2007-10-20spelling fixes: Documentation/Simon Arlott
Spelling fixes in Documentation/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: lib/Simon Arlott
Spelling fix in lib/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: init/Simon Arlott
Spelling fix in init/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: mm/Simon Arlott
Spelling fixes in mm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/x86_64/Simon Arlott
Spelling fixes in arch/x86_64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/v850/Simon Arlott
Spelling fixes in arch/v850/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/um/Simon Arlott
Spelling fixes in arch/um/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/m68k/Simon Arlott
Spelling fixes in arch/m68k/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/m32r/Simon Arlott
Spelling fixes in arch/m32r/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/i386/Simon Arlott
Spelling fixes in arch/i386/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/h8300/Simon Arlott
Spelling fixes in arch/h8300/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/frv/Simon Arlott
Spelling fixes in arch/frv/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/cris/Simon Arlott
Spelling fixes in arch/cris/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20spelling fixes: arch/alpha/Simon Arlott
Spelling fixes in arch/alpha/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20pata_cmd64x.c typo fixAdrian Bunk
Spotted by David Miller <davem@davemloft.net>. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20remove duplicate MMAPPER Kconfig optionAdrian Bunk
This option is already in arch/um/Kconfig.char Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Jeff Dike <jdike@addtoit.com>
2007-10-20fix up security_socket_getpeersec_* documentationSerge Hallyn
Update the security_socket_peersec documentation in include/linux/security.h. security_socket_peersec has been split into two functions - _stream and _dgram, with new capabilities. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20changed emailJohann Deneux
Changed email address of Johann Deneux (myself) Also removed CVS tags in comments (no longer using cvs) Signed-off-by: Johann Deneux <johann.deneux@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20powerpc: Remove obsolete prototypeJulio M. Merino Vidal
The include/asm-powerpc/paca.h file has a prototype for a function that does not exist any more; its name is setup_boot_paca. This function was removed in commit 4ba99b97dadd35b9ce1438b2bc7c992a4a14a8b1, so its prototype should have been removed at that time too. Signed-off-by: Julio M. Merino Vidal <jmerino@ac.upc.edu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20trivial comment wording/typo fix regarding taint flagsDaniel Roesen
Signed-off-by: Daniel Roesen <dr@cluenet.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20LIB: Replace inappropriate include of <linux/bug.h>Robert P. J. Day
Replace an irrelevant include of bug.h with the more appropriate includes of slab.h and module.h. it's not as if the original inclusion is an error, it's simply not related to the contents of that source file, while the other two are. compile-tested on i386. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20H8300: Typo: "buildin" -> "builtin"Robert P. J. Day
2007-10-20Documentation: Remove unreferenced "blkmtd_*" parmsRobert P. J. Day
2007-10-20XTENSA: Emphasize that the "eth" boot-time parm takes a valueRobert P. J. Day
2007-10-20BOOT: Show that no_ipi_broadcast() takes a parameter.Robert P. J. Day
a rather obvious fix given the opening of the function: ... static __init int no_ipi_broadcast(char *str) { get_option(&str, &no_broadcast); ... Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation: Add nested versions of mutex locks to docsRobert P. J. Day
2007-10-20Documentation: Remove reference to non-existent "unwind_debug" kernel parmRobert P. J. Day
2007-10-20Documentation: Fix erroneous "dmascc=" documentationRobert P. J. Day
2007-10-20Documentation: Remove references to dead "eda" and "edb" kernel parmsRobert P. J. Day
2007-10-20Documentation: Remove references to dead "cyclades=" boot optionRobert P. J. Day
2007-10-19Documentation: Remove reference to non-existent "applicom" kernel parmRobert P. J. Day
2007-10-19Documentation: Remove references to dead "noasync" kernel parmRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove reference to dead "lasi" kernel parmRobert P. J. Day
2007-10-19Documentation: Delete final reference to "sg_def_reserved_size" kernel parmRobert P. J. Day
given the following: $ grep -rw sg_def_reserved_size * Documentation/kernel-parameters.txt: sg_def_reserved_size= [SCSI] $ that kernel parameter looks exceedingly dead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove remaining useless reference to acpi_fake_ecdtRobert P. J. Day
>From commit cd8c93a4e04dce8f00d1ef3a476aac8bd65ae40b: "Similar functionality was turned on by acpi_fake_ecdt=1 command line before. Now it is on all the time." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Spelling fix: explicitlyJean Delvare
From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19more UTF-8 conversionsMarcin Garski
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Delete dead OSS-related kernel parameter.Robert P. J. Day
Since the OSS-related "sb" kernel parameter doesn't seem to be supported, drop its reference from the kernel-parameters.txt file. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Drop reference to dead "eicon" kernel paramter.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Armin Schindler <armin@melware.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Drop the superfluous test for an old version of gcc.Robert P. J. Day
The header file <linux/compiler.h> already enforces a suitably recent version of gcc, so there's no point checking for that again. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Remove long-dead commented-out MODULE_PARM reference.Robert P. J. Day
Remove the useless comment referring to the obsolete MODULE_PARM macro. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Explain clearly why kmalloc() can't use __GFP_HIGHMEM.Robert P. J. Day
Fix the wishy-washy comment to clearly explain why kmalloc() can't use the __GFP_HIGHMEM zone modifier. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19crypto: convert crypto.h to UTF-8John Anthony Kazos Jr
Convert the encoding of <include/linux/crypto.h> from ISO-8859-1 to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19crypto: convert "crypto" subdirectory to UTF-8John Anthony Kazos Jr
Convert the subdirectory "crypto" to UTF-8. The files changed are <crypto/fcrypt.c> and <crypto/api.c>. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19fix typos in drivers/block/KconfigPatrick Ringl
2007-10-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (41 commits) ACPICA: hw: Don't carry spinlock over suspend ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write} ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidle ACPI: clean up acpi_enter_sleep_state_prep Hibernation: Make sure that ACPI is enabled in acpi_hibernation_finish ACPI: suppress uninitialized var warning cpuidle: consolidate 2.6.22 cpuidle branch into one patch ACPI: thinkpad-acpi: skip blanks before the data when parsing sysfs ACPI: AC: Add sysfs interface ACPI: SBS: Add sysfs alarm ACPI: SBS: Add ACPI_PROCFS around procfs handling code. ACPI: SBS: Add support for power_supply class (and sysfs) ACPI: SBS: Make SBS reads table-driven. ACPI: SBS: Simplify data structures in SBS ACPI: SBS: Split host controller (ACPI0001) from SBS driver (ACPI0002) ACPI: EC: Add new query handler to list head. ACPI: Add acpi_bus_generate_event4() function ACPI: Battery: add sysfs alarm ACPI: Battery: Add sysfs support ACPI: Battery: Misc clean-ups, no functional changes ... Fix up conflicts in drivers/misc/thinkpad_acpi.[ch] manually
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: fix guest time accounting going faster than user time accounting
2007-10-19Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Delete totally outdated Documentation/mips/time.README [MIPS] Kill duplicated setup_irq() for cp0 timer [MIPS] Sibyte: Finish conversion to modern time APIs. [MIPS] time: Helpers to compute clocksource/event shift and mult values. [MIPS] SMTC: Build fix. [MIPS] time: Delete dead code. [MIPS] MIPSsim: Strip defconfig file to the bones.
