This looks like a simple typo that has gone unnoticed for some time. The
impact is relatively low but it's clearly wrong.
Signed-off-by: John Heffner <johnwheffner@gmail.com>
drivers/net/pcmcia/pcnet_cs.c
net/caif/caif_socket.c
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Effect:
Slave Interface: eth5
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: XX:XX:XX:XX:XX:XX
Slave queue ID: 0
Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl>
This is the second step for neighbour RCU conversion.
(first was commit d6bf7817 : RCU conversion of neigh hash table)
neigh_lookup() becomes lockless, but still take a reference on found
neighbour. (no more read_lock()/read_unlock() on tbl->lock)
struct neighbour gets an additional rcu_head field and is freed after an
RCU grace period.
Future work would need to eventually not take a reference on neighbour
for temporary dst (DST_NOCACHE), but this would need dst->_neighbour to
use a noref bit like we did for skb->_dst.
When an interface was enslaved when it was down, bonding thinks
it has speed -1 even after it goes up. This leads into selecting
a wrong active interface in active/backup mode on mixed 10G/1G or
1G/100M environment.
before:
bonding: bond0: link status definitely up for interface eth5, 100 Mbps full duplex.
bonding: bond0: link status definitely up for interface eth0, 100 Mbps full duplex.
after:
bonding: bond0: link status definitely up for interface eth5, 10000 Mbps full duplex.
bonding: bond0: link status definitely up for interface eth0, 1000 Mbps full duplex.
before:
after:
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Client statistics need to be initialized to -1
This patch does not include any functional changes.
The changes are: empty lines, indentation and comments.
Return proper L2 and L5 SPQ (slow path queue) credits. Previously, all
SPQ events were counted as L5 types.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Decide which interrupt mode to use (MSI-X, MSI, INTa) only once in probe() and
initialize appropriate structures.
57712 HW supported with same set of features as for 57710/57711
The field is now accessed from different contexts.
MF (multi-function) mode supported not only by 57711E (E1H) devices,
but also by coming 57712E, then we use more generic names.
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
New firmware files for all bnx2x devices
Initialize the rings only during cnic_uio_open() and shut them down
during cnic_uio_close(). Check for the new bit CNIC_LCL_FL_RINGS_INITED
before checking for ring interrupt.
The pfid (physical function ID) is the same as PCI function on production
devices. The pfid for future devices will be different and will be used
for internal memory offsets.
Preparation work for upcoming firmware interface changes.
Commit 2ddaad397c47de012dfb956b0c05540da1a0dde5 entitled "tg3: Use
netif_set_real_num_{rx,tx}_queues()" added a new call to
netif_set_real_num_rx_queues in tg3_enable_msix(). This call also needs
to be added to the legacy path to correctly reflect the actual number of
rx queues.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus:
MIPS: Octeon: Place cnmips_cu2_setup in __init memory.
MIPS: Don't place cu2 notifiers in __cpuinitdata
MIPS: Calculate VMLINUZ_LOAD_ADDRESS based on the length of vmlinux.bin
MIPS: Alchemy: Resolve prom section mismatches
MIPS: Fix syscall 64 bit number comments.
MIPS: Hookup fanotify_init, fanotify_mark, and prlimit64 syscalls.
MIPS: TX49xx: Rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN
MIPS: N32: Fix getdents64 syscall for n32
MIPS: Remove pr_<level> uses of KERN_<level>
MIPS: PNX8550: Sort out machine halt, restart and powerdown functions.
MIPS: GIC: Remove dependencies from Malta files.
MIPS: Kconfig: Fix and clarify kconfig help text for VSMP and SMTC.
MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask.
MIPS: Audit: Fix hang in entry.S.
MIPS: Document why RELOC_HIDE is there.
MIPS: Octeon: Determine if helper needs to be built
MIPS: Use generic atomic64 for 32-bit kernels
MIPS: RM7000: Symbol should be static
MIPS: kspd: Adjust confusing if indentation
MIPS: Fix a typo.
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
writeback: always use sb->s_bdi for writeback purposes
git://xenbits.xen.org/people/sstabellini/linux-pvhvm
* 'v2.6.36-rc6-urgent-fixes' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm:
xen: do not initialize PV timers on HVM if !xen_have_vector_callback
xen: do not set xenstored_ready before xenbus_probe on hvm
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: Initialize total_len in fuse_retrieve()
As suggested by Stephen Hemminger:
1) Made functions and data structures static wherever possible.
2) Removed unused code.
Signed-off-by: Debashis Dutt <ddutt@brocade.com>
Signed-off-by: Rasesh Mody <rmody@brocade.com>
This fix handles the case when IRQ handler is called (for shared IRQs)
even before the driver is ready to handle interrupts.
fib_lookup() converted to be called in RCU protected context, no
reference taken and released on a contended cache line (fib_clntref)
fib_table_lookup() and fib_semantic_match() get an additional parameter.
struct fib_info gets an rcu_head field, and is freed after an rcu grace
period.
Stress test :
(Sending 160.000.000 UDP frames on same neighbour,
IP route cache disabled, dual E5540 @2.53GHz,
32bit kernel, FIB_HASH) (about same results for FIB_TRIE)
Before patch :
real 1m31.199s
user 0m13.761s
sys 23m24.780s
After patch:
real 1m5.375s
user 0m14.997s
sys 15m50.115s
Before patch Profile :
13044.00 15.4% __ip_route_output_key vmlinux
8438.00 10.0% dst_destroy vmlinux
5983.00 7.1% fib_semantic_match vmlinux
5410.00 6.4% fib_rules_lookup vmlinux
4803.00 5.7% neigh_lookup vmlinux
4420.00 5.2% _raw_spin_lock vmlinux
3883.00 4.6% rt_set_nexthop vmlinux
3261.00 3.9% _raw_read_lock vmlinux
2794.00 3.3% fib_table_lookup vmlinux
2374.00 2.8% neigh_resolve_output vmlinux
2153.00 2.5% dst_alloc vmlinux
1502.00 1.8% _raw_read_lock_bh vmlinux
1484.00 1.8% kmem_cache_alloc vmlinux
1407.00 1.7% eth_header vmlinux
1406.00 1.7% ipv4_dst_destroy vmlinux
1298.00 1.5% __copy_from_user_ll vmlinux
1174.00 1.4% dev_queue_xmit vmlinux
1000.00 1.2% ip_output vmlinux
After patch Profile :
13712.00 15.8% dst_destroy vmlinux
8548.00 9.9% __ip_route_output_key vmlinux
7017.00 8.1% neigh_lookup vmlinux
4554.00 5.3% fib_semantic_match vmlinux
4067.00 4.7% _raw_read_lock vmlinux
3491.00 4.0% dst_alloc vmlinux
3186.00 3.7% neigh_resolve_output vmlinux
3103.00 3.6% fib_table_lookup vmlinux
2098.00 2.4% _raw_read_lock_bh vmlinux
2081.00 2.4% kmem_cache_alloc vmlinux
2013.00 2.3% _raw_spin_lock vmlinux
1763.00 2.0% __copy_from_user_ll vmlinux
1763.00 2.0% ip_output vmlinux
1761.00 2.0% ipv4_dst_destroy vmlinux
1631.00 1.9% eth_header vmlinux
1440.00 1.7% _raw_read_unlock_bh vmlinux
Reference results, if IP route cache is enabled :
real 0m29.718s
user 0m10.845s
sys 7m37.341s
25213.00 29.5% __ip_route_output_key vmlinux
9011.00 10.5% dst_release vmlinux
4817.00 5.6% ip_push_pending_frames vmlinux
4232.00 5.0% ip_finish_output vmlinux
3940.00 4.6% udp_sendmsg vmlinux
3730.00 4.4% __copy_from_user_ll vmlinux
3716.00 4.4% ip_route_output_flow vmlinux
2451.00 2.9% __xfrm_lookup vmlinux
2221.00 2.6% ip_append_data vmlinux
1718.00 2.0% _raw_spin_lock_bh vmlinux
1655.00 1.9% __alloc_skb vmlinux
1572.00 1.8% sock_wfree vmlinux
1345.00 1.6% kfree vmlinux
caif_connect() might dereference a netdevice after dev_put() it.
It also doesnt check dev_get_by_index() return value and could
dereference a NULL pointer.
Fix it, using RCU to avoid taking a reference.
CC: Sjur Braendeland <sjur.brandeland@stericsson.com>
Allow sysadmins to configure the number of multicast
membership report sent on a link failure event.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
The IGMP specs states that if the system receives a
membership report, it shouldn't send another for the
next minute. However, if a link failure happens right
after that, the backup slave and the switch connected
to this slave will not know about the multicast and
the traffic will hang for about a minute.
This patch fixes it to rejoin multicast groups immediately
after a failover restoring the multicast traffic.
During a failover, the IGMP membership is sent to update
the switch restoring the traffic, but it misses groups added
to VLAN devices running on top of bonding devices.
This patch changes it to iterate over all VLAN devices
on top of it sending IGMP memberships too.
Removing the msleep() call in check_sqs() function, and replacing by a wait queue.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
This patch just remove a msleep loop and change to wait queue,
making the code cleaner.
Following patch fixes warnings reported by `make namespacecheck`
Reported by Stephen Hemminger
CC: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Acked-by: Greg Rose <greg.v.rose@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
Fix a WARN_ON failure in bond_masters sysfs file
Got a report of this warning recently
bonding: bond0 is being created...
WARNING: at fs/proc/generic.c:590 proc_register+0x14d/0x185()
Hardware name: ProLiant BL465c G1
proc_dir_entry 'bonding/bond0' already registered
Modules linked in: bonding ipv6 tg3 bnx2 shpchp amd64_edac_mod edac_core
ipmi_si
ipmi_msghandler serio_raw i2c_piix4 k8temp edac_mce_amd hpwdt microcode hpsa
cc
iss radeon ttm drm_kms_helper drm i2c_algo_bit i2c_core [last unloaded:
scsi_wai
t_scan]
Pid: 935, comm: ifup-eth Not tainted 2.6.33.5-124.fc13.x86_64 #1
Call Trace:
[<ffffffff8104b54c>] warn_slowpath_common+0x77/0x8f
[<ffffffff8104b5b1>] warn_slowpath_fmt+0x3c/0x3e
[<ffffffff8114bf0b>] proc_register+0x14d/0x185
[<ffffffff8114c20c>] proc_create_data+0x87/0xa1
[<ffffffffa0211e9b>] bond_create_proc_entry+0x55/0x95 [bonding]
[<ffffffffa0215e5d>] bond_init+0x95/0xd0 [bonding]
[<ffffffff8138cd97>] register_netdevice+0xdd/0x29e
[<ffffffffa021240b>] bond_create+0x8e/0xb8 [bonding]
[<ffffffffa021c4be>] bonding_store_bonds+0xb3/0x1c1 [bonding]
[<ffffffff812aec85>] class_attr_store+0x27/0x29
[<ffffffff8115423d>] sysfs_write_file+0x10f/0x14b
[<ffffffff81101acf>] vfs_write+0xa9/0x106
[<ffffffff81101be2>] sys_write+0x45/0x69
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
---[ end trace a677c3f7f8b16b1e ]---
bonding: Bond creation failed.
It happens because a user space writer to bond_master can try to
register an already existing bond interface name. Fix it by teaching
bond_create to check for the existance of devices with that name first
in cases where a non-NULL name parameter has been passed in
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Since powerpc uses -Werror on arch powerpc, the build was broken like
this:
cc1: warnings being treated as errors
arch/powerpc/kernel/module.c: In function 'module_finalize':
arch/powerpc/kernel/module.c:66: error: unused variable 'err'
Skge devices installed on some Gigabyte motherboards are not able to
perform 64 dma correctly due to board PCI implementation, so limit
DMA to 32bit if such boards are detected.
Bug was reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=447489
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Tested-by: Luya Tshimbalanga <luya@fedoraproject.org>
Userspace applications can already request to receive timestamps with:
setsockopt(sockfd, SOL_SOCKET, SO_TIMESTAMP, ...)
Although setsockopt() returns zero (success), timestamps are not added to the
ancillary data. This patch fixes that on SOCK_DGRAM and SOCK_SEQPACKET Unix
sockets.
Signed-off-by: Alban Crequy <alban.crequy@collabora.co.uk>
David
This is the first step for RCU conversion of neigh code.
Next patches will convert hash_buckets[] and "struct neighbour" to RCU
protected objects.
[PATCH net-next] net neigh: RCU conversion of neigh hash table
Instead of storing hash_buckets, hash_mask and hash_rnd in "struct
neigh_table", a new structure is defined :
struct neigh_hash_table {
struct neighbour **hash_buckets;
unsigned int hash_mask;
__u32 hash_rnd;
struct rcu_head rcu;
And "struct neigh_table" has an RCU protected pointer to such a
neigh_hash_table.
This means the signature of (*hash)() function changed: We need to add a
third parameter with the actual hash_rnd value, since this is not
anymore a neigh_table field.
neigh_delete() and neigh_add() dont need to touch device refcount,
we hold RTNL when calling them, so device cannot disappear under us.
In various situations, a device provides a packet to our stack and we
drop it before it enters protocol stack :
- softnet backlog full (accounted in /proc/net/softnet_stat)
- bad vlan tag (not accounted)
- unknown/unregistered protocol (not accounted)
We can handle a per-device counter of such dropped frames at core level,
and automatically adds it to the device provided stats (rx_dropped), so
that standard tools can be used (ifconfig, ip link, cat /proc/net/dev)
This is a generalization of commit 8990f468a (net: rx_dropped
accounting), thus reverting it.
