2008-04-29Blackfin EMAC Driver: Initial version of ethtool supportBryan Wu
Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29Blackfin EMAC Driver: code cleanupBryan Wu
- replace specific "bf537" function or data structure name to "bfin_mac" - cleanup bfin_mac_probe with error checking - punt set_pin_mux function, call peripheral request/free list functions directly Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29net: eepro autoport typoHarvey Harrison
Found by sparse dubious !x & y warning...hidden in the GetBit macro why !Word doesn't make any sense. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29Add support for SMSC LAN8187 and LAN8700 PHYsSteve Glendinning
Add support for two additional SMSC PHY models with identical interrupt source and mask registers to the LAN83C185 Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29Rename SMSC phy functions to be more genericSteve Glendinning
Several models of SMSC PHY have the same interrupt status and mask registers as the LAN83C185, so these functions can service multiple different PHY drivers. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29drivers/net/phy: fix kernel-doc notationRandy Dunlap
Fix kernel-doc warning: Warning(linux-2.6.25-git11//drivers/net/phy/phy_device.c:275): No description found for parameter 'bus_id' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29S2io: Version update for multi ring patchesSreenivasa Honnur
- Updated version number. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29S2io: Enable multi ring supportSreenivasa Honnur
- Seperate ring specific data - Initialize all configured rings with equal priority. - Updated boundary check for number of Rings. - Updated per ring statistics of rx_bytes and rx_packets. - Moved lro struct from struct s2io_nic to struct ring_info. - Access respective rx ring directly in fill_rx_buffers. - Moved rx_bufs_left struct s2io_nic to struct ring_info. - Added per ring variables - rxd_mode, rxd_count, dev, pdev. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-293c515: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-293c509: use netstats in net_device structurePaulius Zaleckas
2008-04-293c505: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. No need to memset it to 0, because it is allocated by kzalloc. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29Merge branch 'upstream-jeff' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/romieu/netdev-2.6 into upstream
2008-04-29Merge branch 'sis190' of ↵Jeff Garzik
2008-04-29New driver "sfc" for Solarstorm SFC4000 controller.Ben Hutchings
The driver supports the 10Xpress PHY and XFP modules on our reference designs SFE4001 and SFE4002 and the SMC models SMC10GPCIe-XFP and SMC10GPCIe-10BT. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-27iwlwifi: Allow building iwl3945 without iwl4965.Jason Riedy
If IWL3945 ever depends on IWLCORE, the silent, user-invisible IWLWIFI option can go away. Signed-off-by: Jason Riedy <jason@acm.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27wireless: Fix compile error with wifi & ledsLuca Tettamanti
Fix build error caused by commit e82404ad612ebabc65d15c3d59b971cb35c3ff36 ("iwlwifi: Select LEDS_CLASS.") from David Miller: Since MAC80211_LEDS is selected by wireless drivers it must select its own dependencies otherwise a build error may occur (kbuild will select the symbol regardless of "depends" constraints). Signed-off-By: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27tcp: Fix slab corruption with ipv6 and tcp6fuzzEvgeniy Polyakov
From: Evgeniy Polyakov <johnpol@2ka.mipt.ru> This fixes a regression added by ec3c0982a2dd1e671bad8e9d26c28dcba0039d87 ("[TCP]: TCP_DEFER_ACCEPT updates - process as established") tcp_v6_do_rcv()->tcp_rcv_established(), the latter goes to step5, where eventually skb can be freed via tcp_data_queue() (drop: label), then if check for tcp_defer_accept_check() returns true and thus tcp_rcv_established() returns -1, which forces tcp_v6_do_rcv() to jump to reset: label, which in turn will pass through discard: label and free the same skb again. Tested by Eric Sesterhenn. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-By: Patrick McManus <mcmanus@ducksong.com>
2008-04-27ipv4/ipv6 compat: Fix SSM applications on 64bit kernels.David L Stevens
Add support on 64-bit kernels for seting 32-bit compatible MCAST* socket options. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27[IPSEC]: Use digest_null directly for authHerbert Xu
Previously digest_null had no setkey function which meant that we used hmac(digest_null) for IPsec since IPsec always calls setkey. Now that digest_null has a setkey we no longer need to do that. In fact when only confidentiality is specified for ESP we already use digest_null directly. However, when the null algorithm is explicitly specified by the user we still opt for hmac(digest_null). This patch removes this discrepancy. I have not added a new compat name for it because by chance it wasn't actualy possible for the user to specify the name hmac(digest_null) due to a key length check in xfrm_user (which I found out when testing that compat name :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sunrpc: fix missing kernel-docRandy Dunlap
Fix missing sunrpc kernel-doc: Warning(linux-2.6.25-git7//net/sunrpc/xprt.c:451): No description found for parameter 'action' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27can: Fix copy_from_user() results interpretationSam Ravnborg
Both copy_to_ and _from_user return the number of bytes, that failed to reach their destination, not the 0/-EXXX values. Based on patch from Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Revert "ipv6: Fix typo in net/ipv6/Kconfig"David S. Miller
This reverts commit 5b3f129c5592ca35b3fe8916767c58b98710478c. As requested by Maciej W. Rozycki. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27tipc: endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27ipv6: result of csum_fold() is already 16bit, no need to castAl Viro
2008-04-27[XFRM] AUDIT: Fix flowlabel text format ambibuity.YOSHIFUJI Hideaki
Flowlabel text format was not correct and thus ambiguous. For example, 0x00123 or 0x01203 are formatted as 0x123. This is not what audit tools want. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sis190: account for Tx errorsFrancois Romieu
Update the collision counter as well. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: remove needless MII resetFrancois Romieu
It does not help the auto-negotiation process to settle. Added a debug message to give some hindsight when things do not work as expected. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: Rx path updateFrancois Romieu
- remove the function pointer to help gcc optimizing the inline pci_dma functions - pci_dma_sync_single_for_cpu is not needed for a single large packet - convert rtl8169_try_rx_copy to bool b449655ff52ff8a29c66c5fc3fc03617e61182ee did the same for the r8169 driver. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: use netdev_alloc_skbStephen Hemminger
This sets skb->dev and allows arch specific allocation. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: hard-code the alignment of tiny packetsStephen Hemminger
There is no DMA involved here. Align the IP header without condition. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-27sis190: use the allocated buffer as a status code in sis190_alloc_rx_skbStephen Hemminger
The local status code does not carry mory information. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com>
2008-04-25net: Fix wrong interpretation of some copy_to_user() results.Pavel Emelyanov
I found some places, that erroneously return the value obtained from the copy_to_user() call: if some amount of bytes were not able to get to the user (this is what this one returns) the proper behavior is to return the -EFAULT error, not that number itself. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25Merge branch 'upstream-davem' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-04-25xfrm: alg_key_len & alg_icv_len should be unsignedEric Dumazet
In commit ba749ae98d5aa9d2ce9a7facde0deed454f92230 ([XFRM]: alg_key_len should be unsigned to avoid integer divides <http://git2.kernel.org/?p=linux/kernel/git/davem/net-2.6.git;a=commitdiff;h=ba749ae98d5aa9d2ce9a7facde0deed454f92230>) alg_key_len field of struct xfrm_algo was converted to unsigned int to avoid integer divides. Then Herbert in commit 1a6509d991225ad210de54c63314fd9542922095 ([IPSEC]: Add support for combined mode algorithms) added a new structure xfrm_algo_aead, that resurrected a signed int for alg_key_len and re-introduce integer divides. This patch avoids these divides and saves 64 bytes of text on i386. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25[netdrvr] tehuti: move ioctl perm check closer to function startJeff Garzik
Noticed by davem. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-24ipv6: Fix typo in net/ipv6/KconfigMichael Beasley
Two is used in the wrong context here, as you are connecting to an IPv6 network over IPv4; not connecting two IPv6 networks to an IPv4 one. Signed-off-by: Michael Beasley <youvegotmoxie@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25via-velocity: fix vlan receiptFrancois Romieu
- vlans were using a single CAM register (see mac_set_vlan_cam) - setting the address filtering registers for vlans is not needed when there is no vlan The non-tagged interface is filtered out as soon as a tagged (!= 0) interface is created. Its traffic appears again when an zero-tagged interface is created. Tested on Via Epia SN (VT6130 chipset) with several vlans whose tag was above or beyond 255. Signed-off-by: Séguier Régis <rseguier@e-teleport.net> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-24tg3: sparse cleanupEric Dumazet
Fix the following sparse warning : drivers/net/tg3.c:4025:3: warning: context imbalance in 'tg3_restart_hw' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25forcedeth: realtek phy crossover detectionAyaz Abdulla
This patch fixes an issue seen with the realtek 8201 phy. This phy has a problem with crossover detection and it needs to be disabled. The problem only arises on certain switches. Therefore, a module parameter has been added to allow enabling crossover detection if needed. The default will be set to disabled. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: Increase MDIO timeoutsBenjamin Herrenschmidt
This patch doubles the MDIO timeouts in EMAC as there are field cases where they are two short to communicate with some PHYs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25gianfar: Fix skb allocation strategyAndy Fleming
gianfar was unable to handle failed skb allocation for rx buffers, so we were spinning until it succeeded. Actually, it was worse--we were spinning for a long time, and then silently failing. Instead, we take Stephen Hemminger's suggestion to try the allocation earlier, and drop the packet if it failed. We also make a couple of tweaks to how buffer descriptors are set up. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25netxen: reduce stack usage of netxen_nic_flash_printHarvey Harrison
Don't need to keep a struct netxen_new_user_info on the stack when we only are interested in printing the serial_num. Change to only reading the serial_num. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt}Roel Kluin
When timeout reaches 0 the postfix decrement still subtracts, so the test fails. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25forcedeth: new backoff implementationAyaz Abdulla
This patch adds support for a new backoff algorithm for half duplex supported in newer hardware. The old method is will be designated as legacy mode. Re-seeding random values for the backoff algorithms are performed when a transmit has failed due to a maximum retry count (1 to 15, where max is considered the wraparound case of 0). Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ehea: make things staticAndrew Morton
ehea_flush_sq() and ehea_purge_sq() should be static. Cc: Jeff Garzik <jeff@garzik.org> Cc: Thomas Klein <osstklei@de.ibm.com> Cc: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25phylib: Add support for board-level PHY fixupsAndy Fleming
Sometimes the specific interaction between the platform and the PHY requires special handling. For instance, to change where the PHY's clock input is, or to add a delay to account for latency issues in the data path. We add a mechanism for registering a callback with the PHY Lib to be called on matching PHYs when they are brought up, or reset. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25[netdrvr] atlx: code movement: move atl1 parameter parsingChris Snook
Move some code from atlx.c to atl1.c to prevent build conflict with the upcoming atl2 code. No changes, just movement. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25atlx: remove flash vendor parameterChris Snook
There's no good reason to manually set the flash vendor in a module parameter, outside of an Atheros hardware lab. Remove it, so nobody accidentally bricks their board using it incorrectly. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25korina: misc cleanupFrancois Romieu
- useless initialization (korina_ope / korina_restart) - use a single variable for the status code in korina_probe and propagate the error status code from below - useless checks in korina_remove : the variables are necessarily set when korina_probe succeeds Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
