2008-12-08Merge branches 'x86/signal' and 'x86/irq' into perfcounters/coreIngo Molnar
Merge these pending x86 tree changes into the perfcounters tree to avoid conflicts.
2008-12-08x86: signal: change type of paramter for sys_rt_sigreturn()Hiroshi Shimamoto
Impact: cleanup on 32-bit Peter pointed this parameter can be changed. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-05Fix a race condition in FASYNC handlingJonathan Corbet
Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync() functions without the BKL) introduced a race which could leave file->f_flags in a state inconsistent with what the underlying driver/filesystem believes. Revert that change, and also fix the same races in ioctl_fioasync() and ioctl_fionbio(). This is a minimal, short-term fix; the real fix will not involve the BKL. Reported-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Enforce a minimum SG_IO timeoutLinus Torvalds
There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Fix incorrect use of loose in vpe.c
2008-12-05drivers/message/i2o/iop.c: cleanup kerneldocQinghuang Feng
no argument named @msg in i2o_msg_get_wait(), remove it. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Fix incorrect use of loose in i2o_block.cNick Andrew
Fix incorrect use of loose in i2o_block.c It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Fix incorrect use of loose in tty/serial driversNick Andrew
[Folded together as one diff from 3] It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Revert "ACPI: battery: Convert discharge energy rate to current properly"Linus Torvalds
This reverts commit 558073dd56707864f09d563b64e7c37c021e89d2, along with the failed try to fix the regression it caused ("ACPI: Fix ACPI battery regression introduced by commit 558073"), which just made things worse. Commit aaad077638be1a25871bcae5e43952d6b63abfca (that failed "Fix ACPI battery regression") got the voltage conversion confused, and fixed the problem with Rafael's battery monitor apparently just by mistake. So revert them both, getting us back to the 2.6.27 state in this, and let's revisit it when people understand what's going on. Noted-by: Paul Martin <pm@debian.org> Requested-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <len.brown@intel.com> Cc: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05MIPS: Fix incorrect use of loose in vpe.cNick Andrew
It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: [PATCH] fix bogus argument of blkdev_put() in pktcdvd [PATCH 2/2] documnt FMODE_ constants [PATCH 1/2] kill FMODE_NDELAY_NOW [PATCH] clean up blkdev_get a little bit [PATCH] Fix block dev compat ioctl handling [PATCH] kill obsolete temporary comment in swsusp_close()
2008-12-04Merge branch 'drm-gem-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-gem-update' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: Return error in i915_gem_set_to_gtt_domain if we're not in the GTT. drm/i915: Retry execbuffer pinning after clearing the GTT drm/i915: Move the execbuffer domain computations together drm/i915: Rename object_set_domain to object_set_to_gpu_domain drm/i915: Make a single set-to-cpu-domain path and use it wherever needed. drm/i915: Make a single set-to-gtt-domain path. drm/i915: If interrupted while setting object domains, still emit the flush. drm/i915: Move flushing list cleanup from flush request retire to request emit. drm/i915: Respect GM965/GM45 bit-17-instead-of-bit-11 option for swizzling.
2008-12-04Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/galak/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/powerpc: powerpc/83xx: Enable FIXED_PHY in mpc834x_itx and mpc83xx defconfigs
2008-12-04ACPI: Fix ACPI battery regression introduced by commit 558073Rafael J. Wysocki
Commit 558073dd56707864f09d563b64e7c37c021e89d2 ("ACPI: battery: Convert discharge energy rate to current properly") caused the battery subsystem to report wrong values of the remaining time on battery power and the time until fully charged on Toshiba Portege R500 (and presumably on other boxes too). Fix the issue by correcting the conversion from mW to mA. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-04Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: time: catch xtime_nsec underflows and fix them posix-cpu-timers: fix clock_gettime with CLOCK_PROCESS_CPUTIME_ID
2008-12-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Sync FPU state in VIS emulation handler. sparc64: Fix VIS emulation bugs sparc: asm/bitops.h should define __fls sparc64: Fix bug in PTRACE_SETFPREGS64 handling.
2008-12-04Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: fix early panic with boot option "nosmp" x86/oprofile: fix Intel cpu family 6 detection oprofile: fix CPU unplug panic in ppro_stop() AMD IOMMU: fix possible race while accessing iommu->need_sync AMD IOMMU: set device table entry for aliased devices AMD IOMMU: struct amd_iommu remove padding on 64 bit x86: fix broken flushing in GART nofullflush path x86: fix dma_mapping_error for 32bit x86
2008-12-04Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: don't export sched_mc_power_savings in laptops
2008-12-04Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: check_hung_task(): unsigned sysctl_hung_task_warnings cannot be less than 0 documentation: local_ops fix on_each_cpu
2008-12-04Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Return ENOSYS from sys32_syscall on 64bit kernels like elsewhere. MIPS: 64-bit: vmsplice needs to use the compat wrapper for o32 and N32. MIPS: o32: Fix number of arguments to splice(2). MIPS: Malta: Consolidate platform device code. MIPS: IP22, Fulong, Malta: Update defconfigs. MIPS: Malta: Add back RTC support MIPS: Fix potential DOS by untrusted user app.
2008-12-04Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: [XFS] Fix hang after disallowed rename across directory quota domains
2008-12-05[XFS] Fix hang after disallowed rename across directory quota domainsDave Chinner
When project quota is active and is being used for directory tree quota control, we disallow rename outside the current directory tree. This requires a check to be made after all the inodes involved in the rename are locked. We fail to unlock the inodes correctly if we disallow the rename when the target is outside the current directory tree. This results in a hang on the next access to the inodes involved in failed rename. Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Dave Chinner <david@fromorbit.com> Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-12-04powerpc/83xx: Enable FIXED_PHY in mpc834x_itx and mpc83xx defconfigsAnton Vorontsov
This is needed so that Vitesse 7385 5-port switch could work on MPC8349E-mITX boards. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-04MIPS: Return ENOSYS from sys32_syscall on 64bit kernels like elsewhere.David Daney
When the o32 errno was changed to ENOSYS, we forgot to update the code for 64bit kernels. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: 64-bit: vmsplice needs to use the compat wrapper for o32 and N32.Ralf Baechle
2008-12-04MIPS: o32: Fix number of arguments to splice(2).Ralf Baechle
The syscall code was assuming splice only takes 4 arguments so no stack arguments were being copied from the userspace stack to the kernel stack. As the result splice was likely to fail with EINVAL. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: Malta: Consolidate platform device code.Ralf Baechle
After adding the RTC platform device to malta-platform.c malta-mtd.c should get unified with the rest of the platform device code.
2008-12-04MIPS: IP22, Fulong, Malta: Update defconfigs.Ralf Baechle
These haven't seen much attention for too long but particularly important enable RTC_CLASS and CONFIG_RTC_HCTOSYS so the wall clock time is set on kernel startup. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: Malta: Add back RTC supportTiejun Chen
With the conversion of MIPS to RTC_LIB the old RTC driver CONFIG_RTC became unselectable. Fix by setting up a platform device. Also enable RTC_CLASS so system time gets set from RTC on kernel initialization. [Ralf: Original patch by Tiejun; polished nice and shiny by me] Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: Fix potential DOS by untrusted user app.Vlad Malov
On a 64 bit kernel if an o32 syscall was made with a syscall number less than 4000, we would read the function from outside of the bounds of the syscall table. This led to non-deterministic behavior including system crashes. While we were at it we reworked the 32 bit version as well to use fewer instructions. Both 32 and 64 bit versions are use the same code now. Signed-off-by: Vlad Malov <Vlad.Malov@caviumnetworks.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04sparc64: Sync FPU state in VIS emulation handler.Hong H. Pham
Copy the FPU state to the task's thread_info->fpregs for the VIS emulation functions to access. Signed-off-by: Hong H. Pham <hong.pham@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04x86: fix early panic with boot option "nosmp"Andi Kleen
Impact: fix boot crash with numcpus=0 on certain systems Fix early exception in __get_smp_config with nosmp. Bail out early when there is no MP table. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Tested-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-04[PATCH] fix bogus argument of blkdev_put() in pktcdvdAl Viro
final close of ->bdev should match the initial open, i.e. get FMODE_READ | FMODE_NDELAY; FMODE_READ|FMODE_WRITE has been a braino. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH 2/2] documnt FMODE_ constantsChristoph Hellwig
Make sure all FMODE_ constants are documents, and ensure a coherent style for the already existing comments. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] clean up blkdev_get a little bitChristoph Hellwig
The way the bd_claim for the FMODE_EXCL case is implemented is rather confusing. Clean it up to the most logical style. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] Fix block dev compat ioctl handlingAndreas Schwab
Commit 33c2dca4957bd0da3e1af7b96d0758d97e708ef6 (trim file propagation in block/compat_ioctl.c) removed the handling of some ioctls from compat_blkdev_driver_ioctl. That caused them to be rejected as unknown by the compat layer. Signed-off-by: Andreas Schwab <schwab@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] kill obsolete temporary comment in swsusp_close()Al Viro
it had been put there to mark the call of blkdev_put() that needed proper argument propagated to it; later patch in the same series had done just that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04time: catch xtime_nsec underflows and fix themjohn stultz
Impact: fix time warp bug Alex Shi, along with Yanmin Zhang have been noticing occasional time inconsistencies recently. Through their great diagnosis, they found that the xtime_nsec value used in update_wall_time was occasionally going negative. After looking through the code for awhile, I realized we have the possibility for an underflow when three conditions are met in update_wall_time(): 1) We have accumulated a second's worth of nanoseconds, so we incremented xtime.tv_sec and appropriately decrement xtime_nsec. (This doesn't cause xtime_nsec to go negative, but it can cause it to be small). 2) The remaining offset value is large, but just slightly less then cycle_interval. 3) clocksource_adjust() is speeding up the clock, causing a corrective amount (compensating for the increase in the multiplier being multiplied against the unaccumulated offset value) to be subtracted from xtime_nsec. This can cause xtime_nsec to underflow. Unfortunately, since we notify the NTP subsystem via second_overflow() whenever we accumulate a full second, and this effects the error accumulation that has already occured, we cannot simply revert the accumulated second from xtime nor move the second accumulation to after the clocksource_adjust call without a change in behavior. This leaves us with (at least) two options: 1) Simply return from clocksource_adjust() without making a change if we notice the adjustment would cause xtime_nsec to go negative. This would work, but I'm concerned that if a large adjustment was needed (due to the error being large), it may be possible to get stuck with an ever increasing error that becomes too large to correct (since it may always force xtime_nsec negative). This may just be paranoia on my part. 2) Catch xtime_nsec if it is negative, then add back the amount its negative to both xtime_nsec and the error. This second method is consistent with how we've handled earlier rounding issues, and also has the benefit that the error being added is always in the oposite direction also always equal or smaller then the correction being applied. So the risk of a corner case where things get out of control is lessened. This patch fixes bug 11970, as tested by Yanmin Zhang http://bugzilla.kernel.org/show_bug.cgi?id=11970 Reported-by: alex.shi@intel.com Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03sparc64: Fix VIS emulation bugsJoseph Myers
This patch fixes some bugs in VIS emulation that cause the GCC test failure FAIL: gcc.target/sparc/pdist-3.c execution test for both 32-bit and 64-bit testing on hardware lacking these instructions. The emulation code for the pdist instruction uses RS1(insn) for both source registers rs1 and rs2, which is obviously wrong and leads to the instruction doing nothing (the observed problem), and further inspection of the code shows that RS1 uses a shift of 24 and RD a shift of 25, which clearly cannot both be right; examining SPARC documentation indicates the correct shift for RS1 is 14. This patch fixes the bug if single-stepping over the affected instruction in the debugger, but not if the testcase is run standalone. For that, Wind River has another patch I hope they will send as a followup to this patch submission. Signed-off-by: Joseph Myers <joseph@codesourcery.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04drm/i915: Return error in i915_gem_set_to_gtt_domain if we're not in the GTT.Eric Anholt
It's only for flushing caches appropriately for GTT access, not for actually getting it there. Prevents potential smashing of cpu read/write domains on unbound objects. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Retry execbuffer pinning after clearing the GTTKeith Packard
If we fail to pin all of the buffers in an execbuffer request, go through and clear the GTT and try again to see if its just a matter of fragmentation Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Move the execbuffer domain computations togetherKeith Packard
This eliminates the dev_set_domain function and just in-lines it where its used, with the goal of moving the manipulation and use of invalidate_domains and flush_domains closer together. This also avoids calling add_request unless some domain has been flushed. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Rename object_set_domain to object_set_to_gpu_domainKeith Packard
Now that the CPU and GTT domain operations are isolated to their own functions, the previously general-purpose set_domain function is now used only to set GPU domains. It also has no failure cases, which is important as this eliminates any possible interruption of the computation of new object domains and subsequent emmission of the flushing instructions into the ring. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Make a single set-to-cpu-domain path and use it wherever needed.Eric Anholt
This fixes several domain management bugs, including potential lack of cache invalidation for pread, potential failure to wait for set_domain(CPU, 0), and more, along with producing more intelligible code. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Make a single set-to-gtt-domain path.Eric Anholt
This fixes failure to flush caches in the relocation update path, and failure to wait in the set_domain ioctl, each of which could lead to incorrect rendering. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: If interrupted while setting object domains, still emit the flush.Eric Anholt
Otherwise, we would leave the objects in an inconsistent state, such as write_domain == 0 but on the flushing list. Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Move flushing list cleanup from flush request retire to request emit.Eric Anholt
obj_priv->write_domain is "write domain if the GPU went idle now", not "write domain at this moment." By postponing the clear, we confused the concept, required more storage, and potentially emitted more flushes than are required. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-04drm/i915: Respect GM965/GM45 bit-17-instead-of-bit-11 option for swizzling.Eric Anholt
This fixes readpixels and buffer corruption when swapped out and in by disabling tiling on them. Now that we know that the bit 17 mode isn't just a mistake of older chipsets, we'll need to work on a clever fix so that we can get the performance of tiling on these chipsets, but that will require intrusive changes targeted at the next kernel release, not this one. Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2008-12-03MN10300: Introduce barriers to replace removed volatiles in gdbstub 16550 driverDavid Howells
Introduce into the MN10300 gdbstub 16550 driver a couple of barrier() calls to replace the removed volatility of the input/output index variables for the Rx ring buffer. A previous patch added them into the on-chip serial port driver. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
