Needed to propagate it down to the ip_route_output_flow.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Needed to propagate it down to the __ip_route_output_key.
Signed_off_by: Denis V. Lunev <den@openvz.org>
This is only required to propagate it down to the
ip_route_output_slow.
This function needs a net namespace to lookup devices, fib tables,
etc. in, so pass it there.
in_dev_find() need a namespace to pass it to fib_get_table(), so add
an argument.
Currently fib_select_default calls fib_get_table() with the
init_net. Prepare it to provide a correct namespace to lookup default
route.
The difference in the implementation of the fib_select_default when
CONFIG_IP_MULTIPLE_TABLES is (not) defined looks
negligible. Consolidate it and place into fib_frontend.c.
Two small issues fixed:
- fib_select_multipath is exported from fib_semantics.c rather than from
fib_frontend.c. So, move the declaration below appropriate comment.
- struct rt_entry declaration is not used. Drop it.
This converts dumping (and flushing) of large route tables form O(N^2)
to O(N). If the route dump took multiple pages then the dump routine
gets called again. The old code kept track of location by counter, the
new code instead uses the last key.
This is a really big win ( 0.3 sec vs 12 sec) for big route tables.
One side effect is that if the table changes during the dump, then the
last key will not be found, and we will return -EBUSY.
Get rid of extra search that made route deletion O(n).
It is easier with TRIE to dump the data traversal rather than
interating over every possible prefix. This saves some time and makes
the dump come out in sorted order.
Remove the complex loop structure of nextleaf() and replace it with a
simpler tree walker. This improves the performance and is much
cleaner.
Match fib_hash, and set NLM_F_MULTI to handle multiple part messages.
The code to dump can use the existing hash chain rather than doing
repeated lookup.
Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com>
Compute the number of prefixes when needed, rather than doing bookeeping.
Style cleanups:
* make check_leaf return -1 or plen, rather than by reference
* Get rid of #ifdef that is always set
* split out embedded function calls in if statements.
* checkpatch warnings
This improves locality for operations that touch all the leaves. Save
space since these entries don't need to be hardware cache aligned.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
By default, LMP sets up a 3 seconds timer for discovery.
We don't need it until discovery is set to 1.
Signed-off-by: Ross Burton <ross@openedhand.com>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
always extend the rx timestamp with the local TSF, since this information is
also needed for proper IBSS merging. this is done in the tasklet for now, maybe
has to be moved to the interrupt handler like in madwifi.
drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD
Signed-off-by: Bruno Randolf <bruno@thinktube.com>
in "11.1.2.2 Beacon generation in an IBSS" the IEEE802.11 standard says, each
STA should... "b) Calculate a random delay uniformly distributed in the range
between zero and twice aCWmin × aSlotTime,".
configure cwmin and cwmax of the beacon queue in IBSS mode according to this.
unfortunately beacon backoff does not work reliably yet, so i suspect we have a
problem somewhere else, since the same settings (and similar beacon timer
configuration) work for madwifi.
use SWBA (software beacon alert) interrupts to keep track of the next beacon
time und check if a HW merge (automatic TSF update) has happened on every
received beacon with the same BSSID.
this is necessary because the atheros hardware will silently update the local
TSF in IBSS mode, but not its beacon timers. if the TSF is ahead of the beacon
timers no beacons are sent until the timers wrap around (typically after about
1 minute).
this solution is not very nice, since we have to look into every beacon, but
there is apparently no other way to detect HW merges.
drivers/net/wireless/ath5k/base.h: Changes-licensed-under: 3-Clause-BSD
update ath5k_beacon_update_timers() for better beacon timer calculation in a
variety of situations. most important is the possibility to call it with the
timestamp of a received beacon, when we detected that a HW merge has happened
and we need to reconfigure the beacon timers based on that.
we call this from the mac80211 callback reset_tsf now instead of beacon_update,
and there will be more use of it in the next patch.
the beacon interval is passed by mac80211 in TU already, so we can directly use
it without conversion. also update the comments about TU (1 TU is defined by
802.11 as 1024usec).
drivers/net/wireless/ath5k/ath5k.h: Changes-licensed-under: ISC
reviewed beacon timer initialization with register traces from madwifi: what we
are doing is correct :). one minor fix: use 3 instead of 0x00000003 - it's more
readable.
drivers/net/wireless/ath5k/hw.c: Changes-licensed-under: ISC
This zeros out all microcode related memory before loading
the microcode.
This also fixes initialization of the MAC control register.
The _only_ place where we overwrite the contents of the MAC control
register is at the beginning of b43_chip_init().
All other places must do read() -> mask/set -> write() to not
overwrite existing bits.
This also adds a longer delay for waiting for the microcode
to initialize itself. It seems that the current timeout is sufficient
on all available devices, but there's no real reason why we shouldn't
wait for up to one second. Slow embedded devices might exist.
Better safe than sorry.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
As event_type_pk_size[] is not used, Remove it.
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp>
Otherwise it may be impossible to connected to an open network after a
resume.
This is a modified version of an original patch by
Alex Eskin <alexeskin@yahoo.com>:
https://bugzilla.redhat.com/show_bug.cgi?id=425950#c8
...instead of using AR5K_KEYCACHE_SIZE, which would seem to be a
typo/thinko...
We must also store the ID string (filename) for the cached firmware blobs
and verify that we really have the right firmware cached before using it.
If we don't have the right fw cached, we must free it and request the
correct blobs.
This fixes bandswitch on A/B/G multi-PHY devices.
This patch adds static declarations to functions in the Rx flow in order to
eliminate sparse errors
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
This patch changes ieee80211_bar control and start_seq_num to
match the proper bitwise attribute expected from ieee 802.11 frame
This also adds lots of TODOs. Oh well. Lots of work. :)
Fix last_sample initialization. kzalloc'ing the per-STA data wasn't enough,
as jiffies can assume negative values as well. This fixes a bug which
prevented correct PID operation for a while after booting.
Thanks to Michael Buesch for reporting this.
Reported-and-tested-by: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it>
Commit c7a51bda ("mac80211: restructure __ieee80211_rx") extracted
__ieee80211_rx_handle_packet out of __ieee80211_rx and hence changed
the locking rules for __ieee80211_rx_handle_packet(), it is now
invoked under RCU lock. There is, however, one instance left where
it contains an rcu_read_unlock() in an error path, which is a bug.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This fixes a sparse warning about weird locking.
The spinlock is not needed, so simply remove it.
This also adds some sanity checks to the PHY and radio locking
to protect against recursive locking.
This patch assigns correct TID to frames transmitted between
two stations in the same BSS in AP mode.
The problem is that skb->protocol is not set to ETH_P_IP and it is wrong
to use that field at this stage.
The fix compares the LLC/Protocol headers explicitly to check if the
encapsulated frame is IP frame
Signed-off-by: Guy Cohen <guy.cohen@intel.com>
On x86_64, sizeof(struct rtable) is 0x148, which is rounded up to
0x180 bytes by SLAB allocator.
We can reduce this to exactly 0x140 bytes, without alignment overhead,
and store 12 struct rtable per PAGE instead of 10.
rate_tokens is currently defined as an "unsigned long", while its
content should not exceed 6*HZ. It can safely be converted to an
unsigned int.
Moving tclassid right after rate_tokens to fill the 4 bytes hole
permits to save 8 bytes on 'struct dst_entry', which finally permits
to save 8 bytes on 'struct rtable'
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
On namespace start we mainly prepare the ctl variables.
When the namespace is stopped we have to kill all the fragments that
point to this namespace. The inet_frags_exit_net() handles it.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The inet_frags.lru_list is used for evicting only, so we have
to make it per-namespace, to evict only those fragments, who's
namespace exceeded its high threshold, but not the whole hash.
Besides, this helps to avoid long loops in evictor.
The spinlock is not per-namespace because it protects the
hash table as well, which is global.
Since we have one hashtable to lookup the fragment, having
different secret_interval-s for hash rebuild doesn't make
sense, so move this one to inet_frags.
The inet_frags_ctl becomes empty after this, so remove it.
The appropriate ctl table is kept read-only in namespaces.
This is the same as with the timeout variable.
Currently, after exceeding the high threshold _all_
the fragments are evicted, but it will be fixed in
later patch.
Move it to the netns_frags, adjust the usage and
make the appropriate ctl table writable.
Now fragment, that live in different namespaces can
live for different times.
Each namespace has to have own tables to tune their
different parameters, so duplicate the tables and
register them.
All the tables in sub-namespaces are temporarily made
read-only.
This is also simple, but introduces more changes, since
then mem counter is altered in more places.
This is simple - just move the variable from struct inet_frags
to struct netns_frags and adjust the usage appropriately.
Since fragment management code is consolidated, we cannot have the
pointer from inet_frag_queue to struct net, since we must know what
king of fragment this is.
So, I introduce the netns_frags structure. This one is currently
empty, but will be eventually filled with per-namespace
attributes. Each inet_frag_queue is tagged with this one.
The conntrack_reasm is not "netns-izated", so it has one static
netns_frags instance to keep working in init namespace.
This is a preparation for sysctl netns-ization.
Move the ctl tables to the files, where the tuning
variables reside. Plus make the helpers to register
the tables.
This will simplify the later patches and will keep
similar things closer to each other.
ipv4, ipv6 and conntrack_reasm are patched differently,
but the result is all the tables are in appropriate files.
We are pleased to announce a new Gigabit Ethernet product and its
driver to the linux community. This product is the Intel(R) 82575
Gigabit Ethernet adapter family. Physical adapters will be available
to the public soon. These adapters come in 2- and 4-port versions
(copper PHY) currently. Other variants will be available later.
The 82575 chipset supports significantly different features that
warrant a new driver. The descriptor format is (just like the
ixgbe driver) different. The device can use multiple MSI-X vectors
and multiple queues for both send and receive. This allows us to
optimize some of the driver code specifically as well compared to
the e1000-supported devices.
This version of the igb driver no lnger uses fake netdevices and
incorporates napi_struct members for each ring to do the multi-
queue polling. multi-queue is enabled by default and the driver
supports NAPI mode only.
All the namespace collisions should be gone in this version too. The
register macro's have been condensed to improve readability.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
