2008-07-26[PATCH] preparation to __user_walk_fd cleanupAl Viro
Almost all users __user_walk_fd() and friends care only about struct path. Get rid of the few that do not. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] kill nameidata passing to permission(), rename to inode_permission()Al Viro
Incidentally, the name that gives hundreds of false positives on grep is not a good idea... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] take noexec checks to very few callers that careAl Viro
2008-07-26Re: [PATCH 3/6] vfs: open_exec cleanupChristoph Hellwig
On Mon, May 19, 2008 at 12:01:49AM +0200, Marcin Slusarz wrote: > open_exec is needlessly indented, calls ERR_PTR with 0 argument > (which is not valid errno) and jumps into middle of function > just to return value. > So clean it up a bit. Still looks rather messy. See below for a better version. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 4/4] vfs: immutable inode checking cleanupMiklos Szeredi
Move the immutable and append-only checks from chmod, chown and utimes into notify_change(). Checks for immutable and append-only files are always performed by the VFS and not by the filesystem (see permission() and may_...() in namei.c), so these belong in notify_change(), and not in inode_change_ok(). This should be completely equivalent. CC: Ulrich Drepper <drepper@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 3/4] fat: dont call notify_changeMiklos Szeredi
The FAT_IOCTL_SET_ATTRIBUTES ioctl() calls notify_change() to change the file mode before changing the inode attributes. Replace with explicit calls to security_inode_setattr(), fat_setattr() and fsnotify_change(). This is equivalent to the original. The reason it is needed, is that later in the series we move the immutable check into notify_change(). That would break the FAT_IOCTL_SET_ATTRIBUTES ioctl, as it needs to perform the mode change regardless of the immutability of the file. [Fix error if fat is built as a module. Thanks to OGAWA Hirofumi for noticing.] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 2/4] vfs: utimes cleanupMiklos Szeredi
Untange the mess that is do_utimes(). Add kerneldoc comment to do_utimes(). CC: Ulrich Drepper <drepper@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 1/4] vfs: utimes: move owner check into inode_change_ok()Miklos Szeredi
Add a new ia_valid flag: ATTR_TIMES_SET, to handle the UTIMES_OMIT/UTIMES_NOW and UTIMES_NOW/UTIMES_OMIT cases. In these cases neither ATTR_MTIME_SET nor ATTR_ATIME_SET is in the flags, yet the POSIX draft specifies that permission checking is performed the same way as if one or both of the times was explicitly set to a timestamp. See the path "vfs: utimensat(): fix error checking for {UTIME_NOW,UTIME_OMIT} case" by Michael Kerrisk for the patch introducing this behavior. This is a cleanup, as well as allowing filesystems (NFS/fuse/...) to perform their own permission checking instead of the default. CC: Ulrich Drepper <drepper@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] vfs: use kstrdup() and check failing allocationLi Zefan
- use kstrdup() instead of kmalloc() + memcpy() - return NULL if allocating ->mnt_devname failed - mnt_devname should be const Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] more nameidata removal: exec_permission_lite() doesn't need itAl Viro
2008-07-26[PATCH] pass MAY_OPEN to vfs_permission() explicitlyAl Viro
... and get rid of the last "let's deduce mask from nameidata->flags" bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] fix MAY_CHDIR/MAY_ACCESS/LOOKUP_ACCESS messAl Viro
* MAY_CHDIR is redundant - it's an equivalent of MAY_ACCESS * MAY_ACCESS on fuse should affect only the last step of pathname resolution * fchdir() and chroot() should pass MAY_ACCESS, for the same reason why chdir() needs that. * now that we pass MAY_ACCESS explicitly in all cases, LOOKUP_ACCESS can be removed; it has no business being in nameidata. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] permission checks for chdir need special treatment only on the last stepAl Viro
... so we ought to pass MAY_CHDIR to vfs_permission() instead of having it triggered on every step of preceding pathname resolution. LOOKUP_CHDIR is killed by that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 5/5] vfs: remove mode parameter from vfs_symlink()Miklos Szeredi
Remove the unused mode parameter from vfs_symlink and callers. Thanks to Tetsuo Handa for noticing. CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[patch 4/5] vfs: reuse local variable in vfs_link()Tetsuo Handa
Why not reuse "inode" which is assigned as struct inode *inode = old_dentry->d_inode; in the beginning of vfs_link() ? Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[patch 3/5] vfs: change remove_suid() to file_remove_suid()Miklos Szeredi
All calls to remove_suid() are made with a file pointer, because (similarly to file_update_time) it is called when the file is written. Clean up callers by passing in a file instead of a dentry. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[patch 1/5] vfs: truncate: dont check immutable twiceMiklos Szeredi
vfs_permission(MAY_WRITE) already checked for the inode being immutable, so no need to repeat it. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 05/14] hpfs: dont call permission()Miklos Szeredi
hpfs_unlink() calls permission() prior to truncating the file. HPFS doesn't define a .permission method, so replace with explicit call to generic_permission(). This is equivalent, except that devcgroup_inode_permission() and security_inode_permission() are not called. The truncation is just an implementation detail of the unlink, so these security checks are unnecessary. I suspect that even calling generic_permission() is unnecessary, since we shouldn't mind if the file isn't writable. But I leave that to the maintainer to decide. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
2008-07-26[PATCH] sanitize proc_sysctlAl Viro
* keep references to ctl_table_head and ctl_table in /proc/sys inodes * grab the former during operations, use the latter for access to entry if that succeeds * have ->d_compare() check if table should be seen for one who does lookup; that allows us to avoid flipping inodes - if we have the same name resolve to different things, we'll just keep several dentries and ->d_compare() will reject the wrong ones. * have ->lookup() and ->readdir() scan the table of our inode first, then walk all ctl_table_header and scan ->attached_by for those that are attached to our directory. * implement ->getattr(). * get rid of insane amounts of tree-walking * get rid of the need to know dentry in ->permission() and of the contortions induced by that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sysctl: keep track of tree relationshipsAl Viro
In a sense, that's the heart of the series. It's based on the following property of the trees we are actually asked to add: they can be split into stem that is already covered by registered trees and crown that is entirely new. IOW, if a/b and a/c/d are introduced by our tree, then a/c is also introduced by it. That allows to associate tree and table entry with each node in the union; while directory nodes might be covered by many trees, only one will cover the node by its crown. And that will allow much saner logics for /proc/sys in the next patches. This patch introduces the data structures needed to keep track of that. When adding a sysctl table, we find a "parent" one. Which is to say, find the deepest node on its stem that already is present in one of the tables from our table set or its ancestor sets. That table will be our parent and that node in it - attachment point. Add our table to list anchored in parent, have it refer the parent and contents of attachment point. Also remember where its crown lives. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sysctl: make sure that /proc/sys/net/ipv4 appears before per-ns onesAl Viro
Massage ipv4 initialization - make sure that net.ipv4 appears as non-per-net-namespace before it shows up in per-net-namespace sysctls. That's the only change outside of sysctl.c needed to get sane ordering rules and data structures for sysctls (esp. for procfs side of that mess). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] allow delayed freeing of ctl_table_headerAl Viro
Refcount the sucker; instead of freeing it by the end of unregistration just drop the refcount and free only when it hits zero. Make sure that we _always_ make ->unregistering non-NULL in start_unregistering(). That allows anybody to get a reference to such puppy, preventing its freeing and reuse. It does *not* block unregistration. Anybody who holds such a reference can * try to grab a "use" reference (ctl_head_grab()); that will succeeds if and only if it hadn't entered unregistration yet. If it succeeds, we can use it in all normal ways until we release the "use" reference (with ctl_head_finish()). Note that this relies on having ->unregistering become non-NULL in all cases when one starts to unregister the sucker. * keep pointers to ctl_table entries; they *can* be freed if the entire thing is unregistered. However, if ctl_head_grab() succeeds, we know that unregistration had not happened (and will not happen until ctl_head_finish()) and such pointers can be used safely. IOW, now we can have inodes under /proc/sys keep references to ctl_table entries, protecting them with references to ctl_table_header and grabbing the latter for the duration of operations that require access to ctl_table. That won't cause deadlocks, since unregistration will not be stopped by mere keeping a reference to ctl_table_header. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] beginning of sysctl cleanup - ctl_table_setAl Viro
New object: set of sysctls [currently - root and per-net-ns]. Contains: pointer to parent set, list of tables and "should I see this set?" method (->is_seen(set)). Current lists of tables are subsumed by that; net-ns contains such a beast. ->lookup() for ctl_table_root returns pointer to ctl_table_set instead of that to ->list of that ctl_table_set. [folded compile fixes by rdd for configs without sysctl] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch] hppfs: remove hppfs_permissionMiklos Szeredi
hppfs_permission() is equivalent to the '.permission == NULL' case. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] reuse xxx_fifo_fops for xxx_pipe_fopsDenys Vlasenko
Merge fifo and pipe file_operations. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch] vfs: fix lookup on deleted directoryMiklos Szeredi
Lookup can install a child dentry for a deleted directory. This keeps the directory dentry alive, and the inode pinned in the cache and on disk, even after all external references have gone away. This isn't a big problem normally, since memory pressure or umount will clear out the directory dentry and its children, releasing the inode. But for UBIFS this causes problems because its orphan area can overflow. Fix this by returning ENOENT for all lookups on a S_DEAD directory before creating a child dentry. Thanks to Zoltan Sogor for noticing this while testing UBIFS, and Artem for the excellent analysis of the problem and testing. Reported-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ftrace: fix modular build ftrace: disable tracing on acpi idle calls ftrace: remove latency-tracer leftover ftrace: only trace preempt off with preempt tracer ftrace: fix 4d3702b6 (post-v2.6.26): WARNING: at kernel/lockdep.c:2731 check_flags (ftrace)
2008-07-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, AMD IOMMU: include amd_iommu_last_bdf in device initialization x86: fix IBM Summit based systems' phys_cpu_present_map on 32-bit kernels x86, RDC321x: remove gpio.h complications x86, RDC321x: add to mach-default crashdump: fix undefined reference to `elfcorehdr_addr' flag parameters: fix compile error of sys_epoll_create1
2008-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (30 commits) Blackfin arch: If we double fault, rather than hang forever, reset Blackfin arch: When icache is off, make sure people know it Blackfin arch: Fix bug - skip single step in high priority interrupt handler instead of disabling all interrupts in single step debugging. Blackfin arch: cache the values of vco/sclk/cclk as the overhead of doing so (~24 bytes) is worth avoiding the software mult/div routines Blackfin arch: fix bug - IMDMA is not type struct dma_register Blackfin arch: check the EXTBANKS field of the DDRCTL1 register to see if we are using both memory banks Blackfin arch: Apply Bluetechnix CM-BF527 board support patch Blackfin arch: Add unwinding for stack info, and a little more detail on trace buffer Blackfin arch: Add ISP1760 board resources to BF548-EZKIT Blackfin arch: fix bug - detect 0.1 silicon revision BF527-EZKIT as 0.0 version Blackfin arch: add missing IORESOURCE_MEM flags to UART3 Blackfin arch: Add return value check in bfin_sir_probe(), remove SSYNC(). Blackfin arch: Extend sram malloc to handle L2 SRAM. Blackfin arch: Remove useless config option. Blackfin arch: change L1 malloc to base on slab cache and lists. Blackfin arch: use local labels and ENDPROC() markings Blackfin arch: Do not need this dualcore test module in kernel. Blackfin arch: Allow ptrace to peek and poke application data in L1 data SRAM. Blackfin arch: Add ANOMALY_05000368 workaround Blackfin arch: Functional power management support ...
2008-07-26dsp56k: Fix BKL pushdownGeert Uytterhoeven
commit 236b8756a2b6f90498d45b2c36d43e5372f2d4b8 ("dsp56k: BKL pushdown") removed the `struct inode *inode' parameter from dsp56k_ioctl(), but forgot to update the use of `inode' in the first line of the function. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26drivers/video/fbmem.c: removed duplicated includeHuang Weiyi
Removed duplicated include <linux/major.h> in drivers/video/fbmem.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: When verifying the decoded header before decoding the object identifier [CIFS] Fix warnings from checkpatch [CIFS] Fix improper endian conversion of ACL subauth field [CIFS] Fix possible double free if search immediately after search rewind fails [CIFS] remove checkpatch warning Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> cifs: assorted endian annotations [CIFS] break ATTR_SIZE changes out into their own function lockdep: annotate cifs in-kernel sockets [CIFS] Fix compiler warning on 64-bit
2008-07-26video/stifb.c: make 2 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - stifb_init_fb() - stifb_init() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26video/console/stico{n,re}.c: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - sticon.c: sticonsole_init() - sticore.c: struct default_sti - sticore.c: sti_init_graph() - sticore.c: sti_inq_conf() - sticore.c: sti_rom_copy() - sticore.c: sti_select_fbfont() - sticore.c: sti_select_font() - sticore.c: sti_get_wmode_rom() - sticore.c: sti_read_rom() [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make macfb_setup() staticAdrian Bunk
This patch makes the needlessly global macfb_setup() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make init/do_mounts.c:root_device_name staticAdrian Bunk
This patch makes the needlessly global root_device_name static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26drivers/char/rtc.c: make 2 functions staticAdrian Bunk
The following functions can now become static: - rtc_interrupt() - rtc_get_rtc_time() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Bernhard Walle <bwalle@suse.de> Acked-by: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm/swapfile.c: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - swap_lock - nr_swapfiles - struct swap_list Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make mm/memory.c:print_bad_pte() staticAdrian Bunk
This patch makes the needlessly global print_bad_pte() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26mm/allocpercpu.c: make 4 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - percpu_depopulate() - __percpu_depopulate_mask() - percpu_populate() - __percpu_populate_mask() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make mm/sparse.c: make a function staticAdrian Bunk
This patch makes the needlessly global sparse_early_mem_map_alloc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make parport_cs_release() staticAdrian Bunk
This patch makes the needlessly global parport_cs_release() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make pnp_add_card_id() staticAdrian Bunk
pnp_add_card_id() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Rene Herman <rene.herman@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26make cgroup_seqfile_release() staticAdrian Bunk
cgroup_seqfile_release() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26drm: make drm_minors_cleanup() staticAdrian Bunk
Make the needlessly global drm_minors_cleanup() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26cris: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26frv: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free pages, printed by show_free_areas() where show_mem() calls show_free_areas(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26m32r: use generic show_mem()Johannes Weiner
Remove arch-specific show_mem() in favor of the generic version. This also removes the following redundant information display: - free swap pages, printed by show_swap_cache_info() - pages in swapcache, printed by show_swap_cache_info() where show_mem() calls show_free_areas(), which calls show_swap_cache_info(). Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
