2006-06-26[PATCH] work around ppc64 bootup bug by making mutex-debugging save/restore irqsIngo Molnar
It seems ppc64 wants to lock mutexes in early bootup code, with interrupts disabled, and they expect interrupts to stay disabled, else they crash. Work around this bug by making mutex debugging variants save/restore irq flags. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fix "USB: move <linux/usb_input.h> to <linux/usb/input.h>"Andrew Morton
Update this driver for recent header file movement. Cc: David Brownell <david-b@pacbell.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] uclinux: use PER_LINUX_32BIT in binfmt_flatMalcolm Parsons
binfmt_flat.c calls set_personality with PER_LINUX as the personality. On the arm architecture this results in the program running in 26bit usermode. PER_LINUX_32BIT should be used instead. This doesn't affect other architectures that use binfmt_flat. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: make enable_irq() macro statementGreg Ungerer
Change enable_irq() macro to be a statement, not expression. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: fix ColdFire 5249 PLL setGreg Ungerer
Fix PLL setting for the Coldfire 5249 CPU. This brings it into line with the new style frequency configuration of m68knommu parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: ColdFire cache flush fixupsGreg Ungerer
Fix flush code for the ColdFire 5206/5206e/5272 cases. Add support for the new ColdFire 532x CPU family Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: improve syscall entry and fix stracePhilippe De Muyter
Here is a patch to the system call handling for 5307/5272/etc to: - fix the strace support (one tested the wrong bit) - make all system calls a little bit faster by inlining set_esp0 and supporting ENOSYS out of the critical path. - remove extraneous spaces Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: force stack alignment on ColdFireGreg Ungerer
This patch solve a bug triggered by execvp (this function use calloc to store the argument list and gcc 3.4.x align the stack to word, not to dword). This situation aren't related to signal handling and all 2.6.x have the bug. On ColdFire targets we must force the stack to be aligned. Original patch from Andrea Tarani <andrea.tarani@gilbarco.com>, Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: configurable frequency selection headerGreg Ungerer
Remove list of fixed clock frequency options used for configuring master clock, and make field an int. Much more flexible this way, no need to add more options for every new used freqency. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: configurable frequency selectionGreg Ungerer
2006-06-25[PATCH] m68knommu: configure support for Avnet5282 boardGreg Ungerer
Add support for the AVNET 5282 board. Patch submitted by Daniel Alomar <dalomar@serrasold.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: ColdFire 532x CPU configure supportGreg Ungerer
Add configure support for the new Freescale 532x family of CPUs. Patch submitted by Matt Waddel <Matt.Waddel@freescale.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Revert "swsusp special saveable pages support" commitsLinus Torvalds
This reverts commits 3e3318dee0878d42ed62a19c292a2ac284135db3 [PATCH] swsusp: x86_64 mark special saveable/unsaveable pages b6370d96e09944c6e3ae8d5743ca8a8ab1f79f6c [PATCH] swsusp: i386 mark special saveable/unsaveable pages ce4ab0012b32c1a4a1d6e934aeb73bf3151c48d9 [PATCH] swsusp: add architecture special saveable pages support because not only do they apparently cause page faults on x86, the infrastructure doesn't compile on powerpc. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: ColdFire 532x CPU platform build supportGreg Ungerer
Add build support for the new Freescale 532x CPU platforms. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: add ColdFire 532x UART address supportGreg Ungerer
Add support for the UART addressing on the new Freescale M532x CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: add ColdFire 532x timer build supportGreg Ungerer
Add build support for new Freescale M532x CPU family timer. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: cleanup setup.cGreg Ungerer
A cleanup of m68knommu/kernel/setup.c : - No need to initialize global pointers to NULL, they will have that value automatically, and they eat up space in my data segment image in FLASH. - Remove get_cpuinfo. It has been replaced by show_cpuinfo. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: check DEBUG defined arch codeGreg Ungerer
Don't rely on DEBUG having a value, check for it being defined. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: include ColdFire 532x register definitionsGreg Ungerer
Include the ColdFire 532x support when including ColdFire peripharp support definitions. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: add ColdFire 532x cache initGreg Ungerer
Add cache init support for the new ColdFire 532x CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: 532x UART supportGreg Ungerer
ColdFire serial driver support for the new 532x CPU family UARTs. Patch submitted by Matt Waddel <Matt.Waddel@freescale.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: ColdFire 532x register definitionsGreg Ungerer
Register definitions for the new Freescale 532x Coldfire CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: ColdFire 532x CPU startup codeGreg Ungerer
Add kernel startup code for the new Freescale 532x CPU family. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: read/write register access for PIT timerGreg Ungerer
Modify the m68knommu/ColdFire PIT timer code to use register offsets with raw_read/raw_write access, instead of a mapped struct. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: remove use of rom_lengthGreg Ungerer
Remove use of rom_length. It serves not real purpose, and when we move to new stye RAM configuration it will not be needed. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: switch arch config name to CONFIG_M68KGreg Ungerer
Switch to naming the architecture config options for the m68knommu branch as "M68K", dropping "M68KNOMMU". The CONFIG_MMU separates the 2 now, and the m68knommu branch is still strictly speaking an M68K (including the ColdFire parts). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: read/write register access for ColdFire core timerGreg Ungerer
Modify the m68knommu/ColdFire core timer code to use register offsets with raw_read/raw_write access, instead of a mapped struct. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] m68knommu: 532x FEC eth struct mapGreg Ungerer
Specify the struct mapping used on the new Freescale 532x CPU family's FEC ethernet core. Patch submitted by Matt Waddel <Matt.Waddel@freescale.com>. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] spufs: update ->flush method protoAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] xfs: update ->flush method protoAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/iser: iSER Kconfig and Makefile IB/iser: iSER handling of memory for RDMA IB/iser: iSER RDMA CM (CMA) and IB verbs interaction IB/iser: iSER initiator iSCSI PDU and TX/RX IB/iser: iSCSI iSER transport provider high level code IB/iser: iSCSI iSER transport provider header file IB/uverbs: Remove unnecessary list_del()s IB/uverbs: Don't free wr list when it's known to be empty
2006-06-25Fix NFS2 compile errorLinus Torvalds
Trond had apparently merged the same patch twice, causing a duplicate include of the "internal.h" file, with resulting obvious confusion. Tssk. I'm the only one allowed to send out trees that don't even compile! Who does this Trond guy think he is? Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] i386: Fix softirq accounting with 4K stacksBjörn Steinbrink
Copy the softirq bits in preempt_count from the current context into the hardirq context when using 4K stacks to make the softirq_count macro work correctly and thereby fix softirq cpu time accounting. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (51 commits) nfs: remove nfs_put_link() nfs-build-fix-99 git-nfs-build-fixes Merge branch 'odirect' NFS: alloc nfs_read/write_data as direct I/O is scheduled NFS: Eliminate nfs_get_user_pages() NFS: refactor nfs_direct_free_user_pages NFS: remove user_addr, user_count, and pos from nfs_direct_req NFS: "open code" the NFS direct write rescheduler NFS: Separate functions for counting outstanding NFS direct I/Os NLM: Fix reclaim races NLM: sem to mutex conversion locks.c: add the fl_owner to nlm_compare_locks NFS: Display the chosen RPCSEC_GSS security flavour in /proc/mounts NFS: Split fs/nfs/inode.c NFS: Fix typo in nfs_do_clone_mount() NFS: Fix compile errors introduced by referrals patches NFSv4: Ensure that referral mounts bind to a reserved port NFSv4: A root pathname is sent as a zero component4 NFSv4: Follow a referral ...
2006-06-25Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (244 commits) V4L/DVB (4210b): git-dvb: tea575x-tuner build fix V4L/DVB (4210a): git-dvb versus matroxfb V4L/DVB (4209): Added some BTTV PCI IDs for newer boards Fixes some sync issues between V4L/DVB development and GIT V4L/DVB (4206): Cx88-blackbird: always set encoder height based on tvnorm->id V4L/DVB (4205): Merge tda9887 module into tuner. V4L/DVB (4203): Explicitly set the enum values. V4L/DVB (4202): allow selecting CX2341x port mode V4L/DVB (4200): Disable bitrate_mode when encoding mpeg-1. V4L/DVB (4199): Add cx2341x-specific control array to cx2341x.c V4L/DVB (4198): Avoid newer usages of obsoleted experimental MPEGCOMP API V4L/DVB (4197): Port new MPEG API to saa7134-empress with saa6752hs V4L/DVB (4196): Port cx88-blackbird to the new MPEG API. V4L/DVB (4193): Update cx2341x fw encoding API doc. V4L/DVB (4192): Use control helpers for saa7115, cx25840, msp3400. V4L/DVB (4191): Add CX2341X MPEG encoder module. V4L/DVB (4190): Add helper functions for control processing to v4l2-common. V4L/DVB (4189): Add videodev support for VIDIOC_S/G/TRY_EXT_CTRLS. V4L/DVB (4188): Add new MPEG control/ioctl definitions to videodev2.h V4L/DVB (4186): Add support for the DNTV Live! mini DVB-T card. ...
2006-06-25Fix PM_TRACE dependency: works only on 32-bit x86 for nowLinus Torvalds
Not that x86-64 and other architecture support should be difficult to add (trivial fixups to the data format and add the proper linker script entry). Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fix race in idr codeSonny Rao
I ran into a bug where the kernel died in the idr code: cpu 0x1d: Vector: 300 (Data Access) at [c000000b7096f710] pc: c0000000001f8984: .idr_get_new_above_int+0x140/0x330 lr: c0000000001f89b4: .idr_get_new_above_int+0x170/0x330 sp: c000000b7096f990 msr: 800000000000b032 dar: 0 dsisr: 40010000 current = 0xc000000b70d43830 paca = 0xc000000000556900 pid = 2022, comm = hwup 1d:mon> t [c000000b7096f990] c0000000000d2ad8 .expand_files+0x2e8/0x364 (unreliable) [c000000b7096faa0] c0000000001f8bf8 .idr_get_new_above+0x18/0x68 [c000000b7096fb20] c00000000002a054 .init_new_context+0x5c/0xf0 [c000000b7096fbc0] c000000000049dc8 .copy_process+0x91c/0x1404 [c000000b7096fcd0] c00000000004a988 .do_fork+0xd8/0x224 [c000000b7096fdc0] c00000000000ebdc .sys_clone+0x5c/0x74 [c000000b7096fe30] c000000000008950 .ppc_clone+0x8/0xc
2006-06-25[PATCH] update-devices.txtJan Engelhardt
Update Documentation/devices.txt with a new version from the LANANA site http://www.lanana.org/docs/device-list/devices-2.6+.txt Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] remove unlikely(sb) in prune_dcacheHua Zhong
likely profiling shows that the following is a miss. After boot: [+- ] Type | # True | # False | Function:Filename@Line +unlikely | 1074| 0 prune_dcache()@:fs/dcache.c@409 After a bonnie++ run: +unlikely | 66716| 19584 prune_dcache()@:fs/dcache.c@409 So remove it. Signed-off-by: Hua Zhong <hzhong@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Fix "biovec-(256)" in /proc/slabinfoAlexey Dobriyan
Stringify does what it was told to do. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Fix kdump Crash Kernel boot memory reservation for NUMA machinesAmul Shah
This patch will fix a boot memory reservation bug that trashes memory on the ES7000 when loading the kdump crash kernel. The code in arch/x86_64/kernel/setup.c to reserve boot memory for the crash kernel uses the non-numa aware "reserve_bootmem" function instead of the NUMA aware "reserve_bootmem_generic". I checked to make sure that no other function was using "reserve_bootmem" and found none, except the ones that had NUMA ifdef'ed out. I have tested this patch only on an ES7000 with NUMA on and off (numa=off) in a single (non-NUMA) and multi-cell (NUMA) configurations. Signed-off-by: Amul Shah <amul.shah@unisys.com> Looks-good-to: Vivek Goyal <vgoyal@in.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] s390: setup.c cleanup + build fixHeiko Carstens
Cleanup & fix 31 bit compilation: CC arch/s390/kernel/setup.o arch/s390/kernel/setup.c:83: error: initializer element is not computable at load time arch/s390/kernel/setup.c:83: error: (near initialization for 'code_resource.start') Not sure which patch in the -mm tree breaks this, but since this can be considered a cleanup it can be merged anyway. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] au1xxx: oss sound support for au1200Domen Puncer
au1550 ac97 driver works fine on au1200 too. Comments at the top of file state this code is GPL, so lets mark it as GPL too. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] parport: add to kernel-docRandy Dunlap
Add parport interfaces to kernel-doc template. Small doc. cleanups in 2 parport source files. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] au1550_ac97: spin_unlock in error pathDomen Puncer
Error paths didn't spin_unlock. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ext2: cleanup: put_page and comment fixEvgeniy Dushistov
Things which force me think a little: why so? Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] pacct: none-delayed process accounting accumulationKaiGai Kohei
In current 2.6.17 implementation, signal_struct refered from task_struct is used for per-process data structure. The pacct facility also uses it as a per-process data structure to store stime, utime, minflt, majflt. But those members are saved in __exit_signal(). It's too late. For example, if some threads exits at same time, pacct facility has a possibility to drop accountings for a part of those threads. (see, the following 'The results of original 2.6.17 kernel') I think accounting information should be completely collected into the per-process data structure before writing out an accounting record. This patch fixes this matter. Accumulation of stime, utime, minflt and majflt are done before generating accounting record. [mingo@elte.hu: fix acct_collect() siglock bug found by lockdep] Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] pacct: avoidance to refer the last thread as a representation of the ↵KaiGai Kohei
process When pacct facility generate an 'ac_flag' field in accounting record, it refers a task_struct of the thread which died last in the process. But any other task_structs are ignored. Therefore, pacct facility drops ASU flag even if root-privilege operations are used by any other threads except the last one. In addition, AFORK flag is always set when the thread of group-leader didn't die last, although this process has called execve() after fork(). We have a same matter in ac_exitcode. The recorded ac_exitcode is an exit code of the last thread in the process. There is a possibility this exitcode is not the group leader's one.
2006-06-25[PATCH] pacct: add pacct_struct to fix some pacct bugs.KaiGai Kohei
The pacct facility need an i/o operation when an accounting record is generated. There is a possibility to wake OOM killer up. If OOM killer is activated, it kills some processes to make them release process memory regions. But acct_process() is called in the killed processes context before calling exit_mm(), so those processes cannot release own memory. In the results, any processes stop in this point and it finally cause a system stall.
2006-06-25[PATCH] Corrections to memory barrier docDavid Howells
Apply some small corrections to the memory barrier document, as contributed by: Christoph Lameter <clameter@sgi.com> Kirill Smelkov <kirr@mns.spb.ru> Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
