2009-06-09pkt_sched: Change PSCHED_SHIFT from 10 to 6Jarek Poplawski
Change PSCHED_SHIFT from 10 to 6 to increase schedulers time resolution. This will increase 16x a number of (internal) ticks per nanosecond, and is needed to improve accuracy of schedulers based on rate tables, like HTB, TBF or CBQ, with rates above 100Mbit. It is assumed this change is safe for 32bit accounting of time diffs up to 2 minutes, which should be enough for common use (extremely low rate values may overflow, so get inaccurate instead). To make full use of this change an updated iproute2 will be needed. (But using older iproute2 should be safe too.) This change breaks ticks - microseconds similarity, so some minor code fixes might be needed. It is also planned to change naming adequately eg. to PSCHED_TICKS2NS() etc. in the near future. Reported-by: Antonio Almeida <vexwek@gmail.com> Tested-by: Antonio Almeida <vexwek@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09pkt_sched: Use PSCHED_SHIFT in PSCHED time conversionJarek Poplawski
Use PSCHED_SHIFT constant instead of '10' in PSCHED_US2NS() and PSCHED_NS2US() macros to enable changing this value later. Additionally use PSCHED_SHIFT in sch_hfsc SM_SHIFT and ISM_SHIFT definitions. This part of the patch is based on feedback from Patrick McHardy <kaber@trash.net>. Reported-by: Antonio Almeida <vexwek@gmail.com> Tested-by: Antonio Almeida <vexwek@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09net: dev_addr_init() fixEric Dumazet
commit f001fde5eadd915f4858d22ed70d7040f48767cf (net: introduce a list of device addresses dev_addr_list (v6)) added one regression Vegard Nossum found in its testings. With kmemcheck help, Vegard found some uninitialized memory was read and reported to user, potentialy leaking kernel data. ( thread can be found on http://lkml.org/lkml/2009/5/30/177 ) dev_addr_init() incorrectly uses sizeof() operator. We were initializing one byte instead of MAX_ADDR_LEN bytes. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09be2net: Remove unnecessary frag list traversing.David S. Miller
This driver does not indicate support for frag lists. Furthermore, even if it did, the code is walking the frag lists incorrectly. The idiom is: for (iter = skb_shinfo(skb)->frag_list; iter; iter = iter->next) but it's doing: for (iter = skb_shinfo(skb)->frag_list; iter; iter = skb_shinfo(iter)->frag_list) which would never work. And this proves that this driver never saw an SKB with active frag lists. So just remove the code altogether and the driver TX path becomes much simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09xfrm: Use frag list abstraction interfaces.David S. Miller
2009-06-09sctp: Use frag list abstraction interfaces.David S. Miller
2009-06-09phonet: Use frag list abstraction interfaces.David S. Miller
2009-06-09netfilter: Use frag list abstraction interfaces.David S. Miller
2009-06-09ipv6: Use frag list abstraction interfaces.David S. Miller
2009-06-09ipv4: Use frag list abstraction interfaces.David S. Miller
2009-06-09net/core/user_dma.c: Use frag list abstraction interfaces.David S. Miller
2009-06-09net/core/skbuff.c: Use frag list abstraction interfaces.David S. Miller
2009-06-09net/core/dev.c: Use frag list abstraction interfaces.David S. Miller
2009-06-09datagram: Use frag list abstraction interfaces.David S. Miller
2009-06-09appletalk: Use frag list abstraction interfaces.David S. Miller
2009-06-09netdevice.h: Use frag list abstraction interfaces.David S. Miller
2009-06-09skbuff: Add frag list abstraction interfaces.David S. Miller
With the hope that these can be used to eliminate direct references to the frag list implementation. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08bluetooth: Kill skb_frags_no(), unused.David S. Miller
Furthermore, it twiddles with the details of SKB list handling directly, which we're trying to eliminate. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08declance: Restore tx descriptor ring lockingMaciej W. Rozycki
A driver overhaul on 29 Feb 2000 (!) broke locking around fiddling with the tx descriptor ring in start_xmit(); a follow-on "fix" removed the broken remnants altogether. Here's a patch to restore proper locking in the function -- the complement in the interrupt handler has been correct all the time. This *may* have been the reason for the occasional confusion of the chip -- triggering a tx timeout followed by a chip reset sequence -- seen on R4k-based DECstations with the onboard Ethernet interface. Another theory is the confusion is due to an unindentified problem -- perhaps a silicon erratum -- associated with the variation of the MT ASIC used to interface the R4k CPU to the rest of the system on these computers; with its aggressive write-back buffering the design is particularly weakly ordered when it comes to MMIO (in the absence of ordering barriers uncached reads are allowed to bypass earlier uncached writes, even if to the same location), which may trigger all kinds of corner cases in peripheral hardware as well as software. Either way this piece of code is buggy. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08isdn: extend INTERFACE.CAPI documentTilman Schmidt
Clarify calling context and return codes of callback methods, and add a description of the _cmsg structure and helper functions. Impact: documentation Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08isdn: prevent NULL ptr Oops in capi_cmsg2str()Tilman Schmidt
The dereferencing of the private pointer cmsg->m in capi_cmsg2str() may cause an Oops in case of an error, which is particularly inconvenient as that function is typically used to format an error message. Add a NULL pointer check to avoid this. Impact: error handling improvement Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08isdn: kerneldoc for capiutil.cTilman Schmidt
Add kerneldoc comments for the exported funtions in capiutil.c. Impact: documentation Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08isdn: rename capi_ctr_reseted() to capi_ctr_down()Tilman Schmidt
Change the name of the Kernel CAPI exported function capi_ctr_reseted() to something representing its purpose better. Impact: renaming, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08tun: Fix unregister raceEric W. Biederman
It is possible for tun_chr_close to race with dellink on the a tun device. In which case if __tun_get runs before dellink but dellink runs before tun_chr_close calls unregister_netdevice we will attempt to unregister the netdevice after it is already gone. The two cases are already serialized on the rtnl_lock, so I have gone for the cheap simple fix of moving rtnl_lock to cover __tun_get in tun_chr_close. Eliminating the possibility of the tun device being unregistered between __tun_get and unregister_netdevice in tun_chr_close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Tested-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08e100: Fix napi_enable BUG_ON when recovering from EEH errorAndre Detsch
BUG_ON(!test_bit(NAPI_STATE_SCHED, &n->state)) was being hit during e100 EEH recovery. The problem source was a napi_enable call being made during e100_io_error_detected. Napi should remain disabled after e100_down, and only be reenabled when the interface is recovered. This patch also updates e100_io_error_detected in order to make it similar to the current versions of the error_detected callback in drivers such as e1000e and ixgbe. Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net pkgen.c:fix no need for checkFigo.zhang
vfree() does its own 'NULL' check, so no need for check before calling it. Signed-off-by: Figo.zhang <figo1802@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08mlx4: FIX error flow when initializing EQ tableYevgeny Petrilin
If mlx4_create_eq() would fail for one of EQ's assigned for completion handling, the code would try to free the same EQ we failed to create. The crash was found by Christoph Lameter Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08tun: Fix copy/paste error in tun_get_userSridhar Samudrala
Use the right structure while incrementing the offset in tun_get_user. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: Fix memcpy_toiovecend() to use the right offsetSridhar Samudrala
Increment the iovec base by the offset passed in for the initial copy_to_user() in memcpy_to_iovecend(). Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: Fix skb_copy_datagram_from_iovec() to pass the right offsetSridhar Samudrala
I am working on enabling UFO between KVM guests using virtio-net and i have some patches that i got working with 2.6.30-rc8. When i wanted to try them with net-next-2.6, i noticed that virtio-net is not working with that tree. After some debugging, it turned out to be several bugs in the recent patches to fix aio with tun driver, specifically the following 2 commits. http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=0a1ec07a67bd8b0033dace237249654d015efa21 http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=6f26c9a7555e5bcca3560919db9b852015077dae Fix the call to memcpy_from_iovecend() in skb_copy_datagram_from_iovec to pass the right iovec offset. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: skb_shared_info optimizationEric Dumazet
skb_dma_unmap() is quite expensive for small packets, because we use two different cache lines from skb_shared_info. One to access nr_frags, one to access dma_maps[0] Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements, let dma_head alone in a new dma_head field, close to nr_frags, to reduce cache lines misses. Tested on my dev machine (bnx2 & tg3 adapters), nice speedup ! Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: num_dma_maps is not usedEric Dumazet
Get rid of num_dma_maps in struct skb_shared_info, as it seems unused. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08s2io: Remove private boolean definitionsTobias Klauser
Remove the private definition of TRUE/FALSE and use the ones from linux/stddef.h. Also remove the definition of BOOL which is not referenced inside the driver anyway. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08hso: convert dev_alloc_skb() to netdev_alloc_skb()Paulius Zaleckas
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: Added KS8842 driverRichard Ršöjfors
This is a driver for the Micrel KS8842 ethernet switch. The supplied code is for driving the KS8842 through the Timberdale FPGA on the Russellville board, a development board for Intel Atom CPU in the automotive area. Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: Ensure partial checksum offset is inside the skb headHerbert Xu
On Thu, Jun 04, 2009 at 09:06:00PM +1000, Herbert Xu wrote: > > tun: Optimise handling of bogus gso->hdr_len > > As all current versions of virtio_net generate a value for the > header length that's too small, we should optimise this so that > we don't copy it twice. This can be done by ensuring that it is > at least as large as the place where we'll write the checksum. > > Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> With this applied we can strengthen the partial checksum check: In skb_partial_csum_set we check to see if the checksum offset is within the packet. However, we really should check that it is within the skb head as that's the only bit we can modify without copying. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08tun: Optimise handling of bogus gso->hdr_lenHerbert Xu
As all current versions of virtio_net generate a value for the header length that's too small, we should optimise this so that we don't copy it twice. This can be done by ensuring that it is at least as large as the place where we'll write the checksum. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08virtio_net: Set correct gso->hdr_lenHerbert Xu
Through a bug in the tun driver, I noticed that virtio_net is producing bogus hdr_len values. In particular, it only includes the IP header in the linear area, and excludes the entire TCP header. This causes the TCP header to be copied twice for each packet. (The bug omitted the second copy :) This patch corrects this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08sis190: fix gigabit negotiationRiccardo Ghetta
Fixes an initialization error; the chip negotiates gigabit, but the driver mistakenly handled it as 100Mb. Changes based on both SiS own GPL driver and forcedeth. Hopefully should fix http://bugzilla.kernel.org/show_bug.cgi?id=9735 http://bugzilla.kernel.org/show_bug.cgi?id=11149 Signed-off-by: Riccardo Ghetta <birrachiara@tin.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08sis190: add new phy found on asus F5Sr laptopRiccardo Ghetta
2009-06-08sis190: better message on unknown PHYRiccardo Ghetta
2009-06-08sis190: fix for x86_64 (bug 11509)Riccardo Ghetta
Corrected dma sync handling on small packets. Should fix http://bugzilla.kernel.org/show_bug.cgi?id=11509 Note: While this bug was reported only on x86_64, it could have affected any architecture. Signed-off-by: Riccardo Ghetta <birrachiara@tin.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08qlge: Fix timeout on firmware mailbox commands.Ron Mercer
Some firmware mailbox commands require the firmware to communicate with the FCoE driver running on another PCI function. This can potentially take several seconds. This wait is done in process context only. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08qlge: Fix timeout on indexed register wait.Ron Mercer
There are 8 banks of 'sub-registers' each of which are accessed through address/data register pair. An example would be reading flash or the xgmac. Accessing these require the driver to wait for a ready bit before writing the address and then accessing the data. This patch increases the timeout to 100us to prevent timeouts that have been seen on some platforms. These register are accessed in process context only. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08qlge: Fix bug in MTU setting process.Ron Mercer
Since an FCoE function shares a port with this NIC function, the jumbo settings must always be in place. This patch causes the hardware to be set up for jumbo if it is not already done. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08qlge: Fix bug in firmware event handler.Ron Mercer
Each firmware mailbox command can have a different number of valid data elements. When waiting for a mailbox command to complete it the process passes it's element count and waits for the completion. It is possible that while waiting an unrelated firmware async event (AE) can arrive. When this happens, the handler will over write the element count with the value for the newly arrived AE. This can cause the mailbox command to not get all of it's data. This patch restores original mailbox count at the end of the handler. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08qlge: Fix firmware event handler loop.Ron Mercer
Check status on every iteration of event handler loop and exit if an error occurred. If an error occurred then recover process will be queued so this loop should no continue. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: smsc911x: add missing __devexit_p() usageMike Frysinger
The smsc911x_drv_remove() function is declared with __devexit, so the assignment to the driver structure needs __devexit_p() wrappings to prevent build failure when hotplug is disabled. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: smsc911x: allow building on Blackfin systemsMike Frysinger
The smsc911x driver works fine on Blackfin systems, so add it to the arch list in the Kconfig. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-07ixgbe: Increase the driver version numberPeter P Waskiewicz Jr
With all the last patchsets going in for 82599 feature enablement, the driver version needs to be increased for better identification. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
