It is always set to BUSSTATE_ON.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* Keep pointer to ->init_chipset method also in
struct ide_host and set it in ide_host_alloc_all().
* Add ide_pci_suspend() and ide_pci_resume() helpers
(default ->suspend and ->resume implementations).
* ->init_chipset can no longer be marked __devinit.
* Add proper PCI PM support to IDE PCI host drivers
(rz1000.c and tc86c001.c are skipped for now since
they need to be converted from using ->init_hwif
to use ->init_chipset instead).
v2:
* Cleanup CONFIG_PM #ifdef-s per akpm's suggestion.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
* Factor out disabling of "fast interrupt" prediction from
init_hwif_hpt366() to hpt3xx_disable_fast_irq() helper.
* Use hpt3xx_disable_fast_irq() in ->init_chipset instead of
->init_hwif method.
This is a preparation for adding proper PCI PM support.
While at it:
* Cache chip type in chip_type variable in hpt3xx_disable_fast_irq().
There should be no functional changes caused by this patch.
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Rename lba_capacity_is_ok() to ata_id_is_lba_capacity_ok()
and move it to <linux/ata.h> (remove needless parens while at it).
Cc: Jeff Garzik <jgarzik@pobox.com>
Rename ide_id_to_hd_driveid() to ata_id_to_hd_driveid()
and move it to <linux/ata.h>.
Use ata_id_is_cfa() in do_identify() instead of open-coding
check for CompactFlash devices (the inline helper also takes
care of detecting CFs advertising themselves as ATA disks).
* Add ata_id_flush_ext_enabled() inline helper to <linux/ata.h>.
* ide_id_has_flush_cache_ext() -> ata_id_flush_ext_enabled()
The latter one also checks if the command is marked as
supported in word 83 and validity of words 83 & 86.
* Add ata_id_flush_enabled() inline helper to <linux/ata.h>.
* ide_id_has_flush_cache() -> ata_id_flush_enabled()
All devices supporting CACHE FLUSH EXT command should also support
CACHE FLUSH command so it is sufficient to check only for CACHE FLUSH
in ide_id_has_flush_cache().
* Add ata_id_lba48_enabled() inline helper to <linux/ata.h>.
* idedisk_supports_lba48() -> ata_id_lba48_enabled()
The latter one also checks validity of words 83 & 86.
* Use optimized ATA version check from Sergei in ata_id_is_sata().
* ide_dev_is_sata() -> ata_id_is_sata()
* Remove (id[ATA_ID_FIELD_VALID] & 2) check from ide_dev_has_iordy()
(it is for validity of words 64-70, IORDY is in word 49).
* ide_dev_has_iordy() -> ata_id_has_iordy()
Factor out HDIO_{GET,SET}_NICE ioctl handling from
generic_ide_ioctl() to ide_{get,set}_nice_ioctl().
* Use drive->media and drive->scsi to check if ->dsc_overlap
can be set by HDIO_SET_NICE ioctl in generic_ide_ioctl().
* Remove unused ->supports_dsc_overlap field from ide_driver_t.
Factor out the common code from check_prefetch()
and set_prefetch_mode() to __set_prefetch_mode().
Just use SECTOR_SIZE instead.
* Add struct ide_devset, S_* flags, *DEVSET() & ide*_devset_*() macros.
* Add 'const struct ide_devset **settings' to ide_driver_t.
* Use 'const struct ide_devset **settings' in ide_drive_t instead of
'struct ide_settings_s *settings'. Then convert core code and device
drivers to use struct ide_devset and co.:
- device settings are no longer allocated dynamically for each device
but instead there is an unique struct ide_devset instance per setting
- device driver keeps the pointer to the table of pointers to its
settings in ide_driver_t.settings
- generic settings are kept in ide_generic_setting[]
- ide_proc_[un]register_driver(), ide_find_setting_by_name(),
ide_{read,write}_setting() and proc_ide_{read,write}_settings()
are updated accordingly
- ide*_add_settings() are removed
* Remove no longer used __ide_add_setting(), ide_add_setting(),
__ide_remove_setting() and auto_remove_settings().
* Remove no longer used TYPE_*, SETTING_*, ide_procset_t
and ide_settings_t.
* ->keep_settings, ->using_dma, ->unmask, ->noflush, ->dsc_overlap,
->nice1, ->addressing, ->wcache and ->nowerr ide_drive_t fields
can now be bitfield flags.
While at it:
* Rename ide_find_setting_by_name() to ide_find_setting().
* Rename write_wcache() to set_wcache().
After rework settings will be no longer created dynamically
for each device so we need to make some fixups first.
* Use set_[ksettings,unmaskirq]() as a set function for
["keepsettings","unmaskirq"] setting.
* Allow writes to ["io_32bit","unmaskirq"] settings also when
drive->no_[io_32bit,unmask] is set (this is checked later inside
set_[io_32bit,unmaskirq]() anywyay and keeps consistency with
the corresponding HDIO_SET_[32BIT,UNMASKINTR] ioctls).
* Use max possible multi sectors value (16) as an allowed max for
"multcount" setting. set_multcount() set function checks against
device's max possbile value anyway and it makes the proc setting
consistent with the corresponding HDIO_SET_MULTCOUNT ioctl.
Call ide_proc_register_driver() in ide*_setup() (just before
ide*_add_settings() call) instead of in ->probe method.
Despite being basically a preparation for /proc/ide/hd*/settings
rework this is a nice cleanup in itself.
* Include <linux/ata.h> directly in <linux/ide.h>
instead of through <linux/hdreg.h>.
* Include <linux/hdreg.h> only when needed.
Use multi PIO by default when available and remove no longer
needed CONFIG_IDEDISK_MULTI_MODE (it should be safe nowadays,
despite to what help entry has been saying).
* Change ide_get_paired_drive() to return NULL if peer device
is not present and update all users accordingly.
While at it:
* ide_get_paired_drive() -> ide_get_pair_dev()
* Use ide_get_pair_dev() in cs5530.c, sc1200.c and via82cxxx.c.
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Remove needless drive->present checks from ->probe methods
(device model takes care of that).
They just obfuscate the code.
init_irq() is now called only during initial host registration
so these BUG_ON()-s are no loner needed (+ the last one was done
too late anyway).
* Make ide_busy_sleep() take timeout value as a parameter
and also allow use of AltStatus Register if requested with
altstatus parameter. Update existing users accordingly.
* Convert ide_driveid_update() and actual_try_to_identify()
to use ide_busy_sleep().
Fix EXABYTENEST handling in probe_for_drive() (so drive->present
is checked for "nested" device) and cleanup enable_nest().
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Borislav Petkov <petkovbb@gmail.com>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
On Friday 25 July 2008, Linus Torvalds wrote:
> On Fri, 25 Jul 2008, Ben Dooks wrote:
> > personally, i would much prefer to see the loop being less evil
> > like:
> > for (p = s; p < end; p += 2)
> > be16_to_cpus((u16 *)p);
> Well, in this case, the code actually depends on 'p' being back at the
> start of the buffer by the end of it all, so it would need some more
> changes than that.
> But yes, I applied David's patch, but I _also_ suspect that we would be
> better off without code that does horrid things like casts and assignments
> inside the function arguments.
> So it would be nice to re-code that loop to be more readable. But due to
> the reliance of 'p' being 's' after the loop, the minimal patch would be
> something like the appended.
> Bartlomiej - take this or not, I'm not going to commit it - I haven't
> tested it, nor do I even have any machines that would trigger it. So this
> is more a "maybe something like this" than anything else.
From: Linus Torvalds <torvalds@linux-foundation.org>
CC: Ben Dooks <ben-linux@fluff.org>
Cc: harvey.harrison@gmail.com
Remove ->remap_0_to_1 and ->sect0 (they are always zero now).
* ERR_STAT -> ATA_ERR
* INDEX_STAT -> ATA_IDX
* ECC_STAT -> ATA_CORR
* DRQ_STAT -> ATA_DRQ
* SEEK_STAT -> ATA_DSC
* WRERR_STAT -> ATA_DF
* READY_STAT -> ATA_DRDY
* BUSY_STAT -> ATA_BUSY
* MARK_ERR -> ATA_AMNF
* TRK0_ERR -> ATA_TRK0NF
* ABRT_ERR -> ATA_ABORTED
* MCR_ERR -> ATA_MCR
* ID_ERR -> ATA_IDNF
* MC_ERR -> ATA_MC
* ECC_ERR -> ATA_UNC
* ICRC_ERR -> ATA_ICRC
* BBD_ERR -> ATA_BBK
Also:
* ILI_ERR -> ATAPI_ILI
* EOM_ERR -> ATAPI_EOM
* LFS_ERR -> ATAPI_LFS
* CD -> ATAPI_COD
* IO -> ATAPI_IO
* Use ATA_CMD_* defines instead of WIN_* ones.
* Include <linux/ata.h> directly instead of through <linux/hdreg.h>.
While at it:
* EXABYTE_ENABLE_NEXT -> ATA_EXABYTE_ENABLE_NEST
* SETFEATURES_{EN,DIS}_WCACHE -> SETFEATURES_WC_{ON,OFF}
* SETFEATURES_{EN,DIS}_AAM -> SETFEATURES_AAM_{ON,OFF}
* SMART_* -> ATA_SMART_*
* Remove stale comment from ide-proc.c.
Partially based on earlier work by Chris Wedgwood.
Acked-by: Chris Wedgwood <cw@f00f.org>
Acked-by: Jeff Garzik <jeff@garzik.org>
idedisk_supports_hpa() -> ata_id_hpa_enabled().
The latter one also checks validity of words 82 & 85.
Replace open-coded check by ata_id_wcache_enabled()
(which also checks validity of word 85).
Replace open-coded checks by ata_id_current_chs_valid().
* Factor out HDIO_[OBSOLETE,GET]_IDENTITY ioctls handling
to ide_get_identity_ioctl().
* Use temporary buffer in ide_get_identity_ioctl() instead
of accessing drive->id directly.
* Add ide_id_to_hd_driveid() inline to convert raw id into
struct hd_driveid format (needed on big-endian).
* Use ide_id_to_hd_driveid() in ide_get_identity_ioctl(),
cleanup ide_fix_driveid() and switch ide to use use raw id.
* Remove no longer needed drive->driveid.
This leaves us with 3 users of struct hd_driveid in tree:
- arch/um/drivers/ubd_kern.c
- drivers/block/xsysace.c
- drivers/usb/storage/isd200.c
While at it:
* Use ata_id_u{32,64}() and ata_id_has_{dma,lba,iordy}() macros.
Make drive->id an unnamed union so id can be accessed either by using
'u16 *id' or 'struct hd_driveid *driveid'. Then convert all existing
drive->id users accordingly (using 'u16 *id' when possible).
This is an intermediate step to make ide 'struct hd_driveid'-free.
While at it:
- Add missing KERN_CONTs in it821x.c.
- Use ATA_ID_WORDS and ATA_ID_*_LEN defines.
- Remove unnecessary checks for drive->id.
- s/drive_table/table/ in ide_in_drive_list().
- Cleanup ide_config_drive_speed() a bit.
- s/drive1/dev1/ & s/drive0/dev0/ in ide_undecoded_slave().
v2:
Fix typo in drivers/ide/ppc/pmac.c. (From Stephen Rothwell)
Do all __le16_to_cpu() swapping in one loop.
* Remove superfluous checks for drive->mult_req.
* No need to zero drive's fields.
* Move the common code out of #ifdef scope.
This condition is checked by both ide_disk_init_mult_count()
and set_multcount() so no need to do it again in ide_disk_special().
The format specifier for rq->sector didn't specify the proper size and
signedness. Borislav Petkov discovered that the signedness for
rq->nr_sectors and rq->current_nr_sectors also were incorrect.
Signed-off-by: Mark de Wever <koraq@xs4all.nl>
Acked-by: Borislav Petkov <petkovbb@gmail.com>
[bart: remove trailing whitespace]
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: skcipher - Use RNG interface instead of get_random_bytes
crypto: rng - RNG interface and implementation
crypto: api - Add fips_enable flag
crypto: skcipher - Move IV generators into their own modules
crypto: cryptomgr - Test ciphers using ECB
crypto: api - Use test infrastructure
crypto: cryptomgr - Add test infrastructure
crypto: tcrypt - Add alg_test interface
crypto: tcrypt - Abort and only log if there is an error
crypto: crc32c - Use Intel CRC32 instruction
crypto: tcrypt - Avoid using contiguous pages
crypto: api - Display larval objects properly
crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookup
crypto: Kconfig - Replace leading spaces with tabs
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (29 commits)
RDMA/nes: Fix slab corruption
IB/mlx4: Set RLKEY bit for kernel QPs
RDMA/nes: Correct error_module bit mask
RDMA/nes: Fix routed RDMA connections
RDMA/nes: Enhanced PFT management scheme
RDMA/nes: Handle AE bounds violation
RDMA/nes: Limit critical error interrupts
RDMA/nes: Stop spurious MAC interrupts
RDMA/nes: Correct tso_wqe_length
RDMA/nes: Fill in firmware version for ethtool
RDMA/nes: Use ethtool timer value
RDMA/nes: Correct MAX TSO frags value
RDMA/nes: Enable MC/UC after changing MTU
RDMA/nes: Free NIC TX buffers when destroying NIC QP
RDMA/nes: Fix MDC setting
RDMA/nes: Add wqm_quanta module option
RDMA/nes: Module parameter permissions
RDMA/cxgb3: Set active_mtu in ib_port_attr
RDMA/nes: Add support for 4-port 1G HP blade card
RDMA/nes: Make mini_cm_connect() static
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm:
dlm: choose better identifiers
dlm: remove bkl
dlm: fix address compare
dlm: fix locking of lockspace list in dlm_scand
dlm: detect available userspace daemon
dlm: allow multiple lockspace creates
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm: detect lost queue
dm: publish dm_vcalloc
dm: publish dm_table_unplug_all
dm: publish dm_get_mapinfo
dm: export struct dm_dev
dm crypt: avoid unnecessary wait when splitting bio
dm crypt: tidy ctx pending
dm crypt: fix async inc_pending
dm crypt: move dec_pending on error into write_io_submit
dm crypt: remove inc_pending from write_io_submit
dm crypt: tidy write loop pending
dm crypt: tidy crypt alloc
dm crypt: tidy inc pending
dm exception store: use chunk_t for_areas
dm exception store: introduce area_location function
dm raid1: kcopyd should stop on error if errors handled
dm mpath: remove is_active from struct dm_path
dm mpath: use more error codes
Fixed up trivial conflict in drivers/md/dm-mpath.c manually.
Currently we disable barriers as soon as we get a buffer in xlog_iodone
that has the XBF_ORDERED flag cleared. But this can be the case not only
for buffers where the barrier failed, but also the first buffer of a
split log write in case of a log wraparound. Due to the disabled
barriers we can easily get directory corruption on unclean shutdowns.
So instead of using this check add a new buffer flag for failed barrier
writes.
This is a regression vs 2.6.26 caused by patch to use the right macro
to check for the ORDERED flag, as we previously got true returned for
every buffer.
Thanks to Toei Rei for reporting the bug.
Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
Reviewed-by: David Chinner <david@fromorbit.com>
Signed-off-by: Tim Shimmin <tes@sgi.com>
