2014-07-15drm/radeon: Add radeon <--> amdkfd interfaceOded Gabbay
This patch adds the interface between the radeon driver and the amdkfd driver. The interface implementation is contained in radeon_kfd.c and radeon_kfd.h. The interface itself is represented by a pointer to struct kfd_dev. The pointer is located inside radeon_device structure. All the register accesses that amdkfd need are done using this interface. This allows us to avoid direct register accesses in amdkfd proper, while also avoiding locking between amdkfd and radeon. The single exception is the doorbells that are used in both of the drivers. However, because they are located in separate pci bar pages, the danger of sharing registers between the drivers is minimal. Having said that, we are planning to move the doorbells as well to radeon. v3: Add interface for sa manager init and fini. The init function will allocate a buffer on system memory and pin it to the GART address space via the radeon sa manager. All mappings of buffers to GART address space are done via the radeon sa manager. The interface of allocate memory will use the radeon sa manager to sub allocate from the single buffer that was allocated during the init function. Change lower_32/upper_32 calls to use linux macros Add documentation for the interface v4: Change ptr field type in kgd_mem from uint32_t* to void* to match to type that is returned by radeon_sa_bo_cpu_addr v5: Change format of mqd structure to work with latest KV firmware Add support for AQL queues creation to enable working with open-source HSA runtime. Move generic kfd-->kgd interface and other generic kgd definitions to a generic header file that will be used by AMD's radeon and amdgpu drivers Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-07-14drm/radeon: adding synchronization for GRBM GFXOded Gabbay
Implementing a lock for selecting and accessing shader engines and arrays. This lock will make sure that radeon and amdkfd are not colliding when accessing shader engines and arrays with GRBM_GFX_INDEX register. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-01-28drm/radeon: Report doorbell configuration to amdkfdOded Gabbay
radeon and amdkfd share the doorbell aperture. radeon sets it up, takes the doorbells required for its own rings and reports the setup to amdkfd. radeon reserved doorbells are at the start of the doorbell aperture. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-02-11drm/radeon/cik: Don't touch int of pipes 1-7Oded Gabbay
amdkfd should set interrupts for pipes 1-7. Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-01-16drm/radeon: reduce number of free VMIDs and pipes in KVOded Gabbay
To support HSA on KV, we need to limit the number of vmids and pipes that are available for radeon's use with KV. This patch reserves VMIDs 8-15 for amdkfd (so radeon can only use VMIDs 0-7) and also makes radeon thinks that KV has only a single MEC with a single pipe in it v3: Use define for static vmid allocation in radeon Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-10iommu/amd: fix accounting of device_stateOded Gabbay
This patch fixes a bug in the accounting of the device_state. In the current code, the device_state was put (decremented) too many times, which sometimes lead to the driver getting stuck permanently in put_device_state_wait(). That happen because the device_state->count would go below zero, which is never supposed to happen. The root cause is that the device_state was decremented in put_pasid_state() and put_pasid_state_wait() but also in all the functions that call those functions. Therefore, the device_state was decremented twice in each of these code paths. The fix is to decouple the device_state accounting from the pasid_state accounting - remove the call to put_device_state() from the put_pasid_state() and the put_pasid_state_wait()) Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-13iommu/amd: use new invalidate_range mmu-notifierJoerg Roedel
Make use of the new invalidate_range mmu_notifier call-back and remove the old logic of assigning an empty page-table between invalidate_range_start and invalidate_range_end. Signed-off-by: Joerg Roedel <jroedel@suse.de> Tested-by: Oded Gabbay <oded.gabbay@amd.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-13mmu_notifier: add the callback for mmu_notifier_invalidate_range()Joerg Roedel
Now that the mmu_notifier_invalidate_range() calls are in place, add the callback to allow subsystems to register against it. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-13mmu_notifier: call mmu_notifier_invalidate_range() from VMMJoerg Roedel
Add calls to the new mmu_notifier_invalidate_range() function to all places in the VMM that need it. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-13mmu_notifier: add mmu_notifier_invalidate_range()Joerg Roedel
This notifier closes an important gap in the current mmu_notifier implementation, the existing callbacks are called too early or too late to reliably manage a non-CPU TLB. Specifically, invalidate_range_start() is called when all pages are still mapped and invalidate_range_end() when all pages are unmapped and potentially freed. This is fine when the users of the mmu_notifiers manage their own SoftTLB, like KVM does. When the TLB is managed in software it is easy to wipe out entries for a given range and prevent new entries to be established until invalidate_range_end is called. But when the user of mmu_notifiers has to manage a hardware TLB it can still wipe out TLB entries in invalidate_range_start, but it can't make sure that no new TLB entries in the given range are established between invalidate_range_start and invalidate_range_end. To avoid silent data corruption the entries in the non-CPU TLB need to be flushed when the pages are unmapped (at this point in time no _new_ TLB entries can be established in the non-CPU TLB) but not yet freed (as the non-CPU TLB may still have _existing_ entries pointing to the pages about to be freed). To fix this problem we need to catch the moment when the Linux VMM flushes remote TLBs (as a non-CPU TLB is not very CPU TLB), as this is the point in time when the pages are unmapped but _not_ yet freed. The mmu_notifier_invalidate_range() function aims to catch that moment. IOMMU code will be one user of the notifier-callback. Currently this is only the AMD IOMMUv2 driver, but its code is about to be more generalized and converted to a generic IOMMU-API extension to fit the needs of similar functionality in other IOMMUs as well. The current attempt in the AMD IOMMUv2 driver to work around the invalidate_range_start/end() shortcoming is to assign an empty page table to the non-CPU TLB between any invalidata_range_start/end calls. With the empty page-table assigned, every page-table walk to re-fill the non-CPU TLB will cause a page-fault reported to the IOMMU driver via an interrupt, possibly causing interrupt storms. The page-fault handler in the AMD IOMMUv2 driver doesn't handle the fault if an invalidate_range_start/end pair is active, it just reports back SUCCESS to the device and let it refault the page. But existing hardware (newer Radeon GPUs) that makes use of this feature don't re-fault indefinitly, after a certain number of faults for the same address the device enters a failure state and needs to be resetted. To avoid the GPUs entering a failure state we need to get rid of the empty-page-table workaround and use the mmu_notifier_invalidate_range() function introduced with this patch. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2014-11-13Merge branch 'drm-next-3.19' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Radeon patches for 3.19. Christian has a number of GPUVM improvements slated as well, but I'd like to wait until he gets back to work next week to pull those in. Highlights of this pull: - ttm performance improvements - CI dpm fixes * 'drm-next-3.19' of git://people.freedesktop.org/~agd5f/linux: (26 commits) drm/radeon/si/ci: make u8 static arrays constant drm/radeon: set power control in ci dpm enable drm/radeon: powertune fixes for hawaii drm/radeon: fix dpm mc init for certain hawaii boards drm/radeon: set bootup pcie level to max for ci dpm drm/radeon: fix default dpm state setup drm/radeon: workaround a hw bug in bonaire pcie dpm drm/radeon: fix mclk vddc configuration for cards for hawaii drm/radeon: fix sclk DS enablement drm/radeon: fix activity settings for sclk and mclk for CI drm/radeon: improve mclk param calcuations for ci dpm drm/radeon: fix dram timing for certain hawaii boards drm/radeon: switch force state commands for CI drm/radeon: fix for memory training on bonaire 0x6649 drm/radeon/ci: handle gpio controlled dpm features properly drm/radeon: store the gpio shift as well drm/radeon: export radeon_atombios_lookup_gpio drm/radeon: fix typo in CI dpm disable drm/radeon: rework CI dpm thermal setup drm/radeon: rework SI dpm thermal setup ...
2014-11-12drm/radeon/si/ci: make u8 static arrays constantDave Airlie
These two arrays don't change, just make them constant, reduces data segment by a few bytes. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: set power control in ci dpm enableAlex Deucher
Necessary for poper operation. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: powertune fixes for hawaiiAlex Deucher
- bapm is not available on hawaii - update pt defaults Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix dpm mc init for certain hawaii boardsAlex Deucher
Needs special overrides for certain vram configurations. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: set bootup pcie level to max for ci dpmAlex Deucher
Avoids problems when re-loading the driver. Does not affect power saving when dpm is enabled. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix default dpm state setupAlex Deucher
Only enable the first levels for mclk and sclk. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: workaround a hw bug in bonaire pcie dpmAlex Deucher
Some boards get stuck in pcie x1 otherwise. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix mclk vddc configuration for cards for hawaiiAlex Deucher
Need to use vddc0 for vdcc1 for certain hawaii configurations. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix sclk DS enablementAlex Deucher
Only enable it for levels 0 and 1. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix activity settings for sclk and mclk for CIAlex Deucher
Only need to be enabled on the first level. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: improve mclk param calcuations for ci dpmAlex Deucher
Properly take into account the post divider. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix dram timing for certain hawaii boardsAlex Deucher
Certain memory configurations need a fix. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: switch force state commands for CIAlex Deucher
Use the preferred SMC commands for forcing state on CI. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix for memory training on bonaire 0x6649Alex Deucher
Workaround for memory link training on certain variants of 0x6649. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon/ci: handle gpio controlled dpm features properlyAlex Deucher
Certain feature enablement depends on entries in the atom gpio pin table. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: store the gpio shift as wellAlex Deucher
We need this in the dpm code. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: export radeon_atombios_lookup_gpioAlex Deucher
We need it for dpm. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: fix typo in CI dpm disableAlex Deucher
Need to disable DS, not enable it when disabling dpm. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-11-12drm/radeon: rework CI dpm thermal setupAlex Deucher
In preparation for fan control. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: rework SI dpm thermal setupAlex Deucher
2014-11-12drm/radeon/dpm: grab fan info from vbiosAlex Deucher
Required for fan control support. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/ttm: Use only DRM_MM_SEARCH_BELOW for TTM_PL_FLAG_TOPDOWNMichel Dänzer
DRM_MM_SEARCH_BEST gets the smallest hole which can fit the BO. That seems against the idea of TTM_PL_FLAG_TOPDOWN: * The smallest hole may be in the overall bottom of the area * If the hole isn't much larger than the BO, it doesn't make much difference whether the BO is placed at the bottom or at the top of the hole Reviewed-by: Lauri Kasanen <cand@gmx.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/ttm: Add DRM_MM_SEARCH_BELOW for TTM_PL_FLAG_TOPDOWNMichel Dänzer
If the BO should be placed at the top of the area, we should start looking for holes from the top. Reviewed-by: Lauri Kasanen <cand@gmx.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: Set TTM_PL_FLAG_TOPDOWN also for RADEON_GEM_CPU_ACCESS BOsMichel Dänzer
I wasn't sure if TTM_PL_FLAG_TOPDOWN works correctly with non-0 lpfn, but AFAICT it does. Reviewed-by: Lauri Kasanen <cand@gmx.com> Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm/radeon: Try evicting from CPU accessible to inaccessible VRAM firstMichel Dänzer
2014-11-12drm/radeon: Try placing NO_CPU_ACCESS BOs outside of CPU accessible VRAMMichel Dänzer
This avoids them getting in the way of BOs which might be accessed by the CPU. They can still go to the CPU accessible part of VRAM though if there's no space outside of it. Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-11-12drm: More specific locking for get* ioctlsDaniel Vetter
Motivated by the per-plane locking I've gone through all the get* ioctls and reduced the locking to the bare minimum required. v2: Rebase and make it compile ... v3: Review from Sean: - Simplify return handling in getplane_res. - Add a comment to getplane_res that the plane list is invariant and can be walked locklessly. v4: Actually git add. Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-11-12drm: Per-plane lockingDaniel Vetter
Turned out to be much simpler on top of my latest atomic stuff than what I've feared. Some details: - Drop the modeset_lock_all snakeoil in drm_plane_init. Same justification as for the equivalent change in drm_crtc_init done in commit d0fa1af40e784aaf7ebb7ba8a17b229bb3fa4c21 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Mon Sep 8 09:02:49 2014 +0200 drm: Drop modeset locking from crtc init function Without these the drm_modeset_lock_init would fall over the exact same way. - Since the atomic core code wraps the locking switching it to per-plane locks was a one-line change. - For the legacy ioctls add a plane argument to the locking helper so that we can grab the right plane lock (cursor or primary). Since the universal cursor plane might not be there, or someone really crazy might forgoe the primary plane even accept NULL. - Add some locking WARN_ON to the atomic helpers for good paranoid measure and to check that it all works out. Tested on my exynos atomic hackfest with full lockdep checks and ww backoff injection. v2: I've forgotten about the load-detect code in i915. v3: Thierry reported that in latest 3.18-rc vmwgfx doesn't compile any more due to commit 21e88620aa21b48d4f62d29275e3e2944a5ea2b5 Author: Rob Clark <robdclark@gmail.com> Date: Thu Oct 30 13:39:04 2014 -0400 drm/vmwgfx: fix lock breakage Rebased and fix this up. Cc: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-11-12drm: export atomic wait_for_vblanks helper (v2)Rob Clark
v1: original v2: danvet's kerneldoc nitpicks Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-11-12Merge tag 'v3.18-rc4' into drm-nextDave Airlie
backmerge to get vmwgfx locking changes into next as the conflict with per-plane locking.
2014-11-10drm/mode: document path property and function to set it. (v1.1)Dave Airlie
These two didn't get documented properly, do so. Pointed out by Daniel. v1.1: add missing boilerplate (Daniel) Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-11-10Merge tag 'topic/atomic-helpers-2014-11-09' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next So here's my atomic series, finally all debugged&reviewed. Sean Paul has done a full detailed pass over it all, and a lot of other people have commented and provided feedback on some parts. Rob Clark also converted msm over the w/e and seems happy. The only small thing is that Rob wants to export the wait_for_vblank, which imo makes sense. Since there's other stuff still to do I think we should apply Rob's patch (once it has grown appropriate kerneldoc) later on top of this. This is just the core<->driver interface plus a big pile of helpers. Short recap of the main ideas: - There are essentially three helper libraries in this patch set: * Transitional helpers to use the new plane callbacks for legacy plane updates and in the crtc helper's ->mode_set callback. These helpers are only temporarily used to convert drivers to atomic, but they allow a nice separation between changing the driver backend and switching to the atomic commit logic. * Legacy helpers to implement all the legacy driver entry points (page_flip, set_config, plane vfuncs) on top of the new atomic driver interface. These are completely driver agnostic. The reason for having the legacy support as helpers is that drivers can switch step-by-step. And they could e.g. even keep the legacy page_flip code around for some old platforms where converting to full-blown atomic isn't worth it. * Atomic helpers which implement the various new ->atomic_* driver interfaces in terms of the revised crtc helper and new plane helper hooks. - The revised crtc helper implemenation essentially implements all the lessons learned in the i915 modeset rework (when using the atomic helpers only): * Enable/disable sequence for a given config are always the same and callbacks are always called in the same order. This contrast starkly with the crtc helpers, where the sequence of operations is heavily dependent on the previous config. One corollary of this is that if the configuration of a crtc only partially changes (e.g. a connector moves in a cloned config) the helper code will still disable/enable the full display pipeline. This is the only way to ensure that the enable/disable sequence is always the same. * It won't call disable or enable hooks more than once any more because it lost track of state, thanks to the atomic state tracking. And if drivers implement the ->reset hook properly (by either resetting the hw or reading out the hw state into the atomic structures) this even extends to the hardware state. So no more disable-me-harder kind of nonsense. * The only thing missing is the hw state readout/cross-check support, but if drivers have hw state readout support in their ->reset handlers it's simple to extend that to cross-check the hw state. * The crtc->mode_set callback is gone and its replacement only sets crtc timings and no longer updates the primary plane state. This way we can finally implement primary planes properly. - The new plane helpers should be suitable enough for pretty much everything, and a perfect fit for hardware with GO bits. Even if they don't fit the atomic helper library is rather flexible and exports all the functions for the individual steps to drivers. So drivers can pick what matches and implement their own magic for everything else. - A big difference compared to all previous atomic series is that this one doesn't implement async commit in a generic way. Imo driver requirements for that are too diverse to create anything reasonable sane which would actually work on a reasonable amount of different drivers. Also, we've never had a helper library for page_flips even, so it's really hard to know what might work and what's stupid without a bit of experience in the form of a few driver implementations. I think with the current flexibility for drivers to pick individual stages and existing helpers like drm_flip_queue it's rather easy though to implement proper async commit. - There's a few other differences of minor importance to earlier atomic series: * Common/generic properties are parsed in the callers/core and not in drivers, and passed to drivers by directly setting the right members in atomic state structures. That greatly simplifies all the transitional and legacy helpers an removes a lot of boilerplate code. * There's no crazy trylock mode used for the async commit since these helpers don't do async commit. A simple ordered flip queue of atomic state updates should be sufficient for preventing concurrent hw access anyway, as long as synchronous updates stall correctly with e.g. flush_work_queue or similar function. Abusing locks to enforce ordering isn't a good idea imo anyway. * These helpers reuse the existing ->mode_fixup hooks in the atomic_check callback. Which means that drivers need to adapat and move a lot less code into their atomic_check callbacks. Now this isn't everything needed in the drm core and helpers for full atomic support. But it's enough to start with converting drivers, and except for actually testing multiplane and multicrtc updates also enough to implement full atomic updates. Still missing are: - Per-plane locking. Since these helpers here encapsulate the locking completely this should be fairly easy to implement. - fbdev support for atomic_check/commit, so that multi-pipe finally works sanely in fbcon. - Adding and decoding shared/core properties. That just needs to be rebased from Rob's latest patch series, with minor adjustments so that the decoding happens in the core instead of in drivers. - Actually adding the atomic ioctl. Again just rebasing Rob's latest patch should be all that's needed. - Resolving how to deal with DPMS in atomic. Atomic is a good excuse to fix up the crazy semantics dpms currently has. I'm floating an RFC about this topic already. - Finally I couldn't test connector/encoder stealing properly since my test vehicle here doesn't allow a connector on different crtcs. So drivers which support this might see some surprises in that area. There is no semantic change though in how encoder stealing and assignment works (or at least no intended one), so I think the risk is minimal. As just mentioned I've done a fake conversion of an existing driver using crtc helpers to debug the helper code and validate the smooth transition approach. And that smooth transition was the really big motivation for this. It seems to actually work and consists of 3 phases: Phase 1: Rework driver backend for crtc/plane helpers The requirement here is that universal plane support is already implement. If universal plane support isn't implement yet it might be better though to just do it as part of this phase, directly using the new plane helpers. There are two big things to do: - Split up the existing ->update/disable_plane hooks into check/commit hooks and extract the crtc-wide prep/flush parts (like setting/clearing GO bits). - The other big change is to split the crtc->mode_set hook into the plane update (done using the plane helpers) and the crtc setup in a new ->mode_set_nofb hook. When phase 1 is complete the driver implements all the new callbacks which push the software state into hardware, but still using all the legacy entry points and crtc helpers. The transitional helpers serve as impendance mismatch here. Phase 2: Rework state handling This consists of rolling out the state handling helpers for planes, crtcs and connectors and reviewing all ->mode_fixup and similar hooks to make sure they don't depend upon implicit global state which might change in the atomic world. Any such code must be moved into ->atomic_check functions which just rely on the free-standing atomic state update structures. This phase also adds a few small pieces of fixup code to make sure the atomic state doesn't get out of sync in the legacy driver callbacks. Phase 3: Roll out atomic support Now it's just about replacing vfuncs with the ones provided by the helper and filling out the small missing pieces (like atomic_check logic or async commit support needed for page_flips). Due to the prep work in phase 1 no changes to the driver backend functions should be required, and because of the prep work in phase 2 atomic implementations can be rolled out step-by-step. So if async commit ins't implemented yet page_flip can be implemented with the legacy functions without wreaking havoc in the other operations. * tag 'topic/atomic-helpers-2014-11-09' of git://anongit.freedesktop.org/drm-intel: drm/atomic: Refcounting for plane_state->fb drm: Docbook integration and over sections for all the new helpers drm/atomic-helpers: functions for state duplicate/destroy/reset drm/atomic-helper: implement ->page_flip drm/atomic-helpers: document how to implement async commit drm/atomic: Integrate fence support drm/atomic-helper: implementatations for legacy interfaces drm: Atomic crtc/connector updates using crtc/plane helper interfaces drm/crtc-helper: Transitional functions using atomic plane helpers drm/plane-helper: transitional atomic plane helpers drm: Add atomic/plane helpers drm: Global atomic state handling drm: Add atomic driver interface definitions for objects drm/modeset_lock: document trylock_only in kerneldoc drm: fixup kerneldoc in drm_crtc.h drm: Pull drm_crtc.h into the kerneldoc template drm: Move drm_crtc_init from drm_crtc.h to drm_plane_helper.h
2014-11-09Linux 3.18-rc4v3.18-rc4Linus Torvalds
2014-11-09Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - enable bpf syscall for compat - cpu_suspend fix when checking the idle state type - defconfig update * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: defconfig: update defconfig for 3.18 arm64: compat: Enable bpf syscall arm64: psci: fix cpu_suspend to check idle state type for index
2014-11-09Merge tag 'armsoc-for-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another quiet week: - a fix to silence edma probe error on non-supported platforms from Arnd - a fix to enable the PL clock for Parallella, to make mainline usable with the SDK. - a somewhat verbose fix for the PLL clock tree on VF610 - enabling of SD/MMC on one of the VF610-based boards (for testing) - a fix for i.MX where CONFIG_SPI used to be implicitly enabled and now needs to be added to the defconfig instead - another maintainer added for bcm2835: Lee Jones" * tag 'armsoc-for-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: zynq: Enable PL clocks for Parallella dma: edma: move device registration to platform code ARM: dts: vf610: add SD node to cosmic dts MAINTAINERS: update bcm2835 entry ARM: imx: Fix the removal of CONFIG_SPI option ARM: imx: clk-vf610: define PLL's clock tree
2014-11-09Merge branch 'devicetree/merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree bugfix from Grant Likely: "One buffer overflow bug that shouldn't be left around" * 'devicetree/merge' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: of: Fix overflow bug in string property parsing functions
2014-11-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fix from Chris Mason: "It's a one liner for an error cleanup path that leads to crashes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix kfree on list_head in btrfs_lookup_csums_range error cleanup
2014-11-09Merge tag 'driver-core-3.18-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core fixes from Greg KH: "Here are 3 tiny fixes for 3.18-rc4. One fixes up a long-stading race condition in the driver core for removing directories in /sys/devices/virtual/ and the other 2 fix up the wording of a new Kconfig option that was added in 3.18-rc1" * tag 'driver-core-3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: tiny: rename ENABLE_DEV_COREDUMP to ALLOW_DEV_COREDUMP tiny: reverse logic for DISABLE_DEV_COREDUMP sysfs: driver core: Fix glue dir race condition by gdp_mutex
2014-11-09Merge tag 'staging-3.18-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver fixes from Greg KH: "Here are some staging/iio fixes for 3.18-rc4. Nothing major, just a few bugfixes of things that have been reported" * tag 'staging-3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging:iio:ade7758: Remove "raw" from channel name staging:iio:ade7758: Fix check if channels are enabled in prenable staging:iio:ade7758: Fix NULL pointer deref when enabling buffer iio: as3935: allocate correct iio_device size io: accel: kxcjk-1013: Fix iio_event_spec direction iio: tsl4531: Fix compiler error when CONFIG_PM_OPS is not defined iio: adc: mxs-lradc: Disable the clock on probe failure iio: st_sensors: Fix buffer copy staging:iio:ad5933: Drop "raw" from channel names staging:iio:ad5933: Fix NULL pointer deref when enabling buffer
