I tried to use 'dump_page(page, __func__)' for debugging, but it triggers
warning:
warning: passing argument 2 of `dump_page' discards `const' qualifier from pointer target type [enabled by default]
Let's convert 'reason' to 'const char *' in dump_page() and friends: we
shouldn't modify it anyway.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
vm_map_ram() has a fragmentation problem when it cannot purge a
chunk(ie, 4M address space) if there is a pinning object in that
addresss space. So it could consume all VMALLOC address space easily.
We can fix the fragmentation problem by using vmap instead of
vm_map_ram() but vmap() is known to be slow compared to vm_map_ram().
Minchan said vm_map_ram is 5 times faster than vmap in his tests. So I
thought we should fix fragment problem of vm_map_ram because our
proprietary GPU driver has used it heavily.
On second thought, it's not an easy because we should reuse freed space
for solving the problem and it could make more IPI and bitmap operation
for searching hole. It could mitigate API's goal which is very fast
mapping. And even fragmentation problem wouldn't show in 64 bit
machine.
Another option is that the user should separate long-life and short-life
object and use vmap for long-life but vm_map_ram for short-life. If we
inform the user about the characteristic of vm_map_ram the user can
choose one according to the page lifetime.
Let's add some notice messages to user.
[akpm@linux-foundation.org: tweak comment text]
Signed-off-by: Gioh Kim <gioh.kim@lge.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Signed-off-by: Choi Gi-yong <yong@gnoy.org>
Add unlikely and likely hints to the function mempool_free. It lays out
the code in such a way that the common path is executed straighforward and
saves a cache line.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
The conditions that control the isolation mode in
isolate_migratepages_range() do not change during the iteration, so
extract them out and only define the value once.
This actually does have an effect, gcc doesn't optimize it itself because
of cc->sync.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
The res_counter_{charge,uncharge}_locked() variants are not used in the
kernel outside of the resource counter code itself, so remove the
interface.
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Tim Hockin <thockin@google.com>
Cc: Christoph Lameter <cl@linux.com>
PF_MEMPOLICY is an unnecessary optimization for CONFIG_SLAB users.
There's no significant performance degradation to checking
current->mempolicy rather than current->flags & PF_MEMPOLICY in the
allocation path, especially since this is considered unlikely().
Running TCP_RR with netperf-2.4.5 through localhost on 16 cpu machine with
64GB of memory and without a mempolicy:
threads before after
16 1249409 1244487
32 1281786 1246783
48 1239175 1239138
64 1244642 1241841
80 1244346 1248918
96 1266436 1254316
112 1307398 1312135
128 1327607 1326502
Per-process flags are a scarce resource so we should free them up whenever
possible and make them available. We'll be using it shortly for memcg oom
reserves.
slab_node() is actually a mempolicy function, so rename it to
mempolicy_slab_node() to make it clearer that it used for processes with
mempolicies.
At the same time, cleanup its code by saving numa_mem_id() in a local
variable (since we require a node with memory, not just any node) and
remove an obsolete comment that assumes the mempolicy is actually passed
into the function.
Acked-by: Christoph Lameter <cl@linux.com>
copy_flags() does not use the clone_flags formal and can be collapsed
into copy_process() for cleaner code.
To increase compiler portability there is <linux/compiler.h> which
provides convenience macros for various gcc constructs. Eg: __weak for
__attribute__((weak)). I've replaced all instances of gcc attributes with
the right macro in the memory management (/mm) subsystem.
[akpm@linux-foundation.org: while-we're-there consistency tweaks]
Signed-off-by: Gideon Israel Dsouza <gidisrael@gmail.com>
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
In shmem/tmpfs, we also use the generic filemap_map_pages, seems the
additional checking is not worth a separate version of map_pages for it.
Signed-off-by: Ning Qu <quning@google.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Let's allow people to tweak faultaround at runtime.
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Ning Qu <quning@gmail.com>
Minor cleanups:
- 'size' variable is now in bytes, not pages;
- use round_up(): it should be easier to read.
filemap_map_pages() is generic implementation of ->map_pages() for
filesystems who uses page cache.
It should be safe to use filemap_map_pages() for ->map_pages() if
filesystem use filemap_fault() for ->fault().
Here's new version of faultaround patchset. It took a while to tune it
and collect performance data.
First patch adds new callback ->map_pages to vm_operations_struct.
->map_pages() is called when VM asks to map easy accessible pages.
Filesystem should find and map pages associated with offsets from
"pgoff" till "max_pgoff". ->map_pages() is called with page table
locked and must not block. If it's not possible to reach a page without
blocking, filesystem should skip it. Filesystem should use do_set_pte()
to setup page table entry. Pointer to entry associated with offset
"pgoff" is passed in "pte" field in vm_fault structure. Pointers to
entries for other offsets should be calculated relative to "pte".
Currently VM use ->map_pages only on read page fault path. We try to
map FAULT_AROUND_PAGES a time. FAULT_AROUND_PAGES is 16 for now.
Performance data for different FAULT_AROUND_ORDER is below.
TODO:
- implement ->map_pages() for shmem/tmpfs;
- modify get_user_pages() to be able to use ->map_pages() and implement
mmap(MAP_POPULATE|MAP_NONBLOCK) on top.
Tested on 4-socket machine (120 threads) with 128GiB of RAM.
Few real-world workloads. The sweet spot for FAULT_AROUND_ORDER here is
somewhere between 3 and 5. Let's say 4 :)
Linux build (make -j60)
FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9
minor-faults 283,301,572 247,151,987 212,215,789 204,772,882 199,568,944 194,703,779 193,381,485
time, seconds 151.227629483 153.920996480 151.356125472 150.863792049 150.879207877 151.150764954 151.450962358
Linux rebuild (make -j60)
minor-faults 5,396,854 4,148,444 2,855,286 2,577,282 2,361,957 2,169,573 2,112,643
time, seconds 27.404543757 27.559725591 27.030057426 26.855045126 26.678618635 26.974523490 26.761320095
Git test suite (make -j60 test)
minor-faults 129,591,823 99,200,751 66,106,718 57,606,410 51,510,808 45,776,813 44,085,515
time, seconds 66.087215026 64.784546905 64.401156567 65.282708668 66.034016829 66.793780811 67.237810413
Two synthetic tests: access every word in file in sequential/random order.
It doesn't improve much after FAULT_AROUND_ORDER == 4.
Sequential access 16GiB file
1 thread
minor-faults 4,195,437 2,098,275 525,068 262,251 131,170 32,856 8,282
time, seconds 7.250461742 6.461711074 5.493859139 5.488488147 5.707213983 5.898510832 5.109232856
8 threads
minor-faults 33,557,540 16,892,728 4,515,848 2,366,999 1,423,382 442,732 142,339
time, seconds 16.649304881 9.312555263 6.612490639 6.394316732 6.669827501 6.75078944 6.371900528
32 threads
minor-faults 134,228,222 67,526,810 17,725,386 9,716,537 4,763,731 1,668,921 537,200
time, seconds 49.164430543 29.712060103 12.938649729 10.175151004 11.840094583 9.594081325 9.928461797
60 threads
minor-faults 251,687,988 126,146,952 32,919,406 18,208,804 10,458,947 2,733,907 928,217
time, seconds 86.260656897 49.626551828 22.335007632 17.608243696 16.523119035 16.339489186 16.326390902
120 threads
minor-faults 503,352,863 252,939,677 67,039,168 35,191,827 19,170,091 4,688,357 1,471,862
time, seconds 124.589206333 79.757867787 39.508707872 32.167281632 29.972989292 28.729834575 28.042251622
Random access 1GiB file
1 thread
minor-faults 262,636 132,743 34,369 17,299 8,527 3,451 1,222
time, seconds 15.351890914 16.613802482 16.569227308 15.179220992 16.557356122 16.578247824 15.365266994
8 threads
minor-faults 2,098,948 1,061,871 273,690 154,501 87,110 25,663 7,384
time, seconds 15.040026343 15.096933500 14.474757288 14.289129964 14.411537468 14.296316837 14.395635804
32 threads
minor-faults 8,390,734 4,231,023 1,054,432 528,847 269,242 97,746 26,881
time, seconds 20.430433109 21.585235358 22.115062928 14.872878951 14.880856305 14.883370649 14.821261690
60 threads
minor-faults 15,733,258 7,892,809 1,973,393 988,266 594,789 164,994 51,691
time, seconds 26.577302548 25.692397770 18.728863715 20.153026398 21.619101933 17.745086260 17.613215273
120 threads
minor-faults 31,471,111 15,816,616 3,959,209 1,978,685 1,008,299 264,635 96,010
time, seconds 41.835322703 40.459786095 36.085306105 35.313894834 35.814445675 36.552633793 34.289210594
Touch only one page in page table in 16GiB file
1 thread
minor-faults 8,372 8,324 8,270 8,260 8,249 8,239 8,237
time, seconds 0.039892712 0.045369149 0.051846126 0.063681685 0.079095975 0.17652406 0.541213386
8 threads
minor-faults 65,731 65,681 65,628 65,620 65,608 65,599 65,596
time, seconds 0.124159196 0.488600638 0.156854426 0.191901957 0.242631486 0.543569456 1.677303984
32 threads
minor-faults 262,388 262,341 262,285 262,276 262,266 262,257 263,183
time, seconds 0.452421421 0.488600638 0.565020946 0.648229739 0.789850823 1.651584361 5.000361559
60 threads
minor-faults 491,822 491,792 491,723 491,711 491,701 491,691 491,825
time, seconds 0.763288616 0.869620515 0.980727360 1.161732354 1.466915814 3.04041448 9.308612938
120 threads
minor-faults 983,466 983,655 983,366 983,372 983,363 984,083 984,164
time, seconds 1.595846553 1.667902182 2.008959376 2.425380942 2.941368804 5.977807890 18.401846125
This patch (of 2):
Introduce new vm_ops callback ->map_pages() and uses it for mapping easy
accessible pages around fault address.
On read page fault, if filesystem provides ->map_pages(), we try to map up
to FAULT_AROUND_PAGES pages around page fault address in hope to reduce
number of minor page faults.
We call ->map_pages first and use ->fault() as fallback if page by the
offset is not ready to be mapped (cold page cache or something).
"mm: introduce vm_ops->map_pages()" wants to export a do_set_pte() from core
kernel. Rename lguest's do_set_pte() to something more lguest-specific.
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
After this patch 'page-types' can walk over a file's mappings and
analyze populated page cache pages mostly without disturbing its state.
It maps chunk of file, marks VMA as MADV_RANDOM to turn off readahead,
pokes VMA via mincore() to determine cached pages, triggers page-fault
only for them, and finally gathers information via pagemap/kpageflags.
Before unmap it marks VMA as MADV_SEQUENTIAL for ignoring reference
bits.
usage: page-types -f <path>
If <path> is directory it will analyse all files in all subdirectories.
Symlinks are not followed as well as mount points. Hardlinks aren't
handled, they'll be dumped as many times as they are found. Recursive
walk brings all dentries into dcache and populates page cache of
block-devices aka 'Buffers'.
Probably it's worth to add ioctl for dumping file page cache as array of
PFNs as a replacement for this hackish juggling with
mmap/madvise/mincore/pagemap. Also recursive walk could be replaced
with dumping cached inodes via some ioctl or debugfs interface followed
by openning them via open_by_handle_at, this would fix hardlinks
handling and unneeded population of dcache and buffers. This interface
might be used as data source for constructing readahead plans and for
background optimizations of actively used files.
collateral changes:
+ fix 64-bit LFS: define _FILE_OFFSET_BITS instead of _LARGEFILE64_SOURCE
+ replace lseek + read with single pread
+ make show_page_range() reusable after flush
usage example:
~/src/linux/tools/vm$ sudo ./page-types -L -f page-types
foffset offset flags
page-types Inode: 2229277 Size: 89065 (22 pages)
Modify: Tue Feb 25 12:00:59 2014 (162 seconds ago)
Access: Tue Feb 25 12:01:00 2014 (161 seconds ago)
0 3cbf3b __RU_lA____M________________________
1 38946a __RU_lA____M________________________
2 1a3cec __RU_lA____M________________________
3 1a8321 __RU_lA____M________________________
4 3af7cc __RU_lA____M________________________
5 1ed532 __RU_lA_____________________________
6 2e436a __RU_lA_____________________________
7 29a35e ___U_lA_____________________________
8 2de86e ___U_lA_____________________________
9 3bdfb4 ___U_lA_____________________________
10 3cd8a3 ___U_lA_____________________________
11 2afa50 ___U_lA_____________________________
12 2534c2 ___U_lA_____________________________
13 1b7a40 ___U_lA_____________________________
14 17b0be ___U_lA_____________________________
15 392b0c ___U_lA_____________________________
16 3ba46a __RU_lA_____________________________
17 397dc8 ___U_lA_____________________________
18 1f2a36 ___U_lA_____________________________
19 21fd30 __RU_lA_____________________________
20 2c35ba __RU_l______________________________
21 20f181 __RU_l______________________________
flags page-count MB symbolic-flags long-symbolic-flags
0x000000000000002c 2 0 __RU_l______________________________ referenced,uptodate,lru
0x0000000000000068 11 0 ___U_lA_____________________________ uptodate,lru,active
0x000000000000006c 4 0 __RU_lA_____________________________ referenced,uptodate,lru,active
0x000000000000086c 5 0 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap
total 22 0
~/src/linux/tools/vm$ sudo ./page-types -f /
0x0000000000000028 21761 85 ___U_l______________________________ uptodate,lru
0x000000000000002c 127279 497 __RU_l______________________________ referenced,uptodate,lru
0x0000000000000068 74160 289 ___U_lA_____________________________ uptodate,lru,active
0x000000000000006c 84469 329 __RU_lA_____________________________ referenced,uptodate,lru,active
0x000000000000007c 1 0 __RUDlA_____________________________ referenced,uptodate,dirty,lru,active
0x0000000000000228 370 1 ___U_l___I__________________________ uptodate,lru,reclaim
0x0000000000000828 49 0 ___U_l_____M________________________ uptodate,lru,mmap
0x000000000000082c 126 0 __RU_l_____M________________________ referenced,uptodate,lru,mmap
0x0000000000000868 137 0 ___U_lA____M________________________ uptodate,lru,active,mmap
0x000000000000086c 12890 50 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap
total 321242 1254
Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
There's no reason to enable split page table lock if don't have page
tables.
It also triggers build error at least on ARM since we don't define
pmd_page() for !MMU.
In file included from arch/arm/kernel/asm-offsets.c:14:0:
include/linux/mm.h: In function 'pte_lockptr':
include/linux/mm.h:1392:2: error: implicit declaration of function 'pmd_page' [-Werror=implicit-function-declaration]
include/linux/mm.h:1392:2: warning: passing argument 1 of 'ptlock_ptr' makes pointer from integer without a cast [enabled by default]
include/linux/mm.h:1384:27: note: expected 'struct page *' but argument is of type 'int'
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
load_elf_binary() sets current->mm->def_flags = def_flags and def_flags
is always zero. Not only this looks strange, this is unnecessary
because mm_init() has already set ->def_flags = 0.
Signed-off-by: Alex Thorlton <athorlton@sgi.com>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Add VM_INIT_DEF_MASK, to allow us to set the default flags for VMs. It
also adds a prctl control which allows us to set the THP disable bit in
mm->def_flags so that VMs will pick up the setting as they are created.
The main motivation behind this patch is to provide a way to disable THP
for jobs where the code cannot be modified, and using a malloc hook with
madvise is not an option (i.e. statically allocated data). This patch
allows us to do just that, without affecting other jobs running on the
system.
We need to do this sort of thing for jobs where THP hurts performance,
due to the possibility of increased remote memory accesses that can be
created by situations such as the following:
When you touch 1 byte of an untouched, contiguous 2MB chunk, a THP will
be handed out, and the THP will be stuck on whatever node the chunk was
originally referenced from. If many remote nodes need to do work on
that same chunk, they'll be making remote accesses.
With THP disabled, 4K pages can be handed out to separate nodes as
they're needed, greatly reducing the amount of remote accesses to
memory.
This patch is based on some of my work combined with some
suggestions/patches given by Oleg Nesterov. The main goal here is to
add a prctl switch to allow us to disable to THP on a per mm_struct
basis.
Here's a bit of test data with the new patch in place...
First with the flag unset:
# perf stat -a ./prctl_wrapper_mmv3 0 ./thp_pthread -C 0 -m 0 -c 512 -b 256g
Setting thp_disabled for this task...
thp_disable: 0
Set thp_disabled state to 0
Process pid = 18027
PF/
MAX MIN TOTCPU/ TOT_PF/ TOT_PF/ WSEC/
TYPE: CPUS WALL WALL SYS USER TOTCPU CPU WALL_SEC SYS_SEC CPU NODES
512 1.120 0.060 0.000 0.110 0.110 0.000 28571428864 -9223372036854775808 55803572 23
Performance counter stats for './prctl_wrapper_mmv3_hack 0 ./thp_pthread -C 0 -m 0 -c 512 -b 256g':
273719072.841402 task-clock # 641.026 CPUs utilized [100.00%]
1,008,986 context-switches # 0.000 M/sec [100.00%]
7,717 CPU-migrations # 0.000 M/sec [100.00%]
1,698,932 page-faults # 0.000 M/sec
355,222,544,890,379 cycles # 1.298 GHz [100.00%]
536,445,412,234,588 stalled-cycles-frontend # 151.02% frontend cycles idle [100.00%]
409,110,531,310,223 stalled-cycles-backend # 115.17% backend cycles idle [100.00%]
148,286,797,266,411 instructions # 0.42 insns per cycle
# 3.62 stalled cycles per insn [100.00%]
27,061,793,159,503 branches # 98.867 M/sec [100.00%]
1,188,655,196 branch-misses # 0.00% of all branches
427.001706337 seconds time elapsed
Now with the flag set:
# perf stat -a ./prctl_wrapper_mmv3 1 ./thp_pthread -C 0 -m 0 -c 512 -b 256g
thp_disable: 1
Set thp_disabled state to 1
Process pid = 144957
PF/
512 0.620 0.260 0.250 0.320 0.570 0.001 51612901376 128000000000 100806448 23
Performance counter stats for './prctl_wrapper_mmv3_hack 1 ./thp_pthread -C 0 -m 0 -c 512 -b 256g':
138789390.540183 task-clock # 641.959 CPUs utilized [100.00%]
534,205 context-switches # 0.000 M/sec [100.00%]
4,595 CPU-migrations # 0.000 M/sec [100.00%]
63,133,119 page-faults # 0.000 M/sec
147,977,747,269,768 cycles # 1.066 GHz [100.00%]
200,524,196,493,108 stalled-cycles-frontend # 135.51% frontend cycles idle [100.00%]
105,175,163,716,388 stalled-cycles-backend # 71.07% backend cycles idle [100.00%]
180,916,213,503,160 instructions # 1.22 insns per cycle
# 1.11 stalled cycles per insn [100.00%]
26,999,511,005,868 branches # 194.536 M/sec [100.00%]
714,066,351 branch-misses # 0.00% of all branches
216.196778807 seconds time elapsed
As with previous versions of the patch, We're getting about a 2x
performance increase here. Here's a link to the test case I used, along
with the little wrapper to activate the flag:
http://oss.sgi.com/projects/memtests/thp_pthread_mmprctlv3.tar.gz
This patch (of 3):
Revert commit 8e72033f2a48 and add in code to fix up any issues caused
by the revert.
The revert is necessary because hugepage_madvise would return -EINVAL
when VM_NOHUGEPAGE is set, which will break subsequent chunks of this
patch set.
Here's a snip of an e-mail from Gerald detailing the original purpose of
this code, and providing justification for the revert:
"The intent of commit 8e72033f2a48 was to guard against any future
programming errors that may result in an madvice(MADV_HUGEPAGE) on
guest mappings, which would crash the kernel.
Martin suggested adding the bit to arch/s390/mm/pgtable.c, if
8e72033f2a48 was to be reverted, because that check will also prevent
a kernel crash in the case described above, it will now send a
SIGSEGV instead.
This would now also allow to do the madvise on other parts, if
needed, so it is a more flexible approach. One could also say that
it would have been better to do it this way right from the
beginning..."
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
It is just for clean-up to reduce code size and improve readability.
There is no functional change.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
isolation_suitable() and migrate_async_suitable() is used to be sure
that this pageblock range is fine to be migragted. It isn't needed to
call it on every page. Current code do well if not suitable, but, don't
do well when suitable.
1) It re-checks isolation_suitable() on each page of a pageblock that was
already estabilished as suitable.
2) It re-checks migrate_async_suitable() on each page of a pageblock that
was not entered through the next_pageblock: label, because
last_pageblock_nr is not otherwise updated.
This patch fixes situation by 1) calling isolation_suitable() only once
per pageblock and 2) always updating last_pageblock_nr to the pageblock
that was just checked.
Additionally, move PageBuddy() check after pageblock unit check, since
pageblock check is the first thing we should do and makes things more
simple.
[vbabka@suse.cz: rephrase commit description]
It is odd to drop the spinlock when we scan (SWAP_CLUSTER_MAX - 1) th
pfn page. This may results in below situation while isolating
migratepage.
1. try isolate 0x0 ~ 0x200 pfn pages.
2. When low_pfn is 0x1ff, ((low_pfn+1) % SWAP_CLUSTER_MAX) == 0, so drop
the spinlock.
3. Then, to complete isolating, retry to aquire the lock.
I think that it is better to use SWAP_CLUSTER_MAX th pfn for checking the
criteria about dropping the lock. This has no harm 0x0 pfn, because, at
this time, locked variable would be false.
suitable_migration_target() checks that pageblock is suitable for
migration target. In isolate_freepages_block(), it is called on every
page and this is inefficient. So make it called once per pageblock.
suitable_migration_target() also checks if page is highorder or not, but
it's criteria for highorder is pageblock order. So calling it once
within pageblock range has no problem.
Purpose of compaction is to get a high order page. Currently, if we
find high-order page while searching migration target page, we break it
to order-0 pages and use them as migration target. It is contrary to
purpose of compaction, so disallow high-order page to be used for
migration target.
Additionally, clean-up logic in suitable_migration_target() to simplify
the code. There is no functional changes from this clean-up.
We had a report about strange OOM killer strikes on a PPC machine
although there was a lot of swap free and a tons of anonymous memory
which could be swapped out. In the end it turned out that the OOM was a
side effect of zone reclaim which wasn't unmapping and swapping out and
so the system was pushed to the OOM. Although this sounds like a bug
somewhere in the kswapd vs. zone reclaim vs. direct reclaim
interaction numactl on the said hardware suggests that the zone reclaim
should not have been set in the first place:
node 0 cpus: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
node 0 size: 0 MB
node 0 free: 0 MB
node 2 cpus:
node 2 size: 7168 MB
node 2 free: 6019 MB
node distances:
node 0 2
0: 10 40
2: 40 10
So all the CPUs are associated with Node0 which doesn't have any memory
while Node2 contains all the available memory. Node distances cause an
automatic zone_reclaim_mode enabling.
Zone reclaim is intended to keep the allocations local but this doesn't
make any sense on the memoryless nodes. So let's exclude such nodes for
init_zone_allows_reclaim which evaluates zone reclaim behavior and
suitable reclaim_nodes.
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Tested-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
The described issue now occurs inside mmap_region(). And unfortunately
is still valid.
We abort direct reclaim if we find the zone is ready for compaction.
Sometimes the zone is just a promoted highmem zone to force a scan of
highmem, which is not the intended zone the caller want to allocate a
page from. In this situation, setting aborted_reclaim to indicate the
caller turned back to retry the allocation is waste of time and could
cause a loop in __alloc_pages_slowpath().
This patch does not check compaction_ready() on promoted zones to avoid
the above situation. Only set aborted_reclaim if the caller intended
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
We promote sc->gfp_mask to __GFP_HIGHMEM to forcibly scan highmem if
there are too many buffer_heads pinning highmem. See cc715d99e5 ("mm:
vmscan: forcibly scan highmem if there are too many buffer_heads pinning
highmem").
This patch restores sc->gfp_mask to its caller original value after
finishing the scan job, to avoid the impact on other invocations from
its upper caller, such as vmpressure_prio(), shrink_slab().
The NUMA scanning code can end up iterating over many gigabytes of
unpopulated memory, especially in the case of a freshly started KVM
guest with lots of memory.
This results in the mmu notifier code being called even when there are
no mapped pages in a virtual address range. The amount of time wasted
can be enough to trigger soft lockup warnings with very large KVM
guests.
This patch moves the mmu notifier call to the pmd level, which
represents 1GB areas of memory on x86-64. Furthermore, the mmu notifier
code is only called from the address in the PMD where present mappings
are first encountered.
The hugetlbfs code is left alone for now; hugetlb mappings are not
relocatable, and as such are left alone by the NUMA code, and should
never trigger this problem to begin with.
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Xing Gang <gang.xing@hp.com>
Tested-by: Chegu Vinod <chegu_vinod@hp.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Sasha reported the following bug using trinity
kernel BUG at mm/mprotect.c:149!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 20 PID: 26219 Comm: trinity-c216 Tainted: G W 3.14.0-rc5-next-20140305-sasha-00011-ge06f5f3-dirty #105
task: ffff8800b6c80000 ti: ffff880228436000 task.ti: ffff880228436000
RIP: change_protection_range+0x3b3/0x500
Call Trace:
change_protection+0x25/0x30
change_prot_numa+0x1b/0x30
task_numa_work+0x279/0x360
task_work_run+0xae/0xf0
do_notify_resume+0x8e/0xe0
retint_signal+0x4d/0x92
The VM_BUG_ON was added in -mm by the patch "mm,numa: reorganize
change_pmd_range". The race existed without the patch but was just
harder to hit.
The problem is that a transhuge check is made without holding the PTL.
It's possible at the time of the check that a parallel fault clears the
pmd and inserts a new one which then triggers the VM_BUG_ON check. This
patch removes the VM_BUG_ON but fixes the race by rechecking transhuge
under the PTL when marking page tables for NUMA hinting and bailing if a
race occurred. It is not a problem for calls to mprotect() as they hold
mmap_sem for write.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Reorganize the order of ifs in change_pmd_range a little, in preparation
for the next patch.
[akpm@linux-foundation.org: fix indenting, per David]
huge_pte_offset() could return NULL, so we need NULL check to avoid
potential NULL pointer dereferences.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
- Convert spinlock/static array to va_format (inspired by Joe Perches
help on previous logging patches).
- Convert printk(KERN_ERR to pr_warn in __ntfs_warning.
- Convert printk(KERN_ERR to pr_err in __ntfs_error.
- Convert printk(KERN_DEBUG to pr_debug in __ntfs_debug. (Note that
__ntfs_debug is still guarded by #if DEBUG)
- Improve !DEBUG to parse all arguments (Joe Perches).
- Sparse pr_foo() conversions in super.c
NTFS, NTFS-fs prefixes as well as 'warning' and 'error' were removed :
pr_foo() automatically adds module name and error level is already
specified.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Anton Altaparmakov <anton@tuxera.com>
Cc: Joe Perches <joe@perches.com>
Pull NFS client updates from Trond Myklebust:
"Highlights include:
- Stable fix for a use after free issue in the NFSv4.1 open code
- Fix the SUNRPC bi-directional RPC code to account for TCP segmentation
- Optimise usage of readdirplus when confronted with 'ls -l' situations
- Soft mount bugfixes
- NFS over RDMA bugfixes
- NFSv4 close locking fixes
- Various NFSv4.x client state management optimisations
- Rename/unlink code cleanups"
* tag 'nfs-for-3.15-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (28 commits)
nfs: pass string length to pr_notice message about readdir loops
NFSv4: Fix a use-after-free problem in open()
SUNRPC: rpc_restart_call/rpc_restart_call_prepare should clear task->tk_status
SUNRPC: Don't let rpc_delay() clobber non-timeout errors
SUNRPC: Ensure call_connect_status() deals correctly with SOFTCONN tasks
SUNRPC: Ensure call_status() deals correctly with SOFTCONN tasks
NFSv4: Ensure we respect soft mount timeouts during trunking discovery
NFSv4: Schedule recovery if nfs40_walk_client_list() is interrupted
NFS: advertise only supported callback netids
SUNRPC: remove KERN_INFO from dprintk() call sites
SUNRPC: Fix large reads on NFS/RDMA
NFS: Clean up: revert increase in READDIR RPC buffer max size
SUNRPC: Ensure that call_bind times out correctly
SUNRPC: Ensure that call_connect times out correctly
nfs: emit a fsnotify_nameremove call in sillyrename codepath
nfs: remove synchronous rename code
nfs: convert nfs_rename to use async_rename infrastructure
nfs: make nfs_async_rename non-static
nfs: abstract out code needed to complete a sillyrename
NFSv4: Clear the open state flags if the new stateid does not match
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Nothing major: the stricter permissions checking for sysfs broke a
staging driver; fix included. Greg KH said he'd take the patch but
hadn't as the merge window opened, so it's included here to avoid
breaking build"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
staging: fix up speakup kobject mode
Use 'E' instead of 'X' for unsigned module taint flag.
VERIFY_OCTAL_PERMISSIONS: stricter checking for sysfs perms.
kallsyms: fix percpu vars on x86-64 with relocation.
kallsyms: generalize address range checking
module: LLVMLinux: Remove unused function warning from __param_check macro
Fix: module signature vs tracepoints: add new TAINT_UNSIGNED_MODULE
module: remove MODULE_GENERIC_TABLE
module: allow multiple calls to MODULE_DEVICE_TABLE() per module
module: use pr_cont
Pull arch/tile updates from Chris Metcalf:
"These fix a few stray build issues seen in linux-next, and also add
the minimal required support for perf to tilegx"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: remove unused variable 'devcap'
tile: Fix vDSO compilation issue with allyesconfig
perf tools: Allow building for tile
tile/perf: Support perf_events on tilegx and tilepro
tile: Enable NMIs on return from handle_nmi() without errors
tile: Add support for handling PMC hardware
tile: don't use __get_cpu_var() with structure-typed arguments
tile: avoid overflow in ns2cycles
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper changes from Mike Snitzer:
- Fix dm-cache corruption caused by discard_block_size > cache_block_size
- Fix a lock-inversion detected by LOCKDEP in dm-cache
- Fix a dangling bio bug in the dm-thinp target's process_deferred_bios
error path
- Fix corruption due to non-atomic transaction commit which allowed a
metadata superblock to be written before all other metadata was
successfully written -- this is common to all targets that use the
persistent-data library's transaction manager (dm-thinp, dm-cache and
dm-era).
- Various small cleanups in the DM core
- Add the dm-era target which is useful for keeping track of which
blocks were written within a user defined period of time called an
'era'. Use cases include tracking changed blocks for backup
software, and partially invalidating the contents of a cache to
restore cache coherency after rolling back a vendor snapshot.
- Improve the on-disk layout of multithreaded writes to the
dm-thin-pool by splitting the pool's deferred bio list to be a
per-thin device list and then sorting that list using an rb_tree.
The subsequent read throughput of the data written via multiple
threads improved by ~70%.
- Simplify the multipath target's handling of queuing IO by pushing
requests back to the request queue rather than queueing the IO
internally.
* tag 'dm-3.15-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: (24 commits)
dm cache: fix a lock-inversion
dm thin: sort the per thin deferred bios using an rb_tree
dm thin: use per thin device deferred bio lists
dm thin: simplify pool_is_congested
dm thin: fix dangling bio in process_deferred_bios error path
dm mpath: print more useful warnings in multipath_message()
dm-mpath: do not activate failed paths
dm mpath: remove extra nesting in map function
dm mpath: remove map_io()
dm mpath: reduce memory pressure when requeuing
dm mpath: remove process_queued_ios()
dm mpath: push back requests instead of queueing
dm table: add dm_table_run_md_queue_async
dm mpath: do not call pg_init when it is already running
dm: use RCU_INIT_POINTER instead of rcu_assign_pointer in __unbind
dm: stop using bi_private
dm: remove dm_get_mapinfo
dm: make dm_table_alloc_md_mempools static
dm: take care to copy the space map roots before locking the superblock
dm transaction manager: fix corruption due to non-atomic transaction commit
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU upates from Joerg Roedel:
"This time a few more updates queued up.
- Rework VT-d code to support ACPI devices
- Improvements for memory and PCI hotplug support in the VT-d driver
- Device-tree support for OMAP IOMMU
- Convert OMAP IOMMU to use devm_* interfaces
- Fixed PASID support for AMD IOMMU
- Other random cleanups and fixes for OMAP, ARM-SMMU and SHMOBILE
IOMMU
Most of the changes are in the VT-d driver because some rework was
necessary for better hotplug and ACPI device support"
* tag 'iommu-updates-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (75 commits)
iommu/vt-d: Fix error handling in ANDD processing
iommu/vt-d: returning free pointer in get_domain_for_dev()
iommu/vt-d: Only call dmar_acpi_dev_scope_init() if DRHD units present
iommu/vt-d: Check for NULL pointer in dmar_acpi_dev_scope_init()
iommu/amd: Fix logic to determine and checking max PASID
iommu/vt-d: Include ACPI devices in iommu=pt
iommu/vt-d: Finally enable translation for non-PCI devices
iommu/vt-d: Remove to_pci_dev() in intel_map_page()
iommu/vt-d: Remove pdev from intel_iommu_attach_device()
iommu/vt-d: Remove pdev from iommu_no_mapping()
iommu/vt-d: Make domain_add_dev_info() take struct device
iommu/vt-d: Make domain_remove_one_dev_info() take struct device
iommu/vt-d: Rename 'hwdev' variables to 'dev' now that that's the norm
iommu/vt-d: Remove some pointless to_pci_dev() calls
iommu/vt-d: Make get_valid_domain_for_dev() take struct device
iommu/vt-d: Make iommu_should_identity_map() take struct device
iommu/vt-d: Handle RMRRs for non-PCI devices
iommu/vt-d: Make get_domain_for_dev() take struct device
iommu/vt-d: Make domain_context_mapp{ed,ing}() take struct device
iommu/vt-d: Make device_to_iommu() cope with non-PCI devices
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull hwmon updates from Jean Delvare:
"This includes a number of driver conversions to
devm_hwmon_device_register_with_groups, a few cleanups, and
support for the ITE IT8623E"
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (it87) Add support for IT8623E
hwmon: (it87) Fix IT8603E define name
hwmon: (lm90) Convert to use hwmon_device_register_with_groups
hwmon: (lm90) Create all sysfs groups in one call
hwmon: (lm90) Always use the dev variable in the probe function
hwmon: (lm90) Create most optional attributes with sysfs_create_group
hwmon: Avoid initializing the same field twice
hwmon: (pc87360) Avoid initializing the same field twice
hwmon: (lm80) Convert to use devm_hwmon_device_register_with_groups
hwmon: (adm1021) Convert to use devm_hwmon_device_register_with_groups
hwmon: (lm63) Avoid initializing the same field twice
hwmon: (lm63) Convert to use devm_hwmon_device_register_with_groups
hwmon: (lm63) Create all sysfs groups in one call
hwmon: (lm63) Introduce 'dev' variable to point to client->dev
hwmon: (lm63) Add additional sysfs group for temp2_type attribute
hwmon: (f71805f) Fix author's address
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework changes from Mike Turquette:
"The clock framework changes for 3.15 look similar to past pull
requests. Mostly clock driver updates, more Device Tree support in
the form of common functions useful across platforms and a handful of
features and fixes to the framework core"
* tag 'clk-for-linus-3.15' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: shmobile: fix setting paretn clock rate
clk: shmobile: rcar-gen2: fix lb/sd0/sd1/sdh clock parent to pll1
clk: Fix minor errors in of_clk_init() function comments
clk: reverse default clk provider initialization order in of_clk_init()
clk: sirf: update copyright years to 2014
clk: mmp: try to use closer one when do round rate
clk: mmp: fix the wrong calculation formula
clk: mmp: fix wrong mask when calculate denominator
clk: st: Adds quadfs clock binding
clk: st: Adds clockgen-vcc and clockgen-mux clock binding
clk: st: Adds clockgen clock binding
clk: st: Adds divmux and prediv clock binding
clk: st: Support for A9 MUX clocks
clk: st: Support for ClockGenA9/DDR/GPU
clk: st: Support for QUADFS inside ClockGenB/C/D/E/F
clk: st: Support for VCC-mux and MUX clocks
clk: st: Support for PLLs inside ClockGenA(s)
clk: st: Support for DIVMUX and PreDiv Clocks
clk: support hardware-specific debugfs entries
clk: s2mps11: Use of_get_child_by_name
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"The legacy HAVE_PWM Kconfig symbol is finally being retired. Thanks a
lot to Sascha Hauer for doing that.
Three new drivers are added: Freescale FTM, Cirrus Logic CLPS711X and
Intel Low Power Subsystem.
An assortment of fixes and cleanups rounds things off for this release
cycle"
* tag 'pwm/for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: pxa: Constify OF match table
pwm: pxa: Fix typo "pwm" -> "PWM"
Revert "pwm: pxa: Use of_match_ptr()"
pwm: add support for Intel Low Power Subsystem PWM
pwm: Add CLPS711X PWM support
pwm: atmel: correct CDTY calculation
pwm: atmel: Fix polarity handling
Documentation: Add device tree bindings for Freescale FTM PWM.
pwm: Add Freescale FTM PWM driver support
pwm: samsung: Use SIMPLE_DEV_PM_OPS macro
pwm: renesas-tpu: Add dependency on HAS_IOMEM
pwm: Remove obsolete HAVE_PWM Kconfig symbol
Pull ARM SoC late cleanups from Arnd Bergmann:
"These could not be part of the first cleanup branch, because they
either came too late in the cycle, or they have dependencies on other
branches. Important changes are:
- The integrator platform is almost multiplatform capable after some
reorganization (Linus Walleij)
- Minor cleanups on Zynq (Michal Simek)
- Lots of changes for Exynos and other Samsung platforms, including
further preparations for multiplatform support and the clocks
bindings are rearranged"
* tag 'tags/cleanup2-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
devicetree: fix newly added exynos sata bindings
ARM: EXYNOS: Fix compilation error in cpuidle.c
ARM: S5P64X0: Explicitly include linux/serial_s3c.h in mach/pm-core.h
ARM: EXYNOS: Remove hardware.h file
ARM: SAMSUNG: Remove hardware.h inclusion
ARM: S3C24XX: Remove invalid code from hardware.h
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Keep some essential LDOs enabled for arndale-octa board
ARM: dts: Disable MDMA1 node for arndale-octa board
ARM: S3C64XX: Fix build for implicit serial_s3c.h inclusion
serial: s3c: Fix build of header without serial_core.h preinclusion
ARM: EXYNOS: Allow wake-up using GIC interrupts
ARM: EXYNOS: Stop using legacy Samsung PM code
ARM: EXYNOS: Remove PM initcalls and useless indirection
ARM: EXYNOS: Fix abuse of CONFIG_PM
ARM: SAMSUNG: Move s3c_pm_check_* prototypes to plat/pm-common.h
ARM: SAMSUNG: Move common save/restore helpers to separate file
ARM: SAMSUNG: Move Samsung PM debug code into separate file
ARM: SAMSUNG: Consolidate PM debug functions
ARM: SAMSUNG: Use debug_ll_addr() to get UART base address
Pull ARM SoC sh driver change from Arnd Bergmann:
"The drivers/sh subdirectory used to get merged through the SH
architecture tree, but things are in flux there and some of the
drivers are shared with ARM shmobile, we have picked it up for the
time being.
There is only one trivial patch from Laurent Pinchart this time"
* tag 'sh-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
sh: intc: Enable driver compilation with COMPILE_TEST
Pull ARM SoC driver changes from Arnd Bergmann:
"These changes are mostly for ARM specific device drivers that either
don't have an upstream maintainer, or that had the maintainer ask us
to pick up the changes to avoid conflicts.
A large chunk of this are clock drivers (bcm281xx, exynos, versatile,
shmobile), aside from that, reset controllers for STi as well as a
large rework of the Marvell Orion/EBU watchdog driver are notable"
* tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits)
Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac."
Revert "net: stmmac: Add SOCFPGA glue driver"
ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks
ARM: STi: Add reset controller support to mach-sti Kconfig
drivers: reset: stih416: add softreset controller
drivers: reset: stih415: add softreset controller
drivers: reset: Reset controller driver for STiH416
drivers: reset: Reset controller driver for STiH415
drivers: reset: STi SoC system configuration reset controller support
dts: socfpga: Add sysmgr node so the gmac can use to reference
dts: socfpga: Add support for SD/MMC on the SOCFPGA platform
reset: Add optional resets and stubs
ARM: shmobile: r7s72100: fix bus clock calculation
Power: Reset: Generalize qnap-poweroff to work on Synology devices.
dts: socfpga: Update clock entry to support multiple parents
ARM: socfpga: Update socfpga_defconfig
watchdog: orion_wdt: Use %pa to print 'phys_addr_t'
drivers: cci: Export CCI PMU revision
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
Pull ARM SoC board changes from Arnd Bergmann:
"As we continue to replace board files with device tree descriptions,
this part of the ARM support is getting smaller. We have basically
just defconfig changes here this time, and a significant number of
Renesas shmobile changes, as Renesas is still in the process of
deprecating board file support"
* tag 'boards-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (92 commits)
ARM: enable fhandle in multi_v7_defconfig
ARM: tegra: enable fhandle in tegra_defconfig
ARM: update multi_v7_defconfig for Tegra
ARM: add Marvell Dove and some drivers to multi_v7 defconfig
ARM: fix duplicate symbols in multi_v5_defconfig
ARM: pxa: add gpio keys information
ARM: tegra: defconfig updates
ARM: config: keystone: enable AEMIF/NAND support
ARM: qcom: Enable basic support for Qualcomm platforms in multi_v7_defconfig
ARM: kirkwood: Add HP T5325 devices to {multi|mvebu}_v5_defconfig
ARM: config: Add mvebu_v5_defconfig
ARM: config: Add a multi_v5_defconfig
ARM: shmobile: r7s72100: update defconfig for I2C usage
ARM: shmobile: Remove Lager DT reference legacy clock bits
ARM: shmobile: Remove Koelsch DT reference legacy clock bits
ARM: shmobile: Remove KZM9D board code
ARM: mvebu: update defconfigs for Armada 375 and 38x
ARM: dove: Enable watchdog support in the defconfig
ARM: mvebu: Enable watchdog support in defconfig
ARM: config: keystone: enable led support
Pull ARM SoC specific changes from Arnd Bergmann:
"Lots of changes specific to one of the SoC families. Some that stick
out are:
- mach-qcom gains new features, most importantly SMP support for the
newer chips (Stephen Boyd, Rohit Vaswani)
- mvebu gains support for three new SoCs: Armada 375, 380 and 385
(Thomas Petazzoni and Free-electrons team)
- SMP support for Rockchips (Heiko Stübner)
- Lots of i.MX changes (Shawn Guo)
- Added support for BCM5301x SoC (Hauke Mehrtens)
- Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn
and Sebastian Hesselbarth doing the final part of a long journey)
- Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd
Bergmann)"
* tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits)
ARM: sunxi: Select HAVE_ARM_ARCH_TIMER
ARM: cache-tauros2: remove ARMv6 code
ARM: mvebu: don't select CONFIG_NEON
ARM: davinci: fix DT booting with default defconfig
ARM: configs: bcm_defconfig: enable bcm590xx regulator support
ARM: davinci: remove tnetv107x support
MAINTAINERS: Update ARM STi maintainers
ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE
ARM: bcm21664: Add board support.
ARM: sunxi: Add the new watchog compatibles to the reboot code
ARM: enable ARM_HAS_SG_CHAIN for multiplatform
ARM: davinci: remove da8xx_omapl_defconfig
ARM: davinci: da8xx: fix multiple watchdog device registration
ARM: davinci: add da8xx specific configs to davinci_all_defconfig
ARM: davinci: enable da8xx build concurrently with older devices
ARM: BCM5301X: workaround suppress fault
ARM: BCM5301X: add early debugging support
ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU
ARM: mach-bcm: Remove GENERIC_TIME
ARM: shmobile: APMU: Fix warnings due to improper printk formats
