2011-01-03perf tools: Introduce event selectorsArnaldo Carvalho de Melo
Out of ad-hoc code and global arrays with hard coded sizes. This is the first step on having a library that will be first used on regression tests in the 'perf test' tool. [acme@felicio linux]$ size /tmp/perf.before text data bss dec hex filename 1273776 97384 5104416 6475576 62cf38 /tmp/perf.before [acme@felicio linux]$ size /tmp/perf.new text data bss dec hex filename 1275422 97416 1392416 2765254 2a31c6 /tmp/perf.new Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-30Merge branch 'core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core
2010-12-27perf probe: Fix short file name probe location reportingFranck Bui-Huu
After adding probes, perf-probe(1) reports the probes locations which include filenames for certain cases. But for short file names (whose length < 32), perf-probe didn't display the name correctly. It actually skipped the first character. Here's an example where 'icmp.c' was screwed: $ perf probe -n -a "icmp.c;sk=*" Add new events: probe:icmp_push_reply (on @cmp.c) probe:icmp_reply (on @cmp.c) probe:icmp_reply_1 (on @cmp.c) probe:icmp_send (on @cmp.c) probe:icmp_send_1 (on @cmp.c) probe:icmp_error (on @cmp.c) probe:icmp_error_1 (on @cmp.c) probe:icmp_error_2 (on @cmp.c) probe:icmp_error_3 (on @cmp.c) This patch fixes this bug in synthesize_perf_probe_point(). Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <m31v588r9k.fsf@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-25perf script: Fix event ordering settings to work with older kernelsArnaldo Carvalho de Melo
If we don't use .ordering_requires_timestamps we'll end up trying to order events with no timestamps when running on older kernels. Problem introduced in eac23d1c. After the last three fixes, perf scripting is back working, tested with new perf userspace on old and new (with sample_id_all) kernels. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-25perf record: Fix use of sample_id_all userspace with !sample_id_all kernelsArnaldo Carvalho de Melo
Check if parse_single_tracepoint_event has already asked for PERF_SAMPLE_TIME. This is kludgy but short term fix for problems introduced by eac23d1c that broke 'perf script' by having different sample_types when using multiple tracepoint events when we use a perf binary that tries to use sample_id_all on an older kernel. We need to move counter creation to perf_session, support different sample_types, etc. Ongoing work on the perf test infrastructure needs this so that we can create counters to monitor threads generating specific events, etc. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-25perf script: Finish the rename from trace to scriptArnaldo Carvalho de Melo
The scripts have calls to 'perf trace' that need to be converted to 'perf script', do it. This problem was introduced in 133dc4c. Reported-by: Torok Edwin <edwintorok@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-23Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/core
2010-12-22perf probe: Fix wrong warning in __show_one_line() if read(1) errors happenFranck Bui-Huu
This was introduced by commit fde52dbd7f71934aba4e150f3d1d51e826a08850. Cc: H. Peter Anvin <hpa@zytor.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <m3y67hsr0m.fsf@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf test: Look forward for symbol aliasesArnaldo Carvalho de Melo
Not just before, fixing these false positives: [acme@mica linux]$ perf test -v 1 1: vmlinux symtab matches kallsyms: --- start --- Looking at the vmlinux_path (6 entries long) Using //lib/modules/2.6.37-rc5-00180-ge06b6bf/build/vmlinux for symbols 0xffffffff81058dc0: diff name v: sys_vm86old k: sys_ni_syscall 0xffffffff81058dc0: diff name v: sys_vm86 k: sys_ni_syscall 0xffffffff81058dc0: diff name v: sys_subpage_prot k: sys_ni_syscall 0xffffffff810b5f7c: diff name v: probe_kernel_write k: __probe_kernel_write 0xffffffff810b5fe5: diff name v: probe_kernel_read k: __probe_kernel_read 0xffffffff811bc380: diff name v: __memset k: memset 0xffffffff81384a98: diff name v: __sched_text_start k: sleep_on_common 0xffffffff81386750: diff name v: __sched_text_end k: _raw_spin_trylock 0xffffffff8138cee8: diff name v: __irqentry_text_start k: do_IRQ 0xffffffff8138f079: diff name v: __start_notes k: _etext 0xffffffff8138f079: diff name v: __stop_notes k: _etext ---- end ---- vmlinux symtab matches kallsyms: FAILED! [acme@mica linux]$ Some are weak functions, others are just markers, etc. They get in the rb tree with the same addr, so we need to look around to find the symbol with the same name. We were looking just at the previous entries with the same addr, look forward too. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Han Pingtian <phan@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22perf symbols: Improve kallsyms symbol end addr calculationArnaldo Carvalho de Melo
For kallsyms we don't have the symbol address end, so we do an extra pass and set the symbol end addr as being the start of the next minus one. But this was being done just after we filtered the symbols of a particular type (functions, variables), so the symbol end was sometimes after what it really is. Fixing up symbol end also was falling apart when we have symbol aliases, then the end address of all but the last alias was being set to be before its start. Fix it up by checking for symbol aliases and making the kallsyms__parse routine use the next symbol, whatever its type, as the limit for the previous symbol, passing that end address to the callback. This was detected by the 'perf test' synthetic paranoid regression tests, fix it up so that even that case doesn't mislead us. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-22x86, nmi_watchdog: Remove ARCH_HAS_NMI_WATCHDOG and rely on ↵Don Zickus
CONFIG_HARDLOCKUP_DETECTOR The x86 arch has shifted its use of the nmi_watchdog from a local implementation to the global one provide by kernel/watchdog.c. This shift has caused a whole bunch of compile problems under different config options. I attempt to simplify things with the patch below. In order to simplify things, I had to come to terms with the meaning of two terms ARCH_HAS_NMI_WATCHDOG and CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing, the former on a local level and the latter on a global level. With the old x86 nmi watchdog gone, there is no need to rely on defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't make sense any more. x86 will now use the global implementation. The changes below do a few things. First it changes the few places that relied on ARCH_HAS_NMI_WATCHDOG to use CONFIG_X86_LOCAL_APIC (the former was an alias for the latter anyway, so nothing unusual here). Those pieces of code were relying more on local apic functionality the nmi watchdog functionality, so the change should make sense. Second, I removed the x86 implementation of touch_nmi_watchdog(). It isn't need now, instead x86 will rely on kernel/watchdog.c's implementation. Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from x86. And tweaked the include/linux/nmi.h file to tell users to look for an externally defined touch_nmi_watchdog in the case of ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This changes removes some of the ugliness in that file. Finally, I added a Kconfig dependency for CONFIG_HARDLOCKUP_DETECTOR that said you can't have ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can only have one nmi_watchdog. Tested with ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig, (various broken configs) Hopefully, after this patch I won't get any more compile broken emails. :-) v3: changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-22Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-12-22Merge branch 'perf/core' of ↵Ingo Molnar
2010-12-22Merge commit 'v2.6.37-rc7' into perf/coreIngo Molnar
Merge reason: Pick up the latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-21Linux 2.6.37-rc7v2.6.37-rc7Linus Torvalds
2010-12-21perf probe: Handle gracefully some stupid and buggy line syntaxesFranck Bui-Huu
Currently perf probe doesn't handle those incorrect syntaxes: $ perf probe -L sched.c:++13 $ perf probe -L sched.c:-+13 $ perf probe -L sched.c:10000000000000000000000000000+13 This patches rewrites parse_line_range_desc() to handle them. As a bonus, it reports more useful error messages instead of: "Tailing with invalid character...". Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-7-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Don't always consider EOF as an error when listing source codeFranck Bui-Huu
When listing a whole file or a function which is located at the end, perf-probe -L output wrongly: "Source file is shorter than expected.". This is because show_one_line() always consider EOF as an error. This patch fixes this by not considering EOF as an error when dumping the trailing lines. Otherwise it's still an error and perf-probe still outputs its warning. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-6-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Fix line range description since a single file is allowedFranck Bui-Huu
$ perf-probe -L sched.c is currently allowed but not documented. Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-5-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Clean up redundant tests in show_line_range()Franck Bui-Huu
It also removes some superflous parentheses. Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-4-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Rewrite show_one_line() to make it simplerFranck Bui-Huu
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-3-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Make -L display the absolute path of the dumped fileFranck Bui-Huu
The actual file used by 'perf probe -L sched.c' is reported in the ouput of the command. But it's simply displayed as it has been given to the command (simply sched.c) which is too ambiguous to be really usefull since several sched.c files can be found into the same project and we also don't know which search path has been used. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LKML-Reference: <1292854685-8230-2-git-send-email-fbuihuu@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf probe: Cleanup messagesMasami Hiramatsu
Add new lines for error or debug messages, change dwarf related words to more generic words (or just removed). Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20101217131211.24123.40437.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf symbols: Add symfs option for off-box analysis using specified treeDavid Ahern
The symfs argument allows analysis of perf.data file using a locally accessible filesystem tree with debug symbols - e.g., tree created during image builds, sshfs mount, loop mounted KVM disk images, USB keys, initrds, etc. Anything with an OS tree can be analyzed from anywhere without the need to populate a local data store with build-ids. Commiter notes: o Fixed up symfs="/" variants handling. o prefixed DSO__ORIG_GUEST_KMODULE case with symfs too, avoiding use of files outside the symfs directory. LKML-Reference: <1291926427-28846-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf record,report,annotate,diff: Process events in orderIan Munsie
This patch changes perf report to ask for the ID info on all events be default if recording from multiple CPUs. Perf report, annotate and diff will now process the events in order if the kernel is able to provide timestamps on all events. This ensures that events such as COMM and MMAP which are necessary to correctly interpret samples are processed prior to those samples so that they are attributed correctly. Before: # perf record ./cachetest # perf report # Events: 6K cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ............................... # 74.11% :3259 [unknown] [k] 0x4a6c 1.50% cachetest ld-2.11.2.so [.] 0x1777c 1.46% :3259 [kernel.kallsyms] [k] .perf_event_mmap_ctx 1.25% :3259 [kernel.kallsyms] [k] restore 0.74% :3259 [kernel.kallsyms] [k] ._raw_spin_lock 0.71% :3259 [kernel.kallsyms] [k] .filemap_fault 0.66% :3259 [kernel.kallsyms] [k] .memset 0.54% cachetest [kernel.kallsyms] [k] .sha_transform 0.54% :3259 [kernel.kallsyms] [k] .copy_4K_page 0.54% :3259 [kernel.kallsyms] [k] .find_get_page 0.52% :3259 [kernel.kallsyms] [k] .trace_hardirqs_off 0.50% :3259 [kernel.kallsyms] [k] .__do_fault <SNIP> After: # perf report # Events: 6K cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ............................... # 44.28% cachetest cachetest [.] sumArrayNaive 22.53% cachetest cachetest [.] sumArrayOptimal 6.59% cachetest ld-2.11.2.so [.] 0x1777c 2.13% cachetest [unknown] [k] 0x340 1.46% cachetest [kernel.kallsyms] [k] .perf_event_mmap_ctx 1.25% cachetest [kernel.kallsyms] [k] restore 0.74% cachetest [kernel.kallsyms] [k] ._raw_spin_lock 0.71% cachetest [kernel.kallsyms] [k] .filemap_fault 0.66% cachetest [kernel.kallsyms] [k] .memset 0.54% cachetest [kernel.kallsyms] [k] .copy_4K_page 0.54% cachetest [kernel.kallsyms] [k] .find_get_page 0.54% cachetest [kernel.kallsyms] [k] .sha_transform 0.52% cachetest [kernel.kallsyms] [k] .trace_hardirqs_off 0.50% cachetest [kernel.kallsyms] [k] .__do_fault <SNIP> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1291872833-839-1-git-send-email-imunsie@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf session: Fallback to unordered processing if no sample_id_allIan Munsie
If we are running the new perf on an old kernel without support for sample_id_all, we should fall back to the old unordered processing of events. If we didn't than we would *always* process events without timestamps out of order, whether or not we hit a reordering race. In other words, instead of there being a chance of not attributing samples correctly, we would guarantee that samples would not be attributed. While processing all events without timestamps before events with timestamps may seem like an intuitive solution, it falls down as PERF_RECORD_EXIT events would also be processed before any samples. Even with a workaround for that case, samples before/after an exec would not be attributed correctly. This patch allows commands to indicate whether they need to fall back to unordered processing, so that commands that do not care about timestamps on every event will not be affected. If we do fallback, this will print out a warning if report -D was invoked. This patch adds the test in perf_session__new so that we only need to test once per session. Commands that do not use an event_ops (such as record and top) can simply pass NULL in it's place. Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1291951882-sup-6069@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-20Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: n_gsm: gsm_data_alloc buffer allocation could fail and it is not being checked n_gsm: Fix message length handling when building header
2010-12-20Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: Revert "USB: gadget: Allow function access to device ID data during bind()" USB: misc: uss720.c: add another vendor/product ID USB: usb-storage: unusual_devs entry for the Samsung YP-CP3 USB: gadget: Remove suspended sysfs file before freeing cdev USB: core: Add input prompt and help text for USB_OTG config USB: ftdi_sio: Add D.O.Tec PID xhci: Fix issue with port array setup and buggy hosts.
2010-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: handle partial result from get_user_pages ceph: mark user pages dirty on direct-io reads ceph: fix null pointer dereference in ceph_init_dentry for nfs reexport ceph: fix direct-io on non-page-aligned buffers ceph: fix msgr_init error path
2010-12-20Fix build error in drivers/block/cciss.cLinus Torvalds
.. caused by a missing semi-colon, introduced in commit 0fc13c8995cd ("cciss: fix cciss_revalidate panic"). Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: Thiago Farina <tfransosi@gmail.com> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-20Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] gspca - sonixj: Better handling of the bridge registers 0x01 and 0x17 [media] gspca - sonixj: Add the bit definitions of the bridge reg 0x01 and 0x17 [media] gspca - sonixj: Set the flag for some devices [media] gspca - sonixj: Add a flag in the driver_info table [media] gspca - sonixj: Fix a bad probe exchange [media] gspca - sonixj: Move bridge init to sd start [media] bttv: remove unneeded locking comments [media] bttv: fix mutex use before init (BZ#24602) [media] Don't export format_by_forcc on two different drivers
2010-12-20Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: INTC interrupt priority level demux fix ARM: mach-shmobile: fix compile warning in mm/init.c
2010-12-20Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: clocksource: sh_cmt: Remove nested spinlock fix
2010-12-20Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: OMAP: OMAPFB: disable old omapfb for OMAP4 builds OMAP: DSS: VRAM: Align start & size of vram to 2M
2010-12-20Merge branch 's5p-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung * 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S5PV210: update MAX8998 platform data to get rid of WARN() ARM S3C24XX: Fix compilation of PM code for S3C2416 ARM: S3C24XX: Fix CONFIG_S3C_DEV_NAND Kconfig entry
2010-12-20Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cciss: fix cciss_revalidate panic block: max hardware sectors limit wrapper block: Deprecate QUEUE_FLAG_CLUSTER and use queue_limits instead blk-throttle: Correct the placement of smp_rmb() blk-throttle: Trim/adjust slice_end once a bio has been dispatched block: check for proper length of iov entries earlier in blk_rq_map_user_iov() drbd: fix for spin_lock_irqsave in endio callback drbd: don't recvmsg with zero length
2010-12-20Fix btrfs b0rkageAl Viro
Buggered-in: 76dda93c6ae2 ("Btrfs: add snapshot/subvolume destroy ioctl") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-20clarify a usage constraint for cnt32_to_63()Nicolas Pitre
The cnt32_to_63 algorithm relies on proper counter data evaluation ordering to work properly. This was missing from the provided documentation. Let's augment the documentation with the missing usage constraint and fix the only instance that got it wrong. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-20Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Remove debugging check
2010-12-19sched: Remove debugging checkIngo Molnar
Linus reported that the new warning introduced by commit f26f9aff6aaf "Sched: fix skip_clock_update optimization" triggers. The need_resched flag can be set by other CPUs asynchronously so this debug check is bogus - remove it. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <AANLkTinJ8hAG1TpyC+CSYPR47p48+1=E7fiC45hMXT_1@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-19Merge branches 'x86-fixes-for-linus' and 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32: Make sure we can map all of lowmem if we need to x86, vt-d: Handle previous faults after enabling fault handling x86: Enable the intr-remap fault handling after local APIC setup x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem() bootmem: Add alloc_bootmem_align() x86, gcc-4.6: Use gcc -m options when building vdso x86: HPET: Chose a paranoid safe value for the ETIME check x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Fix off by one in perf_swevent_init() perf: Fix duplicate events with multiple-pmu vs software events ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO scripts/tags.sh: Add magic for trace-events tracing: Fix panic when lseek() called on "trace" opened for writing
2010-12-19Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix the irqtime code for 32bit sched: Fix the irqtime code to deal with u64 wraps nohz: Fix get_next_timer_interrupt() vs cpu hotplug Sched: fix skip_clock_update optimization sched: Cure more NO_HZ load average woes
2010-12-19oprofile, x86: Add support for 6 counters (AMD family 15h)Robert Richter
This patch adds support for up to 6 hardware counters for AMD family 15h cpus. There is a new MSR range for hardware counters beginning at MSRC001_0200 Performance Event Select (PERF_CTL0). Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-12-19oprofile, x86: Add support for AMD family 15hRobert Richter
This patch adds support for AMD family 15h (Interlagos/Valencia/ Zambezi) cpus. Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: handle rt_sigreturn() more cleanly arch/tile: handle CLONE_SETTLS in copy_thread(), not user space
2010-12-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Fix build errors in sc-mips.c
2010-12-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86: avoid high BIOS area when allocating address space x86: avoid E820 regions when allocating address space x86: avoid low BIOS area when allocating address space resources: add arch hook for preventing allocation in reserved areas Revert "resources: support allocating space within a region from the top down" Revert "PCI: allocate bus resources from the top down" Revert "x86/PCI: allocate space from the end of a region, not the beginning" Revert "x86: allocate space within a region top-down" Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode" PCI: Update MCP55 quirk to not affect non HyperTransport variants
2010-12-17arch/tile: handle rt_sigreturn() more cleanlyChris Metcalf
The current tile rt_sigreturn() syscall pattern uses the common idiom of loading up pt_regs with all the saved registers from the time of the signal, then anticipating the fact that we will clobber the ABI "return value" register (r0) as we return from the syscall by setting the rt_sigreturn return value to whatever random value was in the pt_regs for r0. However, this breaks in our 64-bit kernel when running "compat" tasks, since we always sign-extend the "return value" register to properly handle returned pointers that are in the upper 2GB of the 32-bit compat address space. Doing this to the sigreturn path then causes occasional random corruption of the 64-bit r0 register. Instead, we stop doing the crazy "load the return-value register" hack in sigreturn. We already have some sigreturn-specific assembly code that we use to pass the pt_regs pointer to C code. We extend that code to also set the link register to point to a spot a few instructions after the usual syscall return address so we don't clobber the saved r0. Now it no longer matters what the rt_sigreturn syscall returns, and the pt_regs structure can be cleanly and completely reloaded. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-12-17arch/tile: handle CLONE_SETTLS in copy_thread(), not user spaceChris Metcalf
Previously we were just setting up the "tp" register in the new task as started by clone() in libc. However, this is not quite right, since in principle a signal might be delivered to the new task before it had its TLS set up. (Of course, this race window still exists for resetting the libc getpid() cached value in the new task, in principle. But in any case, we are now doing this exactly the way all other architectures do it.) This change is important for 2.6.37 since the tile glibc we will be submitting upstream will not set TLS in user space any more, so it will only work on a kernel that has this fix. It should also be taken for 2.6.36.x in the stable tree if possible. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: stable <stable@kernel.org>
2010-12-17[media] gspca - sonixj: Better handling of the bridge registers 0x01 and 0x17Jean-Francois Moine
The initial values of the registers 0x01 and 0x17 are taken from the sensor table at capture start and updated according to the flag PDN_INV. Their values are updated at each step of the capture initialization and memorized for reuse in capture stop. This patch also fixed automatically some bad hardcoded values of these registers. Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-17[media] gspca - sonixj: Add the bit definitions of the bridge reg 0x01 and 0x17Jean-Francois Moine
