2008-08-25Merge branch 'x86/urgent' into x86/cleanupsH. Peter Anvin
2008-08-25x86: msr: fix bogus return values from rdmsr_safe/wrmsr_safeH. Peter Anvin
Impact: bogus error codes (+other?) on x86-64 The rdmsr_safe/wrmsr_safe routines have macros for the handling of the edx:eax arguments. Those macros take a variable number of assembly arguments. This is rather inherently incompatible with using %digit-style escapes in the inline assembly; replace those with %[name]-style escapes. This fixes miscompilation on x86-64, which at the very least caused bogus return values. It is possible that this could also corrupt the return value; I am not sure. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25x86: cpuid: correct return value on partial operationsH. Peter Anvin
Return the correct return value when the CPUID driver partially completes a request (we should return the number of bytes actually read or written, instead of the error code.) Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25x86: msr: correct return value on partial operationsH. Peter Anvin
Return the correct return value when the MSR driver partially completes a request (we should return the number of bytes actually read or written, instead of the error code.) Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25x86: cpuid: propagate error from smp_call_function_single()H. Peter Anvin
Propagate error (-ENXIO) from smp_call_function_single() in the CPUID driver. This can happen when a CPU is unplugged while the CPUID driver is open. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25x86: msr: propagate errors from smp_call_function_single()H. Peter Anvin
Propagate error (-ENXIO) from smp_call_function_single(). These errors can happen when a CPU is unplugged while the MSR driver is open. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25smp: have smp_call_function_single() detect invalid CPUsH. Peter Anvin
Have smp_call_function_single() return invalid CPU indicies and return -ENXIO. This function is already executed inside a get_cpu()..put_cpu() which locks out CPU removal, so rather than having the higher layers doing another layer of locking to guard against unplugged CPUs do the test here. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-25x86: add X86_FEATURE_XMM4_2 definitionsAustin Zhang
Added Intel processor SSE4.2 feature flag. No in-tree user at the moment, but makes the tree-merging life easier for the crypto tree. Signed-off-by: Austin Zhang <austin.zhang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-25x86: fix cpufreq + sched_clock() regressionPeter Zijlstra
I noticed that my sched_clock() was slow on a number of machine, so I started looking at cpufreq. The below seems to fix the problem for me. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-25Merge branch 'linus' into x86/urgentIngo Molnar
2008-08-25x86: cleanup in amd_cpu_notify()Robert Richter
small coding style fix. Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-25Merge branch 'x86/urgent' into x86/cleanupsIngo Molnar
2008-08-25x86: fix HPET regression in 2.6.26 versus 2.6.25, check hpet against BAR, v3Yinghai Lu
David Witbrodt tracked down (and bisected) a hpet bootup hang on his system to the following problem: a BIOS bug made the hpet device visible as a generic PCI device. If e820 reserved entries happen to be registered first in the resource tree [which v2.6.26 started doing], then the PCI code will reallocate that device's BAR to some other address - breaking timer IRQs and hanging the system. ( Normally hpet devices are hidden by the BIOS from the OS's PCI discovery via chipset magic. Sometimes the hpet is not a PCI device at all. ) Solve this fundamental fragility by making non-PCI platform drivers insert resources into the resource tree even if it overlaps the e820 reserved entry, to keep the resource manager from updating the BAR. Also do these checks for the ioapic and mmconfig addresses, and emit a warning if this happens. Bisected-by: David Witbrodt <dawitbro@sbcglobal.net> Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Tested-by: David Witbrodt <dawitbro@sbcglobal.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-24x86: do not enable TSC notifier if we don't need itLinus Torvalds
Impact: crash on non-TSC-equipped CPUs Don't enable the TSC notifier if we *either*: 1. don't have a CPU, or 2. have a CPU with constant TSC. In either of those cases, the notifier is either damaging (1) or useless(2). From: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-23Fix oops in acer_wmi driver (acer_wmi_init)Arjan van de Ven
The acer_wmi driver does a DMI scan for quirks, and then sets flags into the "interface" datastructure for some cases. However, the quirks happen real early before "interface" is per se initialized from NULL. The patch below 1) adds a NULL pointer check and 2) (re)runs the quirks at the end, when "interface" has it's final value. Reported-by: kerneloops.org Acked-by: Carlos Corbacho <carlos@strangeworlds.co.uk> CC: stable@vger.kernel.org Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: ipv6: protocol for address routes icmp: icmp_sk() should not use smp_processor_id() in preemptible code pkt_sched: Fix qdisc list locking pkt_sched: Fix qdisc_watchdog() vs. dev_deactivate() race sctp: fix potential panics in the SCTP-AUTH API.
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23x86 MCE: Fix CPU hotplug problem with multiple multicore AMD CPUsRafael J. Wysocki
During CPU hot-remove the sysfs directory created by threshold_create_bank(), defined in arch/x86/kernel/cpu/mcheck/mce_amd_64.c, has to be removed before its parent directory, created by mce_create_device(), defined in arch/x86/kernel/cpu/mcheck/mce_64.c . Moreover, when the CPU in question is hotplugged again, obviously the latter has to be created before the former. At present, the right ordering is not enforced, because all of these operations are carried out by CPU hotplug notifiers which are not appropriately ordered with respect to each other. This leads to serious problems on systems with two or more multicore AMD CPUs, among other things during suspend and hibernation. Fix the problem by placing threshold bank CPU hotplug callbacks in mce_cpu_callback(), so that they are invoked at the right places, if defined. Additionally, use kobject_del() to remove the sysfs directory associated with the kobject created by kobject_create_and_add() in threshold_create_bank(), to prevent the kernel from crashing during CPU hotplug operations on systems with two or more multicore AMD CPUs. This patch fixes bug #11337. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Andi Kleen <andi@firstfloor.org> Tested-by: Mark Langsdorf <mark.langsdorf@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-23x86: fix: make PCI ECS for AMD CPUs hotplug capableRobert Richter
Until now, PCI ECS setup was performed at boot time only and for cpus that are enabled then. This patch fixes this and adds cpu hotplug. Tests sequence (check if ECS bit is set when bringing cpu online again): # ( perl -e 'sysseek(STDIN, 0xC001001F, 0)'; hexdump -n 8 -e '2/4 "%08x " "\n"' ) < /dev/cpu/1/msr 00000008 00404010 # ( perl -e 'sysseek(STDOUT, 0xC001001F, 0); print pack "l*", 8, 0x00400010' ) > /dev/cpu/1/msr # ( perl -e 'sysseek(STDIN, 0xC001001F, 0)'; hexdump -n 8 -e '2/4 "%08x " "\n"' ) < /dev/cpu/1/msr 00000008 00400010 # echo 0 > /sys/devices/system/cpu/cpu1/online # echo 1 > /sys/devices/system/cpu/cpu1/online # ( perl -e 'sysseek(STDIN, 0xC001001F, 0)'; hexdump -n 8 -e '2/4 "%08x " "\n"' ) < /dev/cpu/1/msr 00000008 00404010 Reported-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-23x86: fix: do not run code in amd_bus.c on non-AMD CPUsRobert Richter
Jan Beulich wrote: > Even worse - this would even try to access the MSR on non-AMD CPUs > (currently probably prevented just by the fact that only AMD ones use > family values of 0x10 or higher). This patch adds cpu vendor check to the postcore_initcalls. Reported-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-23ipv6: protocol for address routesStephen Hemminger
This fixes a problem spotted with zebra, but not sure if it is necessary a kernel problem. With IPV6 when an address is added to an interface, Zebra creates a duplicate RIB entry, one as a connected route, and other as a kernel route. When an address is added to an interface the RTN_NEWADDR message causes Zebra to create a connected route. In IPV4 when an address is added to an interface a RTN_NEWROUTE message is set to user space with the protocol RTPROT_KERNEL. Zebra ignores these messages, because it already has the connected route. The problem is that route created in IPV6 has route protocol == RTPROT_BOOT. Was this a design decision or a bug? This fixes it. Same patch applies to both net-2.6 and stable. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-23icmp: icmp_sk() should not use smp_processor_id() in preemptible codeDenis V. Lunev
Pass namespace into icmp_xmit_lock, obtain socket inside and return it as a result for caller. Thanks Alexey Dobryan for this report: Steps to reproduce: CONFIG_PREEMPT=y CONFIG_DEBUG_PREEMPT=y tracepath <something> BUG: using smp_processor_id() in preemptible [00000000] code: tracepath/3205 caller is icmp_sk+0x15/0x30 Pid: 3205, comm: tracepath Not tainted 2.6.27-rc4 #1 Call Trace: [<ffffffff8031af14>] debug_smp_processor_id+0xe4/0xf0 [<ffffffff80409405>] icmp_sk+0x15/0x30 [<ffffffff8040a17b>] icmp_send+0x4b/0x3f0 [<ffffffff8025a415>] ? trace_hardirqs_on_caller+0xd5/0x160 [<ffffffff8025a4ad>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff8023a475>] ? local_bh_enable_ip+0x95/0x110 [<ffffffff804285b9>] ? _spin_unlock_bh+0x39/0x40 [<ffffffff8025a26c>] ? mark_held_locks+0x4c/0x90 [<ffffffff8025a4ad>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff8025a415>] ? trace_hardirqs_on_caller+0xd5/0x160 [<ffffffff803e91b4>] ip_fragment+0x8d4/0x900 [<ffffffff803e7030>] ? ip_finish_output2+0x0/0x290 [<ffffffff803e91e0>] ? ip_finish_output+0x0/0x60 [<ffffffff803e6650>] ? dst_output+0x0/0x10 [<ffffffff803e922c>] ip_finish_output+0x4c/0x60 [<ffffffff803e92e3>] ip_output+0xa3/0xf0 [<ffffffff803e68d0>] ip_local_out+0x20/0x30 [<ffffffff803e753f>] ip_push_pending_frames+0x27f/0x400 [<ffffffff80406313>] udp_push_pending_frames+0x233/0x3d0 [<ffffffff804067d1>] udp_sendmsg+0x321/0x6f0 [<ffffffff8040d155>] inet_sendmsg+0x45/0x80 [<ffffffff803b967f>] sock_sendmsg+0xdf/0x110 [<ffffffff8024a100>] ? autoremove_wake_function+0x0/0x40 [<ffffffff80257ce5>] ? validate_chain+0x415/0x1010 [<ffffffff8027dc10>] ? __do_fault+0x140/0x450 [<ffffffff802597d0>] ? __lock_acquire+0x260/0x590 [<ffffffff803b9e55>] ? sockfd_lookup_light+0x45/0x80 [<ffffffff803ba50a>] sys_sendto+0xea/0x120 [<ffffffff80428e42>] ? _spin_unlock_irqrestore+0x42/0x80 [<ffffffff803134bc>] ? __up_read+0x4c/0xb0 [<ffffffff8024e0c6>] ? up_read+0x26/0x30 [<ffffffff8020b8bb>] system_call_fastpath+0x16/0x1b icmp6_sk() is similar. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: authenc - Avoid using clobbered request pointer
2008-08-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Fix call of alc888_coef_init() ALSA: hda_intel: enable snoop for nvidia HDA controller
2008-08-22Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Update documentation to remind users to update mke2fs.conf ext4: Fix small file fragmentation ext4: Initialize writeback_index to 0 when allocating a new inode ext4: make sure ext4_has_free_blocks returns 0 for ENOSPC ext4: journal credit fix for the delayed allocation's writepages() function ext4: Rework the ext4_da_writepages() function ext4: journal credits reservation fixes for DIO, fallocate ext4: journal credits reservation fixes for extent file writepage ext4: journal credits calulation cleanup and fix for non-extent writepage ext4: Fix bug where we return ENOSPC even though we have plenty of inodes ext4: don't try to resize if there are no reserved gdt blocks left ext4: Use ext4_discard_reservations instead of mballoc-specific call ext4: Fix ext4_dx_readdir hash collision handling ext4: Fix delalloc release block reservation for truncate ext4: Fix potential truncate BUG due to i_prealloc_list being non-empty ext4: Handle unwritten extent properly with delayed allocation
2008-08-22Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: enable LB_BIAS by default
2008-08-22Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: fix synchronize_rcu() so that kernel-doc works
2008-08-22Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: nohz: fix wrong event handler after online an offlined cpu
2008-08-22Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: work around MTRR mask setting, v2 x86: fix section mismatch warning - uv_cpu_init x86: fix VMI for early params x86: fix two modpost warnings in mm/init_64.c x86: fix 1:1 mapping init on 64-bit (memory hotplug case) x86: work around MTRR mask setting x86: PAT Update validate_pat_support for intel CPUs devmem, x86: PAT Change /dev/mem mmap with O_SYNC to use UC_MINUS x86: PAT proper tracking of set_memory_uc and friends x86: fix BUG: unable to handle kernel paging request (numaq_tsc_disable) x86: export pv_lock_ops non-GPL x86, mmiotrace: silence section mismatch warning - leave_uniprocessor x86: use WARN() in arch/x86/kernel x86: use WARN() in arch/x86/mm/ioremap.c werror: fix pci calgary x86: fix oprofile + hibernation badness x86, SGI UV: hardcode the TLB flush interrupt system vector x86: fix Xorg startup/shutdown slowdown with PAT x86: fix "kernel won't boot on a Cyrix MediaGXm (Geode)" x86 iommu: remove unneeded parenthesis
2008-08-22Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] pata_it821x: fix warning libata: Fix a large collection of DMA mode mismatches ahci: sis controllers actually can do PMP pata_via: clean up recent tf_load changes libata: restore SControl on detach libata: use ata_link_printk() when printing SError libata: always do follow-up SRST if hardreset returned -EAGAIN libata: fix EH action overwriting in ata_eh_reset() sata_mv: add the Gen IIE flag to the SoC devices. ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDs ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDs sata_mv: don't issue two DMA commands concurrently libata: implement no[hs]rst force params
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IPoIB: Fix deadlock on RTNL in ipoib_stop() IB/ipath: Fix incorrect check for max physical address in TID IB/ipath: Fix lost UD send work request
2008-08-23crypto: authenc - Avoid using clobbered request pointerHerbert Xu
Authenc works in two stages for encryption, it first encrypts and then computes an ICV. The context memory of the request is used by both operations. The problem is that when an asynchronous encryption completes, we will compute the ICV and then reread the context memory of the encryption to get the original request. It just happens that we have a buffer of 16 bytes in front of the request pointer, so ICVs of 16 bytes (such as SHA1) do not trigger the bug. However, any attempt to uses a larger ICV instantly kills the machine when the first asynchronous encryption is completed. This patch fixes this by saving the request pointer before we start the ICV computation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-22ALSA: hda - Fix call of alc888_coef_init()Takashi Iwai
Using init_hook to call alc888_coef_init() is problematic for configurations that already set another init_hook. Better to put it in alc_init() as is (although it looks a bit hackish). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-22x86: work around MTRR mask setting, v2Ingo Molnar
improve the debug printout: - make it actually display something - print it only once would be nice to have a WARN_ONCE() facility, to feed such things to kerneloops.org. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22x86: fix section mismatch warning - uv_cpu_initMarcin Slusarz
WARNING: vmlinux.o(.cpuinit.text+0x3cc4): Section mismatch in reference from the function uv_cpu_init() to the function .init.text:uv_system_init() The function __cpuinit uv_cpu_init() references a function __init uv_system_init(). If uv_system_init is only used by uv_cpu_init then annotate uv_system_init with a matching annotation. uv_system_init was ment to be called only once, so do it from codepath (native_smp_prepare_cpus) which is called once, right before activation of other cpus (smp_init). Note: old code relied on uv_node_to_blade being initialized to 0, but it'a not initialized from anywhere. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22pkt_sched: Fix qdisc list lockingJarek Poplawski
Since some qdiscs call qdisc_tree_decrease_qlen() (so qdisc_lookup()) without rtnl_lock(), adding and deleting from a qdisc list needs additional locking. This patch adds global spinlock qdisc_list_lock and wrapper functions for modifying the list. It is considered as a temporary solution until hfsc_dequeue(), netem_dequeue() and tbf_dequeue() (or qdisc_tree_decrease_qlen()) are redone. With feedback from Herbert Xu and David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-22[libata] pata_it821x: fix warningJeff Garzik
Reported by Andrew Morton: drivers/ata/pata_it821x.c: In function 'it821x_port_start': drivers/ata/pata_it821x.c:609: warning: 'mtype' may be used uninitialized in this function Pretty horrid fix, but so's a warning.. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: Fix a large collection of DMA mode mismatchesAlan Cox
Dave Müller sent a diff for the pata_oldpiix that highlighted a problem where a lot of the ATA drivers assume dma_mode == 0 means "no DMA" while the core code uses 0xFF. This turns out to have other consequences such as code doing >= XFER_UDMA_0 also catching 0xFF as UDMAlots. Fortunately it doesn't generally affect set_dma_mode, although some drivers call back into their own set mode code from other points. Having been through the drivers I've added helpers for using_udma/using_mwdma dma_enabled so that people don't open code ranges that may change (eg if UDMA8 appears somewhere) Thanks to David for the initial bits [and added fix for pata_oldpiix from and signed-off-by Dave Mueller <dave.mueller@gmx.ch> -jg] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ahci: sis controllers actually can do PMPTejun Heo
SIS controllers were blacklisted for PMP as enabling it made device detection fail whether the device was PMP or not - the natural conclusion was the controller chokes on SRST w/ pmp==15. However, it turned out that the controller just didn't like issuing SRST after hardreset w/o clearing SError first. Interestingly, the SRST itself succeeds but the following commands fail. If SError is cleared between hardreset and SRST, which is the default behavior now, everything works fine and SIS controllers work with PMPs happily. Remove PMP blacklisting for SIS AHCIs. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Piter PUNK <piterpunk@slackware.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22pata_via: clean up recent tf_load changesTejun Heo
Commit bfce5e0179ad059035df28558724ff60af708e09 implemented custom tf_load for pata_via. This patch cleans it up a bit. * Instead of duplicating whole body, copy tf and set ATA_TFLAG_DEVICE when necessary. * Rename via_ata_tf_load() to via_tf_load(). * No need to set .tf_load in via_port_ops_noirq as it inherits from via_port_ops. * Clean up indentation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Joseph Chan <JosephChan@via.com.tw> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: restore SControl on detachTejun Heo
Save SControl during probing and restore it on detach. This prevents adjustments made by libata drivers to seep into the next driver which gets attached (be it a libata one or not). It's not clear whether SControl also needs to be restored on suspend. The next system to have control (ACPI or kexec'd kernel) would probably like to see the original SControl value but there's no guarantee that a link is gonna keep working after SControl is adjusted without a reset and adding a reset and modified recovery cycle soley for this is an overkill. For now, do it only for detach. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: use ata_link_printk() when printing SErrorTejun Heo
SError belongs to link not port. Use ata_link_printk() to print it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: always do follow-up SRST if hardreset returned -EAGAINTejun Heo
As an optimization, follow-up SRST used to be skipped if classification wasn't requested even when hardreset requested it via -EAGAIN. However, some hardresets can't wait for device readiness and skipping SRST can cause timeout or other failures during revalidation. Always perform follow-up SRST if hardreset returns -EAGAIN. This makes reset paths more predictable and thus less error-prone. While at it, move hardreset error checking such that it's done right after hardreset is finished. This simplifies followup SRST condition check a bit and makes the reset path easier to modify. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: fix EH action overwriting in ata_eh_reset()Tejun Heo
ehc->i.action got accidentally overwritten to ATA_EH_HARD/SOFTRESET in ata_eh_reset(). The original intention was to clear reset action which wasn't selected. This can cause unexpected behavior when other EH actions are scheduled together with reset. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22sata_mv: add the Gen IIE flag to the SoC devices.Saeed Bishara
The SoC sata port is based on the 7042/6042 devices (Gen IIE). This patch will fix various issues when working with PMP and/or NCQ. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
This patch adds the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ahci: RAID mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
Resend with proper whitespace. This patch adds the Intel Ibex Peak (PCH) SATA RAID Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22sata_mv: don't issue two DMA commands concurrentlyTejun Heo
sata_mv allowed issuing two DMA commands concurrently which the hardware allows. Unfortunately, libata core layer isn't ready for this yet and spews ugly warning message and malfunctions on this. Don't allow concurrent DMA commands for now. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: implement no[hs]rst force paramsTejun Heo
Implement force params nohrst, nosrst and norst. This is to work around reset related problems and ease debugging. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22x86: fix VMI for early paramsAlok Kataria
while fixing a different bug i moved the call to vmi_init before early params could be parsed. This broke the vmi specific commandline parameters. Fix that, by moving vmi initialization after kernel has got a chance to parse early parameters. Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
