To allow layout driver to pass private information around
pg_init/pg_doio.
Signed-off-by: Peng Tao <tao.peng@emc.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
since the only user of nfs4_proc_layoutget is send_layoutget, which
ignores its return value, there is no reason to return any value.
Signed-off-by: Idan Kedar <idank@tonian.com>
Signed-off-by: Benny Halevy <bhalevy@tonian.com>
we have encountered a bug whereby reading a lot of files (copying
fedora's /bin) from a pNFS mount and hitting Ctrl+C in the middle caused
a general protection fault in xdr_shrink_bufhead. this function is
called when decoding the response from LAYOUTGET. the decoding is done
by a worker thread, and the caller of LAYOUTGET waits for the worker
thread to complete.
hitting Ctrl+C caused the synchronous wait to end and the next thing the
caller does is to free the pages, so when the worker thread calls
xdr_shrink_bufhead, the pages are gone. therefore, the cleanup of these
pages has been moved to nfs4_layoutget_release.
Cc: stable@vger.kernel.org
...and ensure that we tear down the nfs_commit_data cache too when
unloading the module.
Cc: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull irqdomain changes from Grant Likely:
"Round of refactoring and enhancements to irq_domain infrastructure.
This series starts the process of simplifying irqdomain. The ultimate
goal is to merge LEGACY, LINEAR and TREE mappings into a single
system, but had to back off from that after some last minute bugs.
Instead it mainly reorganizes the code and ensures that the reverse
map gets populated when the irq is mapped instead of the first time it
is looked up.
Merging of the irq_domain types is deferred to v3.7
In other news, this series adds helpers for creating static mappings
on a linear or tree mapping."
* tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6:
irqdomain: Improve diagnostics when a domain mapping fails
irqdomain: eliminate slow-path revmap lookups
irqdomain: Fix irq_create_direct_mapping() to test irq_domain type.
irqdomain: Eliminate dedicated radix lookup functions
irqdomain: Support for static IRQ mapping and association.
irqdomain: Always update revmap when setting up a virq
irqdomain: Split disassociating code into separate function
irq_domain: correct a minor wrong comment for linear revmap
irq_domain: Standardise legacy/linear domain selection
irqdomain: Make ops->map hook optional
irqdomain: Remove unnecessary test for IRQ_DOMAIN_MAP_LEGACY
irqdomain: Simple NUMA awareness.
devicetree: add helper inline for retrieving a node's full name
Merge Andrew's second set of patches:
- MM
- a few random fixes
- a couple of RTC leftovers
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
rtc/rtc-88pm80x: remove unneed devm_kfree
rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails
mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables
tmpfs: distribute interleave better across nodes
mm: remove redundant initialization
mm: warn if pg_data_t isn't initialized with zero
mips: zero out pg_data_t when it's allocated
memcg: gix memory accounting scalability in shrink_page_list
mm/sparse: remove index_init_lock
mm/sparse: more checks on mem_section number
mm/sparse: optimize sparse_index_alloc
memcg: add mem_cgroup_from_css() helper
memcg: further prevent OOM with too many dirty pages
memcg: prevent OOM with too many dirty pages
mm: mmu_notifier: fix freed page still mapped in secondary MMU
mm: memcg: only check anon swapin page charges for swap cache
mm: memcg: only check swap cache pages for repeated charging
mm: memcg: split swapin charge function into private and public part
mm: memcg: remove needless !mm fixup to init_mm when charging
mm: memcg: remove unneeded shmem charge type
Pull VFIO core from Alex Williamson:
"This series includes the VFIO userspace driver interface for the 3.6
kernel merge window. This driver is intended to provide a secure
interface for device access using IOMMU protection for applications
like assignment of physical devices to virtual machines.
Qemu will be the first user of this interface, enabling assignment of
PCI devices to Qemu guests. This interface is intended to eventually
replace the x86-specific assignment mechanism currently available in
KVM.
This interface has the advantage of being more secure, by working with
IOMMU groups to ensure device isolation and providing it's own
filtered resource access mechanism, and also more flexible, in not
being x86 or KVM specific (extensions to enable POWER are already
working).
This driver is originally the work of Tom Lyon, but has since been
handed over to me and gone through a complete overhaul thanks to the
input from David Gibson, Ben Herrenschmidt, Chris Wright, Joerg
Roedel, and others. This driver has been available in linux-next for
the last month."
Paul Mackerras says:
"I would be glad to see it go in since we want to use it with KVM on
PowerPC. If possible we'd like the PowerPC bits for it to go in as
well."
* tag 'vfio-for-v3.6' of git://github.com/awilliam/linux-vfio:
vfio: Add PCI device driver
vfio: Type1 IOMMU implementation
vfio: Add documentation
vfio: VFIO core
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random subsystem patches from Ted Ts'o:
"This patch series contains a major revamp of how we collect entropy
from interrupts for /dev/random and /dev/urandom.
The goal is to addresses weaknesses discussed in the paper "Mining
your Ps and Qs: Detection of Widespread Weak Keys in Network Devices",
by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman,
which will be published in the Proceedings of the 21st Usenix Security
Symposium, August 2012. (See https://factorable.net for more
information and an extended version of the paper.)"
Fix up trivial conflicts due to nearby changes in
drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c}
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits)
random: mix in architectural randomness in extract_buf()
dmi: Feed DMI table to /dev/random driver
random: Add comment to random_initialize()
random: final removal of IRQF_SAMPLE_RANDOM
um: remove IRQF_SAMPLE_RANDOM which is now a no-op
sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op
[ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op
board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op
isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op
pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op
goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out
uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op
drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op
xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op
n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op
pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op
i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op
input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op
mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull final RDMA changes from Roland Dreier:
- Fix IPoIB to stop using unsafe linkage between networking neighbour
layer and private path database.
- Small fixes for bugs found by Fengguang Wu's automated builds.
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IPoIB: Use a private hash table for path lookup in xmit path
IB/qib: Fix size of cc_supported_table_entries
RDMA/ucma: Convert open-coded equivalent to memdup_user()
RDMA/ocrdma: Fix check of GSI CQs
RDMA/cma: Use PTR_RET rather than if (IS_ERR(...)) + PTR_ERR
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull second set of media updates from Mauro Carvalho Chehab:
- radio API: add support to work with radio frequency bands
- new AM/FM radio drivers: radio-shark, radio-shark2
- new Remote Controller USB driver: iguanair
- conversion of several drivers to the v4l2 core control framework
- new board additions at existing drivers
- the remaining (and vast majority of the patches) are due to
drivers/DocBook fixes/cleanups.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits)
[media] radio-tea5777: use library for 64bits div
[media] tlg2300: Declare MODULE_FIRMWARE usage
[media] lgs8gxx: Declare MODULE_FIRMWARE usage
[media] xc5000: Add MODULE_FIRMWARE statements
[media] s2255drv: Add MODULE_FIRMWARE statement
[media] dib8000: move dereference after check for NULL
[media] Documentation: Update cardlists
[media] bttv: add support for Aposonic W-DVR
[media] cx25821: Remove bad strcpy to read-only char*
[media] pms.c: remove duplicated include
[media] smiapp-core.c: remove duplicated include
[media] via-camera: pass correct format settings to sensor
[media] rtl2832.c: minor cleanup
[media] Add support for the IguanaWorks USB IR Transceiver
[media] Minor cleanups for MCE USB
[media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry
[media] Use a named union in struct v4l2_ioctl_info
[media] mceusb: Add Twisted Melon USB IDs
[media] staging/media/solo6x10: use module_pci_driver macro
[media] staging/media/dt3155v4l: use module_pci_driver macro
Documentation/feature-removal-schedule.txt
Pull second wave of NFS client updates from Trond Myklebust:
- Patches from Bryan to allow splitting of the NFSv2/v3/v4 code into
separate modules.
- Fix Oopses in the NFSv4 idmapper
- Fix a deadlock whereby rpciod tries to allocate a new socket and ends
up recursing into the NFS code due to memory reclaim.
- Increase the number of permitted callback connections.
* tag 'nfs-for-3.6-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: explicitly reject LOCK_MAND flock() requests
nfs: increase number of permitted callback connections.
SUNRPC: return negative value in case rpcbind client creation error
NFS: Convert v4 into a module
NFS: Convert v3 into a module
NFS: Convert v2 into a module
NFS: Keep module parameters in the generic NFS client
NFS: Split out remaining NFS v4 inode functions
NFS: Pass super operations and xattr handlers in the nfs_subversion
NFS: Only initialize the ACL client in the v3 case
NFS: Create a try_mount rpc op
NFS: Remove the NFS v4 xdev mount function
NFS: Add version registering framework
NFS: Fix a number of bugs in the idmapper
nfs: skip commit in releasepage if we're freeing memory for fs-related reasons
sunrpc: clarify comments on rpc_make_runnable
pnfsblock: bail out partial page IO
Pull networking update from David S. Miller:
"I think Eric Dumazet and I have dealt with all of the known routing
cache removal fallout. Some other minor fixes all around.
1) Fix RCU of cached routes, particular of output routes which require
liberation via call_rcu() instead of call_rcu_bh(). From Eric
Dumazet.
2) Make sure we purge net device references in cached routes properly.
3) TG3 driver bug fixes from Michael Chan.
4) Fix reported 'expires' value in ipv6 routes, from Li Wei.
5) TUN driver ioctl leaks kernel bytes to userspace, from Mathias
Krause."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (22 commits)
ipv4: Properly purge netdev references on uncached routes.
ipv4: Cache routes in nexthop exception entries.
ipv4: percpu nh_rth_output cache
ipv4: Restore old dst_free() behavior.
bridge: make port attributes const
ipv4: remove rt_cache_rebuild_count
net: ipv4: fix RCU races on dst refcounts
net: TCP early demux cleanup
tun: Fix formatting.
net/tun: fix ioctl() based info leaks
tg3: Update version to 3.124
tg3: Fix race condition in tg3_get_stats64()
tg3: Add New 5719 Read DMA workaround
tg3: Fix Read DMA workaround for 5719 A0.
tg3: Request APE_LOCK_PHY before PHY access
ipv6: fix incorrect route 'expires' value passed to userspace
mISDN: Bugfix only few bytes are transfered on a connection
seeq: use PTR_RET at init_module of driver
bnx2x: remove cast around the kmalloc in bnx2x_prev_mark_path
ipv4: clean up put_child
devm_kzalloc() doesn't need a matching devm_kfree(), the freeing mechanism
will trigger when driver unloads.
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Ashish Jangam <ashish.jangam@kpitcummins.com>
Cc: David Dajun Chen <dchen@diasemi.com>
At the probe we are assigning ret to return value of PTR_ERR right after
the rtc_register_drive()r, as we would have done it in the if
(IS_ERR(ptr)) check, since the function fails and goes inside that case
If a process creates a large hugetlbfs mapping that is eligible for page
table sharing and forks heavily with children some of whom fault and
others which destroy the mapping then it is possible for page tables to
get corrupted. Some teardowns of the mapping encounter a "bad pmd" and
output a message to the kernel log. The final teardown will trigger a
BUG_ON in mm/filemap.c.
This was reproduced in 3.4 but is known to have existed for a long time
and goes back at least as far as 2.6.37. It was probably was introduced
in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages
look like this;
[ ..........] Lots of bad pmd messages followed by this
[ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7).
[ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7).
[ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7).
[ 127.186778] ------------[ cut here ]------------
[ 127.186781] kernel BUG at mm/filemap.c:134!
[ 127.186782] invalid opcode: 0000 [#1] SMP
[ 127.186783] CPU 7
[ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod
[ 127.186801]
[ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR
[ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002
[ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0
[ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00
[ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003
[ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8
[ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8
[ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000
[ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0
[ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0)
[ 127.186821] Stack:
[ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b
[ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98
[ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000
[ 127.186827] Call Trace:
[ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80
[ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220
[ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30
[ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0
[ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0
[ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50
[ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130
[ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0
[ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230
[ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150
[ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30
[ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80
[ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360
[ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170
[ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b
[ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0
[ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160
[ 127.186870] RSP <ffff8804144b5c08>
[ 127.186871] ---[ end trace 7cbac5d1db69f426 ]---
The bug is a race and not always easy to reproduce. To reproduce it I was
doing the following on a single socket I7-based machine with 16G of RAM.
$ hugeadm --pool-pages-max DEFAULT:13G
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax
$ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall
$ for i in `seq 1 9000`; do ./hugetlbfs-test; done
On my particular machine, it usually triggers within 10 minutes but
enabling debug options can change the timing such that it never hits.
Once the bug is triggered, the machine is in trouble and needs to be
rebooted. The machine will respond but processes accessing proc like "ps
aux" will hang due to the BUG_ON. shutdown will also hang and needs a
hard reset or a sysrq-b.
The basic problem is a race between page table sharing and teardown. For
the most part page table sharing depends on i_mmap_mutex. In some cases,
it is also taking the mm->page_table_lock for the PTE updates but with
shared page tables, it is the i_mmap_mutex that is more important.
Unfortunately it appears to be also insufficient. Consider the following
situation
Process A Process B
hugetlb_fault shmdt
LockWrite(mmap_sem)
do_munmap
unmap_region
unmap_vmas
unmap_single_vma
unmap_hugepage_range
Lock(i_mmap_mutex)
Lock(mm->page_table_lock)
huge_pmd_unshare/unmap tables <--- (1)
Unlock(mm->page_table_lock)
Unlock(i_mmap_mutex)
huge_pte_alloc ...
Lock(i_mmap_mutex) ...
vma_prio_walk, find svma, spte ...
Lock(mm->page_table_lock) ...
share spte ...
Unlock(mm->page_table_lock) ...
Unlock(i_mmap_mutex) ...
hugetlb_no_page <--- (2)
free_pgtables
unlink_file_vma
hugetlb_free_pgd_range
remove_vma_list
In this scenario, it is possible for Process A to share page tables with
Process B that is trying to tear them down. The i_mmap_mutex on its own
does not prevent Process A walking Process B's page tables. At (1) above,
the page tables are not shared yet so it unmaps the PMDs. Process A sets
up page table sharing and at (2) faults a new entry. Process B then trips
up on it in free_pgtables.
This patch fixes the problem by adding a new function
__unmap_hugepage_range_final that is only called when the VMA is about to
be destroyed. This function clears VM_MAYSHARE during
unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA
ineligible for sharing and avoids the race. Superficially this looks like
it would then be vunerable to truncate and madvise issues but hugetlbfs
has its own truncate handlers so does not use unmap_mapping_range() and
does not support madvise(DONTNEED).
This should be treated as a -stable candidate if it is merged.
Test program is as follows. The test case was mostly written by Michal
Hocko with a few minor changes to reproduce this bug.
==== CUT HERE ====
static size_t huge_page_size = (2UL << 20);
static size_t nr_huge_page_A = 512;
static size_t nr_huge_page_B = 5632;
unsigned int get_random(unsigned int max)
struct timeval tv;
gettimeofday(&tv, NULL);
srandom(tv.tv_usec);
return random() % max;
static void play(void *addr, size_t size)
unsigned char *start = addr,
*end = start + size,
*a;
start += get_random(size/2);
/* we could itterate on huge pages but let's give it more time. */
for (a = start; a < end; a += 4096)
*a = 0;
int main(int argc, char **argv)
key_t key = IPC_PRIVATE;
size_t sizeA = nr_huge_page_A * huge_page_size;
size_t sizeB = nr_huge_page_B * huge_page_size;
int shmidA, shmidB;
void *addrA = NULL, *addrB = NULL;
int nr_children = 300, n = 0;
if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) {
perror("shmget:");
return 1;
if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) {
perror("shmat");
return 1;
fork_child:
switch(fork()) {
case 0:
switch (n%3) {
case 0:
play(addrA, sizeA);
break;
case 1:
play(addrB, sizeB);
break;
case 2:
break;
break;
case -1:
perror("fork:");
break;
default:
if (++n < nr_children)
goto fork_child;
play(addrA, sizeA);
break;
shmdt(addrA);
shmdt(addrB);
do {
wait(NULL);
} while (--n > 0);
shmctl(shmidA, IPC_RMID, NULL);
shmctl(shmidB, IPC_RMID, NULL);
return 0;
[akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build]
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: <stable@vger.kernel.org>
When tmpfs has the interleave memory policy, it always starts allocating
for each file from node 0 at offset 0. When there are many small files,
the lower nodes fill up disproportionately.
This patch spreads out node usage by starting files at nodes other than 0,
by using the inode number to bias the starting node for interleave.
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Nick Piggin <npiggin@gmail.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
pg_data_t is zeroed before reaching free_area_init_core(), so remove the
now unnecessary initializations.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Warn if memory-hotplug/boot code doesn't initialize pg_data_t with zero
when it is allocated. Arch code and memory hotplug already initiailize
pg_data_t. So this warning should never happen. I select fields randomly
near the beginning, middle and end of pg_data_t for checking.
This patch isn't for performance but for removing initialization code
which is necessary to add whenever we adds new field to pg_data_t or zone.
Firstly, Andrew suggested clearing out of pg_data_t in MM core part but
Tejun doesn't like it because in the future, some archs can initialize
some fields in arch code and pass them into general MM part so blindly
clearing it out in mm core part would be very annoying.
This patch is preparation for the next patch which removes the zeroing of
the pg_data_t in core MM. All archs except MIPS already do this.
I noticed in a multi-process parallel files reading benchmark I ran on a 8
socket machine, throughput slowed down by a factor of 8 when I ran the
benchmark within a cgroup container. I traced the problem to the
following code path (see below) when we are trying to reclaim memory from
file cache. The res_counter_uncharge function is called on every page
that's reclaimed and created heavy lock contention. The patch below
allows the reclaimed pages to be uncharged from the resource counter in
batch and recovered the regression.
Tim
40.67% usemem [kernel.kallsyms] [k] _raw_spin_lock
--- _raw_spin_lock
|--92.61%-- res_counter_uncharge
| |--100.00%-- __mem_cgroup_uncharge_common
| | |--100.00%-- mem_cgroup_uncharge_cache_page
| | | __remove_mapping
| | | shrink_page_list
| | | shrink_inactive_list
| | | shrink_mem_cgroup_zone
| | | shrink_zone
| | | do_try_to_free_pages
| | | try_to_free_pages
| | | __alloc_pages_nodemask
| | | alloc_pages_current
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
sparse_index_init() uses the index_init_lock spinlock to protect root
mem_section assignment. The lock is not necessary anymore because the
function is called only during boot (during paging init which is executed
only from a single CPU) and from the hotplug code (by add_memory() via
arch_add_memory()) which uses mem_hotplug_mutex.
The lock was introduced by 28ae55c9 ("sparsemem extreme: hotplug
preparation") and sparse_index_init() was used only during boot at that
time.
Later when the hotplug code (and add_memory()) was introduced there was no
synchronization so it was possible to online more sections from the same
root probably (though I am not 100% sure about that). The first
synchronization has been added by 6ad696d2 ("mm: allow memory hotplug and
hibernation in the same kernel") which was later replaced by the
mem_hotplug_mutex - 20d6c96b ("mem-hotplug: introduce
{un}lock_memory_hotplug()").
Let's remove the lock as it is not needed and it makes the code more
confusing.
[mhocko@suse.cz: changelog]
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
__section_nr() was implemented to retrieve the corresponding memory
section number according to its descriptor. It's possible that the
specified memory section descriptor doesn't exist in the global array. So
add more checking on that and report an error for a wrong case.
Acked-by: David Rientjes <rientjes@google.com>
With CONFIG_SPARSEMEM_EXTREME, the two levels of memory section
descriptors are allocated from slab or bootmem. When allocating from
slab, let slab/bootmem allocator clear the memory chunk. We needn't clear
it explicitly.
Add a mem_cgroup_from_css() helper to replace open-coded invokations of
container_of(). To clarify the code and to add a little more type safety.
[akpm@linux-foundation.org: fix extensive breakage]
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Gavin Shan <shangw@linux.vnet.ibm.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
The may_enter_fs test turns out to be too restrictive: though I saw no
problem with it when testing on 3.5-rc6, it very soon OOMed when I tested
on 3.5-rc6-mm1. I don't know what the difference there is, perhaps I just
slightly changed the way I started off the testing: dd if=/dev/zero
of=/mnt/temp bs=1M count=1024; rm -f /mnt/temp; sync repeatedly, in 20M
memory.limit_in_bytes cgroup to ext4 on USB stick.
ext4 (and gfs2 and xfs) turn out to allocate new pages for writing with
AOP_FLAG_NOFS: that seems a little worrying, and it's unclear to me why
the transaction needs to be started even before allocating pagecache
memory. But it may not be worth worrying about these days: if direct
reclaim avoids FS writeback, does __GFP_FS now mean anything?
Anyway, we insisted on the may_enter_fs test to avoid hangs with the loop
device; but since that also masks off __GFP_IO, we can test for __GFP_IO
directly, ignoring may_enter_fs and __GFP_FS.
But even so, the test still OOMs sometimes: when originally testing on
3.5-rc6, it OOMed about one time in five or ten; when testing just now on
3.5-rc6-mm1, it OOMed on the first iteration.
This residual problem comes from an accumulation of pages under ordinary
writeback, not marked PageReclaim, so rightly not causing the memcg check
to wait on their writeback: these too can prevent shrink_page_list() from
freeing any pages, so many times that memcg reclaim fails and OOMs.
Deal with these in the same way as direct reclaim now deals with dirty FS
pages: mark them PageReclaim. It is appropriate to rotate these to tail
of list when writepage completes, but more importantly, the PageReclaim
flag makes memcg reclaim wait on them if encountered again. Increment
NR_VMSCAN_IMMEDIATE? That's arguable: I chose not.
Setting PageReclaim here may occasionally race with end_page_writeback()
clearing it: lru_deactivate_fn() already faced the same race, and
correctly concluded that the window is small and the issue non-critical.
With these changes, the test runs indefinitely without OOMing on ext4,
ext3 and ext2: I'll move on to test with other filesystems later.
Trivia: invert conditions for a clearer block without an else, and goto
keep_locked to do the unlock_page.
Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Ying Han <yinghan@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
The current implementation of dirty pages throttling is not memcg aware
which makes it easy to have memcg LRUs full of dirty pages. Without
throttling, these LRUs can be scanned faster than the rate of writeback,
leading to memcg OOM conditions when the hard limit is small.
This patch fixes the problem by throttling the allocating process
(possibly a writer) during the hard limit reclaim by waiting on
PageReclaim pages. We are waiting only for PageReclaim pages because
those are the pages that made one full round over LRU and that means that
the writeback is much slower than scanning.
The solution is far from being ideal - long term solution is memcg aware
dirty throttling - but it is meant to be a band aid until we have a real
fix. We are seeing this happening during nightly backups which are placed
into containers to prevent from eviction of the real working set.
The change affects only memcg reclaim and only when we encounter
PageReclaim pages which is a signal that the reclaim doesn't catch up on
with the writers so somebody should be throttled. This could be
potentially unfair because it could be somebody else from the group who
gets throttled on behalf of the writer but as writers need to allocate as
well and they allocate in higher rate the probability that only innocent
processes would be penalized is not that high.
I have tested this change by a simple dd copying /dev/zero to tmpfs or
ext3 running under small memcg (1G copy under 5M, 60M, 300M and 2G
containers) and dd got killed by OOM killer every time. With the patch I
could run the dd with the same size under 5M controller without any OOM.
The issue is more visible with slower devices for output.
* With the patch
* tmpfs size=2G
$ vim cgroup_cache_oom_test.sh
$ ./cgroup_cache_oom_test.sh 5M
using Limit 5M for group
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 30.4049 s, 34.5 MB/s
$ ./cgroup_cache_oom_test.sh 60M
using Limit 60M for group
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 31.4561 s, 33.3 MB/s
$ ./cgroup_cache_oom_test.sh 300M
using Limit 300M for group
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 20.4618 s, 51.2 MB/s
$ ./cgroup_cache_oom_test.sh 2G
using Limit 2G for group
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 1.42172 s, 738 MB/s
* ext3
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 27.9547 s, 37.5 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 30.3221 s, 34.6 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 24.5764 s, 42.7 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 3.35828 s, 312 MB/s
* Without the patch
* tmpfs size=2G
./cgroup_cache_oom_test.sh: line 46: 4668 Killed dd if=/dev/zero of=$OUT/zero bs=1M count=$count
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 25.4989 s, 41.1 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 24.3928 s, 43.0 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 1.49797 s, 700 MB/s
* ext3
./cgroup_cache_oom_test.sh: line 46: 4689 Killed dd if=/dev/zero of=$OUT/zero bs=1M count=$count
./cgroup_cache_oom_test.sh: line 46: 4692 Killed dd if=/dev/zero of=$OUT/zero bs=1M count=$count
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 20.248 s, 51.8 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 2.85201 s, 368 MB/s
[akpm@linux-foundation.org: tweak changelog, reordered the test to optimize for CONFIG_CGROUP_MEM_RES_CTLR=n]
[hughd@google.com: fix deadlock with loop driver]
Reviewed-by: Mel Gorman <mgorman@suse.de>
Reviewed-by: Fengguang Wu <fengguang.wu@intel.com>
mmu_notifier_release() is called when the process is exiting. It will
delete all the mmu notifiers. But at this time the page belonging to the
process is still present in page tables and is present on the LRU list, so
this race will happen:
CPU 0 CPU 1
mmu_notifier_release: try_to_unmap:
hlist_del_init_rcu(&mn->hlist);
ptep_clear_flush_notify:
mmu nofifler not found
free page !!!!!!
* At the point, the page has been
* freed, but it is still mapped in
* the secondary MMU.
mn->ops->release(mn, mm);
Then the box is not stable and sometimes we can get this bug:
[ 738.075923] BUG: Bad page state in process migrate-perf pfn:03bec
[ 738.075931] page:ffffea00000efb00 count:0 mapcount:0 mapping: (null) index:0x8076
[ 738.075936] page flags: 0x20000000000014(referenced|dirty)
The same issue is present in mmu_notifier_unregister().
We can call ->release before deleting the notifier to ensure the page has
been unmapped from the secondary MMU before it is freed.
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
shmem knows for sure that the page is in swap cache when attempting to
charge a page, because the cache charge entry function has a check for it.
Only anon pages may be removed from swap cache already when trying to
charge their swapin.
Adjust the comment, though: '4969c11 mm: fix swapin race condition' added
a stable PageSwapCache check under the page lock in the do_swap_page()
before calling the memory controller, so it's unuse_pte()'s pte_same()
that may fail.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Cc: Wanpeng Li <liwp.linux@gmail.com>
Only anon and shmem pages in the swap cache are attempted to be charged
multiple times, from every swap pte fault or from shmem_unuse(). No other
pages require checking PageCgroupUsed().
Charging pages in the swap cache is also serialized by the page lock, and
since both the try_charge and commit_charge are called under the same page
lock section, the PageCgroupUsed() check might as well happen before the
counter charging, let alone reclaim.
When shmem is charged upon swapin, it does not need to check twice whether
the memory controller is enabled.
Also, shmem pages do not have to be checked for everything that regular
anon pages have to be checked for, so let shmem use the internal version
directly and allow future patches to move around checks that are only
required when swapping in anon pages.
It does not matter to __mem_cgroup_try_charge() if the passed mm is NULL
or init_mm, it will charge the root memcg in either case.
Also fix up the comment in __mem_cgroup_try_charge() that claimed the
init_mm would be charged when no mm was passed. It's not really
incorrect, but confusing. Clarify that the root memcg is charged in this
case.
shmem page charges have not needed a separate charge type to tell them
from regular file pages since 08e552c ("memcg: synchronized LRU").
Charging cache pages may require swapin in the shmem case. Save the
forward declaration and just move the swapin functions above the cache
charging functions.
Only anon pages that are uncharged at the time of the last page table
mapping vanishing may be in swapcache.
When shmem pages, file pages, swap-freed anon pages, or just migrated
pages are uncharged, they are known for sure to be not in swapcache.
Not all uncharge paths need to check if the page is swapcache, some of
them can know for sure.
Push down the check into all callsites of uncharge_common() so that the
patch that removes some of them is more obvious.
The conditional mem_cgroup_cancel_charge_swapin() is a leftover from when
the function would continue to reestablish the page even after
mem_cgroup_try_charge_swapin() failed. After 85d9fc8 "memcg: fix refcnt
handling at swapoff", the condition is always true when this code is
reached.
Compaction (and page migration in general) can currently be hindered
through pages being owned by memory cgroups that are at their limits and
unreclaimable.
The reason is that the replacement page is being charged against the limit
while the page being replaced is also still charged. But this seems
unnecessary, given that only one of the two pages will still be in use
after migration finishes.
This patch changes the memcg migration sequence so that the replacement
page is not charged. Whatever page is still in use after successful or
failed migration gets to keep the charge of the page that was going to be
replaced.
The replacement page will still show up temporarily in the rss/cache
statistics, this can be fixed in a later patch as it's less urgent.
Reported-by: David Rientjes <rientjes@google.com>
Commit b3a27d ("swap: Add swap slot free callback to
block_device_operations") dereferences p->bdev->bd_disk but this is a NULL
dereference if using swap-over-NFS. This patch checks SWP_BLKDEV on the
swap_info_struct before dereferencing.
With reference to this callback, Christoph Hellwig stated "Please just
remove the callback entirely. It has no user outside the staging tree and
was added clearly against the rules for that staging tree". This would
also be my preference but there was not an obvious way of keeping zram in
staging/ happy.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Eric Paris <eparis@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Neil Brown <neilb@suse.de>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
GFP_NOFS is _more_ permissive than GFP_NOIO in that it will initiate IO,
just not of any filesystem data.
The problem is that previously NOFS was correct because that avoids
recursion into the NFS code. With swap-over-NFS, it is no longer correct
as swap IO can lead to this recursion.
Cc: Xiaotian Feng <dfeng@redhat.com>
Implement the new swapfile a_ops for NFS and hook up ->direct_IO. This
will set the NFS socket to SOCK_MEMALLOC and run socket reconnect under
PF_MEMALLOC as well as reset SOCK_MEMALLOC before engaging the protocol
->connect() method.
PF_MEMALLOC should allow the allocation of struct socket and related
objects and the early (re)setting of SOCK_MEMALLOC should allow us to
receive the packets required for the TCP connection buildup.
[jlayton@redhat.com: Restore PF_MEMALLOC task flags in all cases]
[dfeng@redhat.com: Fix handling of multiple swap files]
[a.p.zijlstra@chello.nl: Original patch]
The VM does not like PG_private set on PG_swapcache pages. As suggested
by Trond in http://lkml.org/lkml/2006/8/25/348, this patch disables NFS
data cache revalidation on swap files. as it does not make sense to have
other clients change the file while it is being used as swap. This avoids
setting PG_private on swap pages, since there ought to be no further races
with invalidate_inode_pages2() to deal with.
Since we cannot set PG_private we cannot use page->private which is
already used by PG_swapcache pages to store the nfs_page. Thus augment
the new nfs_page_find_request logic.
Replace all relevant occurences of page->index and page->mapping in the
NFS client with the new page_file_index() and page_file_mapping()
functions.
The patch "mm: add support for a filesystem to activate swap files and use
direct_IO for writing swap pages" added support for using direct_IO to
write swap pages but it is insufficient for highmem pages.
To support highmem pages, this patch kmaps() the page before calling the
direct_IO() handler. As direct_IO deals with virtual addresses an
additional helper is necessary for get_kernel_pages() to lookup the struct
page for a kmap virtual address.
The version of swap_activate introduced is sufficient for swap-over-NFS
but would not provide enough information to implement a generic handler.
This patch shuffles things slightly to ensure the same information is
available for aops->swap_activate() as is available to the core.
No functionality change.
Currently swapfiles are managed entirely by the core VM by using ->bmap to
allocate space and write to the blocks directly. This effectively ensures
that the underlying blocks are allocated and avoids the need for the swap
subsystem to locate what physical blocks store offsets within a file.
If the swap subsystem is to use the filesystem information to locate the
blocks, it is critical that information such as block groups, block
bitmaps and the block descriptor table that map the swap file were
resident in memory. This patch adds address_space_operations that the VM
can call when activating or deactivating swap backed by a file.
int swap_activate(struct file *);
int swap_deactivate(struct file *);
The ->swap_activate() method is used to communicate to the file that the
VM relies on it, and the address_space should take adequate measures such
as reserving space in the underlying device, reserving memory for mempools
and pinning information such as the block descriptor table in memory. The
->swap_deactivate() method is called on sys_swapoff() if ->swap_activate()
returned success.
After a successful swapfile ->swap_activate, the swapfile is marked
SWP_FILE and swapper_space.a_ops will proxy to
sis->swap_file->f_mappings->a_ops using ->direct_io to write swapcache
pages and ->readpage to read.
It is perfectly possible that direct_IO be used to read the swap pages but
it is an unnecessary complication. Similarly, it is possible that
->writepage be used instead of direct_io to write the pages but filesystem
developers have stated that calling writepage from the VM is undesirable
for a variety of reasons and using direct_IO opens up the possibility of
writing back batches of swap pages in the future.
This patch adds two new APIs get_kernel_pages() and get_kernel_page() that
may be used to pin a vector of kernel addresses for IO. The initial user
is expected to be NFS for allowing pages to be written to swap using
aops->direct_IO(). Strictly speaking, swap-over-NFS only needs to pin one
page for IO but it makes sense to express the API in terms of a vector and
add a helper for pinning single pages.
Cc: Mark Salter <msalter@redhat.com>
In order to teach filesystems to handle swap cache pages, three new page
functions are introduced:
pgoff_t page_file_index(struct page *);
loff_t page_file_offset(struct page *);
struct address_space *page_file_mapping(struct page *);
page_file_index() - gives the offset of this page in the file in
PAGE_CACHE_SIZE blocks. Like page->index is for mapped pages, this
function also gives the correct index for PG_swapcache pages.
page_file_offset() - uses page_file_index(), so that it will give the
expected result, even for PG_swapcache pages.
page_file_mapping() - gives the mapping backing the actual page; that is
for swap cache pages it will give swap_file->f_mapping.
Failing to allocate a cache entry will only harm performance not
correctness. Do not consume valuable reserve pages for something like
that.
Acked-by: Eric Paris <eparis@redhat.com>
This patch series is based on top of "Swap-over-NBD without deadlocking
v15" as it depends on the same reservation of PF_MEMALLOC reserves logic.
When a user or administrator requires swap for their application, they
create a swap partition and file, format it with mkswap and activate it
with swapon. In diskless systems this is not an option so if swap if
required then swapping over the network is considered. The two likely
scenarios are when blade servers are used as part of a cluster where the
form factor or maintenance costs do not allow the use of disks and thin
clients.
The Linux Terminal Server Project recommends the use of the Network Block
Device (NBD) for swap but this is not always an option. There is no
guarantee that the network attached storage (NAS) device is running Linux
or supports NBD. However, it is likely that it supports NFS so there are
users that want support for swapping over NFS despite any performance
concern. Some distributions currently carry patches that support swapping
over NFS but it would be preferable to support it in the mainline kernel.
Patch 1 avoids a stream-specific deadlock that potentially affects TCP.
Patch 2 is a small modification to SELinux to avoid using PFMEMALLOC
reserves.
Patch 3 adds three helpers for filesystems to handle swap cache pages.
For example, page_file_mapping() returns page->mapping for
file-backed pages and the address_space of the underlying
swap file for swap cache pages.
Patch 4 adds two address_space_operations to allow a filesystem
to pin all metadata relevant to a swapfile in memory. Upon
successful activation, the swapfile is marked SWP_FILE and
the address space operation ->direct_IO is used for writing
and ->readpage for reading in swap pages.
Patch 5 notes that patch 3 is bolting
filesystem-specific-swapfile-support onto the side and that
the default handlers have different information to what
is available to the filesystem. This patch refactors the
code so that there are generic handlers for each of the new
address_space operations.
Patch 6 adds an API to allow a vector of kernel addresses to be
translated to struct pages and pinned for IO.
Patch 7 adds support for using highmem pages for swap by kmapping
the pages before calling the direct_IO handler.
Patch 8 updates NFS to use the helpers from patch 3 where necessary.
Patch 9 avoids setting PF_private on PG_swapcache pages within NFS.
Patch 10 implements the new swapfile-related address_space operations
for NFS and teaches the direct IO handler how to manage
kernel addresses.
Patch 11 prevents page allocator recursions in NFS by using GFP_NOIO
where appropriate.
Patch 12 fixes a NULL pointer dereference that occurs when using
swap-over-NFS.
With the patches applied, it is possible to mount a swapfile that is on an
NFS filesystem. Swap performance is not great with a swap stress test
taking roughly twice as long to complete than if the swap device was
backed by NBD.
This patch: netvm: prevent a stream-specific deadlock
It could happen that all !SOCK_MEMALLOC sockets have buffered so much data
that we're over the global rmem limit. This will prevent SOCK_MEMALLOC
buffers from receiving data, which will prevent userspace from running,
which is needed to reduce the buffered data.
Fix this by exempting the SOCK_MEMALLOC sockets from the rmem limit. Once
this change it applied, it is important that sockets that set
SOCK_MEMALLOC do not clear the flag until the socket is being torn down.
If this happens, a warning is generated and the tokens reclaimed to avoid
accounting errors until the bug is fixed.
[davem@davemloft.net: Warning about clearing SOCK_MEMALLOC]
Under significant pressure when writing back to network-backed storage,
direct reclaimers may get throttled. This is expected to be a short-lived
event and the processes get woken up again but processes do get stalled.
This patch counts how many times such stalling occurs. It's up to the
administrator whether to reduce these stalls by increasing
min_free_kbytes.
