2008-10-10Merge branch 'linus' into x86/pat2Ingo Molnar
Conflicts: arch/x86/mm/init_64.c
2008-10-10x86, cpa: make the kernel physical mapping initialization a two pass ↵Suresh Siddha
sequence, fix Jeremy Fitzhardinge wrote: > I'd noticed that current tip/master hasn't been booting under Xen, and I > just got around to bisecting it down to this change. > > commit 065ae73c5462d42e9761afb76f2b52965ff45bd6 > Author: Suresh Siddha <suresh.b.siddha@intel.com> > > x86, cpa: make the kernel physical mapping initialization a two pass sequence > > This patch is causing Xen to fail various pagetable updates because it > ends up remapping pagetables to RW, which Xen explicitly prohibits (as > that would allow guests to make arbitrary changes to pagetables, rather > than have them mediated by the hypervisor). Instead of making init a two pass sequence, to satisfy the Intel's TLB Application note (developer.intel.com/design/processor/applnots/317080.pdf Section 6 page 26), we preserve the original page permissions when fragmenting the large mappings and don't touch the existing memory mapping (which satisfies Xen's requirements). Only open issue is: on a native linux kernel, we will go back to mapping the first 0-1GB kernel identity mapping as executable (because of the static mapping setup in head_64.S). We can fix this in a different patch if needed. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, pat: cleanupsIngo Molnar
clean up recently added code to be more consistent with other x86 code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86: fix pagetable init 64-bit breakageSuresh Siddha
Fix _end alignment check - can trigger a crash if _end happens to be on a page boundary. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86: track memtype for RAM in page structSuresh Siddha
Track the memtype for RAM pages in page struct instead of using the memtype list. This avoids the explosion in the number of entries in memtype list (of the order of 20,000 with AGP) and makes the PAT tracking simpler. We are using PG_arch_1 bit in page->flags. We still use the memtype list for non RAM pages. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: srlz cpa(), global flush tlb after splitting big page and before ↵Suresh Siddha
doing cpa Do a global flush tlb after splitting the large page and before we do the actual change page attribute in the PTE. With out this, we violate the TLB application note, which says "The TLBs may contain both ordinary and large-page translations for a 4-KByte range of linear addresses. This may occur if software modifies the paging structures so that the page size used for the address range changes. If the two translations differ with respect to page frame or attributes (e.g., permissions), processor behavior is undefined and may be implementation-specific." And also serialize cpa() (for !DEBUG_PAGEALLOC which uses large identity mappings) using cpa_lock. So that we don't allow any other cpu, with stale large tlb entries change the page attribute in parallel to some other cpu splitting a large page entry along with changing the attribute. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: remove cpa pool codeSuresh Siddha
Interrupt context no longer splits large page in cpa(). So we can do away with cpa memory pool code. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: no need to check alias for __set_pages_p/__set_pages_npSuresh Siddha
No alias checking needed for setting present/not-present mapping. Otherwise, we may need to break large pages for 64-bit kernel text mappings (this adds to complexity if we want to do this from atomic context especially, for ex: with CONFIG_DEBUG_PAGEALLOC). Let's keep it simple! Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: dont use large pages for kernel identity mapping with DEBUG_PAGEALLOCSuresh Siddha
Don't use large pages for kernel identity mapping with DEBUG_PAGEALLOC. This will remove the need to split the large page for the allocated kernel page in the interrupt context. This will simplify cpa code(as we don't do the split any more from the interrupt context). cpa code simplication in the subsequent patches. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: make the kernel physical mapping initialization a two pass sequenceSuresh Siddha
In the first pass, kernel physical mapping will be setup using large or small pages but uses the same PTE attributes as that of the early PTE attributes setup by early boot code in head_[32|64].S After flushing TLB's, we go through the second pass, which setups the direct mapped PTE's with the appropriate attributes (like NX, GLOBAL etc) which are runtime detectable. This two pass mechanism conforms to the TLB app note which says: "Software should not write to a paging-structure entry in a way that would change, for any linear address, both the page size and either the page frame or attributes." Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: remove USER permission from the very early identity mapping attributeSuresh Siddha
remove USER from the PTE/PDE attributes for the very early identity mapping. We overwrite these mappings with KERNEL attribute later in the boot. Just being paranoid here as there is no need for USER bit to be set. If this breaks something(don't know the history), then we can simply drop this change. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: arjan@linux.intel.com Cc: venkatesh.pallipadi@intel.com Cc: jeremy@goop.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10x86, cpa: rename PTE attribute macros for kernel direct mapping in early bootSuresh Siddha
2008-10-10Merge phase #1 of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip This merges phase 1 of the x86 tree, which is a collection of branches: x86/alternatives, x86/cleanups, x86/commandline, x86/crashdump, x86/debug, x86/defconfig, x86/doc, x86/exports, x86/fpu, x86/gart, x86/idle, x86/mm, x86/mtrr, x86/nmi-watchdog, x86/oprofile, x86/paravirt, x86/reboot, x86/sparse-fixes, x86/tsc, x86/urgent and x86/vmalloc and as Ingo says: "these are the easiest, purely independent x86 topics with no conflicts, in one nice Octopus merge". * 'x86-v28-for-linus-phase1' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (147 commits) x86: mtrr_cleanup: treat WRPROT as UNCACHEABLE x86: mtrr_cleanup: first 1M may be covered in var mtrrs x86: mtrr_cleanup: print out correct type v2 x86: trivial printk fix in efi.c x86, debug: mtrr_cleanup print out var mtrr before change it x86: mtrr_cleanup try gran_size to less than 1M, v3 x86: mtrr_cleanup try gran_size to less than 1M, cleanup x86: change MTRR_SANITIZER to def_bool y x86, debug printouts: IOMMU setup failures should not be KERN_ERR x86: export set_memory_ro and set_memory_rw x86: mtrr_cleanup try gran_size to less than 1M x86: mtrr_cleanup prepare to make gran_size to less 1M x86: mtrr_cleanup safe to get more spare regs now x86_64: be less annoying on boot, v2 x86: mtrr_cleanup hole size should be less than half of chunk_size, v2 x86: add mtrr_cleanup_debug command line x86: mtrr_cleanup optimization, v2 x86: don't need to go to chunksize to 4G x86_64: be less annoying on boot x86, olpc: fix endian bug in openfirmware workaround ...
2008-10-10PnP: move pnpacpi/pnpbios_init to after PCI initLinus Torvalds
We already did that a long time ago for pnp_system_init, but pnpacpi_init and pnpbios_init remained as subsys_initcalls, and get linked into the kernel before the arch-specific routines that finalize the PCI resources (pci_subsys_init). This means that the PnP routines would either register their resources before the PCI layer could, or would be unable to check whether a PCI resource had already been registered. Both are problematic. I wanted to do this before 2.6.27, but every time we change something like this, something breaks. That said, _every_ single time we trust some firmware (like PnP tables) more than we trust the hardware itself (like PCI probing), the problems have been worse. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10Merge branch 'upstream-2.6.28' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDs libata-eh: clear UNIT ATTENTION after reset ata_piix: add Hercules EC-900 mini-notebook to ich_laptop short cable list libata: reorder ata_device to remove 8 bytes of padding on 64 bits [libata] pata_bf54x: Add proper PM operation pata_sil680: convert CONFIG_PPC_MERGE to CONFIG_PPC libata: Implement disk shock protection support [libata] Introduce ata_id_has_unload() PATA: RPC now selects HAVE_PATA_PLATFORM for pata platform driver ata_piix: drop merged SCR access and use slave_link instead libata: implement slave_link libata: misc updates to prepare for slave link libata: reimplement link iterator libata: make SCR access ops per-link
2008-10-09Linux 2.6.27v2.6.27Linus Torvalds
2008-10-09Don't allow splice() to files opened with O_APPENDLinus Torvalds
This is debatable, but while we're debating it, let's disallow the combination of splice and an O_APPEND destination. It's not entirely clear what the semantics of O_APPEND should be, and POSIX apparently expects pwrite() to ignore O_APPEND, for example. So we could make up any semantics we want, including the old ones. But Miklos convinced me that we should at least give it some thought, and that accepting writes at arbitrary offsets is wrong at least for IS_APPEND() files (which always have O_APPEND set, even if the reverse isn't true: you can obviously have O_APPEND set on a regular file). So disallow O_APPEND entirely for now. I doubt anybody cares, and this way we have one less gray area to worry about. Reported-and-argued-for-by: Miklos Szeredi <miklos@szeredi.hu> Acked-by: Jens Axboe <ens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-09Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (abituguru3) Enable DMI probing feature on Abit AT8 32X hwmon: (abituguru3) Enable reading from AUX3 fan on Abit AT8 32X hwmon: (adt7473) Fix some bogosity in documentation file hwmon: Define sysfs interface for energy consumption register hwmon: (it87) Prevent power-off on Shuttle SN68PT eeepc-laptop: Fix hwmon interface
2008-10-09Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] correct broken links and email addresses
2008-10-09SLOB: fix bogus ksize calculation fixMatt Mackall
This fixes the previous fix, which was completely wrong on closer inspection. This version has been manually tested with a user-space test harness and generates sane values. A nearly identical patch has been boot-tested. The problem arose from changing how kmalloc/kfree handled alignment padding without updating ksize to match. This brings it in sync. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-09[CPUFREQ] correct broken links and email addressesNémeth Márton
Replace the no longer working links and email address in the documentation and in source code. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Dave Jones <davej@redhat.com>
2008-10-09hwmon: (abituguru3) Enable DMI probing feature on Abit AT8 32XAlistair John Strachan
Enable driver checking of the DMI product name (when enabled) on an Abit AT8 32X, instead of falling back to a manual probe. This eliminates false negatives and eventually will help avoid unnecessary bus probes on unsupported mainboards. Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk> Tested-by: Daniel Exner <dex@dragonslave.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09hwmon: (abituguru3) Enable reading from AUX3 fan on Abit AT8 32XAlistair John Strachan
The table for the Abit AT8 32X was incorrectly missing an entry for the sixth ("AUX3") fan. Add this entry, exporting the fan reading to userspace. Closes lm-sensors.org ticket #2339. Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk> Tested-by: Daniel Exner <dex@dragonslave.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09hwmon: (adt7473) Fix some bogosity in documentation fileDarrick J. Wong
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09hwmon: Define sysfs interface for energy consumption registerDarrick J. Wong
Describe the sysfs files that were introduced in the ibmaem driver. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09hwmon: (it87) Prevent power-off on Shuttle SN68PTJean Delvare
On the Shuttle SN68PT, FAN_CTL2 is apparently not connected to a fan, but to something else. One user has reported instant system power-off when changing the PWM2 duty cycle, so we disable it. I use the board name string as the trigger in case the same board is ever used in other systems. This closes lm-sensors ticket #2349: pwmconfig causes a hard poweroff http://www.lm-sensors.org/ticket/2349 Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-09eeepc-laptop: Fix hwmon interfaceCorentin Chary
Creates a name file in the sysfs directory, that is needed for the libsensors library to work. Also rename fan1_pwm to pwm1 and scale its value as needed. This fixes bug #11520: http://bugzilla.kernel.org/show_bug.cgi?id=11520 Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-08Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Sibyte: Register PIO PATA device only for Swarm and Litte Sur
2008-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: tcp: Fix tcp_hybla zero congestion window growth with small rho and large cwnd. net: Fix netdev_run_todo dead-lock tcp: Fix possible double-ack w/ user dma net: only invoke dev->change_rx_flags when device is UP netrom: Fix sock_orphan() use in nr_release ax25: Quick fix for making sure unaccepted sockets get destroyed. Revert "ax25: Fix std timer socket destroy handling." [Bluetooth] Add reset quirk for A-Link BlueUSB21 dongle [Bluetooth] Add reset quirk for new Targus and Belkin dongles [Bluetooth] Fix double frees on error paths of btusb and bpa10x drivers
2008-10-08[MIPS] Sibyte: Register PIO PATA device only for Swarm and Litte SurRalf Baechle
Symbol name spaghetti which is too complicated to cleanup on this stage of the release cycle breaks the build on BCM1480 platforms. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-07tcp: Fix tcp_hybla zero congestion window growth with small rho and large cwnd.Daniele Lacamera
Because of rounding, in certain conditions, i.e. when in congestion avoidance state rho is smaller than 1/128 of the current cwnd, TCP Hybla congestion control starves and the cwnd is kept constant forever. This patch forces an increment by one segment after #send_cwnd calls without increments(newreno behavior). Signed-off-by: Daniele Lacamera <root@danielinux.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07net: Fix netdev_run_todo dead-lockHerbert Xu
Benjamin Thery tracked down a bug that explains many instances of the error unregister_netdevice: waiting for %s to become free. Usage count = %d It turns out that netdev_run_todo can dead-lock with itself if a second instance of it is run in a thread that will then free a reference to the device waited on by the first instance. The problem is really quite silly. We were trying to create parallelism where none was required. As netdev_run_todo always follows a RTNL section, and that todo tasks can only be added with the RTNL held, by definition you should only need to wait for the very ones that you've added and be done with it. There is no need for a second mutex or spinlock. This is exactly what the following patch does. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
2008-10-07tcp: Fix possible double-ack w/ user dmaAli Saidi
From: Ali Saidi <saidi@engin.umich.edu> When TCP receive copy offload is enabled it's possible that tcp_rcv_established() will cause two acks to be sent for a single packet. In the case that a tcp_dma_early_copy() is successful, copied_early is set to true which causes tcp_cleanup_rbuf() to be called early which can send an ack. Further along in tcp_rcv_established(), __tcp_ack_snd_check() is called and will schedule a delayed ACK. If no packets are processed before the delayed ack timer expires the packet will be acked twice. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07net: only invoke dev->change_rx_flags when device is UPPatrick McHardy
Jesper Dangaard Brouer <hawk@comx.dk> reported a bug when setting a VLAN device down that is in promiscous mode: When the VLAN device is set down, the promiscous count on the real device is decremented by one by vlan_dev_stop(). When removing the promiscous flag from the VLAN device afterwards, the promiscous count on the real device is decremented a second time by the vlan_change_rx_flags() callback. The root cause for this is that the ->change_rx_flags() callback is invoked while the device is down. The synchronization is meant to mirror the behaviour of the ->set_rx_mode callbacks, meaning the ->open function is responsible for doing a full sync on open, the ->close() function is responsible for doing full cleanup on ->stop() and ->change_rx_flags() is meant to do incremental changes while the device is UP. Only invoke ->change_rx_flags() while the device is UP to provide the intended behaviour. Tested-by: Jesper Dangaard Brouer <jdb@comx.dk> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07SLOB: fix bogus ksize calculationMatt Mackall
SLOB's ksize calculation was braindamaged and generally harmlessly underreported the allocation size. But for very small buffers, it could in fact overreport them, leading code depending on krealloc to overrun the allocation and trample other data. Signed-off-by: Matt Mackall <mpm@selenic.com> Tested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-07Revert "V4L/DVB (8904): cx88: add missing unlock_kernel"Linus Torvalds
This reverts commit 135aedc38e812b922aa56096f36a3d72ffbcf2fb, as requested by Hans Verkuil. It was a patch for 2.6.28 where the BKL was pushed down from v4l core to the drivers, not for 2.6.27! Requested-by: Hans Verkuil <hverkuil@xs4all.nl> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06Linux 2.6.27-rc9v2.6.27-rc9Linus Torvalds
2008-10-06Marker depmod fix core kernel listMathieu Desnoyers
* Theodore Ts'o (tytso@mit.edu) wrote: > > I've been playing with adding some markers into ext4 to see if they > could be useful in solving some problems along with Systemtap. It > appears, though, that as of 2.6.27-rc8, markers defined in code which is > compiled directly into the kernel (i.e., not as modules) don't show up > in Module.markers: > > kvm_trace_entryexit arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_entryexit arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > > (Note the lack of any of the kernel_sched_* markers, and the markers I > added for ext4_* and jbd2_* are missing as wel.) > > Systemtap apparently depends on in-kernel trace_mark being recorded in > Module.markers, and apparently it's been claimed that it used to be > there. Is this a bug in systemtap, or in how Module.markers is getting > built? And is there a file that contains the equivalent information > for markers located in non-modules code? I think the problem comes from "markers: fix duplicate modpost entry" (commit d35cb360c29956510b2fe1a953bd4968536f7216) Especially : - add_marker(mod, marker, fmt); + if (!mod->skip) + add_marker(mod, marker, fmt); } return; fail: Here is a fix that should take care if this problem. Thanks for the bug report! Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Tested-by: "Theodore Ts'o" <tytso@mit.edu> CC: Greg KH <greg@kroah.com> CC: David Smith <dsmith@redhat.com> CC: Roland McGrath <roland@redhat.com> CC: Sam Ravnborg <sam@ravnborg.org> CC: Wenji Huang <wenji.huang@oracle.com> CC: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb: call touch_softlockup_watchdog on resume kgdb, x86: Avoid invoking kgdb_nmicallback twice per NMI
2008-10-06Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: gart iommu have direct mapping when agp is present too
2008-10-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide: workaround for bogus gcc warning in ide_sysfs_register_port() ide-cd: Optiarc DVD RW AD-7200A does play audio IDE: Fix platform device registration in Swarm IDE driver (v2) ide-dma: fix ide_build_dmatable() for TRM290 ide-cd: temporary tray close fix
2008-10-06Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] IP27: Fix build errors if CONFIG_MAPPED_KERNEL=y [MIPS] Fix CMP Kconfig configuration and mark as broken.
2008-10-06Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (33 commits) V4L/DVB (9103): em28xx: HVR-900 B3C0 - fix audio clicking issue V4L/DVB (9099): em28xx: Add detection for K-WORLD DVB-T 310U V4L/DVB (9092): gspca: Bad init values for sonixj ov7660. V4L/DVB (9080): gspca: Add a delay after writing to the sonixj sensors. V4L/DVB (9075): gspca: Bad check of returned status in i2c_read() spca561. V4L/DVB (9053): fix buffer overflow in uvc-video V4L/DVB (9043): S5H1420: Fix size of shadow-array to avoid overflow V4L/DVB (9037): Fix support for Hauppauge Nova-S SE V4L/DVB (9029): Fix deadlock in demux code V4L/DVB (8979): sms1xxx: Add new USB product ID for Hauppauge WinTV MiniStick V4L/DVB (8978): sms1xxx: fix product name for Hauppauge WinTV MiniStick V4L/DVB (8967): Use correct XC3028L firmware for AMD ATI TV Wonder 600 V4L/DVB (8963): s2255drv field count fix V4L/DVB (8961): zr36067: Fix RGBR pixel format V4L/DVB (8960): drivers/media/video/cafe_ccic.c needs mm.h V4L/DVB (8958): zr36067: Return proper bytes-per-line value V4L/DVB (8957): zr36067: Restore the default pixel format V4L/DVB (8955): bttv: Prevent NULL pointer dereference in radio_open V4L/DVB (8935): em28xx-cards: Remove duplicate entry (EM2800_BOARD_KWORLD_USB2800) V4L/DVB (8933): gspca: Disable light frquency for zc3xx cs2102 Kokom. ...
2008-10-06atmel-mci: Initialize BLKR before sending data transfer commandHaavard Skinnemoen
The atmel-mci driver sometimes fails data transfers like this: mmcblk0: error -5 transferring data end_request: I/O error, dev mmcblk0, sector 2749769 end_request: I/O error, dev mmcblk0, sector 2749777 It turns out that this might be caused by the BLKR register (which contains the block size and the number of blocks being transfered) being initialized too late. This patch moves the initialization of BLKR so that it contains the correct value before the block transfer command is sent. This error is difficult to reproduce, but if you insert a long delay (mdelay(10) or thereabouts) between the calls to atmci_start_command() and atmci_submit_data(), all transfers seem to fail without this patch, while I haven't seen any failures with this patch. Reported-by: Hein_Tibosch <hein_tibosch@yahoo.es> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06netrom: Fix sock_orphan() use in nr_releaseJarek Poplawski
While debugging another bug it was found that NetRom socks are sometimes seen unorphaned in sk_free(). This patch moves sock_orphan() in nr_release() to the beginning (like in ax25, or rose). Reported-and-tested-by: Bernard Pidoux f6bvp <f6bvp@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06ax25: Quick fix for making sure unaccepted sockets get destroyed.David S. Miller
Since we reverted 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74 ("ax25: Fix std timer socket destroy handling.") we have to put some kind of fix in to cure the issue whereby unaccepted connections do not get destroyed. The approach used here is from Tihomir Heidelberg - 9a4gl Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06Revert "ax25: Fix std timer socket destroy handling."David S. Miller
This reverts commit 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74. It causes all kinds of problems, based upon a report by Bernard (f6bvp) and analysis by Jarek Poplawski. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06kgdb: call touch_softlockup_watchdog on resumeJason Wessel
The softlockup watchdog needs to be touched when resuming the from the kgdb stopped state to avoid the printk that a CPU is stuck if the debugger was active for longer than the softlockup threshold. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-10-06kgdb, x86: Avoid invoking kgdb_nmicallback twice per NMIJan Kiszka
Stress-testing KVM's latest NMI support with kgdbts inside an SMP guest, I came across spurious unhandled NMIs while running the singlestep test. Looking closer at the code path each NMI takes when KGDB is enabled, I noticed that kgdb_nmicallback is called twice per event: One time via DIE_NMI_IPI notification, the second time on DIE_NMI. Removing the first invocation cures the unhandled NMIs here. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
