2008-07-15Merge branch 'core/stacktrace' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/stacktrace' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: powerpc/generic-ipi tree build failure stacktrace: fix build failure on sparc64 stacktrace: export save_stack_trace[_tsk] stacktrace: fix modular build, export print_stack_trace and save_stack_trace backtrace: replace timer with tasklet + completions stacktrace: add saved stack traces to backtrace self-test stacktrace: print_stack_trace() cleanup debugging: make stacktrace independent from DEBUG_KERNEL stacktrace: don't crash on invalid stack trace structs
2008-07-15Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix compile error with CONFIG_AS_CFI=n Documentation: document debugpat commandline option x86: sanitize Kconfig x86, suspend, acpi: correct and add comments about Big Real Mode x86, suspend, acpi: enter Big Real Mode Fixed trivial conflict in include/asm-x86/dwarf2.h due to just using different names for "cfi_ignore" (vs "__cfi_ignore") macro.
2008-07-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (61 commits) ext4: Documention update for new ordered mode and delayed allocation ext4: do not set extents feature from the kernel ext4: Don't allow nonextenst mount option for large filesystem ext4: Enable delalloc by default. ext4: delayed allocation i_blocks fix for stat ext4: fix delalloc i_disksize early update issue ext4: Handle page without buffers in ext4_*_writepage() ext4: Add ordered mode support for delalloc ext4: Invert lock ordering of page_lock and transaction start in delalloc mm: Add range_cont mode for writeback ext4: delayed allocation ENOSPC handling percpu_counter: new function percpu_counter_sum_and_set ext4: Add delayed allocation support in data=writeback mode vfs: add hooks for ext4's delayed allocation support jbd2: Remove data=ordered mode support using jbd buffer heads ext4: Use new framework for data=ordered mode in JBD2 jbd2: Implement data=ordered mode handling via inodes vfs: export filemap_fdatawrite_range() ext4: Fix lock inversion in ext4_ext_truncate() ext4: Invert the locking order of page_lock and transaction start ...
2008-07-15Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon: fixup issue with radeon and PAT support.
2008-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: Revert "SELinux: allow fstype unknown to policy to use xattrs if present"
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (52 commits) IB/mlx4: Use kzalloc() for new QPs so flags are initialized to 0 mlx4_core: Use MOD_STAT_CFG command to get minimal page size RDMA/cma: Simplify locking needed for serialization of callbacks RDMA/addr: Keep pointer to netdevice in struct rdma_dev_addr RDMA/cxgb3: Fixes for zero STag RDMA/core: Add local DMA L_Key support IB/mthca: Fix check of max_send_sge for special QPs IB/mthca: Use round_jiffies() for catastrophic error polling timer IB/mthca: Remove "stop" flag for catastrophic error polling timer IPoIB: Double default RX/TX ring sizes IPoIB/cm: Reduce connected mode TX object size IB/ipath: Use IEEE OUI for vendor_id reported by ibv_query_device() IPoIB: Use dev_set_mtu() to change mtu IPoIB: Use rtnl lock/unlock when changing device flags IPoIB: Get rid of ipoib_mcast_detach() wrapper IPoIB: Only set Q_Key once: after joining broadcast group IPoIB: Remove priv->mcast_mutex IPoIB: Remove unused IPOIB_MCAST_STARTED code RDMA/cxgb3: Set rkey field for new memory windows in iwch_alloc_mw() RDMA/nes: Get rid of ring_doorbell parameter of nes_post_cqp_request() ...
2008-07-15x86: Fix compile error with CONFIG_AS_CFI=nKevin Winchester
AS arch/x86/lib/csum-copy_64.o arch/x86/lib/csum-copy_64.S: Assembler messages: arch/x86/lib/csum-copy_64.S:48: Error: Macro `ignore' was already defined make[1]: *** [arch/x86/lib/csum-copy_64.o] Error 1 make: *** [arch/x86/lib] Error 2 It appears that csum-copy_64.S and dwarf2.h both define an ignore macro. I would expect one of them can be renamed quite easily, unless they are references elsewhere. Caused-by-commit: 392a0fc96bd059b38564f5f8fb58327460cb5a9d x86: merge dwarf2 headers Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-15Documentation: document debugpat commandline optionThomas Gleixner
2008-07-15x86: sanitize KconfigThomas Gleixner
Set default n for MEMTEST and MTRR_SANITIZER and fix the help texts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-15Merge branch 'linus' into x86/urgentIngo Molnar
2008-07-15Revert "SELinux: allow fstype unknown to policy to use xattrs if present"James Morris
This reverts commit 811f3799279e567aa354c649ce22688d949ac7a9. From Eric Paris: "Please drop this patch for now. It deadlocks on ntfs-3g. I need to rework it to handle fuse filesystems better. (casey was right)"
2008-07-14IB/mlx4: Use kzalloc() for new QPs so flags are initialized to 0Eli Cohen
Current code uses kmalloc() and then just does a bitwise OR operation on qp->flags in create_qp_common(), which means that qp->flags may potentially have some unintended bits set. This patch uses kzalloc() and avoids further explicit clearing of structure members, which also shrinks the code: add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-65 (-65) function old new delta create_qp_common 2024 1959 -65 Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14mlx4_core: Use MOD_STAT_CFG command to get minimal page sizeVladimir Sokolovsky
There was a bug in some versions of the mlx4 driver in mlx4_alloc_fmr(), which hardcoded the minimum acceptable page_shift to be 12. However, new ConnectX firmware can support a minimum page_shift of 9 (log_pg_sz of 9 returned by QUERY_DEV_LIM) -- so with old drivers, ib_fmr_alloc() would fail for ULPs using the device minimum when creating FMRs. To preserve firmware compatibility with released mlx4 drivers, the firmware will continue to return 12 as before for log_page_sz in QUERY_DEV_CAP for these drivers. However, to enable new drivers to take advantage of the available smaller page size, the mlx4 driver now first sets the log_pg_sz to the device minimum by setting a log_page_sz value to 0 via the MOD_STAT_CFG command and then reading the real minimum via QUERY_DEV_CAP. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/cma: Simplify locking needed for serialization of callbacksOr Gerlitz
The RDMA CM has some logic in place to make sure that callbacks on a given CM ID are delivered to the consumer in a serialized manner. Specifically it has code to protect against a device removal racing with a running callback function. This patch simplifies this logic by using a mutex per ID instead of a wait queue and atomic variable. This means that cma_disable_remove() now is more properly named to cma_disable_callback(), and cma_enable_remove() can now be removed because it just would become a trivial wrapper around mutex_unlock(). Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/addr: Keep pointer to netdevice in struct rdma_dev_addrOr Gerlitz
Keep a pointer to the local (src) netdevice in struct rdma_dev_addr, and copy it in as part of rdma_copy_addr(). Use rdma_translate_ip() in cma_new_conn_id() to reduce some code duplication and also make sure the src_dev member gets set. In a high-availability configuration the netdevice pointer can be used by the RDMA CM to align RDMA sessions to use the same links as the IP stack does under fail-over and route change cases. Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/cxgb3: Fixes for zero STagSteve Wise
Handling the zero STag in receive work request requires some extra logic in the driver: - Only set the QP_PRIV bit for kernel mode QPs. - Add a zero STag build function for recv wrs. The uP needs a PBL allocated and passed down in the recv WR so it can construct a HW PBL for the zero STag S/G entries. Note: we need to place a few restrictions on zero STag usage because of this: 1) all SGEs in a recv WR must either be zero STag or not. No mixing. 2) an individual SGE length cannot exceed 128MB for a zero-stag SGE. This should be OK since it's not really practical to allocate such a large chunk of pinned contiguous DMA mapped memory. - Add an optimized non-zero-STag recv wr format for kernel users. This is needed to optimize both zero and non-zero STag cracking in the recv path for kernel users. - Remove the iwch_ prefix from the static build functions. - Bump required FW version. Signed-off-by: Steve Wise <swise@opengridcomputing.com>
2008-07-14RDMA/core: Add local DMA L_Key supportSteve Wise
- Change the IB_DEVICE_ZERO_STAG flag to the transport-neutral name IB_DEVICE_LOCAL_DMA_LKEY, which is used by iWARP RNICs to indicate 0 STag support and IB HCAs to indicate reserved L_Key support. - Add a u32 local_dma_lkey member to struct ib_device. Drivers fill this in with the appropriate local DMA L_Key (if they support it). - Fix up the drivers using this flag. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/mthca: Fix check of max_send_sge for special QPsRoland Dreier
The MLX transport requires two extra gather entries for sends (one for the header and one for the checksum at the end, as the comment says). However the code checked that max_recv_sge was not too big, instead of checking max_send_sge as it should have. Fix the code to check the correct condition. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/mthca: Use round_jiffies() for catastrophic error polling timerRoland Dreier
Exactly when the catastrophic error polling timer function runs is not important, so use round_jiffies() to save unnecessary wakeups. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/mthca: Remove "stop" flag for catastrophic error polling timerRoland Dreier
Since we use del_timer_sync() anyway, there's no need for an additional flag to tell the timer not to rearm. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Double default RX/TX ring sizesEli Cohen
Increase IPoIB ring sizes to twice their original sizes (RX: 128->256, TX: 64->128) to act as a shock absorber for high traffic peaks. With the current settings, we have seen cases that there are many calls to netif_stop_queue(), which causes degradation in throughput. Also, larger receive buffer sizes help IPoIB in CM mode to avoid experiencing RNR NAK conditions due to insufficient receive buffers at the SRQ. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB/cm: Reduce connected mode TX object sizeEli Cohen
Since IPoIB connected mode does not NETIF_F_SG, we only have one DMA mapping per send, so we don't need a mapping[] array. Define a new struct with a single u64 mapping member and use it for the CM tx_ring. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/ipath: Use IEEE OUI for vendor_id reported by ibv_query_device()Ralph Campbell
The IB spe. for SubnGet(NodeInfo) and query HCA says that the vendor ID field should be the IEEE OUI assigned to the vendor. The ipath driver was returning the PCI vendor ID instead. This will affect applications which call ibv_query_device(). The old value was 0x001fc1 or 0x001077, the new value is 0x001175. The vendor ID doesn't appear to be exported via /sys so that should reduce possible compatibility issues. I'm only aware of Open MPI as a major application which depends on this change, and they have made necessary adjustments. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Use dev_set_mtu() to change mtuEli Cohen
When the driver sets the MTU of the net device outside of its change_mtu method, it should make use of dev_set_mtu() instead of directly setting the mtu field of struct netdevice. Otherwise functions registered to be called upon MTU change will not get called (this is done through call_netdevice_notifiers() in dev_set_mtu()). Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Use rtnl lock/unlock when changing device flagsEli Cohen
Use of this lock is required to synchronize changes to the netdvice's data structs. Also move the call to ipoib_flush_paths() after the modification of the netdevice flags in set_mode(). Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Get rid of ipoib_mcast_detach() wrapperRoland Dreier
ipoib_mcast_detach() does nothing except call ib_detach_mcast(), so just use the core API in the one place that does a multicast group detach. add/remove: 0/1 grow/shrink: 0/1 up/down: 0/-105 (-105) function old new delta ipoib_mcast_leave 357 319 -38 ipoib_mcast_detach 67 - -67 Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Only set Q_Key once: after joining broadcast groupEli Cohen
The current code will set the Q_Key for any join of a non-sendonly multicast group. The operation involves a modify QP operation, which is fairly heavyweight, and is only really required after the join of the broadcast group. Fix this by adding a parameter to ipoib_mcast_attach() to control when the Q_Key is set. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Remove priv->mcast_mutexEli Cohen
No need for a mutex around calls to ib_attach_mcast/ib_detach_mcast since these operations are synchronized at the HW driver layer. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Remove unused IPOIB_MCAST_STARTED codeEli Cohen
The IPOIB_MCAST_STARTED flag is not used at all since commit b3e2749b ("IPoIB: Don't drop multicast sends when they can be queued"), so remove it. Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/cxgb3: Set rkey field for new memory windows in iwch_alloc_mw()Steve Wise
2008-07-14RDMA/nes: Get rid of ring_doorbell parameter of nes_post_cqp_request()Roland Dreier
Every caller of nes_post_cqp_request() passed it NES_CQP_REQUEST_RING_DOORBELL, so just remove that parameter and always ring the doorbell. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Faisal Latif <flatif@neteffect.com>
2008-07-14RDMA/cxgb3: Propagate HW page size capabilitiesJon Mason
cxgb3 does not currently report the page size capabilities, and incorrectly reports them internally. This version changes the bit-shifting to a static value (per Steve's request). Signed-off-by: Jon Mason <jon@opengridcomputing.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/nes: Encapsulate logic nes_put_cqp_request()Roland Dreier
The iw_nes driver repeats the logic if (atomic_dec_and_test(&cqp_request->refcount)) { if (cqp_request->dynamic) { kfree(cqp_request); } else { spin_lock_irqsave(&nesdev->cqp.lock, flags); list_add_tail(&cqp_request->list, &nesdev->cqp_avail_reqs); spin_unlock_irqrestore(&nesdev->cqp.lock, flags); } } over and over. Wrap this up in functions nes_free_cqp_request() and nes_put_cqp_request() to simplify such code. In addition to making the source smaller and more readable, this shrinks the compiled code quite a bit: add/remove: 2/0 grow/shrink: 0/13 up/down: 164/-1692 (-1528) function old new delta nes_free_cqp_request - 147 +147 nes_put_cqp_request - 17 +17 nes_modify_qp 2316 2293 -23 nes_hw_modify_qp 737 657 -80 nes_dereg_mr 945 860 -85 flush_wqes 501 416 -85 nes_manage_apbvt 648 560 -88 nes_reg_mr 1117 1026 -91 nes_cqp_ce_handler 927 769 -158 nes_alloc_mw 1052 884 -168 nes_create_qp 5314 5141 -173 nes_alloc_fmr 2212 2035 -177 nes_destroy_cq 1097 918 -179 nes_create_cq 2787 2598 -189 nes_dealloc_mw 762 566 -196 Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Faisal Latif <flatif@neteffect.com>
2008-07-14IPoIB: Refresh paths instead of flushing them on SM change eventsMoni Shoua
The patch tries to solve the problem of device going down and paths being flushed on an SM change event. The method is to mark the paths as candidates for refresh (by setting the new valid flag to 0), and wait for an ARP probe a new path record query. The solution requires a different and less intrusive handling of SM change event. For that, the second argument of the flush function changes its meaning from a boolean flag to a level. In most cases, SM failover doesn't cause LID change so traffic won't stop. In the rare cases of LID change, the remote host (the one that hadn't changed its LID) will lose connectivity until paths are refreshed. This is no worse than the current state. In fact, preventing the device from going down saves packets that otherwise would be lost. Signed-off-by: Moni Levy <monil@voltaire.com> Signed-off-by: Moni Shoua <monis@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/ehca: Make device table externally visibleJoachim Fenkes
This gives ehca an autogenerated modalias and therefore enables automatic loading. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: add LRO supportVladimir Sokolovsky
Add "ipoib_use_lro" module parameter to enable LRO and an "ipoib_lro_max_aggr" module parameter to set the max number of packets to be aggregated. Make LRO controllable and LRO statistics accessible through ethtool. Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il> Signed-off-by: Eli Cohen <eli@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB: Use multicast loopback blocking if availableRon Livne
Set IB_QP_CREATE_BLOCK_MULTICAST_LOOPBACK for IPoIB's UD QPs if supported by the underlying device. This creates an improvement of up to 39% in bandwidth when sending multicast packets with IPoIB, and an improvment of 12% in cpu usage. Signed-off-by: Ron Livne <ronli@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/mlx4: Add support for blocking multicast loopback packetsRon Livne
Add support for handling the IB_QP_CREATE_MULTICAST_BLOCK_LOOPBACK flag by using the per-multicast group loopback blocking feature of mlx4 hardware. Signed-off-by: Ron Livne <ronli@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/core: Add support for multicast loopback blockingRon Livne
This patch also adds a creation flag for QPs, IB_QP_CREATE_MULTICAST_BLOCK_LOOPBACK, which when set means that multicast sends from the QP to a group that the QP is attached to will not be looped back to the QP's receive queue. This can be used to save receive resources when a consumer does not want a local copy of multicast traffic; for example IPoIB must waste CPU time throwing away such local copies of multicast traffic. This patch also adds a device capability flag that shows whether a device supports this feature or not. Signed-off-by: Ron Livne <ronli@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/cxgb3: Add support for protocol statisticsSteve Wise
- Add a new rdma ctl command called RDMA_GET_MIB to the cxgb3 low level driver to obtain the protocol mib from the rnic hardware. - Add new iw_cxgb3 provider method to get the MIB from the low level driver. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/core: Add iWARP protocol statistics attributes in sysfsSteve Wise
This patch adds a sysfs attribute group called "proto_stats" under /sys/class/infiniband/$device/ and populates this group with protocol statistics if they exist for a given device. Currently, only iWARP stats are defined, but the code is designed to allow InfiniBand protocol stats if they become available. These stats are per-device and more importantly -not- per port. Details: - Add union rdma_protocol_stats in ib_verbs.h. This union allows defining transport-specific stats. Currently only iwarp stats are defined. - Add struct iw_protocol_stats to define the current set of iwarp protocol stats. - Add new ib_device method called get_proto_stats() to return protocol statistics. - Add logic in core/sysfs.c to create iwarp protocol stats attributes if the device is an RNIC and has a get_proto_stats() method. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IPoIB/cm: Fix racy use of receive WR/SGL in ipoib_cm_post_receive_nonsrq()Roland Dreier
For devices that don't support SRQs, ipoib_cm_post_receive_nonsrq() is called from both ipoib_cm_handle_rx_wc() and ipoib_cm_nonsrq_init_rx(), and these two callers are not synchronized against each other. However, ipoib_cm_post_receive_nonsrq() always reuses the same receive work request and scatter list structures, so multiple callers can end up stepping on each other, which leads to posting garbled work requests. Fix this by having the caller pass in the ib_recv_wr and ib_sge structures to use, and allocating new local structures in ipoib_cm_nonsrq_init_rx(). Based on a patch by Pradeep Satyanarayana <pradeep@us.ibm.com> and David Wilder <dwilder@us.ibm.com>, with debugging help from Hoang-Nam Nguyen <hnguyen@de.ibm.com>. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14RDMA/cma: Add missing newlines to printk()sRoland Dreier
Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Sean Hefty <sean.hefty@intel.com>
2008-07-14RDMA/cxgb3: Remove write-only iwch_rnic_attributes fieldsRoland Dreier
The members struct iwch_rnic_attributes.vendor_id and .vendor_part_id are write-only, so we might as well get rid of them. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Steve Wise <swise@opengridcomputing.com>
2008-07-14RDMA/cxgb3: Fix up some ib_device_attr fieldsSteve Wise
- set fw_ver - set hw_ver - set max_qp_wr to something reasonable - set max_cqe to something reasonable Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/ehca: In case of lost interrupts, trigger EOI to reenable interruptsStefan Roscher
During corner case testing, we noticed that some versions of ehca do not properly transition to interrupt done in special load situations. This can be resolved by periodically triggering EOI through H_EOI, if EQEs are pending. Signed-off-by: Stefan Roscher <stefan.roscher@de.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/ehca: Reject receive work requests if QP is in RESET stateJoachim Fenkes
2008-07-14IB/mlx4: Remove extra code for RESET->ERR QP state transitionRoland Dreier
Commit 65adfa91 ("IB/mlx4: Fix RESET to RESET and RESET to ERROR transitions") added some extra code to handle a QP state transition from RESET to ERROR. However, the latest 1.2.1 version of the IB spec has clarified that this transition is actually not allowed, so we can remove this extra code again. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/mthca: Remove extra code for RESET->ERR QP state transitionRoland Dreier
Commit b18aad71 ("IB/mthca: Fix RESET to ERROR transition") added some extra code to handle a QP state transition from RESET to ERROR. However, the latest 1.2.1 version of the IB spec has clarified that this transition is actually not allowed, so we can remove this extra code again. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-14IB/core: Reset to error QP state transition is not allowedRalph Campbell
I was reviewing the QP state transition diagram in the IB 1.2.1 spec and the code for qp_state_table[], and noticed that the code allows a QP to be modified from IB_QPS_RESET to IB_QPS_ERR whereas the notes for figure 124 (pg 457) specifically says that this transition isn't allowed. This is a clarification from earlier versions of the IB spec, which were ambiguous in this area and suggested that the RESET to ERR transition was allowed. Fix up the qp_state_table[] to make RESET->ERR not allowed. Signed-off-by: Ralph Campbell <ralph.campbell@qlogic.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
