2007-10-19Fix build break in tsi108.cOlof Johansson
Fix build break: drivers/net/tsi108_eth.c: In function 'tsi108_init_one': drivers/net/tsi108_eth.c:1633: error: expected ')' before 'dev' drivers/net/tsi108_eth.c:1633: warning: too few arguments for format make[2]: *** [drivers/net/tsi108_eth.o] Error 1 Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19qeth: remove header_ops bugUrsula Braun
Remove qeth bug caused by commit: [NET]: Move hardware header operations out of netdevice. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19ir-functions.c:(.text+0xbce18): undefined reference to `input_event'Randy Dunlap
[bugme-daemon@bugzilla.kernel.org wrote:] From: Randy Dunlap <randy.dunlap@oracle.com> Drivers that use lro functions should depend on INET, otherwise they may not link correctly. Let's not select INET. Select should be used only for library-like code, not to enable subsystems. ERROR: "lro_flush_all" [drivers/net/myri10ge/myri10ge.ko] undefined! ERROR: "lro_receive_frags" [drivers/net/myri10ge/myri10ge.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19NAPI: kconfig prompt and deleted doc fileRandy Dunlap
- make the kconfig NAPI option prompt consistent across all net drivers (other than EXPERIMENTAL; can it now be removed also, or is the new napi_struct implementation now EXPERIMENTAL ?) - remove comment about the now-deleted NAPI_HOWTO.txt file - clean up typos in Tulip NAPI & Interrupt Mitigation Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19phy/bitbang: missing MODULE_LICENSERandy Dunlap
Missing MODULE_LICENSE(), loading this module taints the kernel. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-19DM9000 initialization fixMike Rapoport
DM9000 driver returns success even if it is failed to detect the chip. Below patch fixes it. Signed-off-by: Mike Rapoport <mike@compulab.co.il> drivers/net/dm9000.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-18Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: pcnet32: remove private net_device_stats structure vortex_up should initialize "err" pcnet32: remove compile warnings in non-napi mode pcnet32: fix non-napi packet reception fix EMAC driver for proper napi_synchronize API sky2: shutdown cleanup napi_synchronize: waiting for NAPI forcedeth msi bugfix gianfar: fix obviously wrong #ifdef CONFIG_GFAR_NAPI placement fs_enet: Update for API changes gianfar: remove orphan struct. forcedeth: fix rx-work condition in nv_rx_process_optimized() too
2007-10-18Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: (37 commits) ide: set drive->autotune in ide_pci_setup_ports() triflex: always tune PIO opti621: always tune PIO cy82c693: always tune PIO cs5520: always tune PIO alim15x3: always tune PIO ide: add IDE_HFLAG_LEGACY_IRQS host flag ide: add IDE_HFLAG_SERIALIZE host flag ide: add IDE_HFLAG_ERROR_STOPS_FIFO host flag piix: add DECLARE_ICH_DEV() macro pdc202xx_old: add DECLARE_PDC2026X_DEV() macro pdc202xx_new: add DECLARE_PDCNEW_DEV() macro aec62xx: no need to disable UDMA in ->init_hwif method for ATP850UF ide: remove .init_setup from ide_pci_device_t serverworks: remove ->init_setup scc_pata: remove ->init_setup pdc202xx_old: remove ->init_setup pdc202xx_new: remove ->init_setup hpt366: remove ->init_setup cmd64x: remove ->init_setup ...
2007-10-19ide: set drive->autotune in ide_pci_setup_ports()Bartlomiej Zolnierkiewicz
Majority of host drivers using IDE PCI layer set drive->autotune, the only exceptions are: generic.c ns87415.c rz1000.c trm290.c * no ->set_pio_mode method it821x.c: * if memory allocation fails drive->autotune won't be set (but there also won't be ->set_pio_mode method in such case) piix.c: * MPIIX controller (no ->init_hwif method so also no ->set_pio_mode method) However if there is no ->set_pio_mode method there are no changes in behavior w.r.t. PIO tuning so always set drive->autotune in ide_pci_setup_ports(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19triflex: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19opti621: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19cy82c693: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19cs5520: always tune PIOBartlomiej Zolnierkiewicz
Since cs5520 uses VDMA best PIO mode was tuned anyway by ide_dma_check() but only if DMA was successfully initialized. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19alim15x3: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19ide: add IDE_HFLAG_LEGACY_IRQS host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_LEGACY_IRQS host flag to tell ide_pci_setup_ports() to set hwif->irq to legacy IRQ 14/15 (iff hwif->irq is not already set) and convert atiixp, piix, serverworks, sis5513 and slc90e66 host drivers to use it. While at it: * In piix.c add IDE_HFLAGS_PIIX define and don't use ->init_hwif for MPIIX. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_SERIALIZE host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_SERIALIZE host flag to tell ide_pci_setup_ports() to set hwif/mate->serialized and convert aec62xx, cs5530 and sc1200 host drivers to use it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_ERROR_STOPS_FIFO host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_ERROR_STOPS_FIFO host flag and use it instead of hwif->err_stops_fifo. As a side-effect this change fixes hwif->err_stops_fifo not being restored by ide_hwif_restore(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19piix: add DECLARE_ICH_DEV() macroBartlomiej Zolnierkiewicz
Add DECLARE_ICH_DEV() macro. While at it: * Add init_hwif_ich() (->init_hwif method) for ICH controllers. * Rename init_chipset_piix() to init_chipset_ich() and use it only for ICH controllers. * Remove no longer needed piix_is_ichx() helper. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19pdc202xx_old: add DECLARE_PDC2026X_DEV() macroBartlomiej Zolnierkiewicz
2007-10-19pdc202xx_new: add DECLARE_PDCNEW_DEV() macroBartlomiej Zolnierkiewicz
2007-10-19aec62xx: no need to disable UDMA in ->init_hwif method for ATP850UFBartlomiej Zolnierkiewicz
* No need to disable UDMA in ->init_hwif method for ATP850UF (and since we now always tune PIO it will be disabled by ->set_pio_mode calls anyway). * Bump driver version. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: remove .init_setup from ide_pci_device_tBartlomiej Zolnierkiewicz
Now that all users were fixed we can safely remove it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19serverworks: remove ->init_setupBartlomiej Zolnierkiewicz
Merge init_setup_{svwks,csb6}() into svwks_init_one(). While at it: * Remove redundant dev->device checks. * Operate on a local copy of serverworks_chipsets[] entry. * Use pci_resource_start(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19scc_pata: remove ->init_setupBartlomiej Zolnierkiewicz
2007-10-19pdc202xx_old: remove ->init_setupBartlomiej Zolnierkiewicz
* Split off pdc202ata4_fixup_irq() helper from init_setup_pdc202ata4(). * Merge init_setup_{pdc202ata4,pdc20265,pdc202xx}() into pdc202xx_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19pdc202xx_new: remove ->init_setupBartlomiej Zolnierkiewicz
* Split off pdc20270_get_dev2() helper from init_setup_pdc20270(). * Merge init_setup_{pdcnew,pdc20270,pdc20276}() into pdc202new_init_one(). While at it: * Change KERN_ level of interrupt fixup message from KERN_WARNING to KERN_INFO. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19hpt366: remove ->init_setupBartlomiej Zolnierkiewicz
* Split off hpt{374,371,366}_init() helper from init_setup_hpt{374,371,366}(). * Merge init_setup_{374,372n,371,372a,302,366}() into hpt366_init_one(). While at it: * Use "HPT36x" name for HPT366/HPT368 chipsets. * Add .chip_name to struct hpt_info and use it to set set d->name. * Convert .max_ultra in struct hpt_info to .udma_mask and use it to set d->udma_mask. * Fix hpt302 to use HPT302_ALLOW_ATA133_6 define. * Change HPT366/HPT374 interrupt fixup message from KERN_WARNING to KERN_INFO. * Use the second hpt366_chipsets[] entry for HPT37x chipsets using HPT36x PCI device ID and fix .enablebits/.host_flags for HPT36x hpt366_chipsets[] entry. * Bump driver version. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19cmd64x: remove ->init_setupBartlomiej Zolnierkiewicz
Merge init_setup_{cmd64x,cmd646}() into cmd64x_init_one(). Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19aec62xx: remove ->init_setupBartlomiej Zolnierkiewicz
Merge init_setup_{aec62xx,aec6x80}() into aec62xx_init_one(). While at it: * Use id->driver_data instead of dev->device. * Use ATA_UDMA6 define. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: use I/O ops directly part #2 (take 2)Bartlomiej Zolnierkiewicz
v2: - bump host driver versions (as suggested by Sergei) - use I/O ops directly in drivers/ide/setup-pci.c Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: use pci_dev->revisionBartlomiej Zolnierkiewicz
Some places were using PCI_CLASS_REVISION instead of PCI_REVISION_ID so they were not converted by commit 44c10138fd4bbc4b6d6bff0873c24902f2a9da65. Cc: Auke Kok <auke-jan.h.kok@intel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19cmd64x: Use dev->revisionAuke Kok
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19amd74xx: Omit PCI_REVISION_ID readAuke Kok
2007-10-19ide: add ->mwdma_mask and ->swdma_mask to ide_pci_device_t (take 2)Bartlomiej Zolnierkiewicz
* Add ->mwdma_mask and ->swdma_mask to ide_pci_device_t. * Set ide_hwif_t DMA masks using DMA masks from ide_pci_device_t in setup-pci.c::ide_pci_setup_ports() (iff DMA base is valid and ->init_hwif method may still override them). * Convert IDE PCI host drivers to use ide_pci_device_t DMA masks. While at it: * Use ATA_{UDMA,MWDMA,SWDMA}* defines. * hpt34x.c: add separate ide_pci_device_t instances for HPT343 and HPT345. * serverworks.c: fix DMA masks being set before checking DMA base. v2: * Add missing masks to DECLARE_GENERIC_PCI_DEV() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19pdc202xx_old: remove broken SWDMA supportBartlomiej Zolnierkiewicz
Documentation doesn't mention SWDMA and moreover all timings used for SWDMA modes were over-clocked when compared to ATA spec. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_LBA48 and IDE_HFLAG_NO_LBA48_DMA host flagsBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_LBA48[_DMA] host flags, use it instead of hwif->no_lba48[_dma] and then remove no longer needed hwif->no_lba48[_dma]. As a side-effect this change fixes hwif->no_lba48_dma not being restored by ide_hwif_restore(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: remove ->init_setup_dma from ide_pci_device_t (take 2)Bartlomiej Zolnierkiewicz
* Make ide_pci_device_t.host_flags u32 and add IDE_HFLAG_CS5520 host flag. * Pass ide_pci_device_t *d to setup-pci.c::ide_get_or_set_dma_base() and use d->name instead of hwif->cds->name. * Set IDE_HFLAG_CS5520 host flag in cs5520 host driver and use it in ide_get_or_set_dma_base() to find out which PCI BAR to use, remove no longer needed cs5520.c::cs5520_init_setup_dma() and ide_pci_device_t.init_setup_dma. This fixes PCI bus-mastering not being checked for CS5510/CS5520 hosts. v2: * It is wrong to check simplex bits on CS5510/CS5520 as v1 did. (Noticed by Alan). Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_{DMA,AUTODMA} host flagsBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_{DMA,AUTODMA} host flags. Convert all host drivers using ide_pci_device_t to use these flags instead of d->autodma and then remove no longer needed d->autodma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_BOOTABLE host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_BOOTABLE host flag and IDE_HFLAG_OFF_BOARD define. Convert all host drivers using ide_pci_device_t to use IDE_HFLAG_{BOOTABLE,OFF_BOARD} instead of d->bootable and then remove no longer needed d->bootable. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_ATAPI_DMA host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_ATAPI_DMA host flag and set it in host drivers which don't support ATAPI DMA. Then remove no longer needed hwif->atapi_dma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add DECLARE_GENERIC_PCI_DEV() macro to generic IDE PCI host driverBartlomiej Zolnierkiewicz
* Add DECLARE_GENERIC_PCI_DEV() macro to generic IDE PCI host driver and use it to cleanup generic_chipsets[]. * Remove dead/obsolete code while at it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19siimage: bump driver versionBartlomiej Zolnierkiewicz
2007-10-19ide: Fix cs5535 driver accessing beyond array boundaryBenjamin Herrenschmidt
The cs5535 uses an incorrect construct to access the other drive of a pair, causing it to access beyond an array boundary on the secondary interface. This fixes it by using the new ide_get_paired_drive() helper instead. Bart: patch description fixes Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: Fix siimage driver accessing beyond array boundaryBenjamin Herrenschmidt
The siimage uses an incorrect construct to access the other drive of a pair, causing it to access beyond an array boundary on the secondary interface. This fixes it by using the new ide_get_paired_drive() helper instead. Bart: patch description fixes Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: Add ide_get_paired_drive() helperBenjamin Herrenschmidt
This adds a helper to get to the "other" drive on a pair connected to a given hwif. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-18Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrtLinus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrt: hrtimer: hook compat_sys_nanosleep up to high res timer code hrtimer: Rework hrtimer_nanosleep to make sys_compat_nanosleep easier
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] kill ata_sg_is_last() Update libata driver for bf548 atapi controller against the 2.6.24 tree. libata-sff: Correct use of check_status() drivers/ata: add support to Freescale 3.0Gbps SATA Controller pata_acpi: fix build breakage if !CONFIG_PM
2007-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: mv watchdog tree under drivers
2007-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: reduce schedstat variable overhead a bit sched: add KERN_CONT annotation sched: cleanup, make struct rq comments more consistent sched: cleanup, fix spacing sched: fix return value of wait_for_completion_interruptible()
2007-10-18Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] time: Move R4000 clockevent device code to separate configurable file [MIPS] time: Delete dead cycles_per_jiffy, mips_timer_ack and null_timer_ack [MIPS] IP32: Retire use of plat_timer_setup. [MIPS] Jazz: Retire use of plat_timer_setup. [MIPS] IP27: Convert to clock_event_device. [MIPS] JMR3927: Convert to clock_event_device. [MIPS] Always do the ARC64_TWIDDLE_PC thing.
