When using aes-xcbc-mac for authentication in IPsec,
the kernel crashes. It seems this algorithm doesn't
account for the space IPsec may make in scatterlist for authtag.
Thus when crypto_xcbc_digest_update2() gets called,
nbytes may be less than sg[i].length.
Since nbytes is an unsigned number, it wraps
at the end of the loop allowing us to go back
into loop and causing crash in memcpy.
I used update function in digest.c to model this fix.
Please let me know if it looks ok.
Signed-off-by: Joy Latten <latten@austin.ibm.com>
The XTS blockmode uses a copy of the IV which is saved on the stack
and may or may not be properly aligned. If it is not, it will break
hardware cipher like the geode or padlock.
This patch encrypts the IV in place so we don't have to worry about
alignment.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
Tested-by: Stefan Hellermann <stefan@the2masters.de>
Every file should include the headers containing the externs for its
global code (in this case for struct crypto_{init,exit}_digest_ops()).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The authenc algorithm requires BLKCIPHER to be present.
For compatibility with dm-crypt initramfs setups it is useful to merge
chainiv/seqiv into the crypto_blkcipher module. Since they're required
by most algorithms anyway this is an acceptable trade-off.
This patch fixes the following build error caused by commit
3631c650c495d61b1dabf32eb26b46873636e918:
<-- snip -->
LD .tmp_vmlinux1
crypto/built-in.o: In function `skcipher_null_crypt':
crypto_null.c:(.text+0x3d14): undefined reference to `blkcipher_walk_virt'
crypto_null.c:(.text+0x3d14): relocation truncated to fit: R_MIPS_26 against `blkcipher_walk_virt'
crypto/built-in.o: In function `$L32':
crypto_null.c:(.text+0x3d54): undefined reference to `blkcipher_walk_done'
crypto_null.c:(.text+0x3d54): relocation truncated to fit: R_MIPS_26 against `blkcipher_walk_done'
crypto/built-in.o:(.data+0x2e8): undefined reference to `crypto_blkcipher_type'
make[1]: *** [.tmp_vmlinux1] Error 1
<-- snip -->
Building latest git fails with the following error:
ERROR: "crypto_alloc_ablkcipher" [crypto/tcrypt.ko] undefined!
This appears to happen because CONFIG_CRYPTO_TEST is set while
CONFIG_CRYPTO_BLKCIPHER is not.
The following patch fixes the problem for me.
Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com>
The CRYPTO_DEV_HIFN_795X_RNG ifdefs are missing the CONFIG_ prefix.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: add USB IDs for MacBook 3rd generation
HID: add LCSPEC from VERNIER to quirk list
HID: fix processing of event quirks
HID: Blacklist new GTCO CalComp USB device PIDs
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: DMI: quirk for FSC ESPRIMO Mobile V5505
ACPI: DMI blacklist updates
pnpacpi: __initdata is not an identifier
ACPI: static acpi_chain_head
ACPI: static acpi_find_dsdt_initrd()
ACPI: static acpi_no_initrd_override_setup()
thinkpad_acpi: static
ACPI suspend: Execute _WAK with the right argument
cpuidle: Add Documentation
ACPI, cpuidle: Clarify C-state description in sysfs
ACPI: fix suspend regression due to idle update
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (46 commits)
sh: Fix multiple UTLB hit on UP SH-4.
sh: fix pci io access for r2d boards
sh: fix ioreadN_rep and iowriteN_rep
sh: use ctrl_in/out for on chip pci access
sh: Kill off more dead symbols.
sh: __uncached_start only on sh32.
sh: asm/irq.h needs asm/cpu/irq.h.
serial: sh-sci: Fix up SH-5 build.
sh: Get SH-5 caches working again post-unification.
maple: Fix up maple build failure.
sh: Kill off bogus SH_SDK7780_STANDALONE symbol.
sh: asm/tlb.h needs linux/pagemap.h for CONFIG_SWAP=n.
sh: Tidy include/asm-sh/hp6xx.h
maple: improve detection of attached peripherals
sh: Shut up some trivial build warnings.
sh: Update SH-5 flush_cache_sigtramp() for API changes.
sh: Fix up set_fixmap_nocache() for SH-5.
sh: Fix up pte_mkhuge() build breakage for SH-5.
sh: Disable big endian for SH-5.
sh: Handle SH7366 CPU in check_bugs().
* git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-hrt:
hrtimer: catch expired CLOCK_REALTIME timers early
hrtimer: check relative timeouts for overflow
git://git.kernel.org/pub/scm/linux/kernel/git/christoph/vm
* 'slab-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/christoph/vm:
slub: Support 4k kmallocs again to compensate for page allocator slowness
slub: Fallback to kmalloc_large for failing higher order allocs
slub: Determine gfpflags once and not every time a slab is allocated
make slub.c:slab_address() static
slub: kmalloc page allocator pass-through cleanup
slab: avoid double initialization & do initialization in 1 place
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cma: Do not issue MRA if user rejects connection request
mlx4_core: Move table_find from fmr_alloc to fmr_enable
IB/mlx4: mlx4_ib_fmr_alloc() should call mlx4_fmr_enable()
IPoIB: Remove unused struct ipoib_cm_tx.ibwc member
IPoIB: On P_Key change event, reset state properly
IB/mthca: Convert to use be16_add_cpu()
RDMA/cxgb3: Fail loopback connections
IB/cm: Fix infiniband_cm class kobject ref counting
IB/cm: Remove debug printk()s that snuck upstream
IB/mthca: Add missing sg_init_table() in mthca_map_user_db()
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86:
x86: cpa, fix out of date comment
KVM is not seen under X86 config with latest git (32 bit compile)
x86: cpa: ensure page alignment
x86: include proper prototypes for rodata_test
x86: fix gart_iommu_init()
x86: EFI set_memory_x()/set_memory_uc() fixes
x86: make dump_pagetable() static
x86: fix "BUG: sleeping function called from invalid context" in print_vma_addr()
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Remove unused CONFIG_WANT_DEVICE_TREE
[POWERPC] Cell RAS: Remove DEBUG, and add license and copyright
[POWERPC] hvc_rtas_init() must be __init
[POWERPC] free_property() must not be __init
[POWERPC] vdso_do_func_patch{32,64}() must be __init
[POWERPC] Remove generated files on make clean
[POWERPC] Fix arch/ppc compilation - add typedef for pgtable_t
[POWERPC] Wire up new timerfd syscalls
[POWERPC] PS3: Update sys-manager button events
[POWERPC] PS3: Sys-manager code cleanup
[POWERPC] PS3: Use system reboot on restart
[POWERPC] PS3: Fix bootwrapper hang bug
[POWERPC] PS3: Fix reading pm interval in logical performance monitor
[POWERPC] PS3: Fix setting bookmark in logical performance monitor
[POWERPC] Fix DEBUG_PREEMPT warning when warning
Extract the common code to remove a dentry from the lru into a new function
dentry_lru_remove().
Two call sites used list_del() instead of list_del_init(). AFAIK the
performance of both is the same. dentry_lru_remove() does a list_del_init().
As a result dentry->d_lru is now always empty when a dentry is freed.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to
reflect this.
[akpm@linux-foundation.org: fix build in mm/memory.c]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Christoph Hellwig <hch@infradead.org>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
seq_path() is always called with a dentry and a vfsmount from a struct path.
Make seq_path() take it directly as an argument.
I'm embedding struct path into struct svc_expkey.
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
I'm embedding struct path into struct svc_export.
[ezk@cs.sunysb.edu: NFSD: fix wrong mnt_writer count in rename]
Acked-by: J. Bruce Fields <bfields@citi.umich.edu>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu>
get_dcookie() is always called with a dentry and a vfsmount from a struct
path. Make get_dcookie() take it directly as an argument.
proc_get_link() is always called with a dentry and a vfsmount from a struct
path. Make proc_get_link() take it directly as an argument.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
audit_log_d_path() is a d_path() wrapper that is used by the audit code. To
use a struct path in audit_log_d_path() I need to embed it into struct
avc_audit_data.
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Move and update d_path() kernel API documentation.
All callers to __d_path pass the dentry and vfsmount of a struct path to
__d_path. Pass the struct path directly, instead.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
In nearly all cases the set_fs_{root,pwd}() calls work on a struct
path. Change the function to reflect this and use path_get() here.
Acked-by: Christoph Hellwig <hch@lst.de>
* Use struct path in fs_struct.
This introduces the symmetric function to path_put() for getting a reference
to the dentry and vfsmount of a struct path in the right order.
Use path_put() in a few places instead of {mnt,d}put()
* Add path_put() functions for releasing a reference to the dentry and
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
Move the definition of struct path into its own header file for further
patches.
path_release_on_umount() should only be called from sys_umount(). I merged the
function into sys_umount() instead of having in in namei.c.
This test seems to be unnecessary since we always have rootfs mounted before
calling a usermodehelper.
Acked-by: Greg KH <greg@kroah.com>
The sound drivers and the pnpbios core test for current->root != NULL. This
initializing the drivers.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Jaroslav Kysela <perex@suse.cz>
Acked-by: Takashi Iwai <tiwai@suse.de>
Add explanation of I_DIRTY_DATASYNC bit.
Cc: Joern Engel <joern@logfs.org>
configfs.h uses the container_of macro and as such should include kernel.h.
Signed-off-by: Ben Nizette <bn@niasdigital.com>
Cc: Joel Becker <Joel.Becker@oracle.com>
Change my name & email in MAINTAINERS
Signed-off-by: Christine Caulfield <christine.caulfield@googlemail.com>
The warning issued by fs/binfmt_flat.c when the format handler is given a
non-FLAT and non-script executable is annoying to say the least when working
with FDPIC ELF objects. If you build a kernel that supports both FLAT and
FDPIC ELFs on no-mmu, every time you execute an FDPIC ELF, the kernel spits
out this message. While I understand a lot of newcomers to the no-mmu world
screw up generation of FLAT binaries, this warning is not usable for systems
that support more than just FLAT.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
Cc: Bernd Schmidt <bernds_cb1@t-online.de>
Acked-by: Greg Ungerer <gerg@snapgear.com>
Use tabs instead of spaces.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
I was looking at timers in the Coldfire system and I noticed that the
CONFIG_HIGHPROFILE option seems to be a little out of date.
Modify the extra asm flags for debugger capabilities, use asflags instead for
EXTRA_AFLAGS. Suggestion from Sam Ravnborg.
Avoid unneccessary use of xchg() in set_mb().
Remove bogus conditional jump in return from interrupt path. Reorder the code
path now that is not there.
Add linux-fsdevel to the VFS entry in MAINTAINERS
Signed-off-by: Paul Menage <menage@google.com>
fastcall is gone from the tree, no need to adjust the function prototypes
anymore for this.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Adrian Bunk reported the following compile error with a SVN head GCC:
CC arch/cris/arch-v10/lib/memset.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c: In function 'memset':
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:164: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:165: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:166: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:167: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:185: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:189: error: lvalue required as increment operand
/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/cris/arch-v10/lib/memset.c:192: error: lvalue required as increment operand
... etc ...
This is due to the use of the construct:
*((long*)dst)++ = lc;
Which is no longer legal since casts don't return an lvalue.
The solution is to import the implementation from newlib,
which is continually autotested together with GCC mainline,
and uses the construct:
*(long *) dst = lc; dst += 4;
With this change, the generated code actually shrinks 76 bytes
since gcc notices that it can use autoincrement for the move
instruction in CRIS.
304 0 0 304 130 memset.old.o
228 0 0 228 e4 memset.o
Since this is an import of a file from newlib, I'm not touching
the formatting or correcting any checkpatch errors.
Note also that even if the two files for the CRIS v10 and CRIS v32
are identical at the moment, it might be possible to tweak the
CRIS v32 version. Thus, I'm not yet folding them into the same file,
at least not until we've done some research on it.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <mikael.starvik@axis.com>
Cc: Adrian Bunk <bunk@stusta.de>
inotify_max_user_instances, inotify_max_user_watches,
inotify_max_queued_events can all be made static.
This patch fixes the following compile error with CONFIG_MODULES=n
caused by commit fb40bd78b0f91b274879cf5db8facd1e04b6052e:
/home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/marker.c: In function `marker_update_probes':
/home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/marker.c:627: error: too few arguments to function `module_update_markers'
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
