Since net_device has an instance of net_device_stats,
we can remove the instance of this from the adapter structure.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
we can remove the instance of this from the private adapter structure.
Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
we can remove the instance of this from the private myri10ge_priv structure.
Allow enable/disable UFO on bridge device via ethtool
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Now that software UFO is supported, UFO can be enabled on master
devices like bridge, bond even though the attached device doesn't
support this feature in hardware.
This allows UFO to be used between KVM host and guest even when a
physical interface attached to the bridge doesn't support UFO.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
UDP_HTABLE_SIZE was initialy defined to 128, which is a bit small for
several setups.
4000 active UDP sockets -> 32 sockets per chain in average. An
incoming frame has to lookup all sockets to find best match, so long
chains hurt latency.
Instead of a fixed size hash table that cant be perfect for every
needs, let UDP stack choose its table size at boot time like tcp/ip
route, using alloc_large_system_hash() helper
Add an optional boot parameter, uhash_entries=x so that an admin can
force a size between 256 and 65536 if needed, like thash_entries and
rhash_entries.
dmesg logs two new lines :
[ 0.647039] UDP hash table entries: 512 (order: 0, 4096 bytes)
[ 0.647099] UDP Lite hash table entries: 512 (order: 0, 4096 bytes)
Maximal size on 64bit arches would be 65536 slots, ie 1 MBytes for non
debugging spinlocks.
Following fix a small typo.
Signed-off-by: Alexandre Cassen <acassen@freebox.fr>
There is no reason that cipso_v4_delopt() is not
defined as a static function.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Function argument len was redeclarated within the
function. This patch fix the redeclaration of symbol 'len'.
The variable old_active is first set to bond->curr_active_slave.
Then, it is unconditionally set to new_active, without being used in between.
The first assignment, having no side effect, is useless.
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
When parsing module parameters, bond_check_params() erroneously use
'xor_mode' as the name of a module parameter in an error message.
The right name for this parameter is 'xmit_hash_policy'.
Might as well use the ipv6_addr_set_v4mapped() inline we created last
year.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Change ip6_route_redirect() to use ipv6_addr_copy().
Fix build error introduced in commit fa857afcf - ipv6 sit: 6rd
(IPv6 Rapid Deployment) Support. Struct in6_addr is the issue.
I'm only seeing this on x86_64 systems, not on 32-bit with same
IPv6 config options, so it could be there's a missing forward
declaration somewhere, but including the correct header file
fixes the problem too.
CC [M] net/ipv6/ip6_tunnel.o
In file included from net/ipv6/ip6_tunnel.c:31:
include/linux/if_tunnel.h:59: error: field ‘prefix’ has incomplete type
make[2]: *** [net/ipv6/ip6_tunnel.o] Error 1
make[1]: *** [net/ipv6] Error 2
Add support for route lookup using sk_mark on IPv4 listening sockets.
Signed-off-by: Atis Elsts <atis@mikrotik.com>
This continues the previous patch, by applying the same change to CCID-3.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This removes a redundancy in the CCID half-connection (hc) naming scheme:
* instead of 'hctx->tx_...', write 'hc->tx_...';
* instead of 'hcrx->rx_...', write 'hc->rx_...';
which works because the 'type' of the half-connection is encoded in the
'rx_' / 'tx_' prefixes.
This implements the new naming scheme also for CCID-3.
This patch starts a less problematic naming convention for CCID structs.
The old naming convention used 'hc{tx,rx}->ccid?hc{tx,rx}->...' as
recurring prefixes, which made the code
* hard to write (not easy to fit into 80 characters);
* hard to read (most of the space is occupied by prefixes).
The new naming scheme:
* struct entries for the TX socket are prefixed by 'tx_';
* and those for the RX socket are prefixed by 'rx_'.
The identifiers then remain distinguishable when grep-ing through the tree:
(a) RX/TX sockets are distinguished by the naming scheme,
(b) individual CCIDs are distinguished by filename (ccid{2,3,4}.{c,h}).
This first patch implements the scheme for CCID-2.
adapter doesnot need to maintain a copy of net_device_stats.
Use the one already available in net_device. This patch takes care of the same.
The data center bridging ops structure can be const
All usages of structure net_proto_ops should be declared const.
On Friday 02 October 2009 20:53:51 you wrote:
> This is good although I would have shortened the name.
Ah, I knew I forgot something :) Here is v4.
tavi
>From 24d96d825b9fa832b22878cc6c990d5711968734 Mon Sep 17 00:00:00 2001
Date: Fri, 2 Oct 2009 00:51:15 +0300
Subject: [PATCH] ipv6: new sysctl for sending TLLAO with unicast NAs
Neighbor advertisements responding to unicast neighbor solicitations
did not include the target link-layer address option. This patch adds
a new sysctl option (disabled by default) which controls whether this
option should be sent even with unicast NAs.
The need for this arose because certain routers expect the TLLAO in
some situations even as a response to unicast NS packets.
Moreover, RFC 2461 recommends sending this to avoid a race condition
(section 4.4, Target link-layer address)
Signed-off-by: Cosmin Ratiu <cratiu@ixiacom.com>
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Atis Elsts wrote:
> Not sure if there is need to fill the mark from skb in tunnel xmit functions. In any case, it's not done for GRE or IPIP tunnels at the moment.
Ok, I'll just drop that part, I'm not sure what should be done in this case.
> Also, in this patch you are doing that for SIT (v6-in-v4) tunnels only, and not doing it for v4-in-v6 or v6-in-v6 tunnels. Any reason for that?
I just sent that patch out too quickly, here's a better one with the updates.
Add support for IPv6 route lookups using sk_mark.
After updating firmware stored in flash, users may wish to reset the
relevant hardware and start the new firmware immediately. This should
not be completely automatic as it may be disruptive.
A selective reset may also be useful for debugging or diagnostics.
This adds a separate reset operation which takes flags indicating the
components to be reset. Drivers are allowed to reset only a subset of
those requested, and must indicate the actual subset. This allows the
use of generic component masks and some future expansion.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Jarek Poplawski a écrit :
> Hmm... So you made me to do some "real" work here, and guess what?:
> there is one serious checkpatch warning! ;-) Plus, this new parameter
> should be added to the function description. Otherwise:
> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
> Thanks,
> Jarek P.
> PS: I guess full "Don't" would show we really mean it...
Okay :) Here is the last round, before the night !
Thanks again
[RFC] pkt_sched: gen_estimator: Don't report fake rate estimators
We currently send TCA_STATS_RATE_EST elements to netlink users, even if no estimator
is running.
# tc -s -d qdisc
qdisc pfifo_fast 0: dev eth0 root bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
Sent 112833764978 bytes 1495081739 pkt (dropped 0, overlimits 0 requeues 0)
rate 0bit 0pps backlog 0b 0p requeues 0
User has no way to tell if the "rate 0bit 0pps" is a real estimation, or a fake
one (because no estimator is active)
After this patch, tc command output is :
$ tc -s -d qdisc
Sent 561075 bytes 1196 pkt (dropped 0, overlimits 0 requeues 0)
We add a parameter to gnet_stats_copy_rate_est() function so that
it can use gen_estimator_active(bstats, r), as suggested by Jarek.
This parameter can be NULL if check is not necessary, (htb for
example has a mandatory rate estimator)
The receive_buf methods of the N_PPP and N_SYNC_PPP line disciplines,
ppp_asynctty_receive() and ppp_sync_receive(), call tty_unthrottle()
which may sleep. Fix the comments claiming otherwise.
Impact: documentation
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
In some cases there is not desirable to switch back to primary interface when
it's link recovers and rather stay with currently active one. We need to avoid
packetloss as much as we can in some cases. This is solved by introducing
primary_reselect option. Note that enslaved primary slave is set as current
active no matter what.
Patch modified by Jay Vosburgh as follows: fixed bug in action
after change of option setting via sysfs, revised the documentation
update, and bumped the bonding version number.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Here is a followup on this area, thanks.
[RFC] af_packet: fill skb->mark at xmit
skb->mark may be used by classifiers, so fill it in case user
set a SO_MARK option on socket.
IPv6 Rapid Deployment (6rd; draft-ietf-softwire-ipv6-6rd) builds upon
mechanisms of 6to4 (RFC3056) to enable a service provider to rapidly
deploy IPv6 unicast service to IPv4 sites to which it provides
customer premise equipment. Like 6to4, it utilizes stateless IPv6 in
IPv4 encapsulation in order to transit IPv4-only network
infrastructure. Unlike 6to4, a 6rd service provider uses an IPv6
prefix of its own in place of the fixed 6to4 prefix.
With this option enabled, the SIT driver offers 6rd functionality by
providing additional ioctl API to configure the IPv6 Prefix for in
stead of static 2002::/16 for 6to4.
Original patch was done by Alexandre Cassen <acassen@freebox.fr>
based on old Internet-Draft.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When routing daemon wants to enable forwarding of multicast traffic it
performs something like:
struct vifctl vc = {
.vifc_vifi = 1,
.vifc_flags = 0,
.vifc_threshold = 1,
.vifc_rate_limit = 0,
.vifc_lcl_addr = ip, /* <--- ip address of physical
interface, e.g. eth0 */
.vifc_rmt_addr.s_addr = htonl(INADDR_ANY),
setsockopt(fd, IPPROTO_IP, MRT_ADD_VIF, &vc, sizeof(vc));
This leads (in the kernel) to calling vif_add() function call which
search the (physical) device using assigned IP address:
dev = ip_dev_find(net, vifc->vifc_lcl_addr.s_addr);
The current API (struct vifctl) does not allow to specify an
interface other way than using it's IP, and if there are more than a
single interface with specified IP only the first one will be found.
The attached patch (against 2.6.30.4) allows to specify an interface
by its index, instead of IP address:
.vifc_vifi = 1,
.vifc_flags = VIFF_USE_IFINDEX, /* NEW */
.vifc_lcl_ifindex = if_nametoindex("eth0"), /* NEW */
Signed-off-by: Ilia K. <mail4ilia@gmail.com>
=== modified file 'include/linux/mroute.h'
Add a Kernel CAPI interface to the Gigaset driver.
Impact: optional new functionality
Add a dummy LL interface to the Gigaset driver so that it can be
built and, in a limited way, used without the ISDN4Linux subsystem.
Impact: new configuration alternative
Reorganize the code of the Gigaset driver, moving all isdn4linux
dependencies to the source file i4l.c so that it can be replaced
by a file capi.c interfacing to Kernel CAPI instead.
Impact: refactoring, no functional change
Add kerneldoc comments to some functions in the Gigaset driver.
Dump payload data consistently only when DEBUG_STREAM_DUMP debug bit
is set.
Impact: debugging aid
When the Gigaset base stops responding, try resetting the USB
connection to recover.
Impact: error handling improvement
Clear out pending command that got rejected with 'ERROR' response.
This fixes the bug where unloading the driver module would hang
with the message: "gigaset: not searching scheduled commands: busy"
after a device communication error.
Impact: error handling bugfix
Mention in the driver load announcement whether the driver was built
with debugging messages enabled, to facilitate support.
Impact: informational message
Don't drop the remainder of an URB if an isochronous frame has an error.
The code of the Gigaset driver assumes that sk_buff-s coming
from the ISDN4Linux subsystem are always linear. Explicitly
calling skb_linearize() is cheap if they are, but much more
robust in case they ever aren't.
Impact: robustness improvement
Signal D channel disconnect in a few cases where it was missed,
including when an incoming call is disconnected before it was
accepted.
Being able to change the debugmode module parameter of capidrv on the
fly is quite useful for debugging and doesn't do any harm.
In several places, capidrv sends a CAPI message to the ISDN
device and then updates its internal state accordingly.
If the response message from the device arrives before the
state is updated, it may be rejected or processed incorrectly.
Avoid these races by updating the state before emitting the
message.
Impact: bugfix
Acked-by: Karsten Keil <keil@b1-systems.de>
Info values in the 0x00xx range are defined in the CAPI standard
as "Informational, message processed successfully". Therefore a
CONNECT_B3_CONF message with an Info value in that range should
open an NCCI just as with Info==0.
Impact: minor bugfix
- Note that send_message() may be called in interrupt context.
- Describe the storage of CAPI messages and payload data in SKBs.
- Add more details to the description of the _cmsg structure.
- Describe kernelcapi debugging output.
<ifname> tx off
This is a fix for a bug which was a result of wrong use of checksum offload flag.
The status of tx-checksumming was not changed from on to off
after a 'ethtool -K <ifname> tx off' operation.
Use the proper checksum offload flag NETIF_F_HW_CSUM instead of
NETIF_F_IP_CSUM and NETIF_F_IPV6_CSUM.
Patch is against net-2.6 tree.
