These variables are only used in their source files, so make them static.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Commit f06febc96ba8e0af80bcc3eaec0a109e88275fac ("timers: fix itimer/
many thread hang") introduced a new task_cputime interface and
subsequently only converted binfmt_elf over to it. This results in the
build for binfmt_elf_fdpic blowing up given that p->signal->{u,s}time
have disappeared from underneath us.
Apply the same trivial fix from binfmt_elf to binfmt_elf_fdpic.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Removed duplicated #include <linux/vmalloc.h> in mm/vmalloc.c and
"internal.h" in mm/memory.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
We're trying to keep the !CONFIG_SHMEM tiny-shmem.c (using ramfs without
swap) in synch with CONFIG_SHMEM shmem.c (and mpm is preparing patches
to combine them). I was glad to see EXPORT_SYMBOL_GPL(shmem_file_setup)
go into shmem.c, but why not support DRM-GEM when !CONFIG_SHMEM too?
But caution says still depend on MMU, since !CONFIG_MMU is.. different.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Acked-by: Dave Airlie <airlied@redhat.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
commit 9b7530cc329eb036cfa589930c270e85031f554c ("i915: cleanup coding
horrors in i915_gem_gtt_pwrite()")
broke the i386 build for CONFIG_HIGHMEM=y.
Caught by automatic testing http://www.tglx.de/autoqa-logs/000137-0006-0001.log
[ My bad. It's the same patch I sent out earlier, nobody noticed then either.. ]
powerpc doesn't use the generic WARN_ON infrastructure. The newly
introduced WARN() as a result didn't print the message, this patch adds
the printk for this specific case.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This fixes
kernel/kexec.c: In function 'crash_save_vmcoreinfo_init':
kernel/kexec.c:1374: error: 'vmlist' undeclared (first use in this function)
kernel/kexec.c:1374: error: (Each undeclared identifier is reported only once
kernel/kexec.c:1374: error: for each function it appears in.)
kernel/kexec.c:1410: error: invalid use of undefined type 'struct vm_struct'
make[1]: *** [kernel/kexec.o] Error 1
Signed-off-by: Tony Luck <tony.luck@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: convert to generic compat_sys_ptrace
parisc: add rtc platform driver
parisc: initialize unwinder much earlier
parisc: add new syscalls
parisc: hijack jump to start_kernel
parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlocked
parisc: move include/asm-parisc to arch/parisc/include/asm
parisc: move pdc_result to real2.S
parisc: unify CCIO_COLLECT_STATS implementation
parisc: add arch/parisc/kernel/.gitignore
parisc: ropes.h - fix <asm-parisc/*> -> <asm/*>
parisc: parisc-agp - fix <asm-parisc/*> -> <asm/*>
Resolve remove/rename conflict: include/asm-parisc/a.out.h is no longer
relevant.
This gets rid of an annoying warning in ehci-hcd.c when DEBUG isn't
enabled:
warning: label 'err_debug' defined but not used
by moving it inside the already-existing #ifdef DEBUG, so that it
matches the goto. And now my regular build is warning-free again.
Yes, this will probably be switched over to a cleaner model anyway, but
in the meantime I don't want to see the 'unused variable' warnings that
come from the disgusting #ifdef code. Make the special case be a nice
inlien function of its own, clean up the code, and make the warning go
away.
I wish people didn't write code that gets (valid) warnings from the
compiler, but I'll limit my fixes to code that I actually care about (in
this case just because I see the warning and it annoys me).
Use "%zd" for size_t, and make sure to have a space between the numbers
instead of depending on the field width.
I don't like warnings in my default targeted build.
* 'bkl-removal' of git://git.lwn.net/linux-2.6:
UIO: BKL removal
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (41 commits)
PCI: fix pci_ioremap_bar() on s390
PCI: fix AER capability check
PCI: use pci_find_ext_capability everywhere
PCI: remove #ifdef DEBUG around dev_dbg call
PCI hotplug: fix get_##name return value problem
PCI: document the pcie_aspm kernel parameter
PCI: introduce an pci_ioremap(pdev, barnr) function
powerpc/PCI: Add legacy PCI access via sysfs
PCI: Add ability to mmap legacy_io on some platforms
PCI: probing debug message uniformization
PCI: support PCIe ARI capability
PCI: centralize the capabilities code in probe.c
PCI: centralize the capabilities code in pci-sysfs.c
PCI: fix 64-vbit prefetchable memory resource BARs
PCI: replace cfg space size (256/4096) by macros.
PCI: use resource_size() everywhere.
PCI: use same arg names in PCI_VDEVICE comment
PCI hotplug: rpaphp: make debug var unique
PCI: use %pF instead of print_fn_descriptor_symbol() in quirks.c
PCI: fix hotplug get_##name return value problem
* 'tracing-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (131 commits)
tracing/fastboot: improve help text
tracing/stacktrace: improve help text
tracing/fastboot: fix initcalls disposition in bootgraph.pl
tracing/fastboot: fix bootgraph.pl initcall name regexp
tracing/fastboot: fix issues and improve output of bootgraph.pl
tracepoints: synchronize unregister static inline
tracepoints: tracepoint_synchronize_unregister()
ftrace: make ftrace_test_p6nop disassembler-friendly
markers: fix synchronize marker unregister static inline
tracing/fastboot: add better resolution to initcall debug/tracing
trace: add build-time check to avoid overrunning hex buffer
ftrace: fix hex output mode of ftrace
tracing/fastboot: fix printk format typo in boot tracer
ftrace: return an error when setting a nonexistent tracer
ftrace: make some tracers reentrant
ring-buffer: make reentrant
ring-buffer: move page indexes into page headers
tracing/fastboot: only trace non-module initcalls
ftrace: move pc counter in irqtrace
Manually fix conflicts:
- init/main.c: initcall tracing
- kernel/module.c: verbose level vs tracepoints
- scripts/bootgraph.pl: fallout from cherry-picking commits.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86 ACPI: fix breakage of resume on 64-bit UP systems with SMP kernel
Introduce is_vmalloc_or_module_addr() and use with DEBUG_VIRTUAL
This merges branches irq/genirq, irq/sparseirq-v4, timers/hpet-percpu
and x86/uv.
The sparseirq branch is just preliminary groundwork: no sparse IRQs are
actually implemented by this tree anymore - just the new APIs are added
while keeping the old way intact as well (the new APIs map 1:1 to
irq_desc[]). The 'real' sparse IRQ support will then be a relatively
small patch ontop of this - with a v2.6.29 merge target.
* 'genirq-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (178 commits)
genirq: improve include files
intr_remapping: fix typo
io_apic: make irq_mis_count available on 64-bit too
genirq: fix name space collisions of nr_irqs in arch/*
genirq: fix name space collision of nr_irqs in autoprobe.c
genirq: use iterators for irq_desc loops
proc: fixup irq iterator
genirq: add reverse iterator for irq_desc
x86: move ack_bad_irq() to irq.c
x86: unify show_interrupts() and proc helpers
x86: cleanup show_interrupts
genirq: cleanup the sparseirq modifications
genirq: remove artifacts from sparseirq removal
genirq: revert dynarray
genirq: remove irq_to_desc_alloc
genirq: remove sparse irq code
genirq: use inline function for irq_to_desc
genirq: consolidate nr_irqs and for_each_irq_desc()
x86: remove sparse irq from Kconfig
genirq: define nr_irqs for architectures with GENERIC_HARDIRQS=n
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
m32r: fix build due to notify_cpu_starting() change
powerpc: fix linux-next build failure
* 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
fix documentation of sysrq-q really
Fix documentation of sysrq-q
timer_list: add base address to clock base
timer_list: print cpu number of clockevents device
timer_list: print real timer address
NOHZ: restart tick device from irq_enter()
NOHZ: split tick_nohz_restart_sched_tick()
NOHZ: unify the nohz function calls in irq_enter()
timers: fix itimer/many thread hang, fix
timers: fix itimer/many thread hang, v3
ntp: improve adjtimex frequency rounding
timekeeping: fix rounding problem during clock update
ntp: let update_persistent_clock() sleep
hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds
posix-timers: lock_timer: make it readable
posix-timers: lock_timer: kill the bogus ->it_id check
posix-timers: kill ->it_sigev_signo and ->it_sigev_value
posix-timers: sys_timer_create: cleanup the error handling
posix-timers: move the initialization of timer->sigq from send to create path
posix-timers: sys_timer_create: simplify and s/tasklist/rcu/
Fix trivial conflicts due to sysrq-q description clahes in
Documentation/sysrq.txt and drivers/char/sysrq.c
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (36 commits)
ide: re-add TRM290 fix lost during ide_build_dmatable() cleanup
scc_pata: kill unused variables
sgiioc4: kill duplicate ioremap()
sgiioc4: kill useless address checks
delkin_cb: add PM support
ide: remove broken hpt34x driver
ide-floppy: remove idefloppy_floppy_t typedef
sgiioc4: remove maskproc() method
hpt366: cleanup maskproc() method
ide: mask interrupt in ide_config_drive_speed()
hpt366: fix compile warning
ide: remove unused macros from <asm-parisc/ide.h>
ide: remove M68K_IDE_SWAPW define from <asm-m68k/ide.h>
ide: remove dead <asm-arm/arch-sa1100/ide.h>
ide: fix support for IDE PCI controllers using MMIO on frv
ide-cd: remove stale comment
ide-cd: small drive type print fix
ide-cd: debug log enhancements
ide: add generic ATA/ATAPI disk driver
ide: allow device drivers to specify per-device type /proc settings
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
fsldma: allow Freescale Elo DMA driver to be compiled as a module
fsldma: remove internal self-test from Freescale Elo DMA driver
drivers/dma/dmatest.c: switch a GFP_ATOMIC to GFP_KERNEL
dmatest: properly handle duplicate DMA channels
drivers/dma/ioat_dma.c: drop code after return
async_tx: make async_tx_run_dependencies() easier to read
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] ib700wdt.c - fix buffer_underflow bug
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: implement nonseekable open
fuse: add include protectors
fuse: config description improvement
fuse: add missing fuse_request_free
fuse: fix SEEK_END incorrectness
A consolidated implementation will provide this generically through
asm/byteorder, remove direct includes to avoid breakage when the
changeover to the new implementation occurs.
This hunk was lost from commit 1d8cca44b6a244b7e378546d719041819049a0f9
("byteorder: provide swabb.h generically in asm/byteorder.h")
Update assorted email addresses and related info to point
to a single current, valid address.
additionally
- trivial CREDITS entry updates. (Not that this file means much any more)
- remove arjans dead redhat.com address from powernow driver
Signed-off-by: Dave Jones <davej@redhat.com>
Use fs/*/Kconfig more, which is good because everything related to one
filesystem is in one place and fs/Kconfig is quite fat.
Commit 7c08c9ae0c145807c0dae4a55f240fa3d4fd5262 ("efifb/imacfb
consolidation + hardware support") claimed to remove imacfb entirely and
merge its DMI table into the efifb driver. So far so good, but the diff
actually ended up just generating an empty file instead of removing it.
[ Technical reason: the patch header looked like
diff -puN drivers/video/imacfb.c~efifb-imacfb-consolidation-hardware-support drivers/video/imacfb.c
--- a/drivers/video/imacfb.c~efifb-imacfb-consolidation-hardware-support
+++ a/drivers/video/imacfb.c
@@ -1,376 +0,0 @@
which git will think is a truncation, not a delete. Git wants to see a
target of /dev/null to consider it a delete. ]
So remove it properly.
s390 doesn't have ioremap_*, so protect the definition of the new
pci_ioremap_bar function with CONFIG_HAS_IOMEM to avoid build breakage.
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The generated 'capflags.c' file wasn't properly ignored, and the list of
files in scripts/basic/ wasn't up-to-date.
The 'use pci_find_ext_capability everywhere' cleanup brought a new bug,
which makes the AER stop working. Fix it by actually using find_ext_cap
instead of just find_cap. Drop the unused config space size define while
we're at it.
Signed-off-by: Yu Zhao <yu.zhao@intel.com>
Remove some open coded (and buggy) versions of pci_find_ext_capability
in favor of the real routine in the PCI core.
Tested-by: Tomasz Czernecki <czernecki@gmail.com>
Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
No longer needed since we don't use the function symbol stuff anymore.
The commit 356a9d6f3dd283f83861adf1ac909879f0e66411 (PCI: fix hotplug
get_##name return value problem) doesn't seem to be merged properly.
Because of this, PCI hotplug no longer works (Read/Write PCI hotplug
files always returns -ENODEV).
This patch fixes wrong check of try_module_get() return value check in
get_##name().
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
It can be handy so make sure people know about it.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
A common thing in many PCI drivers is to ioremap() an entire bar. This
is a slightly fragile thing right now, needing both an address and a
size, and many driver writers do.. various things there.
This patch introduces an pci_ioremap() function taking just a PCI device
struct and the bar number as arguments, and figures this all out itself,
in one place. In addition, we can add various sanity checks to this
function (the patch already checks to make sure that the bar in question
really is a MEM bar; few to no drivers do that sort of thing).
Hopefully with this type of API we get less chance of mistakes in
drivers with ioremap() operations.
This patch adds support for legacy_io and legacy_mem files in
bus class directories in sysfs for powerpc
This adds the ability to mmap legacy IO space to the legacy_io files
in sysfs on platforms that support it. This will allow to clean up
X to use this instead of /dev/mem for legacy IO accesses such as
those performed by Int10.
While at it I moved pci_create/remove_legacy_files() to pci-sysfs.c
where I think they belong, thus making more things statis in there
and cleaned up some spurrious prototypes in the ia64 pci.h file
This patch uniformizes PCI probing debug boot messages with dev_printk()
intead of manual printk()
It changes adress range output from [%llx, %llx] to [%#llx-%#llx], like
in pci_request_region().
For example, it goes from the mixed-style:
PCI: 0000:00:1b.0 reg 10 64bit mmio: [f4280000, f4283fff]
pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
to uniform:
pci 0000:00:1b.0: reg 10 64bit mmio: [0xf4280000-0xf4283fff]
This patch has been runtime tested, boot log messages diffed, everything
looks OK.
Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Vincent Legoll <vincent.legoll@gmail.com>
This patch adds support for PCI Express Alternative Routing-ID
Interpretation (ARI) capability.
The ARI capability extends the Function Number field of the PCI Express
Endpoint by reusing the Device Number which is otherwise hardwired to 0.
With ARI, an Endpoint can have up to 256 functions.
This patch centralizes the initialization and release functions of
various PCI capabilities in probe.c, which makes the introduction
of new capability support functions cleaner in the future.
This patch centralizes functions used to add and remove sysfs entries
for various capabilities. With this cleanup, the code is more readable
and easier for adding new capability related functions.
Since patch 6ac665c63dcac8fcec534a1d224ecbb8b867ad59 my infiniband
controller hasn't worked. This is because it has 64-bit prefetchable
memory, which was mistakenly being taken to be 32-bit memory. The
resource flags in this case are PCI_BASE_ADDRESS_MEM_TYPE_64 |
PCI_BASE_ADDRESS_MEM_PREFETCH.
This patch checks only for the PCI_BASE_ADDRESS_MEM_TYPE_64 bit; thus
whether the region is prefetchable or not is ignored. This fixes my
Infiniband.
Reviewed-by: Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au>
This is a cleanup that changes all PCI configuration space size
representations to the macros (PCI_CFG_SPACE_SIZE and
PCI_CFG_SPACE_EXP_SIZE). And the macros are also moved from
drivers/pci/probe.c to drivers/pci/pci.h.
This is a cleanup that replaces the resource calculation formula with
resource_size().
This cleanup makes the argument names in PCI_VDEVICE comment consistent
with those used in its definition.
Change debug variable name to one more unique to this driver.
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Use %pF instead of print_fn_descriptor_symbol() in quirks.c to get the name of
the hook we're calling.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Currently, get_##name in pci_hotplug_core.c will return 0 if module
unload wins the race between unload & reading the hotplug file. Fix
that case to return -ENODEV like it should.
Reviewed-by: Alex Chiang <achiang@hp.com>
Get rid of the second definition of dev which hides the earlier one in
the argument list and causes a warning from sparse.
The current MSI-HOWTO.txt says that device drivers should not request the
memory space that contains MSI-X tables. This is because the original
MSI-X implementation did a request_mem_region() on this space, but that
code was removed long ago (in the pre-git era, in fact). Years after the
code was changed, we might as well clean up the documention to avoid a
confusing mention of requesting regions: drivers using MSI-X can just use
pci_request_regions() just like any other driver, and so there's no need
for MSI-HOWTO.txt to talk about this at all.
Signed-off-by: Roland Dreier <roland@digitalvampire.org>
