2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-17ipv4: Don't use enums as bitmasks in ip_fragment.cDavid S. Miller
Noticed by Joe Perches. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17net: ethtool: fix IPV6 checksum feature name stringMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17net: Change netdev_fix_features messages loglevelMichael S. Tsirkin
Cool, how about we make 'Features changed' debug as well? This way userspace can't fill up the log just by tweaking tun features with an ioctl. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17net: recvmmsg: Strip MSG_WAITFORONE when calling recvmsgAnton Blanchard
recvmmsg fails on a raw socket with EINVAL. The reason for this is packet_recvmsg checks the incoming flags: err = -EINVAL; if (flags & ~(MSG_PEEK|MSG_DONTWAIT|MSG_TRUNC|MSG_CMSG_COMPAT|MSG_ERRQUEUE)) goto out; This patch strips out MSG_WAITFORONE when calling recvmmsg which fixes the issue. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@kernel.org [2.6.34+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17xen: netback: use __CONST_RING_SIZE not __RING_SIZEIan Campbell
The later causes warnings with gcc 4.5+. __CONST_RING_SIZE was introduced in 667c78afaec0 to fix this but as netback wasn't upstream at the time it did not benefit, hence: CC drivers/net/xen-netback/netback.o drivers/net/xen-netback/netback.c:110:37: warning: variably modified 'grant_copy_op' at file scope [enabled by default] drivers/net/xen-netback/netback.c:111:30: warning: variably modified 'meta' at file scope [enabled by default] drivers/net/xen-netback/netback.c: In function 'xen_netbk_rx_action': drivers/net/xen-netback/netback.c:584:6: warning: variable 'irq' set but not used [-Wunused-but-set-variable] Thanks to Witold Baryluk for pointing this out. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next-2.6
2011-05-17net: ping: fix build failureVasiliy Kulikov
If CONFIG_PROC_SYSCTL=n the building process fails: ping.c:(.text+0x52af3): undefined reference to `inet_get_ping_group_range_net' Moved inet_get_ping_group_range_net() to ping.c. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17net: use hlist_del_rcu() in dev_change_name()Eric Dumazet
Using plain hlist_del() in dev_change_name() is wrong since a concurrent reader can crash trying to dereference LIST_POISON1. Bug introduced in commit 72c9528bab94 (net: Introduce dev_get_by_name_rcu()) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16bluetooth: Fix warnings in l2cap_core.cDavid S. Miller
net/bluetooth/l2cap_core.c: In function ‘l2cap_recv_frame’: net/bluetooth/l2cap_core.c:3758:15: warning: ‘sk’ may be used uninitialized in this function net/bluetooth/l2cap_core.c:3758:15: note: ‘sk’ was declared here net/bluetooth/l2cap_core.c:3791:15: warning: ‘sk’ may be used uninitialized in this function net/bluetooth/l2cap_core.c:3791:15: note: ‘sk’ was declared here Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-05-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-tx.c net/mac80211/sta_info.h
2011-05-16sfc: Use netif_device_{detach,attach}() around reset and self-testBen Hutchings
We need to keep the TX queues stopped throughout a reset, without triggering the TX watchdog and regardless of the link state. The proper way to do this is to use netif_device_{detach,attach}() just as we do around suspend/resume, rather than the current bodge of faking link-down. Since we also need to do this during an offline self-test and we perform a reset during that, add these function calls outside of efx_reset_down() and efx_reset_up(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-05-16net: Change netdev_fix_features messages loglevelMichał Mirosław
Those reduced to DEBUG can possibly be triggered by unprivileged processes and are nothing exceptional. Illegal checksum combinations can only be caused by driver bug, so promote those messages to WARN. Since GSO without SG will now only cause DEBUG message from netdev_fix_features(), remove the workaround from register_netdevice(). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16vmxnet3: Fix inconsistent LRO state after initializationThomas Jarosch
During initialization of vmxnet3, the state of LRO gets out of sync with netdev->features. This leads to very poor TCP performance in a IP forwarding setup and is hitting many VMware users. Simplified call sequence: 1. vmxnet3_declare_features() initializes "adapter->lro" to true. 2. The kernel automatically disables LRO if IP forwarding is enabled, so vmxnet3_set_flags() gets called. This also updates netdev->features. 3. Now vmxnet3_setup_driver_shared() is called. "adapter->lro" is still set to true and LRO gets enabled again, even though netdev->features shows it's disabled. Fix it by updating "adapter->lro", too. The private vmxnet3 adapter flags are scheduled for removal in net-next, see commit a0d2730c9571aeba793cb5d3009094ee1d8fda35 "net: vmxnet3: convert to hw_features". Patch applies to 2.6.37 / 2.6.38 and 2.6.39-rc6. Please CC: comments. Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Fix oops in register dump after mapping changeBen Hutchings
Commit 747df2258b1b9a2e25929ef496262c339c380009 ('sfc: Always map MCDI shared memory as uncacheable') introduced a separate mapping for the MCDI shared memory (MC_TREG_SMEM). This means we can no longer easily include it in the register dump. Since it is not particularly useful in debugging, substitute a recognisable dummy value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16net: convert to new cpumask APIKOSAKI Motohiro
We plan to remove cpu_xx() old api later. Thus this patch convert it. This patch has no functional change. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16ipv4: more compliant RFC 3168 supportEric Dumazet
Commit 6623e3b24a5e (ipv4: IP defragmentation must be ECN aware) was an attempt to not lose "Congestion Experienced" (CE) indications when performing datagram defragmentation. Stefanos Harhalakis raised the point that RFC 3168 requirements were not completely met by this commit. In particular, we MUST detect invalid combinations and eventually drop illegal frames. Reported-by: Stefanos Harhalakis <v13@v13.gr> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: FW download for LancerShripad Nunjundarao
Added implementation of FW download feature for Lancer. Signed-off-by: Shripad Nunjundarao <shripad.nunjundarao@emulex.com> Signed-off-by: Sevin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Stats for LancerSelvin Xavier
Added Lancer stats implementation. Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16be2net: Support for version 1 of stats for BE3Ajit Khaparde
Added support to get version 1 of the stats for BE3. Use old stats command for BE2. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16mwifiex: use ieee80211_amsdu_to_8023s routineYogesh Ashok Powar
mwifiex was using its own implementation of converting 802.11n AMSDU to 802.3s. This patch removes mwifiex specific implementation and uses existing ieee80211_amsdu_to_8023s routine. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16cfg80211: make stripping of 802.11 header optional from AMSDUYogesh Ashok Powar
Currently the devices that have already stripped IEEE 802.11 header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s routine. This patch enhances ieee80211_amsdu_to_8023s() API by changing mandatory removing of IEEE 802.11 header from AMSDU to optional. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16nl80211: Move peer link state definition to nl80211Javier Cardona
These definitions need to be exposed now that we can set the peer link states via NL80211_ATTR_STA_PLINK_STATE. They were already being (opaquely) reported by NL80211_STA_INFO_PLINK_STATE. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: make npending frames check as boolMohammed Shafi Shajakhan
we are not doing anything by tracking the number of pending frames. bail out when we first find a pending frame in any one of the 10 queues. Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: make sure main_rssi is positiveMohammed Shafi Shajakhan
some times the rssi control descriptor for the main antenna may be negative like that of alternate antenna, hence before incrementing packet counts/rssi of main/alternate antenna make sure both main_rssi and alt_rssi are positive only. this avoids wrong selection of antenna due to diversity Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: configure fast_div_bias based on diversity groupMohammed Shafi Shajakhan
configure fast diversity bias based on the antenna diversity group and based on main/alt LNA configurations. also configure main antenna and alternate antenna to gain-table 0 for diversity group 2(AR9485) Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: Implement an API to swap main/ALT LNA'sMohammed Shafi Shajakhan
for the diversity group 2(AR9485) we swap the LNA's of main/ALT antenna based on alternate antenna's rssi average in comparision with main antenna's rssi, while for AR9285(antenna diversity group 0)we still follow the older method of looking at the packet count in alternate antenna Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define antenna diversity groupMohammed Shafi Shajakhan
AR9285 belongs to diversity group 0 and AR9485 belongs to diversity group 2. Based on the diversity group we configure certain antenna diversity paramaters such as lna1_lna2_delta and fast diversity bias values. For AR9485 we have some gain table parameter which selects the gain table 0/1 for main and alternate antenna Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define modules to get/set Antenna diversity paramatersMohammed Shafi Shajakhan
these are the two important modules that will be called by the antenna diversity algorithm module in the rx. this will continuosly configure the hardware based on the current diversity status obtained from the algorithm Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: config diversity based on eeprom contentsMohammed Shafi Shajakhan
* enable LNA-diversity, fast-diversity for AR9485 based on the value read from EEPROM content * if antenna diversity/combining is supported, set LNA1 for the main antenna and LNA2 for the alternate antenna based on the new diversity algorithm Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Cc: Luis Rodriguez <Luis.Rodriguez@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define registers/macros to support Antenna diversityMohammed Shafi Shajakhan
define few registers and macros to configure/enable Antenna diversity parameters in AR9485 Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: enable Antenna diversity for AR9485Mohammed Shafi Shajakhan
read antenna diversity and combining information from the EEPROM. Enable antenna diversity/combining feature only when both LNA diversity and fast diversity are supported Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Tested-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: make antenna diversity modules chip specificMohammed Shafi Shajakhan
this is necessary to support Antenna diversity and combining in new chip sets such as AR9485, previously Antenna diversity support is available only in AR9285 Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16net/rfkill/core.c: Avoid leaving freed data in a listJulia Lawall
The list_for_each_entry loop can fail, in which case the list element is not removed from the list rfkill_fds. Since this list is not accessed by the loop, the addition of &data->list into the list is just moved after the loop. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E1,E2; identifier l; @@ *list_add(&E->l,E1); ... when != E1 when != list_del(&E->l) when != list_del_init(&E->l) when != E = E2 *kfree(E);// </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16mac80211: sparse RCU annotationsJohannes Berg
This adds sparse RCU annotations to most of mac80211, only the mesh code remains to be done. Due the the previous patches, the annotations are pretty simple. The only thing that this actually changes is removing the RCU usage of key->sta in debugfs since this pointer isn't actually an RCU-managed pointer (it only has a single assignment done before the key even goes live). As that is otherwise harmless, I decided to make it part of this patch. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16mac80211: fix TX a-MPDU lockingJohannes Berg
During my quest to make mac80211 not have any RCU warnings from sparse, I came across the a-MPDU code again and it wasn't quite clear why it isn't racy. So instead of assigning the tid_tx array with just the spinlock held in ieee80211_start_tx_ba_session use a separate temporary array protected only by the spinlock and protect all assignments to the "live" array by both the spinlock and the mutex so that other code is easily verified to be correct. Due to pointer assignment atomicity I don't think this is a real issue, but I'm not sure, especially on Alpha the current code might be problematic. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16cfg80211: advertise possible interface combinationsJohannes Berg
Add the ability to advertise interface combinations in nl80211. This allows the driver to indicate what the combinations are that it supports. "Combinations" of just a single interface are implicit, as previously. Note that cfg80211 will enforce that the restrictions are met, but not for all drivers yet (once all drivers are updated, we can remove the flag and enforce for all). When no combinations are actually supported, an empty list will be exported so that userspace can know if the kernel exported this info or not (although it isn't clear to me what tools using the info should do if the kernel didn't export it). Since some interface types are purely virtual/software and don't fit the restrictions, those are exposed in a new list of pure SW types, not subject to restrictions. This mainly exists to handle AP-VLAN and monitor interfaces in mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16iwlwifi: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/net/checksum.h:25, from include/linux/skbuff.h:28, from drivers/net/wireless/iwlwifi/iwl-agn-rs.c:28: In function 'copy_from_user', inlined from 'rs_sta_dbgfs_scale_table_write' at drivers/net/wireless/iwlwifi/iwl-agn-rs.c:3099: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16iwlegacy: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/net/checksum.h:25, from include/linux/skbuff.h:28, from drivers/net/wireless/iwlegacy/iwl-4965-rs.c:28: In function 'copy_from_user', inlined from 'iwl4965_rs_sta_dbgfs_scale_table_write' at drivers/net/wireless/iwlegacy/iwl-4965-rs.c:2616: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16bnx2x: Allow ethtool to enable/disable loopback.Mahesh Bandewar
This patch updates the bnx2x_set_features() to handle loopback mode. When enabled; it sets internal-MAC loopback. Signed-off-by: Mahesh Bandewar <maheshb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16ipv4: Trivial rt->rt_src conversions in net/ipv4/route.cDavid S. Miller
At these points we have a fully filled in value via the IP header the form of ip_hdr(skb)->saddr Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Fix TX queue numbering when separate_tx_channels=1Ben Hutchings
This option appears to have been broken by commit 8313aca38b3937947fffebca6e34bac8e24300c8 ('sfc: Allocate each channel separately, along with its RX and TX queues'). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-05-16net: ping: dont call udp_ioctl()Eric Dumazet
udp_ioctl() really handles UDP and UDPLite protocols. 1) It can increment UDP_MIB_INERRORS in case first_packet_length() finds a frame with bad checksum. 2) It has a dependency on sizeof(struct udphdr), not applicable to ICMP/PING If ping sockets need to handle SIOCINQ/SIOCOUTQ ioctl, this should be done differently. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16netfilter: nf_ct_sip: fix SDP parsing in TCP SIP messages for some Cisco phonesPatrick McHardy
Some Cisco phones do not place the Content-Length field at the end of the SIP message. This is valid, due to a misunderstanding of the specification the parser expects the SDP body to start directly after the Content-Length field. Fix the parser to scan for \r\n\r\n to locate the beginning of the SDP body. Reported-by: Teresa Kang <teresa_kang@gemtek.com.tw> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-16netfilter: nf_ct_sip: validate Content-Length in TCP SIP messagesPatrick McHardy
Verify that the message length of a single SIP message, which is calculated based on the Content-Length field contained in the SIP message, does not exceed the packet boundaries. Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-15Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-15net: drivers: kill two unused macro definitionsShan Wei
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: remove unesesarry exportssjur.brandeland@stericsson.com
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
