2016-01-19svcrdma: Clean up process_context()Chuck Lever
Be sure the completed ctxt is put in every path. The xprt enqueue can take a while, so put the completed ctxt back in circulation _before_ enqueuing the xprt. Remove/disable debugging. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-by: Bruce Fields <bfields@fieldses.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19svcrdma: Clean up rdma_create_xprt()Chuck Lever
kzalloc is used here, so setting the atomic fields to zero is unnecessary. sc_ord is set again in handle_connect_req. The other fields are re-initialized in svc_rdma_accept(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-by: Bruce Fields <bfields@fieldses.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: Use hop-limit from IP stack for RoCEMatan Barak
Previously, IPV6_DEFAULT_HOPLIMIT was used as the hop limit value for RoCE. Fixing that by taking ip4_dst_hoplimit and ip6_dst_hoplimit as hop limit values. Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: Rename rdma_addr_find_dmac_by_grhMatan Barak
rdma_addr_find_dmac_by_grh resolves dmac, vlan_id and if_index and downsteram patch will also add hop_limit as an output parameter, thus we rename it to rdma_addr_find_l2_eth_by_grh. Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/cm: Fix a recently introduced deadlockBart Van Assche
ib_send_cm_drep() calls cm_enter_timewait() while holding a spinlock that can be locked from inside an interrupt handler. Hence do not enable interrupts inside cm_enter_timewait() if called with interrupts disabled. This patch fixes e.g. the following deadlock: Acked-by: Erez Shitrit <erezsh@mellanox.com> ================================= [ INFO: inconsistent lock state ] 4.4.0-rc7+ #1 Tainted: G E --------------------------------- inconsistent {HARDIRQ-ON-W} -> {IN-HARDIRQ-W} usage. swapper/8/0 [HC1[1]:SC0[0]:HE0:SE1] takes: (&(&cm_id_priv->lock)->rlock){?.+...}, at: [<ffffffffa036eec4>] cm_establish+0x 74/0x1b0 [ib_cm] {HARDIRQ-ON-W} state was registered at: [<ffffffff810a3c11>] mark_held_locks+0x71/0x90 [<ffffffff810a3e87>] trace_hardirqs_on_caller+0xa7/0x1c0 [<ffffffff810a3fad>] trace_hardirqs_on+0xd/0x10 [<ffffffff8151c40b>] _raw_spin_unlock_irq+0x2b/0x40 [<ffffffffa036ea8e>] cm_enter_timewait+0xae/0x100 [ib_cm] [<ffffffffa036ff76>] ib_send_cm_drep+0xb6/0x190 [ib_cm] [<ffffffffa052ed08>] srp_cm_handler+0x128/0x1a0 [ib_srp] [<ffffffffa0370340>] cm_process_work+0x20/0xf0 [ib_cm] [<ffffffffa0371335>] cm_dreq_handler+0x135/0x2c0 [ib_cm] [<ffffffffa03733c5>] cm_work_handler+0x75/0xd0 [ib_cm] [<ffffffff8107184d>] process_one_work+0x1bd/0x460 [<ffffffff81073148>] worker_thread+0x118/0x420 [<ffffffff81078454>] kthread+0xe4/0x100 [<ffffffff8151cbbf>] ret_from_fork+0x3f/0x70 irq event stamp: 1672286 hardirqs last enabled at (1672283): [<ffffffff81408ec0>] poll_idle+0x10/0x80 hardirqs last disabled at (1672284): [<ffffffff8151d304>] common_interrupt+0x84/0x89 softirqs last enabled at (1672286): [<ffffffff8105b4dc>] _local_bh_enable+0x1c/0x50 softirqs last disabled at (1672285): [<ffffffff8105b697>] irq_enter+0x47/0x70 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&cm_id_priv->lock)->rlock); <Interrupt> lock(&(&cm_id_priv->lock)->rlock); *** DEADLOCK *** no locks held by swapper/8/0. stack backtrace: CPU: 8 PID: 0 Comm: swapper/8 Tainted: G E 4.4.0-rc7+ #1 Hardware name: Dell Inc. PowerEdge R430/03XKDV, BIOS 1.0.2 11/17/2014 ffff88045af5e950 ffff88046e503a88 ffffffff81251c1b 0000000000000007 0000000000000006 0000000000000003 ffff88045af5ddc0 ffff88046e503ad8 ffffffff810a32f4 0000000000000000 0000000000000000 0000000000000001 Call Trace: <IRQ> [<ffffffff81251c1b>] dump_stack+0x4f/0x74 [<ffffffff810a32f4>] print_usage_bug+0x184/0x190 [<ffffffff810a36e2>] mark_lock_irq+0xf2/0x290 [<ffffffff810a3995>] mark_lock+0x115/0x1b0 [<ffffffff810a3b8c>] mark_irqflags+0x15c/0x170 [<ffffffff810a4fef>] __lock_acquire+0x1ef/0x560 [<ffffffff810a53c2>] lock_acquire+0x62/0x80 [<ffffffff8151bd33>] _raw_spin_lock_irqsave+0x43/0x60 [<ffffffffa036eec4>] cm_establish+0x74/0x1b0 [ib_cm] [<ffffffffa036f031>] ib_cm_notify+0x31/0x100 [ib_cm] [<ffffffffa0637f24>] srpt_qp_event+0x54/0xd0 [ib_srpt] [<ffffffffa0196052>] mlx4_ib_qp_event+0x72/0xc0 [mlx4_ib] [<ffffffffa00775b9>] mlx4_qp_event+0x69/0xd0 [mlx4_core] [<ffffffffa006000e>] mlx4_eq_int+0x51e/0xd50 [mlx4_core] [<ffffffffa006084f>] mlx4_msi_x_interrupt+0xf/0x20 [mlx4_core] [<ffffffff810b67b0>] handle_irq_event_percpu+0x40/0x110 [<ffffffff810b68bf>] handle_irq_event+0x3f/0x70 [<ffffffff810ba7f9>] handle_edge_irq+0x79/0x120 [<ffffffff81007f3d>] handle_irq+0x5d/0x130 [<ffffffff810071fd>] do_IRQ+0x6d/0x130 [<ffffffff8151d309>] common_interrupt+0x89/0x89 <EOI> [<ffffffff8140895f>] cpuidle_enter_state+0xcf/0x200 [<ffffffff81408aa2>] cpuidle_enter+0x12/0x20 [<ffffffff810990d6>] call_cpuidle+0x36/0x60 [<ffffffff81099163>] cpuidle_idle_call+0x63/0x110 [<ffffffff8109930a>] cpu_idle_loop+0xfa/0x130 [<ffffffff8109934e>] cpu_startup_entry+0xe/0x10 [<ffffffff8103c443>] start_secondary+0x83/0x90 Fixes: commit be4b499323bf ("IB/cm: Do not queue work to a device that's going away") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Erez Shitrit <erezsh@mellanox.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/srpt: Fix the RDMA completion handlersBart Van Assche
Avoid that the following kernel crash is triggered when processing an RDMA completion: BUG: unable to handle kernel paging request at 0000000100000198 IP: [<ffffffff810a4ea2>] __lock_acquire+0xa2/0x560 Call Trace: [<ffffffff810a53c2>] lock_acquire+0x62/0x80 [<ffffffff8151bd33>] _raw_spin_lock_irqsave+0x43/0x60 [<ffffffffa04fd437>] srpt_rdma_read_done+0x57/0x120 [ib_srpt] [<ffffffffa0144dd3>] __ib_process_cq+0x43/0xc0 [ib_core] [<ffffffffa0145115>] ib_cq_poll_work+0x25/0x70 [ib_core] [<ffffffff8107184d>] process_one_work+0x1bd/0x460 [<ffffffff81073148>] worker_thread+0x118/0x420 [<ffffffff81078454>] kthread+0xe4/0x100 [<ffffffff8151cbbf>] ret_from_fork+0x3f/0x70 Fixes: commit 59fae4deaad3 ("IB/srpt: chain RDMA READ/WRITE requests"). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19irq_poll: Fix irq_poll_sched()Bart Van Assche
The IRQ_POLL_F_SCHED bit is set as long as polling is ongoing. This means that irq_poll_sched() must proceed if this bit has not yet been set. Fixes: commit ea51190c0315 ("irq_poll: fold irq_poll_sched_prep into irq_poll_sched"). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: Fix dereference before checkMatan Barak
Sparse complains about dereference before check. Fixing this by moving the check before the dereference. Fixes: 200298326b27 ('IB/core: Validate route when we init ah') Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: Eliminate sparse false context imbalance warningMatan Barak
When write_gid function needs to do a sleep-able operation, it unlocks table->rwlock and then relocks it. Sparse complains about context imbalance. This is safe as write_gid is always called with table->rwlock. write_gid protects from simultaneous writes to this GID entry by setting the GID_TABLE_ENTRY_INVALID flag. Fixes: 9c584f049596 ('IB/core: Change per-entry lock in RoCE GID table to one lock') Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: sysfs.c: Fix PerfMgt ClassPortInfo handlingHal Rosenstock
Port number is not part of ClassPortInfo attribute but is still needed as a parameter when invoking process_mad. To properly handle this attribute, port_num is added as a parameter to get_counter_table and get_perf_mad was changed not to store port_num in the attribute itself when it's querying the ClassPortInfo attribute. This handles issue pointed out by Matan Barak <matanb@dev.mellanox.co.il> Fixes: 145d9c541032 ('IB/core: Display extended counter set if available') Signed-off-by: Hal Rosenstock <hal@mellanox.com> Acked-by: Matan Barak <matanb@mellanox.com> Acked-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/core: Remove set-but-not-used variable from ib_sg_to_pages()Bart Van Assche
Detected this by building the IB core with W=1. See also patch "IB core: Fix ib_sg_to_pages()" (commit 8f5ba10ed40a). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Sagi Grimberg <sagig@mellanox.com> Cc: Christoph Hellwig <hch@lst.de> Reviewed-by: Leon Romanovsky <leon.romanovsky@mellanox.com> Acked-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mlx5: Fix passing casted pointer in mlx5_query_port_roceLeon Romanovsky
Fix static checker warning: drivers/infiniband/hw/mlx5/main.c:149 mlx5_query_port_roce() warn: passing casted pointer '&props->qkey_viol_cntr' to 'mlx5_query_nic_vport_qkey_viol_cntr()' 32 vs 16. Fixes: 3f89a643eb29 ("IB/mlx5: Extend query_device/port to support RoCE") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mad: use CQ abstractionChristoph Hellwig
Remove the local workqueue to process mad completions and use the CQ API instead. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hal Rosenstock <hal@mellanox.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mad: pass ib_mad_send_buf explicitly to the recv_handlerChristoph Hellwig
Stop abusing wr_id and just pass the parameter explicitly. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hal Rosenstock <hal@mellanox.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19infiniband: Replace memset with eth_zero_addrLucas Tanure
Use eth_zero_addr to assign the zero address to the given address array instead of memset when second argument is address of zero. Signed-off-by: Lucas Tanure <tanure@linux.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mlx5: Delete locally redefined variableLeon Romanovsky
Fix the following sparse warning: drivers/infiniband/hw/mlx5/main.c:1061:29: warning: symbol 'pfn' shadows an earlier one drivers/infiniband/hw/mlx5/main.c:1030:21: originally declared here Fixes: d69e3bcf7976 ('IB/mlx5: Mmap the HCA's core clock register to user-space') Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19net/mlx4: Remove unused macroMoni Shoua
The macro mlx4_foreach_non_ib_transport_port() is not used anywhere. Remove it. Fixes: aa9a2d51a3e7 ("mlx4: Activate RoCE/SRIOV") Signed-off-by: Moni Shoua <monis@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mlx4: Take source mac from AH instead from the portMoni Shoua
In commit dbf727de7440 ("IB/core: Use GID table in AH creation and dmac resolution") we copy source mac to mlx4_ah from the attributes of gid at ib_ah_attr.grh.sgid_index. Now we can use it. Signed-off-by: Moni Shoua <monis@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mlx4: Initialize hop_limit when creating address handleMatan Barak
Hop limit value wasn't copied from attributes when ah was created. This may influence packets for unconnected services to get dropped in routers when endpoints are not in the same subnet. Fixes: fa417f7b520e ("IB/mlx4: Add support for IBoE") Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/mlx5: Expose correct maximum number of CQE capacityLeon Romanovsky
Maximum number of EQE capacity per CQ was mistakenly exposed as CQE. Fix that. Fixes: 938fe83c8dcb ("net/mlx5_core: New device capabilities handling") Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Cc: <stable@vger.kernel.org> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19iw_cxgb4: Take clip reference before starting IPv6 listenHariprasad S
The h/w is designed in such a way that, if you do anything IPv6 related, a valid clip entry must be there. So take clip reference before creating IPv6 listening servers, and then if we fail to create server, release the clip entry. Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19iw_cxgb4: Fixes GW-Basic labels to meaningful error namesHariprasad S
Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19iw_cxgb4: Fixes static checker warning in c4iw_rdev_open()Hariprasad S
Commit c5dfb000b904 ("iw_cxgb4: Pass qid range to user space driver") from Dec 11, 2015, leads to the following static checker warning: drivers/infiniband/hw/cxgb4/device.c:857 c4iw_rdev_open() warn: variable dereferenced before check 'rdev->status_page' Also we weren't deallocating ocqp pool in error path when failed to allocate status page. Fixing it too. Fixes: c5dfb000b904 ("iw_cxgb4: Pass qid range to user space driver") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/cma: allocating too much memory in make_cma_ports()Dan Carpenter
The issue here is that there is a cut and paste bug. When we allocate cma_dev_group->default_ports_group we use "sizeof(*cma_dev_group->ports)" instead of "sizeof(*cma_dev_group->default_ports_group)". We're bumping up against the 80 character limit so I introduced a new local pointer "ports_group" to get around that. Fixes: 045959db65c6 ('IB/cma: Add configfs for rdma_cm') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19RDMA/nes: checking for NULL instead of IS_ERRDan Carpenter
nes_reg_phys_mr() returns ERR_PTRs on error. It doesn't return NULL. This bug has been there for a while, but we recently changed from calling a function pointer to calling nes_reg_phys_mr() directly so now Smatch is able to detect the bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/qib: Support creating qps with GFP_NOIO flagVinit Agnihotri
The current code is problematic when the QP creation and ipoib is used to support NFS and NFS desires to do IO for paging purposes. In that case, the GFP_KERNEL allocation in qib_qp.c causes a deadlock in tight memory situations. This fix adds support to create queue pair with GFP_NOIO flag for connected mode only to cleanly fail the create queue pair in those situations. Cc: <stable@vger.kernel.org> # 3.16+ Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Vinit Agnihotri <vinit.abhay.agnihotri@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/sysfs: Fix sparse warning on attr_idIra Weiny
Attributed ID was declared as an int while the value should really be big endian 16. Fixes: 35c4cbb17811 ("IB/core: Create get_perf_mad function in sysfs.c") Reported-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Lameter <cl@linux.com> Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19RDMA/be2net: Remove open and close entry pointsDevesh Sharma
Recently Dough Ledford reported a deadlock happening between ocrdma-load sequence and NetworkManager service issueing "open" on be2net interface. The deadlock happens when any be2net hook (e.g. open/close) is called in parallel to insmod ocrdma.ko. A. be2net is sending administrative open/close event to ocrdma holding device_list_mutex. It does this from ndo_open/ndo_stop hooks of be2net. So sequence of locks is rtnl_lock---> device_list lock B. When new ocrdma roce device gets registered, infiniband stack now takes rtnl_lock in ib_register_device() in GID initialization routines. So sequence of locks in this path is device_list lock ---> rtnl_lock. This improper locking sequence causes deadlock. In order to resolve the above deadlock condition, ocrdma intorduced a patch to stop listening to administrative open/close events generated from be2net driver. It now depends on link-state-change async-event generated from CNA. This change leaves behind dead code which used to generate administrative open/close events. This patch cleans-up all that dead code from be2net. Reported-by: Doug Ledford <dledford@redhat.com> CC: Sathya Perla <sathya.perla@avagotech.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@avagotech.com> Signed-off-by: Selvin Xavier <selvin.xavier@avagotech.com> Signed-off-by: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19RDMA/ocrdma: Depend on async link events from CNADevesh Sharma
Recently Dough Ledford reported a deadlock happening between ocrdma-load sequence and NetworkManager service issuing "open" on be2net interface. The deadlock happens when any be2net hook (e.g. open/close) is called in parallel to insmod ocrdma.ko. A. be2net is sending administrative open/close event to ocrdma holding device_list_mutex. It does this from ndo_open/ndo_stop hooks of be2net. So sequence of locks is rtnl_lock---> device_list lock B. When new ocrdma roce device gets registered, infiniband stack now takes rtnl_lock in ib_register_device() in GID initialization routines. So sequence of locks in this path is device_list lock ---> rtnl_lock. This improper locking sequence causes deadlock. With this patch we stop using administrative open and close events injected by be2net driver. These events were used to dispatch PORT_ACTIVE and PORT_ERROR events to the IB-stack. This patch implements a logic to receive async-link-events generated from CNA whenever link-state-change is detected. Now on, these async-events will be used to dispatch PORT_ACTIVE and PORT_ERROR events to IB-stack. Depending on async-events from CNA removes the need to hold device-list-mutex and thus breaks the busy-wait scenario. Reported-by: Doug Ledford <dledford@redhat.com> CC: Sathya Perla <sathya.perla@avagotech.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@avagotech.com> Signed-off-by: Selvin Xavier <selvin.xavier@avagotech.com> Signed-off-by: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19RDMA/ocrdma: Dispatch only port event when port state changesDevesh Sharma
Dispatch only port event to IB stack when port state changes. Don't explicitly modify qps to error. Let application listen to port events on async event queue or let QP fail with retry-exceeded completion error. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@avagotech.com> Signed-off-by: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19RDMA/ocrdma: Fix vlan-id assignment in qp parametersDevesh Sharma
vlan-id is wrongly getting as 0 when PFC is enabled. Set vlan-id configured by user in QP parameters. In case vlan interface is not used, flash a warning to user to configure vlan and assign vlan-id as 0 in qp params. Fixes: dbf727de7440 ('IB/core: Use GID table in AH creation and dmac resolution') Cc: Matan Barak <matanb@mellanox.com> Signed-off-by: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/cma: Fix RDMA port validation for iWarpMatan Barak
cma_validate_port wrongly assumed that Ethernet devices are RoCE devices and thus their ndev should be matched in the GID table. This broke the iWarp support. Fixing that matching the ndev only if we work on a RoCE port. Cc: <stable@vger.kernel.org> # 4.4.x- Fixes: abae1b71dd37 ('IB/cma: cma_validate_port should verify the port and netdevice') Reported-by: Hariprasad Shenai <hariprasad@chelsio.com> Tested-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/qib: fix mcast detach when qp not attachedMike Marciniszyn
The code produces the following trace: [1750924.419007] general protection fault: 0000 [#3] SMP [1750924.420364] Modules linked in: nfnetlink autofs4 rpcsec_gss_krb5 nfsv4 dcdbas rfcomm bnep bluetooth nfsd auth_rpcgss nfs_acl dm_multipath nfs lockd scsi_dh sunrpc fscache radeon ttm drm_kms_helper drm serio_raw parport_pc ppdev i2c_algo_bit lpc_ich ipmi_si ib_mthca ib_qib dca lp parport ib_ipoib mac_hid ib_cm i3000_edac ib_sa ib_uverbs edac_core ib_umad ib_mad ib_core ib_addr tg3 ptp dm_mirror dm_region_hash dm_log psmouse pps_core [1750924.420364] CPU: 1 PID: 8401 Comm: python Tainted: G D 3.13.0-39-generic #66-Ubuntu [1750924.420364] Hardware name: Dell Computer Corporation PowerEdge 860/0XM089, BIOS A04 07/24/2007 [1750924.420364] task: ffff8800366a9800 ti: ffff88007af1c000 task.ti: ffff88007af1c000 [1750924.420364] RIP: 0010:[<ffffffffa0131d51>] [<ffffffffa0131d51>] qib_mcast_qp_free+0x11/0x50 [ib_qib] [1750924.420364] RSP: 0018:ffff88007af1dd70 EFLAGS: 00010246 [1750924.420364] RAX: 0000000000000001 RBX: ffff88007b822688 RCX: 000000000000000f [1750924.420364] RDX: ffff88007b822688 RSI: ffff8800366c15a0 RDI: 6764697200000000 [1750924.420364] RBP: ffff88007af1dd78 R08: 0000000000000001 R09: 0000000000000000 [1750924.420364] R10: 0000000000000011 R11: 0000000000000246 R12: ffff88007baa1d98 [1750924.420364] R13: ffff88003ecab000 R14: ffff88007b822660 R15: 0000000000000000 [1750924.420364] FS: 00007ffff7fd8740(0000) GS:ffff88007fc80000(0000) knlGS:0000000000000000 [1750924.420364] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [1750924.420364] CR2: 00007ffff597c750 CR3: 000000006860b000 CR4: 00000000000007e0 [1750924.420364] Stack: [1750924.420364] ffff88007b822688 ffff88007af1ddf0 ffffffffa0132429 000000007af1de20 [1750924.420364] ffff88007baa1dc8 ffff88007baa0000 ffff88007af1de70 ffffffffa00cb313 [1750924.420364] 00007fffffffde88 0000000000000000 0000000000000008 ffff88003ecab000 [1750924.420364] Call Trace: [1750924.420364] [<ffffffffa0132429>] qib_multicast_detach+0x1e9/0x350 [ib_qib] [1750924.568035] [<ffffffffa00cb313>] ? ib_uverbs_modify_qp+0x323/0x3d0 [ib_uverbs] [1750924.568035] [<ffffffffa0092d61>] ib_detach_mcast+0x31/0x50 [ib_core] [1750924.568035] [<ffffffffa00cc213>] ib_uverbs_detach_mcast+0x93/0x170 [ib_uverbs] [1750924.568035] [<ffffffffa00c61f6>] ib_uverbs_write+0xc6/0x2c0 [ib_uverbs] [1750924.568035] [<ffffffff81312e68>] ? apparmor_file_permission+0x18/0x20 [1750924.568035] [<ffffffff812d4cd3>] ? security_file_permission+0x23/0xa0 [1750924.568035] [<ffffffff811bd214>] vfs_write+0xb4/0x1f0 [1750924.568035] [<ffffffff811bdc49>] SyS_write+0x49/0xa0 [1750924.568035] [<ffffffff8172f7ed>] system_call_fastpath+0x1a/0x1f [1750924.568035] Code: 66 2e 0f 1f 84 00 00 00 00 00 31 c0 5d c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 8b 7f 10 <f0> ff 8f 40 01 00 00 74 0e 48 89 df e8 8e f8 06 e1 5b 5d c3 0f [1750924.568035] RIP [<ffffffffa0131d51>] qib_mcast_qp_free+0x11/0x50 [ib_qib] [1750924.568035] RSP <ffff88007af1dd70> [1750924.650439] ---[ end trace 73d5d4b3f8ad4851 ] The fix is to note the qib_mcast_qp that was found. If none is found, then return EINVAL indicating the error. Cc: <stable@vger.kernel.org> Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-01-19IB/IPoIB: Fix kernel panic on multicast flowErez Shitrit
ipoib_mcast_restart_task calls ipoib_mcast_remove_list with the parameter mcast->dev. That mcast is a temporary (used as an iterator) variable that may be uninitialized. There is no need to send the variable dev to the function, as each mcast has its dev as a member in the mcast struct. This causes the next panic: RIP: 0010: ipoib_mcast_leave+0x6d/0xf0 [ib_ipoib] RSP: 0018: EFLAGS: 00010246 RAX: f0201 RBX: 24e00 RCX: 00000 .... .... Stack: Call Trace: ipoib_mcast_remove_list+0x3a/0x70 [ib_ipoib] ipoib_mcast_restart_task+0x3bb/0x520 [ib_ipoib] process_one_work+0x164/0x470 worker_thread+0x11d/0x420 ... Fixes: 5a0e81f6f483 ('IB/IPoIB: factor out common multicast list removal code') Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Reported-by: Doron Tsur <doront@mellanox.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-26IB/iser: Support the remote invalidation exceptionJenny Derzhavetz
Declare that we support remote invalidation in case we are: 1. using fastreg method 2. always registering memory Detect the invalidated rkey from the work completion info so we won't invalidate it locally. The spec mandates that we must not rely on the target remote invalidate our rkey so we must check it upon a receive (scsi response) completion. Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: Change the increment rkey flow logicSagi Grimberg
When we enable remote invalidate support we won't want to perform local invalidates at the same time we do today, but we still need to get new rkeys. So, decouple the rkey update from the local invalidate and tie it to memory reg instead. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/isert: Support the remote invalidation exceptionJenny Derzhavetz
We'll use remote invalidate, according to negotiation result during connection establishment. If the initiator declared that it supports the remote invalidate exception and the local HCA supports IB_DEVICE_MEM_MGT_EXTENSIONS then the target will use IB_WR_SEND_WITH_INV with the correct rkey for the response. Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/isert: Declare correct flags when accepting a connectionJenny Derzhavetz
iser target does not support zero based virtual addresses and send with invalidate, so it should declare that it doesn't. Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/isert: Remove unused file iser_proto.hSagi Grimberg
We don't need iser_proto.h anymore, remove it and move (non-protocol) declarations to ib_isert.h Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser,isert: Create and use new shared headerSagi Grimberg
The iser RDMA_CM negotiation protocol is shared by the initiator and the target, so have a shared header for the defines and structure. Move relevant items from the initiator and target headers. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: set intuitive values for mr_validJenny Derzhavetz
This parameter is described as "is mr valid indicator". In other words, it indicates whether memory registration is valid or not. So intuitive values would be: mr_valid=True, when memory registration is valid and mr_valid=False otherwise. Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: Don't register memory for all immediate data writesJenny Derzhavetz
When all the task data is sent as immediate data, we are allowed to use the local_dma_lkey as it is not sent to the wire. Signed-off-by: Jenny Derzhavetz <jennyf@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: Reuse ib_sg_to_pagesSagi Grimberg
We have in iser iser_sg_to_page_vec which has exactly the same role as ib_sg_to_pages. Customize the page_vec to hold a fake MR so we can reuse ib_sg_to_pages. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: Fix module init not cleaning up on error flowRoi Dayan
Destroy workqueue on transport register error, also release kmem cache on workqueue allocation error. Signed-off-by: Roi Dayan <roid@mellanox.com> Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/core: constify mmu_notifier_ops structuresJulia Lawall
This mmu_notifier_ops structure is never modified, so declare it as const, like the other mmu_notifier_ops structures. Done with the help of Coccinelle. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reviewed-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/iser: constify iser_reg_ops structureJulia Lawall
The iser_reg_ops structures are never modified, so declare them as const. Done with the help of Coccinelle. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24RDMA/nes: constify nes_cm_ops structureJulia Lawall
The nes_cm_ops structure is never modified, so declare it as const. Done with the help of Coccinelle. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/mlx5: report tx/rx checksum cap in query resultsBodong Wang
This patch will report the tx/rx checksum cap for raw qp via the query device results. Signed-off-by: Bodong Wang <bodong@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/mlx4: Convert kmalloc to kmalloc_array for checkpatchLeon Romanovsky
Convert kmalloc to be kmalloc_array to fix warnings below: WARNING: Prefer kmalloc_array over kmalloc with multiply + qp->sq.wrid = kmalloc(qp->sq.wqe_cnt * sizeof(u64), WARNING: Prefer kmalloc_array over kmalloc with multiply + qp->rq.wrid = kmalloc(qp->rq.wqe_cnt * sizeof(u64), WARNING: Prefer kmalloc_array over kmalloc with multiply + srq->wrid = kmalloc(srq->msrq.max * sizeof(u64), Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-24IB/mlx4: Suppress non-fatal memory allocationsLeon Romanovsky
Failure in kmalloc memory allocations will throw a warning about it. Such warnings are not needed anymore, since in commit 0ef2f05c7e02 ("IB/mlx4: Use vmalloc for WR buffers when needed"), fallback mechanism from kmalloc() to __vmalloc() was added. Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
