Implement for_each_free_mem_range() which iterates over free memory
areas according to memblock (memory && !reserved). This will be used
to simplify memblock users.
Link: http://lkml.kernel.org/r/1310462166-31469-7-git-send-email-tj@kernel.org
Cc: Yinghai Lu <yinghai@kernel.org>
early_reserve_e820() implements its own ad-hoc early allocator using
memblock_x86_find_in_range_size(). Use __memblock_alloc_base()
instead and remove the unnecessary @startt parameter (it's top-down
allocation anyway).
Link: http://lkml.kernel.org/r/1310462166-31469-6-git-send-email-tj@kernel.org
From 5732e1247898d67cbf837585150fe9f68974671d Mon Sep 17 00:00:00 2001
Date: Thu, 14 Jul 2011 11:22:16 +0200
Convert x86 to HAVE_MEMBLOCK_NODE_MAP. The only difference in memory
handling is that allocations can't no longer cross node boundaries
whether they're node affine or not, which shouldn't matter at all.
This conversion will enable further simplification of boot memory
handling.
-v2: Fix build failure on !NUMA configurations discovered by hpa.
Link: http://lkml.kernel.org/r/20110714094423.GG3455@htj.dyndns.org
From 83103b92f3234ec830852bbc5c45911bd6cbdb20 Mon Sep 17 00:00:00 2001
Add optional region->nid which can be enabled by arch using
CONFIG_HAVE_MEMBLOCK_NODE_MAP. When enabled, memblock also carries
NUMA node information and replaces early_node_map[].
Newly added memblocks have MAX_NUMNODES as nid. Arch can then call
memblock_set_node() to set node information. memblock takes care of
merging and node affine allocations w.r.t. node information.
When MEMBLOCK_NODE_MAP is enabled, early_node_map[], related data
structures and functions to manipulate and iterate it are disabled.
memblock version of __next_mem_pfn_range() is provided such that
for_each_mem_pfn_range() behaves the same and its users don't have to
be updated.
-v2: Yinghai spotted section mismatch caused by missing
__init_memblock in memblock_set_node(). Fixed.
Link: http://lkml.kernel.org/r/20110714094342.GF3455@htj.dyndns.org
From 19ab281ed67b87a6623d725237a7333ca79f1e75 Mon Sep 17 00:00:00 2001
memblock will be extended to include early_node_map[], which is also
used during memory hotplug. Make memblock use __meminit[data] instead
of __init[data] so that memory hotplug code can safely reference it.
Link: http://lkml.kernel.org/r/20110714094203.GE3455@htj.dyndns.org
Reported-by: Yinghai Lu <yinghai@kernel.org>
memblock_add_region() carefully checked for merge and overlap
conditions while adding a new region, which is complicated and makes
it difficult to allow arbitrary overlaps or add more merge conditions
(e.g. node ID).
This re-implements memblock_add_region() such that insertion is done
in two steps - all non-overlapping portions of new area are inserted
as separate regions first and then memblock_merge_regions() scan and
merge all neighbouring compatible regions.
This makes addition logic simpler and more versatile and enables
adding node information to memblock.
Link: http://lkml.kernel.org/r/1310462166-31469-3-git-send-email-tj@kernel.org
Arch could implement memblock_memor_can_coalesce() to veto merging of
adjacent or overlapping memblock regions; however, no arch did and any
vetoing would trigger WARN_ON(). Memblock regions are supposed to
deal with proper memory anyway. Remove the unused hook.
Link: http://lkml.kernel.org/r/1310462166-31469-2-git-send-email-tj@kernel.org
memblock calls
With the previous changes, generic NUMA aware memblock API has feature
parity with memblock_x86_find_in_range_node(). There currently are
two users - x86 setup_node_data() and __alloc_memory_core_early() in
nobootmem.c.
This patch converts the former to use memblock_alloc_nid() and the
latter memblock_find_range_in_node(), and kills
memblock_x86_find_in_range_node() and related functions including
find_memory_early_core_early() in page_alloc.c.
Link: http://lkml.kernel.org/r/1310460395-30913-9-git-send-email-tj@kernel.org
Node affine memblock allocation logic is currently implemented across
memblock_alloc_nid() and memblock_alloc_nid_region(). This
reorganizes it such that it resembles that of non-NUMA allocation API.
Area finding is collected and moved into new exported function
memblock_find_in_range_node() which is symmetrical to non-NUMA
counterpart - it handles @start/@end and understands ANYWHERE and
ACCESSIBLE. memblock_alloc_nid() now simply calls
memblock_find_in_range_node() and reserves the returned area.
This makes memblock_alloc[_try]_nid() observe ACCESSIBLE limit on node
affine allocations too (again, this doesn't make any difference for
the current sole user - sparc64).
Link: http://lkml.kernel.org/r/1310460395-30913-8-git-send-email-tj@kernel.org
NUMA aware memblock alloc functions - memblock_alloc_[try_]nid() -
weren't properly top-down because memblock_nid_range() scanned
forward. This patch reverses memblock_nid_range(), renames it to
memblock_nid_range_rev() and updates related functions to implement
proper top-down allocation.
Link: http://lkml.kernel.org/r/1310460395-30913-7-git-send-email-tj@kernel.org
memblock_nid_range() is used to implement memblock_[try_]alloc_nid().
The generic version determines the range by walking early_node_map
with for_each_mem_pfn_range(). The generic version is defined __weak
to allow arch override.
Currently, only sparc overrides it; however, with the previous update
to the generic implementation, there isn't much to be gained with arch
override. Sparc would behave exactly the same with the generic
implementation.
This patch disallows arch override for memblock_nid_range() and make
both generic and sparc versions static.
sparc is only compile tested.
Link: http://lkml.kernel.org/r/1310460395-30913-6-git-send-email-tj@kernel.org
Given an address range, memblock_nid_range() determines the node the
start of the range belongs to and upto where the range stays in the
same node.
It's implemented by calling get_pfn_range_for_nid(), which determines
min and max pfns for a given node, for each node and testing whether
start address falls in there. This is not only inefficient but also
incorrect when nodes interleave as min-max ranges for nodes overlap.
This patch reimplements memblock_nid_range() using
for_each_mem_pfn_range(). It's simpler, walks the mem ranges once and
can find the exact range the start address falls in.
Link: http://lkml.kernel.org/r/1310460395-30913-5-git-send-email-tj@kernel.org
The previous patch added for_each_mem_pfn_range() which is more
versatile than for_each_active_range_index_in_nid(). This patch
replaces for_each_active_range_index_in_nid() and open coded
early_node_map[] walks with for_each_mem_pfn_range().
All conversions in this patch are straight-forward and shouldn't cause
any functional difference. After the conversions,
for_each_active_range_index_in_nid() doesn't have any user left and is
removed.
Link: http://lkml.kernel.org/r/1310460395-30913-4-git-send-email-tj@kernel.org
__absent_pages_in_range() was needlessly complex. Reimplement it
using for_each_mem_pfn_range().
Also, update zone_absent_pages_in_node() such that it doesn't call
__absent_pages_in_range() with @zone_start_pfn which is larger than
@zone_end_pfn.
Link: http://lkml.kernel.org/r/1310460395-30913-3-git-send-email-tj@kernel.org
Callback based iteration is cumbersome and much less useful than
for_each_*() iterator. This patch implements for_each_mem_pfn_range()
which replaces work_with_active_regions(). All the current users of
work_with_active_regions() are converted.
This simplifies walking over early_node_map and will allow converting
internal logics in page_alloc to use iterator instead of walking
early_node_map directly, which in turn will enable moving node
powerpc change is only compile tested.
Link: http://lkml.kernel.org/r/20110714074610.GD3455@htj.dyndns.org
memblock_find_base() is a static function with two callers in
memblock.c and memblock_find_in_range() is a wrapper around it which
just changes the types and order of parameters.
Make memblock_find_in_range() take phys_addr_t instead of u64 for
consistency and replace memblock_find_base() with it.
Link: http://lkml.kernel.org/r/1310457490-3356-7-git-send-email-tj@kernel.org
25818f0f28 (memblock: Make MEMBLOCK_ERROR be 0) thankfully made
MEMBLOCK_ERROR 0 and there already are codes which expect error return
to be 0. There's no point in keeping MEMBLOCK_ERROR around. End its
misery.
Link: http://lkml.kernel.org/r/1310457490-3356-6-git-send-email-tj@kernel.org
Link: http://lkml.kernel.org/r/1310457490-3356-5-git-send-email-tj@kernel.org
memblock_alloc_try_nid()
After node affine allocation fails, memblock_alloc_try_nid() calls
memblock_alloc_base() with @max_addr set to MEMBLOCK_ALLOC_ANYWHERE.
This is inconsistent with memblock_alloc() and what the function's
sole user - sparc/mm/init_64 - expects, although it doesn't make any
difference as sparc64 doesn't have highmem and ACCESSIBLE equals
ANYWHERE.
This patch makes memblock_alloc_try_nid() use ACCESSIBLE instead of
ANYWHERE. This isn't complete as node affine allocation doesn't
consider memblock.current_limit. It will be handled with future
changes.
This patch doesn't introduce any behavior difference.
Link: http://lkml.kernel.org/r/1310457490-3356-4-git-send-email-tj@kernel.org
a226f6c899 (FRV: Clean up bootmem allocator's page freeing algorithm)
separated out __free_pages_bootmem() from free_all_bootmem_core().
__free_pages_bootmem() takes @order argument but it assumes @order is
either 0 or ilog2(BITS_PER_LONG). Note that all the current users
match that assumption and this doesn't cause actual problems.
Fix it by using 1 << order instead of BITS_PER_LONG.
Link: http://lkml.kernel.org/r/1310457490-3356-3-git-send-email-tj@kernel.org
The return value of memblock_x86_check_reserved_size() doesn't
indicate whether there's an overlapping reservatoin or not. It
indicates whether the caller needs to iterate further to discover all
reserved portions of the specified area.
efi_reserve_boot_esrvices() wants to check whether the boot services
area overlaps with other reservations but incorrectly used
membloc_x86_check_reserved_size(). Use memblock_is_region_reserved()
instead.
Link: http://lkml.kernel.org/r/1310457490-3356-2-git-send-email-tj@kernel.org
SPARSEMEM w/o VMEMMAP and DISCONTIGMEM, both used only on 32bit, use
sections array to map pfn to nid which is limited in granularity. If
NUMA nodes are laid out such that the mapping cannot be accurate, boot
will fail triggering BUG_ON() in mminit_verify_page_links().
On 32bit, it's 512MiB w/ PAE and SPARSEMEM. This seems to have been
granular enough until commit 2706a0bf7b (x86, NUMA: Enable
CONFIG_AMD_NUMA on 32bit too). Apparently, there is a machine which
aligns NUMA nodes to 128MiB and has only AMD NUMA but not SRAT. This
led to the following BUG_ON().
On node 0 totalpages: 2096615
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3927 pages, LIFO batch:0
Normal zone: 1740 pages used for memmap
Normal zone: 220978 pages, LIFO batch:31
HighMem zone: 16405 pages used for memmap
HighMem zone: 1853533 pages, LIFO batch:31
BUG: Int 6: CR2 (null)
EDI (null) ESI 00000002 EBP 00000002 ESP c1543ecc
EBX f2400000 EDX 00000006 ECX (null) EAX 00000001
err (null) EIP c16209aa CS 00000060 flg 00010002
Stack: f2400000 00220000 f7200800 c1620613 00220000 01000000 04400000 00238000
(null) f7200000 00000002 f7200b58 f7200800 c1620929 000375fe (null)
f7200b80 c16395f0 00200a02 f7200a80 (null) 000375fe 00000002 (null)
Pid: 0, comm: swapper Not tainted 2.6.39-rc5-00181-g2706a0b #17
Call Trace:
[<c136b1e5>] ? early_fault+0x2e/0x2e
[<c16209aa>] ? mminit_verify_page_links+0x12/0x42
[<c1620613>] ? memmap_init_zone+0xaf/0x10c
[<c1620929>] ? free_area_init_node+0x2b9/0x2e3
[<c1607e99>] ? free_area_init_nodes+0x3f2/0x451
[<c1601d80>] ? paging_init+0x112/0x118
[<c15f578d>] ? setup_arch+0x791/0x82f
[<c15f43d9>] ? start_kernel+0x6a/0x257
This patch implements node_map_pfn_alignment() which determines
maximum internode alignment and update numa_register_memblks() to
reject NUMA configuration if alignment exceeds the pfn -> nid mapping
granularity of the memory model as determined by PAGES_PER_SECTION.
This makes the problematic machine boot w/ flatmem by rejecting the
NUMA config and provides protection against crazy NUMA configurations.
Link: http://lkml.kernel.org/r/20110712074534.GB2872@htj.dyndns.org
LKML-Reference: <20110628174613.GP478@escobedo.osrc.amd.com>
Reported-and-Tested-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: Conny Seidel <conny.seidel@amd.com>
DISCONTIGMEM on x86-32 implements pfn -> nid mapping similarly to
SPARSEMEM; however, it calls each mapping unit ELEMENT instead of
SECTION. This patch renames it to SECTION so that PAGES_PER_SECTION
is valid for both DISCONTIGMEM and SPARSEMEM. This will be used by
the next patch to implement mapping granularity check.
This patch is trivial constant rename.
Link: http://lkml.kernel.org/r/20110712074422.GA2872@htj.dyndns.org
Cc: Hans Rosenfeld <hans.rosenfeld@amd.com>
That file harkens back to the days of the big 2.4 -> 2.6 version jump,
and was based even then on older versions. Some of it is just obsolete,
and Jesper Juhl points out that it talks about kernel versions 2.6 and
should be updated to 3.0.
Remove some obsolete text, and re-phrase some other to not be 2.6-specific.
Reported-by: Jesper Juhl <jj@chaosbits.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
[media] msp3400: fill in v4l2_tuner based on vt->type field
[media] tuner-core.c: don't change type field in g_tuner or g_frequency
[media] cx18/ivtv: fix g_tuner support
[media] tuner-core: power up tuner when called with s_power(1)
[media] v4l2-ioctl.c: check for valid tuner type in S_HW_FREQ_SEEK
[media] tuner-core: simplify the standard fixup
[media] tuner-core/v4l2-subdev: document that the type field has to be filled in
[media] v4l2-subdev.h: remove unused s_mode tuner op
[media] feature-removal-schedule: change in how radio device nodes are handled
[media] bttv: fix s_tuner for radio
[media] pvrusb2: fix g/s_tuner support
[media] v4l2-ioctl.c: prefill tuner type for g_frequency and g/s_tuner
[media] tuner-core: fix tuner_resume: use t->mode instead of t->type
[media] tuner-core: fix s_std and s_tuner
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Reintroduce dropped call to check_wakeup_irqs
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: drop spinlock before calling cifs_put_tlink
cifs: fix expand_dfs_referral
cifs: move bdi_setup_and_register outside of CONFIG_CIFS_DFS_UPCALL
cifs: factor smb_vol allocation out of cifs_setup_volume_info
cifs: have cifs_cleanup_volume_info not take a double pointer
cifs: fix build_unc_path_to_root to account for a prefixpath
cifs: remove bogus call to cifs_cleanup_volume_info
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] fix cpumask memory leak in acpi-cpufreq on cpu hotplug.
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86:
hp-wmi: fix use after free
dell-laptop - using buffer without mutex_lock
Revert: "dell-laptop: Toggle the unsupported hardware killswitch"
platform-drivers-x86: set backlight type to BACKLIGHT_PLATFORM
thinkpad-acpi: handle HKEY 0x4010, 0x4011 events
drivers/platform/x86: Fix memory leak
thinkpad-acpi: handle some new HKEY 0x60xx events
acer-wmi: fix bitwise bug when set device state
acer-wmi: Only update rfkill status for associated hotkey events
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'movieboard' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: ohci: do not bind to Pinnacle cards, avert panic
Acked-by: Pavel Roskin <proski@gnu.org>
Since we removed sti()/cli() and related, how about removing it from
Documentation/spinlocks.txt?
Signed-off-by: Muthukumar R <muthur@gmail.com>
...as that function can sleep.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
[ 191.310008] WARNING: kmemcheck: Caught 32-bit read from freed memory (f0d25f14)
[ 191.310011] c056d2f088000000105fd2f00000000050415353040000000000000000000000
[ 191.310020] i i i i f f f f f f f f f f f f f f f f f f f f f f f f f f f f
[ 191.310027] ^
[ 191.310029]
[ 191.310032] Pid: 737, comm: modprobe Not tainted 3.0.0-rc5+ #268 Hewlett-Packard HP Compaq 6005 Pro SFF PC/3047h
[ 191.310036] EIP: 0060:[<f80b3104>] EFLAGS: 00010286 CPU: 0
[ 191.310039] EIP is at hp_wmi_perform_query+0x104/0x150 [hp_wmi]
[ 191.310041] EAX: f0d25601 EBX: f0d25f00 ECX: 000121cf EDX: 000121ce
[ 191.310043] ESI: f0d25f10 EDI: f0f97ea8 EBP: f0f97ec4 ESP: c173f34c
[ 191.310045] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 191.310046] CR0: 8005003b CR2: f540c000 CR3: 30f30000 CR4: 000006d0
[ 191.310048] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 191.310050] DR6: ffff4ff0 DR7: 00000400
[ 191.310051] [<f80b317b>] hp_wmi_dock_state+0x2b/0x40 [hp_wmi]
[ 191.310054] [<f80b6093>] hp_wmi_init+0x93/0x1a8 [hp_wmi]
[ 191.310057] [<c10011f0>] do_one_initcall+0x30/0x170
[ 191.310061] [<c107ab9f>] sys_init_module+0xef/0x1a60
[ 191.310064] [<c149f998>] sysenter_do_call+0x12/0x28
[ 191.310067] [<ffffffff>] 0xffffffff
Using buffer->output[1] without mutex_lock()
Signed-off-by: Jose Alonso <joalonsof@gmail.com>
This reverts commit a3d77411e8b2ad661958c1fbee65beb476ec6d70,
as it causes a mess in the wireless rfkill status on some models.
It is probably a bad idea to toggle the rfkill for all dell models
without the respect to the claim that it is hardware-controlled.
Cc: stable@kernel.org
Signed-off-by: Keng-Yu Lin <kengyu@canonical.com>
Patch 2e711c04dbbf7a7732a3f7073b1fc285d12b369d
(PM: Remove sysdev suspend, resume and shutdown operations)
deleted sysdev_suspend(), which was being relied on to call
check_wakeup_irqs() in suspend. If check_wakeup_irqs() is not
called, wake interrupts that are pending when suspend is
entered may be lost. It also breaks IRQCHIP_MASK_ON_SUSPEND,
which is handled in check_wakeup_irqs().
This patch adds a call to check_wakeup_irqs() in syscore_suspend(),
similar to what was deleted in sysdev_suspend().
Signed-off-by: Colin Cross <ccross@android.com>
I came across a memory leak during a cyclic cpu-online-offline test.
Signed-off-by: Yu Luming <luming.yu@intel.com>
Cc: Len Brown <lenb@kernel.org>
Signed-off-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: (pmbus) Improve auto-detection of temperature status register
hwmon: (lm95241) Fix negative temperature results
hwmon: (lm95241) Fix chip detection code
It is possible that a PMBus device supports the READ_TEMPERATURE2 and/or
READ_TEMPERATURE3 registers but does not support READ_TEMPERATURE1.
Improve temperature status register detection to address this condition.
Reported-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: stable@kernel.org # 2.6.39+
Negative temperatures were returned in degrees C instead of milli-Degrees C.
Also, negative temperatures were reported for remote temperature sensors even
if the chip was configured for positive-only results.
Fix by detecting temperature modes, and by treating negative temperatures
similar to positive temperatures, with appropriate sign extension.
Cc: stable@kernel.org # 2.6.30+
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix a copmile warning
ASoC: ak4642: fixup snd_soc_update_bits mask for PW_MGMT2
ALSA: hda - Change all ADCs for dual-adc switching mode for Realtek
ASoC: Manage WM8731 ACTIVE bit as a supply widget
ASoC: Don't set invalid name string to snd_card->driver field
ASoC: Ensure we delay long enough for WM8994 FLL to lock when starting
ASoC: Tegra: I2S: Ensure clock is enabled when writing regs
ASoC: Fix Blackfin I2S _pointer() implementation return in bounds values
ASoC: tlv320aic3x: Do soft reset to codec when going to bias off state
ASoC: tlv320aic3x: Don't sync first two registers from register cache
audio: tlv320aic26: fix PLL register configuration
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: conditional resource-reallocation through kernel parameter pci=realloc
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6994/1: smp_twd: Fix typo in 'twd_timer_rate' printing
ARM: 6987/1: l2x0: fix disabling function to avoid deadlock
ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1
ARM: 6980/1: mmci: use StartBitErr to detect bad connections
ARM: 6979/1: mach-vt8500: add forgotten irq_data conversion
ARM: move memory layout sanity checking before meminfo initialization
ARM: 6990/1: MAINTAINERS: add entry for ARM PMU profiling and debugging
ARM: 6989/1: perf: do not start the PMU when no events are present
ARM: dmabounce: fix map_single() error return value
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms: clean up multiple crtc handling for evergreen+ (v2)
When firewire-ohci is bound to a Pinnacle MovieBoard, eventually a
"Register access failure" is logged and an interrupt storm or a kernel
panic happens. https://bugzilla.kernel.org/show_bug.cgi?id=36622
Until this is sorted out (if that is going to succeed at all), let's
just prevent firewire-ohci from touching these devices.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: <stable@kernel.org>
Regression introduced in commit 724d9f1cfba.
Prior to that, expand_dfs_referral would regenerate the mount data string
and then call cifs_parse_mount_options to re-parse it (klunky, but it
worked). The above commit moved cifs_parse_mount_options out of cifs_mount,
so the re-parsing of the new mount options no longer occurred. Fix it by
making expand_dfs_referral re-parse the mount options.
This needs to be done regardless of whether that KConfig option is set
or not.
Reported-by: Sven-Haegar Koch <haegar@sdinet.de>
