2015-08-12modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYSDavid Woodhouse
Fix up the dependencies somewhat too, while we're at it. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-12extract-cert: Cope with multiple X.509 certificates in a single fileDavid Woodhouse
This is not required for the module signing key, although it doesn't do any harm — it just means that any additional certs in the PEM file are also trusted by the kernel. But it does allow us to use the extract-cert tool for processing the extra certs from CONFIG_SYSTEM_TRUSTED_KEYS, instead of that horrid awk|base64 hack. Also cope with being invoked with no input file, creating an empty output file as a result. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-12sign-file: Generate CMS message as signature instead of PKCS#7David Howells
Make sign-file use the OpenSSL CMS routines to generate a message to be used as the signature blob instead of the PKCS#7 routines. This allows us to change how the matching X.509 certificate is selected. With PKCS#7 the only option is to match on the serial number and issuer fields of an X.509 certificate; with CMS, we also have the option of matching by subjectKeyId extension. The new behaviour is selected with the "-k" flag. Without the -k flag specified, the output is pretty much identical to the PKCS#7 output. Whilst we're at it, don't include the S/MIME capability list in the message as it's irrelevant to us. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com
2015-08-12PKCS#7: Support CMS messages also [RFC5652]David Howells
Since CMS is an evolution of PKCS#7, with much of the ASN.1 being compatible, add support for CMS signed-data messages also [RFC5652 sec 5]. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com>
2015-08-12X.509: Change recorded SKID & AKID to not include Subject or IssuerDavid Howells
The key identifiers fabricated from an X.509 certificate are currently: (A) Concatenation of serial number and issuer (B) Concatenation of subject and subjectKeyID (SKID) When verifying one X.509 certificate with another, the AKID in the target can be used to match the authoritative certificate. The AKID can specify the match in one or both of two ways: (1) Compare authorityCertSerialNumber and authorityCertIssuer from the AKID to identifier (A) above. (2) Compare keyIdentifier from the AKID plus the issuer from the target certificate to identifier (B) above. When verifying a PKCS#7 message, the only available comparison is between the IssuerAndSerialNumber field and identifier (A) above. However, a subsequent patch adds CMS support. Whilst CMS still supports a match on IssuerAndSerialNumber as for PKCS#7, it also supports an alternative - which is the SubjectKeyIdentifier field. This is used to match to an X.509 certificate on the SKID alone. No subject information is available to be used. To this end change the fabrication of (B) above to be from the X.509 SKID alone. The AKID in keyIdentifier form then only matches on that and does not include the issuer. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com>
2015-08-12PKCS#7: Check content type and versionsDavid Howells
We only support PKCS#7 signed-data [RFC2315 sec 9] content at the top level, so reject anything else. Further, check that the version numbers in SignedData and SignerInfo are 1 in both cases. Note that we don't restrict the inner content type. In the PKCS#7 code we don't parse the data attached there, but merely verify the signature over it. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com>
2015-08-07modsign: Add explicit CONFIG_SYSTEM_TRUSTED_KEYS optionDavid Woodhouse
Let the user explicitly provide a file containing trusted keys, instead of just automatically finding files matching *.x509 in the build tree and trusting whatever we find. This really ought to be an *explicit* configuration, and the build rules for dealing with the files were fairly painful too. Fix applied from James Morris that removes an '=' from a macro definition in kernel/Makefile as this is a feature that only exists from GNU make 3.82 onwards. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Use single PEM file for autogenerated keyDavid Woodhouse
The current rule for generating signing_key.priv and signing_key.x509 is a classic example of a bad rule which has a tendency to break parallel make. When invoked to create *either* target, it generates the other target as a side-effect that make didn't predict. So let's switch to using a single file signing_key.pem which contains both key and certificate. That matches what we do in the case of an external key specified by CONFIG_MODULE_SIG_KEY anyway, so it's also slightly cleaner. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Extract signing cert from CONFIG_MODULE_SIG_KEY if neededDavid Woodhouse
Where an external PEM file or PKCS#11 URI is given, we can get the cert from it for ourselves instead of making the user drop signing_key.x509 in place for us. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Allow external signing key to be specifiedDavid Woodhouse
2015-08-07modsign: Allow signing key to be PKCS#11David Woodhouse
This is only the key; the corresponding *cert* still needs to be in $(topdir)/signing_key.x509. And there's no way to actually use this from the build system yet. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Allow password to be specified for signing keyDavid Woodhouse
We don't want this in the Kconfig since it might then get exposed in /proc/config.gz. So make it a parameter to Kbuild instead. This also means we don't have to jump through hoops to strip quotes from it, as we would if it was a config option. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-08-07modsign: Abort modules_install when signing failsDavid Woodhouse
2015-08-07MODSIGN: Extract the blob PKCS#7 signature verifier from module signingDavid Howells
Extract the function that drives the PKCS#7 signature verification given a data blob and a PKCS#7 blob out from the module signing code and lump it with the system keyring code as it's generic. This makes it independent of module config options and opens it to use by the firmware loader. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ming Lei <ming.lei@canonical.com> Cc: Seth Forshee <seth.forshee@canonical.com> Cc: Kyle McMartin <kyle@kernel.org>
2015-08-07system_keyring.c doesn't need to #include module-internal.hDavid Howells
system_keyring.c doesn't need to #include module-internal.h as it doesn't use the one thing that exports. Remove the inclusion. Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07sign-file: Add option to only create signature fileLuis R. Rodriguez
Make the -d option (which currently isn't actually wired to anything) write out the PKCS#7 message as per the -p option and then exit without either modifying the source or writing out a compound file of the source, signature and metadata. This will be useful when firmware signature support is added upstream as firmware will be left intact, and we'll only require the signature file. The descriptor is implicit by file extension and the file's own size. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07MODSIGN: Use PKCS#7 messages as module signaturesDavid Howells
Move to using PKCS#7 messages as module signatures because: (1) We have to be able to support the use of X.509 certificates that don't have a subjKeyId set. We're currently relying on this to look up the X.509 certificate in the trusted keyring list. (2) PKCS#7 message signed information blocks have a field that supplies the data required to match with the X.509 certificate that signed it. (3) The PKCS#7 certificate carries fields that specify the digest algorithm used to generate the signature in a standardised way and the X.509 certificates specify the public key algorithm in a standardised way - so we don't need our own methods of specifying these. (4) We now have PKCS#7 message support in the kernel for signed kexec purposes and we can make use of this. To make this work, the old sign-file script has been replaced with a program that needs compiling in a previous patch. The rules to build it are added here. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07MODSIGN: Provide a utility to append a PKCS#7 signature to a moduleDavid Howells
Provide a utility that: (1) Digests a module using the specified hash algorithm (typically sha256). [The digest can be dumped into a file by passing the '-d' flag] (2) Generates a PKCS#7 message that: (a) Has detached data (ie. the module content). (b) Is signed with the specified private key. (c) Refers to the specified X.509 certificate. (d) Has an empty X.509 certificate list. [The PKCS#7 message can be dumped into a file by passing the '-p' flag] (3) Generates a signed module by concatenating the old module, the PKCS#7 message, a descriptor and a magic string. The descriptor contains the size of the PKCS#7 message and indicates the id_type as PKEY_ID_PKCS7. (4) Either writes the signed module to the specified destination or renames it over the source module. This allows module signing to reuse the PKCS#7 handling code that was added for PE file parsing for signed kexec. Note that the utility is written in C and must be linked against the OpenSSL crypto library. Note further that I have temporarily dropped support for handling externally created signatures until we can work out the best way to do those. Hopefully, whoever creates the signature can give me a PKCS#7 certificate. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07PKCS#7: Allow detached data to be supplied for signature checking purposesDavid Howells
It is possible for a PKCS#7 message to have detached data. However, to verify the signatures on a PKCS#7 message, we have to be able to digest the data. Provide a function to supply that data. An error is given if the PKCS#7 message included embedded data. This is used in a subsequent patch to supply the data to module signing where the signature is in the form of a PKCS#7 message with detached data, whereby the detached data is the module content that is signed. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07X.509: Support X.509 lookup by Issuer+Serial form AuthorityKeyIdentifierDavid Howells
If an X.509 certificate has an AuthorityKeyIdentifier extension that provides an issuer and serialNumber, then make it so that these are used in preference to the keyIdentifier field also held therein for searching for the signing certificate. If both the issuer+serialNumber and the keyIdentifier are supplied, then the certificate is looked up by the former but the latter is checked as well. If the latter doesn't match the subjectKeyIdentifier of the parent certificate, EKEYREJECTED is returned. This makes it possible to chain X.509 certificates based on the issuer and serialNumber fields rather than on subjectKeyIdentifier. This is necessary as we are having to deal with keys that are represented by X.509 certificates that lack a subjectKeyIdentifier. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07X.509: Extract both parts of the AuthorityKeyIdentifierDavid Howells
Extract both parts of the AuthorityKeyIdentifier, not just the keyIdentifier, as the second part can be used to match X.509 certificates by issuer and serialNumber. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-08-07ASN.1: Copy string names to tokens in ASN.1 compilerDavid Howells
Copy string names to tokens in ASN.1 compiler rather than storing a pointer into the source text. This means we don't have to use "%*.*s" all over the place. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-07ASN.1: Add an ASN.1 compiler option to dump the element treeDavid Howells
Add an ASN.1 compiler option to dump the element tree to stdout. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com>
2015-08-07Merge tag 'asn1-fixes-20150805' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
2015-08-05ASN.1: Handle 'ANY OPTIONAL' in grammarDavid Howells
An ANY object in an ASN.1 grammar that is marked OPTIONAL should be skipped if there is no more data to be had. This can be tested by editing X.509 certificates or PKCS#7 messages to remove the NULL from subobjects that look like the following: SEQUENCE { OBJECT(2a864886f70d01010b); NULL(); } This is an algorithm identifier plus an optional parameter. The modified DER can be passed to one of: keyctl padd asymmetric "" @s </tmp/modified.x509 keyctl padd pkcs7_test foo @s </tmp/modified.pkcs7 It should work okay with the patch and produce EBADMSG without. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Marcel Holtmann <marcel@holtmann.org> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-05ASN.1: Fix non-match detection failure on data overrunDavid Howells
If the ASN.1 decoder is asked to parse a sequence of objects, non-optional matches get skipped if there's no more data to be had rather than a data-overrun error being reported. This is due to the code segment that decides whether to skip optional matches (ie. matches that could get ignored because an element is marked OPTIONAL in the grammar) due to a lack of data also skips non-optional elements if the data pointer has reached the end of the buffer. This can be tested with the data decoder for the new RSA akcipher algorithm that takes three non-optional integers. Currently, it skips the last integer if there is insufficient data. Without the fix, #defining DEBUG in asn1_decoder.c will show something like: next_op: pc=0/13 dp=0/270 C=0 J=0 - match? 30 30 00 - TAG: 30 266 CONS next_op: pc=2/13 dp=4/270 C=1 J=0 - match? 02 02 00 - TAG: 02 257 - LEAF: 257 next_op: pc=5/13 dp=265/270 C=1 J=0 - match? 02 02 00 - TAG: 02 3 - LEAF: 3 next_op: pc=8/13 dp=270/270 C=1 J=0 next_op: pc=11/13 dp=270/270 C=1 J=0 - end cons t=4 dp=270 l=270/270 The next_op line for pc=8/13 should be followed by a match line. This is not exploitable for X.509 certificates by means of shortening the message and fixing up the ASN.1 CONS tags because: (1) The relevant records being built up are cleared before use. (2) If the message is shortened sufficiently to remove the public key, the ASN.1 parse of the RSA key will fail quickly due to a lack of data. (3) Extracted signature data is either turned into MPIs (which cope with a 0 length) or is simpler integers specifying algoritms and suchlike (which can validly be 0); and (4) The AKID and SKID extensions are optional and their removal is handled without risking passing a NULL to asymmetric_key_generate_id(). (5) If the certificate is truncated sufficiently to remove the subject, issuer or serialNumber then the ASN.1 decoder will fail with a 'Cons stack underflow' return. This is not exploitable for PKCS#7 messages by means of removal of elements from such a message from the tail end of a sequence: (1) Any shortened X.509 certs embedded in the PKCS#7 message are survivable as detailed above. (2) The message digest content isn't used if it shows a NULL pointer, similarly, the authattrs aren't used if that shows a NULL pointer. (3) A missing signature results in a NULL MPI - which the MPI routines deal with. (4) If data is NULL, it is expected that the message has detached content and that is handled appropriately. (5) If the serialNumber is excised, the unconditional action associated with it will pick up the containing SEQUENCE instead, so no NULL pointer will be seen here. If both the issuer and the serialNumber are excised, the ASN.1 decode will fail with an 'Unexpected tag' return. In either case, there's no way to get to asymmetric_key_generate_id() with a NULL pointer. (6) Other fields are decoded to simple integers. Shortening the message to omit an algorithm ID field will cause checks on this to fail early in the verification process. This can also be tested by snipping objects off of the end of the ASN.1 stream such that mandatory tags are removed - or even from the end of internal SEQUENCEs. If any mandatory tag is missing, the error EBADMSG *should* be produced. Without this patch ERANGE or ENOPKG might be produced or the parse may apparently succeed, perhaps with ENOKEY or EKEYREJECTED being produced later, depending on what gets snipped. Just snipping off the final BIT_STRING or OCTET_STRING from either sample should be a start since both are mandatory and neither will cause an EBADMSG without the patches Reported-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Marcel Holtmann <marcel@holtmann.org> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-05ASN.1: Fix actions on CHOICE elements with IMPLICIT tagsDavid Howells
In an ASN.1 description where there is a CHOICE construct that contains elements with IMPLICIT tags that refer to constructed types, actions to be taken on those elements should be conditional on the corresponding element actually being matched. Currently, however, such actions are performed unconditionally in the middle of processing the CHOICE. For example, look at elements 'b' and 'e' here: A ::= SEQUENCE { CHOICE { b [0] IMPLICIT B ({ do_XXXXXXXXXXXX_b }), c [1] EXPLICIT C ({ do_XXXXXXXXXXXX_c }), d [2] EXPLICIT B ({ do_XXXXXXXXXXXX_d }), e [3] IMPLICIT C ({ do_XXXXXXXXXXXX_e }), f [4] IMPLICIT INTEGER ({ do_XXXXXXXXXXXX_f }) } } ({ do_XXXXXXXXXXXX_A }) B ::= SET OF OBJECT IDENTIFIER ({ do_XXXXXXXXXXXX_oid }) C ::= SET OF INTEGER ({ do_XXXXXXXXXXXX_int }) They each have an action (do_XXXXXXXXXXXX_b and do_XXXXXXXXXXXX_e) that should only be processed if that element is matched. The problem is that there's no easy place to hang the action off in the subclause (type B for element 'b' and type C for element 'e') because subclause opcode sequences can be shared. To fix this, introduce a conditional action opcode(ASN1_OP_MAYBE_ACT) that the decoder only processes if the preceding match was successful. This can be seen in an excerpt from the output of the fixed ASN.1 compiler for the above ASN.1 description: [ 13] = ASN1_OP_COND_MATCH_JUMP_OR_SKIP, // e [ 14] = _tagn(CONT, CONS, 3), [ 15] = _jump_target(45), // --> C [ 16] = ASN1_OP_MAYBE_ACT, [ 17] = _action(ACT_do_XXXXXXXXXXXX_e), In this, if the op at [13] is matched (ie. element 'e' above) then the action at [16] will be performed. However, if the op at [13] doesn't match or is skipped because it is conditional and some previous op matched, then the action at [16] will be ignored. Note that to make this work in the decoder, the ASN1_OP_RETURN op must set the flag to indicate that a match happened. This is necessary because the _jump_target() seen above introduces a subclause (in this case an object of type 'C') which is likely to alter the flag. Setting the flag here is okay because to process a subclause, a match must have happened and caused a jump. This cannot be tested with the code as it stands, but rather affects future code. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
2015-08-05ASN.1: Fix handling of CHOICE in ASN.1 compilerDavid Howells
Fix the handling of CHOICE types in the ASN.1 compiler to make SEQUENCE and SET elements in a CHOICE be correctly rendered as skippable and conditional as appropriate. For example, in the following ASN.1: Foo ::= SEQUENCE { w1 INTEGER, w2 Bar, w3 OBJECT IDENTIFIER } Bar ::= CHOICE { x1 Seq1, x2 [0] IMPLICIT OCTET STRING, x3 Seq2, x4 SET OF INTEGER } Seq1 ::= SEQUENCE { y1 INTEGER, y2 INTEGER, y3 INTEGER } Seq2 ::= SEQUENCE { z1 BOOLEAN, z2 BOOLEAN, z3 BOOLEAN } the output in foo.c generated by: ./scripts/asn1_compiler foo.asn1 foo.c foo.h included: // Bar // Seq1 [ 4] = ASN1_OP_MATCH, [ 5] = _tag(UNIV, CONS, SEQ), ... [ 13] = ASN1_OP_COND_MATCH_OR_SKIP, // x2 [ 14] = _tagn(CONT, PRIM, 0), // Seq2 [ 15] = ASN1_OP_MATCH, [ 16] = _tag(UNIV, CONS, SEQ), ... [ 24] = ASN1_OP_COND_MATCH_JUMP_OR_SKIP, // x4 [ 25] = _tag(UNIV, CONS, SET), ... [ 27] = ASN1_OP_COND_FAIL, as a result of the CHOICE - but this is wrong on lines 4 and 15 because both of these should be skippable (one and only one of the four can be picked) and the one on line 15 should also be conditional so that it is ignored if anything before it matches. After the patch, it looks like: // Bar // Seq1 [ 4] = ASN1_OP_MATCH_JUMP_OR_SKIP, // x1 [ 5] = _tag(UNIV, CONS, SEQ), ... [ 7] = ASN1_OP_COND_MATCH_OR_SKIP, // x2 [ 8] = _tagn(CONT, PRIM, 0), // Seq2 [ 9] = ASN1_OP_COND_MATCH_JUMP_OR_SKIP, // x3 [ 10] = _tag(UNIV, CONS, SEQ), ... [ 12] = ASN1_OP_COND_MATCH_JUMP_OR_SKIP, // x4 [ 13] = _tag(UNIV, CONS, SET), ... [ 15] = ASN1_OP_COND_FAIL, where all four options are skippable and the second, third and fourth are all conditional, as is the backstop at the end. This hasn't been a problem so far because in the ASN.1 specs we have are either using primitives or are using SET OF and SEQUENCE OF which are handled correctly. Whilst we're at it, also make sure that element labels get included in comments in the output for elements that have complex types. This cannot be tested with the code as it stands, but rather affects future code. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-By: David Woodhouse <David.Woodhouse@intel.com>
2015-07-28Yama: remove needless CONFIG_SECURITY_YAMA_STACKEDKees Cook
Now that minor LSMs can cleanly stack with major LSMs, remove the unneeded config for Yama to be made to explicitly stack. Just selecting the main Yama CONFIG will allow it to work, regardless of the major LSM. Since distros using Yama are already forcing it to stack, this is effectively a no-op change. Additionally add MAINTAINERS entry. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2015-07-20Merge tag 'seccomp-next' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux into next
2015-07-19Linux 4.2-rc3v4.2-rc3Linus Torvalds
2015-07-19Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "Two fairly simple fixes: one is a change that causes us to have a very low queue depth leading to performance issues and the other is a null deref occasionally in tapes thanks to use after put" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: fix host max depth checking for the 'queue_depth' sysfs interface st: null pointer dereference panic caused by use after kref_put by st_open
2015-07-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Another round of MIPS fixes for 4.2. Things are looking quite decent at this stage but the recent work on the FPU support took its toll: - fix an incorrect overly restrictive ifdef - select O32 64-bit FP support for O32 binary compatibility - remove workarounds for Sibyte SB1250 Pass1 parts. There are rare fixing the workarounds is not worth the effort. - patch up an outdated and now incorrect comment" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: fpu.h: Allow 64-bit FPU on a 64-bit MIPS R6 CPU MIPS: SB1: Remove support for Pass 1 parts. MIPS: Require O32 FP64 support for MIPS64 with O32 compat MIPS: asm-offset.c: Patch up various comments refering to the old filename.
2015-07-19Merge branch 'parisc-4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fix from Helge Deller: "A memory leak fix from Christophe Jaillet which was introduced with kernel 4.0 and which leads to kernel crashes on parisc after 1-3 days" * 'parisc-4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: mm: Fix a memory leak related to pmd not attached to the pgd
2015-07-19Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "By far most of the fixes here are updates to DTS files to deal with some mostly minor bugs. There's also a fix to deal with non-PM kernel configs on i.MX, a regression fix for ethernet on PXA platforms and a dependency fix for OMAP" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: keystone: dts: rename pcie nodes to help override status ARM: keystone: dts: fix dt bindings for PCIe ARM: pxa: fix dm9000 platform data regression ARM: dts: Correct audio input route & set mic bias for am335x-pepper ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX MAINTAINERS: digicolor: add dts files ARM: ux500: fix MMC/SD card regression ARM: ux500: define serial port aliases ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs ARM: dts: Fix frequency scaling on Gumstix Pepper ARM: dts: configure regulators for Gumstix Pepper ARM: dts: omap3: overo: Update LCD panel names ARM: dts: cros-ec-keyboard: Add support for some Japanese keys ARM: imx6: gpc: always enable PU domain if CONFIG_PM is not set ARM: dts: imx53-qsb: fix TVE entry ARM: dts: mx23: fix iio-hwmon support ARM: dts: imx27: Adjust the GPT compatible string ARM: socfpga: dts: Fix entries order ARM: socfpga: dts: Fix adxl34x formating and compatible string
2015-07-19MIPS: fpu.h: Allow 64-bit FPU on a 64-bit MIPS R6 CPUMarkos Chandras
Commit 6134d94923d0 ("MIPS: asm: fpu: Allow 64-bit FPU on MIPS32 R6") added support for 64-bit FPU on a 32-bit MIPS R6 processor but it missed the 64-bit CPU case leading to FPU failures when requesting FR=1 mode (which is always the case for MIPS R6 userland) when running a 32-bit kernel on a 64-bit CPU. We also fix the MIPS R2 case. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Fixes: 6134d94923d0 ("MIPS: asm: fpu: Allow 64-bit FPU on MIPS32 R6") Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: <stable@vger.kernel.org> # 4.0+ Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10734/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-19parisc: mm: Fix a memory leak related to pmd not attached to the pgdChristophe Jaillet
Commit 0e0da48dee8d ("parisc: mm: don't count preallocated pmds") introduced a memory leak. After this commit, the 'return' statement in pmd_free is executed in all cases. Even for pmd that are not attached to the pgd. So 'free_pages' can never be called anymore, leading to a memory leak. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v4.0+ Signed-off-by: Helge Deller <deller@gmx.de>
2015-07-18Merge tag 'pxa-fixes-v4.2-rc2' of https://github.com/rjarzmik/linux into fixesDOlof Johansson
Merge "pxa fixes for v4.2" from Robert Jarzmik: ARM: pxa: fixes for v4.2-rc2 This single fix reenables ethernet cards for several pxa boards, broken by regulator addition to dm9000 driver. * tag 'pxa-fixes-v4.2-rc2' of https://github.com/rjarzmik/linux: ARM: pxa: fix dm9000 platform data regression
2015-07-18Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A small set of ARM fixes for -rc3, most of them not far off one-liners, with the exception of fixing the V7 cache invalidation for incoming SMP processors which was causing problems for SoCFPGA devices" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: fix __virt_to_idmap build error on !MMU ARM: invalidate L1 before enabling coherency ARM: 8404/1: dma-mapping: fix off-by-one error in bitmap size check ARM: 8402/1: perf: Don't use of_node after putting it ARM: 8400/1: use virt_to_idmap to get phys_reset address
2015-07-18Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Two families of fixes: - Fix an FPU context related boot crash on newer x86 hardware with larger context sizes than what most people test. To fix this without ugly kludges or extensive reverts we had to touch core task allocator, to allow x86 to determine the task size dynamically, at boot time. I've tested it on a number of x86 platforms, and I cross-built it to a handful of architectures: (warns) (warns) testing x86-64: -git: pass ( 0), -tip: pass ( 0) testing x86-32: -git: pass ( 0), -tip: pass ( 0) testing arm: -git: pass ( 1359), -tip: pass ( 1359) testing cris: -git: pass ( 1031), -tip: pass ( 1031) testing m32r: -git: pass ( 1135), -tip: pass ( 1135) testing m68k: -git: pass ( 1471), -tip: pass ( 1471) testing mips: -git: pass ( 1162), -tip: pass ( 1162) testing mn10300: -git: pass ( 1058), -tip: pass ( 1058) testing parisc: -git: pass ( 1846), -tip: pass ( 1846) testing sparc: -git: pass ( 1185), -tip: pass ( 1185) ... so I hope the cross-arch impact 'none', as intended. (by Dave Hansen) - Fix various NMI handling related bugs unearthed by the big asm code rewrite and generally make the NMI code more robust and more maintainable while at it. These changes are a bit late in the cycle, I hope they are still acceptable. (by Andy Lutomirski)" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it on x86 x86/fpu, sched: Dynamically allocate 'struct fpu' x86/entry/64, x86/nmi/64: Add CONFIG_DEBUG_ENTRY NMI testing code x86/nmi/64: Make the "NMI executing" variable more consistent x86/nmi/64: Minor asm simplification x86/nmi/64: Use DF to avoid userspace RSP confusing nested NMI detection x86/nmi/64: Reorder nested NMI checks x86/nmi/64: Improve nested NMI comments x86/nmi/64: Switch stacks on userspace NMI entry x86/nmi/64: Remove asm code that saves CR2 x86/nmi: Enable nested do_nmi() handling for 64-bit kernels
2015-07-18Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Ingo Molnar: "Fix for a misplaced export that can cause build failures in certain (rare) Kconfig situations" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Move the export of tick_broadcast_oneshot_control to the proper place
2015-07-18Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Ingo Molnar: "A oneliner rq throttling fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Test list head instead of list entry in throttle_cfs_rq()
2015-07-18Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus a static key fix fixing /sys/devices/cpu/rdpmc" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Really allow to specify custom CC, AR or LD perf auxtrace: Fix misplaced check for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORT perf hists browser: Take the --comm, --dsos, etc filters into account perf symbols: Store if there is a filter in place x86, perf: Fix static_key bug in load_mm_cr4() tools: Copy lib/hweight.c from the kernel sources perf tools: Fix the detached tarball wrt rbtree copy perf thread_map: Fix the sizeof() calculation for map entries tools lib: Improve clean target perf stat: Fix shadow declaration of close perf tools: Fix lockup using 32-bit compat vdso
2015-07-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Ingo Molnar: "Misc irq fixes: - two driver fixes - a Xen regression fix - a nested irq thread crash fix" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/gicv3-its: Fix mapping of LPIs to collections genirq: Prevent resend to interrupts marked IRQ_NESTED_THREAD genirq: Revert sparse irq locking around __cpu_up() and move it to x86 for now gpio/davinci: Fix race in installing chained irq handler
2015-07-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "25 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits) lib/decompress: set the compressor name to NULL on error mm/cma_debug: correct size input to bitmap function mm/cma_debug: fix debugging alloc/free interface mm/page_owner: set correct gfp_mask on page_owner mm/page_owner: fix possible access violation fsnotify: fix oops in fsnotify_clear_marks_by_group_flags() /proc/$PID/cmdline: fixup empty ARGV case dma-debug: skip debug_dma_assert_idle() when disabled hexdump: fix for non-aligned buffers checkpatch: fix long line messages about patch context mm: clean up per architecture MM hook header files MAINTAINERS: uclinux-h8-devel is moderated for non-subscribers mailmap: update Sudeep Holla's email id Update Viresh Kumar's email address mm, meminit: suppress unused memory variable warning configfs: fix kernel infoleak through user-controlled format string include, lib: add __printf attributes to several function prototypes s390/hugetlb: add hugepages_supported define mm: hugetlb: allow hugepages_supported to be architecture specific revert "s390/mm: make hugepages_supported a boot time decision" ...
2015-07-17Merge branch 'for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "These are all from Filipe, and cover a few problems we've had reported on the list recently (along with ones he found on his own)" * 'for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix file corruption after cloning inline extents Btrfs: fix order by which delayed references are run Btrfs: fix list transaction->pending_ordered corruption Btrfs: fix memory leak in the extent_same ioctl Btrfs: fix shrinking truncate when the no_holes feature is enabled
2015-07-17Merge tag 'rtc-v4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull rtc fixes from Alexandre Belloni: "A few fixes for the RTC susbsystem for 4.2. The mt6397 driver was introduce in 4.2 so it is worth fixing before the final release. I though the compilation warning for armada38x was fixed by akpm in commit f98b733e93e0 ("rtc-armada38x.c: remove unused local `flags'") but he actually missed some occurrences of the variables. Since I received 4 patches for that, I think we can include it now. Summary: - fix mt6397 wakealarm creation - remove a compilation warning for armada38x that was forgotten" * tag 'rtc-v4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: rtc: armada38x: Remove unused variable from armada38x_rtc_set_time() rtc: mt6397: enable wakeup before registering rtc device
2015-07-17Merge tag 'dm-4.2-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: - revert a request-based DM core change that caused IO latency to increase and adversely impact both throughput and system load - fix for a use after free bug in DM core's device cleanup - a couple DM btree removal fixes (used by dm-thinp) - a DM thinp fix for order-5 allocation failure - a DM thinp fix to not degrade to read-only metadata mode when in out-of-data-space mode for longer than the 'no_space_timeout' - fix a long-standing oversight in both dm-thinp and dm-cache by now exporting 'needs_check' in status if it was set in metadata - fix an embarrassing dm-cache busy-loop that caused worker threads to eat cpu even if no IO was actively being issued to the cache device * tag 'dm-4.2-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache: avoid calls to prealloc_free_structs() if possible dm cache: avoid preallocation if no work in writeback_some_dirty_blocks() dm cache: do not wake_worker() in free_migration() dm cache: display 'needs_check' in status if it is set dm thin: display 'needs_check' in status if it is set dm thin: stay in out-of-data-space mode once no_space_timeout expires dm: fix use after free crash due to incorrect cleanup sequence Revert "dm: only run the queue on completion if congested or no requests pending" dm btree: silence lockdep lock inversion in dm_btree_del() dm thin: allocate the cell_sort_array dynamically dm btree remove: fix bug in redistribute3
2015-07-18x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it ↵Ingo Molnar
on x86 Don't burden architectures without dynamic task_struct sizing with the overhead of dynamic sizing. Also optimize the x86 code a bit by caching task_struct_size. Acked-and-Tested-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-3-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-18x86/fpu, sched: Dynamically allocate 'struct fpu'Dave Hansen
The FPU rewrite removed the dynamic allocations of 'struct fpu'. But, this potentially wastes massive amounts of memory (2k per task on systems that do not have AVX-512 for instance). Instead of having a separate slab, this patch just appends the space that we need to the 'task_struct' which we dynamically allocate already. This saves from doing an extra slab allocation at fork(). The only real downside here is that we have to stick everything and the end of the task_struct. But, I think the BUILD_BUG_ON()s I stuck in there should keep that from being too fragile. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-2-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
