacecheck: automated fixes x86/xen: fix arbitrary_virt_to_machine() x86: don't read maxlvt before checking if APIC is mapped x86: disable TSC for sched_clock() when calibration failed x86: distangle user disabled TSC from unstable x86: fix setup of cyc2ns in tsc_64.c
2008-05-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] integrator: fix build warnings and errors [ARM] fix OMAP include loops Revert "[ARM] pxa: spitz wants PXA27x UDC definitions" [ARM] 5053/1: define before use of processor_id [ARM] 5052/1: export clock functions for the at91x40 [ARM] 5051/1: define pgtable_t for the !CONFIG_MMU case too [ARM] omap: fix omap clk support build errors [ARM] 5039/1: S3C244X: Rename SDI device if running on S3C244X. [ARM] 5043/1: pxafb: remove unused mode variable in pxafb_init_fbinfo [ARM] 5041/1: VR1000: Fix DM9000 IRQ flags initialisation [ARM] 5040/1: BAST: Fix DM9000 IRQ flags initialisation [ARM] 5038/1: ARM: OMAP: Remove tsc2102 references from board-palmte.c [ARM] 5025/2: fix collie cpu initialisation
2008-05-24spi: remove some spidev oops-on-rmmod pathsDavid Brownell
Somehow the spidev code forgot to include a critical mechanism: when the underlying device is removed (e.g. spi_master rmmod), open file descriptors must be prevented from issuing new I/O requests to that device. On penalty of the oopsing reported by Sebastian Siewior <bigeasy@tglx.de> ... This is a partial fix, adding handshaking between the lower level (SPI messaging) and the file operations using the spi_dev. (It also fixes an issue where reads and writes didn't return the number of bytes sent or received.) There's still a refcounting issue to be addressed (separately). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Reported-by: Sebastian Siewior <bigeasy@tglx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24cgroups: remove node_ prefix_from ns subsystemCedric Le Goater
This is a slight change in the namespace cgroup subsystem api. The change is that previously when cgroup_clone() was called (currently only from the unshare path in ns_proxy cgroup, you'd get a new group named "node_$pid" whereas now you'll get a group named after just your pid.) The only users who would notice it are those who are using the ns_proxy cgroup subsystem to auto-create cgroups when namespaces are unshared - something of an experimental feature, which I think really needs more complete container/namespace support in order to be useful. I suspect the only users are Cedric and Serge, or maybe a few others on containers@lists.linux-foundation.org. And in fact it would only be noticed by the users who make the assumption about how the name is generated, rather than getting it from the /proc/<pid>/cgroups file for the process in question. Whether the change is actually needed or not I'm fairly agnostic on, but I guess it is more elegant to just use the pid as the new group name rather than adding a fairly arbitrary "node_" prefix on the front. [menage@google.com: provided changelog] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: "Paul Menage" <menage@google.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24for_each_online_pgdat(): kerneldoc fixFernando Luis Vazquez Cao
for_each_pgdat() was renamed to for_each_online_pgdat() and kerneldoc comments should be updated accordingly. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24frv: export empty_zero_pageAdrian Bunk
Fix the following build error: ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24sys_prctl(): fix return of uninitialized valueShi Weihua
If none of the switch cases match, the PR_SET_PDEATHSIG and PR_SET_DUMPABLE cases of the switch statement will never write to local variable `error'. Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Cc: Andrew G. Morgan <morgan@kernel.org> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24edac: mpc85xx: fix building as a moduleKumar Gala
including of <asm/mpc85xx.h> causes build problems since it doesn't exist. Also removed warning: drivers/edac/mpc85xx_edac.c:45: warning: 'mpc85xx_ctl_name' defined but not used Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: build fixesDavid Brownell
This fixes various gpio-related build errors (mostly potential) reported in part by Russell King and Uwe Kleine-König. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: fix driver MODULE_ALIAS()Ben Dooks
Add a correct MODULE_ALIAS() entry for this driver to enable udev module loading. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: clean out changelog header and tidyBen Dooks
Remove the old changelog entries which are now out of date and should be extractable from git anyway. Also tidy up the copyright for the driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: add error print if we cannot add attributeBen Dooks
Fix the following warning by checking the result of device_create_file and printing an error but not removing the device (loss of debug registers is not fatal). drivers/video/s3c2410fb.c:905: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: ensure that FB_BLANK_POWERDOWN shuts down the controllerBen Dooks
When a blank level of FB_BLANK_POWERDOWN is used, we should shut down the controller so that it no longer tries to produce any panel signals or data, and shuts down the DMA which is not needed. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24SM501: reverse FPEN/VBIASEN flags behaviourBen Dooks
To keep backwards compatibility, reverse the meanings of these flags so that when they are not set, the driver uses the original behvaiour. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24memory hotplug: fix early allocation handlingHeiko Carstens
Trying to add memory via add_memory() from within an initcall function results in bootmem alloc of 163840 bytes failed! Kernel panic - not syncing: Out of memory This is caused by zone_wait_table_init() which uses system_state to decide if it should use the bootmem allocator or not. When initcalls are handled the system_state is still SYSTEM_BOOTING but the bootmem allocator doesn't work anymore. So the allocation will fail. To fix this use slab_is_available() instead as indicator like we do it everywhere else. [akpm@linux-foundation.org: coding-style fix] Reviewed-by: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24zonelists: handle a node zonelist with no applicable entriesAndy Whitcroft
When booting 2.6.26-rc3 on a multi-node x86_32 numa system we are seeing panics when trying node local allocations: BUG: unable to handle kernel NULL pointer dereference at 0000034c IP: [<c1042507>] get_page_from_freelist+0x4a/0x18e *pdpt = 00000000013a7001 *pde = 0000000000000000 Oops: 0000 [#1] SMP Modules linked in: Pid: 0, comm: swapper Not tainted (2.6.26-rc3-00003-g5abc28d #82) EIP: 0060:[<c1042507>] EFLAGS: 00010282 CPU: 0 EIP is at get_page_from_freelist+0x4a/0x18e EAX: c1371ed8 EBX: 00000000 ECX: 00000000 EDX: 00000000 ESI: f7801180 EDI: 00000000 EBP: 00000000 ESP: c1371ec0 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c1370000 task=c12f5b40 task.ti=c1370000) Stack: 00000000 00000000 00000000 00000000 000612d0 000412d0 00000000 000412d0 f7801180 f7c0101c f7c01018 c10426e4 f7c01018 00000001 00000044 00000000 00000001 c12f5b40 00000001 00000010 00000000 000412d0 00000286 000412d0 Call Trace: [<c10426e4>] __alloc_pages_internal+0x99/0x378 [<c10429ca>] __alloc_pages+0x7/0x9 [<c105e0e8>] kmem_getpages+0x66/0xef [<c105ec55>] cache_grow+0x8f/0x123 [<c105f117>] ____cache_alloc_node+0xb9/0xe4 [<c105f427>] kmem_cache_alloc_node+0x92/0xd2 [<c122118c>] setup_cpu_cache+0xaf/0x177 [<c105e6ca>] kmem_cache_create+0x2c8/0x353 [<c13853af>] kmem_cache_init+0x1ce/0x3ad [<c13755c5>] start_kernel+0x178/0x1ee This occurs when we are scanning the zonelists looking for a ZONE_NORMAL page. In this system there is only ZONE_DMA and ZONE_NORMAL memory on node 0, all other nodes are mapped above 4GB physical. Here is a dump of the zonelists from this system: zonelists pgdat=c1400000 0: c14006c0:2 f7c006c0:2 f7e006c0:2 c1400360:1 c1400000:0 1: c14006c0:2 c1400360:1 c1400000:0 zonelists pgdat=f7c00000 0: f7c006c0:2 f7e006c0:2 c14006c0:2 c1400360:1 c1400000:0 1: f7c006c0:2 zonelists pgdat=f7e00000 0: f7e006c0:2 c14006c0:2 f7c006c0:2 c1400360:1 c1400000:0 1: f7e006c0:2 When performing a node local allocation we call get_page_from_freelist() looking for a page. It in turn calls first_zones_zonelist() which returns a preferred_zone. Where there are no applicable zones this will be NULL. However we use this unconditionally, leading to this panic. Where there are no applicable zones there is no possibility of a successful allocation, so simply fail the allocation. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: fix enable_irq_wake/disable_irq_wake imbalance in serial_core.cArjan van de Ven
enable_irq_wake() and disable_irq_wake() need to be balanced. However, serial_core.c calls these for different conditions during the suspend and resume functions... This is causing a regular WARN_ON() as found at http://www.kerneloops.org/search.php?search=set_irq_wake This patch makes the conditions for triggering the _wake enable/disable sequence identical. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24proc: proc_get_inode() should get module only onceDenis V. Lunev
Any file under /proc/net opened more than once leaked the refcounter on the module it belongs to. The problem is that module_get is called for each file opening while module_put is called only when /proc inode is destroyed. So, lets put module counter if we are dealing with already initialised inode. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10737 Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: David Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Acked-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Robert Olsson <robert.olsson@its.uu.se> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Roland Kletzing <devzero@web.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24brd: don't show ramdisks in /proc/partitionsMarcin Krol
In 2.6.25, ramdisk devices show up in /proc/partitions, which is a behaviour change from the old rd.c. Add GENHD_FL_SUPPRESS_PARTITION_INFO, which was present in rd.c. All kernels prior to 2.6.25 weren't displaying ramdisks in /proc/partitions. Since there are many userspace tools using information from /proc/partitions some of them may now behave incorrectly (I didn't tested any though). For example before 2.6.25 /proc/partitions was empty if no block devices like hard disks and such were detected by kernel. Now all 16 ramdisks are always visible there. Some software may rely on such information (I mean, on empty /proc/partitions). There was quite similar situation back in 2004, and ramdisks were excluded back from displaying. Thats why I called this a regression (maybe a bit unfortunate). See this patch for info: http://kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.3-rc2/2.6.3-rc2-mm1/broken-out/nbd-proc-partitions-fix.patch I also think that someone somewhere (long time ago) excluded ramdisks from /proc/partitions for good reasons. It is possible that now such new "feature" is harmless, but I think there are more chances that someone will say "hey, /proc/partitions has changed, now my software doesn't work" then "hey where did my new 2.6.25 feature go". nbd devices are also excluded, maybe for very same (unknown to me) reasons. Signed-off-by: Marcin Krol <hawk@pld-linux.org> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ip2: fix crashes on load/unloadAlan Cox
This doesn't need to be two modules, and making it one cleans up the problem Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpiolib: fix off by one errorsTrent Piepho
The last gpio belonging to a chip is chip->base + chip->ngpios - 1. Some places in the code, but not all, forgot the critical minus one. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: mcp23s08 debug fixRoel Kluin
The return value of mcp23s08_read_regs() can only be evaluated when signed Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: pca953x driver handles pca9554 tooDavid Brownell
Teach drivers/gpio/pca953x.c about PCA9554, another compatible chip. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24signals: fix sigqueue_free() vs __exit_signal() raceOleg Nesterov
__exit_signal() does flush_sigqueue(tsk->pending) outside of ->siglock. This can race with another thread doing sigqueue_free(), we can free the same SIGQUEUE_PREALLOC sigqueue twice or corrupt the pending->list. Note that even sys_exit_group() can trigger this race, not only sys_timer_delete(). Move the callsite of flush_sigqueue(tsk->pending) under ->siglock. This patch doesn't touch flush_sigqueue(->shared_pending) below, it is called when there are no other threads which can play with signals, and sigqueue_free() can't be used outside of our thread group. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: restart recovery cleanly after device failure.NeilBrown
When we get any IO error during a recovery (rebuilding a spare), we abort the recovery and restart it. For RAID6 (and multi-drive RAID1) it may not be best to restart at the beginning: when multiple failures can be tolerated, the recovery may be able to continue and re-doing all that has already been done doesn't make sense. We already have the infrastructure to record where a recovery is up to and restart from there, but it is not being used properly. This is because: - We sometimes abort with MD_RECOVERY_ERR rather than just MD_RECOVERY_INTR, which causes the recovery not be be checkpointed. - We remove spares and then re-added them which loses important state information. The distinction between MD_RECOVERY_ERR and MD_RECOVERY_INTR really isn't needed. If there is an error, the relevant drive will be marked as Faulty, and that is enough to ensure correct handling of the error. So we first remove MD_RECOVERY_ERR, changing some of the uses of it to MD_RECOVERY_INTR. Then we cause the attempt to remove a non-faulty device from an array to fail (unless recovery is impossible as the array is too degraded). Then when remove_and_add_spares attempts to remove the devices on which recovery can continue, it will fail, they will remain in place, and recovery will continue on them as desired. Issue: If we are halfway through rebuilding a spare and another drive fails, and a new spare is immediately available, do we want to: 1/ complete the current rebuild, then go back and rebuild the new spare or 2/ restart the rebuild from the start and rebuild both devices in parallel. Both options can be argued for. The code currently takes option 2 as a/ this requires least code change b/ this results in a minimally-degraded array in minimal time. Cc: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: allow parallel resync of md-devices.Bernd Schubert
In some configurations, a raid6 resync can be limited by CPU speed (Calculating P and Q and moving data) rather than by device speed. In these cases there is nothing to be gained byt serialising resync of arrays that share a device, and doing the resync in parallel can provide benefit. So add a sysfs tunable to flag an array as being allowed to resync in parallel with other arrays that use (a different part of) the same device. Signed-off-by: Bernd Schubert <bs@q-leap.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: notify userspace on 'stop' eventsDan Williams
This additional notification to 'array_state' is needed to allow the monitor application to learn about stop events via sysfs. The sysfs_notify("sync_action") call that comes at the end of do_md_stop() (via md_new_event) is insufficient since the 'sync_action' attribute has been removed by this point. (Seems like a sysfs-notify-on-removal patch is a better fix. Currently removal updates the event count but does not wake up waiters) Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: notify userspace on 'write-pending' changes to array_stateNeilBrown
When an array enters write pending, 'array_state' changes, so we must be sure to sysfs_notify. Also, when waiting for user-space to acknowledge 'write-pending' by marking the metadata as dirty, we don't want to wait for MD_CHANGE_DEVS to be cleared as that might not happen. So explicity test for the bits that we are really interested in. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: raid1: Fix restoration of bio between failed read and write.NeilBrown
When performing a "recovery" or "check" pass on a RAID1 array, we read from each device and possible, if there is a difference or a read error, write back to some devices. We use the same 'bio' for both read and write, resetting various fields between the two operations. We forgot to reset bv_offset and bv_len however. These are often left unchanged, but in the case where there is an IO error one or two sectors into a page, they are changed. This results in correctable errors not being corrected properly. It does not result in any data corruption. Cc: "Fairbanks, David" <David.Fairbanks@stratus.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: md: raid5 rate limit error printkBernd Schubert
Last night we had scsi problems and a hardware raid unit was offlined during heavy i/o. While this happened we got for about 3 minutes a huge number messages like these Apr 12 03:36:07 pfs1n14 kernel: [197510.696595] raid5:md7: read error not correctable (sector 2993096568 on sdj2). I guess the high error rate is responsible for not scheduling other events - during this time the system was not pingable and in the end also other devices run into scsi command timeouts causing problems on these unrelated devices as well. Signed-off-by: Bernd Schubert <bernd-schubert@gmx.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: kill file_path wrapperChristoph Hellwig
Kill the trivial and rather pointless file_path wrapper around d_path. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: proper extern for mdp_majorAdrian Bunk
This patch adds a proper extern for mdp_major in include/linux/raid/md.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24md: fix possible oops when removing a bitmap from an active arrayNeilBrown
It is possible to add a write-intent bitmap to an active array, or remove the bitmap that is there. When we do with the 'quiesce' the array, which causes make_request to block in "wait_barrier()". However we are sampling the value of "mddev->bitmap" before the wait_barrier call, and using it afterwards. This can result in using a bitmap structure that has been freed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: fix atomic_t overflow in vmAlan Cox
The atomic_t type is 32bit but a 64bit system can have more than 2^32 pages of virtual address space available. Without this we overflow on ludicrously large mappings Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24types.h: don't expose struct ustat to userspacemaximilian attems
<linux/types.h> can't be used together with <sys/ustat.h> because they both define struct ustat: $ cat test.c #include <sys/ustat.h> #include <linux/types.h> $ gcc -c test.c In file included from test.c:2: /usr/include/linux/types.h:165: error: redefinition of 'struct ustat' has been reported a while ago to debian, but seems to have been lost in cat fighting: http://bugs.debian.org/429064 Signed-off-by: maximilian attems <max@stro.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: support for InstaShield IS-400 four port RS-232 PCI cardIgnacio García Pérez
Add support for the InstaShield IS-400 four port RS-232 PCI card. Signed-off-by: Ignacio García Pérez <iggarpe@t2i.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fix parenthesis in include/asm-mips/mach-au1x00/au1000.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/mach-au1x00/au1000.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fix parenthesis in include/asm-mips/gic.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/gic.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ibmaem: new driver for power/energy/temp meters in IBM System X hardwareDarrick J. Wong
This driver reads IBM Active Energy Manager energy/temperature/power sensors on IBM System X hardware. [akpm@linux-foundation.org: fix printk warnings] Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24i5k_amb: support Intel 5400 chipsetDarrick J. Wong
Minor rework to support the Intel 5400 chipset. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24hdaps: invert the axes for HDAPS on Lenovo R61i ThinkPadsGabor Czigola
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jiri Kosina <jikos@jikos.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ntfs: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: don't drop a partial page in a zone's memory map sizeJohannes Weiner
In a zone's present pages number, account for all pages occupied by the memory map, including a partial. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24MAINTAINERS: add util-linux-ng packageKarel Zak
(akpm: we often deal with util-linux and I (at least) can never remember where they hang out). Signed-off-by: Karel Zak <kzak@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ecryptfs: fix missed mutex_unlockCyrill Gorcunov
Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24fuse: fix bdi naming conflictMiklos Szeredi
Fuse allocates a separate bdi for each filesystem, and registers them in sysfs with "MAJOR:MINOR" of sb->s_dev (st_dev). This works fine for anon devices normally used by fuse, but can conflict with an already registered BDI for "fuseblk" filesystems, where sb->s_dev represents a real block device. In particularl this happens if a non-partitioned device is being mounted. Fix by registering with a different name for "fuseblk" filesystems. Thanks to Ioan Ionita for the bug report. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Ioan Ionita <opslynx@gmail.com> Tested-by: Ioan Ionita <opslynx@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24mm: allow pfnmap ->fault()sNick Piggin
Take out an assertion to allow ->fault handlers to service PFNMAP regions. This is required to reimplement .nopfn handlers with .fault handlers and subsequently remove nopfn. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Jes Sorensen <jes@sgi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23[ARM] integrator: fix build warnings and errorsRussell King
Fix resource_size_t warning in impd1.c, and printascii() build errors in pci_v3.c Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/mad: Fix kernel crash when .process_mad() returns SUCCESS|CONSUMED IPoIB: Test for NULL broadcast object in ipiob_mcast_join_finish() MAINTAINERS: Add cxgb3 and iw_cxgb3 NIC and iWARP driver entries IB/mlx4: Fix creation of kernel QP with max number of send s/g entries IB/mthca: Fix max_sge value returned by query_device RDMA/cxgb3: Fix uninitialized variable warning in iwch_post_send() IB/mlx4: Fix uninitialized-var warning in mlx4_ib_post_send() IB/ipath: Fix UC receive completion opcode for RDMA WRITE with immediate IB/ipath: Fix printk format for ipath_sdma_status
2008-05-23IB/mad: Fix kernel crash when .process_mad() returns SUCCESS|CONSUMEDDave Olson
If a low-level driver returns IB_MAD_RESULT_SUCCESS | IB_MAD_RESULT_CONSUMED, handle_outgoing_dr_smp() doesn't clean up properly. The fix is to kfree the local data and break, rather than falling through. This was observed with the ipath driver, but could happen with any driver. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=1027>. Signed-off-by: Dave Olson <dave.olson@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
