2009-12-07wl1251: fix bssid handlingKalle Valo
bssid needs to be copied first in wl1251_op_bss_info_changed(), otherwise templates will have incorrect bssid and power save will not work correctly. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07wl1251: remove false warning messagesKalle Valo
There was a warning from wl1251_op_bss_info_changed(): wl1251: WARNING Set ctsprotect failed 0 It was printed always, it's completely false and can be removed. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07iwlwifi: fix warning from ieee80211_stop_tx_ba_cb_irqsafe argument changeJohn W. Linville
CC [M] drivers/net/wireless/iwlwifi/iwl-tx.o drivers/net/wireless/iwlwifi/iwl-tx.c: In function ‘iwl_tx_agg_stop’: drivers/net/wireless/iwlwifi/iwl-tx.c:1356: warning: passing argument 1 of ‘ieee80211_stop_tx_ba_cb_irqsafe’ from incompatible pointer type include/net/mac80211.h:2128: note: expected ‘struct ieee80211_vif *’ but argument is of type ‘struct ieee80211_hw *’ Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-12-05Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (40 commits) tracing: Separate raw syscall from syscall tracer ring-buffer-benchmark: Add parameters to set produce/consumer priorities tracing, function tracer: Clean up strstrip() usage ring-buffer benchmark: Run producer/consumer threads at nice +19 tracing: Remove the stale include/trace/power.h tracing: Only print objcopy version warning once from recordmcount tracing: Prevent build warning: 'ftrace_graph_buf' defined but not used ring-buffer: Move access to commit_page up into function used tracing: do not disable interrupts for trace_clock_local ring-buffer: Add multiple iterations between benchmark timestamps kprobes: Sanitize struct kretprobe_instance allocations tracing: Fix to use __always_unused attribute compiler: Introduce __always_unused tracing: Exit with error if a weak function is used in recordmcount.pl tracing: Move conditional into update_funcs() in recordmcount.pl tracing: Add regex for weak functions in recordmcount.pl tracing: Move mcount section search to front of loop in recordmcount.pl tracing: Fix objcopy revision check in recordmcount.pl tracing: Check absolute path of input file in recordmcount.pl tracing: Correct the check for number of arguments in recordmcount.pl ...
2009-12-05Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix trace_marker output tracing: Fix event format export tracing: Fix return value of tracing_stats_read()
2009-12-05Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix spurious irq seqfile conversion genirq: switch /proc/irq/*/spurious to seq_file irq: Do not attempt to create subdirectories if /proc/irq/<irq> failed irq: Remove unused debug_poll_all_shared_irqs() irq: Fix docbook comments irq: trivial: Fix typo in comment for #endif
2009-12-05Merge branch 'core-softlockup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-softlockup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: Fix hung_task_check_count sysctl
2009-12-05Merge branch 'core-signal-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-signal-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: signal: Print warning message when dropping signals signal: Fix alternate signal stack check
2009-12-05Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) rcu: Make RCU's CPU-stall detector be default rcu: Add expedited grace-period support for preemptible RCU rcu: Enable fourth level of TREE_RCU hierarchy rcu: Rename "quiet" functions rcu: Re-arrange code to reduce #ifdef pain rcu: Eliminate unneeded function wrapping rcu: Fix grace-period-stall bug on large systems with CPU hotplug rcu: Eliminate __rcu_pending() false positives rcu: Further cleanups of use of lastcomp rcu: Simplify association of forced quiescent states with grace periods rcu: Accelerate callback processing on CPUs not detecting GP end rcu: Mark init-time-only rcu_bootup_announce() as __init rcu: Simplify association of quiescent states with grace periods rcu: Rename dynticks_completed to completed_fqs rcu: Enable synchronize_sched_expedited() fastpath rcu: Remove inline from forward-referenced functions rcu: Fix note_new_gpnum() uses of ->gpnum rcu: Fix synchronization for rcu_process_gp_end() uses of ->completed counter rcu: Prepare for synchronization fixes: clean up for non-NO_HZ handling of ->completed counter rcu: Cleanup: balance rcu_irq_enter()/rcu_irq_exit() calls ...
2009-12-05Merge branch 'core-printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ratelimit: Make suppressed output messages more useful printk: Remove ratelimit.h from kernel.h ratelimit: Fix/allow use in atomic contexts ratelimit: Use per ratelimit context locking
2009-12-05Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mutex: Fix missing conditions to build mutex_spin_on_owner() mutex: Better control mutex adaptive spinning config locking, task_struct: Reduce size on TRACE_IRQFLAGS and 64bit locking: Use __[SPIN|RW]_LOCK_UNLOCKED in [spin|rw]_lock_init() locking: Remove unused prototype locking: Reduce ifdefs in kernel/spinlock.c locking: Make inlining decision Kconfig based
2009-12-05Merge branch 'core-ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: Add smp_call_function_any() generic-ipi: Fix misleading smp_call_function*() description
2009-12-05Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) x86, Calgary IOMMU quirk: Find nearest matching Calgary while walking up the PCI tree x86/amd-iommu: Remove amd_iommu_pd_table x86/amd-iommu: Move reset_iommu_command_buffer out of locked code x86/amd-iommu: Cleanup DTE flushing code x86/amd-iommu: Introduce iommu_flush_device() function x86/amd-iommu: Cleanup attach/detach_device code x86/amd-iommu: Keep devices per domain in a list x86/amd-iommu: Add device bind reference counting x86/amd-iommu: Use dev->arch->iommu to store iommu related information x86/amd-iommu: Remove support for domain sharing x86/amd-iommu: Rearrange dma_ops related functions x86/amd-iommu: Move some pte allocation functions in the right section x86/amd-iommu: Remove iommu parameter from dma_ops_domain_alloc x86/amd-iommu: Use get_device_id and check_device where appropriate x86/amd-iommu: Move find_protection_domain to helper functions x86/amd-iommu: Simplify get_device_resources() x86/amd-iommu: Let domain_for_device handle aliases x86/amd-iommu: Remove iommu specific handling from dma_ops path x86/amd-iommu: Remove iommu parameter from __(un)map_single x86/amd-iommu: Make alloc_new_range aware of multiple IOMMUs ...
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: (31 commits) GFS2: Fix glock refcount issues writeback: remove unused nonblocking and congestion checks (gfs2) GFS2: drop rindex glock to refresh rindex list GFS2: Tag all metadata with jid GFS2: Locking order fix in gfs2_check_blk_state GFS2: Remove dirent_first() function GFS2: Display nobarrier option in /proc/mounts GFS2: add barrier/nobarrier mount options GFS2: remove division from new statfs code GFS2: Improve statfs and quota usability GFS2: Use dquot_send_warning() VFS: Export dquot_send_warning GFS2: Add set_xquota support GFS2: Add get_xquota support GFS2: Clean up gfs2_adjust_quota() and do_glock() GFS2: Remove constant argument from qd_get() GFS2: Remove constant argument from qdsb_get() GFS2: Add proper error reporting to quota sync via sysfs GFS2: Add get_xstate quota function GFS2: Remove obsolete code in quota.c ...
2009-12-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (30 commits) TOMOYO: Add recursive directory matching operator support. remove CONFIG_SECURITY_FILE_CAPABILITIES compile option SELinux: print denials for buggy kernel with unknown perms Silence the existing API for capability version compatibility check. LSM: Move security_path_chmod()/security_path_chown() to after mutex_lock(). SELinux: header generation may hit infinite loop selinux: Fix warnings security: report the module name to security_module_request Config option to set a default LSM sysctl: require CAP_SYS_RAWIO to set mmap_min_addr tpm: autoload tpm_tis based on system PnP IDs tpm_tis: TPM_STS_DATA_EXPECT workaround define convenient securebits masks for prctl users (v2) tpm: fix header for modular build tomoyo: improve hash bucket dispersion tpm add default function definitions LSM: imbed ima calls in the security hooks SELinux: add .gitignore files for dynamic classes security: remove root_plug SELinux: fix locking issue introduced with c6d3aaa4e35c71a3 ...
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
2009-12-05avr32: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05s390: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: linux390@de.ibm.com CC: linux-s390@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05MIPS: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of while(1); Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> CC: linux-mips@linux-mips.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05x86: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;);. When allyesconfig is built with a GCC-4.5 snapshot on i686 the size of the text segment is reduced by 3987 bytes (from 6827019 to 6823032). Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> CC: Thomas Gleixner <tglx@linutronix.de> CC: Ingo Molnar <mingo@redhat.com> CC: x86@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-05Add support for GCC-4.5's __builtin_unreachable() to compiler.h (v2)David Daney
Starting with version 4.5, GCC has a new built-in function __builtin_unreachable() that can be used in places like the kernel's BUG() where inline assembly is used to transfer control flow. This eliminated the need for an endless loop in these places. The patch adds a new macro 'unreachable()' that will expand to either __builtin_unreachable() or an endless loop depending on the compiler version. Change from v1: Simplify unreachable() for non-GCC 4.5 case. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04mac80211: fix reorder buffer releaseJohannes Berg
My patch "mac80211: correctly place aMPDU RX reorder code" uses an skb queue for MPDUs that were released from the buffer. I intentially didn't initialise and use the skb queue's spinlock, but in this place forgot that the code variant that doesn't touch the spinlock is needed. Thanks to Christian Lamparter for quickly spotting the bug in the backtrace Reinette reported. Reported-by: Reinette Chatre <reinette.chatre@intel.com> Bug-identified-by: Christian Lamparter <chunkeey@googlemail.com> Tested-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-12-04iwmc3200wifi: Enable wimax core through module parameterSamuel Ortiz
When debugging the wifi firmware, we need to disable the wimax core to gain some memory space. The default value will keep the wimax core enabled. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameterSamuel Ortiz
Wifi and wimax coexistence mode is set by wifi at boot time. There can be several modes, defined by priority tables. User space components can decide which one to select by writing to /sys/module/iwmc3200wifi/parameters/wiwi with this patch, before bringing the interface up. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwmc3200wifi: Coex table command does not expect a responseSamuel Ortiz
When sending the wiwi coexistence priority table, we should not tell the LMAC that we want a response. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwmc3200wifi: Update wiwi priority tableSamuel Ortiz
This update follows the firmware engineers recommendations. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwlwifi: driver version track kernel versionReinette Chatre
The driver version number is a remnant from when there was an out-of-tree iwlwifi driver. Now that the driver forms part of kernel source we do not need a separate driver version. Instead, we now use the kernel version as driver version. We maintain the previous tags used to indicate which components the driver has been compiled with. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwlwifi: indicate uCode type when fail dump error/event logWey-Yi Guy
error_event_table_ptr is only set upon receipt of REPLY_ALIVE. Until then both event log and error log will fail. Add information to indicate which uCode encounter the failure case. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwl3945: remove duplicated event logging codeWey-Yi Guy
In the process of improving uCode event logging capability, the new implementation was introduced without removing the existing implementation. The event log will be dumped to dmesg twice. Remove the old implementation to only log the event once upon sys assert or request by user. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04b43: fix two warningsJohannes Berg
My gcc appears to be able to see past the function boundary and notices that the variable 'behaviour' could be used uninitialised: drivers/net/wireless/b43/leds.c: In function ‘b43_leds_register’: drivers/net/wireless/b43/leds.c:339: warning: ‘behaviour’ may be used uninitialized in this function drivers/net/wireless/b43/leds.c: In function ‘b43_leds_init’: drivers/net/wireless/b43/leds.c:262: warning: ‘behaviour’ may be used uninitialized in this function because b43_led_get_sprominfo() didn't initialise it in all cases. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04ipw2100: fix rebooting hang with driver loadedZhu Yi
Add PCI .shutdown method so that we can disable the device during shutdown or reboot. Without this, the reboot doesn't work well on some platforms. This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2124 Tested-by: pablo <pablolm2005@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04cfg80211: indent regulatory messages with spacesKalle Valo
The regulatory messages in syslog look weird: kernel: cfg80211: Regulatory domain: US kernel: ^I(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) kernel: ^I(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm) kernel: ^I(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm) kernel: ^I(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm) Indent them with four spaces instead of the tab character to get prettier output. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04iwmc3200wifi: fix NULL pointer dereference in pmkid updateZhu Yi
When handling IWM_CMD_PMKID_FLUSH command, the bssid and pmkid in pmksa are all NULL. Check it before memcpy. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04mac80211: Fix TX status reporting for injected data framesJouni Malinen
An earlier optimization on removing unnecessary traffic on cooked monitor interfaces ("mac80211: reduce the amount of unnecessary traffic on cooked monitor interfaces ") ended up removing quite a bit more than just unnecessary traffic. It was not supposed to remove TX status reporting for injected frames, but ended up doing it by checking the injected flag in skb->cb only after that field had been cleared with memset.. Fix this by taking a local copy of the injected flag before skb->cb is cleared. This broke user space applications that depend on getting TX status notifications for injected data frames. For example, STA inactivity poll from hostapd did not work and ended up kicking out stations even if they were still present. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04ath9k: enable 2GHz band only if the device supports itGabor Juhos
Currently, the 2GHz band is enabled unconditionally, even if the device does not support it. Changes-licensed-under: ISC Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04airo: Fix integer overflow warningMichael Buesch
On BigEndian gcc complains: drivers/net/wireless/airo.c: In function ‘sniffing_mode’: drivers/net/wireless/airo.c:4809: warning: integer overflow in expression Fix this by doing the bitwise AND on the host-endian value. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04rt2x00: Fix padding bug on L2PAD devices.Gertjan van Wingerde
While reviewing the l2pad function to align both the header and the payload on a DMA-capable boundary a bug was discovered where the payload would not be properly aligned. The header_align value was used where the payload_align value should have been used. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04WE: Fix set events not propagatedJean Tourrilhes
I've just noticed that some events are no longer propagated for some wireless drivers. Basically, SET request with a extra payload for driver without commit handler. The fix is pretty simple, see attached. Actually, a few lines below this line, you will see that the event generation for simple SET (iwpoint-less ?) is done properly, and this other event generation does not need fixing. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04b43legacy: avoid PPC fault during resumeLarry Finger
For PPC architecture with PHY Revision < 3, a read of the register B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status() returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that the driver is unable to associate after resuming from hibernation unless this routine returns 1. To satisfy both conditions, the routine is rewritten to return TRUE whenever b43legacy_status() returns a value < 2. This patch fixes the second problem listed in the postings for Red Hat Bugzilla #538523. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04b43: avoid PPC fault during resumeLarry Finger
The routine b43_is_hw_radio_enabled() has long been a problem. For PPC architecture with PHY Revision < 3, a read of the register B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43_status() returns a value of 2 (B43_STAT_STARTED) (BUG 14181). Fixing that results in Bug 14538 in which the driver is unable to reassociate after resuming from hibernation because b43_status() returns 0. The correct fix would be to determine why the status is 0; however, I have not yet found why that happens. The correct value is found for my device, which has PHY revision >= 3. Returning TRUE when the PHY revision < 3 and b43_status() returns 0 fixes the regression for 2.6.32. This patch fixes the problem in Red Hat Bugzilla #538523. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Christian Casteyde <casteyde.christian@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-03tcp: fix a timewait refcnt raceEric Dumazet
After TCP RCU conversion, tw->tw_refcnt should not be set to 1 in inet_twsk_alloc(). It allows a RCU reader to get this timewait socket, while we not yet stabilized it. Only choice we have is to set tw_refcnt to 0 in inet_twsk_alloc(), then atomic_add() it later, once everything is done. Location of this atomic_add() is tricky, because we dont want another writer to find this timewait in ehash, while tw_refcnt is still zero ! Thanks to Kapil Dakhane tests and reports. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tcp: connect() race with timewait reuseEric Dumazet
Its currently possible that several threads issuing a connect() find the same timewait socket and try to reuse it, leading to list corruptions. Condition for bug is that these threads bound their socket on same address/port of to-be-find timewait socket, and connected to same target. (SO_REUSEADDR needed) To fix this problem, we could unhash timewait socket while holding ehash lock, to make sure lookups/changes will be serialized. Only first thread finds the timewait socket, other ones find the established socket and return an EADDRNOTAVAIL error. This second version takes into account Evgeniy's review and makes sure inet_twsk_put() is called outside of locked sections. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03be2net: Add support for ethtool self testSuresh R
This patch adds support for ethtool selftest. From: Suresh R <sureshr@serverengines.com> Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03tcp: diag: Dont report negative values for rx queueEric Dumazet
Both netlink and /proc/net/tcp interfaces can report transient negative values for rx queue. ss -> State Recv-Q Send-Q Local Address:Port Peer Address:Port ESTAB -6 6 127.0.0.1:45956 127.0.0.1:3333 netstat -> tcp 4294967290 6 127.0.0.1:37784 127.0.0.1:3333 ESTABLISHED This is because we dont lock socket while computing tp->rcv_nxt - tp->copied_seq, and another CPU can update copied_seq before rcv_next in RX path. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Fix ks8851 snl NULL pointer dereference OopsTristram Ha
This fixes the NULL pointer dereference Oops in the ks8851 snl network driver during transmission. All socket buffers from the queue are processed inside the loop, but new workqueues have been scheduled to run. Signed-off-by: Tristram Ha <Tristram.Ha@micrel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03netdevice: provide common routine for macvlan and vlan operstate managementPatrick Mullaney
Provide common routine for the transition of operational state for a leaf device during a root device transition. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03bnx2: Refine VPD logic.Michael Chan
- Replace magic values with constants - Simplify length calculation and fix a bug Based on valuable feedback from Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03ixgbe: use EIAM to automask MSI-XJesse Brandeburg
when disabling interrupts, driver was writing with IO, this is no necessary because on ixgbe parts the hardware can "oneshot" disable and clear the interrupt. So on 82598/82599 use of EIAM should avoid one posted write per interrupt when in MSI-X mode. This should improve performance and seems to in my limited testing, reduce CPU utilization VERY slightly. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
